2009 Jetta TDI - no start, no crank, no noise
blimes69
Canada
C?ID=565846
Hello everyone,
I have noticed my 2009 TDI wagon cranking longer than usual and then when it feels like it is about to start I stop turning the key and it does not start. Sometimes I have to try 3 or 4 times and eventually it will go. After a week of starting like that the car will not crank or make any noise at all when I turn the key. If I do not try and start it for a while I may hear one click that sounds like it is coming from the relay in the front but then if I try again there is no noise from the engine bay at all while turning over. beside what I figure is the fuel system when turning the key to the first position. I have attached an auto-scan and there is an 00927 code that has to do with the Terminal 30 relay in the under hood fuse box. Any thoughts?
I appreciated the help!
Monday,11,December,2023,15:02:10:60169
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: 3VWML81K19M357945   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 4F 52 56 62 72
Address 01: Engine (CBE)       Labels: 03L-906-022-CBE.clb
   Part No SW: 03L 997 030 H    HW: 03L 906 022 J
   Component: R4 2.0l TDI G001AG  9983
   Revision: 12H01---    Serial number: VWX7Z0I424L0JC
   Coding: 0350078
   Shop #: WSC 11361 004 1048576
   VCID: 33330FE0F73BD802E21-8066
   VINID: 0E69DD70805B04974314724414FB388CC3
008213 - Intake Manifold Flap Position Sensor (Bank 1)
               P2015 - 000 - Implausible Signal - MIL ON
                    Fault Status: 11100000
                    Fault Frequency: 35
                    Mileage: 130481 km
                    Time: 14:07:27
                    Voltage: 12.54 V
                    Lambda: -11.0 %
                    Lambda: 4.7 %
                    Bin. Bits: 00001110
                    Voltage: 3.800 V
Readiness: 1 1 0 0 0
   Part No SW: 02E 300 052     HW: 02E 927 770 AJ
   Component: GSG DSG AG6     440 8938
   Revision: 04844002    Serial number: 00000904091419
   Shop #: WSC 00066 000 00000
   VCID: 51FF65686DE78A12F0D-8004
   Part No SW: 1K0 907 379 CE    HW: 1K0 907 379 AE
   Revision: 00H35001
   Coding: 113B600D49270001881406E8921E0042B100
   Shop #: WSC 25113 002 1048576
   VCID: 77ABFBF0AFC3F4221E9-8022
   Part No SW: 1K0 820 047 JE    HW: 1K0 820 047 JE
   Component: Climatic PQ35   143 1313
   Revision: 00143033    Serial number: 00000000000000
   VCID: 70B9C0ECC6ADA31ADF3-8024
   Part No SW: 3C8 937 049 D    HW: 3C8 937 049 D
   Revision: 00H54000    Serial number: 00000009498982
   Coding: 14898F2340041500070000001C000000000873075C000120000000000000
   VCID: 323D0AE40821D10AE97-8066
   Component: Wischer 020609 021  0501
   Coding: 00038805
00927 - Terminal 30 (Right)
                    Fault Status: 00101011
                    Reset counter: 37
                    Mileage: 132346 km
                    Voltage: 12.30 V
   Part No SW: 1K0 909 605 AD    HW: 1K0 909 605 AD
   Component: 07 AIRBAG VW8R  036 8900
   Revision: 06036000    Serial number: 003EVM00A1PK
   Coding: 0012343
   VCID: 6E85DE94DC99B5EACDF-803A
   Subsystem 1 - Serial number: 6332MSME47130D032
   Subsystem 2 - Serial number: 6342MSME74426D0FN
   Subsystem 3 - Serial number: 6351HSME00250727X
   Subsystem 4 - Serial number: 6361HSME00252708Z
   Subsystem 5 - Serial number: 63727SME1C204874+
   Subsystem 6 - Serial number: 63827SME1C1E487AI
   Part No SW: 1K0 953 549 CP    HW: 1K0 953 549 CP
   Component: J0527           053 0111
   Coding: 0001032
   VCID: 025D9A24F801A18A397-8056
Address 17: Instruments
   Part No SW: 1K0 907 530 T    HW: 1K0 907 951
   Component: J533  Gateway   H06 0071
   Revision:   H06 01    Serial number: 180409F2000342
   Coding: ED807F06000203002002
   VCID: 382938CCEE5D3B5AD73-806C
   Part No SW: 1K0 920 854 D    HW: 1K0 920 854 D
   Component: IMMO            3HL 1222
   Revision: V0002000    Serial number: VWX7Z0I424L0JC
   Shop #: WSC 57104 004 1048576
   VCID: 2C01149C2A0587FAA3B-8078
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1519
   Revision: 72009005    Serial number: 00000764998518
   Coding: 0001205
   VCID: 6FBBC390DB93BCE2C69-803A
01552 - Motor for Central Locking; Drivers Door (V56); Lock
                    Fault Status: 00101100
                    Fault Frequency: 57
                    Reset counter: 27
                    Fault Status: 00111000
                    Fault Frequency: 28
                    Reset counter: 31
00105 - Signal Central Locking SAVE/LOCK Drivers Side
                    Fault Frequency: 200
                    Reset counter: 36
   Part No: 1K0 909 144 E
   Component: EPS_ZFLS Kl. 70     2501
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
            000 - - - MIL ON
                    Battery Volts: 12.2 V
                        PD
                    Temperature: 7.0°C
                    Count: 2
                    Steering Angle: 0.00°
                        SteerAng n.Init
   Part No SW: 1K0 959 433 CA    HW: 1K0 959 433 CA
   Coding: 139007885283281B0904058FB0880F0488FCA0
   VCID: 71BFC5E8CDA7AA12D0D-8024
00332 - Control Circuit for Tank Flap
            007 - Short to Ground
                    Fault Status: 01100111
                    Fault Frequency: 47
                    Reset counter: 252
Address 4F: Centr. Electr. II (J533)       Labels:. 1K0-907-532.clb
   Part No SW: 1K0 907 532     HW: 1K0 907 951
   Coding: 050B0500
   VCID: 6695A6B4F8697DAAB5F-8032
   Subsystem 1 - Part No SW: 8R0 959 591     HW: 8R0 959 591
   Component: J245EE16SKB10  H01 0180
   Subsystem 2 - Part No SW: 8R0 959 591     HW: 8R0 959 591
   Component: J394EE16SKB10  H01 0180
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1519
   Revision: 72009005    Serial number: 08122702515203
   Coding: 0001204
Address 56: Radio        Labels: 1K0-035-1xx-56.clb
   Part No SW: 1K0 035 180 M    HW: 1K0 035 180 M
   Component: Radio DE2       016 0020
   Revision: 00016000    Serial number: VWZ4Z7J3168239
   Coding: 0040401
   VCID: 2A0D128420F199CA517-807E
   Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T
   Component: J388   TUER-SG HL   1401
   Revision: 12006001    Serial number: 00000003957376
   Coding: 0001168
   VCID: 76B5F6F4A4C98D2A05F-8022
Address 72: Door, Rear Right        Labels: None
   Part No SW: 3C0 959 704 C    HW: 3C0 959 794 D
   Component: J389   TUER-SG HR   1509
   Revision: 12008001    Serial number: 00000007145014
   Coding: 0001168
   Shop #: WSC 08224 016 263172
   VCID: 2B0317802F0B80C2AA1-807E
End----(Elapsed Time: 01:30, VBatt start/end: 11.7V/12.1V. VIgn 12.0V)-----
Well, you have an intake flap code for starters... have you looked into that?
Choking the engine would certainly make it harder to start no?
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
That is not going to make any difference in TDI.
To OP,
Did you check do you get 12V at starter while key is in cracking position?
From what I recall, the swirl flaps are supposed to be fully open during "starting", so if they are jammed shut, it could potentially create a very rich starting mixture due to insufficient oxygen during cranking.... not sure how quickly the ECU can adjust starting parameter during cranking when there's no MAF measurements and all those other signals that it typically relies on when adjusting the mixture once it actually fires up and can reply on lambda sensors, GP pressure sensors, MAF\MAP signals, etc.
Obviously, this only applies to the "hard to start" scenario... if it's not cranking, it doesn't matter.
If he's got a weak starter\battery combo, he may not be reaching the required min rpm during cranking, so that could also be a thing....
blimes69
Canada
C?ID=565846
Hey all,
Turns out it was a bad relay in the under hood fuse box.
Cheers.
I have addressed the P2015 code and have the little bolt on attachment to stop if from getting out of position however the light still intermittently comes on. Do you think it would be worth taking the intake manifold apart?
Jetta 97
C?ID=81680
Hey all,
Cheers.
Here is the cheaper fix for that :
blimes69
Canada
C?ID=565846
I have that exact piece installed am still intermittently having the code come on and off…
blimes69
Canada
C?ID=565846
Hello again,
So after replacing the relay '100' in my under hood fuse box with a relay I grabbed from the auto wrecker near my house my car seemed to be fine for several weeks until once again there was the same no start issue as stated before with the same VCDS codes as posted above showing. I once again replaced the relay with a new relay this time and the car immediately started and the "terminal 30" code was gone. Now 3 weeks later I am in the same situation; I have put in a new relay but am getting nothing.
Before I originally replaced the relay the first time I pulled and jumped the starter directly and it seemed to function properly as well. Also this is likely a coincidence but this only has happened while the car is parked at home for the night with temperatures around 0 to -5 degrees C.
So far I have:
Checked all fuses for damage and or excessive heat
Checked wiring for damage or melting
Checked all ground
Replaced ignition switch with one that the wrecker gave me because he thought it could be that if it wasn't the relay as well and felt bad for me owning a VW..
The weird thing to me is that replacing the relay the first two times immediately solved the problem and now I am getting nothing. It obviously seems that something is killing my relays but why am I now getting nothing at all with this new one...
