Resolved 16518 - Oxygen sensor B1 S1 no activity Audi TT
Resolved
Liteace1
Spain
C?ID=90243
Any ideas on this 16518 - Oxygen (Lambda) Sensor B1 S1 P0134 - 35-00 - No Activity
guys, new sensor fitted as before no voltage, now got voltage also maf is doing its thing, all readiness passed, but no lambda,
dont worry about the high resistance code, it needs wiring sorting
Thursday,07,December,2023,13:09:04:39628
VCDS Version: 23.3.1.0 (x64)  HEX-NET CB: 0.4643.4
VIN: TRUZZZ8NZY1075265   License Plate: TF7463CB
Mileage: 231690km-143965mi   Repair Order: TT
Chassis Type: XX (8N - Audi TT (1999 > 2007))
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
VIN: XXXXXXXXXXXXXXXXX   Mileage: 231690km-143965miles
Address 01: Engine        Labels: 06A-906-032-APX.clb
   Part No: 8L0 906 018 M
   Component: 1.8L R4/5VT         0002
   Coding: 05710
   Shop #: WSC 00046
   VCID: 393AD9F321C35E5BCC-5118
17521 - Oxygen (Lambda) Sensor; B1 S1
            P1113 - 35-00 - Internal Resistance too High
Address 03: ABS Brakes        Labels: 8N0-907-379-MK20-E.clb
   Part No: 8N0 907 379 E
   Component: ESP     20    CAN  V004
   Coding: 18446
   Shop #: WSC 01236
   VCID: 3E30CAEF38ED7963F9-4B00
            57-10 - Electric Circuit Failure - Intermittent
Address 08: Auto HVAC        Labels: 8N0-820-043.lbl
   Part No: 8N0 820 043 A
   Component: TT-KLIMAVOLLAUTOMAT D03
   Coding: 00040
   Shop #: WSC 01236
   VCID: 281C0CB7CA69D7D3A3-2580
            30-00 - Open or Short to Plus
            41-00 - Blocked or No Voltage
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
00792 - A/C Pressure Switch (F129)
            31-00 - Open or Short to Ground
Address 15: Airbags        Labels: 8N8-909-601.lbl
   Part No: 8N8 909 601
   Component: Airbag Front+Seite 1005
   Coding: 10102
   Shop #: WSC 01236
   VCID: 77BE1FCB5757882BFA-513C
Address 17: Instruments        Labels: 8Nx-920-xxx-17.lbl
   Part No: 8N1 920 880 H
   Component: KOMBI+WEGFAHRS. M73 D56
   Coding: 00144
   Shop #: WSC 22140
   VCID: 3A38C6FF24C55543C5-4B00
   XXXXXXXXXXXXXXXXX     AUZ5Z0H9025025
Address 22: AWD        Labels: 02D-900-554.lbl
   Part No: 02D 900 554 B
   Component: HALDEX LSC  ECC     0006
   VCID: 1F0E176B9F27106BD2-4B00
Address 35: Centr. Locks        Labels:. 8Nx-962-267.clb
   Part No: 8N7 962 267
   Component: Zentralverrieg.,DWA D04
   Coding: 04698
   Shop #: WSC 22140
   VCID: 7DB20DE3756BA27BA0-4F0C
7 Faults Found:
01366 - Opened Due to Crash Signal
            35-00 - -
01374 - Alarm triggered by Terminal 15
            35-00 - -
01370 - Alarm triggered by Interior Monitoring
            35-00 - -
01616 - Signal Wire to Interior Monitor
            36-10 - Open Circuit - Intermittent
01559 - Drivers Door
            58-10 - Can't Lock - Intermittent
            60-10 - Won't Safe - Intermittent
00849 - S-contact at Ignition/Starter Switch (D)
Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
   Part No: 8N7 951 177
   Component: Innenraumueberw.    D15
   Coding: 00001
   VCID: 7BB603FB6B7FAC4B9E-50D0
Address 55: Headlight Range        Labels: 4B0-907-357-AUT.lbl
   Part No: 4B0 907 357
   Component: LEUCHTWEITEREGLER  D004
   Coding: 00010
   Shop #: WSC 01236
   VCID: 65824583FDFB0ABB58-5160
End----------(Elapsed Time: 02:37, VBatt start/end: 12.3V/12.3V)-----------
Readiness Status: 0000 0000
Exhaust Gas Recirculation: Passed
Oxygen Sensor Heating: Passed
Oxygen Sensor(s): Passed
Air Conditioning: Passed
Secondary Air Injection: Passed
Evaporative Emissions: Passed
Catalyst Heating: Passed
Catalytic Converter(s): Passed
headliner
Chicago, IL, USA
C?ID=18119
I had an issue with some supplier of sensors , had same problem till installed a expensive one
Liteace1
Spain
C?ID=90243
This one is a brand new bosch sensor
TTT
C?ID=547002
With plug or without? I would sort the high resistance code. Note that soldering O2 sensors wiring might cause no activity codes.
headliner
Chicago, IL, USA
C?ID=18119
yeah! or they could unsolder in cat heat enviroment LOL, making more guessing
headliner
Chicago, IL, USA
C?ID=18119
do not trust that much new boxes and fine packaging.
I had most beatuful temp sensor packaging from RA I have ever seen. EMP foil, soft black foam and Iphone box with 4k images. LOL
I changed that hard to do sensor like 3 times after got OEM. This one works till now.
You could swap sensors and read value then. You will get readings.
Yep. There are lots of counterfeit "Bosch" and other OEM parts being produced in Asia by manufacturers who are absolutely shameless about trademark infringement and country-of-origin markings, in countries with governments that either encourage this or simply turn a blind eye to it.
However, I do agree that all relevant wiring and connections should be verified (load tested!) before blaming the sensor.
headliner
Chicago, IL, USA
C?ID=18119
thats very politely and kindly expressed.
dont forget about manufacturers operations "client will cover the cost-CWCTC"
Liteace1
Spain
C?ID=90243
The wiring had been chopped loom side near plug, its now sorted with new plug and connectors but still no activity, the bosch sensor was not a universal, it was x-ref'ed from the original part number and has plug on it
TTT
C?ID=547002
So I would inject additional "fuel" (brake cleaner) or air leak and watch the sensor output at the plug, by back probing the wiring and determine the ability of the sensor to react to such inputs.
vwtech
Verified Coal Cracker
Wilkes-Barre, PA
C?ID=7573
I still say Wiring or O2 sensor.
Good Luck
headliner
Chicago, IL, USA
C?ID=18119
at this kind of scenario: I suggest my daily electrical special, in head scratching sauce
W I R E TRACING
tada
if all good and no work it must be either -"all good" or wire :thumbs:
ECU ------------------- OX connector - continuity test, with little excersise and head bumps
Liteace1
Spain
C?ID=90243
The sensor is showing correct voltage in live data. also I have injected voltage to o2 sig wire using sensor simulator and I can see the o2 voltage changing but live data lambda is stuck at 0.0% ?
headliner
Chicago, IL, USA
C?ID=18119
it might be situation where :
-OK
-Ok
-OK
-Ok
not work,:)
sensor at B1S1 flactuates UP and DOwn~ 600,800+ , 600,800- , normal quiet fast regulating Lambda mixture
B1S2 sensor should stay steady at ~600,800 + to check long trim and "caterpillar" work
if 4 wires set up , 2 are heater and 2 are signal, can be changed for testing.
if not obtained B1S1 = either sensor malfuntion or "caterpillar" malfunction or moved away from gas flow
newer are much more sensitive and have few more wires
you mentioned wiring issue , suggest to correct wiring prior OX2 testing
Larry Manton
C?ID=112505
So O2 is changing voltage but that info is not getting to the ECU, would look hard ad the signal wire to The ECU, and everywhere in between.
Liteace1
Spain
C?ID=90243
"The sensor is showing correct voltage in live data"
when I say "live data" I mean MB's in VCDS, the sig wire must be OK or I would not see voltage change
TTT
C?ID=547002
I am skeptical to use processed data as real data. Did you mention if fuel system is open loop or closed loop and what are the fuel trims doing? Or I missed it?
Liteace1
Spain
C?ID=90243
Happy new year Guys, Im back on this now
Another Bosch sensor fitted from sealed box with hologram security stickers, Ive checked the security code:
13TBVD V9S904 5WXJF2
With the bosch website:
and I get the message:
Congratulations! The Code you entered is correct. The quality verification is carried out in combination with the genuine Bosch Hologram
Ive also bypassed the loom to the sensor and and gone direct to ECU (its a very short distance) and still get the same codes
whats next?
