- Dec 29, 2021
- 27
- 2
- Benton, LA, USA
- C?ID=502699
I pulled fuel pump yesterday, and pump working. when i start the car most the time it will run for a second a couple of minutes it varies. if I can get it to finally to hold an idle, but rough idle about 700 RPM, i can drive a mile two sometime 20 miles before it dies. after it dies normally it will restart and I can go, but lately it dies and takes me about 3 to 4 times to finally get it to shift from or neutral into drive. most times one it restarts it takes some time to be able to shift to drive without it dying.
Saturday,09,December,2023,12:46:14:36168
VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
VIN: WVWAK93C17P059522 License Plate:
Mileage: 324400km-201572mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 37 42 44 46 52 53 56 62 65
72
VIN: WVWAK93C17P059522 Mileage: 324400km-201572miles
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 3C0 907 115 S HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH15--- Serial number: VWZCZ000000000
Coding: 0404010A19070160
Shop #: WSC 25153 444 89132
VCID: 30391FFAE62B870A9F3-8064
VINID: 9E69D16C90D3047800149142088D95AD80
9 Faults Found:
000256 - Mass Air Flow Sensor (G70)
P0100 - 004 - Supply Voltage - MIL ON
Fault Status: 11100100
Mileage: 322605 km
Date: 2023.07.29
Time: 22:21:50
RPM: 761 /min
Load: 21.6 %
Temperature: 84.0°C
Temperature: 37.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.970 V
000022 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
P0016 - 001 - Incorrect Correlation - MIL ON
Fault Status: 11100001
Fault Frequency: 170
Mileage: 322605 km
Date: 2023.07.29
Time: 22:22:06
RPM: 829 /min
Load: 30.2 %
Speed: 4.0 km/h
Temperature: 87.0°C
Temperature: 47.0°C
Voltage: 13.970 V
000833 - Camshaft Position Sensor (G40)
P0341 - 008 - Implausible Signal - MIL ON
Fault Status: 11101000
Fault Frequency: 208
Mileage: 322779 km
Date: 2023.07.31
Time: 01:32:47
RPM: 1082 /min
Load: 18.8 %
Speed: 61.0 km/h
Temperature: 84.0°C
Temperature: 45.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.843 V
000136 - Fuel Rail/System Pressure
P0088 - 001 - Too High - Intermittent
Fault Status: 00100001
Fault Frequency: 31
Mileage: 322781 km
Date: 2023.07.31
Time: 01:34:30
RPM: 466 /min
Load: 24.3 %
Speed: 59.0 km/h
Temperature: 54.0°C
Temperature: 15.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.208 V
004243 - Bank 1; Fuel Measuring System 2
P1093 - 008 - Malfunction - Intermittent
Mileage: 323036 km
Date: 2023.08.04
Time: 03:23:58
RPM: 1337 /min
Load: 20.4 %
Speed: 65.0 km/h
Temperature: 63.0°C
Temperature: 17.0°C
Voltage: 14.478 V
000802 - Engine Speed Sensor (G28)
P0322 - 004 - No Signal - Intermittent
Fault Frequency: 17
Mileage: 323234 km
Date: 2023.08.06
Time: 09:04:28
Temperature: 61.0°C
Temperature: 42.0°C
Voltage: 8.509 V
005668 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 008 - - Intermittent
Mileage: 323312 km
Date: 2023.08.08
Time: 22:19:22
RPM: 1004 /min
Load: 37.6 %
Temperature: 21.0°C
Temperature: 20.0°C
Voltage: 14.224 V
000807 - Knock Sensor 1 (G61)
P0327 - 002 - Signal too Low - Intermittent
Mileage: 323536 km
Date: 2023.08.13
Time: 07:08:42
RPM: 2738 /min
Load: 40.4 %
Speed: 37.0 km/h
Temperature: 69.0°C
Temperature: 18.0°C
Voltage: 14.351 V
012425 - Signal Line for Fuel Pump Electronics
P3089 - 004 - Electrical Malfunction - Intermittent
Mileage: 324401 km
Date: 2023.08.31
Time: 03:54:00
RPM: 1062 /min
Load: 33.3 %
Temperature: 18.0°C
Temperature: 19.0°C
Voltage: 11.557 V
Readiness: 0000 0100
Part No SW: 09G 927 750 HJ HW: 09G 927 750 FP
Component: AQ 250 6F 1068
Revision: 00H38000 Serial number:
Coding: 0000072
VCID: 00598F3A160BD78A2F3-8054
Fault Status: 00101101
Fault Frequency: 28
Reset counter: 201
Mileage: 70147 km
Date: 2010.11.17
Time: 13:59:33
013 - Check DTC Memory
Fault Frequency: 28
Reset counter: 201
Mileage: 70147 km
Date: 2010.11.17
Time: 13:59:33
Address 03: ABS Brakes Labels:. 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 S HW: 3C0 614 095 S
Component: ESP 440 C2 H015 0004
Revision: H015 Serial number: 0667902102
Coding: 0013755
Shop #: WSC 00028 028 00001
VCID: 323D15F2E827B51AE97-8066
Fault Status: 01101101
Reset counter: 19
Mileage: 322605 km
Date: 2023.07.29
Time: 22:22:36
Part No: 1K0 820 047 FQ
Component: Climatic PQ35 120 0606
VCID: 78A9E7DA4EDB9F4A173-802C
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 Q HW: 3C0 937 049 Q
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000006045865
Coding: 14848F0340041A00470000000F00000000285D435C0000
VCID: 372B24E603455032DE9-8062
Subsystem 1 - Part No: 3C1 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer VW461 012 0503
Coding: 00063445
Shop #: WSC 00028
Fault Status: 00101100
Fault Frequency: 52
Reset counter: 114
Mileage: 322779 km
Date: 2023.07.31
Time: 01:32:00
Voltage: 12.00 V
Fault Status: 01101100
Fault Frequency: 83
Reset counter: 74
Mileage: 322606 km
Date: 2023.07.29
Time: 22:49:00
Voltage: 13.75 V
01064 - Terminal 58d; Interior Dimming
Fault Status: 00101010
Reset counter: 106
Mileage: 323974 km
Date: 2023.08.19
Time: 05:23:00
Voltage: 13.80 V
01259 - Fuel Pump Relay (J17)
Fault Status: 00101001
Reset counter: 114
Mileage: 324401 km
Date: 2023.08.31
Time: 03:47:00
Voltage: 12.05 V
00906 - Horn (H1)
Fault Status: 01101001
Reset counter: 74
Mileage: 322605 km
Date: 2023.07.29
Time: 22:22:00
Voltage: 13.70 V
Fault Status: 01101010
Reset counter: 74
Mileage: 322605 km
Date: 2023.07.29
Time: 22:22:00
Voltage: 13.75 V
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 F HW: 8E0 035 593 F
Component: SDAR SIRIUS H03 0120
Revision: 00000000 Serial number: AUZ4Z7F2033037
VCID: 2C010B8ACA03E3EAA3B-8078
Reset counter: 20
Mileage: 322605 km
Date: 2023.07.29
Time: 22:22:46
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 N HW: 3C0 909 605 N
Component: 09 AIRBAG VW8R 030 2522
Revision: 11030000 Serial number: 003B2PFFN2X0
Coding: 0012345
VCID: 313F1AFEED218E0290D-8064
Subsystem 1 - Part No: 3C0 959 339 B
Component: BF-Gewichtsens. 007 0003
Subsystem 2 - Serial number: 0000000003A0CM
Subsystem 3 - Serial number: 0001.01.000000700000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332MSME12535E427ÿ†63
Subsystem 5 - Serial number: 35E427ÿ†6342MSME131C6D60Eÿ†63
Subsystem 6 - Serial number: C6D60Eÿ†6351HTS6K5QA65432ÿ†63
Subsystem 7 - Serial number: A65432ÿ†6361HTS6VARE93J2$ÿ†63
Subsystem 8 - Serial number: E93J2$ÿ†63727TS6QLLMQKA3Mÿ†63
Subsystem 9 - Serial number: MQKA3Mÿ†63827TS6K5QQK863Vÿ
Subsystem 10 - Serial number: QK863Vÿ
01217 - Side Airbag Igniter; Driver Side (N199)
001 - Upper Limit Exceeded - Intermittent - MIL ON
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 H HW: 3C0 953 549 H
Component: J0527 0015
Revision: 00006000 Serial number: 3C5953507R
Coding: 0002013
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 971 A HW: 3C0 920 971 A
Component: KOMBIINSTRUMENT VD1 1614
Revision: X0006000 Serial number: 00000000000000
Coding: 0007205
Shop #: WSC 25153 444 52509
VCID: 2313E0B6A7DD2C92121-8076
00771 - Fuel Level Sensor (G)
Reset counter: 114
Mileage: 324401 km
Date: 2023.08.31
Time: 03:54:10
Address 19: CAN Gateway Labels:. 3C0-907-530-V1.clb
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C06821071C
Coding: 3FFD0E44C31002
VCID: 211FEABEBDC13E8200D-8074
Part No SW: 3C0 959 433 AA HW: 3C0 959 433 AA
Component: IMMO 051 0383
Revision: 00051000 Serial number: VWZCZ000000000
Shop #: WSC 25153 444 11701
VCID: 698FB29E057136C298D-803C
Component: ELV 029 0380
3C0905861J ELV 029 0380
Address 37: Navigation
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1123
Revision: 12007001 Serial number: 00000592568911
Coding: 0001205
VCID: 3B2338D63F6D74523A1-806E
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.135 H07 1806
VCID: 343113EA1233BB2AFBB-8060
Component: KSG PQ46 RDK 051 0218
Coding: 13910F8001862E521004141FF08A0F0E085800
Fault Frequency: 35
Reset counter: 114
Mileage: 324401 km
Date: 2023.08.30
Time: 03:54:42
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1123
Revision: 12007001 Serial number: 00000075568911
Coding: 0001204
VCID: 3C213BCA3A63736A33B-8068
Fault Status: 00100101
Reset counter: 104
Mileage: 322936 km
Date: 2023.08.02
Time: 08:39:41
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0000013
Address 56: Radio Labels:
VCID: 55F78E6EBC0982222C5-FFFE
Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
Component: J388 TUER-SG HL 1113
Revision: 12005001 Serial number: 00000000487998
Coding: 0001168
VCID: 3E2531C22C7F617A1DF-806A
Component: RDK 0420
Coding: 0100101
Reset counter: 20
Mileage: 322620 km
Date: 2023.07.29
Time: 23:05:28
Part No SW: 1K0 959 704 Q HW: 1K0 959 794 J
Component: J389 TUER-SG HR 1113
Revision: 12005001 Serial number: 00000000559617
Coding: 0001168
VCID: 3FDB4CC62B756872169-806A
End----(Elapsed Time: 02:26, VBatt start/end: 14.2V/14.1V. VIgn 0.0V)------
