Hi all,
I hope you are all well?
I've got a vw crafter in with some ABS codes stored. It has had a replacement ABS Pump but the control module was swapped over from the pump. I believe its a second hand pump but apparently the same fault codes. The vehicle has been bought into me to have a look at with the original pump installed.
Just wondering if anyone has come across this problem before?
Regards
Adam
Regards
Adam
Friday,08,December,2023,12:03:42:43516
VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
Dealer/Shop Name: AE Autotechnik
VIN: WV1ZZZ2EZB6014132 License Plate:
Mileage: Repair Order: 12486
Chassis Type: 2E (2E - VW Crafter Panel Van (LT3 / 2006 > 2016))
Scan: 01 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0 A1 A2 A3
B0 B1 B2 B3 B4 B5 B6 C1
Address 01: Engine (CEB) Labels: 076-906-022-CEB.clb
Part No SW: 076 906 022 N HW: 076 906 022 G
Component: R5 2,5L EDC A0A0SG 9021
Revision: 24H38--- Serial number: VWXDZ0J1027930
Coding: 0003032
Shop #: WSC 00001 067 57207
VCID: 1E642E58DCAD4A3A3DF-5160
VINID: 9E606AAAA095A9218004404308238DD840
P0299 - 000 - Control Range Not Reached - Intermittent - MIL ON
Fault Status: 10100000
RPM: 2079 /min
Speed: 42.0 km/h
Load: 78.8 %
Absolute Pres.: 2356.2 mbar
Absolute Pres.: 1162.8 mbar
Lambda: 100.2 %
Lambda: 8.7 %
009571 - Turbocharger Boost Control Position Sensor Circuit
P2563 - 000 - Implausible Signal - Intermittent
RPM: 735 /min
Voltage: 13.38 V
Temperature: -6.0 C
Lambda: 4.7 %
Bin. Bits: 00001110
Voltage: 2.432 V
Readiness: 1 2 0 0 1
Address 91: LT3 Engine Labels: 076-906-022-CEB.clb
Coding: 0003032
VCID: 1E642E58DCBD4A3A3DF-804A
RPM: 2079 /min
Speed: 42.0 km/h
Load: 78.8 %
Lambda: 100.2 %
Lambda: 8.7 %
RPM: 735 /min
Voltage: 13.38 V
Temperature: -6.0 C
Lambda: 4.7 %
Bin. Bits: 00001110
Voltage: 2.432 V
Address 93: LT3 Immo Labels: 2E0-905-865-93.clb
Part No SW: 2E0 905 865 AD HW: 906 545 580 8
Component: IMMO 0805 0815
Revision: 00805000 Serial number: VWXDZ0J1027930
VCID: 6D863994619B61A2F45-8038
01176 - Key
Address 94: LT3 Airbag
Part No HW: 9064461442
Shop #: WSC 00117 555 00000
ASAM Dataset: 3 3332
ROD: CRFT_AB_3_3331.rod (*)
VCID: 55F67174E58BC9622C5-8000
Address 95: LT3 ESP
Part No SW: 9069022800 HW: 0004460153
ASAM Dataset: 3 4101
ROD: CRFT_ESP_3_36946.rod (*)
VCID: 04507C305E9180EA0BB-8050
5731 - ACM: Development monitor E
MIL ON - Test Complete - Active/Stored
5721 - ACM: Development monitor C
5016 - Pressure sensor: Value outside the specified range
MIL ON - Test Complete - Stored
Address 96: LT3 Instruments
Part No SW: 9069026400 HW: 9069012000
ASAM Dataset: 32 787
ROD: CRFT_KOMBI_32_787.rod
9217 - Brakes indicator light: Faulty
Address 99: LT3 Ign. Switch
Part No HW: 9065455808
ASAM Dataset: 67 257
ROD: CRFT_EZS_67_257.rod (*)
9012 - Electronic Steering Column Lock Module (J764): Position is incorrect
900E - ABS Control Module (J104): Emergency opening performed
900D - ABS Control Module (J104): Emergency opening detected
9001 - Voltage: Lower limit not reached
Address 9A: LT3 Central Locks Labels: 2E0-905-865-9A.clb
Component: HF-FFB 0805 0815
Revision: 00805000 Serial number: 12345678901234
00171 - Key 1 not learned
002 - Lower Limit Exceeded
Address 9B: LT3 Driver Door
Part No HW: 9068204126
ASAM Dataset: 33 773
ROD: CRFT_FTUHR_33_773.rod (*)
9023 - Central locking; emergency opening activated: msg from elect. Ign./starter switch
Address B0: LT3 Roof Display
Part No SW: 9069021000 HW: 9069010900
ASAM Dataset: 21 3
ROD: CRFT_DBE_21_3.rod (*)
VCID: 7BA207CC236FFF127A1-802E
909B - Alarm Horn (H12): No communication
9092 - Interior Monitoring Sensor (G273)/ Interior Monitoring Sensor (G592): Comm. error
9096 - Interior Monitoring Sensor 3 (G593): Self-test malfunction
9095 - Interior Monitoring Sensor 2 (G592): Self-test malfunction
9020 - Interior light: Short circuit
Address B1: LT3 Upper Console
Part No HW: 9065450107
ASAM Dataset: 67 3
ROD: CRFT1_OBF_67_3.rod (*)
9036 - Supply voltage: Limit value exceeded
Address B4: LT3 Central Elec.
Part No SW: 9069027500 HW: 9069011500
ASAM Dataset: 33 804
ROD: CRFT_EZE_33_804.rod (*)
VCID: 0654663868ADB2FA15F-8052
9097 - Cent. locking - emerg. unlock activated: Sensor msg. from elect. Ign./start switch
90C2 - Emergency light activated; for rotary light switch evaluation: voltage not correct
90A6 - Fuel level sensor: Short to Plus
90C1 - Emergency light activated; rotary light switch: implausible condition
Address B6: LT3 Steering Wheel
Part No SW: 9064640318 HW: 9064640318
ASAM Dataset: 72 257
ROD: CRFT_SML_72_257.rod (*)
VCID: 094E6D0479B3DD8278D-805C
End----------(Elapsed Time: 01:09, VBatt start/end: 12.4V/12.4V)-----------
