009571 - Turbocharger Boost Control Position Sensor Circuit P2563
jimmyfrack
C?ID=164848
Hi I'm new to the forum and relatively new to the VCDS. I've been using it to prime the fuel lines after changing the fuel filters on both of my TDI's. I've also used it to service the DSG on my mother's golf tdi but I haven't tried to do a lot of diagnostic things with it because the cars are all relatively new. Yesterday my wife had a CEL on her 2010 Jetta TDI with 60,000 miles on it. When I look up the code and google around a little bit I get a turbo actuator issue. VW makes a kit to replace the turbo actuator part number 03L198716A. The car isn't suffering from any kind of limp mode condition or lack of power the only indication that there is any kind of an issue is the CEL. Is there a way to test the actuator with the VCDS? I know I can go to select --> 01 engine --> 08 --> measuring blocks --> choose 11 and graph it but I'm not really sure what I'm looking at or what I'm looking for? Also the bently manual talks about measuring the resistance on the g851 circuit or the voltage coming out of the connector but I can't find in the manual what readings I should be getting from the meter. Below are the results from my auto scan any help would be greatly appreciated.
Wednesday,10,October,2012,21:07:14:18333
VCDS Version: Release 11.11.4 (x64)
Data version: 20120807
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 1C 25 42 44 46 52 56 62 65 72 77
VIN: 3VWAL7AJ7AM052216
   Part No SW: 03L 906 019 CL    HW: 03L 906 022 TS
   Component: R4 2,0L EDC G000SG  7966
   Revision: 12H02---    Serial number:
   Coding: 0050072
   Shop #: WSC 08230 444 83945
   VCID: 77F7D54B068AD9A010F
Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
   Coding: 114B400C492700FC880D02E5921F00423000
   Shop #: WSC 00066 000 00000
   VCID: 7EF9C06FE9B0E8E8539
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 3C8 907 336 N    HW: 3C8 907 336 N
   Component: Climatic      H13 0203
   Revision: 00006001
   Coding: 0000000000
   Shop #: WSC 00066 000 00185
   ASAM Dataset: EV_Climatic A01001
   ROD: EV_Climatic_VW36.rod
   VCID: 38751677831416D8D95
   Part No SW: 5K0 937 085 C    HW: 5K0 937 085 C
   Component: BCM PQ35 B++  008 0019
   Revision: BI008001
   Coding: 6D200B1A902F3EE4800800054000000401000086510085605C8020000000
   VCID: 336F215B9272F580EC7
   Component: Wischer 20100  21  0501
   Coding: 009795
            000 -  -  - Intermittent
                    Reset counter: 7
                    Mileage: 58173 km
                    Date: 2096.14.11
                    Time: 20:09:50
                        Term 15 Off
                    Voltage: 12.15 V
   Part No SW: 1K0 909 605 AD    HW: 1K0 909 605 AD
   Component: 04 AIRBAG VW8R  036 8900
   Revision: 06036000    Serial number: 003EVM01CA3A
   Coding: 0012340
   VCID: 6ED9F02F79D09868C39
   Part No: 1K0 959 339 H
   Component: BF-Gewichtsens. 007 0006
   Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
   Coding: 0000731
   VCID: 76E9D84F0180A0A80B9
   Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H05 0010
   Coding: 00000130
   Part No SW: 5M0 920 970 C    HW: 5M0 920 970 C
   Component: KOMBI         H08 0021
   Revision: V0008011    Serial number:
   Coding: 271F00
   Shop #: WSC 00066 000 00146
   ASAM Dataset: EV_KombiUDSMM9RM10 A04010
   ROD: EV_KombiUDSMM9RM10_VW36.rod
   VCID: 30652E576B64CE98915
13701120 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
                    Reset counter: 41
Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
   Component: J533  Gateway   H07 0081
   Revision:   H07 01    Serial number: 270809F2000343
   Coding: E9807F07001602001002
   VCID: 66C9880F51205028BB9
   Part No SW: 1K5 919 965 D    HW: 1K5 919 965 D
   Component: Kompass         001 0001
   Revision: 00001000    Serial number: 1293324T4FZF05
   Coding: 0000004
   VCID: 3C7D0A677F2C3AF83DD
   Component: IMMO          H08 0021
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01010
   ROD: EV_ImmoUDSMM9RM10_VW36.rod
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1525
   Revision: 72009005    Serial number: 00000876698923
   Coding: 0001205
   VCID: 6FE7ED2B7EDA9160C8F
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 70     2901
   Revision: 00H17000
   Shop #: WSC 02069 000 90108
   VCID: 2F672D2BBE5AD16088F
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Battery Volts: 12.4 V
                        PD
                    Temperature: 30.0°C
                    Count: 2
                    Steering Angle: 0.00°
                        SteerAng n.Init
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1525
   Revision: 72009005    Serial number: 09071109230803
   Coding: 0001204
   VCID: 70E5EE5763E48E98D15
   Part No SW: 1K0 035 180 AC    HW: 1K0 035 180 AC
   Component: Radio Prem-8  H10 0035
   Revision: -----20S    Serial number: VWZ4Z7J3033852
   Coding: 0500040004
   VCID: 61C39B13780E37104EB
   Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T
   Component: J388   TUER-SG HL   1401
   Revision: 12006001    Serial number: 00000004410039
   Coding: 0001168
Address 65: Tire Pressure (J502)       Labels: 1K0-937-08x-65.clb
   Component: RDK           008 0817
   Coding: 018705
02904 - Hard Warning 3
                    Mileage: 39456 km
                    Date: 2023.14.30
                    Time: 07:34:21
                    Text: 3445517757
                    Pressure: 1.90 bar
                    Pressure: 2.40 bar
                    Temperature: 1.2°C
                    Text: 00
                    Speed: 18.0 km/h
   Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T
   Component: J389   TUER-SG HR   1401
   Revision: 12006001    Serial number: 00000004302874
   Coding: 0001168
Address 77: Telephone        Labels: 5P0-862-335.lbl
   Part No SW: 1Z0 035 729 C    HW: 1Z0 035 729 C
   Component: FSE_2P8x        H35 0170
   Revision: 00000000    Serial number: 00000005068440
   Coding: 0011070
   VCID: 387516774B1416D8D95
Monday,18,February,2013,22:11:48:18333
VCDS Version: Release 11.11.5 (x64)
Data version: 20121222
Chassis Type: 1K0
   Coding: 0050072
   VCID: 77F7D54B068AD9A0106
   Revision: 00H45001
   Shop #: WSC 00066 123 12345
   VCID: 7EF9C06FE9B0E8E8530
   Revision: 00006001
   Coding: 0000000000
   VCID: 38751677831416D8D9C
9479441 - Control Circuit for Front Right Seat Heater
          B10A5 11 [008] - Short to Ground
                    Reset counter: 211
                    Mileage: 69595 km
                    Date: 2037.14.01
                    Time: 17:33:33
9479697 - Control Circuit for Front Left Seat Heater
          B10A6 11 [008] - Short to Ground
                    Reset counter: 234
                    Mileage: 67731 km
                    Date: 2036.14.04
                    Time: 08:02:42
   Revision: BI008001
   Coding: 6F200B1A902F3EE4800800054000000401000086510085605C8020000000
   VCID: 336F215B9272F580ECE
   Coding: 009795
                    Reset counter: 239
                    Mileage: 69777 km
                    Date: 2101.14.08
                    Time: 13:19:06
                        Term 15 Off
                    Voltage: 12.15 V
   Coding: 0012340
   VCID: 6ED9F02F79D09868C30
   Coding: 0000731
   VCID: 76E9D84F0180A0A80B0
   Coding: 00000130
   Coding: 271F00
   VCID: 30652E576B64CE9891C
   VCID: 66C9880F51205028BB0
   Coding: 0000004
   VCID: 3C7D0A677F2C3AF83D4
   Coding: 0001205
   VCID: 6FE7ED2B7EDA9160C86
   Revision: 00H17000
   VCID: 2F672D2BBE5AD160886
   Coding: 0001204
   VCID: 70E5EE5763E48E98D1C
   Coding: 0500040004
   VCID: 61C39B13780E37104E2
   Coding: 0001168
   Coding: 018705
   Coding: 0001168
   Coding: 0011070
   VCID: 387516774B1416D8D9C
                    Reset counter: 211
                    Mileage: 69612 km
                    Date: 2101.14.04
                    Time: 07:57:00
Wednesday,23,April,2014,19:55:58:18333
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: 3VWAL7AJ7AM052216   License Plate:
Chassis Type: AJ (1K0)
   Coding: 0050072
   VCID: 77F7D54B068AD9A6AAD-8022
               P2563 - 000 - Implausible Signal - Intermittent - MIL ON
                    Fault Status: 10100000
                    Mileage: 96897 km
                    Date: 2051.14.05
                    Time: 18:51:11
                    RPM: 897 /min
                    Speed: 1.0 km/h
                    Voltage: 13.98 V
                    Temperature: 192.0°C
                    Lambda: -29.2 %
                    Bin. Bits: 00001110
                    Voltage: 1.824 V
Readiness: 1 1 0 0 0
   Revision: 00H45001
   VCID: 7EF9C06FE9B0E8EEE9B-802B
   Revision: 00006001
   Coding: 0000000000
   ROD: EV_ClimaBasis_SE36.rod
   VCID: 38751677831416DE637-806D
   Revision: BI008001
   VCID: 336F215B9272F586565-8066
   Coding: 009795
   Coding: 0012340
   VCID: 6ED9F02F79D0986E79B-803B
   Subsystem 1 - Part No: 1K0 959 339 H
   Subsystem 2 - Serial number: 6332MSME4A044C027
   Subsystem 3 - Serial number: 6342MSME4B114D0BH
   Subsystem 4 - Serial number: 6351HSME1D3725356
   Subsystem 5 - Serial number: 6361HSME1D3F3508G
   Subsystem 6 - Serial number: 63727SME00134730L
   Subsystem 7 - Serial number: 63827SME00216A7B+
   Coding: 0000731
   VCID: 76E9D84F0180A0AEB1B-8023
   Coding: 00000130
   Coding: 271F00
   VCID: 30652E576B64CE9E2B7-8065
   VCID: 66C9880F5120502E01B-8033
   Coding: 0000004
   VCID: 3C7D0A677F2C3AFE87F-8069
   ROD: EV_ImmoUDSMM9RM10_SE36.rod
   Coding: 0001205
   VCID: 6FE7ED2B7EDA916672D-803A
   Revision: 00H17000
   VCID: 2F672D2BBE5AD16632D-807A
   Coding: 0001204
   VCID: 70E5EE5763E48E9E6B7-8025
                    Fault Status: 00101100
                    Reset counter: 68
                    Mileage: 96522 km
                    Date: 2051.14.03
                    Time: 08:54:15
   Coding: 0500040004
   VCID: 61C39B13780E3716F49-8034
   Coding: 0001168
   Coding: 018705
   Coding: 0001168
   Coding: 0011070
   VCID: 387516774B1416DE637-806D
Thursday,24,April,2014,21:43:27:18333
   Coding: 0050072
               P2563 - 000 - Implausible Signal - MIL ON
                    Mileage: 96922 km
                    Date: 2051.14.06
                    Time: 08:01:47
                    RPM: 1035 /min
                    Speed: 1.0 km/h
                    Voltage: 14.21 V
                    Temperature: 294.0°C
                    Lambda: -26.0 %
                    Bin. Bits: 00001110
                    Voltage: 1.748 V
   Revision: 00H45001
   Revision: 00006001
   Coding: 0000000000
   Revision: BI008001
   Coding: 009795
   Coding: 0012340
   Coding: 0000731
   Coding: 00000130
   Coding: 271F00
   Coding: 0000004
   Coding: 0001205
   Revision: 00H17000
   Coding: 0001204
                    Reset counter: 68
                    Mileage: 96522 km
                    Date: 2051.14.03
                    Time: 08:54:15
   Coding: 0500040004
   Coding: 0001168
   Coding: 018705
   Coding: 0001168
   Coding: 0011070
Gone But Not Forgotten
Its possible the WG unit is bad, sticking on, or a wire from waste-gate to ecu is damaged or ecu faulty.
Could even be contaminated with carbon slightly in turbo charger......... causing the rod to stick, and in some cases corroded at pivot point.
I would observe block 011 and look at requested boost by the ecu verse actual. Look for things like the actual being slightly higher than request for a sticky gate.
If it sticks on......it may not be enough to pend a deviation but could be an indication of a problem.
Usually anything over 150/200 MBAR deviation will cause a deviation fault boost fault.
It is possible if the turbo charger is adapted for the linearizer function it may help.
Maybe someone from RT will give advise since I don't see mention in the wiki.
The 2.0L CR TDI should use a G581 Vane Position Sensor (I believe you had a typo in the initial post) and Measuring Block Group # 034.2 and .3 will show you specified and actual positions. Those two fields should mirror each other, very similar to group 011 as Jack suggested.
It looks like Eric's 2009 TDI Jetta had the following values at idle in 034:
828 /min | 100.00% | 99.40% | 94.70%
.. but sticky turbo issues aren't always obvious at idle. You may need to log that while driving and if you do please wrap the log and paste it here (wrapped in code).
Keithuk
Stoke on Trent, England
C?ID=122432
02903 - Hard Warning 2
I've seen these codes recently but Google or Ross Tech Wiki doesn't show any results, what is it referring to?
Why are you asking about TPMS codes in a thread that's about Turbocharger codes?
Keithuk
C?ID=122432
I'm just asking about jimmyfrack's first VCDS log with:
Mileage: 39456 km
Date: 2023.14.30
Time: 07:34:21
Its a Priority: 1 so it must be important. Ross Tech Wiki doesn't show any results.
OK, perhaps I wasn't clear. Stop polluting a thread about an engine fault with generic questions about a TPMS fault. If you wish to discuss TPMS faults, start a different thread.
jimmyfrack
C?ID=164848
finally had some time to look at the car again sorry for the delay
I haven't had a lot of time this week to look at the issue but I managed to find some time tonight and took the car for a drive both before resetting the CEL and after. I drove the car up a pretty steep hill and back down. I monitored group 11 and graphed it and I'm going to post links to the 2 screen captures I took from my laptop. I'm not sure how to monitor Measuring Block Group # 034.2 and .3 but if someone can tell me I can go for another drive again and log it this time and do a screen recording if that's helpful. After I reset the CEL I drove around again up a hill etc. and I couldn't get the light to come back on. The car was at normal operating temperature when I did it, so I'm confused how my wife manages to get the light to turn back on, on her way to work. I'm sure when she gets home from work tomorrow the light will be on again if someone can tell me how to monitor the other 2 blocks I can go ahead and do more tests. I would take the car myself except I have a very short commute to work and it doesn't seem to come on in the 5 minutes I drive to work but my wife drives 50 miles round trip local and highway and it usually turns on somewhere during the local driving.
Driving the car with CEL before resetting it.
Driving car after resetting the CEL
jimmyfrack
C?ID=164848
Are you original owner?
Yes, I bought the car brand new from VW. The history of the car is my wife got into an accident with it front passenger side fender, front passenger wheel, and door. The other 2 things that have been done to the car are they had to do the recall for the intercooler freezing up because I was getting situations where the car wouldn't start when it was very cold outside. The recall for that seemed to fix the issues this last winter we had. The other thing that has happened to the car was the air conditioning system was replaced under warranty because of some issue with the compressor but that was some time ago. Nothing else. Is there some block or something else I should be looking at? Does something look weird?
The reason these don't show a sign of a performance problem is they go into over-speed of the turbo charger typically.
I would say check the wires to the WG control to engine ecu and even run an overlay from ecu to unit.
I have seen the wires get damaged at the location of the plug about 3 inches back from plug due to inadequate strain relief.
If this isn't bad change the WG control on the turbo charger before it over-speeds the turbo to turbo death......
jimmyfrack
C?ID=164848
If I do the procedure below will it be able to verify if the wiring is ok going from the actuator to the ecu?
On a CBEA/CJAA engine, the rod should begin to move around 2*3" and stop moving around 15". To check the sensor, start VCDS and enter the engine module *> 06 Basic Setting*> Adaptation of turbocharger. Select "Positioner for high pressure turbocharger, actual raw voltage" *> Start. The voltage should fluctuate between .65*.85V and 3.3*3.9V.
And is it the wiring from the actuator that's attached to the turbo or the wiring from the n75 to the ecu that I need to check? If its from the n75 where is it when I'm looking at the engine? I have the shop manual but it just shows the break apart. Not that I want to go this route but the car has ~59,500 miles on it is this something that the dealer should cover under the power train warranty?
Both.......
It might be under warranty.......... check your book or with your dealer for sales contract and responsibilities.
jimmyfrack
C?ID=164848
Ok I went to go run the test as described above and I have a few questions. Below is a screen shot of the options I have when it comes to running the basic tests.
I assume the test I want to run is Turbo Charge Boot Control Solenoid Function Test/Adaptation? There isn't any description but I assume the engine should be running and then I just push the on/off/next button and the test will run its course? When the engine was just running the voltage in the far right box read 3.6v of course it wasn't fluctuating or anything and I didn't want to run something I wasn't sure what it was going to do. My mighty vac should come tomorrow so I'll be able to test if the actuator moves freely and if it holds vacuum. I did call vw and of course the turbo will be covered under the drive train but not the n75 and they want 113.00 to do a diagnostic if I'm not going to get the car repaired there. And how do I test the n75 for vacuum? Do I unplug one line at a time and just connect the vacuum pump to it? Sorry for the basic questions but I was very comfotable with my old alh engine and I'm totally lost with the new one.
jimmyfrack
C?ID=164848
Affirmative....that test.
Please get a repair manual and the SSP for your car.
Erwin
https://www.erwin.vw.com
yes.... I'm just trying to fix my car not become a mechanic and at the beginning of the thread I did mention I didn't have a lot of experience with the VCDS so thank you but I ended up just needing the car repaired and I ran out of time and options so I had to take the car to the dealer just to get this thing solved. I got my car back from the dealer today feeling beaten after not finding the vacuum line they were talking about. I couldn't find it in any diagrams or anything and then when I compared the engine to my 2012 wagon I noticed something missing on the newer car. The 2010 that was having both of these codes has the TSB # 21 11 06 / 2025464 fix added to the car. The one vacuum line 1k0-133-902-B that runs under a coolant hose was totally melted... Which explains why the codes and things were so weird, they modified all kinds of stuff to put that kit in http://www.ecstuning.com/ES2099557/
Just thought I would update this thread in case anyone else was having something similar with the TSB applied to their car
Visual inspection will usually bring good results and should always be observed in addition to wiggle tests.
Doesn't take a rocket scientist to do the obvious.
Thank you for sharing the picture.
Did you observe after the new line was installed......... it is routed correct or has anti chafe or Tin foil heat tape to stop it again?
Maybe go do on other car yourself.
Hi James,
Per our phone conversation I added that Implausible Signal description in addition to some notes on this page:
http://wiki.ross-tech.com/wiki/inde...l_Position_Sensor_Circuit:_Implausible_Signal
If you have a picture showing the engine bay after they replaced the hose please post it.
I would be tempted to wrap it in heat tape as Jack mentioned. I don't have any experience with this exact product but 3M makes some nice stuff. http://solutions.3m.com/wps/portal/...um-Foil-Tape-1450?N=3294332405+5471909&rt=rud
