2001 Passat HVAC coding
hans j
Utah
C?ID=60436
Had this car come in from another shop, noticed the control head loose and coding says it's definitely not coded correctly. Out of all my old autoscans, I don't have one that uses the same part number and can't verify the coding.
Tuesday,08,September,2015,17:03:27:05734
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
Dealer/Shop Name: Utah Imports hj
VIN: WVWRH63B41P280188   License Plate:
Mileage: 269060km-167186mi   Repair Order:
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
VIN: WVWRH63B41P280188   Mileage: 269060km-167186miles
Address 01: Engine        Labels: 078-907-551-ATQ.lbl
   Part No: 3B0 907 551 BS
   Component: 2.8L V6/5V      G   0001
   Coding: 07501
   Shop #: WSC 00028
   VCID: F5A2A14ACDD7D096FE-5184
   WVWRH63B41P280188     VWZ7Z0A3593376
16814 - Catalyst System; Bank 2
            P0430 - 35-00 - Efficiency Below Threshold
16804 - Catalyst System; Bank 1
            P0420 - 35-10 - Efficiency Below Threshold - Intermittent
18010 - Power Supply Terminal 30
            P1602 - 35-10 - Voltage too Low - Intermittent
16514 - Oxygen (Lambda) Sensor B1 S1
            P0130 - 35-10 - Malfunction in Circuit - Intermittent
Readiness: 0000 1000
Address 03: ABS Brakes        Labels: 8E0-614-111-ASR.lbl
   Part No: 3B0 614 111
   Component: ABS/ASR 5.3 FRONT   D00
   Coding: 00032
   Shop #: WSC 00028
   VCID: D3E63FD223E3AEA630-5184
   Part No: 3B1 907 044 C
   Component: CLIMATRONIC     C 0.7.0
   Coding: 01000
   Shop #: WSC 00066
   VCID: A10AA51A29DF0C36F2-523C
            30-00 - Open or Short to Plus
00281 - Vehicle Speed Sensor (G68)
            37-10 - Faulty - Intermittent
            37-00 - Faulty
   Part No: 6Q0 909 605 C
   Component: 09 AIRBAG VW6  04   0004
   Coding: 12345
   Shop #: WSC 00028
   VCID: B73E6B42975B62862C-5160
   Part No: 1J0 907 487 B
   Component: Lenkradelektronik   0002
   Coding: 00008
   Shop #: WSC 00028
   VCID: B02C505E7235B5BE6D-5216
Address 17: Instruments        Labels: 3B0-920-xx5-17.lbl
   Part No: 3B0 920 925 B
   Component: KOMBI+WEGFAHRSP VDO V13
   Coding: 07235
   Shop #: WSC 19419
   VCID: A208AA162CD9172EEB-5160
01176 - Key
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 00028
   VCID: F0AC905EB2B5F5BE2D-5160
Address 36: Seat Mem. Drvr        Labels: 3B1-959-760.lbl
   Part No: 3B1 959 760 D
   Component: Sitzverstellung     0101
   VCID: AE104E263801A34E7F-5160
01008 - Note; Emergency OFF Switch is Active!
            000 -  -  - Intermittent
   Part No: 1C0 959 799 C
   Component: 09 Komfortgerát HLO 0001
   Coding: 00258
   Shop #: WSC 00028
   VCID: B73E6B42975B62862C-4B3C
   Subsystem 1 - Part No: 1C0959801
   Component: 09 Tõrsteuer.FS     0001
   Subsystem 2 - Part No: 1C0959802A
   Component: 09 Tõrsteuer.BF     0001
   Subsystem 3 - Part No: 1C0959811
   Component: 09 Tõrsteuer.HL     0001
   Subsystem 4 - Part No: 1C0959812
   Component: 09 Tõrsteuer.HR     0001
11 Faults Found:
00849 - S-contact at Ignition/Starter Switch (D)
            25-10 - Unknown Switch Condition - Intermittent
            54-10 - Incorrectly Equipped - Intermittent
            37-00 - Faulty
00913 - Window Regulator Switch; Front Right Driver (E81)
01035 - Electric Window Thermal Protection Active; Passenger
            35-10 -  -  - Intermittent
End-------------------------(Elapsed Time: 06:44)--------------------------
The A/C has a shut off code for no engine speed signal, but no fault in Engine for engine speed. So I'm wondering if the coding is way off (even when I change it to what I think it should be it still doesn't work).
Can anyone suggest the proper coding for this VIN and part number?
dubTECH
Northern ireland
C?ID=104757
is it possible it's the speed signal wire into the rear of the hvac unit, maybe high resistance/open circuit? I saw this same issue before on a SEAT ibiza.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Even with an incorrect coding of that module, you shouldn't have any electrical issues with the flaps.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Try coding to 17200. In the label file you'll see a reference to that being a W8-specific coding, but I can tell you my 2004 GLX with ATQ V6 was coded that way from the factory and works fine. If that doesn't work, you could try 15200.
Ignore the faulty positioning motor DTCs for the moment. The Climatronic control head in this car is notorious for declaring flap control motors faulty when they're still working okay. I think my old Passat has declared three separate flap motors faulty and the whole system works just fine. You also don't mention if anyone tried the flap position adaptation, which could also explain the faulty code. That's absolutely necessary after swapping control heads, especially a used one.
Recode, clear faults in 08 and 19, perform flap position adaptation so it's matched to this car, and then re-check behavior and fault codes.
Jason
NostraJackAss
Regardless of coding issues here, there is clear swing in voltages; based on the scan which need to be addressed ASAP.
Check connections to battery, and alternator for proper output............
hans j
Utah
C?ID=60436
Thanks for the ideas! CAN gateway keeps coming up with a had fault for no communication with HVAC and block 125 in any CAN connected module doesn't include HVAC. Since the car came in with the HVAC control head loose and no identifying part number (sticker pulled off) on the module, I've warned the customer that there is more to look at and I'm not doing it for free.
I've tried all the coding options and no change. I could only find 17200 referenced in all my old autoscans as well.
Battery and alternator are good
I'm never worried about the flap faults or the ambient air temp faults. I've had those many times with no effect to the air conditioning. I got in to the menu of the climatronic and it said the air temp sensor behind the bumper was the issue.
So it could be the speed sensor wire to the HVAC module, but I'm betting the module isn't equipped to take the CAN signal (and I'm betting it gets it's speed signal from the CAN). I'll post back up if they decide on a new HVAC module!
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
I think you may indeed have the wrong HVAC module.
The control head we can see installed in your Auto-Scan (3B1 907 044 C) does NOT share cross-references with the one I looked up in PL24 for this specific vehicle by VIN (3B1 907 044 J). Both show as valid for a "2001" Passat but that's the only year of overlap; -C fits older cars and -J fits newer. Parts shopping for a 2001 Passat sucks because of the mid-model year platform refresh, B5 to B5.5 if you've ever seen those terms. A 2001 can be either.
Suffix -J units are readily available for $cheap on eBay. See if your customer will try one out. I wouldn't be surprised if there are more gremlins hiding; somebody was already in there screwing with it for a reason and you're showing all sorts of other comfort-CAN comms faults. But, it should get you a lot closer.
Jason
hans j
Utah
C?ID=60436
Definitely the wrong module! Parts guy finally looked it up and told the other shop to supply a "J" version. Sure enough it works... Came coded 17200 and would not allow me to change it to 15200 so it's staying 17200. Shut off compressor code stays 0.0 and engine RPM is read just fine. Hard fault also cleared in CAN gateway.
Interesting to note measuring block 80 would not work on the "C" version.
Funny thing is, Chavez Auto Service did an evac/recarge, changed the pressure sensor, swapped the A/C relay, and finally changed the control valve (their words) before bringing it to us.
Oh and the next best thing is after I installed it, the display went blank! Turns out someone used a 2 amp fuse in position 5 (for A/C and other items). Sometimes that tree with all that shade just doesn't make you a good mechanic...
Thanks for the help guys.
Oh and the temp sensor fault went away and the CAN for HVAC is located in block 132! It was 0 with the old module and 1 with the new module.
