At 3am on a 45F degree nite, the computer in my 2015 gas model S flashed a warning "RISK" message that extinguished before I put my reading glasses on.
Questions (haven't jacked up the car yet): Is there only one heater control pump in a 2015 VW 1.8 gas, model S?
Does this pump warm the heater core more rapidly to provide passenger heat? Is that its only purpose?
Does the pump connector include +, -, and PWM signal? Three leads? Mitchell Wiring doesn't include this.
If there is only 1 pump, and it's only purpose is to warm the heater core rapidly, I may not fix it because I live in a warm climate. Nevertheless, I plan to check the circuit with a voltmeter and look for ground faults or shorts.
Please ignore the "15048 - Coolant Fan Control Circuit 1 error". The coolant fan operates via an external signal generator that provides a 50% duty cycle, 100hz PWM signal. Engine temp remains precisely at 210 degrees.
Comments welcome.
Comments welcome.
Chassis Type: AU-VW37 (5Q0)
VIN: 3VW217AU3FM073477 License Plate:
Mileage: 156840km-97455mi Repair Order: 2023-11-23
Address 01: Engine Labels: 06K-907-425-V1.clb
Control Module Part Number: 5GM 906 264 HW: 06K 907 425 B
Component and/or Version: 1.8l R4 TFSI H13 0001
Software Coding: 091A00122424002F0000
Work Shop Code: WSC 48004 001 1048576
ASAM Dataset: EV_ECM18TFS0205GM906264 001001 (VW37)
ROD: EV_ECM18TFS0208V0906264F.rod
VCID: 04519D43AE92594A0BB-8050
P0480 00 [00101000] - Electrical Malfunction
Fault Frequency: 61
Mileage: 155384 km
Date: 2023.09.28
Time: 12:55:44
Engine RPM: 0.00 /min
Coolant temperature: 39 °C
Intake air temperature: 32 °C
Ambient air pressure: 900 mbar
Voltage terminal 30: 11.621 V
Unlearning counter according OBD: 36
Engine: operating status: ES
STATE_LS_SAE[1]: INI
T_AST_SAE: 0 s
MAP_MES_SAE: 90 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
FAC_TPS_1_SAE: 16.015625 %
FUP_H_SAE: 1850.0 kPa
23652 - Heater support pump
P16C7 00 [00100000] - locked
Mileage: 156760 km
Date: 2023.11.19
Time: 06:33:35
Coolant temperature: 104 °C
Intake air temperature: 22 °C
Ambient air pressure: 910 mbar
Voltage terminal 30: 12.558 V
Unlearning counter according OBD: 33
Engine oil temperature: 94.0 °C
ECU_STATE: PWL
RVC_AV: 228.52 °
T_AST_SAE: 551 s
T_ES_DC: 4 min
RVC_SP: 229.00 °
