DPF P2002, P2000
DontKnowWhatImDoing
Derby, UK
HN-2H
new member. ive got 3 audi a3's and they all have dpf fault codes, soot was 35g and ash was 26g on this particular vehicle and no soot in the tailpipe. used dpf cleaner and carried out static regen. reset ash to 1g and car drove fine with no codes. 1 week later lights back on with these codes,
Particulate Trap Bank 1
P2002 00 [11101101] - Efficiency Below Threshold
NOx Catalyst/Trap Bank 1
P2000 00 [01100101] - Efficiency Below Threshold
this has happed on all 3 audi's anyone got the same issues.
Wednesday,22,November,2023,10:51:22:41934
VCDS Version: Release 23.11.0 (x64) Running on Windows 11 x64
                Address 01: Engine       Labels: 04L-907-309-V1.CLB
Control Module Part Number: 04L 906 021 AQ    HW: 04L 907 309 E
  Component and/or Version: R4 1.6l TDI   H22 9229
           Software Coding: 02190012032501092000
            Work Shop Code: WSC 57639 001 1048576
              ASAM Dataset: EV_ECM16TDI01104L906021AQ 002007 (AU37)
                       ROD: EV_ECM16TDI01104L906021AN_VW37.rod
                      VCID: 74BAB2BF6E31134A3BB-8020
19226 - Particulate Trap Bank 1
                    Mileage: 152663 km
                    Date: 2023.11.13
                    Time: 16:43:40
                    Engine RPM: 1792.00 /min
                    Normed load value: 57.6 %
                    Vehicle speed: 63 km/h
                    Coolant temperature: 92 °C
                    Intake air temperature: 93 °C
                    Voltage terminal 30: 12.840 V
                    Exhaust mass flow of low-pressure EGR: calculated: 23.718
                    Differential pressure ratio: low-pressure EGR: 31.3 kg/h
                    Exh.recircul. 2: differential pres.sensor 1 bank 1: adap. value: 854.8 hPa
                    Exhaust recirculat.2: different.press.sens.1 bank 1: raw value: 1054.7 hPa
                    Exh.recircul.valve 1 bank 1: pos.feedback - Actual value: 58.03 %
                    Exhaust recirc.valve 2 bank 1: posit.feedback - Actual value: 47.52 %
8195 - NOx Catalyst/Trap Bank 1
                    Mileage: 152688 km
                    Date: 2023.11.13
                    Time: 17:05:12
                    Engine RPM: 1924.50 /min
                    Normed load value: 44.3 %
                    Vehicle speed: 90 km/h
                    Intake air temperature: 84 °C
                    Voltage terminal 30: 13.320 V
                    Accelerator pedal travel: raw value: 36.84 %
                    Particulate filter output: temp. sensor 1: bank 1: raw value: 241.2 °C
                    O2 sensor 1 bank 1 dwnstrm cat.: raw value: 0.9612
                    Setpoint generation interior torque: 88.8 Nm
                    Throttl.valve adapt. 1 bank 1: posit feedback - Specified value: 81.80 %
                    O2 sens. 1 bank 1 upstrm oxi cat: raw value: 0.9180
Readiness: 1 1 0 0 0
