CB777
Hi - hoping someone can help with this.
Did a mechatronic swap with the exact same replacement down to the part no. (02e 927 770 al) MK6 GTI w/ DSG . It's installed and my flashing spanner wrench is no longer on the dash. I went thru basic settings as described on Ross Tech & it gives me an error on group 062 (Clutch Adaptation). I kept moving through the rest of the steps and go to drive the car, but it will not take off like it used too and it feels like there's no boost / does drive and go thru all gears.
I checked all my hoses / lines and hit the N75 with an Ohm meter (24.5Ohms resistance) also checked waste gate...turbo's about a year old. So i feel like i ruled out the turbo.
When i connect my VAG-COM i see a fault code: 01315? I'm wondering if the mech needs a software update maybe? ANY HELP WOULD BE AWESOME - Ty
also - I hooked up my old mech and checked the coding, then plugged the new one in & it appeared identical - so i changed nothing.
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 37 42 44 46 47 52 55
56 62 72 77
VIN: WVWHD7AJ6BW291000 Mileage: 256820km-159580miles
02-Auto Trans -- Status: Sporadic communication error 1000
Address 01: Engine (CBF) Labels:. 06J-907-115-CBF.clb
Part No SW: 1K0 907 115 AT HW: 1K0 907 115 AK
Component: 2.0l R4/4V TFSI 0040
Revision: E3H25--- Serial number:
Coding: 040301081C070160
Shop #: WSC 34188 067 57207
VCID: 78D1077C0BE6A451FB-802C
VINID: 9E69D850745A1929C22410000096AAF4A3
Readiness: 0110 0101
Part No SW: 02E 300 053 B HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2113
Revision: 51112 Serial number: 00000912160958
VCID: 140953CC374E603177-8040
Part No SW: 1K0 907 379 BG HW: 1K0 907 379 BG
Component: ESP MK60EC1 H31 0106
Revision: 00H31001
Coding: 114B600C492B00FB880B06E492190041B70800
VCID: 78D1077CCBE6A451FB-802C
Reset counter: 120
Mileage: 256823 km
Date: 2018.04.12
Time: 00:00:22
Count: 2
Count: 12
Count: 28672
Count: 8195
Count: 41984
Count: 771
Reset counter: 120
Mileage: 256823 km
Date: 2018.04.12
Time: 00:22:12
Count: 16387
Count: 14
Count: 29184
Count: 16390
Count: 50688
Count: 6912
Fault Status: 00101101
Reset counter: 121
Mileage: 256824 km
Date: 2018.04.12
Time: 01:56:33
Count: 32768
Count: 4608
Count: 8193
Count: 48129
Count: 1
Count: 1023
Part No SW: 5K0 959 434 A HW: 5K0 959 434 A
Component: VWKESSYPQ35GP 085 0802
Revision: 00085000 Serial number: 0144953623 Dataset Number: 5K0116v____ 5K0B
Coding: 030C0C
ASAM Dataset: EV_KESSY_PQ35GP A01018
ROD: EV_KESSY_PQ35GP.rod
VCID: 334BF0509A0087090E-8066
Part No SW: 7N0 907 426 AC HW: 7N0 907 426 AC
Component: AC Manuell H18 0303
Revision: 00013001
Coding: 0000001002
VCID: 75CF0E48D4F4D939E0-8020
Part No SW: 1K0 937 087 L HW: 1K0 937 087 L
Component: BCM PQ35 H 104 0615
Revision: 00104 AF
Coding: 6D180A1A80262AC41088028570000D0440050086474D8DF064802020A040
VCID: 3A55DD74B56A7641CD-806E
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 11031 26 0512
Coding: 009795
Reset counter: 119
Mileage: 256823 km
Date: 2018.04.12
Time: 00:00:22
Voltage: 11.80 V
Term 50 On
01800 - Light Switch (E1)
Reset counter: 120
Mileage: 256825 km
Date: 2018.04.12
Time: 02:00:42
Term 15 Off
Voltage: 12.70 V
Term 50 Off
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 021 0706
Serial number: 003C4R01WNFV Dataset Number: 5K0003v__B_ 0058
Coding: 00003031
ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3957C278B86C7D59C4-806C
Subsystem 1 - Part No SW: 5K0 959 339 HW: 5K0 959 339
Component: BF-Gewichtss. 007 0002
Serial number: ---0000R--0005FA7H00
Serial number: 3572MSME272F615DZZZ1
Serial number: 3582MSME6B21505CZZZ-
Serial number: 3512QSME72020A7CZZZV
Serial number: 3522QSME42070847ZZZO
Serial number: 35527SME73497526ZZZJ
Serial number: 35627SME31717526ZZZ9
Part No SW: 5K0 953 521 BR HW: 5K0 953 569 E
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20110330200912
Coding: 101A140000
ROD: EV_SMLSNGVOLWS.rod
VCID: 7DDF1668ECC48179A8-8028
Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H06 0010
Coding: 830000
Part No SW: 5K6 920 971 C HW: 5K6 920 971 C
Component: KOMBI H20 0420
Coding: 270F01
VCID: 354FCE489474993920-8060
12648704 - Function Restricted due to Missing Message(s)
U1111 00 [00001000] - -
Reset counter: 119
Mileage: 256823 km
Date: 2023.11.20
Time: 00:00:22
Part No SW: 7N0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H37 0614
Revision: H37 Serial number: 020411F1002572
Coding: 350002
VCID: 3041FF5C6316BC1173-8064
Fault Status: 00110100
Reset counter: 119
Mileage: 256823 km
Date: 2018.04.12
Time: 00:00:21
Component: IMMO H20 0420
Coding: 000007
Shop #: WSC 33311 002 1048576
VCID: 6AF52D348D4A06C17D-803E
Part No SW: 5K0 905 861 A HW: 5K0 905 861 A
Component: ELV-PQ35 H20 0230
Revision: 00000000 Serial number: 11000077981003
Coding: 4900000000000000
ROD: EV_ELVMarquMPVW36X.rod
VCID: 2E7DE1247122AAE161-807A
12666368 - Function Restricted due to Missing Message(s)
Reset counter: 119
ELV State: 0A
Information Clamps: 00 00
CoCo State: F0 01
WFS State: 00 1A
Vehicle speed: 655.35 km/h
Voltage: 75
12666369 - Function Restricted due to Missing Message(s)
Reset counter: 119
ELV State: 0A
CoCo State: F0 01
WFS State: 00 1A
Voltage: 75
12666372 - Function Restricted due to Missing Message(s)
Reset counter: 119
ELV State: 0A
CoCo State: F0 01
WFS State: 00 1A
Voltage: 76
Part No SW: 5N0 035 342 D HW: 5N0 035 342 D
Revision: A1001003 Serial number: 7669713777
Coding: 020000
VCID: 2871173C5BC6F4D1AB-807C
Reset counter: 119
Reset counter: 121
Mileage: 256825 km
Date: 2018.04.12
Time: 04:48:45
Part No SW: 1K0 035 274 HW: 1K0 035 274
Component: RNS315-NAR H05 0011
Serial number: VWZAZ2L8438503
Coding: 040500210100000000001000
ASAM Dataset: EV_RNS315VWNARV1UDS A01005
ROD: EV_RNS315VWNARV1UDS.rod
VCID: 61E74A18707C4599AC-8034
Reset counter: 79
Mileage: 256823 km
Date: 2023.11.20
Time: 00:22:14
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2119
Coding: 0001204
VCID: 3147FA58A81CB5197C-8064
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 74 3201
Revision: 00H20000
VCID: 3449F34C570E803117-8060
Part No SW: 5K0 035 456 HW: 5K0 035 456
Component: KonzernAmp 8K H06 0340
Revision: -------- Serial number: BP218109121727 Dataset Number: 1K8050v____ 5K04
ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
ROD: EV_AudioVerst8KanalBNO1_VW12.rod
VCID: 67F354009E583BA962-8032
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Coding: 0001204
VCID: 3245F554AD1A8E0105-8066
Address 55: Headlight Range Labels: 5M0-907-357-V2.clb
Component: AFS-Steuergeraet 0148
Coding: 1446940
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Coding: 00000022
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Coding: 00000022
Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
Component: Tuer-SG 007 2101
Coding: 0001168
Shop #: WSC 01357 011 1012552
VCID: 354FCE485C74993920-8060
Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
Coding: 0001168
VCID: 364DC9444172922129-8062
Part No SW: 5K0 035 730 HW: 5K0 035 730
Component: TELEFON H09 1020
Revision: 1B001001 Serial number: 00007669672602 Dataset Number: 5K0035730 0001
Coding: 0A00000000010100
ASAM Dataset: UHVNA A01009
ROD: UHVNA.rod
VCID: 62E54514757A5E81B5-8036
End-------------------------(Elapsed Time: 02:52)--------------------------
