Lost ABS Coding (MK60EC1)
learden1
C?ID=440229
Hi I’ve lost my coding on ABS unit and steering column module could someone advise please. Many thanks
Tuesday,21,November,2023,06:58:16:02897
VCDS Version: 21.3.0.0  HEX-V2 CB: 0.4615.4
VIN: WVWZZZ1KZCW069910   License Plate:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 56 61 62 72 77
VIN: WVWZZZ1KZCW069910   Mileage: 206510km-128319miles
   Part No SW: 03L 997 557 T    HW: 03L 907 425 C
   Component: R4 1.6l TDI   H43 9982
   Revision: --H43---    Serial number: 00000000000000
   Coding: 08114034032501080000
   ASAM Dataset: EV_ECM16TDI02103L997557T 003003
   ROD: EV_ECM16TDI02103L906023ND.rod
   VCID: 4DC69730FD51AB73345-8018
6082 - Steering Column Control Module
          U0212 00 [037] - No Communications
                    Mileage: 206515 km
                    Date: 2023.11.21
                    Time: 02:44:49
                    Engine RPM: 780.25 /min
                    Normed load value: 47.8 %
                    Coolant temperature: 21 °C
                    Intake air temperature: 9 °C
                    Voltage terminal 30: 11.633 V
                    Driver intention torque-TQI_DRIV_SUB: 0.00 Nm
                    Control Module temperature-TECU: 18 °C
7196 - Function Restriction due to Faults in Other Modules
          U1113 00 [101] - -
                    Mileage: 206515 km
                    Date: 2023.11.21
                    Time: 02:44:49
                    Normed load value: 46.3 %
                    Voltage terminal 30: 11.746 V
                    Engine RPM: 0 /min
                    Accelerator position: normalized-Accelerator position: 0.00 %
                    Battery voltage: 12.5 V
9858 - Sensor for Ambient Air Temperature (G17)
          P0072 00 [037] - Signal too Low
                    Mileage: 206515 km
                    Date: 2023.11.21
                    Time: 02:44:50
                    Engine RPM: 802.75 /min
                    Normed load value: 42.4 %
10446 - Neutral Gear Sensor
          P15A0 00 [037] - Electrical Malfunction
                    Mileage: 206515 km
                    Date: 2023.11.21
                    Time: 02:44:49
                    Engine RPM: 783.00 /min
                    Normed load value: 49.4 %
                    Battery voltage: 12.6 V
                    Neutral position sensor: current transmission angle-ANG_NEUT_GEAR: 20.001 °
                    Neutral position sensor: adapted transmission angle-ANG_NEUT_GEAR_AD_NEUT: -180.000 °
                    Engaged gear: calculated-DRI_MT_BAS: 0
                    Clutch Position Sensor-Starter control: clutch switch: 00000000
                    Starter control: clutch switch-Starter control: interlock switch: 00000000
   Revision: 00H31001
   VCID: 7BA209E813E5D5C3DA1-802E
                    Reset counter: 209
                    Date: 2018.04.13
                    Time: 02:44:47
                    Count: 20992
                    Count: 195
                    Count: 41472
                    Count: 3840
   Part No SW: 7N0 907 426 AM    HW: 7N0 907 426 AM
   Component: AC Manuell    H19 0304
   Revision: 00001015
   Coding: 0000004003
   VCID: 7F5AFDF8077DC9E3F69-802A
13701968 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [Steuergerät im Schalttafeleinsatz - bitte Fehlerspeicher auslesen]
                    Reset counter: 209
                    Mileage: 206515 km
                    Date: 2023.11.21
                    Time: 02:44:47
9481748 - High Pressure Sensor
          B10AE 14 [009] - Open or Short to Ground
                    Reset counter: 209
                    Mileage: 206515 km
                    Date: 2023.11.21
                    Time: 02:44:47
   Part No SW: 1K0 937 084 F    HW: 1K0 937 084 F
   Component: BCM PQ35  B   110 0651
   Revision: 00110 AC
   Coding: 48180A3A8825F1C0400800C0340000E44B510288436D8160648087200041
   VCID: 313EEBC08129EF9330D-8064
   Subsystem 1 - Part No: 5K2 955 119
   Component: Wischer 20071  26  0512
   Coding: 009795
   Component: RLS 190711 05  54  0403
   Coding: 0230AD
00061 - Footwell Lights
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 209
                    Mileage: 206515 km
                    Date: 2018.04.13
                    Time: 02:44:53
                    Voltage: 11.65 V
                        Term 50 On
Address 10: Park/Steer Assist (J446)       Labels:. 3C8-919-475.clb
   Part No SW: 5K0 919 475 E    HW: 5K0 919 475 E
   Component: PARKHILFE 8K  H01 0012
   Revision: --------    Serial number: 12561119501086
   Coding: 008001
   VCID: 3828D6E462533EDB773-806C
                    Reset counter: 209
                    Mileage: 206515 km
                    Date: 2018.04.13
                    Time: 02:44:46
                    Temperature: 0.0°C
   Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
   Component: AirbagVW10    013 0613
   Serial number: 003G5RA86XBX
   Coding: 00003954
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 313EEBC081A9EF9330D-8064
   Serial number: 3572MSME4E372361ZZZX
   Serial number: 3582MSME6B320442ZZZQ
   Serial number: 3512QSME78151E39ZZZ$
   Serial number: 3522QSME56504458ZZZT
   Part No SW: 5K0 953 507 BC    HW: 5K0 953 549 E
   Revision: --------    Serial number:  90440KGK001GH
   Coding: 0000000000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 72BC24CC442F948B897-8026
267264 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Reset counter: 209
                    Mileage: 206515 km
                    Date: 2023.11.21
                    Time: 02:44:47
   Part No SW: 5K0 920 972 A    HW: 5K0 920 972 A
   Coding: 470B01
   VCID: 2E04F0BC9097F06B2DF-807A
9453329 - Outside temperature sensor
          B103F 1A [009] - Resistance Too Low
                    Reset counter: 209
                    Mileage: 206515 km
                    Date: 2023.11.21
                    Time: 02:44:47
   Part No SW: 7N0 907 530 J    HW: 1K0 907 951
   Component: J533  Gateway H43 1620
   Revision:   H43       Serial number: 160711F1001355
   Coding: 350003
   VCID: 372AD5D86F4D31A37E9-8062
   VCID: 6A8C3CAC6CFF5C4B317-803E
   Revision: A1001003    Serial number: 7662539254
   Shop #: WSC 00028 028 00001
   VCID: 290E03A0A9F99753F8D-807C
   Part No SW: 5K0 959 701 B    HW: 5K0 959 701 B
   Component: Tuer-SG         009 2120
   Coding: 0131764
   VCID: 313EEBC08D29EF9330D-8064
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 69     3201
   Revision: 00H20000
   VCID: 3430E2D4723BDABB5BB-8060
   Part No SW: 5K0 959 702 C    HW: 5K0 959 702 C
   Coding: 0132020
   VCID: 3332E1C87735DD83421-8066
Address 56: Radio (J0503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195 G    HW: 3C8 035 195 G
   Component: Radio RCD510  052 0208
   Revision: 00000001    Serial number: VWZ1Z3L6680992
   Coding: 01000400040005
   VCID: 2C00FAB4A60B827B03B-8078
   Component: Batt.regelung H43 1620
   Coding: 030B185A
   VCID: 71BE2BC041A9AF9370D-8024
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900101485
02252 - Generator
                    Reset counter: 209
                    Mileage: 206515 km
                    Date: 2018.04.13
                    Time: 02:45:46
   Coding: 0131216
   Shop #: WSC 01357 011 1012552
   VCID: 3536DFD07941C3B36C5-8060
   Coding: 0131216
   VCID: 3634D8DC6447C8AB65F-8062
   Part No SW: 7P6 035 730 E    HW: 7P6 035 730 E
   Component: TELEFON       H09 2730
   Revision: 1B001001    Serial number: 00007660466909
   Coding: 0A01000000010101
   ASAM Dataset: EV_UHVNA A01015
   ROD: EV_UHVNA_A01_VW25.rod
   VCID: 3430E2D47EBBDABB5BB-8060
9458195 - Control Module for Cellular Telephone
          B1052 13 [000] - Open Circuit
          [Bedieneinheit für Handyvorbereitung (Drei Tasten Module): Unterbrechung]
End----(Elapsed Time: 01:16, VBatt start/end: 11.8V/11.7V. VIgn 11.7V)-----
Boki Ar
Arandjelovac, Serbia
C?ID=57300
RHD, HH, Vac. sensor - YES
TPMS, Diff. lock. - NO
133B200D09280003C81404E590190081310000
iichel
Netherlands, Operation Market Garden
C?ID=284912
might be worthwhile to update your vcds version to 23.11 as well
boki, 14/5 7L6 = 1 ;)
133B200D09280003C81404E590190091310000
learden1
C?ID=440229
Thank you !!
Where did you see it last? ;)
That's only half a joke. What did you do to the car that cause it to lose it? Have you checked your Scans sub-folder for older scans that would have the correct coding?
