2008 A4 B8 reverse light bulb warning
JanBroersma
Poland
C?ID=498477
Hello all,
first post as verified user.
A client of mine has changed his reverse light bulbs for LED, of course this triggers the reverse light bulb warning now.
He states there is really no good room to fit a resistance.
I wondered, whether there might be maybe an option to change the adaptation.
Before is the coding, as found during an earlier autoscan of the central convenience module.
Part No SW: 8K0 907 064 AD HW: 8K0 907 064 AD
Component: BCM2 1.1 H80 0141
Revision: 00002001 Serial number: 0113635253
Coding: 011A0E20003904C5012001
Shop #: WSC 06335 000 00000
VCID: 72BC248D04AB3ADA097-8026
Not familiar whether a long coding helper will guide me in the right direction, my VCDS is on the 23.11 software
Any help, before i call the car in for an appointment would be greatly appreciated.
Westbury, UK
We always ask for a full Auto-Scan to give context on the vehicle configuration.
JanBroersma
Poland
C?ID=498477
Don't know why this would be beneficial for a possible adjustment in the 46 module...., but here you go.
Monday,13,March,2023,09:17:26:16820
VCDS Version: 23.3.0.0 (x64)  HEX-V2 CB: 0.4631.4
Dealer/Shop Name: J. Broersma
VIN: WAUZZZ8K19A109725   License Plate:
Mileage: 347240km-215764mi   Repair Order:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 03 05 07 08 09 0E 0F 10 13 14 15 16 17 19 1B 36 37 3C 42
          46 47 52 53 55 56 5C 62 6C 72 77
VIN: WAUZZZ8K19A109725   Mileage: 347240km-215764miles
5C-Lane Maintain. -- Status: OK 0000
Address 01: Engine (J623-CCWA)       Labels:| 059-907-401-V1.clb
   Part No SW: 8K2 907 401 A    HW: 8K1 907 401 A
   Component: 3.0TDI EDC17  H01 0006
   Revision: 15H01---    CVN: E0126485
   Coding: 0104002C180F0218
   Shop #: WSC 01286 386 08256
   ASAM Dataset: EV_ECM30TDI0118K2907401A 001006
   ROD: EV_ECM30TDI0118K2907401A.rod
   VCID: 2B02F9E9E3812B128A1-807E
   VINID: 9D196AAAA21B0494410091C2142538CAD0
5120 - Oxygen (Lambda) Sensor B1 S1
          P2196 00 [109] - Signal too High (Rich)
                    Mileage: 339472 km
                    Date: 2022.10.17
                    Time: 15:43:36
                    Engine RPM: 1301.00 /min
                    Vehicle speed: 50 km/h
                    Coolant temperature: 54 °C
                    Intake air temperature: 29 °C
                    Voltage terminal 30: 13.940 V
                    Crankshaft speed (RPM): 1301.0 /min
                    Vehicle speed: 50.94 km/h
                    Lambda probe heater activation: 41.88 %
                    LSU r O2 Adap: 0.02264
                    Oxygen signal calibration status-Bits 0-7: 00000000
                    Lambda probe diagnosis-Bits 0-7: 00000000
                    Lambda probe diagnosis-Bits 0-7: 00010000
                    Lambda probe temperature signal: 995.6 mV
5174 - Fuel Pressure Regulation
          P1065 00 [109] - Regulation Discrepancy
                    Mileage: 339588 km
                    Date: 2022.10.21
                    Time: 12:51:13
                    Engine RPM: 1144.50 /min
                    Normed load value: 61.2 %
                    Vehicle speed: 30 km/h
                    Coolant temperature: 43 °C
                    Intake air temperature: 19 °C
                    Voltage terminal 30: 13.700 V
                    Crankshaft speed (RPM): 1144.5 /min
                    Vehicle speed: 30.54 km/h
                    Fuel Pressure Regulator Valve: 18.99 %
                    Fuel high pressure: actual: 556300 hPa
                    Rail pressure regulation: status-Bits 0-7: 00000100
                    Fuel temperature: 23.3 °C
                    Vehicle voltage terminal 30: 13700 mV
   Part No SW: 8K0 907 379 AD    HW: 8K0 907 379 AD
   Component: ESP8 quattro  H04 0060
   Coding: 1B6D00
   Shop #: WSC 06325 000 00000
   VCID: 7BA209A953E17B925A1-802E
   Coding: 070100
   Subsystem 1 - Part No SW: 8T0 959 754 K    HW: 8T0 959 754 K
   Serial number: 0508000037133021
   Component: ELVAUDIB8  H36 0041
   Serial number: 0208000043774014
03285 - Sensor for Contact with Door Handle; Front Left
                    Reset counter: 177
                    Mileage: 339477 km
                    Date: 2022.10.17
                    Time: 15:52:03
03286 - Sensor for Contact with Door Handle; Front Right
                    Fault Frequency: 11
                    Reset counter: 247
                    Mileage: 339477 km
                    Date: 2022.10.17
                    Time: 15:52:03
00193 - Rear Right Door Handle Touch Sensor (G418)
                    Reset counter: 115
                    Mileage: 339477 km
                    Date: 2022.10.17
                    Time: 15:52:03
03283 - Antenna for Access & Start Authorization; Left
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 115
                    Mileage: 339504 km
                    Date: 2022.10.17
                    Time: 16:57:32
                    Fault Status: 00100111
                    Reset counter: 31
                    Mileage: 343364 km
                    Date: 2023.01.01
                    Time: 17:32:00
Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
   Part No SW: 8T0 035 729 P    HW: 4E0 035 729 A
   Component: Interfacebox    H43 5170
   Revision: 00000000    Serial number: 331HO087528070
   Coding: 0000001
   Shop #: WSC 00723 219 105703
   VCID: 46D4A85D54A3F67A75F-8012
   Subsystem 1 - Part No: 8T0 919 609 C
   Component: E0380 BedienteilH08 0100
   Subsystem 2 - Serial number: 00000000132835
   Subsystem 3 - Serial number: 0113.08.080000000100010188ÿ
   Subsystem 4 - Serial number: 010188ÿ
   Part No SW: 8T1 820 043 AC    HW: 8T1 820 043 AC
   Component: KLIMA 3 ZONEN H06 0140
   Revision: C1000000    Serial number: 0112.08.081272
   Coding: 36000000
   Component: BCM1 1.0      H22 0253
   Revision: 05022001    Serial number: 00000000206036
   Coding: 260050914034AF311E01000300001D0D0F9C834800010141000000
   VCID: 3038EE85CA2748CABF3-8064
   Component: WWS 150808  H06 0070
   Serial number: SWFBIE 0005995
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10230596
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
   Component: E1 - LDS  H07 0070
   Serial number: 00000000001908080415
   Part No SW: 8T1 035 110 C    HW: 8T1 035 110 C
   Component: MP3-Changer     H43 0390
   Revision: 00043003    Serial number: AUZ5ZBH8548373
   VCID: 2A0CFCEDE0FB321A717-807E
Address 0F: Digital Radio        Labels: None
   Part No SW: 4E0 910 563 C    HW: 4E0 035 563
   Component: DAB-Tuner       H41 0830
   Revision: 00000001    Serial number: KE1276W7300451
   Coding: 0000001
   VCID: 241012D582DFE46A4BB-8070
   Part No SW: 8K0 919 475 E    HW: 8K0 919 475 A
   Component: PARKHILFE 8K  H06 0020
   Revision: 11001001    Serial number: 52840820608084
   Coding: 300003
   Shop #: WSC 80093 222 69422
   VCID: 3B22C9A91361BB921A1-806E
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 8K0 907 561     HW: 8K0 907 561
   Component: ACC2          H07 0080
   Coding: 0079C0
   VCID: 6FBA2DF917991732E69-803A
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 8K0 907 364     HW: 8K0 907 364
   Component: DAEMPFUNGS-SG H08 0044
   Revision: 00000000    Serial number: 21070801990001
   Coding: 070181
   VCID: 70B82E850AA708CAFF3-8024
00142 - Left Front Dampening Adjustment Valve (N336)
                    Fault Status: 00101100
                    Reset counter: 4
                    Mileage: 343112 km
                    Date: 2022.12.29
                    Time: 14:06:46
                    Bin. Bits: 00000000 10000000
03264 - Functionalty Shut Off
                    Reset counter: 22
                    Mileage: 343112 km
                    Date: 2022.12.29
                    Time: 14:06:46
                    Error Code: 8
00144 - Rear Left Dampening Adjustment Valve (N338)
                    Reset counter: 22
                    Mileage: 346586 km
                    Date: 2023.02.27
                    Time: 07:25:50
   Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
   Component: AirbagVW-AU10 H27 0410
   Serial number: 0038JD1A1A0M   Dataset Number: 8K0909602C  0010
   Coding: 30353434363030303030554A304C384B3053
   VCID: 3C20CAB516EFBCAA13B-8068
   Serial number: 6334MSME35032C4EG
   Serial number: 6344MSME22527878F
   Serial number: 6352QSME4A0024366
   Serial number: 6362QSME6B051814E
   Serial number: 63732SME3500343EV
   Serial number: 63832SME4C003608X
   Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
   Component: Lenks.Modul   H13 0013
   Revision: --------    Serial number: 90304HH20006J
   Coding: 00009E
   VCID: 3E24C0BD0073AEBA3DF-806A
   Component: E221 - MFL  H01 0003
02795 - Steering Wheel Vibration Motor (V331)
                    Fault Status: 00101011
                    Fault Frequency: 13
                    Reset counter: 22
                    Mileage: 339510 km
                    Date: 2022.10.18
                    Time: 04:29:15
   Part No SW: 8K0 920 930 J    HW: 8K0 920 930 J
   Component: KOMBIINSTR.   H16 0224
   Revision: 00100000    Serial number: 9EA68DN88
   Coding: 0F0409007F000008000000
   VCID: 3430E2953E3F74EADBB-8060
   Part No SW: 8T0 907 468 L    HW: 8T0 907 468 L
   Component: GW-BEM 5CAN-M H10 0092
   Revision: FB402044    Serial number: 4400F08726828E
   Coding: 000303
   VCID: 4ACC9C6D4CBB121A917-801E
   Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
   Component: J367-BDM  H04 0150
   Serial number: 18038955050808
   Part No SW: 8K0 907 144 B    HW: 8K0 907 144 B
   Component: DYNAMIKLENK.  H05 0490
   Revision: 50000003    Serial number: --------------
   Coding: 0C0000
   Shop #: WSC 06324 000 00000
   VCID: 2E04F0FDD0135E3AADF-807A
   Part No SW: 8K0 959 760     HW: 8K0 959 760
   Component: MEM-FS        H05 0043
   Revision: AA000000    Serial number: 00001001133097
   Coding: 00581B00000000000000
   VCID: 77AA15996FC95FF23E9-8022
   Part No SW: 4E0 910 888 P    HW: 4E0 919 887 M
   Component: MNS ECE         H51 1060
   Revision: 00000000    Serial number: 333HP087603354
   Shop #: WSC 21599 142 57226
   VCID: 3B22C9A91F61BB921A1-806E
   Part No SW: 8K0 907 566 B    HW: 4L0 907 566 B
   Revision: 00H01000    Serial number: 6PZ 009 014-13
   Coding: 0000101
   VCID: 3634D89D244366FAE5F-8062
02071 - Local Databus
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 231
                    Mileage: 333287 km
                    Date: 2022.07.01
                    Time: 14:58:29
   Part No SW: 8K0 959 793 B    HW: 8K0 959 793
   Component: TSG FA        H10 0170
   Revision:             Serial number: 0000007569388
   Coding: 011C12205E00410001
   VCID: 3FDABDB90779A7B2369-806A
                    Fault Status: 01101100
                    Reset counter: 248
                    Mileage: 339510 km
                    Date: 2022.10.18
                    Time: 04:29:03
                    Reset counter: 3
                    Mileage: 345188 km
                    Date: 2023.02.07
                    Time: 02:57:20
   Subsystem 3 - Part No SW: 8K0 959 591     HW: 8K0 959 591
   Component: J245 PS034  H06 0037
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 115
                    Mileage: 339477 km
                    Date: 2022.10.17
                    Time: 15:52:46
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 115
                    Mileage: 339477 km
                    Date: 2022.10.17
                    Time: 15:53:08
00166 - Access/Start Authorization Switch (E415)
                    Reset counter: 0
                    Mileage: 343881 km
                    Date: 2023.01.12
                    Time: 15:16:37
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASM.clb
   Part No SW: 8T0 035 223 AD    HW: 8T0 035 223 G
   Component: DSP STD       H08 0300
   Revision: S2600000
   Coding: 010101
00418 - Front Right DSP Mid-Bass Speaker (R102)
                    Reset counter: 115
                    Mileage: 339477 km
                    Date: 2022.10.17
                    Time: 16:17:15
                    Voltage: 12.40 V
                    Temperature: 38.0°C
                    Bin. Bits: 00000011
   Part No SW: 8K0 959 792 B    HW: 8K0 959 792
   Component: TSG BF        H10 0170
   Revision:             Serial number: 0000007567664
                    Reset counter: 248
                    Mileage: 339510 km
                    Date: 2022.10.18
                    Time: 04:29:03
   Revision: 00000003    Serial number: 00000000661534
Address 55: Headlight Range        Labels: 8T0-907-357.clb
   Part No SW: 8H0 907 357 A    HW: 8H0 907 357
   VCID: 3038EE85C62748CABF3-8064
   Subsystem 1 - Part No: 8K0 941 329
   Component: AFS-Modul links H01 S001
   Subsystem 2 - Part No: 8K0 941 329
   Component: AFS-Modul rechtsH01 S001
   Part No SW: 4E0 910 541 Q    HW: 4F0 035 541 L
   Component: TUNER EU/US/RDW H42 0620
   Revision: 00000000    Serial number: 336HU087590081
   Coding: 0000001
   VCID: 2E04F0FDDC135E3AADF-807A
Address 5C: Lane Maintain.        Labels: None
   Part No SW: 8K0 907 217 A    HW: 4E0 907 217 C
   Component: J759  LDW           0070
   Revision: 00H07012    Serial number: 20020861600101
   Coding: 0003001
   Part No SW: 8K0 959 795     HW: 8K0 959 795
   Component: TSG HL        H06 0170
   Revision:             Serial number: 0000007626575
   Coding: 010C12204000210001
   VCID: 7F5AFDB947F967B2769-802A
                    Fault Status: 01101000
                    Reset counter: 139
                    Mileage: 339479 km
                    Date: 2022.10.17
                    Time: 16:22:38
   Part No SW: 8T0 907 441 B    HW: 4L0 907 441 A
   Component: J772__Rearview      0070
   Revision: --H12---    Serial number: 525PA8-J8890GK
   Coding: 1021006
   VCID: 372AD59923499FF2FE9-8062
   Part No SW: 8K0 959 794     HW: 8K0 959 795
   Component: TSG HR        H06 0170
   Revision:             Serial number: 0000007625587
   VCID: 7EA400BD40F36EBA7DF-802A
   Part No SW: 4E0 910 336 M    HW: 4E0 862 335
   Component: Handyvorb2      H20 1130
   Revision: 00000000    Serial number: 00000005250260
   Coding: 0010910
   VCID: 2C00FAF5EA0F2C2A83B-8078
End----(Elapsed Time: 02:38, VBatt start/end: 11.6V/11.9V. VIgn 11.8V)-----
Wednesday,15,March,2023,18:10:14:16820
Dealer/Shop Name: J. Broersma Bielawy 135
VIN: WAUZZZ8K19A109725   License Plate: FWS3C01
   Coding: 1B6D00
   Coding: 070100
   Coding: 0000001
   Coding: 36000000
   Coding: 00FD11
   Coding: 025028
   Coding: 0000001
   Coding: 300003
   Coding: 0079C0
   Coding: 070181
   Coding: 00009E
   Coding: 000303
   Coding: 0C0000
   Coding: 0000101
   Subsystem 1 - Part No: 8K0 907 568 B
   Subsystem 2 - Serial number: 6PZ 009 014-33
   Subsystem 3 - Serial number: 5F24.08.0800H010003CD10480ÿ
   Subsystem 4 - Serial number: D10480ÿ
02850 - Control Module 2 for Lane Change Assistance (J770)
            014 - Defective
                    Reset counter: 248
                    Mileage: 347247 km
                    Date: 2023.03.15
                    Time: 17:01:05
                    Reset counter: 248
                    Mileage: 347247 km
                    Date: 2023.03.15
                    Time: 17:05:09
   Revision: S2600000
   Coding: 010101
                    Reset counter: 248
                    Mileage: 347247 km
                    Date: 2023.03.15
                    Time: 17:44:21
                    Voltage: 12.30 V
                    Temperature: 10.0°C
                    Bin. Bits: 00000011
                    Reset counter: 248
                    Mileage: 347247 km
                    Date: 2023.03.15
                    Time: 17:05:09
   Coding: 0000001
   Coding: 0003001
   Coding: 1021006
   Coding: 0010910
End----------(Elapsed Time: 02:15, VBatt start/end: 14.1V/14.1V)-----------
Why do so many people insist on putting incorrect light bulbs in their cars?
On this CCM/BCM2, if it can be done at all, I expect it will be in the upper adaptation channels, probably in the 19x range, but these are no well documented. In other words, I can't tell you how to do it, or even whether it can be done at all.
JanBroersma
Poland
C?ID=498477
Hello Uwe,
The issue is insufficient lighting.
Over here we don't have a lot of street lighting and to be honest this guy almost lives in the forest.
The reverse lights on these cars are just two small 1*5 cm slits and I have to agree with him, that the LED replacements do give more than 50% more light over stock.
Leaves him with the dash warning.
If it concerns license plates, interior lighting etc.. I am also not for LED, but it is what it is, in this case.
Westbury, UK
The parallel resistor need not be close to the bulbs, they can be fitted at a distance where there is some bodywork to act as a heatsink - this may be the best answer to keep the LED bulbs.
Boki Ar
Arandjelovac, Serbia
C?ID=57300
@JanBroersma, test on my A4, before.
[46] -> [SA 16017] - [Adaptation] Ch.181 -> enter value 62463, ignition off 15 sec., no more reverse light warning.
JanBroersma
Poland
C?ID=498477
I will try that, if that doesn't work, I'll put inline resistors somewhere in the wiring.
Boki Ar
C?ID=57300
A4, before.
Also confirmed on Q5:
Address 46, 8K0 907 064 FE, channel 181, adapted from 65535 to 62463; Saturday, 21. October; 2023,16:22:57
   Part No SW: 8K0 907 064 FE    HW: 8K0 907 064 FE
   Component: BCM2 2.0      H10 0602
   Revision: 00002001    Serial number: 0174701608
   Coding: 013A0620208904408420053680000000
   VCID: F8A203A9A2DC9C0AA7B-80AC
JanBroersma
Poland
C?ID=498477
NOT inline, in parallel - you want to add current not reduce voltage.
Yes, I meant somewhere along the wire harness, not in series, I am familiar with that.
Apparently there is not a lot of room to do it near the bulb fitting.
Boki Ar
C?ID=57300
Have you tried adaptation, the post above yours, #10. Working 100%. ;)
JanBroersma
Poland
C?ID=498477
I will contact the guy today and I will let you know if it went through on this particular car. I'll definitely give feedback.
Boki Ar
C?ID=57300
Don't forget the [Security Access] - 16017, first. :cool:
JanBroersma
Poland
C?ID=498477
Got to it today and it worked. No more reverse light warnings.
Many thanks for the help!
