Engine speed
cosmaa1
C?ID=566476
I can't seem to find engine speed in the drop down window. Can someone please tell me how. The path I am using 01eng, measuring values search for speed. I am able to find the load flap data but not engine speed. Thanks
Bruce
Near Philadelphia, PA, USA
Could we have some help please? Year and model to start? Then how about an autoscan so we can know which modules are installed.
cosmaa1
C?ID=566476
Will do. Thanks 2012 Audi A4 B8 GAS TFSI
Maybe you can advise me what may be causing my EPC light to stay on and also triggering the following codes: P034300 Camshaft position circ. high input, P201400 Intake manifold runner position sensor/switch circuit,P201600 Intake manifold position sensor switch low.I pulled off the intake manifold but could not find any overt problems except some missing insulation on the black wire connected to the knock sensor connector. I replaced the fuel injector o rings, cam position sensor, Intake manifold runner position sensor and new NGK spark plugs. Still no good.
Background: In Dec 22 because of EVAP issues I replaced the intake manifold (OEM), purge valve, breather/oil separator, rebuilt fuel injectors, air charge temp sensor, ignition coils, NGK spark plugs and did a manual carbon removal. After that, the car ran great until now.
Any help would be appreciated. I just bought the Ross Tech VCDS software and just starting to learn how to use it.
Monday,20,November,2023,15:50:38:39342
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: WAUFFAFL6CA115987   License Plate:
Mileage: 133000km-82642mi   Repair Order: 1120rev1
                Address 01: Engine       Labels: 06H-907-115-CAB.clb
Control Module Part Number: 8K2 907 115 AG    HW: 8K2 907 115 D
  Component and/or Version: 2.0l R4/4V TF H20 0002
           Software Coding: 0104010A290F0160
            Work Shop Code: WSC 06324 000 00000
              ASAM Dataset: EV_ECM20TFS0118K2907115AG 001002 (AU48)
                       ROD: EV_ECM20TFS0118K2907115AG.rod
                      VCID: 74B1CC9B3E32B54A3BB-8020
5531 - Camshaft Position Sensor (G40)
          P0343 00 [11100101] - Signal too High
                    Mileage: 133004 km
                    Date: 2023.11.20
                    Time: 15:43:01
                    Engine RPM: 683.00 /min
                    Normed load value: 10.2 %
                    Coolant temperature: 97 ∞C
                    Intake air temperature: 50 ∞C
                    Voltage terminal 30: 14.347 V
2980 - Intake Manifold Flap Position Sensor (Bank 1)
          P2016 00 [00100111] - Short to Ground
                    Mileage: 133004 km
                    Date: 2023.11.20
                    Time: 15:44:05
                    Engine RPM: 0.00 /min
                    Coolant temperature: 98 ∞C
                    Intake air temperature: 51 ∞C
                    Voltage terminal 30: 12.839 V
Readiness: 1110 0101
Any advice would be greatly appreciated. I am pretty much at an impasse. Thanks TC
cosmaa1
C?ID=566476
From what I am told there is a there is a parameter that is engine speed which is not the same as RPM. Someone on Audi world forms who is supposed to be an Audi SME told me that he needed that data and load flap values and he would take a look at it. See his message below.
For the load flaps, you need to go to control modules, 01-engine, adv. measuring values, search on load, checkmark the load flap values (actual, specified), search on speed, checkmark engine speed. Checkmark Group UDS. Then you can just look at them manually reving up the engine below/above 3000 rpm
How else would you measure engine speed other than in RPM? :confused:
Well there is a block called engine speed.
There are no "blocks" in your ECU, which uses the newer UDS protocol.
cosmaa1
C?ID=566476
Thanks for your prompt reply Uwe. So my A4 is a 2012 is the new UDS.
I am trying to find our what may be causing my EPC light to stay on and also triggering the following codes: P034300 Camshaft position circ. high input, P201400 Intake manifold runner position sensor/switch circuit,P201600 Intake manifold position sensor switch low.I pulled off the intake manifold but could not find any overt problems except some missing insulation on the black wire connected to the knock sensor connector. I replaced the fuel injector o rings, cam position sensor, Intake manifold runner position sensor and new NGK spark plugs. Still no good.
Zenerdiode
Newcastle, England
C?ID=24330
I can see:
IDE00021,Engine speed,698, /min
IDE00405,Crankshaft speed (RPM),1407.0, /min
IDE00406,Camshaft speed (RPM),350.3, /min
in my car, idling with a very similar engine. OK, the Camshaft speed is half Engine speed; but that Crankshaft speed looks whacky...
@cosmaa1 would you go to:
VCDS > [Applications] > [Controller Channel Map]
* Single Controller Address - enter 01
Check Function-Adaptations, Output-CSV file
[Go] with the engine running. When complete, open the .csv file in Notepad and Copy & Paste here, just like an Auto-Scan.
@Zenerdiode
It looks to me as though VAG has changed the nomenclature associated with IDE00021 from "Engine Speed" to "Engine RPM" at some point. But another possibility is that the ASAM/ROD data for your "very similar engine" is different.
cosmaa1
C?ID=566476
New Castle, I have been there many years ago when Siemens built a Semiconductor there. Had some crazy nightlife there.
Tony
Zenerdiode
Newcastle, England
C?ID=24330
You’re not very far away from the truth there, Tony. Atmel took over the site, they managed to make a few more but unfortunately Wallsend was not an economically viable area for them.
Yep, the Geordie lass is a hardy bird, they can still manage to flutter from bar to bar in subzero temperatures in plumage that barely covers their modesty for a dance around their handbags. :D
cosmaa1
C?ID=566476
So true. Freezing rain coming down sideways, micro mini skirt, halter top and no coat. Barely escaped from a Bar fight one night after a soccer game let out and I don't even watch soccer. Had a lot of fun with the people at the factory. Those were the days.:)
Tony
cosmaa1
C?ID=566476
I can see:
cosmaa1
C?ID=566476
I can see:
cosmaa1
C?ID=566476
Greetings:
Here is the data I pulled. Hope it works.
Tony
I can see:
cosmaa1
C?ID=566476
Can you see if this works? I am using a MAC so not sure. Thanks Tony
;SW:8K2-907-115-AG   HW:8K2-907-115-D ---  Engine
;Component:2.0l R4/4V TF H20 0002, Coding:0104010A290F0160
;EV_ECM20TFS0118K2907115AG,001002,EV_ECM20TFS0118K2907115AG.rod
;Wednesday,22,November,2023,15:28:02:39342
;VCDS Version: Release 23.11.0 (x64)  Data version: 20231027 DS351.0
;VCID: 74B1CC9B3E32B54A3BB-8020
Group,Description,Actual
IDE00011,Vehicle Identification Number (VIN),WAUFFAFL6CA115987,
IDE00019,Voltage terminal 30,14.371, V
IDE00021,Engine RPM,705, /min
IDE00025,Coolant temperature,65, °C
IDE00078,Time since engine start,172, s
IDE00083,Throttle valve position (absolute),12.2, %
IDE00084,Absolute load value,23, %
IDE00085,Normed load value,11.8, %
IDE00086,Accelerator pedal position,14.9, %
IDE00090-ENG188621,selected gear-Bits 0-7,0,
IDE00094,Kick-down status,Not operated,
IDE00094-ENG127320,Kick-down status-Test_Program_Channel 284,167,
IDE00097,OBD - requirements for which this vehicle is designed,OBD + OBD II,
IDE00100,Engine torque,39.4, Nm
IDE00148,Mean injection time,1.535, ms
IDE00151,Oil fill level,60.056, mm
IDE00152,Oil warning threshold,51.008, mm
IDE00155,Ignition timing angle retard cylinder 1,0.0, °
IDE00156,Ignition timing angle retard cylinder 2,0.0, °
IDE00157,Ignition timing angle retard cylinder 3,0.0, °
IDE00158,Ignition timing angle retard cylinder 4,0.0, °
IDE00167,Exhaust temperature 1 bank 1,193.0, °C
IDE00172,A/C compressor torque,0.0, Nm
IDE00173,Cruise Control System: specified speed,0.00, km/h
IDE00178,Camshaft adjustment intake bank 1: specified value,28.000, °
IDE00179,Camshaft adjustment intake bank 1: actual value,28.000, °
IDE00182,Camshaft adaptation intake bank 1: phase position,0.00, °
IDE00187,Coolant temperature at engine start,45.8, °C
IDE00190,Charge air pressure: specified value,380, hPa
IDE00191,Charge air pressure: actual value,994.53, hPa
IDE00194,Coolant temperature at radiator output: specified value,90.0, °C
IDE00196,Engine oil temperature,51.4, °C
IDE00201,High fuel pressure: specified value,4.0000, MPa
IDE00323,Security Access: Number of invalid keys,2,
IDE00347,Air mass: actual value:,3.13, g/s
IDE00348,Intake air temperature,33, °C
IDE00349,Throttle valve position: normed,2.0, %
IDE00354,Engine start: start synchronization,EPM_MODE_OK,
IDE00354-ENG127291,Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE,48,
IDE00355-ENG188621,Cruise Control System (CCS): status-Bits 0-7,44,
IDE00356-ENG188621,Cruise Control System (CCS): switch position-Bits 0-7,129,
IDE00357,Fuel temperature,50.3, °C
IDE00358,Limitation: torque,1000.0, Nm
IDE00360,Limitation: accelerator pedal,0.0, Nm
IDE00371,Fuel consumption,1.55, l/h
IDE00375,Generator: load signal,0.00, %
IDE00380,Coolant fan 1: activation,10.20, %
IDE00381,Coolant fan 2: activation,0.00, %
IDE00392,Accelerator pedal: sensor voltage 1,754.4, mV
IDE00393,Accelerator pedal: sensor voltage 2,379.6, mV
IDE00399,Regulation factor: total,0.0000,
IDE00405,Crankshaft speed (RPM),1397.0, /min
IDE00406,Camshaft RPM,0.0, /min
IDE00407-ENG188621,Rail pressure regulation: status-Bits 0-7,1,
IDE00412-ENG188621,Starter control: terminal 50-Bits 0-7,0,
IDE00413-ENG188621,Starter control: Interlock- or P/N-signal-Bits 0-7,0,
IDE00443-ENG188621,Accelerator pedal: switch positions-Bits 0-7,8,
IDE00451,Currently running routine,0,
IDE00474,Ambient air pressure,99, kPa abs
IDE00477,Torque request: sum of auxiliary aggregate,8.1, Nm
IDE00496-ENG188621,Oil pressure switch valve activation-Bits 0-7,1,
IDE00497-ENG188621,Status of oil pressure switches-Bits 0-7,1,
IDE00541,Acceleration,0.000, m/s²
IDE00556,Outside temperature,16, °C
IDE00558,Voltage of oxygen sensor bank 1 sensor 1 (broadband sensor),1.489, V
IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),0.998 Lambda / -0.020 mA,
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,0.455, V
IDE00582,Specified value of equivalence ratio,1.000, Lambda
IDE00583,Throttle valve specified value,2.7, %
IDE00584,Distance driven since erasing DTC memory,0, km
IDE00589,Fuel pressure,3970, kPa rel
IDE00592,Status of oxygen sensor control,Open loop, conditions for  / closed loop not yet satisfied ,
IDE00593,Ignition timing adjustment cylinder 1,2.0, Degrees
IDE00597,Long term adaptation of mixture formation bank 1,13.3, %
IDE00601,Monitoring status since erasing DTC memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE00603,Number of driving cycles since erasing DTC memory,1,
IDE00604,Short term adaptation of mixture formation bank 1,0.0, %
IDE00612,Target position of EVAP canister valve,0.0, %
IDE00738,Oxygen sensor test: bank 1: delta lambda,0.00000,
IDE00752,Oxygen sensor control test,Test off,
IDE00752-ENG127302,Oxygen sensor control test-Test_Program_Channel 213,235,
IDE00949,Hide cylinder,not active,
IDE00949-ENG127318,Hide cylinder-Test_Program_cylinder 1,0,
IDE00949-ENG127309,Hide cylinder-Test_Program_cylinder 10,0,
IDE00949-ENG127308,Hide cylinder-Test_Program_cylinder 11,0,
IDE00949-ENG127307,Hide cylinder-Test_Program_cylinder 12,0,
IDE00949-ENG127306,Hide cylinder-Test_Program_cylinder 13,0,
IDE00949-ENG127305,Hide cylinder-Test_Program_cylinder 14,0,
IDE00949-ENG127304,Hide cylinder-Test_Program_cylinder 15,0,
IDE00949-ENG127303,Hide cylinder-Test_Program_cylinder 16,0,
IDE00949-ENG127317,Hide cylinder-Test_Program_cylinder 2,0,
IDE00949-ENG127316,Hide cylinder-Test_Program_cylinder 3,0,
IDE00949-ENG127315,Hide cylinder-Test_Program_cylinder 4,0,
IDE00949-ENG127314,Hide cylinder-Test_Program_cylinder 5,0,
IDE00949-ENG127313,Hide cylinder-Test_Program_cylinder 6,0,
IDE00949-ENG127312,Hide cylinder-Test_Program_cylinder 7,0,
IDE00949-ENG127311,Hide cylinder-Test_Program_cylinder 8,0,
IDE00949-ENG127310,Hide cylinder-Test_Program_cylinder 9,0,
IDE01098,Test of knock sensors: short trip result,Test off,
IDE01098-ENG127299,Test of knock sensors: short trip result-Test_Program_Channel 165,235,
IDE01196,Dynamic factor O2 sensors bank 1 or bank 3 before cat. conv.,1.0000,
IDE01236-ENG188621,Coolant recirculation pump-Bits 0-7,0,
IDE01260,Generator performance,593.761, W
IDE01267,Height correction,0.98718,
IDE01405-ENG188621,Starter activation: status-Bits 0-7,2,
IDE01638,Result O2 sensor aging test bank 1 or 3 before cat. conv.,Test off,
IDE01638-ENG127368,Result O2 sensor aging test bank 1 or 3 before cat. conv.-Test_Program_Channel 951,235,
IDE01650,Throttle valve position 2,12, %
IDE01665,Result of test of camshaft adjustment intake bank 1,Test off,
IDE01665-ENG127298,Result of test of camshaft adjustment intake bank 1-Test_Program_Channel 140,235,
IDE01680,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve,Test off,
IDE01680-ENG127300,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve-Test_Program_Channel 195,235,
IDE01683,Valve stroke switch of AVS from small to large,0,
IDE01684,Valve stroke switch of AVS from large to small,0,
IDE01685,Result of test of valve stroke switch AVS,0,
IDE01773,Misfire totalizer,0,
IDE01774,Status misfire recognition,activated,
IDE01774-ENG127319,Status misfire recognition-Test_Program_Channel 232,103,
IDE01869,Long-term fuel trim bank 1 at idle,3.00, %
IDE01870,Oxygen sensor after catalytic converter: operating status,Test off,
IDE01870-ENG127295,Oxygen sensor after catalytic converter: operating status-Test_Program_Channel 113,235,
IDE01872,Result of oxygen sensor aging test after catalytic converter,Test off,
IDE01872-ENG127321,Result of oxygen sensor aging test after catalytic converter-Test_Program_Channel 378,235,
IDE01873,Test of catalytic converter: measured value,1.4500,
IDE01874,Test of catalytic converter: result,Test off,
IDE01874-ENG127322,Test of catalytic converter: result-Test_Program_Channel 486,235,
IDE01875,Required torque adjustment by idling regulator,-0.882, %
IDE01876,Adaptation of loss torque,5.2, Nm
IDE01877-ENG188621,Operating condition of idle speed control-Bits 0-7,0,
IDE01878-ENG159537,Adaptation of throttle valve-Byte,00000100 ,
IDE01879,Adaptation of throttle valve: result,ADP is OK,
IDE01879-ENG127324,Adaptation of throttle valve: result-Test_Program_Channel 698,2,
IDE01880,Accelerator pedal position 2,14.9, %
IDE01881,Adaptation of kick-down shifting point,4125.2, mV
IDE01884,Camshaft adjustment intake bank 1: activation,6.250, %
IDE01885,Shut off of oxygen sensor control,l-Reg.OFF,
IDE01885-ENG127301,Shut off of oxygen sensor control-Test_Program_Channel 212,3,
IDE01888,Cold start enrichment: adaptation area 1,1.000,
IDE01889,Cold start enrichment: adaptation area 2,1.000,
IDE01890,Cold start enrichment: adaptation area 3,1.000,
IDE01891,Cold start enrichment: adaptation area 4,1.000,
IDE01892,Cold start enrichment: adaptation area 5,1.000,
IDE01893,Fuel pump: specified value,47.581, %
IDE01896,Charge pressure control: damping grtr max. threshold adaptation,0.000, %
IDE01897,Charge pressure control: damping lsr min. threshold adaptation,0.000, %
IDE01898,Load value: specified value,160.83, %
IDE01899,Load value: corrected specified value,160.83, %
IDE01900,Charge press. ctrl.: spec. value,1.6, %
IDE01901,Lost torque adaptation: idle,5.2, Nm
IDE01902,Lost torque adaptation A/C compressor,0.3, Nm
IDE01903,Lost torque adaptation driving mode,0.7, Nm
IDE01904,Lost torque adaptation A/C compressor and driving mode,-3.9, Nm
IDE01905,Average of ignition timing angle delay adjustment,0.0, °
IDE01906,Dynamic average of ignition timing angle delay adjustment,0.0, °
IDE01907,Maximum filling correction factor from knock control,1.00000,
IDE01908,Overboost value charge pressure reduction factor,0.99998,
IDE01909,Short term adapt. throttle valve for mass air flow sensor,0.99390,
IDE01910,Long term adaptation of throttle valve for mass air flow sensor,0.97449,
IDE01911,Leakage air,4.6, kg/h
IDE01912,Oxygen sensor B1: sensor 1: specified value,1.0000,
IDE01913,Number of oxygen sensor dynamic tests: bank 1 sensor 1,0,
IDE01914-ENG188621,Oxygen sensor wiring diagnosis: bank 1 sensor 1-Bits 0-7,160,
IDE01916,Leakage recognition from oxygen sensor control,0.9976,
IDE01917,Leakage after throttle valve,0.000,
IDE01918,Leakage before throttle valve,0.000,
IDE01919-ENG188621,Leakage recognition: status-Bits 0-7,209,
IDE01920,Oxygen sensor: mixture correction with active diagnosis,0.0000,
IDE01921-ENG100991,O2 reg: evap. emiss. can. purge reg. valve w/ active diagn.-Rel uw b200 UWORD Chann 295,100.000, %
IDE01921-ENG127296,O2 reg: evap. emiss. can. purge reg. valve w/ active diagn.-Test_Program_Bitregister,0,
IDE01922,Vehicle distance driven,133004, km
IDE01923,Control module distance driven,132426671, m
IDE01924,Load shift flaps: actual value,99.998, %
IDE01925,Load shift flaps: specified value,0.000, %
IDE01926,Adaptation of intake manifold runner flaps,3.799, V
IDE01927,Result of load shift flap adaptation,ERROR,
IDE01927-ENG129325,Result of load shift flap adaptation-Test_Program_Channel 514,90,
IDE01928,Close cam shaft angle at quantity control valve,70.6, °
IDE01929,Open cam shaft angle at quantity control valve,59.3, °
IDE01930,High pressure regulation: adaptation value,-0.2000, MPa
IDE01931,High pressure pump injection volume control deviation,-0.0315, MPa
IDE01932,High pressure pump injection volume,-42.69, mm³
IDE01975,Numb.of misfir.: cylinder 1,10,
IDE01976,Numb.of misfir.: cylinder 2,10,
IDE01977,Numb.of misfir.: cylinder 3,3,
IDE01978,Numb.of misfir.: cylinder 4,1667,
IDE01986,Contact for tank leak test,Reed closed,
IDE01986-ENG130112,Contact for tank leak test-Test_Program_Channel 235,298,
IDE01987,Fuel tank integrity test,Cancel,
IDE01987-ENG130113,Fuel tank integrity test-Test_Program_Channel 236,231,
IDE01988,Tank leak: status,tbd,
IDE01988-ENG130114,Tank leak: status-Test_Program_Channel 237,0,
IDE01989,Tank leak: result,Test off,
IDE01989-ENG130115,Tank leak: result-Test_Program_Channel 238,235,
IDE02115-ENG188621,Requirements for basic setting-Bits 0-7,54,
IDE02116,Exhaust gas temperature before catalytic converter,251.85, °C
IDE02117,Relative load value,20.91, %
IDE02119,Long term adaptation of oxygen sensor control: bank 1,0.0, %
IDE03108,Result of test of oxygen sensors bank 1,Test off,
IDE03108-ENG127369,Result of test of oxygen sensors bank 1-Test_Program_Channel 976,235,
IDE03692-ENG188621,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bits 0-7,136,
IDE03693-ENG188621,Monitoring status of additional Onboard Diagnosis-Bits 0-7,171,
IDE03711,Mass flow through throttle valve,11.3, kg/h
IDE03806-ENG188621,Oxygen sensor bank 1 sensor 1: status-Bits 0-7,0,
IDE03807-ENG188621,O2 Sensor B1-S2: Status-Bits 0-7,0,
IDE03818-ENG99405,Heated oxygen sensor bank 1: sensor 2: resistance-R uw q2 UWORD Chann 120,0.000, Ohm
IDE03818-ENG127296,Heated oxygen sensor bank 1: sensor 2: resistance-Test_Program_Bitregister,0,
IDE03819,Heated oxygen sensor bank 1: sensor 2: activation,Htg.aC.OFF,
IDE03819-ENG127297,Heated oxygen sensor bank 1: sensor 2: activation-Test_Program_Channel 123,217,
IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,900.00, Ohm
IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,1.627, %
IDE03836,Result of O2 sensor aging test bank 1 after cat. conv.,Test off,
IDE03836-ENG129323,Result of O2 sensor aging test bank 1 after cat. conv.-Test_Program_Channel 2114,235,
MAS00043,Terminal 30 power supply,14440, mV
ENG105021-ENG188621,AC compressor shut-off status-Bits 0-7,0,
ENG105037,Acc Ped trq Des,-42.6, Nm
ENG105038,Acc Ped trq Des Pull,0.0, Nm
ENG105194,Accelerator position,0.00, %
ENG105042,ACCI a Des,0.000, m/s²
ENG105043,ACCI phi Road,0.0098, rad
ENG105044,ACCI r Brk Des,0.00, %
ENG105045-ENG188621,ACCI st ACC-Bits 0-7,6,
ENG105047-ENG188621,ACCI st Brk Err mp-Bits 0-7,0,
ENG105048-ENG188621,ACCI st Sens Err mp-Bits 0-7,0,
ENG105049-ENG188621,ACCI st State-Bits 0-7,0,
ENG105050,ACCI trq Brk,0.0, Nm
ENG105054,Act Mod trq Clth,-0.7, Nm
ENG105091,Afmim n,99.6, %
ENG105092,Afmim x,0.0, %
ENG105093,Afnmn,10200, /min
ENG105094,Afnmx,0, /min
ENG105095,AFS dm,11.1, kg/h
ENG105113,Air C p Clnt,0, hPa
ENG105116-ENG188621,Air C st Swt Raw-Bits 0-7,1,
ENG105117,Air C trq Cmpr Max,25.0, Nm
ENG105114,Air conditioner fan activation,0.00, %
ENG105166,Alt trq Des,8.0, Nm
ENG106228,Ambient air pressure,1000, hPa
ENG106231,Ambient temperature,13.5, °C
ENG105188,Anzhr dnawz,0.0, s
ENG105189,Anzhr dynaw,0,
ENG105190,Anzhr dynws,0.0, s
ENG105192,APP r,0.00, %
ENG105195-ENG188621,APP st Pla Brk mp-Bits 0-7,0,
ENG110009,AVS current valve lift position,False result,
ENG110009-ENG127289,AVS current valve lift position-Test_Program_B TRUE UBYTE,0,
ENG110006,AVS switch count reg.op.in curr. drivecycle: reset at en.off,0,
ENG110007,AVS switch counter (total),80,
ENG105270-ENG188621,Bas Svr Appl st Actr Tst-Bits 0-7,0,
ENG105272-ENG188621,Bas Svr Appl st DFC Err 0-Bits 0-7,64,
ENG105273-ENG188621,Bas Svr Appl st DFC Err 1-Bits 0-7,64,
ENG105274-ENG188621,Bas Svr Appl st DFC Err 10-Bits 0-7,0,
ENG105275-ENG188621,Bas Svr Appl st DFC Err 11-Bits 0-7,112,
ENG105276-ENG188621,Bas Svr Appl st DFC Err 12-Bits 0-7,64,
ENG105277-ENG188621,Bas Svr Appl st DFC Err 13-Bits 0-7,0,
ENG105278-ENG188621,Bas Svr Appl st DFC Err 14-Bits 0-7,0,
ENG105279-ENG188621,Bas Svr Appl st DFC Err 15-Bits 0-7,0,
ENG105280-ENG188621,Bas Svr Appl st DFC Err 16-Bits 0-7,0,
ENG105281-ENG188621,Bas Svr Appl st DFC Err 17-Bits 0-7,0,
ENG105282-ENG188621,Bas Svr Appl st DFC Err 18-Bits 0-7,0,
ENG105283-ENG188621,Bas Svr Appl st DFC Err 19-Bits 0-7,0,
ENG105284-ENG188621,Bas Svr Appl st DFC Err 2-Bits 0-7,0,
ENG105285-ENG188621,Bas Svr Appl st DFC Err 20-Bits 0-7,0,
ENG105286-ENG188621,Bas Svr Appl st DFC Err 21-Bits 0-7,0,
ENG105287-ENG188621,Bas Svr Appl st DFC Err 22-Bits 0-7,0,
ENG105288-ENG188621,Bas Svr Appl st DFC Err 23-Bits 0-7,0,
ENG105289-ENG188621,Bas Svr Appl st DFC Err 3-Bits 0-7,0,
ENG105290-ENG188621,Bas Svr Appl st DFC Err 4-Bits 0-7,16,
ENG105291-ENG188621,Bas Svr Appl st DFC Err 5-Bits 0-7,192,
ENG105292-ENG188621,Bas Svr Appl st DFC Err 6-Bits 0-7,32,
ENG105293-ENG188621,Bas Svr Appl st DFC Err 7-Bits 0-7,192,
ENG105294-ENG188621,Bas Svr Appl st DFC Err 8-Bits 0-7,0,
ENG105295-ENG188621,Bas Svr Appl st DFC Err 9-Bits 0-7,0,
ENG105296-ENG188621,Bas Svr Appl st Frm MDCS-Bits 0-7,4,
ENG105298-ENG188621,Bas Svr x Env Sig Dat 0-Bits 0-7,2,
ENG105299-ENG188621,Bas Svr x Env Sig Dat 1-Bits 0-7,7,
ENG105300-ENG188621,Bas Svr x Env Sig Dat 2-Bits 0-7,140,
ENG105301-ENG188621,Bas Svr x Env Sig Dat 3-Bits 0-7,0,
ENG105302-ENG188621,Bas Svr x Env Sig Dat 4-Bits 0-7,94,
ENG105303-ENG188621,Bas Svr x Env Sig Dat 5-Bits 0-7,236,
ENG105304-ENG188621,Bas Svr x Env Sig Dat 6-Bits 0-7,246,
ENG105305-ENG188621,Bas Svr x Env Sig Dat 7-Bits 0-7,185,
ENG105310,Batt U u Raw,1848.2, mV
ENG105311,Batt U u Sens OBD,14.418, V
ENG110460,Boost_pressure_adaptation_value_0,0, hPa
ENG110461,Boost_pressure_adaptation_value_1,0, hPa
ENG110463,Boost_pressure_adaptation_value_2,0, hPa
ENG110464,Boost_pressure_adaptation_value_3,0, hPa
ENG101413,Calibration Identification,8K2907115AGQ0002,
ENG99697,Calibration Verification Numbers,FC A4 3A DE,
ENG105051,CCS limiting torque,-50000.0, Nm
ENG105513-ENG188621,Clth st Ils Deb Val-Bits 0-7,0,
ENG108511,Clutch torque min.,-40.1, Nm
ENG105524,Cmibe g w,0,
ENG105526-ENG188621,Co Eng st-Bits 0-7,3,
ENG105553-ENG188621,Com ct Rx TO ACC-Bits 0-7,0,
ENG105554-ENG188621,Com ct Rx TO AIRBG-Bits 0-7,0,
ENG105555-ENG188621,Com ct Rx TO AWD-Bits 0-7,0,
ENG105556-ENG188621,Com ct Rx TO BEM-Bits 0-7,0,
ENG105557-ENG188621,Com ct Rx TO BRK-Bits 0-7,0,
ENG105558-ENG188621,Com ct Rx TO CCTL-Bits 0-7,0,
ENG105559-ENG188621,Com ct Rx TO CHG1-Bits 0-7,0,
ENG105560-ENG188621,Com ct Rx TO CHG2-Bits 0-7,0,
ENG105561-ENG188621,Com ct Rx TO CLIMA-Bits 0-7,0,
ENG105562-ENG188621,Com ct Rx TO DSP-Bits 0-7,0,
ENG105563-ENG188621,Com ct Rx TO EPB-Bits 0-7,0,
ENG105564-ENG188621,Com ct Rx TO ESCU-Bits 0-7,0,
ENG105565-ENG188621,Com ct Rx TO GW-Bits 0-7,0,
ENG105566-ENG188621,Com ct Rx TO IGN-Bits 0-7,0,
ENG105567-ENG188621,Com ct Rx TO LVL-Bits 0-7,0,
ENG105568-ENG188621,Com ct Rx TO RES17-Bits 0-7,0,
ENG105569-ENG188621,Com ct Rx TO RES18-Bits 0-7,0,
ENG105570-ENG188621,Com ct Rx TO RES19-Bits 0-7,0,
ENG105571-ENG188621,Com ct Rx TO RES20-Bits 0-7,0,
ENG105572-ENG188621,Com ct Rx TO RES21-Bits 0-7,0,
ENG105573-ENG188621,Com ct Rx TO RES22-Bits 0-7,0,
ENG105574-ENG188621,Com ct Rx TO RES23-Bits 0-7,0,
ENG105575-ENG188621,Com ct Rx TO SA-Bits 0-7,0,
ENG105576-ENG188621,Com ct Rx TO TSC-Bits 0-7,0,
ENG105578,Com l Oil Lvl Sig,0.000, mm
ENG105382,Coolant temperature,66.7, °C
ENG106503,Coolant temperature at radiator outlet,66.7, °C
ENG105677-ENG188621,Cr C st Key-Bits 0-7,0,
ENG105681-ENG188621,Cr Ctl st Sh Off Irv Lst-Bits 0-7,255,
ENG105682-ENG188621,Cr Ctl st Sh Off Rv Lst-Bits 0-7,255,
ENG105683-ENG188621,Cr Ctl st Shut Offirev-Bits 0-7,0,
ENG105707,Ct T dm Air Mass Avrg,12.1, kg/h
ENG105708,Ct T m Air Mass Integ,0.67, kg
ENG105709,Ct T m Air Mass Integ Mode6,0.00, kg
ENG105710,Ct T m Air Mass Thres,10.08, kg
ENG105711,Ct T m Air Mass Thres Mode6,0.00, kg
ENG105712-ENG188621,Ct T num Mon Mode6-Bits 0-7,0,
ENG105715,Ct T t Eng Mode6,-273.1, °C
ENG105716,Ct T t Env T Mn,13.5, °C
ENG105717,Ct T ti Max Out,0, s
ENG105718,Ct T v Avrg,0.00, km/h
ENG105775,Dcycn t,4,
ENG105883,Dlama tr w,0.0000,
ENG105884,Dlatr mo w,0.00000,
ENG105886,Dmdaf mb,0,
ENG105887,Dmdlf mb,0, s
ENG105888,Dmdsf mb w,0, s
ENG100152-ENG104003,ECUNAME-ECU,ECM,
ENG100152,ECUNAME,EngineControl,
ENG106050-ENG188621,EEM st Wt Htr Stp-Bits 0-7,0,
ENG106254,Epm H Cr S st Sig Mode,GAPFOUND,
ENG106254-ENG127292,Epm H Cr S st Sig Mode-Test_Program_Epm H Cr S st Sig Mode State t UBYTE,7,
ENG106259,Epm st Sync,EPM_FULL_SYNC,
ENG106259-ENG127375,Epm st Sync-Test_Program_Epm st Sync State t UBYTE,30,
ENG106495,Fan Ctl r Clg Dem Eng mp,0.00, %
ENG106501,Fan Ctl st Ok,0,
ENG106507,Fan r Ps,10.20, %
ENG106510,Fan r2 Ps,0.00, %
ENG106563,Fkate i,0.000,
ENG106564,Fkmsd k w,0.96899,
ENG106576,Fldrx l w,1.00000,
ENG106669,Fofre sz,0,
ENG106677,Frm w,1.00000,
ENG106685,Frxt,1.000,
ENG106686,Frxta w,1.00000,
ENG106691,Ftead w,0.000,
ENG106762,Gbx trq TSC Des,1000.0, Nm
ENG109561,Gearbox control unit limiting torque,1000.0, Nm
ENG106880,HLS Dem n Set P Lo,700.0, /min
ENG107016,Injection quantity average,0.00, mg/stroke
ENG100634,In-use Performance Tracking: 16 or 20 counters,0, counts
ENG107232,Knock_sensor_cylinder_1_voltage,0.386, V
ENG107233,Knock_sensor_cylinder_2_voltage,0.410, V
ENG107234,Knock_sensor_cylinder_3_voltage,0.449, V
ENG107235,Knock_sensor_cylinder_4_voltage,0.493, V
ENG107344,Lambt s w,1.0000,
ENG107346,Lamfa w,1.0000,
ENG107349,Lamso ni w,0.9976,
ENG107356,Ldeld rae w,0.00, s
ENG107357,Ldeuk m w,0.00, hPa
ENG105529,Limiting torque,499.9, Nm
ENG107723,Mshfm w,11.3, kg/h
ENG107847,Nsol,700, /min
ENG107943,Oscdk ta w,0.0, mg
ENG107944,Oscdk tn w,0.0000,
ENG107945,Oscdk tr w,0.0000,
ENG110568,Oxygen_sensor_bank_1_sensor_2_lean_to_rich_transient_gradient,0.00, s
ENG110566,Oxygen_sensor_bank_1_sensor_2_lean_to_rich_transient_response_time,0.00, s
ENG110569,Oxygen_sensor_bank_1_sensor_2_rich_to_lean_transient_gradient,0.00, s
ENG110567,Oxygen_sensor_bank_1_sensor_2_rich_to_lean_transient_response_time,0.00, s
ENG108175,Pbksa dwa w,0.0, kPa
ENG108176,Pbksa dwc w,0.0, kPa
ENG108177,Pbksa dwd w,0.0, kPa
ENG108179,Pbkso ll w,400.0, kPa
ENG108283,Priok o,11,
ENG108339,Psr w,350.08, hPa
ENG108341,Pth Set trq Inr Set,38.9, Nm
ENG108356,Pvdkd s w,994.45, hPa
ENG108474,Rinsh w,4560, Ohm
ENG108499,Rlfdk roh w,20.93, %
ENG108500,Rlflm roh w,21.07, %
ENG108502,Rlsol w,21.73, %
ENG108534,S Lmp Ctl d Sot Equiv,0.00000000,
ENG108535-ENG188621,S Lmp Ctl d Sot Idx-Bits 0-7,0,
ENG108536,S Lmp Ctl d Wear Equiv,0.00000000,
ENG108537-ENG188621,S Lmp Ctl d Wear Idx-Bits 0-7,0,
ENG108542,S Lmp Ctl lvl Oil Max Cycl,16.692, mm
ENG108543,S Lmp Ctl lvl Oil Min Cycl,15.520, mm
ENG108949-ENG188621,Shtrp ct Remain-Bits 0-7,0,
ENG108950-ENG188621,Shtrp num Curr Tst-Bits 0-7,0,
ENG108952-ENG188621,Shtrp st Vehv DC-Bits 0-7,1,
ENG108953-ENG188621,Shtrp txt Msg-Bits 0-7,0,
ENG108954-ENG188621,Shtrp txt State-Bits 0-7,0,
ENG109006,Spark_efficiency_deviation_at_idle_maximum,3.1, %
ENG109007,Spark_efficiency_deviation_at_part_load_maximum,0.0, %
ENG109109,Stb Intv trq Clth DCS Des,-3276.8, Nm
ENG109110,Stb Intv trq DCS Des,-50000.0, Nm
ENG109145,Strg trq Des,0.0, Nm
ENG109190,SWSVW ag Cha Elg Max1,0.00, °
ENG109191,SWSVW ag Cha Elg Max2,0.00, °
ENG109192,SWSVW ag Cha Elg1,0.00, °
ENG109193,SWSVW ag Cha Elg2,0.00, °
ENG109325,Tabst w,6635, s
ENG109327,Tahso m w,54.11, °C
ENG109329,Tahso w,54.18, °C
ENG109330,Taikr m w,354.15, °C
ENG109338,Tamax,42.0, °C
ENG109339,Tamin,24.8, °C
ENG109346,Tc6ld ps,0,
ENG109347,Tc6ld pw,0,
ENG109625,Temperature at air conditioner heat exchanger output,95.0, °C
ENG109415,Throttle valve feedback,2.73, %
ENG109449,Timrs,0.00, s
ENG109458,Tix l 0,1.505, ms
ENG109459,Tiy l 0,0.636, ms
ENG109461,TKMWL chlno 1053,Test on,
ENG109461-ENG130093,TKMWL chlno 1053-Test_Program_Channel 1053,234,
ENG109462,TKMWL chlno 1163,Combi 1,
ENG109462-ENG130094,TKMWL chlno 1163-Test_Program_Channel 1163,377,
ENG109463,TKMWL chlno 1164,Unknown (0),
ENG109463-ENG130095,TKMWL chlno 1164-Test_Program_Channel 1164,0,
ENG109465,TKMWL chlno 122,Htg.bC.ON,
ENG109465-ENG130073,TKMWL chlno 122-Test_Program_Channel 122,214,
ENG109467,TKMWL chlno 131,A/C Low,
ENG109467-ENG130074,TKMWL chlno 131-Test_Program_Channel 131,14,
ENG109468,TKMWL chlno 132,Compr. OFF,
ENG109468-ENG130075,TKMWL chlno 132-Test_Program_Channel 132,16,
ENG109471-ENG188621,TKMWL chlno 139-Bits 0-7,16,
ENG109472-ENG188621,TKMWL chlno 142-Bits 0-7,209,
ENG109473,TKMWL chlno 1465,Gateway 1,
ENG109473-ENG130096,TKMWL chlno 1465-Test_Program_Channel 1465,634,
ENG109474,TKMWL chlno 148,EGR not active,
ENG109474-ENG130076,TKMWL chlno 148-Test_Program_Channel 148,119,
ENG109475,TKMWL chlno 149,no intervention,
ENG109475-ENG130077,TKMWL chlno 149-Test_Program_Channel 149,120,
ENG109476,TKMWL chlno 1500,TC open,
ENG109476-ENG130097,TKMWL chlno 1500-Test_Program_Channel 1500,60,
ENG109477-ENG188621,TKMWL chlno 1668-Bits 0-7,6,
ENG109478-ENG101650,TKMWL chlno 169-Channel 169,0.0, %
ENG109479-ENG188621,TKMWL chlno 173-Bits 0-7,61,
ENG109480-ENG188621,TKMWL chlno 174-Bits 0-7,0,
ENG109481-ENG188621,TKMWL chlno 175-Bits 0-7,31,
ENG109482,TKMWL chlno 1768,Parkbrake 1,
ENG109482-ENG130098,TKMWL chlno 1768-Test_Program_Channel 1768,791,
ENG109483-ENG188621,TKMWL chlno 177-Bits 0-7,0,
ENG109484-ENG188621,TKMWL chlno 2079-Bits 0-7,33,
ENG109488,TKMWL chlno 218,ABS 1,
ENG109488-ENG130078,TKMWL chlno 218-Test_Program_Channel 218,373,
ENG109489,TKMWL chlno 219,Transmission 1,
ENG109489-ENG130079,TKMWL chlno 219-Test_Program_Channel 219,375,
ENG109490,TKMWL chlno 220,Unknown (0),
ENG109490-ENG130080,TKMWL chlno 220-Test_Program_Channel 220,0,
ENG109491,TKMWL chlno 221,Unknown (0),
ENG109491-ENG130081,TKMWL chlno 221-Test_Program_Channel 221,0,
ENG109493,TKMWL chlno 372,OK,
ENG109493-ENG129324,TKMWL chlno 372-Test_Program_Channel 372,194,
ENG109494,TKMWL chlno 430,Combi 1,
ENG109494-ENG130082,TKMWL chlno 430-Test_Program_Channel 430,377,
ENG109495,TKMWL chlno 440,Nebenlastsignal,
ENG109495-ENG130083,TKMWL chlno 440-Test_Program_Channel 440,1,
ENG109496,TKMWL chlno 453,Airbag 1,
ENG109496-ENG130084,TKMWL chlno 453-Test_Program_Channel 453,414,
ENG109497-ENG188621,TKMWL chlno 457-Bits 0-7,0,
ENG109500-ENG188621,TKMWL chlno 503-Bits 0-7,1,
ENG109501,TKMWL chlno 548,Air cond.1,
ENG109501-ENG130085,TKMWL chlno 548-Test_Program_Channel 548,418,
ENG109502,TKMWL chlno 551,Unknown (0),
ENG109502-ENG130086,TKMWL chlno 551-Test_Program_Channel 551,0,
ENG109503,TKMWL chlno 552,Unknown (0),
ENG109503-ENG130087,TKMWL chlno 552-Test_Program_Channel 552,0,
ENG109504-ENG188621,TKMWL chlno 598-Bits 0-7,1,
ENG109505,TKMWL chlno 599,OFF,
ENG109505-ENG130088,TKMWL chlno 599-Test_Program_Channel 599,136,
ENG109506,TKMWL chlno 666,Unknown (115),
ENG109506-ENG130089,TKMWL chlno 666-Test_Program_Channel 666,115,
ENG109507,TKMWL chlno 750,Unknown (0),
ENG109507-ENG130090,TKMWL chlno 750-Test_Program_Channel 750,0,
ENG109508,TKMWL chlno 751,1. map,
ENG109508-ENG130091,TKMWL chlno 751-Test_Program_Channel 751,271,
ENG109509,TKMWL chlno 760,Steer wheel 1,
ENG109509-ENG130092,TKMWL chlno 760-Test_Program_Channel 760,513,
ENG109510-ENG188621,TKMWL chlno 79-Bits 0-7,5,
ENG109511,TKMWL chlno 87,Idle,
ENG109511-ENG127326,TKMWL chlno 87-Test_Program_Channel 87,5,
ENG109512-ENG188621,TKMWL chlno 870-Bits 0-7,0,
ENG109513-ENG188621,TKMWL chlno 872-Bits 0-7,0,
ENG109626,TS t Clnt Eng Out,67.5, °C
ENG109652,Tumc,14.3, °C
ENG109653,Tumg,13.5, °C
ENG109678,Udknl p1r,0.831, V
ENG109679,Udknl p2r,4.167, V
ENG109680,Udkp1 asr w,0.498, V
ENG109681,Udkp2 asr w,4.503, V
ENG109682,Udkp2 w,4.390, V
ENG109859-ENG188621,Veh Mot st Stab Intv-Bits 0-7,0,
ENG109861,Vehicle speed,0.00, km/h
ENG109886,Vgesh dp w,0.00, mm³
ENG109972,VMSI trq Des Max,50000.0, Nm
ENG109973,VMSI trq Min,-50000.0, Nm
ENG109994,Vvl Cord st VW,2,
ENG109995,Vvl Ctl ct Ind Vl0 VW 0,0,
ENG109996,Vvl Ctl ct Ind Vl0 VW 1,0,
ENG109997,Vvl Ctl ct Ind Vl0 VW 2,0,
ENG109998,Vvl Ctl ct Ind Vl0 VW 3,0,
ENG109999,Vvl Ctl ct Ind Vl1 VW 0,0,
ENG110000,Vvl Ctl ct Ind Vl1 VW 1,0,
ENG110001,Vvl Ctl ct Ind Vl1 VW 2,0,
ENG110002,Vvl Ctl ct Ind Vl1 VW 3,0,
ENG110003,Vvl Ctl ct Lih Acv VW,0,
ENG110004,Vvl Ctl ct Lih Deac VW,0,
ENG110005,Vvl Ctl ct Ovf Swo VW,0,
ENG110008,Vvl Lih b Lih VW,----,
ENG110008-ENG127289,Vvl Lih b Lih VW-Test_Program_B TRUE UBYTE,0,
ENG110109,Wdho1 abr w,360.00, °
ENG110119,Who1s 1 w,6.07, °
ENG110130,Wkrdy a 0,0.0, °
ENG110131,Wkrdy a 1,0.0, °
ENG110132,Wkrdy a 2,0.0, °
ENG110133,Wkrdy a 3,0.0, °
ENG110134,Wkrdy a 4,0.0, °
ENG110135,Wkrmv,0.0, °
ENG110366,Zbezd ldr,0,
ENG110367,Zbezt afix,6,
Elapsed Time: 00:40
Given that the engine appears to have been running at that point, I'd say you have a problem with the camshaft sensor, or its wiring.
cosmaa1
C?ID=566476
Hello Uwe:
I just replaced the Cam shaft sensor, still same problem. Is there a diagnostic in VCDS that I can run to further verify the issue. If it is the wire, do you know how I would check that? With your experience, have you seen that issue kick off the intake manifold runner DTC.
Tony
