Is this error code indicative of a failing chain, or might it just be the sensor (and/or any correlation to the lambda errors)...
Car is a 06 Passat V6, roughly 255000km, always had short oil change intervals (roughly 10K km inbetween) with castrol oil.
000022 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
P0016 - 008 - Incorrect Correlation - MIL ON
Fault Status: 11101000
Mileage: 255750 km
Date: 2023.07.11
Time: 18:25:52
Full scan:
Mileage: 255750 km
Date: 2023.07.11
Time: 18:25:52
Full scan:
Monday,20,November,2023,11:08:06:12859
VCDS Version: 23.11.0.0 (x64)
VIN: WVWZZZ3CZ6P179758 License Plate: NF20216
Mileage: 255800km-158946mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 22 25 37 42 44 46 47 52 53 55 56
62 65 72 77
VIN: WVWZZZ3CZ6P179758 Mileage: 255800km-158946miles
Address 01: Engine Labels: 03H-906-032-BLV.clb
Part No SW: 03H 997 033 K HW: Hardware No
Component: P3.2 FSI-EU4 G00 2368
Revision: --H11--- Serial number: VWZCZ000000000
Coding: 0000175
Shop #: WSC 00830 218 50197
VCID: B56B070ADC73CD39A0-80E0
VINID: 9E69EAAAA0D3A868011C91C52093DD4496
008756 - Oxygen (Lambda) Sensor B2 S1
P2234 - 004 - Signal Shorted to Heater Circuit
Mileage: 246375 km
Date: 2022.07.04
Time: 04:35:03
RPM: 648 /min
Load: 24.7 %
Temperature: 84.0°C
Temperature: 27.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.716 V
008753 - Oxygen (Lambda) Sensor B1 S1
P2231 - 004 - Signal Shorted to Heater Circuit - Intermittent
Fault Frequency: 121
Mileage: 246491 km
Date: 2022.07.06
Time: 20:52:31
RPM: 1486 /min
Load: 43.9 %
Speed: 69.0 km/h
Temperature: 84.0°C
Temperature: 5.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.843 V
Mileage: 255750 km
Date: 2023.07.11
Time: 18:25:52
RPM: 1851 /min
Load: 29.4 %
Speed: 86.0 km/h
Temperature: 84.0°C
Temperature: 4.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.097 V
Part No SW: 02E 300 047 J HW: 02E 927 770 AE
Component: GSG DSG 070 1154
Revision: 04507000 Serial number: 00000602030510
Shop #: WSC 00028 028 00001
VCID: 9F47C5A24E8F67695A-80CA
Address 03: ABS Brakes Labels:. 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 Q HW: 3C0 614 095 Q
Component: ESP 440 C2 H015 0003
Revision: H015 Serial number: 0667084044
Coding: 0046535
VCID: B065361E2311E811F3-80E4
Address 08: Auto HVAC Labels: 3C0-907-044.clb
Part No SW: 3C0 907 044 AC HW: 3C0 907 044 AC
Component: ClimatronicPQ46 050 0404
Revision: 00050005 Serial number: 00000000000000
VCID: E2C18C563D7D0A8135-80B6
00229 - Refrigerant Pressure
Fault Status: 00110010
Fault Frequency: 115
Reset counter: 193
Mileage: 253257 km
Date: 2023.02.09
Time: 12:45:49
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 J HW: 3C0 937 049 J
Component: Bordnetz-SG H37 1301
Revision: 00H37000 Serial number: 00000003835431
Coding: EF868F0700041A00000A00000F000000000B5D435C0000
Subsystem 1 - Part No: 3C1 955 419 Labels: 1KX-955-119.CLB
Component: Wischer VW461 001 0101
Coding: 00063445
Shop #: WSC 00028
Subsystem 2 - Part No: 1K0 955 559 T Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 011 1110
Coding: 00208933
Shop #: WSC 00028
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 K HW: 3C0 909 605 K
Component: 10 AIRBAG VW8R 029 2521
Revision: 10029000 Serial number: 003A3P1ULYSQ
Coding: 0012592
VCID: AE5928663925FEE1E1-80FA
Subsystem 1 - Serial number: 6332MSME0D287D4FX
Subsystem 2 - Serial number: 6342MSME0D5C210BG
Subsystem 3 - Serial number: 6351HTS64IKU4AV2%
Subsystem 4 - Serial number: 6361HTS64IKQG473M
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 E HW: 3C0 953 549 E
Component: J0527 0015
Revision: 00005000 Serial number: 3C5953507P
Coding: 0001211
Component: E0221 007 0050
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 870 P HW: 3C0 920 870 P
Component: KOMBIINSTRUMENT VD1 4240
Revision: V0033000 Serial number: 00000000000000
Coding: 0004105
Shop #: WSC 00830 218 79993
Address 19: CAN Gateway Labels:. 3C0-907-530-V1.clb
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C0621307DA
Coding: FFFD0E54C61002
VCID: A143C35A78FB51996C-80F4
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554 C
Component: HALDEX 4Motion 0108
Coding: 0000001
VCID: AD5B2F6A342385F9D8-80F8
Part No SW: 3C0 959 433 P HW: 3C0 959 433 P
Component: IMMO 043 0364
Revision: 00043000 Serial number: VWZCZ000000000
Shop #: WSC 00155 218 186452
VCID: B7770D02C67F3F29B2-80E2
Component: ELV 029 0380
3C0905861J ELV 029 0380
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1T0 035 680 C HW: 1T0 035 680 C
Component: RNS-MID H50 2840
Revision: AB001001 Serial number: VWZ6Z7L4083060
Coding: 040500020100000100
Shop #: WSC 05314 000 00000
VCID: AE592866F925FEE1E1-80FA
Fault Status: 00101011
Reset counter: 212
Mileage: 246375 km
Date: 2022.07.04
Time: 02:01:25
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
Part No: 1K0 959 701 L
Component: Tuer-SG 024 2461
Coding: 0000247
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
VCID: B36F3912D207D3098E-80E6
Component: KSG PQ46 RDK 043 0213
Coding: 01910A0801860E763804941570084FCE701900
Subsystem 2 - Part No: 3C0 951 171 A
Component: Neigungssensor 002 0508
Subsystem 3 - Part No: 3C0 951 171 A
Component: Innenraumueberw.002 0508
Address 47: Sound System Labels: 3C0-035-456.clb
Part No SW: 3C0 035 456 C HW: 3C0 035 456 C
Component: DSP 10 Kanal 0012
Revision: 00009000 Serial number: 00000000004277
VCID: A045C65E73F1589163-80F4
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX2.lbl
Part No: 1K0 959 702 L
Coding: 0000246
VCID: B8750E3ECB613051BB-80EC
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0000012
Shop #: WSC 05311 000 00000
Address 55: Headlight Range Labels: 5M0-907-357-V1.lbl
Part No SW: 5M0 907 357 HW: 5M0 907 357
Component: AFS-Steuergeraet X016
Revision: H09 Serial number:
Coding: 0000001
VCID: F1E3F31AE89BA119BC-80A4
Subsystem 1 - Part No: 7L6 941 329 Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l X017
Coding: 00000035
Subsystem 2 - Part No: 7L6 941 330
Component: AFS-Lst.-Modul r X017
Coding: 00000035
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Reset counter: 212
Mileage: 246375 km
Date: 2022.07.04
Time: 02:01:25
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 F
Component: Tuer-SG 021 2432
Coding: 0000144
Component: RDK 0391
Coding: 0161211
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 F
Coding: 0000144
VCID: B46D3A0ED709D43197-80E0
Address 77: Telephone (J738) Labels:. 1K8-035-730.clb
Part No SW: 1K8 035 730 D HW: 1K8 035 730 D
Component: Telefon H08 6900
Revision: 00008000 Serial number: 00000A11008983
Coding: 412120
Shop #: WSC 00081 790 00131
VCID: AA512476C5CD92C13D-80FE
End-------------------------(Elapsed Time: 02:33)--------------------------
