- Oct 5, 2023
- 22
- 8
- California, USA
- C?ID=564172
Straight up, I’m fairly new on this forum. I am the happy owner of a Hex Can II. I’ve been using it to troubleshoot fairly simple things. This one is a bit more subtle. As with my other postings I try to document things well for others who follow.
Car is a 2007 Tourareg with a 3.6L v6. I have had it since 2007. Fairly high mileage, but it’s been very well cared for. I like it and plan to keep it.
First thing in the morning it starts great, tachs up to 1200 rpm as it should. At 45 seconds, as it idles down, the motor has a noticeable miss. If I’m driving it, the motor might stall. Regardless, it starts, idles and runs fine the rest of the day. The problem is only on first start in the morning when it’s cold - about 40 degrees F here. No CEL, pending or otherwise.
Worthy of note, the problem is the same regardless of emission systems being ready or not.
Unrelated, over the past few months I have changed;
I’m thinking fuel delivery, so today I used VCDS to log the rail pressure and RPM on start. We see the miss (~200 rpm drop) , however the fuel pressure is fine 70.11 bar. I will figure out how to link an image if it's important.
Other than bank 2 O2 sensors, I’m out of ideas.
Appreciate the help.
- Air filter
- OEM Plugs & Coils
- MAF Sensor - Bosch
- Bank 1 O2 sensors. OEM front, Bosch rear.
VIN: WVGZE77L37D001532 Mileage: 274940km-170839miles
Address 01: Engine Labels: 03H-906-032-BLV.clb
Part No SW: 03H 906 032 D HW: Hardware No
Component: T 3.6-FSI-LEV2 G00 9709
Revision: --H05--- Serial number: VWZ3Z0F6461149
Coding: 0001175
Shop #: WSC 31414 000 00000
VCID: 2313FF8E07CFD6E2329-5160
VINID: 9E65EA5471DC0C750000114308AF7C09C4
005241 - Brake Boost Vacuum System
P1479 - 008 - Mechanical Failure
Fault Status: 01101000
Mileage: 274863 km
RPM: 988 /min
Load: 42.7 %
Speed: 2.0 km/h
Temperature: 89.0°C
Temperature: 30.0°C
Absolute Pres.: 980.0 mbar
Voltage: 14.097 V
Address 02: Auto Trans Labels: 09D-927-750.clb
Part No: 09D 927 750 CP
Component: AL 750 6A 0901
Coding: 0004216
VCID: 7EA5EEFACCED5B0A7D7-5160
Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
Part No: 7L0 907 379 G
Component: ESP ALLRAD MK25 0203
Coding: 0014338
VCID: 3D2729F6816B801224D-5160
Address 05: Acc/Start Auth. Labels: None
Part No SW: 7L0 909 137 A HW: 5WK 485 02
Component: G2 Kessy 6700
Revision: 67005915 Serial number: VWZ3Z0F6461149
Coding: 0147688
VCID: 313F05C64D337472B05-5184
Component: ELV XXXX
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
Address 08: Auto HVAC Labels: 7L6-907-040.clb
Part No: 7L6 907 040 T
Component: CLIMAtronic R/L 4222
Coding: 0020030
VCID: 41DF5506FD93E4F2405-5184
014 - Defective
Address 09: Cent. Elect. Labels:. 7Lx-937-049-V1.clb
Part No: 7L6 937 049 M
Component: 3002
Coding: 0101599
Shop #: WSC 26030 444 12125
VCID: 46D5461AD4BDC3CA757-5160
01494 - Bulb for Parking Lamps; Left (M1)
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 H
Component: 05 Airbag 8.4E++H01 0562
Revision: BB38727 Serial number: 0007721:
Coding: 0012341
VCID: 2809E8A27EE935BA67B-5160
Subsystem 1 - Part No: 7L0 959 339 C
Component: BF-Gewichtsens. 006 0008
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 H
Component: Lenksäulenmodul 3401
Coding: 0010032
VCID: 44D15C12E281F1DA6B3-5184
Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl
Part No: 7L6 920 981 P
Component: KOMBIINSTRUMENT RB8 3211
Coding: 0007231
Address 19: CAN Gateway Labels: 6N0-909-901-19.clb
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: 70B9C0C286B93D7AFFB-5160
Address 1C: Position Sensing Labels: 7L6-919-879.lbl
Part No: 7L6 919 879 A
Component: JCI PathPoint 2200
VCID: 45D74116E9BBC8D27CD-5160
Address 22: AWD Labels: None
Part No: 0AD 927 755 AT
Component: TRANSFERCASE 0114
VCID: 0D47B936F14B709274D-5160
02039 - Position Sensor in Transfer Case (G398)
Address 25: Immobilizer Labels: None
Coding: 0147688
VCID: 313F05C64D337472B05-5160
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Address 33: OBD-II Labels:
VCID: 55F791561C0B78520CD-5160
Part No: 7L0 959 760
Component: Sitzverstellung 0703
VCID: 77ABFBDEE3D76A423E1-5160
Address 37: Navigation Labels: 7L6-919-887-DVD.lbl
Part No: 7L6 919 887 MX
Component: Navigation 0049
Coding: 0000101
Address 39: Right Light Labels: 3D0-909-158.lbl
Part No: 3D0 909 158
Component: EVG GDL+AutoLWR(r) 0001
Coding: 0000002
VCID: 678BAB9EB377FAC2AE1-5160
Address 46: Central Conv. Labels: 7L0-959-933.clb
Part No: 7L0 959 933 J
Component: HSG 5115
Coding: 0000085
VCID: 43D35F0EE78FF6E2529-4B1E
Subsystem 1 - Part No: 7L0 959 701 H
Component: Tuersteuergeraet FS 0201
Subsystem 2 - Part No: 7L0 959 702 H
Component: Tuersteuergeraet BF 0201
Subsystem 3 - Part No: 7L0 959 703 D
Component: Tuersteuergeraet HL 0201
Subsystem 4 - Part No: 7L0 959 704 D
Component: Tuersteuergeraet HR 0201
Address 47: Sound System Labels:
Note: Excessive Comm Errors
Address 56: Radio Labels: 7L6-035-186-DVD.lbl
Part No: 7L6 035 186 EX
Component: Radio 0049
Coding: 0014062
Shop #: WSC 26071 444 82799
Address 68: Wiper Electr. Labels: 7L0-955-119-V2.clb
Part No: 7L0 955 119 K
Component: Front Wiper 4027
Coding: 0000341
Shop #: WSC 31414 000 376832
VCID: 3C2124F29A71891A133-5160
Subsystem 2 - Part No: 1K0 955 559 T Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 011 1110
Coding: 00208933
Shop #: WSC 31414
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 7L6 907 441 HW: 7L6 907 441
Component: J772__Rearview 0051
Revision: 00H07000 Serial number: PA8 J620695
Coding: 0000201
VCID: 72BDCACA88B50F6A09F-5160
Address 6E: Ctrl Head Roof Labels: None
Part No: 7L6 919 044 T
Component: DACHDISPLAY 0539
Revision: 00900539 Serial number: 2009289.07
VCID: 48C94822DEA9D5BA87B-5160
Address 76: Park Assist Labels: Redir Fail!
Part No: 7L0 919 283 F
Component: 0E Einparkhilfe 1107
VCID: 392F3DE69543BC32085-5160
