Stop start disable with VCDS
senna1
C?ID=231631
Hi all
i can disable the stop start system on my vw caddy van 2012 Vw T5 but you still have to dip the clutch to start the vehicle , is there away on the vcds software to
disable the Stop start system so you don't have to dip the clutch pedal, as i know you can do the initial stop start disable several ways, but not sure about if any of these options selects so you dont have to dip the clutch pedal so rather that keep trying or long coding i thought i would ask if possible to do it ,, i would rather do it with the software than mechanically/electrically at the switch.
here is a T5 log file before you ask for a file from me.
Saturday,21,October,2023,13:23:30:51242
VCDS Version: 23.3.1.0 (x64)  HEX-NET2 CB: 0.4631.5
VIN: WV1ZZZ7HZEH037985   License Plate: T5 SATURDAY 21-10-23
Mileage: 170620km-106018mi   Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 15 17 19 25 56 61 0B
VIN: WV1ZZZ7HZEH037985   Mileage: 170620km-106018miles
Address 01: Engine (J623-CAAD)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 FH    HW: 03L 907 309 L
   Component: R4 2,0L EDC   H38 6293
   Revision: 22H38---    Serial number: 00000000000000 CVN: 13593D87
   Coding: 01114018232401080000
   Shop #: WSC 07051 005 104857
   ASAM Dataset: EV_ECM20TDI01103L906019FH 003007
   ROD: EV_ECM20TDI01103L906019FH_003.rod
   VCID: 76BE8932E84BBF1A257-8022
   VINID: 9E606AAAA1D8A956000C724814F66D2210
4451 - Powertrain Databus
          U0002 00 [168] - No Communications
          [High Speed CAN Communication BusPerformance]
                    Mileage: 170621 km
                    Date: 2023.10.20
                    Time: 20:27:31
                    Engine RPM: 864.50 /min
                    Normed load value: 16.5 %
                    Coolant temperature: 86 °C
                    Intake air temperature: 46 °C
                    Voltage terminal 30: 14.660 V
                    CAN status - engine control module-Bits 0-7: 8
                    Cruise Control System (CCS): status-Bits 0-7: 40
                    selected gear-Bits 0-7: 0
5523 - Engine Start Blocked by Immobilizer
          P1570 00 [044] - -
                    Engine RPM: 998.50 /min
                    Vehicle speed: 255 km/h
                    Coolant temperature: 87 °C
                    Intake air temperature: 50 °C
                    Voltage terminal 30: 11.960 V
                    Immobilizer snapshot A-Sia Error Snap A: 14 00 09
                    Immobilizer snapshot B-Sia Error Snap B: 03 00 00
Readiness: 1 1 0 0 0
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 K    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0110
   Revision: 00H43001
   Coding: 508724AD89A70A9C24AB9179B96390
   Shop #: WSC 02736 790 49152
   VCID: 3A265D029C531B7A01F-806E
                    Reset counter: 11
                    Mileage: 170621 km
                    Date: 2023.10.20
                    Time: 20:27:31
                    Count: 16384
                    Count: 4096
                    Count: 8214
                    Count: 512
01312 - Powertrain Data Bus
                    Reset counter: 11
                    Mileage: 170621 km
                    Date: 2023.10.20
                    Time: 20:27:31
                    Count: 16384
                    Count: 4352
                    Count: 8264
                    Count: 512
                    Fault Status: 00101110
                    Reset counter: 11
                    Mileage: 170621 km
                    Date: 2023.10.20
                    Time: 20:27:31
                    Count: 16384
                    Count: 4352
                    Count: 161
                    Count: 512
   Part No SW: 7E0 907 047 AK    HW: 7E0 907 047 AK
   Component: Climatic-T5   H23 0708
   Revision: 00001003
   Coding: 0000000003
   Shop #: WSC 00012 790 50316
   ROD: EV_ClimaT5Basis.rod
   VCID: 73B8B026FB39AA32029-8026
          U1111 00 [008] - -
          [Motorsteuergerät - kein Signal/Kommunikation]
                    Fault Frequency: 8
                    Reset counter: 51
                    Mileage: 170621 km
                    Date: 2023.10.20
                    Time: 20:27:32
13701392 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Bremsensteuergerät - kein Signal/Kommunikation]
                    Fault Frequency: 9
                    Reset counter: 51
                    Mileage: 170621 km
                    Date: 2023.10.20
                    Time: 20:27:32
13701600 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Airbagsteuergerät - kein Signal/Kommunikation --> Fehlende Botschaft [ID] von Airbagsteuergerät]
                    Fault Frequency: 8
                    Reset counter: 51
                    Mileage: 170621 km
                    Date: 2023.10.20
                    Time: 20:27:32
   Part No SW: 7E0 937 090     HW: 7E0 937 090
   Component: BCM PQ25 Max4 H80 0736
   Revision: B9080001    Serial number: 0771 342200003
   Coding: 20A0393A0A612411802849702E2B8C540780610F60064C41320000020000
   Shop #: WSC 12345 288 27091
   VCID: 6882D74AB27F59EAA7B-803C
   Subsystem 1 - Part No SW: 7E0 959 801 K    HW: 7E0 959 801 K  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  003 8654
   Serial number: KU0KU006041660975355
   Coding: 1400B0
   Subsystem 2 - Part No SW: 7E0 959 802 K    HW: 7E0 959 802 K  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  003 8653
   Serial number: KU0KU029051551498270
   Coding: 0000A0
                    Fault Status: 00101010
                    Reset counter: 51
                    Mileage: 170621 km
                    Date: 2023.10.20
                    Time: 20:43:11
   Component: VW10Airbag009 H07 0013
   Revision: --------    Serial number: 003HL00KBFMN Dataset Number: 7E0003v____ 0471
   Shop #: WSC 02734 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 353C4E3EB5CDF402ECD-8060
12583168 - Powertrain Databus
          U0001 00 [136] - Unspecified Malfunction
          [Drive Train CAN Communication Bus defect]
   Part No SW: 7E0 920 960 JX    HW: 7E0 920 960 JX
   Component: KOMBI         H04 0709
   Coding: 460201
   Shop #: WSC 07051 005 1048576
   VCID: 0842F7CA92BFB9EA47B-805C
12648448 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Motor: keine Kommunikation]
                    Reset counter: 51
                    Mileage: 170621 km
                    Date: 2023.10.20
                    Time: 20:27:31
12656896 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Bremse: keine Kommunikation]
                    Reset counter: 51
                    Mileage: 170621 km
                    Date: 2023.10.20
                    Time: 20:27:31
12669184 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Airbag: keine Kommunikation]
                    Fault Frequency: 13
                    Reset counter: 51
                    Mileage: 170621 km
                    Date: 2023.10.20
                    Time: 20:27:31
   Part No SW: 7E0 909 901     HW: 7E0 937 090
   Component: GW-K-CAN TP20 H80 0736
   Revision: B9080001
   Coding: 042300
                    Fault Frequency: 21
                    Reset counter: 51
                    Mileage: 170621 km
                    Date: 2023.10.20
                    Time: 20:27:32
   Component: IMMO          H04 0709
   VCID: 6A86AD42ACF36BFAB1F-803E
   Part No SW: 7E0 035 156 B    HW: 7E0 035 156 B
   Component: Radio         H54 0107
   Revision: R0000000    Serial number: VWZAZ1N6420947
   Coding: 0000020001
   Shop #: WSC 02734 790 00000
   VCID: 2216856214C373BA39F-8076
00625 - Vehicle Speed Signal
                    Reset counter: 51
                    Mileage: 170621 km
                    Date: 2023.10.20
                    Time: 20:28:31
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H80 0736
   Coding: 230B1A73
   Shop #: WSC 01693 210 00002
   Subsystem 1 - Part No SW: 7E0 915 181 B    HW: 7E0 915 181 B
   Component: J367-BDM  H08 0181
   Serial number: 50238G45562221010723
End----(Elapsed Time: 01:19, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
Westbury, UK
you still have to dip the clutch to start the vehicle , is there away on the vcds software to disable the Stop start system so you don't have to dip the clutch pedal
Having to press the clutch pedal to start the engine predates stop/start by many many years - it was introduced in the wake of some unintended vehicle moving when starting, so it's not related to stop/start and I very much doubt there is any way to disable it.
AINils
Germany (AIB)
C?ID=56975
Tipping clutch isn't a start/stop feature. This was a nice idea to prevent car to jump during start as people forget to tick cluth with gear.
2kaa52
Ceska Republica, Praha
C?ID=319193
There is a cable between Clutch cylinder and bcm.
Remove it from Clutch cylinder and Connect it to permanent ground.
Westbury, UK
Duplicate post due to slow forum...
senna1
C?ID=231631
Yes this is why i said rather do it by software if possible , i have by passed call it the switch on other manufactures when doing test, with no problems.
senna1
C?ID=231631
... and hope you never try to start the vehicle whilst it's in gear whithout pressing the clutch.
Maybe i'm old school , we didn't always have the clutch switch on vehicles & managed it is all part of driving,, like sheep all the manufactures copy and more wear and tear on components .
Never say never..........when you or a family member launches the car through the garage wall or another parked car (perhaps because your other vehicles are automatics), be sure to come back to the forum and let us know how that too is "all part of driving".
Start / Stop is one thing, not wanting to depress the clutch before starting engine is quite another matter!
Back when practically "everything" was a manual trans. , your point/request is well taken but now with automatic transmissions being the norm, your looking for a accident waiting to happen.
senna1
C?ID=231631
Back when practically "everything" was a manual trans. , your point/request is well taken but now with automatic transmissions being the norm, your looking for a accident waiting to happen,
Ive been driving since the 80's and no problems driving is driving, i find this stop a pain as wear and tear mainly , driven manual transmission pretty much all that time, what about motorcycles there you go, no stop start and you don't want any jerking on them but if one manufacture does introduce it they all will
senna1
C?ID=231631
Just had a quick look on my Tech wiring
just had a quick look on tech stuff wiring for clutch switch 4 wires 1 to Gnd shares with brake switch 1 to engine Ecu, 1 from relay via fuse, and 1 listed as from power supply control unit, i assume you mean this wire to gnd, i will check when home on elswin probably called J519 bcm on there
or is the ecu grounding it
Westbury, UK
I've be driving since the 1970's mostly manual transmissions...
You still seem to be thinking that pressing the clutch to start is related to stop/start - as has already been said it's not related in any way to stop/start, it's an additional safety feature. If you want to disable that additional safety feature then go ahead at your own risk, but it's not something most of us would advise.
  • Agree
Cuzoe
C?ID=279487
I'm not as old as you folks... but my first few cars were manual and did not require pressing the clutch to start. I was taught to press the clutch the start. I remember having a split second of panic one time as I cranked the car without my foot on the clutch... luckily I had remembered the other thing I was taught which was to confirm I was in neutral. But now my manuals will not start without the clutch pressed, and that's a good thing... and I still make sure I'm in neutral :p.
FWIW, the clutch/starter interlock thing has been mandatory here in the USA for a very long time. I think (but I'm not 100% certain) that all my VWs, going all the way back to the first 1977 Mk.1 have had this. I'm positive my Mk.3 had it.
My impression is it wasn't standard (or mandatory?) in Europe until much later.
Now when I first learned to drive a manual the vehicle in question did not have it, and in fact, I was taught that if the engine ever quit and the vehicle was stuck in a dangerous spot (like in the middle of the road), it was possible to move it off the road onto the shoulder using the starter motor alone. Obviously, the interlock would prevent that.
AINils
Germany (AIB)
C?ID=56975
Iam not sure it's mandatory in Europe, but VAG started to use it since Golf MK6 Plattform in nearly all cars in Europe
Westbury, UK
My B7 Audi RS4 had it back in 2006 which is earlier than the Golf Mk6.
AINils
Germany (AIB)
C?ID=56975
Well than there was some cars ealier I never recognize. But since Golf MK6 (PQ36 Platform) all cars for sure use it. Older Model depend on Equipment I think. Maybe RS4 and other Performance Models use this as security feature earlier
Mari
C?ID=150535
... not wanting to press the clutch pedal by starting the car is for lazy people... ;)
siLc
Tallinn, Estonia
C?ID=330192
Checked WD, clutch position sensor is wired to ECU, not BCM.
I think it's a bad idea to try this physical mod. The engine ECU uses the clutch position signal for fuel cut when shifting gears.
2kaa52
C?ID=319193
Dep
Depends on Car and year.
