Polo 6R ESP8.2i coding
Mihaisrb
Hello.
I have one polo 2012 CBZB Japan import and someone change the instrument cluster without saving abs coding.
Can someone help me with abs long code?
I know is common problem and is hard to calculate long code, i try wits esp calculator but i cant find CBZB engine and RHD on option.
Thank You!
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
Dealer/Shop Name: DAVIMAR AUTO LTD
VIN: WVWZZZ6RZCU079232   License Plate:
Mileage: 66650km-41414mi   Repair Order:
Chassis Type: 6R-VW25 (6R0)
Scan: 01 02 03 08 09 15 17 19 25 44 56 61
VIN: WVWZZZ6RZCU079232   Mileage: 66650km-41414miles
Address 01: Engine (J623-CBZB)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 FR    HW: 03F 907 309 K
   Component: SIMOS10.23AH10 2683
   Revision: --H10---    Serial number:                CVN: 99AC0375
   Coding: 00250096200401080000
   Shop #: WSC 31414 790 50316
   ASAM Dataset: EV_ECM12TFS02103F906070FR 004005
   ROD: EV_ECM12TFS02103F906070FP.rod
   VCID: 77ABE23A1F4037E21E9-8022
   VINID: 9E69EAAAA1A2A939401C9083089E14FB6D
11003 - EVAP Emission Control Sys
          P0441 00 [01100101] - Incorrect Flow
                    Mileage: 66584 km
                    Date: 2023.11.14
                    Time: 01:44:31
                    Engine RPM: 1390.00 /min
                    Vehicle speed: 52 km/h
                    Coolant temperature: 77 °C
                    Intake air temperature: 30 °C
                    Voltage terminal 30: 14.523 V
                    Fuel high-pressure: actual value-Actual fuel rail pressure: 51703.4 hPa
                    Sensor control factor: output value-Lambda control value: bank 1: 0.000 %
                    ACF: load: 0.03519
                    Tank breather valve: duty cycle: 0.000000 %
   Part No SW: 0AM 300 060 G    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 6562
   Revision: 00043014    Serial number: CU501205216454
   Shop #: WSC 08222 004 1048576
   VCID: 2E05075EAC1A362A8DF-807A
   Part No SW: 6R0 907 379 BC    HW: 6R0 907 379 AF
   Component: ESP8.2i front H05 0002
   Revision: --------
   Coding: 000000000000000000000000000000000000
   Shop #: WSC 31414 790 31414
   VCID: 005989E64A4E705A2F3-8054
03306 - Coding Not Valid
                    Fault Frequency: 14
                    Reset counter: 24
                    Mileage: 66650 km
                    Date: 2018.04.07
                    Time: 23:17:54
                    Hex Value: 0x0002
                    Hex Value: 0x0000
                    Hex Value: 0x12E7
                    Hex Value: 0x259E
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7FF8
                    Reset counter: 24
                    Mileage: 66650 km
                    Date: 2018.04.07
                    Time: 23:25:52
                    Hex Value: 0x0007
                    Hex Value: 0x0000
                    Hex Value: 0x1211
                    Hex Value: 0x149C
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
                    Fault Status: 01100101
                    Reset counter: 24
                    Mileage: 66650 km
                    Date: 2018.04.07
                    Time: 23:25:52
                    Hex Value: 0x0007
                    Hex Value: 0x0000
                    Hex Value: 0x1251
                    Hex Value: 0x1B9C
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AB.clb
   Part No SW: 6R0 820 045 N    HW: 6R0 820 045 N
   Component: Man AC        H02 0202
   Revision: 0003SH02
   VCID: 392F24026954E19228D-806C
   Part No SW: 6R0 937 088 G    HW: 6R0 937 088 A
   Component: BCM PQ25 Re3  H50 0353
   Revision: BT050001    Serial number: 0454 104120270
   Coding: 24B02BBF08A10000003009B02C2B0CD05F40612F7E060001A00000000000
   VCID: 42DD43EE0482A24A797-8016
   Subsystem 1 - Part No SW: 6R0 959 802 AC    HW: 6R0 959 802 AC  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  008 1611
   Serial number: KU0KU004051200016846
   Coding: 58BC34
   Subsystem 2 - Part No SW: 6R0 959 801 AE    HW: 6R0 959 801 AE  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  008 1611
   Serial number: KU0KU011051200011753
   Coding: 58BC34
   Subsystem 3 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU022051200011183
   Coding: 58BC32
   Subsystem 4 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU022051200014415
   Coding: 58BC32
                    Fault Status: 00100001
                    Reset counter: 52
                    Mileage: 66231 km
                    Date: 2018.03.17
                    Time: 14:32:09
   Part No SW: 6R0 959 655 L    HW: 6R0 959 655 L
   Component: VW10Airbag01K H10 0020
   Revision: --------    Serial number: 003GY006DKDJ Dataset Number: v00305726R0 0001
   Coding: 00314B
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4BC36ECA334863028A1-801E
   Serial number: 3575HRB40691CAIC19F0
   Serial number: 3585HRB40531D5MSF8PX
   Serial number: 3515RRB405718OOGNP23
   Serial number: 3525RRB405718OOGC0JS
   Part No SW: 6R0 920 960 M    HW: 6R0 920 960 M
   Component: KOMBI         H04 0709
   Coding: 440A01
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW23.rod
   VCID: 3FDB4A1A77F0CFA2169-806A
Address 19: CAN Gateway (J533)       Labels:. 6R0-907-530-V2.clb
   Part No SW: 6R0 907 530 D    HW: 1K0 907 951
   Component: J533  Gateway H38 0035
   Revision:   H38       Serial number: 090512F6000407
   Coding: 2500C3
   VCID: 343115364E361CFAFBB-8060
   Component: IMMO          H04 0709
   VCID: 6A8DCB4E5CF29A0A917-803E
   Part No: 6R0 423 156 B
   Coding: 11230
   Shop #: WSC 31414
   VCID: 2F3B1A5AAE503F22869-807A
   Part No SW: 5M0 035 183 C    HW: 5M0 035 183 C
   Component: Radio RCD310  042 0082
   Revision: 01000001    Serial number: VWZ1Z2M9366016
   Coding: 05000400020001
   VCID: 290FF44299F4511258D-807C
   Part No SW: 6R0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H38 0035
   Coding: 03237A64
   VCID: 74B1D5360EB65CFA3BB-8020
   Subsystem 1 - Part No SW: 6R0 915 181 E    HW: 6R0 915 181 E
   Component: J367-BDM  H08 0181
   Serial number: 00000000004970893700
End----------(Elapsed Time: 01:07, VBatt start/end: 12.3V/12.3V)-----------
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Yes but it would be good to do the verification first.
