DPF Replacement
blimes69
Canada
C?ID=565846
Hi Everyone,
I am a new VW owner (2009 JETTA TDI wagon) and just bought a VCDS hookup. I am replacing my DPF with a used DPF with very low kms that I found for cheap off someone. Does anyone have any thoughts about recoding the used dpf; I am wondering if I can just follow the Ross Tech steps on here for resetting the ash levels? Because the dpf is used can I just tell it that the levels are at zero even though there is going to be some ash in there? Can I force a regen after to clear that soot aswell or what would people recommend? Sorry for the rookie questions, just new to this system.
Cheers
1SVK1
Slovakia
C?ID=311579
Hi Everyone,
Cheers
there is a calculation for that. it's not really best to set it to 0
Yup. On this engine (presumably a CBEA), the New Value in in Adaptation channel 15 should be the mileage in the replacement DPF in km divided by 1000. So if the replacement DPF has 50,000 km on it, put 50 in there.
blimes69
Canada
C?ID=565846
Thankyou! Do I need to reset anything else for it to function properly in there? And do you think I need to force a regen?
MrMeeseeks
LP/SN
Since you are fitting a used one, it would make economic sense to get the used one professionally cleaned first before you fit it (and save removing it again in the near future), then you can reset the values to zero. Less to worry about
blimes69
Canada
C?ID=565846
Hi again,
I was having trouble getting my account verified but it seems to be working properly now. I have attached an auto-scan of the vehicle and am wondering how to find the security access code for my vehicle so I can do the dpf adaptation?
I really appreciate the help you guys all provide on here and I apologize for being quite slow with this computer stuff.
Monday,20,November,2023,14:07:18:60169
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: 3VWML81K19M357945   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 4F 52 56 62 72
VIN: 3VWML81K19M357945   Mileage: 130460km-81064miles
Address 01: Engine (CBE)       Labels: 03L-906-022-CBE.clb
   Part No SW: 03L 997 030 H    HW: 03L 906 022 J
   Component: R4 2.0l TDI G001AG  9983
   Revision: 12H01---    Serial number: VWX7Z0I424L0JC
   Coding: 0350078
   Shop #: WSC 11361 004 1048576
   VCID: 33330FE0F73BD802E21-8066
   VINID: 0E69DD70805B04974314724414FB388CC3
   Part No SW: 02E 300 052     HW: 02E 927 770 AJ
   Component: GSG DSG AG6     440 8938
   Revision: 04844002    Serial number: 00000904091419
   Shop #: WSC 00066 000 00000
   VCID: 51FF65686DE78A12F0D-8004
   Part No SW: 1K0 907 379 CE    HW: 1K0 907 379 AE
   Revision: 00H35001
   Coding: 113B600D49270001881406E8921E0042B100
   Shop #: WSC 25113 002 1048576
   VCID: 77ABFBF0AFC3F4221E9-8022
   Part No SW: 1K0 820 047 JE    HW: 1K0 820 047 JE
   Component: Climatic PQ35   143 1313
   Revision: 00143033    Serial number: 00000000000000
   VCID: 70B9C0ECC6ADA31ADF3-8024
   Part No SW: 3C8 937 049 D    HW: 3C8 937 049 D
   Revision: 00H54000    Serial number: 00000009498982
   Coding: 14898F2340041500070000001C000000000873075C000120000000000000
   VCID: 323D0AE40821D10AE97-8066
   Component: Wischer 020609 021  0501
   Coding: 00038805
   Part No SW: 1K0 909 605 AD    HW: 1K0 909 605 AD
   Component: 07 AIRBAG VW8R  036 8900
   Revision: 06036000    Serial number: 003EVM00A1PK
   Coding: 0012343
   VCID: 6E85DE94DC99B5EACDF-803A
   Subsystem 1 - Serial number: 6332MSME47130D032
   Subsystem 2 - Serial number: 6342MSME74426D0FN
   Subsystem 3 - Serial number: 6351HSME00250727X
   Subsystem 4 - Serial number: 6361HSME00252708Z
   Subsystem 5 - Serial number: 63727SME1C204874+
   Subsystem 6 - Serial number: 63827SME1C1E487AI
   Part No SW: 1K0 953 549 CP    HW: 1K0 953 549 CP
   Component: J0527           053 0111
   Coding: 0001032
   VCID: 025D9A24F801A18A397-8056
   Part No SW: 1K0 920 854 D    HW: 1K0 920 854 D
   Component: KOMBIINSTRUMENT 3HL 1222
   Revision: V0002000    Serial number: VWX7Z0I424L0JC
   Coding: 0007303
   Shop #: WSC 00066 067 57207
   VCID: 2C01149C2A0587FAA3B-8078
00771 - Can't Decode, CODE File Not Loaded!
            003 - Can't Decode, CODE File Not Loaded! - Intermittent
                    Fault Status: 00100011
                    Fault Frequency: 149
                    Reset counter: 240
                    Mileage: 126969 km
                    Time: 22:54:10
   Part No SW: 1K0 907 530 T    HW: 1K0 907 951
   Component: J533  Gateway   H06 0071
   Revision:   H06 01    Serial number: 180409F2000342
   Coding: ED807F06000203002002
   VCID: 382938CCEE5D3B5AD73-806C
   Component: IMMO            3HL 1222
   Shop #: WSC 57104 004 1048576
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1519
   Revision: 72009005    Serial number: 00000764998518
   Coding: 0001205
   VCID: 6FBBC390DB93BCE2C69-803A
00932 - Can't Decode, CODE File Not Loaded!
            005 - Can't Decode, CODE File Not Loaded!
                    Fault Status: 01100101
                    Reset counter: 201
01552 - Unlicensed Version. Not all DTCs
            012 - will be decoded. - Intermittent
                    Fault Status: 00101100
                    Fault Frequency: 23
                    Reset counter: 240
00928 - Unlicensed Version. Not all DTCs
            008 - will be decoded. - Intermittent
                    Fault Status: 00111000
                    Fault Frequency: 15
                    Reset counter: 240
00105 - Can't Decode, CODE File Not Loaded!
            008 - Can't Decode, CODE File Not Loaded! - Intermittent
                    Fault Frequency: 165
                    Reset counter: 240
   Part No: 1K0 909 144 E
   Component: EPS_ZFLS Kl. 70     2501
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
   Part No SW: 1K0 959 433 CA    HW: 1K0 959 433 CA
   Coding: 139007885283281B0904058FB0880F0488FCA0
   VCID: 71BFC5E8CDA7AA12D0D-8024
00332 - Can't Decode, CODE File Not Loaded!
            007 - Can't Decode, CODE File Not Loaded!
                    Fault Status: 01100111
                    Fault Frequency: 11
                    Reset counter: 201
Address 4F: Centr. Electr. II (J533)       Labels:. 1K0-907-532.clb
   Part No SW: 1K0 907 532     HW: 1K0 907 951
   Coding: 050B0500
   VCID: 6695A6B4F8697DAAB5F-8032
   Subsystem 1 - Part No SW: 8R0 959 591     HW: 8R0 959 591
   Component: J245EE16SKB10  H01 0180
   Subsystem 2 - Part No SW: 8R0 959 591     HW: 8R0 959 591
   Component: J394EE16SKB10  H01 0180
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1519
   Revision: 72009005    Serial number: 08122702515203
   Coding: 0001204
00933 - Can't Decode, CODE File Not Loaded!
                    Reset counter: 201
00110 - Unlicensed Version. Not all DTCs
                    Reset counter: 203
                    Mileage: 126969 km
Address 56: Radio        Labels: 1K0-035-1xx-56.clb
   Part No SW: 1K0 035 180 M    HW: 1K0 035 180 M
   Component: Radio DE2       016 0020
   Revision: 00016000    Serial number: VWZ4Z7J3168239
   Coding: 0040401
   VCID: 2A0D128420F199CA517-807E
   Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T
   Component: J388   TUER-SG HL   1401
   Revision: 12006001    Serial number: 00000003957376
   Coding: 0001168
   VCID: 76B5F6F4A4C98D2A05F-8022
Address 72: Door, Rear Right        Labels: None
   Part No SW: 3C0 959 704 C    HW: 3C0 959 794 D
   Component: J389   TUER-SG HR   1509
   Revision: 12008001    Serial number: 00000007145014
   Coding: 0001168
   Shop #: WSC 08224 016 263172
   VCID: 2B0317802F0B80C2AA1-807E
End----------(Elapsed Time: 01:41, VBatt start/end: 12.4V/12.4V)-----------
Go to the Security Access function in 01-Engine and pause there for a few seconds. VCDS should pop up a yellow info balloon with two security access codes.
blimes69
Canada
C?ID=565846
Hi Uwe,
A yellow balloon pops up when I hover over the "Enter security access key" box saying 'Registered version has coding info for this ECU! Did I not properly register my VCDS if this is popping up?
Can you post a screen-shot of this please?
blimes69
Canada
C?ID=565846
I also have this message upon start up of the program, which I am not sure if it has anything to do with it? I download the program to program files on my C-drive so I am not sure if that is an issue?
May I ask why you are replacing the DPF on such a low mileage specimen?
My prior '10 (CJAA) went to vw heaven with its original DPF still going at almost 300k kms....
blimes69
Canada
C?ID=565846
My previous one was cracked, had low differential pressures and excessive soot past the dpf… and I basically got this new one for free…
OK, I'll shut up now :D
blimes69
Canada
C?ID=565846
Plus p2002 p0401 codes
blimes69
Canada
C?ID=565846
Hahaha no no worries man!
OK, that looks a Windows permissions problem.
VCDS should not be in the Program Files tree. Our download page explicitly tells you that, and the default installation location is not there.
Please remove VCDS from wherever it is currently and re-run the installer. Let it install VCDS either in the default location (C:\Ross-Tech\VCDS\) or somewhere in your User tree, e.g.: C:\Users\[your username]\VCDS\
blimes69
Canada
C?ID=565846
Thanks Uwe, got it all sorted!
