Retrofitting torque splitting rear differential 08E to Passat B8 - no comms!
iichel
Netherlands, Operation Market Garden
C?ID=284912
Hey Nils, yes that's correct. It will also allow to start the clutch adaptation but that fails. There are some more basic settings that I didn't try so far.
The SA is also needed to do the adaptations.
   #22
NEtech
Denmark
C?ID=56995
What Adaptations have you performed with success?
IDE03339-ENG278503-Friction classes (customer service) - Class_gearbox
IDE03339-ENG278454-Friction classes (customer service) - Class_version
IDE06869-installation position
IDE07160-MAS01155-Control module switch-off: switch-off time - Control module
IDE07160-MAS05583-Control module switch-off: switch-off time - Data bus
IDE16464-Data transfer after exchange of control module
   #24
TTT
C?ID=547002
So ESP module needs to tell the awd stop messing about, I am in control now of the wheels speeds (during hard braking). I assume and you probably know, that the errors are the result of missing canbus messages, due to incompatible hw and sw.
   #26
iichel
C?ID=284912
So I had the chance to scan an Arteon R from 2022 (3Q0 platform) today with the diff from factory. It was a showroom car with a flat battery so i took the liberty of editting out some of the errors:
Friday,30,August,2024,13:59:28:11868
VCDS Version: 24.7.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: WVWZZZ3HZPE5024xx   License Plate:
Mileage: 7276km-4521mi   Repair Order:
Chassis Type: 3H-VW48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 17 19 23 2B 36 3C 42 44 47 4B
          52 5F 65 6C 6D 75 A5 A9 BB BC CA D6 D7 8126 8127
VIN: WVWZZZ3HZPE5024xx   Mileage: 7276km-4521miles
CA-Sunroof -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: Malfunction 0010
D7-Light Ctrl Right 2 -- Status: Malfunction 0010
8126-Trq distrib RearL axle -- Status: Malfunction 0010
8127-Trq distrib RearR axle -- Status: Malfunction 0010
Address 01: Engine (J623-DNFG)       Labels: None
   Part No SW: 3G0 906 259 M    HW: 06K 907 425 M
   Component: R4 2.0l TFS   H80 0003
   CVN: 839836B5
   Coding: 092540322466050B30040000000000000000000000000000
   ASAM Dataset: EV_ECM20TFS0203G0906259M 001005
   ROD: EV_ECM20TFS0203G0906259L.rod
   VCID: 3635DB9978C5987AB5F-8062
   VINID: 9E69EAAAA0D8AA0545002107103A48DAE7
   Part No SW: 0DL 300 014 C    HW: 0GC 927 711 H
   Component: GSG DQ500     H06 3704
   Revision: 00H06V13    CVN: 851E7413
   VCID: 2B03FAEDB387D592DA1-807E
   Part No SW: 3Q0 614 517 AK    HW: 5Q0 614 517 BR
   Component: ESC           H82 0993
   Revision: 00000000    Serial number: 61282000000110
   Coding: 0DEC7B94D1203B6E477B070760C769B0DE8BDCE2E00696753842558852A849080003010312121212B435351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100VWR 001005
   ROD: EV_Brake1UDSContiMK100VWR_VW48.rod
   VCID: 78A915A13251AE0A673-802C
   Part No SW: 3Q0 959 435 Q    HW: 3Q0 959 435 Q
   Component: VWKESSYMQB    037 1400
   Revision: 00037000    Serial number: 0603040039 Dataset Number: V03935330VK 0001
   Coding: 1F20200723
   Shop #: WSC 05311 115 00319
   ASAM Dataset: EV_KessyHellaMQBAB 004055
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 48C9A56102311E8AD73-801C
   Subsystem 1 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 25915633
   Part No SW: 3G8 907 044 Q    HW: 3G8 907 044 Q
   Component: Climatronic   H10 0221
   Coding: 14020024200114011115100C8010D936
   Shop #: WSC 00015 115 08193
   ASAM Dataset: EV_AirCondiBHTCMQB3rTranc 002004
   ROD: EV_AirCondiBHTCMQB3rTranc_002_VW37.rod
   VCID: 3B23CAAD43E745124A1-806E
   Air quality sensor:
   Humidity sensor: exterior:
   Subsystem 2 - Part No SW: 4H0 907 658 C    HW: 4H0 907 658 C
   Component: G935 MuFu  H06 0012
   Serial number: B4458B2D00PAG0MUFU04
   Subsystem 3 - Part No SW: 11A 907 049 B    HW: 11A 907 049 B
   Component: E265 KPH SH  H02 0184
   Serial number: G06S31.08.2200973530
   Coding: FFFFFF
   Part No SW: 5Q0 937 086 CK    HW: 5Q0 937 086 BR
   Component: BCM PQ37BOSCH 040 0400
   Revision: --------    Serial number: J53F0708221764 Dataset Number: V03935368JF 0001
   ASAM Dataset: EV_BodyContrModul1UDSBosc 021001
   ROD: EV_BCMBOSCH_021_VW37.rod
   VCID: 05576C5575A3C3E26C5-8050
   Subsystem 1 - Part No SW: 3G1 955 119 D    HW: 3G1 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS    220315  046 0607
   Serial number:         220322113637
   Subsystem 2 - Part No SW: 5Q0 955 555 A    HW: 5Q0 955 555 A
   Component: RLHSS  054 0207
   Serial number: S6Y22M08D05H04M20S34
   Coding: 0008DD
   Subsystem 3 - Part No SW: 3G8 941 633     HW: 3G8 941 633
   Serial number: 27 04 2022  10000711
   Subsystem 4 - Part No SW: 5Q0 951 172 A    HW: 5Q0 951 172 B
   Component: Sensor, DWA  005 0403
   Serial number: 000000000ZL2215800JZ
   Subsystem 5 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004 0007
   Serial number: 00000000000002680583
   Humidity sensor: interior:
   Steering Column Switch:
   Subsystem 7 - Part No SW: 5Q1 953 521 MT    HW: 5Q1 953 569 K
   Component: Lenks.Modul  H24 0190
   Serial number: 0100150820220C300763
   Part No SW: 5QA 919 298 K    HW: 5QA 919 298 A
   Component: PLA 3.0 12K   H10 0075
   Serial number: 000150057322237 Dataset Number: V03935375US 0001
   Coding: 8271167851
   Shop #: WSC 05311 115 00090
   ASAM Dataset: EV_EPHVA2CAU3700000 009055
   VCID: 58E97521D2918E0A473-800C
   Part No SW: 2Q0 907 572 AA    HW: 2Q0 907 572 D
   Component: ACCCONTIMQB   H09 0396
   Dataset Number: V03935375VL 0001
   Coding: 32057FD35CFF8728749F812481408780000000000000000064
   ASAM Dataset: EV_ACCMRRCONTIVW376 003018
   ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
   VCID: 73B3228D2B37CD52521-8026
   Part No SW: 5Q0 907 376 C    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H17 0130
   Serial number: 30082241350106 Dataset Number: V03935328WN 0001
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 392FD0A549DB770258D-806C
   Part No SW: 5QF 959 655 AP    HW: 5QF 959 655 AP
   Component: Airbag VW22   015 0755
   Revision: --------    Serial number: 003019EPH2LX95 Dataset Number: V03935349HH 0001
   Coding: 98FCC0C00C8000005C5400CF000C40000065
   ASAM Dataset: EV_AirbaVW22TS6VW48X 001036
   ROD: EV_AirbaVW22TS6VW48X.rod
   VCID: 241111D1DE591AEA1BB-8070
   Left seat belt tensioner:
   Component: BeltPretRevFL  106 1062
   Serial number: 3G8857705F0237W00380
   Coding: 802006
   Right seat belt tensioner:
   Component: BeltPretRevFR  106 1062
   Serial number: 3G8857706F0252W00441
   Coding: 802006
   Subsystem 3 - Part No SW: -----------    HW: 454 002 008 22
   Serial number: 357000000000A6D0C16K
   Subsystem 4 - Part No SW: -----------    HW: 454 001 908 22
   Serial number: 35800000000F13DC036Q
   Subsystem 5 - Part No SW: -----------    HW: 454 802 008 22
   Serial number: 35100FBAA1820000000N
   Subsystem 6 - Part No SW: -----------    HW: 454 801 908 22
   Serial number: 3520045748F20000000C
   Subsystem 7 - Part No SW: -----------    HW: 454 801 408 22
   Serial number: 35500B40F8E20000000O
   Subsystem 8 - Part No SW: -----------    HW: 454 802 905 22
   Component: PedP_Sensor_D  304 0149
   Serial number: 22800D4EE4E1F0000005
   Subsystem 9 - Part No SW: -----------    HW: 454 802 905 22
   Component: PedP_Sens_P_2  304 0149
   Serial number: 229000EF74E1F000000/
   Subsystem 10 - Part No SW: -----------    HW: 454 802 805 22
   Component: PedP_Sensor_C  304 0149
   Serial number: 2300092F616200000003
   Subsystem 11 - Part No SW: -----------    HW: 454 002 507 22
   Component: PedP_Sens_D_2  008 0887
   Serial number: I0M00000000901F4B060
   Subsystem 12 - Part No SW: -----------    HW: 454 002 507 22
   Component: PedP_Sensor_P  008 0887
   Serial number: I0N00000000201F4B06.
   Part No SW: 3G0 920 320 C    HW: 3G0 920 320 C
   Component: KOMBI         524 6220
   Dataset Number: V03935376JY 0001
   Coding: 04AC3898FE8C00080180624F1001000880700003
   Shop #: WSC 00015 015 00040
   ASAM Dataset: EV_DashBoardVDDMQBA0 001048
   ROD: EV_DashBoardVDDMQBA0_001_VW37.rod
   VCID: 1D672435FD332B22545-8048
   Part No SW: 3Q0 907 530 AR    HW: 3Q0 907 530 E
   Component: GW MQB High   524 5502
   Serial number: 22082210802227 Dataset Number: V03935364QX 0001
   Coding: 0B0900047F015B00FB1088BE980F00010001070000000000000000000000
   GVL: 014E3C100800060840DC80008082CC0010000000000200000030000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 7F5BFEBD177F9932269-802A
   Generator:
   Component: 5-00-14-00-04
   Subsystem 2 - Part No SW: 1EA 959 442 F    HW: 1EA 959 442 F
   Component: MFL  H03 0219
   Serial number: 17038315102082202828
   Coding: 2F2B00
   Subsystem 3 - Part No SW: 3Q0 915 181 B    HW: 3Q0 915 181 B
   Component: J367-BDMHella  H11 9070
   Serial number: 7758930106
   Inverter for electrical outlet:
   Subsystem 4 - Part No SW: 5Q0 907 155 C    HW: 5Q0 907 155 C
   Component: U13DCAC  H27 0810
   Serial number: 3335101
1282 - Supply voltage
          U1011 00 [00001000] - Voltage too Low
          [Versorgungsspannung - unterer Grenzwert unterschritten]
                    Reset counter: 61
                    Mileage: 7276 km
                    Date: 2024.08.11
                    Time: 00:09:33
                    Terminal 30 power supply: 8.4 V
                    Terminal 15: OFF
Address 23: Brake Booster (J539)       Labels:. 5QE-909-059.clb
   Part No SW: 3Q0 909 059 AF    HW: 3Q0 909 059 D
   Component: EBKV          H09 0209
   Serial number: BPA085150822013
   Coding: 4103C500400000B5D65A6BAD000049922449922400
   ASAM Dataset: EV_BrakeBoostG2BoschVW48X 015024
   ROD: EV_BrakeBoostG2BoschVW48X_015.rod
   VCID: 7BA30AAD036785120A1-802E
26 Faults Found:
   Component: ELV-MQBB      H07 0020
   Serial number: 22000207836018
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 3333E28D6BB78D52921-8066
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 3Q0 959 760 E    HW: 3Q0 959 760 E
   Component: Sitzmemory    H07 0026
   Serial number: Y0007VGN36435
   Coding: 001000020000050081C281808080000000008181000000F440
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   VCID: 3D27C4B55DF34B22745-8068
Address 3C: Lane Change (J1086)       Labels:* Redir Fail!
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H06 0150
   Serial number: 14520017912529  Dataset Number: V03935334PN 0001
   Coding: 52A54640
   ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15_002_VW27.rod
   Subsystem 1 - Part No SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Component: HRE3_Kl15_Slv  H06 0150
   Serial number: 14520017890919
   Part No SW: 5Q0 959 593 L    HW: 5Q0 959 593 F
   Component: TSG FS003 0350
   Serial number: YE007VHS0810A Dataset Number: V03935363WB 0001
   Coding: 003F5B42D200028000001000
   VCID: 4ACD9F691C3DEC9AC17-801E
   Part No SW: 5WA 907 145 Q    HW: 5WA 907 145 C
   Component: BASGEN1MQB37  502 1063
   Serial number: 01426080 Dataset Number: V03935375UD 0001
   Coding: 01000100010000010001020101000100000001010100
   ASAM Dataset: EV_SteerAssisBASGEN1MQB37 010058
   ROD: EV_SteerAssisBASGEN1MQB37_010.rod
   Part No SW: 3G0 035 466 D    HW: 3G0 035 466 D
   Component: AMPeth16C     H03 3831
   Serial number: A1130J00078754  Dataset Number: V03935352H  0001
   Coding: 24090000000000000000000000000000000000000000000000
   ASAM Dataset: EV_AMPEthMQB 001005
   ROD: EV_AMPEthMQB_VW48.rod
   VCID: 26150BD9A865E8FA05F-8072
   Part No SW: 3Q0 907 338 F    HW: 3Q0 907 338 L
   Component: FCM MQB High  006 0370
   Serial number: 28082211600537 Dataset Number: V03935347XG 0001
   Coding: 000000070F0004D207106F04020300000000000000000000000000000000
   ROD: EV_MultiModulContiVW48X_003.rod
   VCID: 3829D5A172D16E0AA73-806C
   Antenna for short-range communication:
   Subsystem 1 - Part No SW: 3V0 959 121 A    HW: 3V0 959 121 A
   Component: R350 NFCTGS  401 0109
   Serial number: 0000000000B556C5010C
   Antenna 2 for short-range communication:
   Subsystem 2 - Part No SW: 3G0 980 611     HW: 3G0 980 611
   Component: J524 NFCMIKO  H09 0062
   Serial number: 32200000000001681553
   Part No SW: 5Q0 959 592 L    HW: 5Q0 959 592 F
   Component: TSG BFS003 0350
   Serial number: YE007VHN3577C Dataset Number: V03935358AV 0001
   Coding: 003F5142DE00028000001000
   VCID: 49CFA065193BE782C8D-801C
Address 5F: Information Electr. (J794)       Labels:| 3G5-035-MIB-HGH3.clb
   Part No SW: 3G1 035 816 B    HW: 3G5 035 816
   Component: MU-O-ND-EU    H57 0836
   Serial number: WG8LGM010922000 Dataset Number: V03935374QT 0001
   Coding: 24831000000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB 001002
   ROD: EV_MUOIMQB_001_VW48.rod
   Subsystem 1 - Part No SW: 5G6 919 606 C    HW: 5G6 919 606 C
   Component: ABT_High-2     381 9304
   Serial number: VWZ6ZHA2393996
   Subsystem 2 - Part No SW: V03 959 817 SM    HW: -----------
   Component: EUR 2022/23    --- 7065
   Part No SW: 5Q0 907 273 F    HW: 5Q0 907 273
   Component: RDKBERU30     H06 0011
   Serial number: 40000000632092 Dataset Number: V03935358KR 0001
   ROD: EV_RDKBERU30_006_VW37.rod
   Dataset Number: V03935320P  0001
   Coding: 0184030162002017000040
   ROD: EV_CamSysRVRVCPANAMQBAB_006_VW48.rod
   Part No SW: 5WC 959 107 A    HW: 5WC 959 107 A
   Component: HDSG-Modul    H05 0433
   Revision: --------    Serial number: A2-C767-1160-8 Dataset Number: V03935376GA 0001
   Coding: 5808
   ASAM Dataset: EV_DeckLidCONTIAU536 001002
   ROD: EV_DeckLidCONTIAU536_VW42.rod
   VCID: 4FFB8E7DE75FC9B2969-801A
   Part No SW: 5WA 035 284 G    HW: 5WA 035 284 B
   Component: OCUGen3High   H20 0143
   Serial number: 0000000207VIHJ9 Dataset Number: V03935357NU 0001
   Coding: 024830001968AC209025460161502E07
   ASAM Dataset: EV_OCUGen3High 003007
   ROD: EV_OCUGen3High_003_VW27.rod
   Part No SW: 2Q0 980 653 D    HW: 2Q0 980 653
   Component: MQB MFK 3.0   H16 1401
   Serial number: EA1567404222360 Dataset Number: V03935374AF 0001
   Coding: 00000888216EC020089E10001030004000418000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007042
   Part No SW: 3G8 907 159 A    HW: 4K0 907 159
   Component: SAS-GEN 2.5   H08 0001
   Serial number: 220617290003
   VCID: 323DE78994AD845A997-8066
   Part No SW: 5Q0 959 595 L    HW: 8W1 959 595 D
   Component: TSG HFS005 0350
   Serial number: YE007VGU16096 Dataset Number: V03935357KU 0001
   Coding: 000A51420100028000001000
   VCID: 4CC199711649F2AAF3B-8018
   Component: TSG HBFS005 0350
   Serial number: YE007VGT36026 Dataset Number: V03935357KN 0001
   Dataset Number: V03935356RV 0001
   Coding: 608040748312
   ROD: EV_SunRoofCONTIAU736_009_VW37.rod
   VCID: 75B71C952543D3627C5-8020
   Part No SW: 992 941 572 AA    HW: 992 941 572 A
   Component: LED1L         H08 9002
   ROD: EV_LLPGen3LKEBODPO68X_001_VW27.rod
   VCID: 629D57C984CD54DA297-8036
   Component: LED1R         H08 9002
Address 8126: Trq distrib RearL axle (J492)       Labels: 08E-907-554.clb
   Part No SW: 08E 907 554 H    HW: 08E 525 130
   Component: 4Motion       H05 0125
   Serial number: 013387N
   Coding: 00010100
   ASAM Dataset: EV_TorquSplitLeftMAGNA 001005
   ROD: EV_TorquSplitLeftMAGNA.rod
Address 8127: Trq distrib RearR axle (J492)       Labels: 08E-907-554.clb
   Serial number: 01337E4
   Coding: 00010100
   ASAM Dataset: EV_TorquSplitRightMAGNA 001005
   ROD: EV_TorquSplitRightMAGNA.rod
End----(Elapsed Time: 02:36, VBatt start/end: 11.7V/11.6V. VIgn 11.6V)-----
    SW:3Q0-614-517-AK   HW:5Q0-614-517-BR ---  ABS Brakes
    Component:ESC           H82 0993, Coding:0DEC7B94D1203B6E477B070760C769B0DE8BDCE2E00696753842558852A849080003010312121212B435351919323200
    EV_Brake1UDSContiMK100VWR,001005,EV_Brake1UDSContiMK100VWR_VW48.rod
    Friday,30,August,2024,14:00:02:11868
    VCDS Version: Release 24.7.0 (x64)  Data version: 20240715 DS356.3
IDE00252-Brake system vacuum pump,5 ,1
IDE00820-Activating and deactivating all development messages,0 ,1
IDE01763-Dimming,activated ,1
IDE02332-Deactivate production mode,Deactivating ,3
IDE03493-Driver's door status,activated ,1
IDE03659-Roller test bench mode,Manual activation: possible ,1
IDE04456-Brake disk drying,Medium ,1
IDE04508-Hydraulic brake booster,8 ,1
IDE04643-Overboost in brake system,activated ,1
IDE04645-Electromechanical parking brake,not activated ,1
IDE04774-Vehicle and trailer stabilization,not activated ,1
IDE04871-Dynamic starting assist,normal ,1
IDE04939-Tire Pressure Monitoring System (TPMS),Conditions not correct or request sequence error,1
IDE04944-Brake pedal evaluation,activated ,1
IDE04949-Engine drag torque control,activated ,1
IDE04951-Brake Boost,4 ,1
IDE04952-Braking torque boost for distance regulation,3 ,1
IDE05055-Hydraulic brake assistant,normal ,1
IDE05057-Brake prefill,activated ,1
IDE05161-Straight ahead brake stabilization,activated ,1
IDE05263-AUTO HOLD functionality,not activated ,1
IDE05264-AUTO HOLD increase threshold: reduced tensioning force,0 %,1
IDE05265-AUTO HOLD increase threshold: full tensioning force,10 %,1
IDE05286-Expanded electronic differential lock,Standard ,1
IDE05711-Automatic application during engine stalling,activated ,1
IDE06137-IDE04772-Monitoring of functional lights-Indicator light in the button for electromech. parking brake,7 ,2
IDE06137-IDE05333-Monitoring of functional lights-Indicator light in AUTO HOLD button,7 ,2
IDE06139-AUTO HOLD slippage recognition,activated ,1
IDE06505-Electromechanical parking brake: delay level,6 ,1
IDE07006-Tire pressure monitoring display: tire selection,Conditions not correct or request sequence error,1
IDE07565-ABS in lower speed range,activated ,1
IDE07848-Thresholds for brake performance,activated ,1
IDE12030-Rough road optimization,activated ,1
MAS00122-Electronic Stability Program,not activated ,1
MAS00970-Running manufacturer number,activated ,1
MAS01180-AUTO HOLD functional status,Last setting ,1
MAS01299-Offroad,0 ,1
MAS02080-XCP calibration protocol,not activated ,1
MAS02138-Hill-start assistant,normal ,1
MAS02666-Seat belt buckle scan,activated ,1
MAS07300-Monitoring infotainment control unit,Security access required,1
MAS09008-MAS00988-Plausibility check-Reverse gear,activated ,3
MAS09008-MAS09009-Plausibility check-Neutral gear sensor,activated ,3
MAS09008-MAS10668-Plausibility check-Clutch movement,activated ,3
MAS11606-Electromechanical parking brake: emergency braking,activated ,1
ENG118148-Developer_Function_1,Security access required,1
ENG122612-Developer_Function_100,Security access required,1
ENG122613-Developer_Function_101,Security access required,1
ENG122615-Developer_Function_103,Security access required,1
ENG122616-Developer_Function_104,Security access required,1
ENG122617-Developer_Function_105,Security access required,1
ENG122618-Developer_Function_108,Security access required,1
ENG130301-Developer_Function_121,Conditions not correct or request sequence error,1
ENG118149-Developer_Function_2,Security access required,1
ENG118200-Developer_Function_3,Security access required,1
ENG118201-Developer_Function_4,Security access required,1
ENG127702-Developer_Function_5,Security access required,1
ENG122844-ENG101574-dimming_characteristic_1-X1,0 ,12
ENG122844-ENG99557-dimming_characteristic_1-X2,10 ,12
ENG122844-ENG102140-dimming_characteristic_1-X3,50 ,12
ENG122844-ENG102936-dimming_characteristic_1-X4,100 ,12
ENG122844-ENG103548-dimming_characteristic_1-X5,220 ,12
ENG122844-ENG113992-dimming_characteristic_1-X6,253 ,12
ENG122844-ENG99777-dimming_characteristic_1-Y1,6 ,12
ENG122844-ENG100480-dimming_characteristic_1-Y2,6 ,12
ENG122844-ENG100773-dimming_characteristic_1-Y3,8 ,12
ENG122844-ENG100631-dimming_characteristic_1-Y4,12 ,12
ENG122844-ENG102174-dimming_characteristic_1-Y5,80 ,12
ENG122844-ENG113993-dimming_characteristic_1-Y6,100 ,12
ENG122845-ENG101574-dimming_characteristic_2-X1,0 ,12
ENG122845-ENG99557-dimming_characteristic_2-X2,10 ,12
ENG122845-ENG102140-dimming_characteristic_2-X3,50 ,12
ENG122845-ENG102936-dimming_characteristic_2-X4,100 ,12
ENG122845-ENG103548-dimming_characteristic_2-X5,220 ,12
ENG122845-ENG113992-dimming_characteristic_2-X6,253 ,12
ENG122845-ENG99777-dimming_characteristic_2-Y1,6 ,12
ENG122845-ENG100480-dimming_characteristic_2-Y2,6 ,12
ENG122845-ENG100773-dimming_characteristic_2-Y3,8 ,12
ENG122845-ENG100631-dimming_characteristic_2-Y4,12 ,12
ENG122845-ENG102174-dimming_characteristic_2-Y5,80 ,12
ENG122845-ENG113993-dimming_characteristic_2-Y6,100 ,12
Elapsed Time: 00:16
    SW:08E-907-554-H   HW:08E-525-130 ---  Trq distrib RearL axle
    Component:4Motion       H05 0125, Coding:00010100
    EV_TorquSplitLeftMAGNA,001005,EV_TorquSplitLeftMAGNA.rod
    Friday,30,August,2024,13:59:44:11868
IDE00820-ENG278519-Activating and deactivating all development messages-Dev Msg Rx Test Bench,reception of testbench message disabled ,1
IDE00820-ENG278512-Activating and deactivating all development messages-Dev Msg Tx Private Can,disable transmission of developer message on private CAN ,1
IDE00820-ENG278533-Activating and deactivating all development messages-Dev Msg Tx Public Can,disable transmission of developer message on public CAN ,1
IDE00820-ENG278447-Activating and deactivating all development messages-Dev Msg Tx Test Bench,disable transmission of testbench message (private CAN only) ,1
IDE00820-ENG278546-Activating and deactivating all development messages-Xcp Rd Wr Enable,Xcp disabled ,1
IDE03339-ENG278503-Friction classes (customer service)-Class_gearbox,6808 ,3
IDE03339-ENG278454-Friction classes (customer service)-Class_version,21 ,3
IDE06869-installation position,Variant selection - CAN 2.0 L ,1
IDE16464-Data transfer after exchange of control module,03 06 00 02 01 82 57 56 57 5A 5A 5A 33 48 5A 50 45 35 30 32 34 37 34 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1A 98 15 02 5A 00 00 00 22 00 00 00 04 00 00 00 01 00 00 00 00 00 00 03 24 00 00 00 00 1C 6E 00 00 00 22 00 00 00 04 00 00 00 01 00 00 03 24 00 00 1C 6E 00 00 03 D9 00 00 AD F2 00 00 34 EE 00 00 09 AB 00 02 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 3E C3 47 09 ,512
Elapsed Time: 00:02
    SW:08E-907-554-H   HW:08E-525-130 ---  Trq distrib RearR axle
    EV_TorquSplitRightMAGNA,001005,EV_TorquSplitRightMAGNA.rod
    Friday,30,August,2024,13:59:53:11868
IDE03339-ENG278503-Friction classes (customer service)-Class_gearbox,6386 ,3
IDE06869-installation position,Variant selection - CAN 2.0 R ,1
IDE16464-Data transfer after exchange of control module,02 06 00 02 01 82 57 56 57 5A 5A 5A 33 48 5A 50 45 35 30 32 34 37 34 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 18 F2 15 02 B8 00 00 00 29 00 00 00 05 00 00 00 01 00 00 00 00 00 00 03 24 00 00 00 00 1C 6E 00 00 00 29 00 00 00 05 00 00 00 01 00 00 03 24 00 00 1C 6E 00 00 03 D9 00 00 B3 04 00 00 33 9B 00 00 09 C9 00 02 FF 43 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0D 35 31 9A ,512
Elapsed Time: 00:02
Continuing tomorrow
Since its tomorrow and it's my birthday, I got this:
and this from myself:
just waiting for @downtime to join my birthday party :)
iichel
C?ID=284912
We made some progress...
ECU DTC Var mismatch error gone
Successfully wrote VIN to both modules
Just the clutch basic setting error and the ESP error left
Saturday,31,August,2024,19:16:02:11868
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VMWare)
VCDS Version 24.7.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: WVWZZZ3CZJE025658   License Plate:
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 02 03 05 06 08 09 10 13 14 15 16 17 18 19 2B 36 3C 42 44
          47 4B 52 5F 65 69 6C 6D A5 BB BC CA D6 D7 8126 8127
VIN: WVWZZZ3CZJE025658   Mileage: 194819km-121054miles
Address 01: Engine (J623-CJXB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 F    HW: 06K 907 425 B
   Revision: --H13---    CVN: B7DB7878
   Coding: 091D003A2476050B3004
   Shop #: WSC 30389 123 56831
   ASAM Dataset: EV_ECM20TFS0205G0906259F 001004
   ROD: EV_ECM20TFS0205G0906259J.rod
   VCID: 313FE88591ABBF42E0D-8065
   VINID: 9E69EAAAA0D3A9A54008518520274044B7
15 Faults Found:
20646 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
          P0030 00 [00100111] - Malfunction / Open Circuit
                    Mileage: 194819 km
                    Date: 2024.08.31
                    Time: 19:13:04
                    Engine RPM: 0.00 /min
                    Coolant temperature: 21 °C
                    Intake air temperature: 24 °C
                    Voltage terminal 30: 12.226 V
                    Engine: operating status: ES
                    STATE_LS_SAE[1]: INI
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 102 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
                    TTIP_MES_LS_UP[1]: -2048.0000 °C
                    TEG_DYN_LS_UP[1]: 22.4750 °C
15170 - Engine Oil Temp. Sensor (G8)
          P0198 00 [00100111] - Signal too High
                    Mileage: 194819 km
                    Date: 2024.08.31
                    Time: 19:13:06
                    T_AST_SAE: 0 s
                    FAC_TPS_1_SAE: 16.406250 %
                    FUP_H_SAE: 760.0 kPa
15376 - Fuel Pressure Regulator Valve (N276)
          P2294 00 [10100111] - Open Circuit
                    Mileage: 194819 km
                    Date: 2024.08.31
                    Time: 19:13:02
                    ECU_STATE: ENG_STOP
                    High-pressure system: status: VCV_OPEN
                    STATE_CRK_STST: CRK_STST_PAS
                    TFPA: -14 °C
                    TFU_HPP: 9.00 °C
                    FUP_H_SAE: 740.0 kPa
15015 - Turbocharger Bypass Valve Control Circuit
          P0033 00 [00100111] - Malfunction / Open Circuit
                    Mileage: 194819 km
                    Date: 2024.08.31
                    Time: 19:13:02
                    T_AST_SAE: 0 s
                    FUP_H_SAE: 750.0 kPa
15270 - Camshaft Timing Adj. Bank1 (N205)
          P1528 00 [00100111] - Open Circuit
                    Mileage: 194819 km
                    Date: 2024.08.31
                    Time: 19:13:03
                    T_AST_SAE: 0 s
15267 - Bank1; Exhaust Cam Adjustment Valve 1 (N318)
          P1050 00 [00100111] - Open Circuit
                    Mileage: 194819 km
                    Date: 2024.08.31
                    Time: 19:13:03
                    T_AST_SAE: 0 s
15381 - Cam Adjustment Actuator A; Cylinder 1
          P11A1 00 [00100111] - Elec. Malf. or Open Circuit
                    Mileage: 194819 km
                    Date: 2024.08.31
                    Time: 19:13:01
                    CAM_VCP[EX_1]: 0.000 °
                    CTR_VVL_LIH_DEAC: 0
                    CTR_VVL_LIH_ACT: 0
                    CTR_VVL_SWI_DC: 0
                    T_SWI_VVL_ACR: 0.0 ms
                    NR_CYL_FIRST_VVL_SWI: 0
15383 - Cam Adjustment Actuator A; Cylinder 3
          P11A9 00 [00100111] - Elec. Malf. or Open Circuit
                    Mileage: 194819 km
                    Date: 2024.08.31
                    Time: 19:13:01
                    CTR_VVL_LIH_DEAC: 0
                    CTR_VVL_LIH_ACT: 0
                    CTR_VVL_SWI_DC: 0
15384 - Cam Adjustment Actuator A; Cylinder 4
          P11AD 00 [00100111] - Elec. Malf. or Open Circuit
                    Mileage: 194819 km
                    Date: 2024.08.31
                    Time: 19:13:01
                    CTR_VVL_LIH_DEAC: 0
                    CTR_VVL_LIH_ACT: 0
                    CTR_VVL_SWI_DC: 0
15382 - Cam Adjustment Actuator A; Cylinder 2
          P11A5 00 [00100111] - Elec. Malf. or Open Circuit
                    Mileage: 194819 km
                    Date: 2024.08.31
                    Time: 19:13:01
                    CTR_VVL_LIH_DEAC: 0
                    CTR_VVL_LIH_ACT: 0
                    CTR_VVL_SWI_DC: 0
15401 - Cam Adjustment Actuator B; Cylinder 1
          P11A3 00 [00100111] - Elec. Malf. or Open Circuit
                    Mileage: 194819 km
                    Date: 2024.08.31
                    Time: 19:13:01
                    CTR_VVL_LIH_DEAC: 0
                    CTR_VVL_LIH_ACT: 0
                    CTR_VVL_SWI_DC: 0
15403 - Cam Adjustment Actuator B; Cylinder 3
          P11AB 00 [00100111] - Elec. Malf. or Open Circuit
                    Mileage: 194819 km
                    Date: 2024.08.31
                    Time: 19:13:01
                    CTR_VVL_LIH_DEAC: 0
                    CTR_VVL_LIH_ACT: 0
                    CTR_VVL_SWI_DC: 0
15404 - Cam Adjustment Actuator B; Cylinder 4
          P11AF 00 [00100111] - Elec. Malf. or Open Circuit
                    Mileage: 194819 km
                    Date: 2024.08.31
                    Time: 19:13:01
                    CTR_VVL_LIH_DEAC: 0
                    CTR_VVL_LIH_ACT: 0
                    CTR_VVL_SWI_DC: 0
15402 - Cam Adjustment Actuator B; Cylinder 2
          P11A7 00 [00100111] - Elec. Malf. or Open Circuit
                    Mileage: 194819 km
                    Date: 2024.08.31
                    Time: 19:13:01
                    CTR_VVL_LIH_DEAC: 0
                    CTR_VVL_LIH_ACT: 0
                    CTR_VVL_SWI_DC: 0
15423 - Turbocharger Boost Control Position Sensor Circuit
          P2565 00 [10100111] - Signal too High
                    Mileage: 194819 km
                    Date: 2024.08.31
                    Time: 19:13:01
                    Status of charge air pressure control valve basic setting-LV_BPA_AD_REQ[0]: 00000000
                    Charge air pressure control valve uncond voltage sensor: 4.9902 V
                    Charge air pressure control valve position: target value: 0.00 %
                    Charge air pressure control valve position: actual value: 0.00 %
                    Charge air pressure control valve activation pulse duty factor: 0.00 %
                    Charge air pressure control valve voltage: position closed: 4.3604 V
                    STATE_BPA[0]: OPM
Readiness: 1110 0000
   Part No SW: 0D9 300 018 C    HW: 02E 927 770 AS
   Component: DQ250-6A MQB  H54 5297
   Revision: 06454104    Serial number: TFK01706160335 CVN: 000099EF
   Shop #: WSC 05311 115 00065
   ROD: EV_TCMDQ250021.rod
   VCID: 1C612931E629222AA3B-8049
   Part No SW: 5Q0 614 517 FM    HW: 5Q0 614 517 AH
   Component: ESC           H62 0755
   Revision: 00000000    Serial number: 61907000000236
   Coding: 0FEC6B8F54222371477D070540CB69F0D62AC4E2E00296753842508842A9420000000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_037_VW48.rod
   VCID: 015F7845618BEFC250D-8055
8210 - Databus
          U1121 00 [10001001] - Missing Message
          [FCAN: Allrad_03 message is not received]
                    Reset counter: 210
                    Mileage: 194819 km
                    Date: 2024.08.31
                    Time: 19:13:03
   Revision: 00037000    Serial number: 0577965047 Dataset Number: V03935321YJ 0001
   Coding: 1F20200723
   VCID: 48C9A56102311E8AD73-801D
   Subsystem 1 - Part No SW: 3G0 962 243     HW: 3G0 962 243
   Component: GEB.F.Heckoef  H17 0812
   Serial number: ;8001216
   Part No SW: 3Q0 959 760 D    HW: 3Q0 959 760 B
   Component: Sitzmemory    H05 0024
   Serial number: Y0006PKA28228 Dataset Number: V03935285VX 0001
   Coding: 001000020000050081C481808080000000008181000000F400
   ASAM Dataset: EV_SeatMemorPasseSide 002022
   ROD: EV_SeatMemorPasseSide.rod
   VCID: 3C21C9B146E9422A43B-8069
   Part No SW: 3G8 907 044 T    HW: 3G8 907 044 T
   Coding: 12020024104411011115500D0018592A
   VCID: 3E25C3B950F5503A6DF-806B
   Air quality sensor:
   Subsystem 3 - Part No SW: 11A 907 049 A    HW: 11A 907 049 A
   Component: E265 KPH SH  H02 0183
   Serial number: G04S01.11.2100972191
   Coding: FFFFFF
655621 - Temperature Sensor for Rear Left Seat
          B1113 15 [00101111] - Open or Short to Plus
                    Mileage: 194819 km
                    Date: 2024.08.31
                    Time: 19:13:00
                    Control Module Voltage: 12.100 V
655623 - Temperature Sensor for Rear Right Seat
          B1114 15 [00101111] - Open or Short to Plus
                    Mileage: 194819 km
                    Date: 2024.08.31
                    Time: 19:13:00
   Part No SW: 5Q1 937 084 B    HW: 5Q1 937 084 B
   Component: BCM MQBAB HO  H44 0512
   Serial number: 02102311001826 Dataset Number: V03935381P  0001
   ASAM Dataset: EV_BCMMQB 022001
   ROD: EV_BCMBOSCH_022_VW37.rod
   VCID: 3829D5A172D16E0AA73-806D
   Subsystem 1 - Part No SW: 3G1 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    170615  042 0607
   Serial number:         170629234856
   Coding: 0F4DFD
   Serial number: 22181601X81A955555A0
   Coding: 02005D
   Serial number: 19 04 2017  10000901
   Serial number: 000000000ZL23010051V
   Serial number: 00000000000070188699
   Subsystem 6 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Component: SysNameFanLin  014 0101
   Serial number: ESE0158736
   Subsystem 7 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0096892
   Subsystem 8 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0145994
   Subsystem 9 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0146336
   Part No SW: 5QA 919 298 L    HW: 5QA 919 298 A
   Component: PLA 3.0 12K   H07 0074
   Serial number: 000308417617172 Dataset Number: V03935315EN 0001
   Coding: 8A79267951
   VCID: 59EF7025A99B970278D-800D
13637426 - Databus
                    Reset counter: 210
                    Mileage: 194819 km
                    Date: 2024.08.31
                    Time: 19:13:00
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 S    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0780
   Dataset Number: V12345678AA V315
   Coding: 351F5FFBDFFFCF28979F813681500D80000000000099000032
   ASAM Dataset: EV_ACCBOSCHVW416 003015
   ROD: EV_ACCBOSCHVW416_003_VW41.rod
   VCID: 47CBA65D0F2F11F2DE9-8013
0803 - Databus
          [FAULT_BV1_FEHLER]
                    Reset counter: 210
                    Mileage: 194819 km
                    Date: 2024.08.31
                    Time: 19:13:06
                    Control Module temperature: 40 °C
                    Voltage terminal 15-Voltage: 12.1 V
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: 0.00 m/s²
                    Adaptive distance regulation: status: ACC_irreversible error
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM]
                    Reset counter: 210
                    Mileage: 194819 km
                    Date: 2024.08.31
                    Time: 19:13:00
0928 - Databus
          U1122 00 [00001000] - Implausible Message
          [FAULT_STOPPING_DISTANCE_CONTROL_NOT_AVAILABLE]
                    Reset counter: 250
                    Mileage: 194819 km
                    Date: 2024.08.31
                    Time: 19:13:00
2068 - Databus
          [FAULT_TSK_IRREV_FAIL]
                    Reset counter: 210
                    Mileage: 194819 km
                    Date: 2024.08.31
                    Time: 19:13:00
   Serial number: 25061741350001 Dataset Number: V03935290WM 0001
   VCID: 392FD0A549DB770258D-806D
   Part No SW: 3Q0 959 655 CP    HW: 3Q0 959 655 CP
   Component: Airbag VW21   006 0721
   Revision: --------    Serial number: 003Z4PGADL1% Dataset Number: V03935283XG 0001
   Coding: 98FCC0C0008000005C5400CF000800000065
   VCID: 0E45537920D580BADDF-805B
   Component: BeltPretRevFL  106 1040
   Serial number: 3G0857705 0031T01500
   Coding: 80000D
   Serial number: 3G1857706G0185R01460
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 454 001 606 17
   Serial number: 357000000000507D3628
   Subsystem 4 - Part No SW: -----------    HW: 454 001 806 17
   Serial number: 358000000008D140C62J
   Subsystem 5 - Part No SW: -----------    HW: 454 801 106 17
   Serial number: 3510091305210000000U
   Subsystem 6 - Part No SW: -----------    HW: 454 801 106 17
   Serial number: 352002F2F52100000009
   Subsystem 7 - Part No SW: -----------    HW: 454 801 406 17
   Serial number: 3550040279610000000%
   Part No SW: 5Q0 953 521 KT    HW: 5Q0 953 569 B
   Component: Lenks.Modul   100 0265
   Revision: FF035035    Serial number: 20170828500092 Dataset Number: V03935250KY 0001
   Coding: 8410
   ASAM Dataset: EV_SMLSVALEOMQBLRH 001007
   ROD: EV_SMLSVALEOMQBLRH.rod
   Part No SW: 3G0 920 791 D    HW: 3G0 920 791 C
   Component: KOMBI         406 4191
   Coding: 07AD0898FE8C000C01887F0F3001000080000000
   Shop #: WSC 00046 000 00000
   VCID: 2A0DFFE9BC7DCC9A217-807F
Address 18: Aux. Heat (J364)       Labels:| 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 K    HW: 5Q0 963 272 H
   Component: STH-MQB       008 0080
   Coding: 9309
   Shop #: WSC 00015 115 00001
   Auxiliary heating remote control:
   Subsystem 1 - Part No SW: 3Q0 963 513     HW: 3Q0 963 513
   Component: R64 D208L  004 0401
   Serial number: 00000000000000276932
   Part No SW: 3Q0 907 530 AR    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5502
   Serial number: 06071710802132 Dataset Number: V03935278KN 0001
   Coding: 0B0B00347F015900DB00025E9C0F00010001070000000000000000000000
   GVL: 015E3C0008000600C0FC80000006CC0010000000000200000030000000000000
   VCID: 7F5BFEBD177F9932269-802B
   Generator:
   Component: 4-00-03-00-04
   Subsystem 2 - Part No SW: 1EA 959 442 E    HW: 1EA 959 442 E
   Serial number: 17036218123222100161
   Coding: AF0B00
   Serial number: 5131394104
   Component: U13DCAC  H26 0780
   Serial number: 0066181
   Analog clock:
   Subsystem 5 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  111 1004
   Serial number: 3003201700010095
   Serial number: 17000160250002
   ROD: EV_ELVMarquMQBB_VW37.rod
   VCID: 71BF2885512BFF42A0D-8025
   Serial number: Y0006QFD15173 Dataset Number: V03935285VX 0001
   Coding: 001000020000150081C481808080000000008181000000F400
   Component: HRE3_Kl15_Mst H07 0150
   Serial number: 00000591782366  Dataset Number: V03935345YL 0001
   Coding: 62954640
   Component: HRE3_Kl15_Slv  H07 0150
   Serial number: 00000606636104
2240558 - Databus
          [databus error value received - ESP_33 - ESC_Verz_Reg_nicht_verfuegbar]
                    Mileage: 194819 km
                    Date: 2024.08.31
                    Time: 19:13:02
   Serial number: YE007VFP28434 Dataset Number: V03935363WB 0001
   Coding: 00359A20D200028200011000
   VCID: 4ACD9F691C3DEC9AC17-801F
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  506 5082
   Dataset Number: 8V0909852AA 0001
   Coding: 93070000
   Shop #: WSC 00015 115 00319
   ROD: EV_SteerAssisMQB_015.rod
Address 47: Sound System (J525)       Labels:| 3Q0-035-466.clb
   Part No SW: 3Q0 035 465     HW: 3Q0 035 465
   Component: MIB2_amp_P_VW H60 0440
   Revision: 00000001    Serial number: VWZ8Z1HJD00RUVL Dataset Number: V03935264BQ 0001
   Coding: 1284020001AA0A2AAA0000000000
   ASAM Dataset: EV_AMPMst16C3Gen2ALPI 001018
   ROD: EV_AMPMst16C3Gen2ALPI_VW48.rod
   VCID: 6B833AED730715929A1-803F
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Serial number: 01071710801233 Dataset Number: V03935339UR 0001
   Coding: 000000060100035207007F010A0000000000000000000000000000000000
   VCID: 72BD2789542DC45A597-8027
   Subsystem 1 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _
   Component: Leimo links  H02 0003
   Coding: E02400
   Subsystem 2 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _
   Component: Leimo rechts  H02 0003
   Coding: E02400
13705999 - Databus
          U1123 00 [10001001] - Received Error Message
          [Kamera_FDD_Funktionsstatus_Fehler received error status]
                    Reset counter: 210
                    Mileage: 194819 km
                    Date: 2024.08.31
                    Time: 19:12:59
13706000 - Databus
          [Kamera_FDD_Eigenblend_Guete received error status]
                    Reset counter: 210
                    Mileage: 194819 km
                    Date: 2024.08.31
                    Time: 19:13:00
   Serial number: YE007VF20444B Dataset Number: V03935358AV 0001
   Coding: 00359020DE00028200011000
   VCID: 49CFA065193BE782C8D-801D
   Part No SW: 5NA 035 022 D    HW: 5NA 035 022
   Component: MU-H-LND-EU   H54 1367
   Serial number: A846F0JS020395 Dataset Number: V03935262VW 0001
   Coding: 02840201000000005111110200880A301F0106E4012004009F
   VCID: 3431E1916EB98A6A8BB-8061
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H50 9130
   Serial number: VWZ6ZJT1915518
   Subsystem 2 - Part No SW: V03 959 821 CG    HW: -----------
   Component: ECE 2024  --- 0350
   Compact disc data bank:
   Component: Gracenote2  --- 1016
   Component: RDKBERU30     H04 0011
   Serial number: 40000000081630 Dataset Number: RDKS_TinyQ_ 1017
   Part No SW: 5Q0 907 383 N    HW: 5Q0 907 383 N
   Component: Anhaenger     H27 0264
   Revision: 8A001003    Serial number: 0446947174 Dataset Number: V03935259HF 0001
   Coding: 0100000202000000
   VCID: 42DDB749240D34DA097-8017
   Part No SW: 5Q0 907 556 C    HW: 5Q0 907 556
   Component: Areaview 2    H13 0608
   Serial number: C854707JG069231 Dataset Number: ----------
   Coding: 01840200E70F200004314817
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
   ROD: EV_CamSysRVAV2ARCE2MQBAB_006_VW37.rod
   Part No SW: 5Q0 959 107 Q    HW: 5Q0 959 107 C
   Component: HDSG-Modul    H12 0265
   Revision: --------    Serial number: 31344982200000 Dataset Number: V03935262CS 0001
   Coding: 02A8
   ROD: EV_DeckLidCONTIAU736_VW48.rod
   VCID: 46D5AB59082508FA25F-8013
   Component: MQB MFK 3.0   H16 1421
   Serial number: E80320003220200 Dataset Number: V03935411EY 0001
   Coding: 0004019821FAC02888DF14001020004000218000000000000000000000000000
   VCID: 3635DB9978C5987AB5F-8063
1135140 - Databus
          [APS_03_US_Fehler_HS]
                    Mileage: 194819 km
                    Date: 2024.08.31
                    Time: 19:13:01
1135139 - Databus
          [APS_03_US_Fehler_VS]
                    Mileage: 194819 km
                    Date: 2024.08.31
                    Time: 19:13:01
1123173 - Databus
          [ESP_21_ESP_Systemstatus]
                    Mileage: 194819 km
                    Date: 2024.08.31
                    Time: 19:13:00
   Serial number: YE007VBO10863 Dataset Number: V03935306SB 0001
   Coding: 000490200100028000001000
   VCID: 4CC199711649F2AAF3B-8019
   Serial number: YE007VBO13878 Dataset Number: V03935306RQ 0001
   Part No SW: 4M0 907 594 D    HW: 4M0 907 594
   Component: SAD_STG_1     011 0003
   Dataset Number: V03935218DJ 0001
   Coding: 208040748202
   VCID: 372BD69D7FCF6172AE9-8063
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   VCID: 16753B191805787A95F-8043
   Component: LED1R         H09 0003
   Serial number: 012WDYM
   Coding: 00101000
   VCID: 3333E28D6BB78D52921-8067
24588 - Clutch Position Not Learned
          P080A 00 [00101111] - -
          [Inital_calibration_missing]
                    Snapshot Record Number: 16
                    Number Of Identifiers: 18
                    DID: 64768
                    Major Version Number: 6
                    Minor Version Number: 0
                    Bugfix Version Number: 2
                    Patch version number: 1
                    Occurrence Counter TOC: 1
                    Occurrence Counter SLC: 1
                    Occurrence Counter TNCTOC: 0
                    Occurrence Counter SLF: 0
                    Occurrence Counter SFF: 12
                    Core Service State: 4
                    Error Event Number: 91
                    Event Triggers Current Backup Function: true
                    Origin System Up Counter: 2
                    Most Recent System Up Counter: 1
                    Origin Operation Cycle Counter: 0
                    Most Recent Operation Cycle Counter: 51
                    Error specific Freeze Frame raw data: B3 25 10 00 00 00 00 00 08 00 FF 00 4D FF 00 00 00 00 00 00 00 80 00 FF 00 00 00 00
                    Oil temperature: 31.69 °C
                    Clutch Input Speed: 0.0 /min
                    Estimated Transferred Clutch RPM: 0 /min
                    Battery voltage: 13.99 V
                    Vehicle speed: 0.00 km/h
                    Actuator current: 0.00 A
                    Actuator angle: 1.72 °
                    Engine speed: 0.0 /min
                    Bridge Temperature: 30 °C
                    KL15 Status SW: 0
                    KL15Status HW: 1
                    KL15 Status Comb: 1
                    System Condition of error decision manager: 232
                    Status CSM: 1
                    stTC: 7
                    stTCExtdSec: 0
12563 - Databus
          U1121 00 [00101111] - Missing Message
          [Brake_control_unit_to_eps_40]
                    Fault Frequency: 14
                    DID: 64768
                    Occurrence Counter SLC: 14
                    Error Event Number: 113
                    Event Triggers Current Backup Function: false
                    Origin System Up Counter: 28716
                    Most Recent System Up Counter: 502
                    Origin Operation Cycle Counter: 5
                    Error specific Freeze Frame raw data: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                    Oil temperature: 0.00 °C
                    Battery voltage: 0.00 V
                    Actuator angle: 0.00 °
                    Bridge Temperature: 0 °C
                    KL15 Status SW: 0
                    KL15Status HW: 0
                    KL15 Status Comb: 0
                    System Condition of error decision manager: 0
                    Status CSM: 0
                    stTC: 0
                    stTCExtdSec: 0
   Serial number: 012WEOT
   Coding: 00010100
                    DID: 64768
                    Occurrence Counter SFF: 11
                    Most Recent Operation Cycle Counter: 46
                    Error specific Freeze Frame raw data: B3 25 10 00 00 00 00 00 08 00 FF 00 E4 00 00 00 00 00 00 00 00 80 00 FF 00 00 00 00
                    Oil temperature: 31.44 °C
                    Battery voltage: 14.05 V
                    Actuator angle: 1.97 °
                    KL15 Status SW: 0
                    KL15Status HW: 1
                    KL15 Status Comb: 1
                    Status CSM: 1
                    stTC: 7
                    stTCExtdSec: 0
12563 - Databus
                    Fault Frequency: 13
                    Mileage: 194370 km
                    Date: 2024.08.21
                    Time: 13:38:40
                    DID: 64768
                    Occurrence Counter SLC: 13
                    Origin System Up Counter: 22801
                    Oil temperature: 30.50 °C
                    Battery voltage: 12.05 V
                    Actuator current: -0.00 A
                    Actuator angle: -1.95 °
                    KL15 Status SW: 1
                    KL15Status HW: 1
                    KL15 Status Comb: 1
                    System Condition of error decision manager: 233
                    Status CSM: 1
                    stTC: 4
                    stTCExtdSec: 275
End----------(Elapsed Time: 02:36, VBatt start/end: 12.2V/12.2V)-----------
   #28
iichel
C?ID=284912
just to tidy it all up:
- I think it needs the 3Q0 AK ABS ecu for the torque splitter
- 3Q0 AK ABS ECU needs simos 19 engine controller
So I made a shortcut (emulator) to make it all work and add the missing can messages.
VIN mismatch: disconnect engine controller and reset chassis number via basic settings, SA 20103
dtc_ecuvar mismatch: disconnect engine controller and cycle ignition, SA 20103
clutch basic settings: engine on, all wheel drive control motor basic setting, SA 20103
just discovered the 2025 S3 will also offer the torque splitting rear diff: https://www.hagerty.com/media/news/...olf-rs-trick-diff-america-cross-your-fingers/
So cars with the rear diff:
MY2021+ VW Tiguan R
MY2021+ VW Arteon R
MY2020+ VW Golf 8R
MY2020+ Audi RS3 8Y
MY2025+ Audi S3
MY2018 VW Passat R-line :D
Monday,28,April,2025,09:19:49:11868
VCDS Version: 25.3.1.1 (x64)  HEX-V2 CB: 0.4671.4
Data version: 20250415 DS365.0
Workshop Code: 108 31889 005361
VIN: WVWZZZ3CZJEiichel   License Plate:
6C-Back-up Cam. --OK 0000
D6-Light Ctrl Left 2 -- OK 0000
D7-Light Ctrl Right 2 -- OK 0000
8126-Trq distrib RearL axle -- Status: OK 0000
8127-Trq distrib RearR axle -- Status: OK 0000
   Coding: 0925003A2476050B3004
   VCID: 313FE88591ABBF42304-8064
Readiness: 0010 0000
   Part No SW: 0DL 300 012     HW: 0BH 927 711 F
   Component: GSG DQ500     H10 5301
   Revision: 00H10V01    CVN: B537C3CB
   ROD: EV_TCMDQ500021.rod
   VCID: 66954BD968E528FA156-8032
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-VWR-V1.clb
   Part No SW: 5Q0 614 517 GS    HW: 5Q0 614 517 BP
   Component: ESC           H35 0993
   Revision: 00000000    Serial number: 60863000000564
   Coding: 0FEC6B8F54222371477D070540CB69F0D62AC4E2E00296758842508842A94A000000000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100VWR.rod
   VCID: 0849656142B1DE8AC7A-805C
   Coding: 1F20200727
   VCID: 48C9A56102311E8A07A-801C
   ROD: N/A
   VCID: 3C21C9B146E9422A932-8068
No ASAM data for: "EV_SeatMemorPasseSide" (VW48)
   Coding: 12010024104411011115500D0018592A
   VCID: 3E25C3B950F5503ABD6-806A
   Air quality sensor:
   Coding: FFFFFF
   ROD: EV_BCMBOSCH_022_VW27.rod
   VCID: 3829D5A172D16E0A77A-806C
   Coding: 0F4DFD
   Coding: 02005D
   Coding: 8A79267951
   VCID: 59EF7025A99B9702A84-800C
   Coding: 351F5FFBDFFFCF28979F813681500D800000000000B9C00032
   VCID: 47CBA65D0F2F11F20E0-8012
   VCID: 392FD0A549DB7702884-806C
   VCID: 0E45537920D580BA0D6-805A
   Coding: 80000D
   Coding: 80000D
   Coding: 8410
   VCID: 2A0DFFE9BC7DCC9AF1E-807E
   Coding: 9309
   Shop #: WSC 00046 123 12345
   VCID: 7F5BFEBD177F9932F60-802A
   Generator:
   Subsystem 2 - Part No SW: 1EA 959 442 C    HW: 1EA 959 442 C
   Component: MFL  H03 0217
   Serial number: 17038315050562101970
   Coding: AF0B00
   Analog clock:
   VCID: 71BF2885512BFF42704-8024
   ROD: EV_SeatMemorDriveSide_002_VW48.rod
   Coding: 62954640
   ROD: EV_DCU2DriveSideMAXHKLO_VW37.rod
   VCID: 4ACD9F691C3DEC9A11E-801E
   Dataset Number: V03935339RG 0001
   Coding: 93070000
   VCID: 6B833AED730715924A8-803E
   ROD: EV_MultiModulContiVW48X_001_VW37.rod
   VCID: 72BD2789542DC45A89E-8026
   Coding: E02400
   Coding: E02400
   ROD: EV_DCU2PasseSideMAXHKLO_VW37.rod
   VCID: 49CFA065193BE782184-801C
   VCID: 3431E1916EB98A6A5B2-8060
   VCID: 42DDB749240D34DAD9E-8016
   Part No SW: 5Q0 907 556 E    HW: 5Q0 907 556 E
   Component: Areaview 2    H34 0617
   Serial number: C855711JV003395 Dataset Number: V03935374AY 0001
   Shop #: WSC 33000 790 00534
   VCID: 3B23CAAD43E745129A8-806E
   Coding: 02A8
   VCID: 46D5AB59082508FAF56-8012
   ROD: EV_MFK3ValeoMQB_007_VW48.rod
   VCID: 3635DB9978C5987A656-8062
   VCID: 4CC199711649F2AA232-8018
   VCID: 372BD69D7FCF61727E0-8062
   VCID: 16753B191805787A456-8042
   Coding: 00101000
   VCID: 3333E28D6BB78D52428-8066
   Coding: 00010100
End----(Elapsed Time: 02:32, VBatt start/end: 12.6V/11.8V. VIgn 11.8V)-----
------------------------------0 Faults Found------------------------------
@Ross tech
As per VW wiring diagram, the left torque splitter is called J1257 and the right one is called J1258, could we get those names in the autoscan too?
This is from the Arteon Component Location pdf:
Eric
HC800000
The J-number (also "workshop name") comes from querying the module, not something hardcoded in VCDS.
