I have recently installed a Westfalia removable tow bar with the Trail-Tec CAN module. That all went easy enough.
I coded the following after install and then cleared all faults. All have cleared except for a few. Any idea what I may have missed or messed up.
These are the steps I took so far
Now I am left with 2 faults codes, see attached log. There are no faults on the dash and everything appears to be working normally. Anyone have any idea how to resolve this.
- Initialise 69(trailer module)
- Control Unit 09 (ACC) - Byte 13 Bit 4 ticked
- Control Unit 17 (Dashboard) - Nothing changed
- Control Unit 6D (Deck Lid Control) - Byte 01 Bit 7 ticked
Friday,17,November,2023,09:44:18:37956
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 arm64(arm64 CPU)(VMWare)
VCDS Version 23.11.0.0 (arm64) HEX-NET CB: 0.4643.4
VIN: WVGBD1A12PV721813 License Plate:
Mileage: 6754km-4196mi Repair Order:
Chassis Type: A1-VW27 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 2B 3C 42 44 4B 52 5F 69 6D
75 BB BC D6 D7
VIN: WVGBD1A12PV721813 Mileage: 6754km-4196miles
BB-Door Rear Drv -- Status: Cannot be reached 0100
BC-Door Rear Pass -- Status: Cannot be reached 0100
Address 01: Engine (J623-DJKA) Labels: None
Part No SW: 04E 906 025 AF HW: 04E 907 309 DM
Component: R4 1.4l TFS H20 9971
Revision: DPH20000 CVN: A6759859
Coding: 012A003223641D083000
Shop #: WSC 00016 035 00180
ASAM Dataset: EV_ECM14TFS01104E906025AF 002003
ROD: EV_ECM14TFS01104E906025AF.rod
VCID: 6680B7A599F389A159-8033
VINID: 9E65D25014410A09870812010C824091A6
Address 02: Auto Trans (J217) Labels: None
Part No SW: 09S 927 158 BK HW: 09S 927 158
Component: AISIN 8G30/18 301 3697
CVN: 118638D8
Coding: 0100000100000000010000000000000000000000
Shop #: WSC 00016 035 00202
ASAM Dataset: EV_TCMAQ300031 001009
ROD: EV_TCMAQ300031_VW27.rod
VCID: 095A9C19A8AD06D994-805D
Part No SW: 5Q0 614 517 GE HW: 5Q0 614 517 BS
Component: ESC H82 0114
Revision: 00000000 Serial number: 61063000000723 Dataset Number: V03935352LR 0001
Coding: 46FA6A7D9022246DC57F060162C62562560924A36046A4723841F578D2824B0B00000523525212121035351919323200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 049015
ROD: EV_Brake1UDSContiMK100IPB_049.rod
VCID: 7AB8F3D5FD4B1D418D-802F
Part No SW: 3Q0 959 435 Q HW: 3Q0 959 435 Q
Component: VWKESSYMQB 037 1400
Revision: 00037000 Serial number: 0620460688 Dataset Number: V03935358XU 0001
Coding: 032C2C070F
Shop #: WSC 00016 035 00114
ASAM Dataset: EV_KessyHellaMQBAB 004055
ROD: EV_KessyHellaMQBAB.rod
VCID: 48DC591DF327BFD14B-801D
Subsystem 1 - Part No SW: 3G0 962 243 D HW: 3G0 962 243 D
Component: GEB.F.Heckoef H17 0908
Serial number: 44146329
Part No SW: 2GA 907 044 A HW: 2GA 907 044 A
Component: Climatronic H10 0221
Dataset Number: V03935354ZE 0001
Coding: 060200042001100D100500001010D032
ASAM Dataset: EV_AirCondiBHTCMQB3rTranc 002004
ROD: EV_AirCondiBHTCMQB3rTranc_002_VW37.rod
VCID: 33261EF19AA12C090E-8067
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q1 937 084 A HW: 5Q1 937 084 A
Component: BCM MQBAB M+O H44 0512
Serial number: 02102311401875 Dataset Number: V03935394NA 0001
Coding: 000000000000000000000000001000000000000000000000000000000000
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_BCMMQB 022001
ROD: EV_BCMBOSCH_022_VW27.rod
VCID: 373E2AE18ED9C02932-8063
Subsystem 1 - Part No SW: 5Q0 955 547 C HW: 5Q0 955 547 C Labels: 5Q0-955-547.CLB
Component: RLHS 054 0206
Serial number: S7Y23M04D21H12M26S38
Coding: 0018DD
Steering Column Switch:
Subsystem 2 - Part No SW: 5Q1 953 521 KF HW: 5Q1 953 569 H
Component: Lenks.Modul H04 0190
Serial number: 0100030520230C204050
Part No SW: 5QA 919 298 K HW: 5QA 919 298 A
Component: PLA 3.0 12K H10 0075
Serial number: 000150057323122 Dataset Number: V03935360WN 0001
Coding: 8271165951
ASAM Dataset: EV_EPHVA2CAU3700000 009055
ROD: EV_EPHVA2CAU3700000_010_VW37.rod
VCID: 58FC895D23872F51DB-800D
Part No SW: 2Q0 907 572 AA HW: 2Q0 907 572 D
Component: ACCCONTIMQB H09 0396
Dataset Number: V03935360JY 0001
Coding: 3000071B58FF8448949C810480308700000000000000000004
ASAM Dataset: EV_ACCMRRCONTIVW376 003018
ROD: EV_ACCMRRCONTIVW376_003.rod
VCID: 73A6DEF1DA216C09CE-8027
Part No SW: 5Q0 959 655 CF HW: 5Q0 959 655 CF
Component: AirbagVW21 011 0421
Serial number: 003J8R9MFAL5 Dataset Number: V03935371QB 0001
Coding: 88CCC0C0000000005C5400CF004800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002166
ROD: EV_AirbaVW20SMEVW37X_VW27.rod
VCID: 06409725B9B369A1F9-8053
Subsystem 1 - Part No SW: ----------- HW: 480 001 404 23
Serial number: 357000000009C448676S
Subsystem 2 - Part No SW: ----------- HW: 480 001 404 23
Serial number: 358000000000A76DB66W
Subsystem 3 - Part No SW: ----------- HW: 480 052 104 23
Component: SideSensor_Dr 000 0149
Serial number: 35100007AC257607C7A8
Subsystem 4 - Part No SW: ----------- HW: 480 052 104 23
Component: SideSensor_Pr 000 0149
Serial number: 35200007EC716345481$
Subsystem 5 - Part No SW: ----------- HW: 480 052 004 23
Component: FrontSensor_D 000 0149
Serial number: 355000092C470C0C0AD8
Part No SW: 2GJ 920 310 B HW: 2GJ 920 310 B
Component: KOMBI 065 4848
Coding: 05A400182F880008018862291001000100000908
ASAM Dataset: EV_DashBoardJCIMQBAB 010007
ROD: EV_DashBoardJCIMQBAB_010_VW27.rod
VCID: 34241DED9FAF2B3117-8061
16776996 - Databus
[FCW_01 keine Kommunikation]
Mileage: 6735 km
Date: 2023.11.17
Time: 00:51:45
Part No SW: 3Q0 907 530 AR HW: 3Q0 907 530 G
Component: GW MQB High 527 5504
Serial number: 24042310521549 Dataset Number: V03935383ZM 0001
Coding: 030100046F085708220002581C0F00010001070000000000000000000000
GVL: 01463C0008000600C04C80008000C80000000000000200000000000000000000
ROD: EV_GatewNF_VW27.rod
VCID: 7F4E02C1E6693869BA-802B
Generator:
Component: 4-01-13-01-04
Subsystem 2 - Part No SW: 3G0 959 442 AB HW: 3G0 959 442 AB Labels: 3C8-959-537.CLB
Component: E221__MFL-PR6 H07 0120
Serial number: PR6-0440071095234848
Coding: 2C2900
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Component: J367-BDMHella H11 9070
Serial number: 7764301806
131655 - No Communication with Towing System Control Module (J345)
U1003 00 [00001000] - -
[Timeout Knoten 0x47 / 69 - Steuergerät für Anhängererkennung]
Reset counter: 153
Mileage: 6754 km
Date: 2023.11.17
Time: 01:04:16
Terminal 30 power supply: 12.6 V
Terminal 15: OFF
8531970 - Quiescent Current
U1406 00 [00001000] - Too High
[Ruhestrom oberer Grenzwert überschritten]
Reset counter: 153
Mileage: 6754 km
Date: 2023.11.17
Time: 07:34:42
Terminal 30 power supply: 12.4 V
Terminal 15: OFF
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 2Q0 905 861 A HW: 2Q0 905 861 A
Component: ELV-MQBB H10 0021
Serial number: 23000066169002 Dataset Number: V03935272PH 0001
Coding: 0800000000000000
ROD: EV_ELVMarqMQBA0_VW27.rod
VCID: 312A14F960BD1E197C-8065
Address 3C: Lane Change (J1086) Labels:* None
Part No SW: 2Q0 907 686 B HW: 2Q0 907 686 B
Component: HRE3_Kl15_Mst H06 0150
Serial number: 14520025577478 Dataset Number: V03935363XP 0001
Coding: 52954640
ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
ROD: EV_HREntryHellaGen3Kl15.rod
VCID: 393A2CD9B8CDD659C4-806D
Subsystem 1 - Part No SW: 2Q0 907 685 B HW: 2Q0 907 685 B
Component: HRE3_Kl15_Slv H06 0150
Serial number: 14520025642765
Part No SW: 5Q4 959 593 R HW: 5Q4 959 593 R
Component: TSG FS 002 0031
Serial number: 0000495248331 Dataset Number: V03935376ZZ 0001
Coding: 003B1B20D000028008001000
VCID: 54E47D6D3F6F0B3137-8001
Subsystem 1 - Part No SW: 5Q0 959 407 D HW: 5Q0 959 163 C
Component: FOND_FHSG_DRV 007 0011
Serial number: 00000000000070267387
Address 44: Steering Assist (J500) Labels:| 5WA-907-14X-V1.clb
Part No SW: 5WA 907 144 Q HW: 5WA 907 144 C
Component: BASGEN1MQB37 102 1063
Serial number: 02265923 Dataset Number: V03935373PH 0001
Coding: 01000100000000000001020101000100000001010100
ASAM Dataset: EV_SteerAssisBASGEN1MQB37 010058
ROD: EV_SteerAssisBASGEN1MQB37_010_VW27.rod
VCID: 57FE8A612E992029D2-8003
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 G HW: 3Q0 907 338 K
Component: FCM MQB Low 005 0382
Serial number: 25042310801842 Dataset Number: V03935364UC 0001
Coding: 0000000709004542000025100A0000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 004006
ROD: EV_MultiModulContiVW48X_004_VW27.rod
Part No SW: 5Q4 959 592 R HW: 5Q4 959 592 R
Component: TSG BFS 002 0031
Serial number: 0000495397657 Dataset Number: V03935367YA 0001
Coding: 003B1120DC00028000001000
VCID: 53E67E713A610C092E-8007
Subsystem 1 - Part No SW: 5Q0 959 408 D HW: 5Q0 959 164 C
Component: FOND_FHSG_PSG 007 0011
Serial number: 00000000000070107089
Coding: 190000
Part No SW: 3G9 035 824 D HW: 3G9 035 824 D
Component: MU-O-ND-R1 H22 0306
Serial number: VWZAZ2B0793421 Dataset Number: V03935363RB 0001
Coding: 22760000000020000000000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB 001001
ROD: EV_MUOIMQB_001_VW27.rod
VCID: 2D1208897C857AF958-8079
Subsystem 1 - Part No SW: 5NN 919 605 B HW: 5NN 919 605 B
Component: ABT_Std-2_Nav 381 8304
Serial number: VWZ6ZHB1021369
Subsystem 2 - Part No: V03 959 817 TB
Component: MRM 2023 8073
Part No SW: 5Q0 907 383 E HW: 5Q0 907 383 B
Component: Anhaenger H14 0137
Serial number: 0356562488
Coding: 0100000200000000
Shop #: WSC 01286 386 08256
ROD: EV_TrailFunctGener2Hella_VW27.rod
Part No SW: 5WC 959 107 A HW: 5WC 959 107 A
Component: HDSG-Modul H05 0433
Revision: -------- Serial number: A2-C767-1161-5 Dataset Number: V03935400MV 0001
Coding: 1C88
ASAM Dataset: EV_DeckLidCONTIAU536 001002
ROD: EV_DeckLidCONTIAU536_VW27.rod
VCID: 4FEE7201164968E90A-801B
Part No SW: 5WA 035 284 G HW: 5WA 035 284 B
Component: OCUGen3High H22 0143
Serial number: 0000000304VIXF7 Dataset Number: V03935363DJ 0001
Coding: 022760001868A8209005460100400607
ASAM Dataset: EV_OCUGen3High 003007
ROD: EV_OCUGen3High_003_VW27.rod
VCID: 4AD86315ED2B4DC15D-801F
Address BB: Door Rear Drv
Address BC: Door Rear Pass
Part No SW: 992 941 571 AE HW: 992 941 571 A
Component: LED1L H08 9202
ROD: EV_LLPGen3LKEBODPO68X_001_VW27.rod
VCID: 6582B0A964F582B950-8031
Component: LED1R H08 9202
End----------(Elapsed Time: 01:43, VBatt start/end: 12.8V/12.8V)-----------
