Resolved Bentley Continental 04 Wet KESSY
Resolved
scoper
South, UK
C?ID=525167
Working on a Bentley Continental, water drains under ECUs in the scuttle got blocked whole area under 4" of water. Leaked down to the KESSY in the floor pass floor (RHD), - KESSY destroyed no Ign/start action.
As per this thread : https://forums.ross-tech.com/index.php?threads/15997/ despite that being a later car, it has a very similar module except his is 3D0 909 137 F and mine is 3D0 909 135 L. EEPROM chip is the same so took it off the board, and copied the data, swapped it into a numbers matched used unit. No joy - still "immo on" on the dash and nothing else except radio, interior lights and door locks (not on fob)
Have checked all fuses and that the KESSY has all P+G. - Have factory WD.
Put Gnd and B+ to various wires on the KESSY to activate T15, ECU, acc relays, got the dash lit up ok, did an auto scan, cleared codes and did it again:
Tuesday,17,October,2023,17:11:18:34176
VCDS Version: 23.3.1.0 (x64)  HEX-V2 CB: 0.4631.4
Dealer/Shop Name: REMOVED
Chassis Type: 3W - Bentley Continental (2004 > 2007)
Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 26 28 34 36
          37 38 46 47 53 54 57 65 66 68 69 6C 71 75 76 77
Address 02: Auto Trans        Labels: 09E-927-156.lbl
   Part No SW: 09E 927 760 A    HW: GS1 904 1
   Component: AG6 09E 6.0L W12TT  1004
   Coding: 0000101
   Shop #: WSC 00083 000 00000
   VCID: 2E05030A2C0F1D7AAD7-513C
18274 - Powertrain Data Bus
            P1866 - 000 - Missing Messages
                    (no units): 30.0
                    (no units): 25.0
                    Temperature: 17.0°C
                    T.B. Angle: 60.0°
                    Voltage: 12.32 V
Address 03: ABS Brakes        Labels: 3W0-614-517-V1.lbl
   Part No: 3W0 614 517 B
   Component: ESP 5.7 4WD     H02 0011
   Coding: 0007878
   Shop #: WSC 95147 000 00000
   VCID: 34311162C22337AADB3-51CE
Address 05: Acc/Start Auth.        Labels: None
   Part No SW: XXXXXXXXXX      HW: 5WK 4
   Component:    Kessy            6400
   Coding: 0000000
   VCID: 70B9DD72F6BB4B8AFFB-5160
00003 - Control Module
            014 - Defective
00185 - Control Circuit; Relay for Supply Voltage Terminal 15
            009 - Open or Short to Ground
Address 08: Auto HVAC        Labels: 3W7-907-040.clb
   Part No: 3W0 907 040 A
   Component: Climatronic BY614   0030
   Coding: 0000001
   Shop #: WSC 98765 666 30877
   VCID: 2F3B1E0E2B051472A61-5160
Address 09: Cent. Elect.        Labels: 3D0-937-049-V1.clb
   Part No: 3D0 937 049 G
   Component: STG.Bordnetz        5001
   Coding: 0000107
   VCID: 2E05030A2C0F1D7AAD7-5160
No Faults Found
Address 16: Steering wheel        Labels: 3D0-953-549.lbl
   Part No: 3D0 953 549 E
   Coding: 0000212
Address 36: Seat Mem. Drvr        Labels: 3W0-959-759.clb
   Part No: 3W0 959 760 A
   Component:    CM Seat Driver   0008
   Coding: 0000002
   Shop #: WSC 95147 753 45725
   VCID: 3FDB4E4EFB65E4F2361-5160
01895 - Motor for Steering Column Adjustment; Vertical (V123)
Address 37: Navigation        Labels:
   VCID: 55F78CE66C090EA20CD-5160
   Note: Excessive Comm Errors
Address 38: Roof Electronics        Labels: None
   Part No: 3W0 907 135 C
   Component: Dachmodul           0702
   Coding: 0000157
   VCID: 36352B6AD45F25BAE57-5160
00205 - Garage Door Opener Indicator Lamp (K179)
            007 - Short to Ground
Address 46: Central Conv.        Labels: 3D0-959-933.clb
   Part No: 3D0 959 933 E
   Component:    HSG              3211
   Coding: 0000032
   VCID: 323D177A3837399AC9F-4B00
   Subsystem 1 - Part No: 3W2 959 701
   Component: Tuersteuergeraet FS 0702
   Subsystem 2 - Part No: 3W2 959 702
   Component: Tuersteuergeraet BF 0702
   Subsystem 3 - Part No: 3W3 959 703
   Component: Tuersteuergeraet HL 0702
   Subsystem 4 - Part No: 3W3 959 704
   Component: Tuersteuergeraet HR 0702
   Subsystem 5 - Part No: 7L0 907 719
   Part No: 3W0 035 456 B
   Component: 12K-AUDIOVERST      4120
   VCID: 3333127EC72D3092C29-5160
Address 53: Parking Brake        Labels: 3W0-907-801.clb
   Part No SW: 3W0 907 801 A    HW: 4E0 907 801
   Component: EPB  BC6HX21    HC6 X210
   Coding: 0022413
   Shop #: WSC 00125 106 59538
   VCID: 34311162C22337AADB3-513C
01312 - Powertrain Data Bus
                    Fault Status: 11100000
                    Reset counter: 3
                    Voltage: 11.49 V
                    Count: 20
01019 - Relay
                    Reset counter: 3
                    Voltage: 11.49 V
                    Count: 53
Address 54: Rear Spoiler        Labels: 1C0-959-733.lbl
   Part No: 1C0 959 733 G
   Component: Heckspoiler         0002
   VCID: 2F3B1E0E2E051472A61-51CE
Address 57: TV Tuner        Labels: 3D0-919-146.lbl
   Part No: 3D0 919 146
   Component: TV Tuner        H07 1205
   Coding: 0000010
   VCID: 6597BC2639799E229CD-5160
Address 65: Tire Pressure        Labels: 3D0-907-273-V2.clb
   Part No: 3D0 907 273 G
   Component: Reifendruckueberw.  0026
   Coding: 0210330
   VCID: 2A0D0F1A10E7715A71F-5160
Address 76: Park Assist        Labels: 3W0-919-283-V1.clb
   Part No: 3W0 919 283
   Component: 02 Einparkhilfe     0203
   VCID: 7AADFF5AA0C701DA41F-5160
Address 77: Telephone        Labels: None
   Part No: 3W0 035 729 C
   Component: Telefon             0241
   VCID: 372B266ED355DCB2FE1-5160
End----(Elapsed Time: 08:51, VBatt start/end: 12.6V/12.6V. VIgn 0.0V)------
The KESSY had no data in it at all (as per scan above), though I could talk to it with teh IM508 and no keys were seen in the car. So I went back to it today having swapped the physical chip into the used unit, still no ign but now when I scan it I have more ID but no coding.
Friday,17,November,2023,16:21:09:34176
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
Dealer/Shop Name: Removed
VIN:    License Plate: BENTLEY
Mileage:    Repair Order: kessy  chip swap
                Address 25: Immobilizer       Labels: NONE
Control Module Part Number: XXXXXXXXXX      HW: 5WK 4
  Component and/or Version:    Kessy            6400
           Software Coding: 0000000
            Work Shop Code: WSC 00000 000 00000
           Additional Info: 4E0905852C  ELV                 1734
           Additional Info: Geraet 00000
                      VCID: 70B9DD72F6BB4B8ADF3-5160
            014 - Defective
01176 - Key
There is an autoscan on here of an 04 UK car so tried to enter that coding but it would not take it "incorrect number or procedure" - probably as there are codes set in it, or possible as I have not been able to get security access - Does anyone know the security number, tried a couple off here but no joy.
I did use an IM508 to extract the CS code and the 5 digit PIN from the ECU when I had the ign on last time.
Not sure why the coding is not there unless it was wiped when the KESSY got wet.
Looking for suggestions on best way forward please
EuroX
Northern NJ USA
C?ID=208579
In such old car, best to pull pin from dash or ecm then pull pin from donor kessy and match kessy via VCDS using pin. Althought eeprom swap normally works sometimes its not full proof. Do you have eeprom dump?
FYI cluster is the gateway in this vehicle.
scoper
South, UK
C?ID=525167
Thanks.
Pulled the ECU pin + CS with a IM508 - not sure how to use it ? do I add two zeros to the front and use it as the 7 digit security access?
That will be a "no" then ! https://www.ross-tech.com/vcds/tour/pin-skc.php
I got the data off the eeprom with both the IM508 and then later VVDI, this is IM508:
The donor has the eeprom soldered in it so theoretically should be the same ?
Is this procedure likely to work if I use the same PIN for old and new?
followed by
EuroX
Northern NJ USA
C?ID=208579
What pin code did you get 46978? Is the dump from a donor kessy? It looks to be blank mostly. No keys no immo id no vin no nothing.
scoper
South, UK
C?ID=525167
That's the dump from the original, that's now soldered into the donor that's in the car. I did think the scan looked odd with no data in it.
PIN pulled from the car 01426
edit - I see what you mean, this is the dump from the used/donor kessy - same numbers but off a Touareg I think, before I put the Bently dump on it. When that did not work I moved the chip.
I have got the PIN from the above donor file, written the file back to the donor chip, and I'm going to swap the donor chip back in to the KESSY then follow the VCDS procedure.
Do you think the data has been removed previously to immo off the car as the VIN seems to have been replaced with X's - This was a running driving vehicle until left in the rain.
EuroX
Northern NJ USA
C?ID=208579
It is possible that data was manipulated and immo status set to mode 6 in order for the vehicle to run, and the keys written in manually. As the dump above looks to be complete with all relevant data available. For this dump I would try one of these pins 05255 or 37369.
scoper
South, UK
C?ID=525167
Thanks for your help. Let you know how it goes!
scoper
South, UK
C?ID=525167
Well it was a mission but got it going finally.
Took 3 goes to get the original ECU Pin to take, and then it just did - no idea why it didn't first time.
Tried to match two keys but not having it, then went through the IM508 with just 1 key, that would crank start die and say learnt successfully but as soon as the key came out or I tried to crank it, it would be back to "Immobiliser on". In the end just left it in the ign on for 30 mins and it took :)
Only 1 key at this moment but quit whilst I was ahead as the car starts and runs on the key.
There is no fob action though not investigated, but also there is no detection of the key in the car unless in the ignition
I have codes set in the KESSY for broken antennas:
   Part No SW: 3D0 909 135 L    HW: 5WK 470 22
   Coding: 0147688
   Shop #: WSC 31414 000 00000
   VCID: 2E05030A2C0F1D7A8DF-5160
   Subsystem 1 - Part No: 4E0 905 852 C
   Component: ELV                 1734
00955 - Key 1
            002 - Lower Limit Exceeded
00179 - Access/Start Authorization Antenna; Drivers Side (R134)
00180 - Access/Start Authorization Antenna; Passenger Side (R135)
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
Either these were fried by the KESSY or does the KESSY need coding - it's numbers matching but from a Touareg, obviously no coding from dead KESSY as it was dead!
Looking in here for 04 Auto scans I find a bunch, the two with nearest last 5 on the VIN have the same coding
Current
04 UK Coding: 0147688 VIN: SCBCE63W34C0 20140
Others
04 UK Coding: 0159981 VIN: 27726
04 UK Coding: 0155885 VIN: 25106
04 UK Coding: 0422125 VIN: 21039
04 UK Coding: 0422125 VIN: 20479
However I note in the WD that the Antennas changed prior to VIN 20300 - If I re-code this am I going to start again with the immo ?
scoper
South, UK
C?ID=525167
Following on from getting this Bentley running with 1 key and only in the ignition following a flooded KESSY the owner would now like me to finish it off so that the keyless ign/opening works. Back story : https://forums.ross-tech.com/index.php?threads/40183/post-331181
I have codes set in 05 Immo/KESSY for all the antennas not working and I am looking for guidance on if this is a coding/immo issue or all destroyed antenna's or the amp.
I did change the coding to 0155885 that I found on here for several UK vehicles (used unit was from Germany) , I tried 0422125 which I found for vehicles closer in age but not accepted. No difference.
This is autoscan after clearing and changing the KESSY coding (battery was allowed to go flat so when I got there the autoscan was full of LV issues) I did sort out the SAS as well
Friday,23,February,2024,11:12:31:34176
Dealer/Shop Name:
VIN: SCBCE63W34C020140   License Plate:
Chassis Type: 3W (3W - Bentley Continental (2004 > 2007))
VIN: SCBCE63W34C020140   Mileage: 63420km-39407miles
Address 01: Engine        Labels: 07C-906-018-BEB1.clb
   Part No SW: 07C 906 018 H    HW:
   Component: BY-6.0L-TT      G  ª5415
   Coding: 0000173
   Shop #: WSC 00000 000 08192
   VCID: 2A0D0F1A10E7715A517-513C
   VINID: 8D34935460E70C44C0080044008EC261FD
18331 - Please Check DTC Memory of ECU Number 2
            P1923 - 008 -
Readiness: 0110 1101
   Coding: 0000101
   VCID: 2E05030A2C0F1D7A8DF-513C
   Coding: 0007878
   VCID: 34311162C22337AAFBB-51F2
   Coding: 0155885
Address 06: Seat Mem. Pass        Labels: 3W0-959-759.clb
   Part No: 3W0 959 759 A
   Component:    CM Seat Pass.    0009
   Coding: 0000002
   VCID: 47CB56AEA3B5AC32AE9-5160
02343 - Backrest Locking Switch (E446)
02569 - Control Module for Massage (J740)
Address 07: Control Head        Labels: 3D0-035-00x-07.lbl
   Part No: 3W0 035 007 G
   Component:    ZAB COCKPIT      0220
   Coding: 0400335
   VCID: 30391D72363B0B8A9F3-5160
   Coding: 0000001
   VCID: 2F3B1E0E2B051472869-5160
   Coding: 0000107
No Faults Found
Address 11: Engine II        Labels: 07C-906-018-BEB2.clb
   Coding: 0000173
   Part No: 3D0 909 601 D
   Component: 0H Airbag 8.4E+ H07 0936
   Coding: 0012360
   VCID: 2411E12272C3A72A6BB-5160
   Coding: 0000212
Address 17: Instruments        Labels: 3Wx-920-xxx-17.clb
   Part No: 3W0 920 840 M
   Component: KOMBIINSTRUMENT RB4 0401
   Coding: 0021400
   VCID: 3E25334AFC6FEDFA1DF-5160
   Part No: 6N0 909 901
   Coding: 0000006
Address 34: Level Control        Labels: 3D0-907-553-V1.clb
   Part No: 3W0 907 553
   Component: LUFTFDR.-CDC- 3C1V0 7014
   Coding: 0015500
   VCID: 77ABE66E93D51CB21E9-5160
   Coding: 0000002
   VCID: 3FDB4E4EFB65E4F2169-5160
Address 37: Navigation        Labels: None
   Part No: 3W0 919 887 B
   Component:    NAVIGATION       0168
   Coding: 0400000
   VCID: 46D55BAAA4BFB53A55F-5160
   Coding: 0000157
   VCID: 36352B6AD45F25BAC5F-5160
   Component:    HSG              3211
   Coding: 0000032
   VCID: 323D177A3837399AE97-4B00
01516 - Terminal 30; Left
   VCID: 3333127EC72D3092E21-5160
   Coding: 0022413
   VCID: 34311162C22337AAFBB-5160
   VCID: 2F3B1E0E2E051472869-51F2
   Coding: 0000010
   VCID: 6597BC2639799E22BC5-5160
   Coding: 0210330
   VCID: 2A0D0F1A10E7715A517-5160
Address 68: Wiper Electr.        Labels: 3Wx-955-023.clb
   Part No: 3W2 955 023 C
   Component: WischeZ
   Shop #: WSC 00000 725 65552
   VCID: 372B266ED355DCB2DE9-5160
Address 71: Battery Charger        Labels: 3D0-915-181.lbl
   Part No: 3D0 915 181 A
   Component: Batteriemanagement  2500
   VCID: 211FE8366DD1B20200D-5160
   VCID: 7AADFF5AA0C701DA617-5160
End----(Elapsed Time: 08:40, VBatt start/end: 12.1V/12.1V. VIgn 0.0V)------
However the re-code didn't sort the antenna's and this is what I am left with (LV stuff removed for clarity)
Control Module Part Number: 3D0 909 135 L    HW: 5WK 470 22
           Software Coding: 0147688
            Work Shop Code: WSC 31414 000 00000
           Additional Info: XXXXXXXXXXX ELV                 XXXX
10 Faults Found:
00182 - Luggage Compartment Access/Start Authorization Antenna (R137)
00955 - Key 1
01176 - Key
I notice that there is no VIN or Immo ID in the additional info , group23 shows the immo status as 6 indicating I believe as "all good". https://www.ross-tech.com/vag-com/cars/Immo3-measuring-blocks.html
EDIT Just realised looking at this that although I have 3 dead antennas (doors, bumper and luggage) the WD shows 3 other interior antennas.
EuroX
Northern NJ USA
C?ID=208579
Address antenna issue.
scoper
South, UK
C?ID=525167
err yes, that's the question - physical antenna issue or software/coding
EuroX
Northern NJ USA
C?ID=208579
This vehicle had water in it. What would make you think this is a coding issue? This module clearly has soft coding written into it. So I would say unfuck the water damage and all will be well.
scoper
South, UK
C?ID=525167
...because I have seen it before where multiple things are reported open circuit because the software coding points to a different pin on the module to find the data. Variations of this module are in about 20 VAG models, this was 100% numbers matching but off a Toureg I think.
Codes are set for all external antennas , all open circuit- seems a bit of a coincidence, and I have no key recognition inside the car. Also wondering why I have :
Entirely possible that when the KESSY got wet only the external antennas were powered up and so more likely to fail. AFAIK the internal transponders are supposed to power up on door opening. I don't think that this being a hardware issue is certain.
EuroX
Northern NJ USA
C?ID=208579
@Uwe can we merge threads to have this disaster with all relevant info?
I hate going through 2 different threads, why not just use the original thread?
EuroX
Northern NJ USA
C?ID=208579
   Coding: 0147688
   Component: ELV                 1734
00955 - Key 1
Current
Others
recode of module will not affect immo data. Considering you have standing water in the vehicle please check wiring to kessy and antennas.
scoper
South, UK
C?ID=525167
The footwell was dried out (the only part with water in it) and the KESSY replaced as above.
All plugs/wires inspected + cleaned at the same time.
Going to gain access to one of the offending antennas and see if there is connection/life.
scoper
South, UK
C?ID=525167
FIXED
Added the 2nd key and Keyless entry started working! Battery was low in first and only key I had programmed - even though key signal was the first thing I checked way back when this started.
It would appear that unless the external entry works on the fob then the internal antennas don't work - as the second key (when programmed) did not work for internal detection until I exited, locked+unlocked with it.
Still have codes set for Driver, Passenger+Bumper antennas but it all now works. I checked the luggage area antenna and that no longer sets a code.
Anyway thanks for the help all.
