Resolved Front Right DRL and Rear Left Reverse light not funtioning
Resolved
mk6tdinick
Byron, MI, USA
C?ID=560664
Hey all, When I first acquired this car I had a city light out and a bulb out indicator on the dash. I replaced the bulb and still had the dash notification. I figured it was an issue with the cold diagnostic and I tried to disable it. I messed with Byte 18 and wrote this code (00010101) to the binary that's in this video, initially after I wrote the original byte 18 value back I noticed the reverse light was stuck on and the front DRL had blown the element. Now neither will function. But I did save the original long code and have wrote that back. But I still cannot get the front right DRL and left reverse light to function. Any tips on what I should do to fix this issue? TIA
Wednesday,15,November,2023,11:55:35:60557
VCDS Version: Release 23.3.1 (x64) Running on Windows 11 x64
                Address 09: Cent. Elect.       Labels: 1K0-937-08x-09.clb
Control Module Part Number: 5K0 937 084 G    HW: 5K0 937 084 G
  Component and/or Version: BCM PQ35 B    011 0048
           Software Coding: 2F380E1A802F3EC4008800817000004441000086535D0560648020200040
            Work Shop Code: WSC 00066 000 00000
                      VCID: 36353747F849B56AE57-8062
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 50
                    Mileage: 471971 km
                    Date: 2063.14.31
                    Time: 23:54:29
                    Voltage: 12.05 V
2kaa52
Ceska Republica, Praha
C?ID=319193
Congratulation, you killed your light configuration.
Restore with vcds is Not possible
  • Agree
2kaa52
C?ID=319193
So
Replace j519?
Yes,but only from a Car with exact Same Lights configuration! Or a New one ordered by your VIN.
Or restore the light config manualy with vcp Program or odis-e Program,then you can keep your BCM
mk6tdinick
Byron, MI, USA
C?ID=560664
So the CECM isn't actually electrically damaged?
mk6tdinick
Byron, MI, USA
C?ID=560664
I'm interested in this option, but I know nothing about it. Purchase Odis-E and it can reflash the module? Special cable required? Software come with cable?
I took a quick glance at your email and the factory condition Byte 18 coding of a NAR market 2010 JSW is: HEX 09 Lighting: VW Jetta Variant/Wagon (AJ5/VW362) North American Region (NAR)
That's one of the drop-down menu options in the Long Coding Helper.
mk6tdinick
Byron, MI, USA
C?ID=560664
Thanks for the reply, the chassis is actually a 2012 JSW. Same thing?
Hmm, the scan you sent us has a VIN ending in 9999.
Model jetta variant GOV​
Date of production 15.02.2010​
Year 2010​
Sales type AJ539L​
Engine Code CJAA​
Transmission Code LHD​
If that's not right and the coding doesn't fix it please post the real VIN here.
mk6tdinick
Byron, MI, USA
C?ID=560664
Year 2010​
Sales type AJ539L​
Engine Code CJAA​
It's pulling VIN off of the ECU, it has been swapped to match the engine and manual trans that was swapped into this car that was once DSG.
3VWPL7AJ5CM637146 is the chassis.
mk6tdinick
Byron, MI, USA
C?ID=560664
Fixed. Thanks a million Dana. You guys at Ross-Tech are awesome! 😎
