VW Touareg - rough start- 2017 V6 Tdi 150Kw
ak77
Singapore & Australia
C?ID=232348
Hi There ,
I have noticed an issue with my 2017 TDI V6 Touareg at start-up, which has a very rough idle and started to shake.
I have only started noticing this at a cold start. I scanned the car without any indications or clues from the sensor readings. Could someone point me in the right direction regarding what I should look at?
Please advise .
Cheers
Al
Friday,10,November,2023,05:17:34:41771
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VMWare)
VCDS Version 23.3.1.0
VIN: WVGZZZ7PZHD000954   License Plate: 1234
Mileage: 182587km-113454mi   Repair Order: 000
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 5F 62 69
          6C 6D 72
VIN: WVGZZZ7PZHD000954   Mileage: 182587km-113454miles
Address 01: Engine (J623-CJMA)       Labels:. 059-907-401-V2.clb
   Part No SW: 7P1 907 401 D    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H41 0001
   Revision: 53H41---    CVN: 29B3A68F
   Coding: 292A4012233601020000
   Shop #: WSC 40950 002 1048576
   ASAM Dataset: EV_ECM30TDI0117P1907401D 001002
   ROD: EV_ECM30TDI0117P1907401D.rod
   VCID: 316926E4608A711B74-8065
   VINID: 9E65EAAAA1E0A9850000024510ADC23CBC
Address 02: Auto Trans (J217)       Labels: 0C8-927-7XX-V2.clb
   Part No SW: 0C8 927 755 N    HW: 0C8 927 755
   Component: AL1000 AISIN  130 2877
   CVN: C6F63456
   Coding: 010100011C008400000000000000000000000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_TCMAL991031 003118
   ROD: EV_TCMAL991031_003.rod
   VCID: 3C7707D0B7C88C73D7-8069
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 R    HW: 7P0 907 379 A
   Component: MK25A         H37 0521
   Revision: --------    Serial number: 41216442544132 Dataset Number: 7P0012v____ 0001
   Coding: 5B6B13C349242553DAFDC89892D6A470F701
   ASAM Dataset: EV_MK25AXT 010001
   ROD: EV_ESPMK25A01000.rod
   VCID: 4C975710E7683CF367-8019
   Part No SW: 4H0 907 064 GM    HW: 4H0 907 064 GM
   Component: BCM2 2.0      H37 0572
   Coding: 05B60016000000000000
   VCID: 7AFBC1C8F57C724385-802F
   Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Serial number: 3216000089135005
Address 08: Auto HVAC (J255)       Labels:| 7P6-907-040.clb
   Part No SW: 7P6 907 040 CR    HW: 7P6 907 040 CR
   Component: Klima 2 Zonen H23 1608
   Coding: 36A6200890
   VCID: 0603A538B98406A3F1-8053
   Part No SW: 4H0 907 063 DA    HW: 4H0 907 063 AA
   Component: BCM1 2.0      H20 0311
   Revision: 22020001    Serial number: 00001366973201
   Coding: 26000014D0345D010029400300005D4C431D670827014241000000000040110000000000000000
   VCID: 6ADBF18885DCC2C375-803F
   Subsystem 1 - Part No SW: 7P0 955 120     HW: 7P0 955 120
   Component: WWS    160425  033 0021
   Serial number: 90243401160517144633
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-955-559.CLB
   Component: RLFS  H10 0020
   Serial number: 80834089
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 AB    HW: 7P6 941 431 AB
   Component: E1 - LDS  H02 0040
   Serial number: 00000000002105160067
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475 D    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0030
   Revision: --------    Serial number: 28261613102463
   Coding: 318504
   ASAM Dataset: EV_VW526ParkiAssis2 001013
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 44877F30CF38F4B3AF-8011
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655 F    HW: 7P0 959 655 F
   Component: VW10Airbag00T H10 0044
   Revision: --------    Serial number: 003S8003NBB1 Dataset Number: 7P6003V____ 1681
   Coding: 000000000000000000000000000000003054
   ASAM Dataset: EV_AirbaVW10BPAVW526 002001
   ROD: EV_AirbaVW10BPAVW526_002_VW52.rod
   Serial number: 3575LRB405342FVS1OO5
   Serial number: 3585LRB405942AGA0H7Z
   Serial number: 3517ARB4010554CITJC1
   Serial number: 3527ARB4010554CIK41A
   Serial number: 3557BRB405T42FVU1OSR
   Serial number: 3567BRB405D43C1CQOVX
   Part No SW: 4H0 953 568 M    HW: 7P6 953 507 AC
   Component: Lenks.Modul   H06 0010
   Revision: --------    Serial number: 01374PEL0000T
   Coding: 000C35
   VCID: 3D710AD4A4D2857BE0-8069
   Subsystem 1 - Part No SW: 7P6 959 542 A    HW: 7P6 959 542 A
   Component: E221__MFL-TAS  H04 0028
   Serial number: 0127239 TRW 20160512
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Part No SW: 7P6 920 883 L    HW: 7P6 920 883 L
   Component: Kombi         H13 0604
   Revision: 13240308    Serial number: 658260516592031
   Coding: 332731002A00000800000C
   ASAM Dataset: EV_KombiUDSRBVW526 001030
   ROD: EV_KombiUDSRBVW526.rod
   VCID: 479D683CFE0EDFAB4A-8013
   Part No SW: 7P6 907 530 Q    HW: 7P6 907 530 F
   Component: GW-CAN-L-MOST H15 6051
   Revision: --------    Serial number: 00000002263688 Dataset Number: V03935235BB 0001
   Coding: 000D07AD00
   GVL: FB4F40051D6F000000
   ASAM Dataset: EV_GatewVW526UDS 001008
   ROD: EV_GatewUDS_VW52.rod
   VCID: 46836538F904C6A3B1-8013
   Subsystem 1 - Part No SW: 7P0 915 181 C    HW: 7P0 915 181 C
   Component: Batt_Sensor  H07 0270
   Serial number: 43130627375811043921
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 7PP 959 663 E    HW: 7PP 959 663 E
   Serial number: 16144001859021200181
   Part No SW: 4H0 959 793 AC    HW: 4H0 959 793 P
   Component: TSG FA        H03 0306
   Revision: --------    Serial number: 0000200783054
   Coding: 011D1620D001451005080002
   Revision: 00002001    Serial number: 0405363917
   Coding: 019B1E20A8B9108183200624210000000000000000000000000000000000
   Subsystem 1 - Part No: 7P6 951 172
   Component: Sensor, DWA  005 0502
   Part No SW: 4H0 959 792 S    HW: 4H0 959 792 M
   Component: TSG BF        H03 0306
   Revision: --------    Serial number: 0000200810449
   Coding: 011D1620D001451005080000
   VCID: 489F6B00FB10D0D343-801D
Address 53: Parking Brake (J540-)       Labels:| 7P0-907-801.clb
   Part No SW: 7P0 907 801 G    HW: 7P0 907 801 G
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: C1652100385    Dataset Number:             A001
   Coding: 01040100
   Shop #: WSC 16417 004 1048576
   ROD: EV_ParkbA7.rod
   VCID: 377D18FC8EEEAF2B3A-8063
   Slave 3:
   Component: AFS-ECU       H01 0120
   Revision: --------    Serial number: -------------- Dataset Number: 7P0036v____ 0019
   Coding: 01AE02000B000200
   ROD: EV_HeadlRegulAFSMQBMLB_VW52.rod
   VCID: 3F8D70DCA6DE976BF2-806B
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0006
   Coding: B00000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0006
   Coding: B00000
   Part No SW: 4G1 035 053 J    HW: 4G1 035 053
   Component: Radio U Basic H41 0133
   Revision: AB001007    Serial number: 227EO0G2531014
   Coding: 040005020100000003
   VCID: 2643C5B8514426A391-8073
   Part No SW: 7P6 035 764 M    HW: 7P6 035 764 A
   Component: H-BNT-RW      H42 1023
   Revision: --------    Serial number: 605E-0GB000863
   Coding: 010A01050040C1EF01002B0E00000003F00001030000000000
   VCID: 43857C2CC236F38B96-8017
   Subsystem 1 - Part No: 8R0 060 884 DJ
   Component: ROW 2016  0806
   Subsystem 2 - Part No SW: 7P6 919 603 J    HW: 7P6 919 603 J
   Component: DU8 SV Touch  H56 0046
   Serial number: VWZ8Z9SGF00UDN
   Subsystem 3 - Part No SW: 7P6 919 603 J    HW: 7P6 919 603 J
   Component: CD-Database  6890
   Part No SW: 4H0 959 795 P    HW: 4H0 959 795 J
   Component: TSG HL        H04 0306
   Revision: --------    Serial number: 0000200954039
   Coding: 011814200001251005080000
Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
   Part No SW: 4H0 907 383 M    HW: 4H0 907 383 K
   Component: Anhaenger     H20 0160
   Revision: 7C001003    Serial number: 0377273915
   Coding: 0300000202000000
   ROD: EV_TrailFunctGener2Hella_VW52.rod
   Part No SW: 7P6 980 556     HW: 7P6 980 556
   Component: RVC Compact   H08 0160
   Dataset Number: V03935238CQ 0001
   Coding: 0125060123002003000040
   ASAM Dataset: EV_CamSysRVRVCPANAVW526 001001
   ROD: EV_CamSysRVRVCPANAVW526.rod
   VCID: 7EF3CDD8E1545E63B9-802B
   Part No SW: 7P6 959 107 C    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0043
   Revision: 22010001    Serial number: 140600211 Dataset Number: 7p0771v____ 0012
   Coding: 0533314003
   ASAM Dataset: EV_HeckkTouar 202142
   ROD: EV_HeckkTouar.rod
   Component: TSG HR        H04 0306
   Revision: --------    Serial number: 0000200855564
End-------------------------(Elapsed Time: 05:03)--------------------------
Larry Manton
C?ID=112505
AK77, diesels are testy when cold. Don't know how quick you fire it off, but do you wait about 3 seconds to see the glow light come on, then go off, or is it.
My wife and I have this discussion occasionally. jump in, shove the key in, then crank, all in one smooth motion.NOT!
We have no codes which is always nice, but while running rough is there any smoke from the stacks? Assume glo plugs get their Q from ambient temp, engine or other. Are these congruent with the day around you.
Modern diesels, not so much. Besides, just how cold can it possibly be Western Australia?
Have you looked at your injector deviations?
ak77
C?ID=232348
The symptoms are the same regardless of whether you give glow plugs for 10 sec or longer. I will look at injectors next and replace air and fuel filters. Every day is different; today, the shake lasted longer.
ak77
C?ID=232348
Thanks, mate; I will look at the deviations now and report back. It's not very cold here, even during winter. I'm thinking along the way of fuel or injectors.
ak77
C?ID=232348
does anyone know where to find the Injector Minimum Deviation section? Not listed in my software dropdown option?
Advanced Measuring Values.
Type deviation into the search/filter box.
Should be the first six things you see.
ak77
C?ID=232348
Ok, I have done that part. I get the 6 readings.
I can see the numbers but where is the menu to run a minimum deviation ( basic settings or similar) like on the smaller 2L engines? Can it be done on 6cyl or just Soft Reset?
ak77
C?ID=232348
I'm noticing more and more this rattle shake is happening more as I reverse out of the garage,
Shakes and revs up as in reverse gear.
Any clues
ak77
C?ID=232348
I did the deviation measurement 3 times today under correct conditions.
IDE00... Injection quantity deviation cylinder 1
-0.83 mg/stroke
IDE00... Injection quantity deviation cylinder 2
0.60 mg/stroke
IDE00... Injection quantity deviation cylinder 3
0.20 mg/stroke
IDE0O... Injection quantity deviation cylinder 4
-0.11 mg/stroke
IDE0O... Injection quantity deviation cylinder 5
-0.09 mg/stroke
IDE0O... Injection quantity deviation cylinder 6
0.20 mg/stroke
____________________________
-0.81 mg/stroke
0.72 mg/stroke
0.25 mg/stroke
IDE00... Injection quantity deviation cylinder 4
-0.08 mg/stroke
IDE00... Injection quantity deviation cylinder 5
-0.19 mg/stroke
IDE00... Injection quantity deviation cylinder 6
0.10 mg/stroke
___________________________________
IDE00….
-0.96 mg/stroke
0.62 mg/stroke
0.26 mg/stroke
IDE00... Iniection auantitv deviation cvlinder 4
-0.04 mg/stroke
IDE00.. Injection quantity deviation cylinder 5
0.12 mg/stroke
0.00 mg/stroke
Please explain what you mean by "correct conditions".
Cylinder 1 is starting to look a bit borderline, but by factory standards, it's probably acceptable, so I'm doubtful that this is the source of of the issue.
Larry Manton
C?ID=112505
Okay, will bring this up, and have posted it before, mostly no comments.
Had a 99 Jetta 2.0 gas, and would hard crank, run extremely rough then die, morning only. If you could keep it running would fix itself after about a minute, only when cold, maybe not do it again for days or weeks.
So looked at all codes, none, truly wanting to fault electrical, fuel anything, not about the price just fix it.
One morning for giggles, own a DSO, VAG, and others, so put a vacuum gauge on it, and during rough run read about 15 inches of vacuum, normal IMO 20 and up. Managed to get it to die but had been running for a minute or so long enough to start to warm. Crank it over, it lites off, runs smooth and magically now pulling a solid 20 inches, 30 seconds ago 15. I did suspect oil so changed again, no change.
We know they don't heal themselves but maybe there is a lifter holding a valve tight or slightly open. This was a rebuilt motor with a VW OEM oil pump. Took it off suspecting bypass valve and seen nothing alarming. Was already in there so replaced it, problem never came up again. Oil pressure number as I recall in suspected pump were almost at 100, don't recall, but IMO high. New pump stone cold maybe 80 (has been a while) but dropping after warm.
Don't know how you would validate this in the diesel, maybe MAP, MAF, but just a thought.
ak77
C?ID=232348
Correct conditions: as per Ross-Tech recommendations, temp, etc.. I was just thinking as per the below text some vacuum hose or something?
ak77
C?ID=232348
Just thinking about this and conclusion would be a sensor somewhere would pick up incorrect reading? Yes?
Larry Manton
C?ID=112505
AK77, not familiar with each and every car, and the ability, but 99% sure oil pressure would be shown in the advanced section.
Thinking back probably not an option on my 99, but in this case would be good to look at. JmO.
Jagman246
Australia
C?ID=578684
Hi ak77, did you fix this?
I had exactly the same issue which eventually deteriorated into a hard start, and then no-start over a period of a month.
It was the dreaded leaking injector seals (copper rings) problem where the leaking gasses overheated and cooked the injector. I left mine to long and had to replace all the injectors. I bought thm from Bosch and did it myself.
