BCM? ECU? 2017 Audi A3 Premium Plus Quattro
JohnFrost
Wausau, WI, USA
C?ID=512610
So, I recently Bought a new battery because of my low voltage warnings, hoping it would take care of at least some of my problems, and ultimately it made it worse. I went under 19-Canbus and I did the four adaptions to teach the new battery. and within a day or two my car would not start. Worked fine at first. and now it will start and shut off immediately. Please Help! I have tried to put the old battery back and everything. Same result. I have a current scan. I do believe i have another scan from before the battery replacement too. Im hoping this is an easy fix. -FacePalm.
Friday,10,November,2023,14:23:44:48745
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: WAUJ8GFF7H1034988   License Plate:
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 3C 42 44 52 5F 61
          6C BB BC CF
VIN: WAUJ8GFF7H1034988   Mileage: 120185km-74679miles
61-Battery Regul. -- Status: Cannot be reached 0100
BB-Door Rear Drv -- Status: Malfunction 0010
CF-Lane Chge Asst 2 -- Status: Malfunction 0010
Address 01: Engine (J623-CNTC)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 L    HW: 06K 907 425 B
   Revision: --H13---    CVN: 0F61BC97
   Coding: 0A1D00124426010F3000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0205G0906259L 001004
   ROD: EV_ECM20TFS0205G0906259L.rod
   VCID: 372B2590FFC66222DE9-8062
   VINID: 9D195A2175961D80400C4248207B2FED60
20638 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
          P0036 00 [00100111] - Malfunction / Open Circuit
                    Mileage: 120185 km
                    Date: 2023.11.09
                    Time: 10:39:33
                    Engine RPM: 0.00 /min
                    Coolant temperature: 55 °C
                    Intake air temperature: 9 °C
                    Voltage terminal 30: 11.289 V
                    Engine: operating status: ES
                    ECU_STATE: ENG_STOP
                    T_ES: 16 min
                    T_AST_SAE: 0 s
                    Lambda probe heater: resistance: bank 1: probe 2: 65535 Ohm
                    TEG_DYN_LS_DOWN[1]: 8.1625 °C
                    VLS_DOWN_SAE[1]: 1.275 V
23648 - Heater support pump
          P16C1 00 [00100111] - Open circuit
                    Mileage: 120185 km
                    Date: 2023.11.09
                    Time: 10:39:29
                    STATE_LS_SAE[1]: INI
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 97 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
                    FAC_TPS_1_SAE: 16.406250 %
                    FUP_H_SAE: 6810.0 kPa
17789 - Insufficient Engine Cooling / Coolant Flow
          P00B7 00 [00100110] - -
                    Mileage: 120185 km
                    Date: 2023.11.10
                    Time: 14:05:13
                    Intake air temperature: 8 °C
                    Voltage terminal 30: 11.601 V
                    Engine temp. management actuator: raw value: 2464
                    Engine temperature management actuator: stop open: 143
                    Engine temperature management actuator: after-run stop: 3957
                    RVC_SP: 164.50 °
                    RVC_AV: 155.19 °
                    RVCPWM: -76.691 %
17178 - Databus
          U1123 00 [00100111] - Received Error Message
                    Mileage: 120185 km
                    Date: 2023.11.10
                    Time: 00:00:12
                    Coolant temperature: 58 °C
                    Intake air temperature: 7 °C
                    Voltage terminal 30: 11.875 V
                    Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                    Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                    Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                    Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                    Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                    Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                    Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                    Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
                    Drivetrain coordinator: brake fault status-ESP system error: No
Readiness: 1110 1101
   Part No SW: 0D9 300 014 N    HW: 02E 927 770 AS
   Component: DQ250-6A MQB  H54 5002
   Revision: 06454104    Serial number: TFK01609250776 CVN: 00000389
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 2313E1C05B5E1E82121-8076
          P1734 00 [00000010] - -
   Part No SW: 5Q0 614 517 AR    HW: 5Q0 614 517 AG
   Component: ESC           H62 0642
   Revision: 00000000    Serial number: 62806000000493
   Coding: 13FF6A923423227089800B0880CB29C8562C4491D0019476124100548288420000000012121212B835351919323200
   VCID: 015F8B48E182EC9220D-8054
0128 - Function Restricted due to Insufficient Voltage
          U1400 00 [00001000] - -
          [undervoltage]
                    Reset counter: 30
                    Mileage: 120186 km
                    Date: 2023.11.02
                    Time: 02:17:22
0295 - Steering angle sensor
          B1168 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 30
                    Mileage: 120186 km
0297 - Steering Angle Sensor
          B1168 F2 [10001001] - Not Initialized
                    Reset counter: 30
                    Mileage: 120185 km
                    Date: 2023.11.09
                    Time: 10:23:29
4235 - Vacuum sensor
          C10A3 01 [00001000] - Electrical Failure
          [No frames received from the vacuum sensor or Invalid data received from the sensor]
                    Reset counter: 70
                    Mileage: 120186 km
32928 - Function Restricted due to Insufficient Voltage
          U1400 00 [00001001] - -
          [IPB: Supply Voltage below undervoltage threshold]
                    Reset counter: 30
                    Mileage: 120186 km
                    Date: 2023.11.02
                    Time: 02:29:32
32951 - Control Module for Electronic Parking Brake
          C10E2 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 30
                    Mileage: 120186 km
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0710
   Revision: 00021000    Serial number: 0420178739 Dataset Number: 8V0909577D  0010
   Coding: 030C0C
   VCID: 3B2339A0C3EE46423A1-806E
65813 - Supply voltage
          U1011 00 [00001000] - Voltage too Low
                    Reset counter: 70
                    Mileage: 120186 km
                    Date: 2023.11.02
                    Time: 02:18:18
   Part No SW: 8V0 820 043 Q    HW: 8V0 820 043 Q
   Component: AC Automat    H03 0110
   Revision: 20001000    Serial number: 00000001068592
   Coding: 03000014010000001000000000001400
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008021
   VCID: 40D94E4CAA08259A6F3-8014
   Humidity sensor: exterior:
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: AQ_Hum_Sensor  H01 0005
   Serial number: F938C15800PAG0MUFU03
   Part No SW: 5Q0 937 085 BF    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H34 0236
   Serial number: 02001627901174 Dataset Number: 8V0909514Q  0035
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7EA5F0B4907C936A5DF-802A
   Component: WWS371 160729  043 0585
   Serial number:         160805164043
   Coding: 0A47F7
   Serial number: 62351461
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Component: E1 - LDS MQB  H06 0032
   Serial number: 01 08 2016  00001616
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000036653978
   Sunroof control module:
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST0018CUJY00000
   Coding: 101F00
131330 - Supply voltage
          [Versorgungsspannung - unterer Grenzwert unterschritten >]
                    Reset counter: 70
                    Mileage: 120186 km
                    Date: 2023.11.02
                    Time: 02:18:22
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Voltage: 8.5 V
                    Outside temperature: 4.0 °C
   Part No SW: 5QA 919 294     HW: 5QA 919 294
   Component: PDC 8 KanalH07 0031
   Serial number: 000308418616280 Dataset Number: 8V0909526G  0058
   Coding: 0430155011
   ASAM Dataset: EV_EPHVA18AU3700000 009027
   ROD: EV_EPHVA18AU3700000_VW41.rod
   VCID: 094F9368D9B2A4D278D-805C
13637426 - Databus
                    Reset counter: 30
                    Mileage: 120186 km
                    Date: 2023.11.01
                    Time: 16:41:44
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 G    HW: 5Q0 907 572 G
   Component: ACC BOSCH MQB H10 0571
   Dataset Number: 8V1909863J  0031
   Coding: B500000218F78428949C8055000024
   ASAM Dataset: EV_ACCBOSCHVW416 001005
   ROD: EV_ACCBOSCHVW416_001_VW37.rod
0267 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [00001001] - -
          [FAULT_ALIGNMENT_NOT_OK]
                    Reset counter: 30
                    Mileage: 120186 km
                    Date: 2023.11.01
                    Time: 16:41:31
                    Control Module temperature: 17 °C
                    Voltage terminal 15: 11.9 V
2055 - Databus
          [FAULT_ALP_STEERINGWHEEL_INIT]
                    Reset counter: 30
                    Mileage: 120185 km
                    Date: 2023.11.09
                    Time: 10:23:31
                    Control Module temperature: 7 °C
                    Voltage terminal 15: 11.2 V
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM]
                    Reset counter: 30
                    Mileage: 120186 km
                    Date: 2023.11.01
                    Time: 16:41:31
0791 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          [FAULT_MISALIGNMENT_VERTICAL]
                    Reset counter: 30
                    Mileage: 120186 km
                    Date: 2023.11.01
                    Time: 16:41:31
   Serial number: 003GCR06EAUW Dataset Number: 8V0909602R  0002
   Shop #: WSC 10936 002 1048576
   VCID: 47CB55508F2612A2AE9-8012
   Left seat belt tensioner:
   Serial number: 34230167A17101641347
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34230168A18101650105
   Coding: 333135
   Serial number: 694000000000001JGZJN
   Coding: 303333
   Subsystem 4 - Part No SW: -----------    HW: 480 000 610 16
   Serial number: 35700000000A8C7C4E1/
   Subsystem 5 - Part No SW: -----------    HW: 480 000 610 16
   Serial number: 358000000007E6253F1Q
   Subsystem 6 - Part No SW: -----------    HW: 480 401 010 16
   Serial number: 3510001B123204C1E60N
   Subsystem 7 - Part No SW: -----------    HW: 480 401 010 16
   Serial number: 3520001C12303C9683C$
   Subsystem 8 - Part No SW: -----------    HW: 480 400 909 16
   Serial number: 3550002B9215E1E1F0EG
   Subsystem 9 - Part No SW: -----------    HW: 480 400 909 16
   Serial number: 3560002BD215E1E1E19G
17 Faults Found:
9438481 - Igniter for Driver head airbag
          B1005 11 [10001001] - Short to Ground
                    Mileage: 120186 km
                    Date: 2023.11.01
                    Time: 16:41:35
9440282 - Driver side knee airbag igniter
          B100C 1A [10001001] - Resistance Too Low
                    Mileage: 120186 km
                    Date: 2023.11.01
                    Time: 16:41:35
9440794 - Front Passenger's Knee Airbag Igniter
          B100E 1A [10001001] - Resistance Too Low
                    Mileage: 120186 km
                    Date: 2023.11.01
                    Time: 16:41:35
          B1000 1B [10001001] - Resistance Too High
                    Mileage: 120186 km
                    Date: 2023.11.01
                    Time: 16:41:35
9440539 - Driver's Safety Belt Tensioner Igniter 2
          B100D 1B [10001001] - Resistance Too High
                    Mileage: 120186 km
                    Date: 2023.11.01
                    Time: 16:41:35
9437723 - Igniter for Passenger's Airbag
          B1002 1B [10001001] - Resistance Too High
                    Mileage: 120186 km
                    Date: 2023.11.01
                    Time: 16:41:35
9437979 - Igniter 2  for Passenger's Airbag
          B1003 1B [10001001] - Resistance Too High
                    Mileage: 120186 km
                    Date: 2023.11.01
                    Time: 16:41:35
          B1006 1B [10001001] - Resistance Too High
                    Mileage: 120186 km
                    Date: 2023.11.01
                    Time: 16:41:35
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
          B1007 1B [10001001] - Resistance Too High
                    Mileage: 120186 km
                    Date: 2023.11.01
                    Time: 16:41:35
9438235 - Igniter for Front passenger's Head Curtain Airbag
          B1004 1B [10001001] - Resistance Too High
                    Mileage: 120186 km
                    Date: 2023.11.01
                    Time: 16:41:35
9439515 - Seat Belt Tensioner Igniter; rear; driver's side
          B1009 1B [10001001] - Resistance Too High
                    Mileage: 120186 km
                    Date: 2023.11.01
                    Time: 16:41:35
9439259 - Igniter for Seat Belt Tensioner; Rear Passenger's Side
          B1008 1B [10001001] - Resistance Too High
                    Mileage: 120186 km
                    Date: 2023.11.01
                    Time: 16:41:35
9441051 - Front passenger's safety belt tensioner igniter 2
          B100F 1B [10001001] - Resistance Too High
                    Mileage: 120186 km
                    Date: 2023.11.01
                    Time: 16:41:35
9442075 - Driver's Belt Force Limiter Igniter
          B1013 1B [10001001] - Resistance Too High
                    Mileage: 120186 km
                    Date: 2023.11.01
                    Time: 16:41:35
9442331 - Passenger's Belt Force Limiter Igniter
          B1014 1B [10001001] - Resistance Too High
                    Mileage: 120186 km
                    Date: 2023.11.01
                    Time: 16:41:35
          B10B3 00 [10001001] - Function Restriction due to Implausible Message(s)
                    Fault Frequency: 9
                    Reset counter: 30
                    Mileage: 120186 km
                    Date: 2023.11.03
                    Time: 11:48:16
1050117 - Databus
          [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
                    Reset counter: 30
                    Mileage: 120185 km
                    Date: 2023.11.09
                    Time: 10:23:31
   Part No SW: 8V0 953 521 KK    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 13101604400566
   Coding: A018
   VCID: 0D47A778ADDAB8F2545-8058
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
   Part No SW: 8V0 920 890     HW: 8V0 920 890
   Component: FBenUSA       H13 0045
   Coding: 00E518512398CF050285E8001800000000000000
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_DashBoardFPKAU37X 001023
   ROD: EV_DashBoardFPKAU37X.rod
   VCID: 7AADFCA48C54BF4A617-802E
13635840 - Supply voltage
          [ECU voltage lower limit supply voltage permanent too low]
                    Reset counter: 70
                    Mileage: 120186 km
                    Date: 2023.11.02
                    Time: 02:18:05
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2265
   Revision: --------    Serial number: 13101610800850 Dataset Number: 8V0909515L  0078
   Coding: 030100043F085A005B00024C180B00000001010000000000000000000000
   GVL: 01D43C0000000600404C80000002C80000040010000000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 7CA1FABC8660817A73B-8028
   Generator:
   Subsystem 2 - Part No SW: 8W0 951 523 E    HW: 8W0 951 523 E
   Component: J453 MFL  H04 0002
   Serial number: 20160930113149 00631
   Serial number: 75410803001610132164
131740 - Battery Energy Control Module 2
          U014A 00 [00001001] - No Communication
          [Timeout Knoten 0x9C / 21 - Steuergerät für Batterieenergiemanagement 2]
                    Reset counter: 30
                    Mileage: 120185 km
                    Date: 2023.11.10
                    Time: 14:05:00
                    Terminal 30 power supply: 11.9 V
                    Terminal 15: On
   Serial number: HA1-00009.09.16 Dataset Number: v1260x015G0 0000
   Coding: 0001
   VCID: 4ACD6C649C34EFCAB17-801E
   Revision: 00000000    Serial number: 16000160652008
   Coding: 5D00000000000000
   VCID: 3431129CEEB0893AFBB-8060
          [Under voltage (continued)]
                    Reset counter: 70
                    Mileage: 120186 km
                    Date: 2023.11.02
                    Time: 02:18:21
                    ELV State: 04
                    Information Clamps: 00 00
                    CoCo State: 20 01
                    WFS State: 07 06
                    Vehicle speed: 0.00 km/h
                    Voltage: 47
                    AD-Value H-bridge: 23
                    Clamp15 flip flop: SSTx: button contacts: 06
                    CAN signals: 00
          [Under voltage (temporary)]
                    Reset counter: 70
                    Mileage: 120186 km
                    Date: 2023.11.02
                    Time: 02:16:31
                    ELV State: 04
                    CoCo State: 20 01
                    WFS State: 07 06
                    Voltage: 4C
                    AD-Value H-bridge: 26
                    CAN signals: 00
   Part No SW: 3Q0 907 566 D    HW: 3Q0 907 566
   Component: MRR1Rear      H16 0410
   Revision: --------    Dataset Number: 8V0909535F  0005
   Coding: 040002
   ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
   ROD: EV_RearRadarS1BoschVW48X_AU37.rod
   VCID: 392F23A8C9D2745228D-806C
1188165 - Databus
          [databus unreasonable message - LWI_Lenkradwinkel]
                    Reset counter: 30
                    Mileage: 120185 km
                    Date: 2023.11.09
                    Time: 10:23:29
                    Control Module temperature: 5 °C
                    Voltage terminal 30: Measuring value not available
                    Terminal 15 status: Measuring value not available
                    Voltage terminal 15: 11.20 V
267010 - Databus
          [FAULT_SLAVE]
                    Reset counter: 30
                    Mileage: 120185 km
                    Date: 2023.11.09
                    Time: 10:23:29
                    Voltage terminal 15: 11.00 V
   Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
   Serial number: 220916EIL16137 Dataset Number: 8V0909872H  0038
   Coding: 00141B204000048000000002
   VCID: 41DF4B48A1022C9260D-8014
65548 - Supply voltage
                    Reset counter: 70
                    Mileage: 120186 km
                    Date: 2023.11.02
                    Time: 02:18:37
   Component: EPS_MQB_ZFLS  129 1072
   Dataset Number: 8V0909852P  0026
   Coding: 0107
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 45D75F58B52A00B25C5-8010
11776 - Supply voltage
          [Warnung vor dauerhaft zu geringer Versorgungsspannung Anzeige von Unterspannung]
                    Reset counter: 70
                    Mileage: 120186 km
                    Date: 2023.11.02
                    Time: 01:53:04
                    Motor status: 00
                    Supply voltage: 10.75 V
                    Temperature: 16.0 °C
                    KFC: 2E
                    KFA: 00 00
                    Freeze frame conditions: 21
                    uioUdNotFilt_xdu16: 10.84 V
                    uAdSensI_SwitchedKl30_xdu16: 10.84 V
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: not activated
16272 - Steering Angle Sensor
          B1168 F2 [00001001] - Not Initialized
                    Reset counter: 30
                    Motor status: 00
                    System status: Reset
                    Supply voltage: 11.75 V
                    Temperature: 7.0 °C
                    KFC: 3F
                    KFA: 00 90
                    Freeze frame conditions: 5F
                    uioUdNotFilt_xdu16: 11.69 V
                    uAdSensI_SwitchedKl30_xdu16: 11.69 V
                    NoInitCause_AsicSens: [0x12] ASC_CTRL_SAS_PERIOD_ERR - SASPERIOD content lost after last ignition off
                    NoInitCause_RackPos_Rohwert: 00 C0
                    RP_UNDERVOLT: activated
                    RP_CNTERR: activated
   Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
   Serial number: 200916EIJ06441 Dataset Number: 8V0909873H  0038
   Coding: 001413204C00048000000002
                    Reset counter: 70
                    Mileage: 120186 km
                    Date: 2023.11.02
                    Time: 02:18:39
Address 5F: Information Electr. (J794)       Labels:* 8V0-035-MIB-HGH2.clb
   Part No SW: 8V1 035 890     HW: 8V1 035 890
   Component: MU-P-LNS-US   052 0694
   Serial number: A703H0G7502554 Dataset Number: 8V2909545M  0017
   Coding: 01730102FF0A000011220001041A00102F002BE5017001047E
   Shop #: WSC 47485 002 1048576
   VCID: 78A9E6ACB258AD5A173-802C
   Subsystem 1 - Part No SW: V03 959 802 DL    HW: -----------
   Component: NAR 2019  --- 0069
   Multimedia System 1:
   Component: DU High  H49 0014
   Serial number: AUZ8Z9GY20800U
   Subsystem 3 - Part No SW: 8V0 919 614 BK    HW: 8V0 919 614 BK
   Component: ControlUnit_H  H85 0855
   Serial number: ALJAL109091600010251
   Compact disc data bank:
   Component: Gracenote2---  --- 3009
1537 - Supply voltage
          [Supply voltage - lower limit value not reached]
                    Reset counter: 70
                    Mileage: 120186 km
                    Date: 2023.11.02
                    Time: 02:18:10
                    Voltage terminal 30: 8.6 V
                    Reset counter: 30
                    Mileage: 120186 km
                    Date: 2023.11.01
                    Time: 16:43:44
                    Voltage terminal 30: 12.6 V
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                    Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
5633 - Control Head for Multimedia System; Rotary Menu Knob
          B1291 F2 [00001000] - Unknown Error Elaboration
                    Reset counter: 70
                    Mileage: 120186 km
                    Date: 2023.11.01
                    Time: 17:24:46
                    Voltage terminal 30: 12.2 V
5688 - Control Head for Mulimedia System
          B13C9 F2 [00001000] - On/Off Switch
                    Reset counter: 70
                    Mileage: 120186 km
                    Date: 2023.11.03
                    Time: 11:49:47
Address 61: Battery Regul.
   Dataset Number: 8V0909460E  0005
   Coding: 0273010102002001400040
          [Power supply - undervoltage]
                    Reset counter: 70
                    Mileage: 120186 km
                    Date: 2023.11.02
                    Time: 02:20:14
                    CAN communication
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Serial number: 041016EJ307034 Dataset Number: 8V0909897G  0026
   Coding: 000013204000048000000002
   VCID: 43D34140BB1E3E82721-8016
                    Reset counter: 70
                    Mileage: 120186 km
                    Date: 2023.11.02
                    Time: 02:18:50
   Serial number: 041016EJ307132 Dataset Number: 8V0909896G  0026
                    Reset counter: 70
                    Mileage: 120186 km
                    Date: 2023.11.02
                    Time: 02:18:51
   Part No SW: 3Q0 907 590 D    HW: 3Q0 907 590
   Revision: --------
   Coding: 040002
   ASAM Dataset: EV_RearRadarS2BoschVW48X 001002
   ROD: EV_RearRadarS2BoschVW48X_AU37.rod
   VCID: 36352894F8CC9B2AC5F-8062
1188165 - Databus
                    Reset counter: 30
                    Mileage: 120185 km
                    Date: 2023.11.09
                    Time: 10:23:29
End----(Elapsed Time: 01:51, VBatt start/end: 11.9V/11.9V. VIgn 12.0V)-----
Goodness this car is a mess. Has it been crashed?
Have you done basic checks with a volt meter to see if it's charging when the engine is running?
JohnFrost
Wausau, WI, USA
C?ID=512610
Well that doesn’t sound very good. Yes it was crashed (hit a deer.) however it runs very well, well did run very well. And no I didn’t do a volt meter test. And now I cannot get it to run in order to do the test
Ziddywerks
Northern NJ USA
C?ID=208579
Charge the battery. Then clear all faults. Then rescan and post updated log.
siLc
Tallinn, Estonia
C?ID=330192
There is the regular MQB platform BDM module present under the CAN gateway, yet there is also module 61 in the CAN gateway installation list, which is a standalone BDM which this vehicle doesn't have and the CAN gateway seems to miss? Do as previously advised and try removing this erroneus address from the CAN installation list and see if anything improves.
