Jetta Hybrid 2013: no-start , no comm with battery control module (BCM, address 8c)
jhwhite
uC-2H
The following has many details, maybe too many details, but I hope it is better than too few details. I have searched all over and people do not seem to know how to fix this problem.
High-level description: Aforementioned car will not start ("hybrid error"). Dealer did diag and proposed to change the entire HV battery and BCM battery control module, a costly repair that is in excess of car value. I declined and towed the car home.
Low-level description: ODIS output file from dealer indicates that the CANbus communication with the BCM is not operating, and that this is the reason for the no-start. I confirmed this with oscilloscope as follows: There are CAN signals going into the BCM on the T8ax/1+2 connector pins, but there is indeed no data coming back out, as checked by disconnecting the T8ax and scoping the CANbus on the BCM/battery side (I'm using schematics of the vwts(dot)ru site).
How the car got into this state is unknown. My best guess is that a low-voltage on the 12V battery caused some errant signal (maybe airbag) and that the ECU and/or J234 (Airbag control module) somehow disabled both the BCM itself *and* the BCM CANbus. Maybe a crash-shutdown of BCM, although there was never a crash. Something like a P1609 but additionally disabling the BCM CANbus, so that the P1609 cannot be observed nor cleared. So I am stuck.
Debugging details: I have the BCM (J840, 5C6915182B) extracted from the car, and I'm testing it on my kitchen table, rigging up the scope to the CANbus using a pinout I found on youtube for an Audi that very likely has the same pinout for at least the relevant Vdd/GND/CANbus pins.
Now, CANbus has no signal, but I can see some mV-level burst-like noise that *might* be the ghost of a CANbus signal leaking through a High-Z driver. Other checks I did: I punctured+scratched the protective lacquer (a.k.a the "conformal coating") on BCM pcb502 (full name at bottom) and was able to verify that the 12V-to-5V switching converter is working and providing 5V. Idd(12V)=10.8mA, which seems low, not sure. Was not able to locate/probe the internal CANbus traces yet. R(CANbus+/-)=7.85kohm, which is perhaps not surprising since the 120ohm terminations are elsewhere and not inside the BCM.
Additional speculation: The Dealer ODIS output also says that the car has the fault "18187 - Service Mode Active", and it says this mode was active when the car was brought in. I wonder if service mode is in some sense turning off the BCM CANbus so that a technician cannot accidentally turn on the HV battery (as a safety measure), same as, or in addition to, a "crash shutdown". But I have no idea how I can reset or clear this mode or any other mode inside the BCM, given that the CANbus is not functioning. I don't think it is the CANbus itself that is broken. I'm thinking there is some bit or bits that need to get flipped, but how?
Related to J234 Airbag Control Module possibly generating a crash-shutdown: The BMC has the following inputs via the T14x connector outside the battery as follows.
T14ax/1 : p500 says connected to J234.T100/74=Airbag control module. NBNB: could be related to battery locked
T14ax/2 : p500 says connected to J234.T100/75=Airbag control module. NBNB: could be related to battery locked
I don't know whether setting these signals to the correct voltage would wake up the CANbus. And I do not know the pattern needed (00,01,10,11). Neither do I know on the BMC numerous connectors these signals would be located. Not able to find a schematic from Sanyo or VW. Could posssibly trace/ohm from T14ax to BMC connectors A-F (100s of pins) and find out.
The big question: If I can get the CANbus to wake up (and I need some help with that), would connecting a VCDS *directly* to the BCM let me clear whatever error codes are disabling the BCM (assuming my overall theory is correct)?
Conclusion: Could really need some help here. How does my analysis sound? Does anyone know some of the details that I am missing?
Part numbers or names:
Battery 5C6915590C (a.k.a AX1)
BCM 5C6915182B (a.k.a J840)
BCM PCB1 model number: Sanyo 2RR4B14A69501 == 2rr4b14a69501
BCM PCB2 model number: Sanyo 2RR4B14A69502 == 2rr4b14a69502
J234 Airbag control module
MrMeeseeks
LP/SN
jhwhite
uC-2H
Thank you. I was apparently mistaken that to post Autoscan, I had to be verified AND had a product bought directly from dealer (not 2nd hand). Let me try to post it here:
Thursday,02,November,2023,18:56:13:36500
VCDS Version: 23.11.0.0 (x64)
VIN: 3VW637AJ3DM000111   License Plate:
Mileage: 79999km-46335mi   Repair Order: 1f
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 42 44 46 51 52 56 61
          62 65 72 77 8C
VIN: 3VW637AJ3DM000111   Mileage: 79999km 49709miles
51-Electric Drive -- Status: Malfunction 0010
65-Tire Pressure -- Status: Cannot be reached 1100
8C-HV Battery -- Status: Cannot be reached 1100
Address 01: Engine (J623-CNLA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 023     HW: 04E 907 309 B
   Component: 1.4l TFSI hy  H01 5631
   Revision: V8H01---    Serial number: (redacted) CVN: E115C0CE
   Coding: 00250012442401000000
   Shop #: WSC 22803 444 124050
   ASAM Dataset: EV_ECM14TFS01104E906023 002018
   ROD: EV_ECM14TFS01104E906023_002.rod
   VCID: 5D9F66434CBF1A7988-8008
   VINID: (redacted)
13143 - No Communication with HV Battery Energy Control Module
          U0112 00 [00100111] - -
                    Mileage: 74571 km
                    Date: 2023.11.02
                    Time: 04:31:09
                    Engine RPM: 0.00 /min
                    Coolant temperature: 12 °C
                    Intake air temperature: 15 °C
                    Voltage terminal 30: 11.544 V
                    Cruise control switch actuation-Bits 0-7: 0
          U1106 00 [10100111] - -
                    Mileage: 74571 km
                    Date: 2023.11.02
                    Time: 04:31:08
                    Voltage terminal 30: 11.567 V
                    Mean injection time: 0.000 ms
                    Engine operating condition: Idle
                    Power reduction status-Bits 0-7: 13
                    Engine torque: 0.0 Nm
Readiness: 1110 1101
   Part No SW: 0CG 300 045 F    HW: 0AM 927 769 H
   Component: GSG DSG AG7     431 5307
   Revision: 00043014    Serial number: (redacted)
   Shop #: WSC 46206 000 1048576
   VCID: 2C79FB878F85A3F14F-8078
   Part No SW: 1K0 907 379 AR    HW: 1K0 907 379 AR
   Component: ESP MK60EC1   H31 0135
   Revision: 00H31001
   Coding: A14B400C492A20FD850F02EA921C0440A71800
   Shop #: WSC 00066 790 00186
   VCID: 0225753F9D818581D5-8056
                    Reset counter: 111
                    Mileage: 74571 km
                    Date: 2018.03.25
                    Time: 04:31:24
                    Count: 3
                    Count: 14
                    Count: 12800
                    Count: 16390
                    Count: 41216
                    Count: 253
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434
   Revision: 00086000    Serial number: (redacted) Dataset Number: 5K0116v____ 1609
   Coding: 030C0C
   Shop #: WSC 00066 000 00000
   VCID: 3449E3E79FB5FB3117-8060
   Part No SW: 3AA 907 044 AQ    HW: 3AA 907 044 AQ
   Component: Climatronic   H03 0202
   Revision: 00001K04
   Coding: 0010401002
   Shop #: WSC 00066 000 00119
   ASAM Dataset: EV_ACClimaBHBVW361Hybri 001001
   ROD: EV_ACClimaBHBVW361Hybri.rod
   VCID: 7F23FCCBE673E869BA-802A
   A/C compressor:
   Subsystem 1 - Part No SW: 5C0 820 803 F    HW: 5C0 820 803 F
   Component: J842 eKK  H03 0001
13701888 - Function Restriction due to Faults in Other Modules
          U1113 00 [00001001] - -
                    Reset counter: 111
                    Mileage: 74571 km
                    Date: 2023.11.02
                    Time: 04:31:43
   Part No SW: 5K0 937 084 J    HW: 5K0 937 084 J
   Component: BCM PQ35 B    021 1068
   Revision: BG021001
   Coding: 6F200A1A912F06C4008808810000004401000088448089B05C802600A043
   VCID: 3957D2D3B0D70659C4-806C
   Part No SW: 5C0 959 655 J    HW: 5C0 959 655 J
   Component: AirbagVW10    101 0911
   Serial number: (redacted)   Dataset Number: 160003v____ 0194
   Coding: 00004838
   ASAM Dataset: EV_AirbaVW10SMEVW360 001024
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3957D2D3B8D70659C4-806C
   Coding: 303037
   Part No SW: 1K5 953 521 AR    HW: 5K0 953 569 E
   Revision: FF010041    Serial number: (redacted)
   Coding: 000A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7DDF06C3EC7FFA79A8-8028
   Coding: 820000
   Part No SW: 5C6 920 970 D    HW: 5C6 920 970 D
   Component: KOMBI         H08 0710
   Coding: 281E01
   VCID: 2D7FF6837C9FAAF958-8078
12658432 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
                    Reset counter: 111
                    Mileage: 74571 km
                    Date: 2023.11.02
                    Time: 04:30:58
   Part No SW: 7N0 907 530 AG    HW: 7N0 907 530 AG
   Component: J533  Gateway H53 1634
   Revision:   H53       Serial number: (redacted)
   Coding: 351002
   Shop #: WSC 12345 123 61029
   VCID: 75CF1EE3DC4FA239E0-8020
   Component: IMMO          H08 0710
   Coding: 000007
   VCID: 6AF53D9F8DF17DC17D-803E
   Revision: 00000000    Serial number: (redacted)
   Coding: 4900000000000000
   Shop #: WSC 00066 790 50316
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 3041EFF76BADC71173-8064
   Component: SG EXT.PLAYER H19 0550
   Revision: A1001003    Serial number: (redacted)
   Coding: 010100
   VCID: 2A75FD9F4571BDC1BD-807E
   Component: TUER-SG FT    002 0515
   Revision: 13110009    Serial number: (redacted)
   Coding: 0004B5
   Shop #: WSC 01383 790 50316
   VCID: 5B9B685B52AB1449F6-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703 C    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  008 1508
   Coding: 000490
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 69     3305
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 3753D4EB46C3102932-8062
            000 - - - MIL ON
                    Fault Status: 11100000
                    Mileage: 74571 km
                    Date: 2018.03.25
                    Time: 04:33:06
                    Battery Volts: 11.6 V
                        DD
                    Temperature: 20.0°C
                    Count: 2
                    Steering Angle: 0.00°
                    Count: 1
                        SteerAng n.Init
   Part No SW: 5C0 907 080 E    HW: 5C0 907 080 C
   Component: VW361H0108000 H02 0535
   Revision: 00H02000    Serial number: (redacted) CVN: 82E4C0E2
   Coding: 40020000000000000000
   ASAM Dataset: EV_DMCM04510115C0907080E 001021
   ROD: EV_DMCM04510115C0907080E.rod
   VCID: 256F0EA3246F92B990-8070
19063 - No Communication with Battery Energy Control Module
          U0111 00 [10100111] - -
                    Mileage: 74571 km
                    Date: 2023.11.02
                    Time: 04:31:09
                    Voltage terminal 30: 11.402 V
                    Drive control condition: DisCharge
                    RPM of electric machine: 0.0 /min
                    Power Electronics IGBT-Module Temperature Phase U: 15.78 °C
                    E-machine stator temperature: 14.23 °C
                    Power electronics: traction network voltage: 2.50 V
                    Torque: current value: -0.06 Nm
                    E-machine effective current: 0.22 A
19067 - No Communication with Battery Energy Control Module
          U0111 00 [00100111] - -
                    Mileage: 74571 km
                    Date: 2023.11.02
                    Time: 04:31:09
                    Voltage terminal 30: 11.375 V
                    E-machine stator temperature: 14.22 °C
                    Torque: current value: -0.09 Nm
19071 - No Communication with Battery Energy Control Module
                    Mileage: 74571 km
                    Date: 2023.11.02
                    Time: 04:31:09
                    Torque: current value: -0.03 Nm
19075 - No Communication with Battery Energy Control Module
                    Mileage: 74571 km
                    Date: 2023.11.02
                    Time: 04:31:13
                    Voltage terminal 30: 11.380 V
   Component: TUER-SG BT    002 0515
   Revision: 15110009    Serial number: (redacted)
   Coding: 0004B4
   VCID: 5C996B4757A51371FF-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704 B    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  008 1508
   Coding: 000490
Address 56: Radio (J503)       Labels: None
   Part No SW: 5C6 035 180     HW: 5C6 035 180
   Component: Radio Prem-8  H04 0009
   Revision: -----10S    Serial number: (redacted)
   Coding: 01000400020006
   VCID: 5FE35C4B4EB308699A-800A
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AG
   Component: Batt.regelung H53 1634
   Coding: 16660164
   VCID: 71C72AF3A8278E193C-8024
   Subsystem 1 - Part No SW: 1S0 915 181 A    HW: 1S0 915 181 A
   Component: J367-BDM  H08 0181
Address 65: Tire Pressure
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Revision: 1B001001    Serial number: (redacted) Dataset Number: 7P6035730K  0001
   Coding: 0A10040000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3A55CDDFBDD10D41CD-806E
Address 8C: HV Battery
End-------------------------(Elapsed Time: 03:13)--------------------------
Westbury, UK
Mileage: 74571 km
Date: 2023.11.02
Time: 04:31:08
Any idea how Service Mode got activated on the ECU?
BTW why is every serial number field redacted?
jhwhite
uC-2H
The below clarifies a bit more than the OP, but pls refer to OP as well. I did mention (with less detail) in the OP.
Additional speculation: The Dealer ODIS output says that the car has the fault "18187 - Service Mode Active", and it says this mode was active when ODIS was started, or at least the mode was active before the specific ODIS run that generated the PDF file that they gave me. It may have been the dealer that turned on service mode, or it may have been the the original no-start problem that did it. I do not know. I also do not know whether being in service mode is what is causing the engine not to start (and causing the BCM no-comm). That is part of the mystery.
I like my privacy and wrote a perl script to redact Autoscan output :).
jhwhite
uC-2H
By the way, I just submitted my serial number by email. Could not figure out how to send a PM private message.
jhwhite
uC-2H
I thought readers might be amused by my benchtop debug setup for the BCM 5C6915182B (a.k.a J840)
TTT
C?ID=547002
I think you are a pirate. Just go?
  • Disagree
jhwhite
uC-2H
Meanwhile, I have been doing some more experiments. I was inspired by https://forums.ross-tech.com/index.php?threads/14415/#post-130075 and decided to try something similar.
I went to the car and plugged in VCDS and looked at 01-Engine for error codes. The service mode error is there. I found some adaptations related to "service mode", specifically:
IDE00001 Production mode
IDE02332 Deactivate production mode
IDE04617 Protective Function
IDE05847 Hybrid Drive Customer Service <---- this one looked promising.
I tried to change that last one, IDE05847, from value "Drive by Combustion Engine" to "Not active". Writing this setting (twice) did not stick. Maybe it did not stick because BCM is not plugged in, and the ECU would need to talk to the BCM to set the value to "Not active"? As you know, the BCM is out of the car and sitting on my benchtop. It was a lot of work to take the BCM out, and it will be a lot of work to put it back in properly, so looking for some guidance here on whether the BCM need to be back in. Remember. the CANbus on the BCM is was never talking to the network. But maybe it can still receive and accept reset commands. I just don't know.
jhwhite
uC-2H
That's not nice. I bought my device on ebay. Software says serial is valid/activated. I have emailed in the serial. Can't you wait before accusing me?
  • Agree
TTT
C?ID=547002
No, persons messing with the serials on auto scan are simply that, just pirates. Ebay purchase does not give ensurance that the unit is genuine.
Posting an unedited auto-scan is not a choice but a requirement. Just go?
  • Disagree
No, he's not a pirate. He's got a second-hand Micro-CAN interface, which is legit.
Please do not make accusations like that without being sure.
I like my privacy
You're trying to fix a car here, not engaging in anything nefarious or illegal.
But whatever. Your HV battery is clearly off-line. Have you got a wiring diagram for this car? You need to check the low voltage connections to it, power, ground and CAN. If those are all good, then the problem is internal to the HV battery.
jhwhite
uC-2H
Thanks, Uwe. I have schematics. I have checked voltages and scoped the CANbus, as indicated in the 1st post. Outgoing CANbus from BCM inside HV battery is silent, incoming signal to BCM/battery is perfect and clean.
My main question is (1) whether the service mode could be disabling/silencing (high-Z) the outbound CANbus signals from the BCM, and (2) whether the service mode disable IDE05847 that I described above should "stick" (be accepted) whether or not the BCM is plugged into the car, given that it is an ECU adaptation and not a BCM/battery (address 8c) adaptation per se.
It is so much work to install the BCM again that it would be helpful to know whether really need to do it for the adaptation to stick.
TTT
C?ID=547002
My appologies then.
I don't know. There were not many of these Jetta Hybrids sold and I've never seen one in the flesh, much less worked on one.
I don't have a wiring diagram for this car hand. I'm not sure what you mean by "Outgoing CAN bus" and "Incoming signal". CAN bus is 2 wires with differential signalling, but traffic goes in both directions on that bus. Is there more than one CAN bus to the battery?
jhwhite
uC-2H
T8ax/1+2 is the CANbus connecting to the BCM/battery. When I unplug this connector I can see perfect signals incoming from the ECU/gateway/whatnot on scope. The battery outgoing side of that same unplugged connector is High-Z (high impedance) and no signal, even with power/GND applied (verified also via bench test pictured further above).
Schematics/wiring diagram are at http://redacted.net (says 2010 but is really up to 2015)__I think I'm going to bite the bullet and reinstall the BCM into the battery and see if that will make the IDE05847 adaptation reset stick and maybe turn on the CANbus.__Based on your considerable experience, does IDE05847 appear to be the right adaptation for me to look at (with respect to getting out of the "service mode")"]Redacted.net/URL] (says 2010 but is really up to 2015)
Based on your considerable experience, does IDE05847 appear to be the right adaptation for me to look at (with respect to getting out of the "service mode").
MrMeeseeks
LP/SN
No one noticed the Battery voltage in the autoscan is 11.3v-11.5v? Thats too low, and could be why there's communication issues.
I've watched a video recently of a Renault Zoe that had lost drive and had module communication issues. HV battery was absolutely fine, and after the 12v battery was replaced, everything came alive, and drive was restored.
jhwhite
uC-2H
Action: That is a good and valid point. Interesting Renault anecdote/data point, too. I have a brand new 12V AGM battery in hand, and I will install it and test again.
Already done: I had to some extent addressed low voltage by attaching a battery charger and redoing the scan. I had also load-tested the battery and it was decent enough. But please also re-read the original post, where I talk about how a low 12V battery voltage may be the mechanism by which certain types of intermittent errors get generated. It may for example be the case that all my problems started with some phantom crash-shutdown signal from an airbag.
Also keep in mind that I bench-tested the BCM (J840, 5C6915182B), and for that test I used a PC/ATX power supply that put out 12.2V. It made no difference, still no signal on the CANbus, it was all High-Z state.
