A8 Laser scanner error while adjustment
smurph98
C?ID=545507
Hi. I have a 2018 audi A8 that has all the driver assists. intermittently while driving the message driver assist unavailable would appear but system was working ( lane assist, distance control etc)
stupidly I used vcds to check alignment of laser and must have pressed on something in error as now the driver assist doesn't work apart from the lane sensors.
I noticed in module CD laser scanner i get error no basic setting and also Error_while_adjustment
I have taken the car to kwik fit whi now have the calibration boards and software to calibrate but they could not fully calibrate because of the laser error no basic settings.
please if anyone can help would be appreciated.
Full log after messing with VCDS and also log from before messing when everything was working on the driver assists.
AFTER MESSING WITH SETTINGS 😞
Sunday,05,November,2023,19:13:53:27503
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: WAUZZZF86JN006370   License Plate:
Chassis Type: F8-AU65 (4N2)
Scan: 01 02 03 06 09 13 15 16 17 19 1B 29 2B 36 39 42 44 46 47 48
          52 5B 5F 61 65 6D 74 81 82 A5 AC BA BB BC C4 CB CC CD D6 D7
          DE E0
VIN: WAUZZZF86JN006370   Mileage: 360304km-223882miles
48-Seat, Rear, DS -- Status: OK 0000
5B-Seat,Rear,PS -- Status: OK 0000
65-Tire Pressure -- Status: Not registered 0001
C4-DC/DC Converter -- Status: OK 0000
CB-Rear Axle Steering -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
CD-Laser Scanner -- Status: Malfunction 0010
E0-Auxiliary Display 1 -- Status: OK 0000
Address 01: Engine (J623-DDVC)       Labels: None
   Part No SW: 4N0 907 401     HW: 059 907 309 L
   Component: 3.0l V6 TDI   H25 0002
   Revision: CAH25---    CVN: 83184B4256070F8A755A2113755A211300000000D6C3ECFE
   Coding: 0A2A4012056E050334086000000400000000000000000000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TDI0114N0907401 001007
   ROD: EV_ECM30TDI0114N0907401.rod
   VCID: 678AB8E67FEB62C28E9-8032
   VINID: 9D196AAAA58819A7800060C700C835DF8B
17156 - Databus
          U1123 00 [00100111] - Received Error Message
                    Mileage: 360304 km
                    Date: 2023.11.05
                    Time: 19:08:45
                    Engine RPM: 782.00 /min
                    Normed load value: 44.3 %
                    Coolant temperature: 53  C
                    Intake air temperature: 17  C
                    Voltage terminal 30: 13.040 V
                    Drivetrain coordinator: brake function status-Bits 0-7: 32
                    Acceleration: 0.000 m/s
                    Engine status: COENG_RUNNING
30403 - NOx Sensor Bank 2
          P225B 00 [10101111] - Calibration Failure
                    Mileage: 360304 km
                    Date: 2023.11.05
                    Time: 19:08:47
                    Engine RPM: 783.00 /min
                    Normed load value: 43.9 %
                    Voltage terminal 30: 13.080 V
28992 - No Communications with NOX Sensor 2
          U029E 00 [00100111] - -
                    Mileage: 360304 km
                    Date: 2023.11.05
                    Time: 19:08:45
                    Engine RPM: 781.00 /min
                    Com st X Set2 Val1-Bits 0-7: 0
                    Com st X Set2 Val2-Bits 0-7: 0
                    Com st X Set2 Val3-Bits 0-7: 0
                    Com st X Set2 Val4-Bits 0-7: 32
                    Com st X Set2 Val4-Bits 0-7: 0
                    Com st X Set2 Val5-Bits 0-7: 0
                    Com st X Set2 Val6-Bits 0-7: 0
                    Com st X Set2 Val7-Bits 0-7: 1
                    Com st X Set2 Val7-Bits 0-7: 0
Readiness: 1 1 0 0 1
Address 02: Auto Trans (J217)       Labels:* None
   Part No SW: 4N0 927 158 C    HW: 0D5 927 156 P
   Component: 0D5  30TDIRdW H05 1004
   Revision: --H05---    CVN: 9E4436B400009238
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002014
   ROD: EV_TCMALX52011_VW53.rod
   VCID: 353622AE75C7C052CC5-8060
   ATF pump:
   Subsystem 1 - Part No SW: 4M0 927 154 AA    HW: 0D7 321 281 A
   Component: V552 ATFP  H01 0705
   Serial number: 170415200090
   Part No SW: 4N0 907 379 S    HW: 4N0 907 379 P
   Component: ESP9 Premium  H05 0848
   Dataset Number: 4N0909504Q  0001 CVN: E1BB3D60
   Coding: 1CAA329D31A24B9C11A14898187D91E2F5B9C1384C8CD28812188947AF9D83
   Shop #: WSC 00720 210 00000
   ROD: EV_ESP9BOSCHCMP_004_AU58.rod
   VCID: 48C85B5A12354DBAA73-801C
   Part No SW: 4M4 959 760 D    HW: 4M4 959 760 D
   Component: MEM-BFS       009 0042
   Serial number: 00000294453276 Dataset Number: 4N0909866C  0011
   Coding: 0038B6400085BE8100438181A101A10081A100070700878700000000000600
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006009
   ROD: EV_SCMPasseSideCONTIAU736_VW38.rod
   VCID: 3D263A8E4DF71812045-8068
   Valve block 1 in front seat passenger side:
   Subsystem 1 - Part No SW: 4N0 907 182     HW: 4N0 907 182
   Component: N477 VB1 BFSv  H04 0011
   Serial number: SJ800112121740258168
   Coding: BF2F00
   Part No SW: 4N0 907 063 CE    HW: 4N0 907 063 AE
   Component: BCM1 MLBevo   H10 0634
   Dataset Number: 4N0909514E  0026
   Coding: 07500143C13900CD070C57281FEB8C68131BB31114060493A1000800220196800845010200100000000003030045001B380010104001F107000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 013006
   ROD: EV_BCM1BOSCHAU651_013_VW53.rod
   VCID: 73B2DCB63B339E62221-8026
   Subsystem 1 - Part No SW: 4N2 955 119     HW: 4N2 955 119
   Component: WWS651 171020  052 0913
   Serial number: 904753F0401729300645
   Coding: 7DC767
   Serial number: 21011914X81A955555A0
   Coding: 02005E
   Subsystem 3 - Part No SW: 4N2 941 501 C    HW: 4N2 941 501 C
   Component: E1 - LTM  H09 0086
   Serial number: 18S19.12.1700300076
   Serial number: GX1CE110101723310265
   Coding: 210000
   Interior Light Module:
   Subsystem 5 - Part No SW: 4N0 947 135 BM    HW: 4N0 947 135 BM
   Component: Dachelektroni  H42 0056
   Serial number: 00000070460000000000
   Coding: 200000
   Subsystem 6 - Part No SW: 80A 907 705     HW: 80A 907 705
   Component: J866-EVLS-SG  H03 0100
   Serial number: WA129910000040935573
   Coding: 020100
   Front windshield washer pump:
   Subsystem 7 - Part No SW: 4N0 907 605     HW: 4N0 907 605
   Component: J1100/SWP  H09 0004
   Serial number: 00000000001733500282
   Coding: 040000
   Interior Light Module 2:
   Subsystem 8 - Part No SW: 4N0 947 111 G    HW: 4N0 947 111 G
   Component: Dachelektroni  H42 0055
   Serial number: 00000068830000000000
66432 - Indicator Lamp for Emergency Flashers
          B11E7 15 [00001001] - Open or Short to Plus
                    Reset counter: 126
                    Mileage: 360304 km
                    Date: 2023.11.05
                    Time: 19:08:45
                    average_Voltage_terminals: 13.10 V
                    Outside air temperature sensor-Outside air temperature on CAN: 13.50  C
                    interior_temperature: 20.00  C
                    Vehicle speed: 0.00 km/h
   Part No SW: 4N0 907 561 F    HW: 4N0 907 561
   Component: LRR4          H04 0332
   Dataset Number: 4N4909863L  0001
   Coding: 5461FF4478082C00010360E0000000BA4A1246484481009E00
   ASAM Dataset: EV_ACCBOSCHAU65X 002023
   ROD: EV_ACCBOSCHAU65X_VW53.rod
   VCID: 34301FAA7EBDD95AFBB-8060
2342 - Databus
          [FAULT_ACA_QF_STATUS_DISPLAY_ERROR]
                    Reset counter: 126
                    Mileage: 360304 km
                    Date: 2023.11.05
                    Time: 19:08:44
                    Control Module temperature: 16  C
                    Voltage terminal 15: 13.0 V
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: 0.00 m/s
                    Adaptive distance regulation: status: ACC_irreversible error
                    Steering_angle-Data: -13.700
                    Yaw_rate-Data: 0.000 rad/s
                    adjustment_calculation: OFF
                    Misalignment angle: horiz: -0.490
                    Misalignment angle: horiz: fast algorithm: -0.673
                    Congestion pilot: status: OFF
                    Outside temperature: 13.50  C
                    Sensor blindness: radar: no blindness detected
0267 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [00001001] - -
          [FAULT_ALIGNMENT_NOT_OK]
                    Reset counter: 126
                    Mileage: 360304 km
                    Date: 2023.11.05
                    Time: 19:08:44
2341 - Databus
          [FAULT_LIDAR_ERROR]
                    Reset counter: 126
                    Mileage: 360304 km
                    Date: 2023.11.05
                    Time: 19:08:44
   Part No SW: 4N0 959 655 R    HW: 4N0 959 655 H
   Component: AirbagVW31    H35 2710
   Serial number: 003U1M004HWN Dataset Number: 4N0909602VA 0001
   Coding: AAFCF0C30CC00000985400FFF08D410000C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001028
   ROD: EV_AirbaVW31SMEAU65x_001_VW53.rod
   VCID: 4BC264560343A6A28A1-801E
   Left seat belt tensioner:
   Serial number: 00AI2017340014200000
   Coding: 0A0301
   Right seat belt tensioner:
   Serial number: 00AI2017333007300000
   Coding: 0A0301
   Subsystem 3 - Part No SW: -----------    HW: 480 001 412 17
   Serial number: 35700000000C186D682S
   Subsystem 4 - Part No SW: -----------    HW: 480 001 412 17
   Serial number: 358000000001086D682H
   Subsystem 5 - Part No SW: -----------    HW: 480 032 712 17
   Serial number: 351001C08F24C4D12B3B
   Subsystem 6 - Part No SW: -----------    HW: 480 032 712 17
   Serial number: 352001C08F2D00C0282%
   Subsystem 7 - Part No SW: -----------    HW: 480 032 712 17
   Serial number: 355001C088354E70BDFS
   Subsystem 8 - Part No SW: -----------    HW: 480 032 712 17
   Serial number: 356001C088358CE0CAEZ
   Subsystem 9 - Part No SW: -----------    HW: 480 030 912 17
   Component: PedP_Sensor_D  002 0149
   Serial number: 228001C08EDC46009C2J
   Subsystem 10 - Part No SW: -----------    HW: 480 030 912 17
   Component: PedP_Sensor_P  002 0149
   Serial number: 229001C08ED44CE119BV
   Subsystem 11 - Part No SW: -----------    HW: 480 030 912 17
   Component: PedP_Sensor_C  002 0149
   Serial number: 230001C08F24C4506BBA
   Subsystem 12 - Part No SW: -----------    HW: 480 001 112 17
   Serial number: I0M00000000A3518EAAF
   Subsystem 13 - Part No SW: -----------    HW: 480 001 112 17
   Serial number: I0N0000000064518EAAD
   Central crash sensor X/Y:
   Subsystem 14 - Part No SW: -----------    HW: 480 022 312 17
   Component: CentrSensorXY  000 0148
   Serial number: I0O00019D28B1CF5123$
   Part No SW: 4N0 907 129 CA    HW: 4N0 907 129 CA
   ROD: EV_SMLSKLOAU736_VW53.rod
   VCID: 72BCD9B24429976A297-8026
   Part No SW: 4N0 920 790 D    HW: 4N0 920 790 D
   Component: FBenRDWACC--- H10 0153
   Dataset Number: 4N0909525F  0023
   Coding: A58400E07C80060001B5E160B080480008000000
   Shop #: WSC 00720 210 12345
   ROD: EV_DashBoardAU65X_001_AU58.rod
   VCID: 313E16BE81AFEC7290D-8064
   Part No SW: 4N2 907 468 AB    HW: 4N2 907 468 B
   Component: Gateway       H12 0037
   Revision: 7N000002    Serial number: 0287N271117C29 Dataset Number: 4N0909515VC 0001
   Coding: 060100050004864073960000005B0132DC98004818000000097D078E10000000
   GVL: 71507C080844020002BC88000100C800810B0010000000000000000000000000
   ASAM Dataset: EV_CGateCONTIAU491 003150
   ROD: EV_CGateCONTIAU491_003_AU58.rod
   VCID: 79AEEE9E195FE43268D-802C
   Subsystem 1 - Part No SW: 4N0 951 523 A    HW: 4N0 951 523 A
   Component: E221__MFL  H06 0003
   Subsystem 2 - Part No SW: 4N0 915 181 A    HW: 4N0 915 181 A
   Serial number: 758854010018010800E8
   Inverter for electrical outlet:
   Subsystem 3 - Part No SW: 4N0 907 155     HW: 4N0 907 155
   Component: U13  DCAC  H13 0017
   Serial number: 00000000000000000047
66304 - Databus
          U1124 00 [00001001] - Additional Installations Detected
          [Data_Bus_Commponent_List_detected]
                    Reset counter: 126
                    Mileage: 360304 km
                    Date: 2023.11.05
                    Time: 19:08:44
   Part No SW: 4N0 907 144 C    HW: 8W0 907 144 C
   Component: SCU_MLBevo    H03 0802
   Serial number: 30303030303030 Dataset Number: 4N0909848H  0001
   ASAM Dataset: EV_SCUZFLSAU65X 003019
   ROD: EV_SCUZFLSAU65X.rod
   VCID: 2E040DC29091F38A8DF-807A
Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
   Part No SW: 80A 907 397 D    HW: 80A 907 397 D
   Component: LCM_MLBevo    H07 0022
   Dataset Number: 4N0909519B  0014
   ROD: EV_LCMLeftCONTIAU426_VW53.rod
   VCID: 303813BA8AA5E57A9F3-8064
   Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
   Component: ELV-MLBevo    H05 0032
   Serial number: 17000305535011
   Coding: 8800000000000000
   ROD: EV_ELVMarquMQBB_VW27.rod
   VCID: 323C19B284A9D76AE97-8066
   Component: MEM-FS        009 0042
   Serial number: 00000294454127 Dataset Number: 4N0909856B  0010
   Coding: 00389EC00085BE81000301012101210081A100070700878700000000004600
   Valve block 1 in front seat driver side:
   Component: N475 VB1 FSv  H04 0011
   Serial number: SJ800112121740258166
   Coding: BF2F00
Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
   Dataset Number: 4N0909520B  0014
   Part No SW: 4M1 959 793 C    HW: 4M1 959 793 B
   Component: TSG FS006 0849
   Serial number: YE007QK832733 Dataset Number: 4N0909872A  0037
   Coding: 001DDA00520104C2A009B006
   ROD: EV_DCU2DriveSideMAXHKLO_VW27.rod
   VCID: 3FDA408647FB0A02169-806A
   Part No SW: 4N0 909 144 C    HW: 4N0 909 144 A
   Component: EPS_MLBEVO2BS H20 0503
   Dataset Number: 4N0909852K  0006
   Coding: E1000101010000
   ASAM Dataset: EV_EPSVWBSAU426 009015
   ROD: EV_EPSVWBSAU426_009_VW53.rod
   Part No SW: 4N0 907 064 G    HW: 4N0 907 064 G
   Component: BCM2 MLBevo H14 0111
   Coding: 013500002FB000406309A0040E00090E0B004000804F02502F0400200504823F001F0100010001
   ASAM Dataset: EV_BCM2CONTIAU651 006004
   ROD: EV_BCM2CONTIAU651_006_AU58.rod
   VCID: 33321CB67BB3DE62E21-8066
   ID - sensor:
   Serial number: 000000000ZY1731929P7
   Serial number: 00000000000099954213
   Subsystem 4 - Part No SW: 3G0 962 243 B    HW: 3G0 962 243 B
   Component: GEB.F.Heckoef  H17 0904
   Serial number: 58334770
   Rear spoiler control module:
65677 - Rear Lid Opening Sensor 1
          B1471 01 [00001001] - Electrical Failure
                    Reset counter: 126
                    Mileage: 360304 km
                    Date: 2023.11.05
                    Time: 19:08:47
                    Supply voltages-Terminal 30 power supply: 13.313 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 13.237 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 13.167 V
                    general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0  C
                    general_additional_freeze_frame-interior_temperature: -50.0  C
                    general_additional_freeze_frame-terminal_control_intern_status: 1B 02 0A 90 04 60
                    can_lin_communication_freeze_frame: 11111111 11111111 11111111 11111111
   Part No SW: 4N0 035 223 C    HW: 4N0 035 223
   Component: MIB2_amp_P_D5 H01 0170
   Revision: 00000001    Serial number: AUZ8ZAHKC003UD8 Dataset Number: 4N4909510B  0011
   Coding: 0156010000AAAAAFAA0000010000
   ASAM Dataset: EV_AMPMst16C1Gen2pALPI 001011
   ROD: EV_AMPMst16C1Gen2pALPI_AU58.rod
   VCID: 2410EFEACE5D49DA6BB-8070
Address 48: Seat, Rear, DS (J876)       Labels:* None
   Part No SW: 4M1 959 760 C    HW: 4M1 959 760 C
   Component: MEM-FS-Fond   009 0042
   Serial number: 00000293533908 Dataset Number: 4N0909878B  0013
   Coding: 002892800080B081020099B9009900000000009F9F00000000000000001000
   ASAM Dataset: EV_SCMRearDriveCONTIAU651 001003
   ROD: EV_SCMRearDriveCONTIAU651_VW53.rod
   VCID: 392E2E9E59DF243228D-806C
   Driver side rear seat switch module:
   Subsystem 1 - Part No SW: 4N0 959 819 A    HW: 4N0 959 819 A
   Component: E683 - SBM  H04 0054
   Serial number: G11S12.12.170010-121
   Valve block 1 in rear seat driver side:
   Subsystem 2 - Part No SW: 4N0 907 182 C    HW: 4N0 907 182 C
   Component: N479 VB1 FSh  H04 0011
   Serial number: SJ80012210174025814C
   Coding: AC2F00
   Part No SW: 4M1 959 792 C    HW: 4M1 959 792 B
   Component: TSG BFS006 0849
   Serial number: YE007QK829676 Dataset Number: 4N0909873A  0037
   Coding: 001DDA005E0104C2A009B004
   ROD: EV_DCU2PasseSideMAXHKLO_VW27.rod
   VCID: 3E243D8240F1030A1DF-806A
          B1487 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 126
                    Mileage: 360304 km
                    Date: 2023.11.05
                    Time: 19:08:43
Address 5B: Seat,Rear,PS (J877)       Labels:* None
   Component: MEM-BFS-Fond  009 0042
   Serial number: 00000293533468 Dataset Number: 4N0909879B  0013
   Coding: 002896800080B081020099B99B99BB000000009F9F00000000000000001000
   ASAM Dataset: EV_SCMRearPasseCONTIAU651 001003
   Passenger side rear seat switch module:
   Component: E688 - SBM  H04 0054
   Valve block 1 in rear seat passenger side:
   Component: N481 VB1 BFSh  H04 0011
   Serial number: SJ800122101740258146
   Coding: AC2F00
Address 5F: Information Electr. (J794)       Labels:| 4G1-035-MIB-HGH2.clb
   Part No SW: 4K0 035 063 D    HW: 4N0 035 063 A
   Component: MU-H-LND-EU   045 2711
   Dataset Number: 4N0909545VC 0003
   Coding: 0156010100000000C3111102C00800302F0001E601F008008E
   Subsystem 1 - Part No: V03 959 807 SM
   Component: MIB2P_EU_Q322  0630
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4N0 919 605 K    HW: 4N0 919 605
   Component: DU AU651 Top  H42 0147
   Serial number: INX00105121700040070
   Compact disc data bank:
   Component: Gracenote2  1006
   Volume Control 1:
   Subsystem 4 - Part No SW: 4N1 919 616 B    HW: 4N1 919 616
   Serial number: 00004417000196234050
   Multimedia System 5:
   Subsystem 5 - Part No SW: 4N0 919 603 C    HW: 4N0 919 603
   Component: DU AU651 Bot  H41 0147
   Serial number: INX00117111700050275
   Media Player 1:
   Subsystem 6 - Part No SW: 4N0 035 123     HW: 4N0 035 123
   Component: DISC PLAYER  H06 0006
   Serial number: AUZ8ZCHKJ003WY/
   Media socket:
   Subsystem 7 - Part No SW: 4N0 035 736 A    HW: 4N0 035 736
   Component: MediaConnectH  014 0133
   Serial number: 051700681677008
Address 61: Battery Regul. (J1120)       Labels: 4N0-915-105.clb
   Part No SW: 4N0 915 105 B    HW: 4N0 915 105 B
   Component: BMS_48V_LiIon H06 0108
   ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
   ROD: EV_BMS48VLiIonLGAU536_AU58.rod
   VCID: 290EFEDEA97F94B258D-807C
Address 65: Tire Pressure (J502)       Labels: 4M0-907-273.clb
   Part No SW: 4M0 907 273 B    HW: 4M0 907 273 B
   Component: RDKHUFAU736   H04 0010
   Serial number: 30000000014689 Dataset Number: 4N0909850B  0001
   ROD: EV_RDKHUFAU736_AU38.rod
   VCID: 2F3A10C6979BFA82869-807A
   Part No SW: 8W5 959 107 B    HW: 8W5 959 107
   Component: HDSG-Modul    H13 0163
   Revision: --------    Serial number: 31692148700000 Dataset Number: 4N0909541A  0004
   Coding: 1430
   ASAM Dataset: EV_DeckLidCONTIAU736 001015
   VCID: 45D6526E252750D25C5-8010
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 4N0 907 777 AE    HW: 4N0 907 777 B
   Component: Fahrwerk-SG   H51 2016
   Serial number: 1912170447  Dataset Number: 4N0909576M  0008
   Coding: 745C4843FA50
   ASAM Dataset: EV_ChassContrContiAU651 001011
   ROD: EV_ChassContrContiAU651_001_AU58.rod
   VCID: 7DA6FA8E0D77D812445-8028
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004130234356
   Coding: 303030
   Part No SW: 4N2 713 041 E    HW: 4N2 713 041 E
   Component: GSM-LL        H09 0077
   Revision: 0L0D5012    Serial number: 17101844498688
   ROD: EV_GSMWaehlZFAU736_AU58.rod
Address 82: Head Up Display (J898)       Labels:* None
   Part No SW: 4N2 919 617 A    HW: 4N2 919 617
   Component: HeadupDisplay H09 1815
   Coding: 4700E0
   ASAM Dataset: EV_HeadUpDisplAU65X 001010
   ROD: EV_HeadUpDisplAU65X_VW53.rod
   VCID: 363425A268C1CB4AC5F-8062
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* 4N0-907-107-V2.clb
   Part No SW: 4KE 907 107 AC    HW: 4N0 907 107 H
   Component: zFAS Var C    H08 0291
   Dataset Number: 4N0909466M  0049
   Coding: 04C1840000000000000FD60000F0D40C181F520000000000000000000096D401009BA80000000000000000800000000000000000000000000000400000000000000078D0008000B000800080000000000080400000A0
   ASAM Dataset: EV_ZFASAU516 001005
   ROD: EV_ZFASAU516_001_VW53.rod
   VCID: 0058837A7A85B5FA2F3-8054
2114638 - Databus
          [LS1_SensorHeader_LS1_Fehler]
                    Reset counter: 126
                    Mileage: 360304 km
                    Date: 2023.11.05
                    Time: 19:08:44
4108 - Databus
          [irreversibler_Fehler_im_ACC_System]
                    Reset counter: 126
                    Mileage: 360304 km
                    Date: 2023.11.05
                    Time: 19:08:44
65540 - Following-Distance Warning (High)
          C12DA F0 [00001001] - Status Feedback for HMI Implausible
                    Reset counter: 126
                    Mileage: 360304 km
                    Date: 2023.11.05
                    Time: 19:08:45
                    Profile master status distance warning high-Nominal status: On
                    Profile master status distance warning high-Actual status:: Malfunction
Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
   Part No SW: 4M0 907 355 D    HW: 4M0 907 355 B
   Component: SCR-Stg-G3H04 0006
   Dataset Number: 4N0909571D  0002
   ASAM Dataset: EV_RDCMINERGAU736 005012
   ROD: EV_RDCMINERGAU736_VW53.rod
Address BA: Motor Mounts (J931)       Labels: None
   Part No SW: 4M0 907 145 E    HW: 4M0 907 145 B
   Component: AEMevo        H10 0132
   Dataset Number: 4N0909578G  0001
   ASAM Dataset: EV_AEMZFAU736 006014
   ROD: EV_AEMZFAU736_VW53.rod
   Part No SW: 4M1 959 795 C    HW: 4M1 959 795 B
   Component: TSG HFS006 0849
   Serial number: YE007QK723322 Dataset Number: 4N0909897A  0037
   Coding: 000DDA00020104C2A008B004
   ROD: EV_DCU2RearDriveMAXHKLO_VW38.rod
   VCID: 41DE467E310F7CF260D-8014
   Component: TSG HBFS006 0848
   Serial number: YE007RB71369A Dataset Number: 4N0909897A  0041
   Coding: 000FDA0000010482A008B000
   Shop #: WSC 00164 210 00000
   ROD: EV_DCU2RearPasseMAXHKLO_VW38.rod
Address C4: DC/DC Converter (A7)       Labels: 4M0-959-663.clb
   Part No SW: 4M0 959 663 C    HW: 4M0 959 663 C
   Component: PCU10         022 0323
   Dataset Number: 4N0909475A  0014
   ASAM Dataset: EV_DCDC48V210ABOSCHAU736 001008
   ROD: EV_DCDC48V210ABOSCHAU736_VW53.rod
   VCID: 3A2C31925CD92F2A217-806E
Address CB: Rear Axle Steering (J1019)       Labels:* None
   Part No SW: 4N0 909 145 K    HW: 4N0 909 145 C
   Component: HAL_MLBevoH03 0398
   Revision: --------    Serial number: CCC_098_B_9056_ Dataset Number: 4N0909904K  0001
   Coding: 42244200
   ASAM Dataset: EV_RearAxleSteerZFAU736 010018
   ROD: EV_RearAxleSteerZFAU736_010_VW53.rod
Address CC: Starter-Generator (C29)       Labels:* None
   Part No SW: 4N0 903 028 Q    HW: 4N0 903 028 Q
   Component: BSG-HP1-65    H18 0527
   Serial number: 29072200030018
   Coding: 28000000000000
   ASAM Dataset: EV_Start48VAU651 002007
   ROD: EV_Start48VAU651_002.rod
Address CD: Laser Scanner (J1122)       Labels: None
   Part No SW: 4K8 907 660 C    HW: 4N0 907 660
   Component: LASER_SCANNER H36 0205
   Dataset Number: 4N4909639L  0004
   ASAM Dataset: EV_LaserScannAU651 013017
   ROD: EV_LaserScannAU651_013.rod
11575298 - No Basic Setting
          B2010 00 [00001001] - -
          [Error_while_adjustment]
                    Reset counter: 126
                    Mileage: 360304 km
                    Date: 2023.11.05
                    Time: 19:08:44
                    Control Module temperature-Host: external temperature: 13  C
                    Control Module temperature-Zynq: internal temperature: 28  C
                    Control Module temperature-Host: internal temperature: 13  C
                    Control Module temperature-Zynq: external temperature: 10  C
                    Voltage terminal 15: 13.195 V
                    Performed adjustment-Year: 2000
                    Performed adjustment-Month: 11
                    Performed adjustment-Day: 5
                    Performed adjustment-recorded yaw angle: -0.00
                    Performed adjustment-Saved pitch angle: -0.00
                    Performed adjustment-Store sway angle: -0.00
                    Status adjustment-Status: Marginal conditions have not been met
                    Status adjustment-Reason: Adjustment table incorrectly positioned
11546627 - Laser for Adaptive Cruise
          C12EB F1 [00001001] - Malfunction
          [Heater_Resistance_too_high_error]
                    Reset counter: 126
                    Mileage: 360304 km
                    Date: 2023.11.05
                    Time: 19:08:47
                    Voltage terminal 15: 13.102 V
                    heating_resistor: 95.64 Ohm
                    heater-Medium power: 0.000 W
                    heater-Voltage: 0.000 V
                    heater-PWM value: 0 %
                    heater-Current draw (mean value): 0.000 A
                    Heating and cleaning management-Visibility: 0 %
                    Heating and cleaning management-Degree of contamination: 95 %
                    Heating and cleaning management-Heating status: 02
                    Heating and cleaning management-Cleaning status: 02
                    Outside temperature: 13  C
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-592.clb
   Part No SW: 7PP 941 592 BA    HW: 7PP 941 592 B
   Component: LED1L         H09 4002
   Dataset Number: 4N0909471B  0012
   ROD: EV_LEDModLeftMELCOAU736_VW51.rod
   VCID: 1868CB1A02151D3AF73-804C
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-592.clb
   Component: LED1R         H09 4002
   Dataset Number: 4N0909472B  0012
Address DE: Charger 1 for mobile dev (J1146)       Labels:* 4N0-035-502.clb
   Part No SW: 4N0 035 502     HW: 4N0 035 502
   Component: WLC Front     H06 0042
   Coding: 800000
   ROD: EV_Charg1MobilDevicAU651_004_VW53.rod
   VCID: 619EA6FE91CF1CF240D-8034
Address E0: Auxiliary Display 1 (E857)       Labels: None
   Part No SW: 4N0 035 705 A    HW: 4N0 035 705
   Component: E859          H41 0019
   Serial number: KE0 MK90005157C
   ASAM Dataset: EV_SCC1AU651 001004
   ROD: EV_SCC1AU651.rod
   VCID: 270AF8E6BF6BA2C24E9-8072
End----------(Elapsed Time: 03:03, VBatt start/end: 12.9V/13.2V)-----------
WORKING LOG BEFORE MESSING
Saturday,28,January,2023,17:01:34:27503
VCDS Version: 23.3.1.0 (x64)  HEX-V2 CB: 0.4631.4
          DE E0
VIN: WAUZZZF86JN006370   Mileage: 360178km-223804miles
1B-Active Steering -- Status: Malfunction 0010
33-Flux Capacitor -- Status: Malfunction 0010
AC-Reductant Control -- Status: Malfunction 0010
BB-Door Rear Drv -- Status: Malfunction 0010
CC-Starter-Generator -- Status: Malfunction 0010
   Revision: CAH25---    CVN: 83184B4256070F8A755A2113755A21130000000000000000
   VCID: 678AB8E67FEB62C2AE1-8032
18851 - Control Module for Reductant Metering System; Voltage Suppy
          P21CA 00 [039] - Electrical Malfunction
                    Mileage: 360178 km
                    Date: 2023.10.28
                    Time: 16:44:31
                    Engine RPM: 778.50 /min
                    Normed load value: 43.1 %
                    Coolant temperature: 81 °C
                    Intake air temperature: 26 °C
                    Voltage terminal 30: 12.300 V
                    Reducing agent quality sensor: urea concentration: 399.99 %
                    Sensor 2 for temp. reducing agent: act. value: 12.0 °C
                    Sensor for reducing agent fill level: voltage: 13107.0 mV
                    Reducing agent metering system heating circuit 1: actual current: 0.0 A
                    Reducing agent metering system heating circuit 2: actual current: 0.0 A
                    Pump for reducing agent: speed: 0.0 /min
                    Current temperature with NOx Reduction CAT: 114.7 °C
          P225B 00 [175] - Calibration Failure
                    Mileage: 360178 km
                    Date: 2023.10.28
                    Time: 16:44:31
                    Engine RPM: 782.50 /min
                    Voltage terminal 30: 12.280 V
28991 - No Communications with NOX Sensor 1
          U029D 00 [039] - -
                    Mileage: 360178 km
                    Date: 2023.10.28
                    Time: 16:44:29
                    Normed load value: 43.5 %
                    Com st X Set2 Val4-Bits 0-7: 240
          U029E 00 [039] - -
                    Mileage: 360178 km
                    Date: 2023.10.28
                    Time: 16:44:29
25425 - No Communications with Particulate Sensor
          U02A3 00 [039] - -
                    Mileage: 360178 km
                    Date: 2023.10.28
                    Time: 16:44:29
   Coding: 100000
   ROD: EV_TCMALX52011_AU65.rod
   VCID: 353622AE75C7C052ECD-8060
   ATF pump:
   ROD: EV_ESP9BOSCHCMP_AU58.rod
   VCID: 48C85B5A12354DBA87B-801C
   VCID: 3D263A8E4DF7181224D-8068
   Coding: BF2F00
   ROD: EV_BCM1BOSCHAU651_013.rod
   VCID: 73B2DCB63B339E62029-8026
   Coding: 7DC767
   Coding: 02005E
   Coding: 210000
   Coding: 200000
   Coding: 020100
   Coding: 040000
          B11E7 15 [009] - Open or Short to Plus
                    Reset counter: 124
                    Mileage: 360178 km
                    Date: 2023.10.28
                    Time: 16:37:35
                    average_Voltage_terminals: 12.30 V
                    Outside air temperature sensor-Outside air temperature on CAN: 18.50 °C
                    interior_temperature: 23.00 °C
393217 - End-Stops for HVAC Flaps Not Learned
          B175A 00 [009] - -
                    Reset counter: 124
                    Mileage: 360178 km
                    Date: 2023.10.28
                    Time: 16:37:33
                    Outside air temperature sensor-Outside air temperature on CAN: 18.00 °C
                    System run time-Engine running time: 65535 s
                    System run time-Terminal 15 on: 0 s
   ROD: EV_ACCBOSCHAU65X_AU58.rod
   VCID: 34301FAA7EBDD95ADB3-8060
2406 - Laser for Adaptive Cruise
          C12EB F3 [009] - Distance Detection Restricted
          [FAULT_LASER_BLIND]
                    Reset counter: 124
                    Mileage: 360178 km
                    Date: 2023.10.28
                    Time: 16:38:31
                    Control Module temperature: 42 °C
                    Voltage terminal 15: 12.1 V
                    Longitudinal acceleration: 0.00 m/s²
                    Adaptive distance regulation: status: ACC_StandBy
                    Steering_angle-Data: 1.000 °
                    Yaw_rate-Data: 0.011 rad/s
                    adjustment_calculation: On
                    Misalignment angle: horiz: -0.529 °
                    Misalignment angle: horiz: fast algorithm: -0.629 °
                    Outside temperature: 18.50 °C
   VCID: 4BC264560343A6A2AA9-801E
   Coding: 0A0301
   Coding: 0A0301
   VCID: 72BCD9B24429976A09F-8026
   VCID: 313E16BE81AFEC72B05-8064
1048578 - Incorrect Basic Setting
          B2011 00 [009] - -
          [ECU no or wrong basic setting]
                    Reset counter: 117
                    Mileage: 359673 km
                    Date: 2023.10.25
                    Time: 20:03:14
   GVL: 71587C080844020002BC88000100C800810B0010000000000000000000000000
   VCID: 79AEEE9E195FE432485-802C
   VCID: 2E040DC29091F38AAD7-807A
18688 - Initialization Sensor in Steering Motor
          C110E 01 [008] - Electrical Failure
                    Reset counter: 164
                    Mileage: 360178 km
                    Date: 2023.10.28
                    Time: 16:46:39
                    Expanded ambient data 10-Malfunction type: 00 51
                    Expanded ambient data 10-Terminal 30 power supply: 12.40 V
                    Expanded ambient data 10-Steering wheel angle: internal value: 0 °
                    Expanded ambient data 10-Engine current: 1.20 A
                    Expanded ambient data 10-System status: high
                    Expanded ambient data 10-Calculated vehicle speed: -140 km/h
                    Expanded ambient data 10-Active_steering_internal_status: Initializing
                    Expanded ambient data 10-position_control_mode: NormalPositionControl
                    Expanded ambient data 10-Steering wheel angle velocity: -10 °/s
                    Expanded ambient data 10-Steering_torque_eps: -0.80 Nm
   VCID: 303813BA8AA5E57ABFB-8064
   VCID: 323C19B284A9D76AC9F-8066
   Coding: BF2F00
   ROD: EV_DCU2DriveSideMAXHKLO_AU58.rod
   VCID: 3FDA408647FB0A02361-806A
   ROD: EV_EPSVWBSAU426_009.rod
   VCID: 33321CB67BB3DE62C29-8066
   ID - sensor:
   Component: ID-Geber  H09 0231
          B1471 01 [009] - Electrical Failure
                    Reset counter: 124
                    Mileage: 360178 km
                    Date: 2023.10.28
                    Time: 16:41:05
                    Supply voltages-Terminal 30 power supply: 12.534 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.464 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.402 V
   ROD: EV_AMPMst16C1Gen2pALPI.rod
   VCID: 2410EFEACE5D49DA4B3-8070
   VCID: 392E2E9E59DF2432085-806C
   Coding: AC2F00
   ROD: EV_DCU2PasseSideMAXHKLO_AU58.rod
   VCID: 3E243D8240F1030A3D7-806A
196677 - Switch for Interior Door Handle
          B132E 29 [009] - Signal Implausible
                    Reset counter: 124
                    Mileage: 360178 km
                    Date: 2023.10.28
                    Time: 16:41:44
196709 - Switch for Exterior Door Handle
          B132F 29 [009] - Signal Implausible
                    Reset counter: 124
                    Mileage: 360178 km
                    Date: 2023.10.28
                    Time: 16:41:44
   Coding: AC2F00
   Volume Control 1:
   Media Player 1:
   Media socket:
          B201A 00 [009] - -
                    Reset counter: 124
                    Mileage: 360178 km
                    Date: 2023.10.28
                    Time: 16:42:37
                    Voltage terminal 30: 12.4 V
                    Status_Software_Version_Management-module_name: zFAS_Var_C_CL020
Address 61: Battery Regul. (J1120)       Labels: 4M0-915-105.clb
   VCID: 290EFEDEA97F94B2785-807C
   ROD: EV_RDKHUFAU736.rod
   VCID: 2F3A10C6979BFA82A61-807A
   Coding: 1430
   VCID: 45D6526E252750D27CD-8010
   VCID: 7DA6FA8E0D77D81264D-8028
   Coding: 303030
   ROD: EV_GSMWaehlZFAU736_VW53.rod
   Coding: 4700E0
   ROD: EV_HeadUpDisplAU65X.rod
   VCID: 363425A268C1CB4AE57-8062
   ROD: EV_ZFASAU516_001.rod
   VCID: 0058837A7A85B5FA0FB-8054
0259 - Control Module for Reductant Metering System; Voltage Suppy
          P21CA 00 [013] - Electrical Malfunction
                    Reset counter: 124
                    Mileage: 360178 km
                    Date: 2023.10.28
                    Time: 16:44:29
                    Terminal 30A voltage: 12.46 V
                    Terminal 30B voltage: 3.40 V
                    Supply voltage for external components: 5.00 V
                    Reducing agent quality sensor: voltage terminal 31: 0.00 V
                    Pump for reducing agent: speed: 0 /min
                    Pump for reducing agent: current: 0.00 A
                    Reducing agent pump: operating state: OFF
                    Reducing agent pump: activation: 0.00 %
                    Reducing agent pump: end stage activation status: not active
                    Reducing agent pump: end stage temperature: 16 °C
                    Heating circuit 1 f. red. agent metering sys.: end stage temp.: 11 °C
                    Sensor for reducing agent tank temperature: temperature: 12 °C
                    Pressure sensor for reducing agent: voltage: 0.71 V
                    Sensor for reducing agent fill level: fill level height: 234 mm
                    Reducing agent quality sensor: urea concentration: 106.50 %
                    Sensor 2 for temp. reducing agent: act. value: 82.00 °C
                    Heating circuit 1 for reducing agent: power: 0 W
                    Heating circuit 1 for reducing agent: power set value: 0 W
                    Heating circuit 1 for reducing agent: power limitation: 130 W
                    Heating circuit 3 for reducing agent: power: 0 W
                    Heating circuit 3 for reducing agent: power set value: 0 W
                    Heating circuit 3 for reducing agent: power limitation: 78 W
                    Heating circuit 2 for reducing agent metering: power: 0 W
                    Heating circuit 2 for reducing agent metering: activation: not active
                    Dataset_Elements: F81049
   ROD: EV_AEMZFAU736_006.rod
   VCID: 41DE467E310F7CF2405-8014
                    Reset counter: 117
                    Mileage: 359673 km
                    Date: 2023.10.25
                    Time: 20:03:13
                    Reset counter: 117
                    Mileage: 359673 km
                    Date: 2023.10.25
                    Time: 20:03:13
   Serial number: YE007QK72326A Dataset Number: 4N0909896A  0037
196753 - Motor for rear side window shade
          B154B 01 [008] - Electrical Failure
                    Reset counter: 159
                    Mileage: 359879 km
                    Date: 2023.10.26
                    Time: 12:17:40
   ROD: EV_DCDC48V210ABOSCHAU736.rod
   VCID: 3A2C31925CD92F2A01F-806E
   Coding: 42244200
   Coding: 00000000000000
19261 - Control module not coded
          U1013 00 [047] - -
          [codification not implemented]
                    Reset counter: 124
                    Mileage: 360178 km
                    Date: 2023.10.28
                    Time: 16:44:28
          C12EB F1 [009] - Malfunction
                    Reset counter: 124
                    Mileage: 360178 km
                    Date: 2023.10.28
                    Time: 16:45:03
                    Control Module temperature-Host: external temperature: 25 °C
                    Control Module temperature-Zynq: internal temperature: 39 °C
                    Control Module temperature-Host: internal temperature: 23 °C
                    Control Module temperature-Zynq: external temperature: 25 °C
                    Voltage terminal 15: 12.283 V
                    heating_resistor: 101.16 Ohm
                    Heating and cleaning management-Degree of contamination: 100 %
                    Outside temperature: 18 °C
   VCID: 1868CB1A02151D3AD7B-804C
   Coding: 800000
   VCID: 619EA6FE91CF1CF2605-8034
   VCID: 270AF8E6BF6BA2C26E1-8072
End----------(Elapsed Time: 03:01, VBatt start/end: 12.4V/12.4V)-----------
What exactly did you do?
Check your Debug sub-folder. There should be log files in there that have a record of what you did.
That said, I have no idea what's involved in fixing the Basic Settings fault for the laser sensor.
smurph98
C?ID=545507
Hi Uwe. Will check that and post
smurph98
C?ID=545507
looked in the logs
possibly the first line of the following
Address 0xCD,4K8 907 660 C,UDS Basic Settings,IDE09847-ENG164676-Production calibration,Saturday,04,November,2023,16:00:10:27503
Address 0xCD,4K8 907 660 C,UDS Basic Settings,IDE09847-ENG164676-Production calibration,Saturday,04,November,2023,16:10:45:27503
Address 0xCD,4K8 907 660 C,UDS Basic Settings,MAS03646-ENG164676-Customer service calibration,Saturday,04,November,2023,16:10:53:27503
Address 0x17,4N0 920 790 D,UDS Basic Settings,IDE04327-Activation of SWaP function,Saturday,04,November,2023,16:12:47:27503
Address 0x17,4N0 920 790 D,UDS Basic Settings,IDE04328-Deletion of a SWaP function,Saturday,04,November,2023,16:48:16:27503
Address 0x17,4N0 920 790 D,UDS Basic Settings,IDE04327-Activation of SWaP function,Saturday,04,November,2023,16:48:20:27503
All I can do is shake my head had wonder why someone would go "messing" with these functions.
smurph98
C?ID=545507
It was this line.
The rest were attempts at undoing but all refused.
I shook my own head also.
MasterTommy
Amsterdam
C?ID=295586
Kwik fit with an A8?
Anyway, if you get driver assist errors again, there is metric ton of updates for driver assist systems including the laserscanner for this generation A8.
smurph98
C?ID=545507
Kwik fit have just taken delivery and training for the driver assists and were confident that they could do it 🙄 local Audi were quoting £650 min and were looking at next month.
Which updates are you meaning ?
MasterTommy
Amsterdam
C?ID=295586
VAGdiagnose
C?ID=363040
They change the software part number with most updates, if you search for the SW part no without the suffix, youll probably get a load of SW versions.
Edit: I stand corrected, it does appear to be the latest. My bad!
Well, you're both correct and incorrect at the same time :D
There's been an update, and indeed, it uses a different sw number.
There is a TSB with SVM code "CDA003" updating it to SW0306. It uses "FL_4N0907660E_0306_APP__S" and automatically retrieves the correct dataset when logged in online
  • Informative
smurph98
C?ID=545507
I am so sad but appreciate any input even after a while. Just saw this and as there was no previous reply for a while I gave up and purchased a new laser scanner. BUT now am left with a new (second hand) scanner which I have managed to remove the component protection, update via ODIS with SVM. Now says all modules are correctly coded via Odis but this laser scanner retains the error Data set implausible.
I have the VCDS scan from old laser scanner and the new one. I am stuck and don't know if the new scanner is workable or not.
