'13 B8.5 S4 Multiple errors after checking fuses
[27]
Austin, TX, USA
C?ID=558833
I was receiving some errors regarding the airbag, so I wanted to make sure fuses were good, so I shut the car down and pulled 3 or 4 fuses and put them back where I found them. All were good. Car goes in tomorrow for the airbag. There's also an error for the rear brake light, that's to be expected as I have it disconnected currently for a separate issue.
However, my concern is with the multitude of errors that came up when I started the car back up after checking the fuses. I'd like to have this resolved before it goes in for the airbag. The fact that checking fuses causes something like this is beyond me, but sure enough there's information in the manual that it may occur. I don't know why this is even a thing, I've never had this issue on any other car, but new is new I guess.
On the dash LCD I got the following:
  • Sport Differential system fault
  • Stabilization control fault
  • Dynamic Steer: System fault You can continue driving
Hooking up via HEX-V2 I got the following. Note that trying to clear the codes does not work, maybe I am doing something wrong as I am new to using a tool/software like this. I went in and tried via each error code to clear and they all still remain. Tried shutting car off and trying again, no dice. They all seem to cascade from a communications error. Any assistance in clearing this is much appreciated as the car is running in limp mode now.
Mileage: 129120km-80231mi   Repair Order:
Chassis Type: FL-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 36 42 44 46 47 52 53 56 5F
          62 6C 72 A9
VIN: WAUBGAFL3DA038587   Mileage: 129120km-80231miles
04-Steering Angle -- Status: Cannot be reached 1100
Address 01: Engine (J623-CGXC)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 8K5 907 551 E    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0004
   Revision: --H07---    CVN: 450F3A95
   Coding: 0A250034052600060000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM30TFS0218K5907551E 001004
   ROD: EV_ECM30TFS0218K5907551E.rod
   VCID: 3829398F92DF515AF7B-806C
   VINID: 9D19525D159C0D44400C81481CC7868E95
6201 - Function Restriction due to Faults in Other Modules
          U1113 00 [047] - -
                    Fault Frequency: 8
                    Mileage: 129096 km
                    Date: 2023.08.04
                    Time: 16:05:34
                    Engine RPM: 907.00 /min
                    Normed load value: 38.0 %
                    Coolant temperature: 55 °C
                    Intake air temperature: 54 °C
                    Voltage terminal 30: 11.882 V
                    Engine speed: actual: 672 /min
                    MAF_ENVD: 141.62353 mg/stroke
                    Coolant temperature (unfiltered): 89.25 °C
                    Engine: operating status: IS
                    Engine load: 14.453125 %
                    Vehicle speed: actual: 0 km/h
6082 - Steering Column Control Module
          U0212 00 [047] - No Communications
                    Fault Frequency: 9
                    Mileage: 129096 km
                    Date: 2023.08.04
                    Time: 16:05:35
                    Engine RPM: 1504.00 /min
                    Normed load value: 16.5 %
                    Voltage terminal 30: 11.577 V
                    Engine speed: actual: 1152 /min
                    T_AST_ENVD: 0.00 s
                    Gear: 0
                    Battery voltage: 11.476563 V
6078 - No Communications with Steering Angle Sender (G85)
          U0126 00 [047] - -
                    Fault Frequency: 9
                    Mileage: 129096 km
                    Date: 2023.08.04
                    Time: 16:05:34
                    Engine RPM: 426.00 /min
                    Normed load value: 41.2 %
                    Voltage terminal 30: 11.273 V
                    Engine speed: actual: 1408 /min
                    T_AST_ENVD: 0.00 s
                    Gear: 0
                    Battery voltage: 11.273438 V
6134 - Function Restriction due to Faults in Other Modules
          U1113 00 [047] - -
                    Mileage: 129096 km
                    Date: 2023.08.04
                    Time: 16:05:37
                    Engine RPM: 785.00 /min
                    Normed load value: 17.6 %
                    Vehicle speed: 1 km/h
                    Voltage terminal 30: 11.780 V
                    Engine speed: actual: 640 /min
                    MAF_ENVD: 239.67058 mg/stroke
                    Coolant temperature (unfiltered): 84.00 °C
                    Engine load: 23.828125 %
                    Vehicle speed: actual: 1 km/h
   Part No SW: 8K1 927 156 S    HW: 0B5 927 156 F
   Component: 0B5 30TFSINAR H10 0005
   Revision: --H10---    Serial number: 0000000992 CVN: 0000B2F0
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMDL501 A02196
   ROD: EV_TCMDL501.rod
   VCID: 45D7407BD52D3CB27CD-8010
8007 - No Communications with Steering Angle Sender (G85)
          U0126 00 [047] - -
          [Lost Communication With Steering Wheel Angle Sensor Control Module]
                    Mileage: 129096 km
                    Date: 2023.08.04
                    Time: 16:05:34
                    Engine RPM: 243 /min
                    Transmission input speed: 243 /min
                    Engine torque: 124 Nm
                    ATF temperature: 48 °C
                    Accelerator pedal position: 0.0 %
                    Clutch status: Beide Kupplungen offen
                    Voltage terminal 30: 11.400 V
                    Voltage_5V_CAN_pressuresensors-Param to DOP: 4.972 V
8015 - Steering Column Control Module
                    Mileage: 129096 km
                    Date: 2023.08.04
                    Time: 16:05:34
   Part No SW: 8K0 907 379 CK    HW: 8K0 907 379 CK
   Component: ESP8 quattro  H09 0100
   Coding: 291D1A
   Shop #: WSC 06324 000 00000
   VCID: 04519D7F9E17C5BA2B3-8050
                    Reset counter: 171
                    Mileage: 129096 km
                    Date: 2023.08.04
                    Time: 16:05:35
                    Hex Value: 0x00C0
                    Hex Value: 0x07A2
                    Hex Value: 0x002F
                    Hex Value: 0x7A8E
                    Hex Value: 0x0000
01324 - Control Module for All Wheel Drive (J492)
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 171
                    Mileage: 129096 km
                    Date: 2023.08.04
                    Time: 16:05:35
                    Hex Value: 0x00C0
                    Hex Value: 0x07A2
                    Hex Value: 0x000E
                    Hex Value: 0x508C
                    Hex Value: 0x0000
   Part No SW: 8K0 907 064 FM    HW: 8K0 907 064 FM
   Component: BCM2 2.0      H10 0602
   Coding: 0D810000000000000000
   VCID: 0059916F8A0FD99A0FB-8054
   Serial number: 2312000040763009
00956 - Key 2
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 171
                    Mileage: 125911 km
                    Date: 2022.11.15
                    Time: 08:21:58
00955 - Key 1
                    Reset counter: 53
                    Mileage: 126680 km
                    Date: 2022.12.18
                    Time: 07:26:39
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 AH
   Component: BCM1 1.0      H14 0103
   Revision: 08014001    Serial number: 00000393212002
   Coding: 26000091863CAFE0210048C300003D0D0F9CD308A2090221000008000000030100000030000000
   Shop #: WSC 25168 444 109236
   VCID: 78A9F98FD2DF915A37B-802C
   Component: WWS 130312  H07 0070
   Serial number: SWF12030135682
   Coding: 00FD11
   Serial number: 20196621
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000903123594
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R19AD02
   Component: AQ_Hum_Sensor  H02 0002
   Serial number: 43284C16000000000001
                    Reset counter: 171
                    Mileage: 129096 km
                    Date: 2023.08.04
                    Time: 16:05:42
   Part No SW: 8K0 959 655 P    HW: 8K0 959 655 P
   Serial number: 003KJD9010F.   Dataset Number: 8K0909602VA 0001
   Coding: 303844354730303030304A55304C384B3053
   Shop #: WSC 47343 001 1048576
   VCID: 4ACD7347FC33D3CA91F-801E
   Serial number: 6334MSME6C44000ED
   Serial number: 6344MSME6C543800C
   Serial number: 6352QSME7C0F3146P
   Serial number: 6362QSME4C0F5248S
   Serial number: 63732SME77101E5A1
   Serial number: 63832SME2D114A40Z
9445929 - Seat occupied recognition control module
          B1022 29 [137] - Signal Implausible
                    Mileage: 129075 km
                    Date: 2023.08.04
                    Time: 08:18:57
9445937 - Seat occupied recognition control module
          B1022 31 [137] - No Signal
                    Reset counter: 171
                    Mileage: 129075 km
                    Date: 2023.08.04
                    Time: 08:18:53
9446163 - Pressure sensor for seat recognition
          B1023 13 [137] - is defective
                    Fault Frequency: 19
                    Reset counter: 170
                    Mileage: 129028 km
                    Date: 2023.06.30
                    Time: 10:27:00
9445889 - Seat occupied recognition control module
          B1022 01 [137] - Electrical Failure
                    Reset counter: 171
                    Mileage: 129075 km
                    Date: 2023.08.04
                    Time: 08:18:54
9446418 - Seat Occupied Recognition Safety Belt Force Sensor
          B1024 12 [137] - Short to Plus
                    Reset counter: 170
                    Mileage: 129043 km
                    Date: 2023.07.07
                    Time: 09:05:39
12658176 - No Communications with Steering Angle Sender (G85)
          U0126 00 [009] - -
          [Steer Angle Control Unit no signal/communication]
                    Reset counter: 171
                    Mileage: 129096 km
                    Date: 2023.08.04
                    Time: 16:05:34
   Part No SW: 8R0 953 568 S    HW: 8R0 953 568 S
   Component: Lenks.Modul   H07 0171
   Revision: 00000000    Serial number: 20120314001464
   Coding: 000036
   VCID: 51FF642B11E5E012D05-8004
   Component: E221 - MFL  H03 0003
00576 - Terminal 15
                    Fault Status: 01101000
                    Fault Frequency: 8
                    Reset counter: 171
                    Mileage: 129096 km
                    Date: 2023.08.04
                    Time: 16:05:34
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
   Component: 4 Wheel Drive H13 0100
   Serial number: 001403120001050 Dataset Number: 8K0909104D  0025
   VCID: 2F3B02D3679196E2A61-807A
0243 - Steering Column Control Module
          U0212 00 [137] - No Communications
          [Lenkradwinkelsensor keine Kommunikation DTC_CAN_LWI_NO_COM]
                    Reset counter: 171
                    Mileage: 129096 km
                    Date: 2023.08.04
                    Time: 16:05:35
0059 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [137] - -
          [ESP - Steuergerät nicht verfügbar DRC_CAN_ESP_01_SYS_ST]
                    Fault Frequency: 12
                    Reset counter: 171
                    Mileage: 129096 km
                    Date: 2023.08.04
                    Time: 16:05:36
   Component: RCEPS         H36 0507
   Revision: 00001000    Serial number: 0001411899 Dataset Number: 8K0909852H  0023
   Coding: 100000010001
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 34310DBF8EB7B53ADB3-8060
3158276 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Botschaftsausfall des Lenkwinkelsensors]
                    Fault Frequency: 8
                    Reset counter: 171
                    Mileage: 129096 km
                    Date: 2023.08.04
                    Time: 16:05:37
                    Write only channel
4208000 - Steering Angle Sensor
          B1168 F1 [137] - Synchronization Failed
                    Fault Frequency: 8
                    Reset counter: 171
                    Mileage: 129096 km
                    Date: 2023.08.04
                    Time: 16:05:36
                    Write only channel
   Revision: 00002001    Serial number: 0172014859
   Coding: 0106023A00FA400580B0013200000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000494316
   Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J245 PS050  H08 0043
01503 - Bulb for 3rd Brake Light (M25)
                    Fault Status: 11101100
                    Reset counter: 169
                    Mileage: 128647 km
                    Date: 2023.05.24
                    Time: 15:17:04
                    Fault Frequency: 8
                    Reset counter: 171
                    Mileage: 129096 km
                    Date: 2023.08.04
                    Time: 16:05:37
   Part No SW: 8R1 035 746 B    HW: 8R1 035 746 A
   Component: H-BNT-NA      H42 0552
   Revision: --------    Serial number: 096CQ0C7502150
   Coding: 110200000206A1EF45028B4E00000403140000000000000000
   VCID: 363537B7984BA72AE57-8062
   Component: NAR 2011  0505
   Subsystem 2 - Part No SW: 8R0 919 604     HW: 8R0 919 604
   Component: DU7 High  H41 0104
   Serial number: A130C60CS126296
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Serial number: 00000001803001
   Component: CD-Database  3371
                    Reset counter: 211
                    Mileage: 123364 km
                    Date: 2022.07.27
                    Time: 10:28:11
                    Text: KBD_FB8,KBD,B,c,a,1
End----(Elapsed Time: 02:03, VBatt start/end: 14.0V/14.0V. VIgn 0.0V)------
Are you 100% certain that they are all back in the same locations? We've seen it a number of times, where someone pulled fuses to check them and then put one or more back in an incorrect position.
In any case, the plethora of fault codes appears to be due to your your steering angle sensor being off-line.
[27]
Austin, TX, USA
C?ID=558833
I sincerely appreciate the reply.
So Audi just got back to me, stating that the Center Spring is causing the malfunction, I'll attach what they gave me below. While I'm for Audi to decide as to whether or not to reply to me for clarification, I was curious about the detection of module J453 by Audi as it wasn't listed in the report VCDS outputted. Is there something else that I should have done that may have outputted that code that I missed?
CONCERN DISCOVERED DURING VEHICLE CHECK OVER. VERIFIED THE CUSTOMER’S CONCERN OF THE STEERING FAULT CODE. CONNECTED THE BATTERY CHARGER, ACCESSED THE DIAGNOSTIC PORT AND PERFORMED A DIAGNOSTIC SCAN TO FIND DTC(S) U021200 WHICH IS RELATED TO LOST COMMUNICATION WITH STEERING COLUMN. CONTROL MODULE CLEARED ALL CODES AND RECONFIRMED ACTIVE DTC(S) OF u021200. CONNECTED THE BATTERY CHARGER AND PERFORMED A GUIDED FAULT FINDING TEST PLAN FUNCTION TEST 3 WHICH FOUND MULTIFUCTION STEERING WHEEL CONTROL MODULE J453. FURTHER EXAMINATION FOUND THE CLOCK SPRING OPEN IN CLOCK SPRING CAUSING COMMUNICATION ERRORS WITH OTHER SYSTEMS.
[27]
Austin, TX, USA
C?ID=558833
Just bumping this to see if anyone has any idea why the J453 module would be showing for Audi and not me.
Have you re-scanned it since you got it back?
[27]
Austin, TX, USA
C?ID=558833
Haven't gotten the car back yet, I'm waiting for the tech that worked on it to get back in the office as I'm getting some strange answers from them like they aren't seeing the airbag error now. So I'm doing research into it that clock spring, if it was malfunctioning would have thrown that code to begin with, amoungst other line items unrelated to the engine.
