Vw california year 2020 controller for camper area blank screen leisure battery full, will vcds sort this.
salmonpikey
Northern Ireland, UK
C?ID=263476
Vw california year 2020 controller for camper section blank, can vcds clear this fault. Thank you Des.
salmonpikey
C?ID=263476
I am sorry I cannot send you an autoscan my vcds are not compatible with my 2020 year vw california Coast, my vcds are hex+can, my query is if I upgrade to the latest software you have could it clear this fault, thank you.
You can still scan it. Some things may not show. Most everything will show "Unsupported", but that doesn't mean we won't have some kind of idea what's going on.
Westbury, UK
It'a not software that's your issue, it's the HEX-CAN cable that isn't fully compatible with 2019 on vehicles (because VAG have changed the complexity of some of the diagnostic messages beyond the capability of the older interface cables like yours).
But as Uwe says an Auto-Scan with your HEX-CAN (and preferably the latest 23.11 VCDS software) will still help us to help you.
salmonpikey
C?ID=263476
Westbury, UK
We can't do anything until you post an Auto-Scan - as Uwe says it won't be complete but hopefully it will give us a clue what you are asking as none of us understand what you have posted at the moment.
salmonpikey
C?ID=263476
Apologies for the format of the full scan. I have just copied and pasted it. So its a 6.1 VW California camper. All electrics in the camper part of the vehicle ie. heating, fridge, lighting etc are controlled via a touch screen control panel built into the roof above the front seats. When the dial is pressed to turn on the control panel a brief message is displayed in what seems to be German (bediensystem bitte werkststt aufsuchen) Translates roughly as please visit workshop. before the panel shuts down again. The vehicle has just been returned after being repaired post a minor collision where damage was sustained to the front bumper area including the sensors. I am basically hoping there is some way to reset or reinstate the control panel system. I have it re booked via the workshop who done the repair however the soonest they can look at it is over a month away.
Address 01: Engine        Labels: 03G-906-021-BLS.clb
   Part No SW: 03G 906 056 AA    HW: 03G 906 021 AB
   Component: R4 1,9L EDC G000SG  2898
   Revision: --H11---    Serial number:
   Coding: 0050071
   Shop #: WSC 66565 257 00032
   VCID: 66C3D7EE5106B2A159-8032
   VINID: 9A38EAAAA060A91880000143042271F90E
7 Faults Found:
005658 - Glowplug for Cylinder 1 (Q10)
               P161A - 000 - Open Circuit
                    Mileage: 244561 km
                    Date: 2018.03.28
                    Time: 19:14:22
                    RPM: 882 /min
                    Voltage: 14.52 V
                    Bin. Bits: 00101000
                    Temperature: 9.9°C
                    Bin. Bits: 10110000
005659 - Glowplug for Cylinder 2 (Q11)
               P161B - 000 - Open Circuit
                    Mileage: 244561 km
                    Date: 2018.03.28
                    Time: 19:14:22
                    RPM: 882 /min
                    Voltage: 14.52 V
                    Bin. Bits: 00101000
                    Temperature: 9.9°C
                    Bin. Bits: 10110000
005660 - Glowplug for Cylinder 3 (Q12)
               P161C - 000 - Open Circuit
                    Mileage: 244561 km
                    Date: 2018.03.28
                    Time: 19:14:22
                    RPM: 882 /min
                    Voltage: 14.52 V
                    Bin. Bits: 00101000
                    Temperature: 9.9°C
                    Bin. Bits: 10110000
005661 - Glowplug for Cylinder 4 (Q13)
               P161D - 000 - Open Circuit
                    Mileage: 244561 km
                    Date: 2018.03.28
                    Time: 19:14:22
                    RPM: 882 /min
                    Voltage: 14.52 V
                    Bin. Bits: 00101000
                    Temperature: 9.9°C
                    Bin. Bits: 10110000
005697 - Please check DTC Memory of A/C Controller
               P1641 - 000 -  - Intermittent
                    Mileage: 253547 km
                    Date: 2018.03.28
                    Time: 16:04:20
                    Voltage: 12.08 V
                    Bin. Bits: 00101100
                    Temperature: 27.9°C
                    (no units): 16.0
005441 - Fuel Pump Relay (J17)
               P1541 - 000 - Open Circuit - Intermittent
                    Mileage: 253547 km
                    Date: 2018.03.28
                    Time: 16:04:23
                    Voltage: 12.08 V
                    Bin. Bits: 00101100
                    Bin. Bits:        0
                    (no units): 0.0
005522 - Altitude Sensor / Boost Pressure Sensor
               P1592 - 000 - Implausible Correlation - MIL ON
                    Fault Status: 11100000
                    Pressure: 196 mbar
                    Pressure: -252 mbar
                    Bin. Bits: 00011010
                    Absolute Pres.: 958.8 mbar
                    Absolute Pres.: 1183.2 mbar
Readiness: 1 1 0 0 0
   Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
   Coding: 133B2012092200FAC81004E7901A00813400
   Shop #: WSC 04941 000 00000
   VCID: 7EF39F8EE9960A61B1-802A
   Part No SW: 5P0 907 044 M    HW: 5P0 907 044 M
   Component: Climatronic   H14 0401
   Revision: 00001001
   Coding: 0000000000
   ASAM Dataset: EV_Climatronic A01001
   ROD: EV_ClimaAutoBasis_SE35.rod
   VCID: 3A7B539EBD3EE641CD-806E
          U1111 00 [00001000] - -
                    Reset counter: 32
                    Mileage: 253547 km
                    Date: 2023.11.05
                    Time: 16:04:07
13701392 - Function Restricted due to Missing Message(s)
                    Reset counter: 32
                    Mileage: 253547 km
                    Date: 2023.11.05
                    Time: 16:04:07
13701424 - Function Restricted due to Missing Message(s)
                    Reset counter: 33
                    Mileage: 253704 km
                    Date: 2023.11.05
                    Time: 17:02:34
9481748 - High Pressure Sensor
          B10AE 14 [00001000] - Open or Short to Ground
                    Reset counter: 32
                    Mileage: 253547 km
                    Date: 2023.11.05
                    Time: 16:04:05
   Part No SW: 5K0 937 086     HW: 5K0 937 086
   Component: BCM PQ35 M    008 0019
   Revision: BC008001
   Coding: 46180A3C9025B0C04680008095008104050100A8425D81605C8040000000
   VCID: 71E9B4B2A8C865193C-8024
   Subsystem 1 - Part No: 1P0 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 12050  22  0601
   Coding: 00DB90
   Subsystem 2 - Part No: 1P0 951 171
   Component: Innenraumuebe  010 4971
27 Faults Found:
00185 - Control Circuit; Relay for Supply Voltage Terminal 15
                    Fault Status: 00101100
                    Fault Frequency: 56
                    Reset counter: 32
                    Mileage: 240540 km
                    Date: 2017.02.14
                    Time: 10:41:47
                        Term 15 Off
                    Voltage: 12.55 V
                    Reset counter: 33
                        Term 15 Off
                    Voltage: 14.15 V
                    Reset counter: 32
                    Mileage: 253547 km
                    Date: 2018.03.28
                    Time: 16:04:09
                    Voltage: 11.70 V
                    Fault Status: 00101001
                    Reset counter: 32
                    Mileage: 253547 km
                    Date: 2018.03.28
                    Time: 15:57:58
                        Term 15 Off
                    Voltage: 12.55 V
                    Fault Status: 01101000
                    Fault Frequency: 183
                    Reset counter: 248
                    Mileage: 248231 km
                    Date: 2018.03.28
                    Time: 04:40:11
                    Voltage: 11.75 V
00893 - Switch for Trunk Handle (E234)
                    Reset counter: 14
                    Mileage: 219050 km
                    Date: 2015.02.17
                    Time: 12:43:40
                        Term 15 Off
                    Voltage: 12.45 V
00927 - Terminal 30 (Right)
                    Fault Frequency: 163
                    Reset counter: 248
                    Mileage: 253496 km
                    Date: 2018.03.28
                    Time: 04:03:48
                    Voltage: 14.30 V
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 246
                    Mileage: 253490 km
                    Date: 2018.03.28
                    Time: 04:00:22
                    Voltage: 14.25 V
00985 - Right Tail Light (M2)
                    Fault Frequency: 227
                    Reset counter: 246
                    Mileage: 249568 km
                    Date: 2018.03.28
                    Time: 04:27:56
                    Voltage: 14.40 V
                    Reset counter: 246
                    Mileage: 253487 km
                    Date: 2018.03.28
                    Time: 14:06:18
                    Voltage: 14.25 V
                    Reset counter: 33
                    Mileage: 248495 km
                    Date: 2018.03.28
                    Time: 10:37:19
                        Term 15 Off
                    Voltage: 12.35 V
                    Reset counter: 32
                    Mileage: 253547 km
                    Date: 2018.03.28
                    Time: 16:04:09
                    Voltage: 11.65 V
                    Reset counter: 32
                    Mileage: 253547 km
                    Date: 2018.03.28
                    Time: 16:04:08
                    Voltage: 11.65 V
                    Reset counter: 32
                    Mileage: 253547 km
                    Date: 2018.03.28
                    Time: 16:04:09
                    Voltage: 11.65 V
                    Reset counter: 32
                    Mileage: 253547 km
                    Date: 2018.03.28
                    Time: 16:04:02
                    Voltage: 11.70 V
                    Reset counter: 246
                    Mileage: 253488 km
                    Date: 2018.03.28
                    Time: 14:08:43
                    Voltage: 14.10 V
                    Reset counter: 246
                    Mileage: 253492 km
                    Date: 2018.03.28
                    Time: 10:34:60
                    Voltage: 12.15 V
                    Reset counter: 246
                    Mileage: 253492 km
                    Date: 2018.03.28
                    Time: 10:34:60
                    Voltage: 12.15 V
01501 - Bulb for Blinkers; Rear Left (M6)
                    Reset counter: 246
                    Mileage: 253490 km
                    Date: 2018.03.28
                    Time: 14:12:30
                    Voltage: 14.20 V
01502 - Bulb for Rear Fog; Left (L46)
                    Reset counter: 246
                    Mileage: 253487 km
                    Date: 2018.03.28
                    Time: 14:06:18
                    Voltage: 14.25 V
01503 - Bulb for 3rd Brake Light (M25)
                    Reset counter: 246
                    Mileage: 253487 km
                    Date: 2018.03.28
                    Time: 14:06:39
                    Voltage: 14.20 V
01516 - Terminal 30; Left
                    Fault Status: 00101011
                    Reset counter: 33
                    Mileage: 253704 km
                    Date: 2018.03.28
                    Time: 13:15:29
                        Term 15 Off
                    Voltage: 12.35 V
                    Reset counter: 246
                    Mileage: 253487 km
                    Date: 2018.03.28
                    Time: 14:06:18
                    Voltage: 14.25 V
01834 - Bulb for Side-Blinkers; Left (M18)
                    Reset counter: 246
                    Mileage: 253490 km
                    Date: 2018.03.28
                    Time: 14:12:30
                    Voltage: 14.05 V
02391 - Terminal 30 Reference
                    Reset counter: 33
                    Mileage: 253547 km
                    Date: 2018.03.28
                    Time: 16:07:58
                    Voltage: 14.20 V
                    Reset counter: 246
                    Mileage: 253487 km
                    Date: 2018.03.28
                    Time: 14:06:28
                    Voltage: 14.30 V
                    Fault Status: 00101010
                    Reset counter: 32
                    Mileage: 253547 km
                    Date: 2018.03.28
                    Time: 16:26:32
                    Voltage: 12.20 V
   Part No SW: 5N0 959 655 J    HW: 5N0 959 655 J
   Component: J234__A0E VW10 HI   1916
   Revision: 20013000    Serial number: 003E2P8WKE0W
   Coding: 0012357
   Shop #: WSC 06402 785 00200
   VCID: 44872D6607FAA0B1A7-8010
   Subsystem 1 - Serial number: 6332MTS679870919
   Subsystem 2 - Serial number: 6342MTS655520919
   Subsystem 3 - Serial number: 6351HTS63BUB16KJ
   Subsystem 4 - Serial number: 6361HTS63U9816KR
   Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
   Component: J0527           855 0111
   Coding: 0000532
   VCID: 78FF89960BB23451FB-802C
   Subsystem 1 - Part No: 1P0 959 538 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAP   01ÿ 0100
   Coding: 00000226
00576 - Terminal 15
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
   Part No SW: 1P0 920 910 C    HW: 1P0 920 910 C
   Component: KOMBI         H17 0109
   Coding: 410A00
   VCID: 29599CD248985DD9B4-807C
12664832 - Function Restricted due to Missing Message(s)
                    Reset counter: 33
                    Mileage: 253704 km
                    Date: 2023.11.05
                    Time: 17:02:32
13631488 - Function Restricted due to Missing Message(s)
                    Reset counter: 33
                    Mileage: 253704 km
                    Date: 2023.11.05
                    Time: 17:02:34
   Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
   Component: J533  Gateway   H16 0222
   Revision:   H16       Serial number: 4020K0951404CA
   Coding: E9807F06000212000203
                    Reset counter: 32
                    Mileage: 253704 km
                    Reset counter: 32
                    Mileage: 253704 km
   Component: IMMO          H17 0109
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Component: SG EXT.PLAYER H13 0084
   Revision: A1001003    Serial number: 7667422443
   Coding: 020000
   VCID: 264397EE518672A199-8072
                    Reset counter: 33
                    Mileage: 253704 km
                    Date: 2018.03.28
                    Time: 17:02:40
   Part No SW: 1T0 959 701 L    HW: 1K0 959 793 P
   Component: J386  TUER-SG FT    1518
   Revision: 71009005    Serial number: 00000528698116
   Coding: 0004784
   VCID: 408F217613E2BC9183-8014
                    Reset counter: 33
                    Mileage: 253704 km
                    Date: 2018.03.28
                    Time: 17:02:36
                    Reset counter: 33
                    Mileage: 253704 km
                    Date: 2018.03.28
                    Time: 17:02:36
                    Reset counter: 32
                    Mileage: 253547 km
                    Date: 2018.03.28
                    Time: 16:04:04
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 65     2901
   Revision: 00H17000
   VCID: 2F6D72CABE7C33E96A-807A
   Part No SW: 1T0 959 702 L    HW: 1K0 959 792 P
   Component: J387  TUER-SG BT    1518
   Revision: 71009005    Serial number: 00000658798122
   Coding: 0004784
   VCID: 4189247218E8B5998C-8014
                    Reset counter: 33
                    Mileage: 253704 km
                    Date: 2018.03.28
                    Time: 17:02:36
                    Reset counter: 33
                    Mileage: 253704 km
                    Date: 2018.03.28
                    Time: 17:02:36
                    Reset counter: 32
                    Mileage: 253547 km
                    Date: 2018.03.28
                    Time: 16:04:04
   Part No SW: 1P0 035 153     HW: 1P0 035 153
   Component: Radio         H03 0008
   Revision: R0000000    Serial number: SEZAZ1I7809032
   Coding: 0101040002
   VCID: 62CBCBFE7D2ECE81B5-8036
00849 - S-contact at Ignition/Starter Switch (D)
                    Reset counter: 33
                    Mileage: 253704 km
                    Date: 2018.03.28
                    Time: 17:02:37
   Part No SW: 1K0 959 703 AF    HW: 1K0 959 795 S
   Component: J388   TUER-SG HL   1401
   Revision: 11006001    Serial number: 00000003860976
   Coding: 0000144
   VCID: 74E7BDA617DA5031D7-8020
   Part No SW: 1K0 959 704 AF    HW: 1K0 959 794 S
   Component: J389   TUER-SG HR   1401
   Revision: 11006001    Serial number: 00000003906931
   Coding: 0000144
   VCID: 75E180A21CA04939E0-8020
                    Fault Status: 01111000
                    Reset counter: 248
                    Mileage: 238572 km
                    Date: 2016.11.29
                    Time: 14:10:36
                    Fault Status: 01111100
                    Reset counter: 248
End-------------------------(Elapsed Time: 02:32)--------------------------
Uhm, the scan you posted above does not look like it's from a T6.1. I cant' imagine that van having a 1.9 BLS engine, nor a 1P0 instrument cluster.
Westbury, UK
The lack of a VIN is not helpful, next time please post the scan without editing it.
There are an awful lot of faults with the same date stamp, which I'm wondering if they are historical from the front end repair?
There are so many faults it's really hard to "see the wood for the trees" so I suggest you go into each controller and do a clear faults, followed by a new Auto-Scan to pst here. Hopefully then we'll be able to see the faults which are still present now - which should be less confusing!
salmonpikey
C?ID=263476
You are certainly correct I never seen that scan before my son posted that one
salmonpikey
C?ID=263476
You are certainly correct I never seen that scan before, my son posted that one,
my vw california is a 2 litre tdi engine 110 kW engine code cxfa 7 speed dsg gearbox I will ask my son to find the proper autoscan and post same, sorry about this mistake.
salmonpikey
C?ID=263476
Hopefully the correct full scan results this time.
Tuesday,07,November,2023,10:44:25:17482
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: WV2ZZZ7HZLH044606   License Plate: DG70KFF
Mileage: 38571km-23966mi   Repair Order: 1548
Chassis Type: 7H-VN46 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 18 19 3D 44 5F 69 75 800B
VIN: WV2ZZZ7HZLH044606   Mileage: 38571km-23966miles
3D-Special Function -- Status: Malfunction 0010
800B-Aux air heater 2 -- Status: OK 0000
Address 01: Engine (J623-CXFA)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 QF    HW: 04L 907 445 M
   Component: R4 2.0l TDI   H01 9695
   Revision: 23301001
   Coding: 0025401C4374050800000000000000000000000000000000
   Shop #: WSC 00012 790 00174
   ASAM Dataset: EV_ECM20TDI03004L906056QF 004004
   ROD: EV_ECM20TDI03004L906056QF_004.rod
   VCID: 015F9462E18D4EA220D-8054
   VINID: 9E60AAAAA1D8A9C60010418018148A98E3
Readiness: N/A
   Part No SW: 0BT 300 046 N    HW: 0GC 927 711 H
   Component: GSG DQ500     H06 3107
   Revision: 00H06V11    CVN: 4644A9CA
   ROD: EV_TCMDQ500021.rod
   VCID: 41DF5462A10D8EA260D-8014
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 7LA 614 517 A    HW: 7LA 614 517
   Component: ESC_high      H01 0700
   Serial number: 08508090200120
   Coding: 40552452484BEE89025A24A4126C770639372078
   ASAM Dataset: EV_Brake1ESP90iBOSCHVN46X 002010
   ROD: EV_Brake1ESP90iBOSCHVN46X_002.rod
   VCID: 3D272892DDF5EA42045-8068
Address 08: Auto HVAC (J301)       Labels:* Redir Fail!
   Part No SW: 7LA 907 426     HW: 7LA 907 426
   Component: AC Manuell    H01 0502
   Coding: 903110000810210001000800504001050000000000030500A00000000000
   Shop #: WSC 00012 790 00160
   ASAM Dataset: EV_AirCondiBHTCT6PA 001004
   ROD: EV_AirCondiBHTCT6PA.rod
   VCID: 55F79032458512022C5-8000
   Rear A/C Control Head 1:
   Subsystem 1 - Part No SW: 7LA 906 453     HW: 7LA 906 453
   Component: E857  H01 0106
   Serial number: 00002140120212050102
   Part No SW: 2Q5 937 090     HW: 2Q5 937 090
   Component: BCM T6PA Std+ H10 0935
   Serial number: 01102003300273 Dataset Number: V03935315CB 0001
   ASAM Dataset: EV_BCMA0 205001
   ROD: EV_BCMA0_205_VW27.rod
   VCID: 74B1CDB6AE3F6B0A3BB-8020
   Subsystem 1 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  050 0105
   Serial number: S2Y19M05D27H19M21S42
   Coding: 02B8DD
   Driver door control module:
   Subsystem 2 - Part No SW: 7L1 959 405 B    HW: 7L1 959 163 B
   Component: FHSG_DRV  001 0002
   Serial number: 00000000000036271737
   Coding: 1F0007
   Front passenger door control module:
   Subsystem 3 - Part No SW: 7L1 959 406 B    HW: 7L1 959 164 B
   Component: FHSG_PSG  001 0002
   Serial number: 00000000000036905122
   Coding: 050007
   Subsystem 4 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY193301AKG
   Serial number: 00000000000032317731
541461 - Databus
          [MFG_01 Datenbus fehlende Botschaft]
                    Fault Frequency: 17
                    Reset counter: 93
                    Mileage: 38562 km
                    Date: 2023.11.05
                    Time: 00:22:12
                    Zusaetzliche Umgebungsdaten-Terminal 15 status: On
                    Zusaetzliche Umgebungsdaten-Terminal 50 status: OFF
                    Zusaetzliche Umgebungsdaten-Low beam: Not operated
                    Zusaetzliche Umgebungsdaten-OFF: Not operated
                    Zusaetzliche Umgebungsdaten-Outside temperature: -50.0 °C
                    Zusaetzliche Umgebungsdaten-Automatic high beam assist: Not operated
                    Zusaetzliche Umgebungsdaten-Position lamps: Not operated
                    Zusaetzliche Umgebungsdaten-Parking light left: Not operated
                    Zusaetzliche Umgebungsdaten-Parking light right: Not operated
                    Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: On
                    Zusaetzliche Umgebungsdaten-last wakeup: keine Stoerschutzursache
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN): OFF
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW): OFF
                    Zusaetzliche Umgebungsdaten-voltage measurement: 14.8 V
609036 - Child Safety / Anti Car-Jacking for Sliding Door; Rear Driver Side
          B1A74 F0 [00001000] - Elect. Malfunction
                    Reset counter: 93
                    Mileage: 38562 km
                    Date: 2023.11.05
                    Time: 00:25:52
                    Zusaetzliche Umgebungsdaten-Terminal 15 status: OFF
                    Zusaetzliche Umgebungsdaten-voltage measurement: 12.9 V
Address 10: Park/Steer Assist
   Part No SW: 2Q0 907 572 R    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0372
   Dataset Number: V03935303EM 0001
   Coding: 3200670A41FF8748949C815580508700000000000000000004
   Shop #: WSC 00012 790 00163
   ROD: EV_ACCMRRCONTIVW376_003.rod
   VCID: 43D35E6ABB119CB2721-8016
   Part No SW: 2Q0 959 655 AE    HW: 2Q0 959 655 AE
   Component: VW22Airbag    015 0506
   Revision: --------    Dataset Number: V03935308TY 0001
   Coding: 88CCC00000000000800000CF008C40000065
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001022
   ROD: EV_AirbaVW22BPAVW27X.rod
   VCID: 00599166EA8747AA2F3-8054
   Subsystem 1 - Part No SW: -----------    HW: 442 062 101 20
   Serial number: 3577Y50C534457D2506+
   Subsystem 2 - Part No SW: -----------    HW: 442 062 101 20
   Serial number: 3587Y51C534457D2B49D
Address 17: Instruments (J285)       Labels:| 7LA-920-XXX-V1.clb-SRI3
   Part No SW: 7LA 920 951     HW: 7LA 920 951
   Component: KOMBI         305 6750
   Coding: 27A40A0A2580260001886A011401000000600000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009069
   ROD: EV_DashBoardVDDMQBAB_VW27.rod
   VCID: 7EA5EF9E9073315A5DF-802A
Address 18: Aux. Heat (J364)       Labels:* Redir Fail!
   Part No SW: 5WA 963 271 A    HW: 5WA 963 271 A
   Component: STH-VW37x     006 0010
   Serial number: 000000000000950
   Coding: 7143221854121512DCE519
   ASAM Dataset: EV_AuxilHeateWOSVW38X 001009
   ROD: EV_AuxilHeateWOSVW38X_001.rod
   VCID: 4ACD734E9C3B4DFAB17-801E
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5388
   Serial number: 09012011604446 Dataset Number: V03935320AV 0001
   Coding: 030100544F05730401100018100F00010001070000000000000000000000
   Shop #: WSC 00012 790 00021
   GVL: 01443C0000100000C00080008004C80000000000100000000000000000000000
   ROD: EV_GatewNF_VW27.rod
   VCID: 70B9C1A6DA27572ADF3-8024
   Generator:
   Component: 4-00-11-01-04
   Subsystem 2 - Part No SW: 3G0 959 442 F    HW: 3G0 959 442 F  Labels: 3C8-959-537.CLB
   Component: E221__MFL-PR6  H06 0110
   Serial number: PR6-0440036013203698
   Coding: 2C1D00
   Subsystem 3 - Part No SW: 7E0 915 181 L    HW: 7E0 915 181 L
   Serial number: 77197200002001070340
Address 3D: Special Function (J608)       Labels:* Redir Fail!
   Part No SW: 2N0 907 427 P    HW: 2N0 907 427 H
   Component: KFG       H24 0306
   Serial number: GB24195025909 Dataset Number: V03935316UR 0001
   Coding: 0000000000000000000000000000000000000000
   ASAM Dataset: EV_SpeciFunctFlextVN54X 007029
   ROD: EV_SpeciFunctFlextVN54X_007_VN46.rod
140314 - Unknown Error Code
          B1B6E F5 [00001001] - Unknown Error Elaboration
          [Frischwasser Pumpe defekt: Strom zu niedrig]
                    Reset counter: 53
                    Mileage: 38562 km
                    Date: 2023.11.05
                    Time: 00:23:21
Address 44: Steering Assist (J500)       Labels:| 2N0-909-143.clb
   Part No SW: 7LA 909 144 F    HW: 7LA 909 144 D
   Component: EPS_MQB_ZFLS  751 7150
   Dataset Number: V03935309JN 0001
   Coding: 0106
   ASAM Dataset: EV_SteerAssisMNB 002012
   ROD: EV_SteerAssisMNB.rod
   VCID: 45D74072B525A2825C5-8010
Address 5F: Information Electr. (J794)       Labels:| 3G5-035-MIB-HGH3.clb
   Part No SW: 3G5 035 820     HW: 3G5 035 820
   Component: MU-O-ND-EU    H12 0156
   Serial number: VWZAZ2X0525274  Dataset Number: V03935318FN 0001
   Coding: 64600008000020000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB 001001
   ROD: EV_MUOIMQB_VW49.rod
   VCID: 619FB4E201CDEEA240D-8034
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  H61 8214
   Serial number: VWZ6ZJX0293838
   Subsystem 2 - Part No: V03 959 806 MG
   Component: EU 2019/04     1004
Address 69: Trailer (J345)       Labels:. 5H0-907-383.clb
   Part No SW: 5H0 907 383     HW: 5H0 907 383
   Component: Anhaenger     H09 Anhaenger     H09 00400040
   Serial number: 000000000005400 Dataset Number: V03935309CF 0001
   Coding: 0100000202001300
   ASAM Dataset: EV_TrailFunctGener3Hella 001009
   ROD: N/A
   VCID: 6B83D6CAF301B4F2EA1-803E
No ASAM data for: "EV_TrailFunctGener3Hella" (VN46)
   Part No SW: 5WA 035 284     HW: 5WA 035 284
   Component: OCUGen3High   H20 0088
   Serial number: 0000000001VINV1 Dataset Number: V03935314UU 0001
   Coding: 06462000196898209005460160000607
   ASAM Dataset: EV_OCUGen3High 002115
   ROD: EV_OCUGen3High_002_VW27.rod
   VCID: 03539E6AFB915CB2321-8056
7170 - Function Restricted due to Missing Message(s)
          [Multi Function Display (0x0F) - Funktionseinschränkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful]
                    Mileage: 38562 km
                    Date: 2023.11.05
                    Time: 00:22:06
                    Voltage terminal 30: 14.7 V
13631561 - Internal Control Module Memory Check Sum Error
          B2000 49 [00001001] - Internal Electronic Failure
          [Control unit defective Analog circuitry]
                    Mileage: 32926 km
                    Date: 2023.07.24
                    Time: 04:47:29
                    Voltage terminal 30: 12.6 V
Address 800B: Aux air heater 2 (J604)       Labels:* None
   Part No SW: 7C0 963 273 B    HW: 7C0 963 273 B
   Component: LSH_DIESEL    006 0026
   Dataset Number: 0026        0026
   Coding: 3200
   ASAM Dataset: EV_LSHECCSMNB 002018
   ROD: EV_LSHECCSMNB.rod
   VCID: 2A0D13CE3C7B6DFA517-807E
   Auxiliary heating remote control:
   Subsystem 1 - Part No SW: 3Q0 963 513     HW: 3Q0 963 513
   Component: R64 D208L  004 0402
   Serial number: 00000000000000951635
End----(Elapsed Time: 03:07, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
