No response from engine controller
mmosberg
Norway
C?ID=65477
On a 2008 VW Marine TDI 265-6 i keep getting "No response from controller" when adressing 01 Engine. When I run the interface test everything is ok except the CAN which says not OK. But I believe that is because in the boat there is no CAN network. The only controller present is the ECU. Tested the interface on my 2014 Audi and everything is working ok. Here even the CAN is OK.
Back to the boat. The diode on my interface lights up yellow and goes green after 1-2 seconds. But I cant get in touch with the controller. I am afraid the ECU is dead, but since this is not a cheap part I wanted to check in here to get some advices. I have disconnected and reconnected the two big connectors on the ECU a few times. Everything looks nice, dry and without corrossion. Please help :p
Bruce
Near Philadelphia, PA, USA
Other symptoms? Does the engine crank and run? Does the ECU have power?
Do you have a wiring diagram for this engine, and specifically what is between the ECU and the diagnostic socket?
If not, check what pins are populated on the diagnostic socket.
mmosberg
Norway
C?ID=65477
It cranks better than ever before :thumbs:, but without even the smallest sign of combustion. No puff or huffing. Just clean cranking. The battery is a fully charged AGM battery with 11,9V with the ignition on. I dont know if the ECU has power. No fuses are blown and the diode on the interface is lit when connected.
I dont have a wiring diagram. There are two diagnostic sockets, one in the dashboard and one in the watertight ECU compartement. Same result from both sockets. I noticed that there was just a few pins populated. I could check which ones if you told me how to name them. From where do I count?
mmosberg
Norway
C?ID=65477
I will check this and update tomorrow. Thx so far :)
Here are e few photos of the ECU, diagnostic port and the watertight cabinet:
mmosberg
Norway
C?ID=65477
Uwe, looking at one of the pictures I can see that the following pins are populated:
3, 4, 7, 9, 11, 16
3, 4, 7, 9, 11, 16
Must be K-Line then (not CAN).
Check continuity from Pin 7 on diagnostic connector to respective pin on ECU harness (with ECU disconnected). Don't know which pin it is on the ECU? Neither do I. Check for continuity to SOME pin on the ECU harness -- it has to go to one of them.
If it does, then verify power and ground connections to ECU.
mmosberg
Norway
C?ID=65477
OK. I think I will be able to find the respective pin from 7 in the ECU harness using a multimeter. Is there an easy way to find the power and ground connections in the ECU harness? I mean if they are alive I can find them, but finding the power if it is dead will be difficult.... :confused: I must admit that I am not very much of an electrician :p
And if I find that power and ground in the ECU harness are OK, then I can assume that the ECU is dead?
Honestly, if I were you, I would try to find and obtain a set of wiring diagrams for what's in that box, 'cause without them, you're probably going to be playing some expensive guessing games.
mmosberg
Norway
C?ID=65477
Found the basic wiring for the Bosch EDC16CP34 ECU. Here it is:
Should I now check if there is power on pin 5 & 18 and the ground and K Line are also OK? Then what?
Normally, all a K-Line ECU needs to "talk" is power (both unswitched and switched), Ground, and the K-Line. So yes, please check that the harness to the ECU is supplying power to pins 5 (and maybe 3 and 6 as well). I would expect those to be unswitched, while I would expect 18 to be switched. Unswitched power should be checked using some kind of load, like a light bulb. Check for ground (check resistance to ground, not just 0V) on pin 1 (and maybe 2 and 4 as well). And of course, check for continuity between pin 72 and pin 7 of the DLC.
mmosberg
Norway
C?ID=65477
SOLVED :-) :-)
Thanks to the input from Uwe and the pin out diagram of the ECU connector we managed to find the error. We measured everything that Uwe advised and everything was OK except for no power on pin 5 on the ECU connector. After some fault seeking we found that power did not make it`s way through relay J317. Short of a new relay on a Sunday we decided to manually activate the relay. Then first the ECU EDC16 responded to diagnosis giving evidence that it was alive. Finally we tried to start the engine and it fired :-) The sound of a VW V6 TDI is always beautifull, but today it was nicer than ever. My friend the boat owner and myself are not much of electricians either of us, but thanks to this forum and the support from Ross-Tech we were able to find the fault. A new relay is something like $30,-, while a new EDC16 is like $12-1500,-.
Relay J317 identified as faulty:
Relay J317 manually switched to power up ECU / EDC16:
ECU / EDC16 responding. VCDS fault code reading, no fault codes:-) :
NEtech
Denmark
C?ID=56995
If possible, could you please make controller map files (PLA and PLB) from [01-Engine], as shown here.
You can write secure code: 12233
Then copy text and post them between: [code] here... [/code] or mail them to support.
mmosberg
Norway
C?ID=65477
Will do tomorrow :-)
mmosberg
Norway
C?ID=65477
Here is the log from the engine:
;SW:06V-910-401-C   HW:06V-910-401 ---  Engine
;Component:TDI265-6CEZA 000AG  0010, Coding:0000000
;Monday,07,September,2015,18:44:45:34655
;VCDS Version: Release 15.7.1  Data version: 20150904
;VCID: 2E58C233BA901A4EFF-5120
A01,0,
;0
A01,1,
;0.0 mbar
A01,2,
;80.9 %
A01,3,
;1050.6 mbar
A01,4,
;0.93 l/h
A02,0,
;8192
A02,1,
;0.0 mbar
A02,2,
; 0 01
A02,3,
;1009.8 mbar
A02,4,
;18.5 %
A03,0,
;8192
A03,1,
;0.0 mbar
A03,2,
;1.02
A03,3,
;928.3 mg/str
A03,4,
;198.9 Nm
A04,0,
;8192
A04,1,
;0.0 mbar
A04,2,
;5.08
A04,3,
;1050.6 mbar
A04,4,
;0.93 l/h
A05,0,
;0
A05,1,
;0.0 mbar
A05,2,
;80.9 %
A05,3,
;517.0 mg/str
A05,4,
;0.93 l/h
A06,0,
;0
A06,1,
;651 /min
A06,2,
A06,3,
A06,4,
A07,0,
;247
A07,1,
;0.0 km/h
A07,2,
;248.6 km/h
A07,3,
A07,4,
A08,0,
;0
A08,1,
;0.0 mbar
A08,2,
;80.9 %
A08,3,
;511.1 mg/str
A08,4,
;11000000
A09,0,
;8192
A09,1,
;0.0 mbar
A09,2,
;-8.1°C
A09,3,
;511.1 mg/str
A09,4,
;11000000
A10,0,
;0
A10,1,
;630 /min
A10,2,
A10,3,
A10,4,
A11,0,
;0
A11,1,
;651 /min
A11,2,
A11,3,
A11,4,
;12 N/A
;13 N/A
A14,0,
;0
A14,1,
A14,2,
A14,3,
A14,4,
;15 N/A
;16 N/A
;17 N/A
;18 N/A
;19 N/A
;20 N/A
;21 N/A
;22 N/A
;23 N/A
;24 N/A
;25 N/A
;26 N/A
;27 N/A
;28 N/A
;29 N/A
;30 N/A
;31 N/A
;32 N/A
;33 N/A
;34 N/A
;35 N/A
;36 N/A
;37 N/A
;38 N/A
;39 N/A
;40 N/A
;41 N/A
;42 N/A
;43 N/A
;44 N/A
;45 N/A
;46 N/A
;47 N/A
;48 N/A
;49 N/A
A50,0,
;32000
A50,1,
;Malfunction
A50,2,
A50,3,
A50,4,
;51 N/A
;52 N/A
;53 N/A
;54 N/A
;55 N/A
;56 N/A
;57 N/A
;58 N/A
;59 N/A
;60 N/A
;61 N/A
;62 N/A
;63 N/A
;64 N/A
;65 N/A
;66 N/A
;67 N/A
;68 N/A
;69 N/A
;70 N/A
A71,0,
;6RHV7EI
A71,1,
A71,2,
A71,3,
A71,4,
A72,0,
;AIAWE5I
A72,1,
A72,2,
A72,3,
A72,4,
A73,0,
;7SH7CNI
A73,1,
A73,2,
A73,3,
A73,4,
A74,0,
;7Z8YDWI
A74,1,
A74,2,
A74,3,
A74,4,
A75,0,
;81ALD1I
A75,1,
A75,2,
A75,3,
A75,4,
A76,0,
;BA15GNI
A76,1,
A76,2,
A76,3,
A76,4,
;77 N/A
;78 N/A
;79 N/A
;80 N/A
A81,0,
;0
A81,1,
A81,2,
A81,3,
A81,4,
A82,0,
;0
A82,1,
A82,2,
A82,3,
A82,4,
A83,0,
;0
A83,1,
A83,2,
A83,3,
A83,4,
A84,0,
;0
A84,1,
A84,2,
A84,3,
A84,4,
;85 N/A
;86 N/A
;87 N/A
;88 N/A
;89 N/A
;90 N/A
A91,0,
;4
A91,1,
A91,2,
A91,3,
A91,4,
;92 N/A
;93 N/A
;94 N/A
;95 N/A
;96 N/A
;97 N/A
;98 N/A
;99 N/A
;100 N/A
;101 N/A
;102 N/A
;103 N/A
;104 N/A
;105 N/A
;106 N/A
;107 N/A
;108 N/A
;109 N/A
;110 N/A
;111 N/A
;112 N/A
;113 N/A
;114 N/A
;115 N/A
;116 N/A
;117 N/A
;118 N/A
;119 N/A
;120 N/A
;121 N/A
;122 N/A
;123 N/A
;124 N/A
;125 N/A
;126 N/A
;127 N/A
A128,0,
A128,1,
;ERROR:
A128,2,
;Security
A128,3,
;access
A128,4,
;required
A129,0,
A129,1,
;ERROR:
A129,2,
;Security
A129,3,
;access
A129,4,
;required
A130,0,
A130,1,
;ERROR:
A130,2,
;Security
A130,3,
;access
A130,4,
;required
A131,0,
A131,1,
;ERROR:
A131,2,
;Security
A131,3,
;access
A131,4,
;required
A132,0,
A132,1,
;ERROR:
A132,2,
;Security
A132,3,
;access
A132,4,
;required
A133,0,
A133,1,
;ERROR:
A133,2,
;Security
A133,3,
;access
A133,4,
;required
A134,0,
A134,1,
;ERROR:
A134,2,
;Security
A134,3,
;access
A134,4,
;required
A135,0,
A135,1,
;ERROR:
A135,2,
;Security
A135,3,
;access
A135,4,
;required
A136,0,
A136,1,
;ERROR:
A136,2,
;Security
A136,3,
;access
A136,4,
;required
A137,0,
A137,1,
;ERROR:
A137,2,
;Security
A137,3,
;access
A137,4,
;required
A138,0,
A138,1,
;ERROR:
A138,2,
;Security
A138,3,
;access
A138,4,
;required
A139,0,
A139,1,
;ERROR:
A139,2,
;Security
A139,3,
;access
A139,4,
;required
A140,0,
A140,1,
;ERROR:
A140,2,
;Security
A140,3,
;access
A140,4,
;required
A141,0,
A141,1,
;ERROR:
A141,2,
;Security
A141,3,
;access
A141,4,
;required
A142,0,
A142,1,
;ERROR:
A142,2,
;Security
A142,3,
;access
A142,4,
;required
A143,0,
A143,1,
;ERROR:
A143,2,
;Security
A143,3,
;access
A143,4,
;required
A144,0,
A144,1,
;ERROR:
A144,2,
;Security
A144,3,
;access
A144,4,
;required
A145,0,
A145,1,
;ERROR:
A145,2,
;Security
A145,3,
;access
A145,4,
;required
A146,0,
A146,1,
;ERROR:
A146,2,
;Security
A146,3,
;access
A146,4,
;required
A147,0,
A147,1,
;ERROR:
A147,2,
;Security
A147,3,
;access
A147,4,
;required
A148,0,
A148,1,
;ERROR:
A148,2,
;Security
A148,3,
;access
A148,4,
;required
A149,0,
A149,1,
;ERROR:
A149,2,
;Security
A149,3,
;access
A149,4,
;required
A150,0,
A150,1,
;ERROR:
A150,2,
;Security
A150,3,
;access
A150,4,
;required
A151,0,
A151,1,
;ERROR:
A151,2,
;Security
A151,3,
;access
A151,4,
;required
A152,0,
A152,1,
;ERROR:
A152,2,
;Security
A152,3,
;access
A152,4,
;required
A153,0,
A153,1,
;ERROR:
A153,2,
;Security
A153,3,
;access
A153,4,
;required
A154,0,
A154,1,
;ERROR:
A154,2,
;Security
A154,3,
;access
A154,4,
;required
A155,0,
A155,1,
;ERROR:
A155,2,
;Security
A155,3,
;access
A155,4,
;required
A156,0,
A156,1,
;ERROR:
A156,2,
;Security
A156,3,
;access
A156,4,
;required
A157,0,
A157,1,
;ERROR:
A157,2,
;Security
A157,3,
;access
A157,4,
;required
A158,0,
A158,1,
;ERROR:
A158,2,
;Security
A158,3,
;access
A158,4,
;required
A159,0,
A159,1,
;ERROR:
A159,2,
;Security
A159,3,
;access
A159,4,
;required
A160,0,
A160,1,
;ERROR:
A160,2,
;Security
A160,3,
;access
A160,4,
;required
A161,0,
A161,1,
;ERROR:
A161,2,
;Security
A161,3,
;access
A161,4,
;required
A162,0,
A162,1,
;ERROR:
A162,2,
;Security
A162,3,
;access
A162,4,
;required
A163,0,
A163,1,
;ERROR:
A163,2,
;Security
A163,3,
;access
A163,4,
;required
A164,0,
A164,1,
;ERROR:
A164,2,
;Security
A164,3,
;access
A164,4,
;required
A165,0,
A165,1,
;ERROR:
A165,2,
;Security
A165,3,
;access
A165,4,
;required
A166,0,
A166,1,
;ERROR:
A166,2,
;Security
A166,3,
;access
A166,4,
;required
A167,0,
A167,1,
;ERROR:
A167,2,
;Security
A167,3,
;access
A167,4,
;required
A168,0,
A168,1,
;ERROR:
A168,2,
;Security
A168,3,
;access
A168,4,
;required
A169,0,
A169,1,
;ERROR:
A169,2,
;Security
A169,3,
;access
A169,4,
;required
A170,0,
A170,1,
;ERROR:
A170,2,
;Security
A170,3,
;access
A170,4,
;required
A171,0,
A171,1,
;ERROR:
A171,2,
;Security
A171,3,
;access
A171,4,
;required
A172,0,
A172,1,
;ERROR:
A172,2,
;Security
A172,3,
;access
A172,4,
;required
A173,0,
A173,1,
;ERROR:
A173,2,
;Security
A173,3,
;access
A173,4,
;required
A174,0,
A174,1,
;ERROR:
A174,2,
;Security
A174,3,
;access
A174,4,
;required
A175,0,
A175,1,
;ERROR:
A175,2,
;Security
A175,3,
;access
A175,4,
;required
A176,0,
A176,1,
;ERROR:
A176,2,
;Security
A176,3,
;access
A176,4,
;required
A177,0,
A177,1,
;ERROR:
A177,2,
;Security
A177,3,
;access
A177,4,
;required
A178,0,
A178,1,
;ERROR:
A178,2,
;Security
A178,3,
;access
A178,4,
;required
A179,0,
A179,1,
;ERROR:
A179,2,
;Security
A179,3,
;access
A179,4,
;required
A180,0,
A180,1,
;ERROR:
A180,2,
;Security
A180,3,
;access
A180,4,
;required
A181,0,
A181,1,
;ERROR:
A181,2,
;Security
A181,3,
;access
A181,4,
;required
A182,0,
A182,1,
;ERROR:
A182,2,
;Security
A182,3,
;access
A182,4,
;required
A183,0,
A183,1,
;ERROR:
A183,2,
;Security
A183,3,
;access
A183,4,
;required
A184,0,
A184,1,
;ERROR:
A184,2,
;Security
A184,3,
;access
A184,4,
;required
A185,0,
A185,1,
;ERROR:
A185,2,
;Security
A185,3,
;access
A185,4,
;required
A186,0,
A186,1,
;ERROR:
A186,2,
;Security
A186,3,
;access
A186,4,
;required
A187,0,
A187,1,
;ERROR:
A187,2,
;Security
A187,3,
;access
A187,4,
;required
A188,0,
A188,1,
;ERROR:
A188,2,
;Security
A188,3,
;access
A188,4,
;required
A189,0,
A189,1,
;ERROR:
A189,2,
;Security
A189,3,
;access
A189,4,
;required
A190,0,
A190,1,
;ERROR:
A190,2,
;Security
A190,3,
;access
A190,4,
;required
A191,0,
A191,1,
;ERROR:
A191,2,
;Security
A191,3,
;access
A191,4,
;required
A192,0,
A192,1,
;ERROR:
A192,2,
;Security
A192,3,
;access
A192,4,
;required
A193,0,
A193,1,
;ERROR:
A193,2,
;Security
A193,3,
;access
A193,4,
;required
A194,0,
A194,1,
;ERROR:
A194,2,
;Security
A194,3,
;access
A194,4,
;required
A195,0,
A195,1,
;ERROR:
A195,2,
;Security
A195,3,
;access
A195,4,
;required
A196,0,
A196,1,
;ERROR:
A196,2,
;Security
A196,3,
;access
A196,4,
;required
A197,0,
A197,1,
;ERROR:
A197,2,
;Security
A197,3,
;access
A197,4,
;required
A198,0,
A198,1,
;ERROR:
A198,2,
;Security
A198,3,
;access
A198,4,
;required
A199,0,
A199,1,
;ERROR:
A199,2,
;Security
A199,3,
;access
A199,4,
;required
A200,0,
A200,1,
;ERROR:
A200,2,
;Security
A200,3,
;access
A200,4,
;required
A201,0,
A201,1,
;ERROR:
A201,2,
;Security
A201,3,
;access
A201,4,
;required
A202,0,
A202,1,
;ERROR:
A202,2,
;Security
A202,3,
;access
A202,4,
;required
A203,0,
A203,1,
;ERROR:
A203,2,
;Security
A203,3,
;access
A203,4,
;required
A204,0,
A204,1,
;ERROR:
A204,2,
;Security
A204,3,
;access
A204,4,
;required
A205,0,
A205,1,
;ERROR:
A205,2,
;Security
A205,3,
;access
A205,4,
;required
A206,0,
A206,1,
;ERROR:
A206,2,
;Security
A206,3,
;access
A206,4,
;required
A207,0,
A207,1,
;ERROR:
A207,2,
;Security
A207,3,
;access
A207,4,
;required
A208,0,
A208,1,
;ERROR:
A208,2,
;Security
A208,3,
;access
A208,4,
;required
A209,0,
A209,1,
;ERROR:
A209,2,
;Security
A209,3,
;access
A209,4,
;required
A210,0,
A210,1,
;ERROR:
A210,2,
;Security
A210,3,
;access
A210,4,
;required
A211,0,
A211,1,
;ERROR:
A211,2,
;Security
A211,3,
;access
A211,4,
;required
A212,0,
A212,1,
;ERROR:
A212,2,
;Security
A212,3,
;access
A212,4,
;required
A213,0,
A213,1,
;ERROR:
A213,2,
;Security
A213,3,
;access
A213,4,
;required
A214,0,
A214,1,
;ERROR:
A214,2,
;Security
A214,3,
;access
A214,4,
;required
A215,0,
A215,1,
;ERROR:
A215,2,
;Security
A215,3,
;access
A215,4,
;required
A216,0,
A216,1,
;ERROR:
A216,2,
;Security
A216,3,
;access
A216,4,
;required
A217,0,
A217,1,
;ERROR:
A217,2,
;Security
A217,3,
;access
A217,4,
;required
A218,0,
A218,1,
;ERROR:
A218,2,
;Security
A218,3,
;access
A218,4,
;required
A219,0,
A219,1,
;ERROR:
A219,2,
;Security
A219,3,
;access
A219,4,
;required
A220,0,
A220,1,
;ERROR:
A220,2,
;Security
A220,3,
;access
A220,4,
;required
A221,0,
A221,1,
;ERROR:
A221,2,
;Security
A221,3,
;access
A221,4,
;required
A222,0,
A222,1,
;ERROR:
A222,2,
;Security
A222,3,
;access
A222,4,
;required
A223,0,
A223,1,
;ERROR:
A223,2,
;Security
A223,3,
;access
A223,4,
;required
A224,0,
A224,1,
;ERROR:
A224,2,
;Security
A224,3,
;access
A224,4,
;required
A225,0,
A225,1,
;ERROR:
A225,2,
;Security
A225,3,
;access
A225,4,
;required
A226,0,
A226,1,
;ERROR:
A226,2,
;Security
A226,3,
;access
A226,4,
;required
A227,0,
A227,1,
;ERROR:
A227,2,
;Security
A227,3,
;access
A227,4,
;required
A228,0,
A228,1,
;ERROR:
A228,2,
;Security
A228,3,
;access
A228,4,
;required
A229,0,
A229,1,
;ERROR:
A229,2,
;Security
A229,3,
;access
A229,4,
;required
A230,0,
A230,1,
;ERROR:
A230,2,
;Security
A230,3,
;access
A230,4,
;required
A231,0,
A231,1,
;ERROR:
A231,2,
;Security
A231,3,
;access
A231,4,
;required
A232,0,
A232,1,
;ERROR:
A232,2,
;Security
A232,3,
;access
A232,4,
;required
A233,0,
A233,1,
;ERROR:
A233,2,
;Security
A233,3,
;access
A233,4,
;required
A234,0,
A234,1,
;ERROR:
A234,2,
;Security
A234,3,
;access
A234,4,
;required
A235,0,
A235,1,
;ERROR:
A235,2,
;Security
A235,3,
;access
A235,4,
;required
A236,0,
A236,1,
;ERROR:
A236,2,
;Security
A236,3,
;access
A236,4,
;required
A237,0,
A237,1,
;ERROR:
A237,2,
;Security
A237,3,
;access
A237,4,
;required
A238,0,
A238,1,
;ERROR:
A238,2,
;Security
A238,3,
;access
A238,4,
;required
A239,0,
A239,1,
;ERROR:
A239,2,
;Security
A239,3,
;access
A239,4,
;required
A240,0,
A240,1,
;ERROR:
A240,2,
;Security
A240,3,
;access
A240,4,
;required
A241,0,
A241,1,
;ERROR:
A241,2,
;Security
A241,3,
;access
A241,4,
;required
A242,0,
A242,1,
;ERROR:
A242,2,
;Security
A242,3,
;access
A242,4,
;required
A243,0,
A243,1,
;ERROR:
A243,2,
;Security
A243,3,
;access
A243,4,
;required
A244,0,
A244,1,
;ERROR:
A244,2,
;Security
A244,3,
;access
A244,4,
;required
A245,0,
A245,1,
;ERROR:
A245,2,
;Security
A245,3,
;access
A245,4,
;required
A246,0,
A246,1,
;ERROR:
A246,2,
;Security
A246,3,
;access
A246,4,
;required
A247,0,
A247,1,
;ERROR:
A247,2,
;Security
A247,3,
;access
A247,4,
;required
A248,0,
A248,1,
;ERROR:
A248,2,
;Security
A248,3,
;access
A248,4,
;required
A249,0,
A249,1,
;ERROR:
A249,2,
;Security
A249,3,
;access
A249,4,
;required
A250,0,
A250,1,
;ERROR:
A250,2,
;Security
A250,3,
;access
A250,4,
;required
A251,0,
A251,1,
;ERROR:
A251,2,
;Security
A251,3,
;access
A251,4,
;required
A252,0,
A252,1,
;ERROR:
A252,2,
;Security
A252,3,
;access
A252,4,
;required
A253,0,
A253,1,
;ERROR:
A253,2,
;Security
A253,3,
;access
A253,4,
;required
A254,0,
A254,1,
;ERROR:
A254,2,
;Security
A254,3,
;access
A254,4,
;required
A255,0,
A255,1,
;ERROR:
A255,2,
;Security
A255,3,
;access
A255,4,
;required
;Monday,07,September,2015,18:51:22:34655
A01,0,
;0
A01,1,
;0.0 mbar
A01,2,
;78.5 %
A01,3,
;1050.6 mbar
A01,4,
;0.93 l/h
A02,0,
;8192
A02,1,
;0.0 mbar
A02,2,
; 0 01
A02,3,
;1009.8 mbar
A02,4,
;19.3 %
A03,0,
;8192
A03,1,
;0.0 mbar
A03,2,
;1.02
A03,3,
;799.0 mg/str
A03,4,
;198.9 Nm
A04,0,
;8192
A04,1,
;0.0 mbar
A04,2,
;5.08
A04,3,
;1050.6 mbar
A04,4,
;0.93 l/h
A05,0,
;0
A05,1,
;0.0 mbar
A05,2,
;77.7 %
A05,3,
;517.0 mg/str
A05,4,
;0.93 l/h
A06,0,
;0
A06,1,
;630 /min
A06,2,
A06,3,
A06,4,
A07,0,
;247
A07,1,
;0.0 km/h
A07,2,
;248.6 km/h
A07,3,
A07,4,
A08,0,
;0
A08,1,
;0.0 mbar
A08,2,
;80.5 %
A08,3,
;511.1 mg/str
A08,4,
;11000000
A09,0,
;8192
A09,1,
;0.0 mbar
A09,2,
;-8.1°C
A09,3,
;499.4 mg/str
A09,4,
;11000000
A10,0,
;0
A10,1,
;630 /min
A10,2,
A10,3,
A10,4,
A11,0,
;0
A11,1,
;651 /min
A11,2,
A11,3,
A11,4,
;12 N/A
;13 N/A
A14,0,
;0
A14,1,
A14,2,
A14,3,
A14,4,
;15 N/A
;16 N/A
;17 N/A
;18 N/A
;19 N/A
;20 N/A
;21 N/A
;22 N/A
;23 N/A
;24 N/A
;25 N/A
;26 N/A
;27 N/A
;28 N/A
;29 N/A
;30 N/A
;31 N/A
;32 N/A
;33 N/A
;34 N/A
;35 N/A
;36 N/A
;37 N/A
;38 N/A
;39 N/A
;40 N/A
;41 N/A
;42 N/A
;43 N/A
;44 N/A
;45 N/A
;46 N/A
;47 N/A
;48 N/A
;49 N/A
A50,0,
;32000
A50,1,
;Malfunction
A50,2,
A50,3,
A50,4,
;51 N/A
;52 N/A
;53 N/A
;54 N/A
;55 N/A
;56 N/A
;57 N/A
;58 N/A
;59 N/A
;60 N/A
;61 N/A
;62 N/A
;63 N/A
;64 N/A
;65 N/A
;66 N/A
;67 N/A
;68 N/A
;69 N/A
;70 N/A
A71,0,
;6RHV7EI
A71,1,
A71,2,
A71,3,
A71,4,
A72,0,
;AIAWE5I
A72,1,
A72,2,
A72,3,
A72,4,
A73,0,
;7SH7CNI
A73,1,
A73,2,
A73,3,
A73,4,
A74,0,
;7Z8YDWI
A74,1,
A74,2,
A74,3,
A74,4,
A75,0,
;81ALD1I
A75,1,
A75,2,
A75,3,
A75,4,
A76,0,
;BA15GNI
A76,1,
A76,2,
A76,3,
A76,4,
;77 N/A
;78 N/A
;79 N/A
;80 N/A
A81,0,
;0
A81,1,
A81,2,
A81,3,
A81,4,
A82,0,
;0
A82,1,
A82,2,
A82,3,
A82,4,
A83,0,
;0
A83,1,
A83,2,
A83,3,
A83,4,
A84,0,
;0
A84,1,
A84,2,
A84,3,
A84,4,
;85 N/A
;86 N/A
;87 N/A
;88 N/A
;89 N/A
;90 N/A
A91,0,
;4
A91,1,
A91,2,
A91,3,
A91,4,
;92 N/A
;93 N/A
;94 N/A
;95 N/A
;96 N/A
;97 N/A
;98 N/A
;99 N/A
;100 N/A
;101 N/A
;102 N/A
;103 N/A
;104 N/A
;105 N/A
;106 N/A
;107 N/A
;108 N/A
;109 N/A
;110 N/A
;111 N/A
;112 N/A
;113 N/A
;114 N/A
;115 N/A
;116 N/A
;117 N/A
;118 N/A
;119 N/A
;120 N/A
;121 N/A
;122 N/A
;123 N/A
;124 N/A
;125 N/A
;126 N/A
;127 N/A
A128,0,
A128,1,
;ERROR:
A128,2,
;Security
A128,3,
;access
A128,4,
;required
A129,0,
A129,1,
;ERROR:
A129,2,
;Security
A129,3,
;access
A129,4,
;required
A130,0,
A130,1,
;ERROR:
A130,2,
;Security
A130,3,
;access
A130,4,
;required
A131,0,
A131,1,
;ERROR:
A131,2,
;Security
A131,3,
;access
A131,4,
;required
A132,0,
A132,1,
;ERROR:
A132,2,
;Security
A132,3,
;access
A132,4,
;required
A133,0,
A133,1,
;ERROR:
A133,2,
;Security
A133,3,
;access
A133,4,
;required
A134,0,
A134,1,
;ERROR:
A134,2,
;Security
A134,3,
;access
A134,4,
;required
A135,0,
A135,1,
;ERROR:
A135,2,
;Security
A135,3,
;access
A135,4,
;required
A136,0,
A136,1,
;ERROR:
A136,2,
;Security
A136,3,
;access
A136,4,
;required
A137,0,
A137,1,
;ERROR:
A137,2,
;Security
A137,3,
;access
A137,4,
;required
A138,0,
A138,1,
;ERROR:
A138,2,
;Security
A138,3,
;access
A138,4,
;required
A139,0,
A139,1,
;ERROR:
A139,2,
;Security
A139,3,
;access
A139,4,
;required
A140,0,
A140,1,
;ERROR:
A140,2,
;Security
A140,3,
;access
A140,4,
;required
A141,0,
A141,1,
;ERROR:
A141,2,
;Security
A141,3,
;access
A141,4,
;required
A142,0,
A142,1,
;ERROR:
A142,2,
;Security
A142,3,
;access
A142,4,
;required
A143,0,
A143,1,
;ERROR:
A143,2,
;Security
A143,3,
;access
A143,4,
;required
A144,0,
A144,1,
;ERROR:
A144,2,
;Security
A144,3,
;access
A144,4,
;required
A145,0,
A145,1,
;ERROR:
A145,2,
;Security
A145,3,
;access
A145,4,
;required
A146,0,
A146,1,
;ERROR:
A146,2,
;Security
A146,3,
;access
A146,4,
;required
A147,0,
A147,1,
;ERROR:
A147,2,
;Security
A147,3,
;access
A147,4,
;required
A148,0,
A148,1,
;ERROR:
A148,2,
;Security
A148,3,
;access
A148,4,
;required
A149,0,
A149,1,
;ERROR:
A149,2,
;Security
A149,3,
;access
A149,4,
;required
A150,0,
A150,1,
;ERROR:
A150,2,
;Security
A150,3,
;access
A150,4,
;required
A151,0,
A151,1,
;ERROR:
A151,2,
;Security
A151,3,
;access
A151,4,
;required
A152,0,
A152,1,
;ERROR:
A152,2,
;Security
A152,3,
;access
A152,4,
;required
A153,0,
A153,1,
;ERROR:
A153,2,
;Security
A153,3,
;access
A153,4,
;required
A154,0,
A154,1,
;ERROR:
A154,2,
;Security
A154,3,
;access
A154,4,
;required
A155,0,
A155,1,
;ERROR:
A155,2,
;Security
A155,3,
;access
A155,4,
;required
A156,0,
A156,1,
;ERROR:
A156,2,
;Security
A156,3,
;access
A156,4,
;required
A157,0,
A157,1,
;ERROR:
A157,2,
;Security
A157,3,
;access
A157,4,
;required
A158,0,
A158,1,
;ERROR:
A158,2,
;Security
A158,3,
;access
A158,4,
;required
A159,0,
A159,1,
;ERROR:
A159,2,
;Security
A159,3,
;access
A159,4,
;required
A160,0,
A160,1,
;ERROR:
A160,2,
;Security
A160,3,
;access
A160,4,
;required
A161,0,
A161,1,
;ERROR:
A161,2,
;Security
A161,3,
;access
A161,4,
;required
A162,0,
A162,1,
;ERROR:
A162,2,
;Security
A162,3,
;access
A162,4,
;required
A163,0,
A163,1,
;ERROR:
A163,2,
;Security
A163,3,
;access
A163,4,
;required
A164,0,
A164,1,
;ERROR:
A164,2,
;Security
A164,3,
;access
A164,4,
;required
A165,0,
A165,1,
;ERROR:
A165,2,
;Security
A165,3,
;access
A165,4,
;required
A166,0,
A166,1,
;ERROR:
A166,2,
;Security
A166,3,
;access
A166,4,
;required
A167,0,
A167,1,
;ERROR:
A167,2,
;Security
A167,3,
;access
A167,4,
;required
A168,0,
A168,1,
;ERROR:
A168,2,
;Security
A168,3,
;access
A168,4,
;required
A169,0,
A169,1,
;ERROR:
A169,2,
;Security
A169,3,
;access
A169,4,
;required
A170,0,
A170,1,
;ERROR:
A170,2,
;Security
A170,3,
;access
A170,4,
;required
A171,0,
A171,1,
;ERROR:
A171,2,
;Security
A171,3,
;access
A171,4,
;required
A172,0,
A172,1,
;ERROR:
A172,2,
;Security
A172,3,
;access
A172,4,
;required
A173,0,
A173,1,
;ERROR:
A173,2,
;Security
A173,3,
;access
A173,4,
;required
A174,0,
A174,1,
;ERROR:
A174,2,
;Security
A174,3,
;access
A174,4,
;required
A175,0,
A175,1,
;ERROR:
A175,2,
;Security
A175,3,
;access
A175,4,
;required
A176,0,
A176,1,
;ERROR:
A176,2,
;Security
A176,3,
;access
A176,4,
;required
A177,0,
A177,1,
;ERROR:
A177,2,
;Security
A177,3,
;access
A177,4,
;required
A178,0,
A178,1,
;ERROR:
A178,2,
;Security
A178,3,
;access
A178,4,
;required
A179,0,
A179,1,
;ERROR:
A179,2,
;Security
A179,3,
;access
A179,4,
;required
A180,0,
A180,1,
;ERROR:
A180,2,
;Security
A180,3,
;access
A180,4,
;required
A181,0,
A181,1,
;ERROR:
A181,2,
;Security
A181,3,
;access
A181,4,
;required
A182,0,
A182,1,
;ERROR:
A182,2,
;Security
A182,3,
;access
A182,4,
;required
A183,0,
A183,1,
;ERROR:
A183,2,
;Security
A183,3,
;access
A183,4,
;required
A184,0,
A184,1,
;ERROR:
A184,2,
;Security
A184,3,
;access
A184,4,
;required
A185,0,
A185,1,
;ERROR:
A185,2,
;Security
A185,3,
;access
A185,4,
;required
A186,0,
A186,1,
;ERROR:
A186,2,
;Security
A186,3,
;access
A186,4,
;required
A187,0,
A187,1,
;ERROR:
A187,2,
;Security
A187,3,
;access
A187,4,
;required
A188,0,
A188,1,
;ERROR:
A188,2,
;Security
A188,3,
;access
A188,4,
;required
A189,0,
A189,1,
;ERROR:
A189,2,
;Security
A189,3,
;access
A189,4,
;required
A190,0,
A190,1,
;ERROR:
A190,2,
;Security
A190,3,
;access
A190,4,
;required
A191,0,
A191,1,
;ERROR:
A191,2,
;Security
A191,3,
;access
A191,4,
;required
A192,0,
A192,1,
;ERROR:
A192,2,
;Security
A192,3,
;access
A192,4,
;required
A193,0,
A193,1,
;ERROR:
A193,2,
;Security
A193,3,
;access
A193,4,
;required
A194,0,
A194,1,
;ERROR:
A194,2,
;Security
A194,3,
;access
A194,4,
;required
A195,0,
A195,1,
;ERROR:
A195,2,
;Security
A195,3,
;access
A195,4,
;required
A196,0,
A196,1,
;ERROR:
A196,2,
;Security
A196,3,
;access
A196,4,
;required
A197,0,
A197,1,
;ERROR:
A197,2,
;Security
A197,3,
;access
A197,4,
;required
A198,0,
A198,1,
;ERROR:
A198,2,
;Security
A198,3,
;access
A198,4,
;required
A199,0,
A199,1,
;ERROR:
A199,2,
;Security
A199,3,
;access
A199,4,
;required
A200,0,
A200,1,
;ERROR:
A200,2,
;Security
A200,3,
;access
A200,4,
;required
A201,0,
A201,1,
;ERROR:
A201,2,
;Security
A201,3,
;access
A201,4,
;required
A202,0,
A202,1,
;ERROR:
A202,2,
;Security
A202,3,
;access
A202,4,
;required
A203,0,
A203,1,
;ERROR:
A203,2,
;Security
A203,3,
;access
A203,4,
;required
A204,0,
A204,1,
;ERROR:
A204,2,
;Security
A204,3,
;access
A204,4,
;required
A205,0,
A205,1,
;ERROR:
A205,2,
;Security
A205,3,
;access
A205,4,
;required
A206,0,
A206,1,
;ERROR:
A206,2,
;Security
A206,3,
;access
A206,4,
;required
A207,0,
A207,1,
;ERROR:
A207,2,
;Security
A207,3,
;access
A207,4,
;required
A208,0,
A208,1,
;ERROR:
A208,2,
;Security
A208,3,
;access
A208,4,
;required
A209,0,
A209,1,
;ERROR:
A209,2,
;Security
A209,3,
;access
A209,4,
;required
A210,0,
A210,1,
;ERROR:
A210,2,
;Security
A210,3,
;access
A210,4,
;required
A211,0,
A211,1,
;ERROR:
A211,2,
;Security
A211,3,
;access
A211,4,
;required
A212,0,
A212,1,
;ERROR:
A212,2,
;Security
A212,3,
;access
A212,4,
;required
A213,0,
A213,1,
;ERROR:
A213,2,
;Security
A213,3,
;access
A213,4,
;required
A214,0,
A214,1,
;ERROR:
A214,2,
;Security
A214,3,
;access
A214,4,
;required
A215,0,
A215,1,
;ERROR:
A215,2,
;Security
A215,3,
;access
A215,4,
;required
A216,0,
A216,1,
;ERROR:
A216,2,
;Security
A216,3,
;access
A216,4,
;required
A217,0,
A217,1,
;ERROR:
A217,2,
;Security
A217,3,
;access
A217,4,
;required
A218,0,
A218,1,
;ERROR:
A218,2,
;Security
A218,3,
;access
A218,4,
;required
A219,0,
A219,1,
;ERROR:
A219,2,
;Security
A219,3,
;access
A219,4,
;required
A220,0,
A220,1,
;ERROR:
A220,2,
;Security
A220,3,
;access
A220,4,
;required
A221,0,
A221,1,
;ERROR:
A221,2,
;Security
A221,3,
;access
A221,4,
;required
A222,0,
A222,1,
;ERROR:
A222,2,
;Security
A222,3,
;access
A222,4,
;required
A223,0,
A223,1,
;ERROR:
A223,2,
;Security
A223,3,
;access
A223,4,
;required
A224,0,
A224,1,
;ERROR:
A224,2,
;Security
A224,3,
;access
A224,4,
;required
A225,0,
A225,1,
;ERROR:
A225,2,
;Security
A225,3,
;access
A225,4,
;required
A226,0,
A226,1,
;ERROR:
A226,2,
;Security
A226,3,
;access
A226,4,
;required
A227,0,
A227,1,
;ERROR:
A227,2,
;Security
A227,3,
;access
A227,4,
;required
A228,0,
A228,1,
;ERROR:
A228,2,
;Security
A228,3,
;access
A228,4,
;required
A229,0,
A229,1,
;ERROR:
A229,2,
;Security
A229,3,
;access
A229,4,
;required
A230,0,
A230,1,
;ERROR:
A230,2,
;Security
A230,3,
;access
A230,4,
;required
A231,0,
A231,1,
;ERROR:
A231,2,
;Security
A231,3,
;access
A231,4,
;required
A232,0,
A232,1,
;ERROR:
A232,2,
;Security
A232,3,
;access
A232,4,
;required
A233,0,
A233,1,
;ERROR:
A233,2,
;Security
A233,3,
;access
A233,4,
;required
A234,0,
A234,1,
;ERROR:
A234,2,
;Security
A234,3,
;access
A234,4,
;required
A235,0,
A235,1,
;ERROR:
A235,2,
;Security
A235,3,
;access
A235,4,
;required
A236,0,
A236,1,
;ERROR:
A236,2,
;Security
A236,3,
;access
A236,4,
;required
A237,0,
A237,1,
;ERROR:
A237,2,
;Security
A237,3,
;access
A237,4,
;required
A238,0,
A238,1,
;ERROR:
A238,2,
;Security
A238,3,
;access
A238,4,
;required
A239,0,
A239,1,
;ERROR:
A239,2,
;Security
A239,3,
;access
A239,4,
;required
A240,0,
A240,1,
;ERROR:
A240,2,
;Security
A240,3,
;access
A240,4,
;required
A241,0,
A241,1,
;ERROR:
A241,2,
;Security
A241,3,
;access
A241,4,
;required
A242,0,
A242,1,
;ERROR:
A242,2,
;Security
A242,3,
;access
A242,4,
;required
A243,0,
A243,1,
;ERROR:
A243,2,
;Security
A243,3,
;access
A243,4,
;required
A244,0,
A244,1,
;ERROR:
A244,2,
;Security
A244,3,
;access
A244,4,
;required
A245,0,
A245,1,
;ERROR:
A245,2,
;Security
A245,3,
;access
A245,4,
;required
A246,0,
A246,1,
;ERROR:
A246,2,
;Security
A246,3,
;access
A246,4,
;required
A247,0,
A247,1,
;ERROR:
A247,2,
;Security
A247,3,
;access
A247,4,
;required
A248,0,
A248,1,
;ERROR:
A248,2,
;Security
A248,3,
;access
A248,4,
;required
A249,0,
A249,1,
;ERROR:
A249,2,
;Security
A249,3,
;access
A249,4,
;required
A250,0,
A250,1,
;ERROR:
A250,2,
;Security
A250,3,
;access
A250,4,
;required
A251,0,
A251,1,
;ERROR:
A251,2,
;Security
A251,3,
;access
A251,4,
;required
A252,0,
A252,1,
;ERROR:
A252,2,
;Security
A252,3,
;access
A252,4,
;required
A253,0,
A253,1,
;ERROR:
A253,2,
;Security
A253,3,
;access
A253,4,
;required
A254,0,
A254,1,
;ERROR:
A254,2,
;Security
A254,3,
;access
A254,4,
;required
A255,0,
A255,1,
;ERROR:
A255,2,
;Security
A255,3,
;access
A255,4,
;required
NEtech
Denmark
C?ID=56995
Thank you very much, but PLB data is missing. The most important:thumbs:
mmosberg
Norway
C?ID=65477
Ooops, here they are:
;Monday,07,September,2015,18:44:03:34655
1,0,,
1,1,,,
;630 /min,RPM,
1,2,,,
;5.8 mg/str,Inj. Quantity,
1,3,,,
;262.7 bar,Pressure,
1,4,,,
;76.5°C,Temperature,
2,0,,
2,1,,,
;651 /min,RPM,
2,2,,,
;1.0 %,Duty Cycle,
2,3,,,
; 0 01   ,Bin. Bits,
2,4,,,
3,0,,
3,1,,,
;651 /min,RPM,
3,2,,,
;834.3 mg/str,Mass Air / Rev.,
3,3,,,
;511.1 mg/str,Mass Air / Rev.,
3,4,,,
;95.6 %,Duty Cycle,
4,0,,
4,1,,,
;630 /min,RPM,
4,2,,,
;-7.0°KW,Idle Stabilization,
4,3,,,
;0.42 ms,Time,
4,4,,,
5,0,,
5,1,,,
;630 /min,RPM,
5,2,,,
;17.0 mg/str,Inj. Quantity,
5,3,,,
;48.0,(no units),
5,4,,,
6,0,,
6,1,,,
;0.0 km/h,Speed,
6,2,,,
;11000000,Bin. Bits,
6,3,,,
;0.0 km/h,Speed,
6,4,,,
;00000001,Bin. Bits,
7,0,,
7,1,,,
;26.1°C,Temperature,
7,2,,,
;71.1°C,Temperature,
7,3,,,
;23.4°C,Temperature,
7,4,,,
8,0,,
8,1,,,
;630 /min,RPM,
8,2,,,
;39.0 Nm,Torque,
8,3,,,
;198.9 Nm,Torque,
8,4,,,
;319.8 Nm,Torque,
9,0,,
9,1,,,
;0.0 Nm,Torque,
9,2,,,
;1045.5 Nm,Torque,
9,3,,,
;-195.0 Nm,Torque,
9,4,,,
;799.5 Nm,Torque,
10,0,,
10,1,,,
10,2,,,
;1009.8 mbar,Absolute Pres.,
10,3,,,
;1050.6 mbar,Absolute Pres.,
10,4,,,
;1.0 %,Duty Cycle,
11,0,,
11,1,,,
;651 /min,RPM,
11,2,,,
;1091.4 mbar,Absolute Pres.,
11,3,,,
11,4,,,
;80.9 %,Duty Cycle,
12,0,,
12,1,,,
;01010000,Bin. Bits,
12,2,,,
;0.00 s,Time,
12,3,,,
;14.36 V,Voltage,
12,4,,,
13,0,,
13,1,,,
;0.00 mg/str,Inj. Quantity,
13,2,,,
13,3,,,
13,4,,,
14,0,,
14,1,,,
14,2,,,
14,3,,,
14,4,,,
15,0,,
15,1,,,
;651 /min,RPM,
15,2,,,
;5.5 mg/str,Inj. Quantity,
15,3,,,
;0.93 l/h,Fuel Consump.,
15,4,,,
;0.0 Nm,Torque,
16,0,,
16,1,,,
;      00,Bin. Bits,
16,2,,,
;11000001,Bin. Bits,
16,3,,,
;      00,Bin. Bits,
16,4,,,
;10.0 %,Duty Cycle,
17,0,,
17,1,,,
;00000000,Bin. Bits,
17,2,,,
;00100010,Bin. Bits,
17,3,,,
17,4,,,
18,0,,
18,1,,,
;630 /min,RPM,
18,2,,,
;0.4 %,Duty Cycle,
18,3,,,
18,4,,,
;517.0 mg/str,Mass Air / Rev.,
19,0,,
19,1,,,
19,2,,,
;100.6 %,Duty Cycle,
19,3,,,
;10.3 %,Duty Cycle,
19,4,,,
;10.3 %,Duty Cycle,
20,0,,
20,1,,,
;50.4°C,Temperature,
20,2,,,
;-40.5°C,Temperature,
20,3,,,
20,4,,,
;10010000,Bin. Bits,
21,0,,
21,1,,,
21,2,,,
;00000100,Bin. Bits,
21,3,,,
21,4,,,
22,0,,
22,1,,,
;630 /min,RPM,
22,2,,,
22,3,,,
22,4,,,
;18.5 %,Duty Cycle,
23,0,,
23,1,,,
;630 /min,RPM,
23,2,,,
23,3,,,
23,4,,,
;31.6 %,Duty Cycle,
24,0,,
24,1,,,
;651 /min,RPM,
24,2,,,
24,3,,,
;0.26 ms,Time,
24,4,,,
25,0,,
25,1,,,
;651 /min,RPM,
25,2,,,
25,3,,,
;0.26 ms,Time,
25,4,,,
;255.6 bar,Pressure,
26,0,,
26,1,,,
;630 /min,RPM,
26,2,,,
;0.0°KW,Idle Stabilization,
26,3,,,
;0.00 ms,Time,
26,4,,,
27,0,,
27,1,,,
;651 /min,RPM,
27,2,,,
;0.00 ms,Time,
27,3,,,
;0.00 ms,Time,
27,4,,,
28,0,,
28,1,,,
;1B9F,RPM,
29,0,,
29,1,,,
;1.0,(no units),
29,2,,,
29,3,,,
;0.0 km/h,Speed,
29,4,,,
30,0,,
30,1,,,
;0.400 V,Voltage,
30,2,,,
;0.000 V,Voltage,
30,3,,,
; 0 01   ,Bin. Bits,
30,4,,,
;1.0 %,Duty Cycle,
34,0,,
34,1,,,
;630 /min,RPM,
34,2,,,
;80.9 %,Duty Cycle,
34,3,,,
;0.4 %,Duty Cycle,
34,4,,,
35,0,,
35,1,,,
;651 /min,RPM,
35,2,,,
;133.4°C,Temperature,
35,3,,,
;1.64,(no units),
35,4,,,
;1.64,(no units),
36,0,,
36,1,,,
;651 /min,RPM,
36,2,,,
;20.5 %,Duty Cycle,
36,3,,,
;0.4 %,Duty Cycle,
36,4,,,
;505.3 mg/str,Mass Air / Rev.,
37,0,,
37,1,,,
;651 /min,RPM,
37,2,,,
;20.5 %,Duty Cycle,
37,3,,,
;0.4 %,Duty Cycle,
37,4,,,
40,0,,
40,1,,,
;2.2 %,Lambda,
40,2,,,
;0.000 V,Voltage,
40,3,,,
;1.0 %,Duty Cycle,
40,4,,,
;0.0,(no units),
41,0,,
41,1,,,
;0.0,(no units),
41,2,,,
;95.1 %,Duty Cycle,
41,3,,,
;4.980 V,Voltage,
41,4,,,
;1.00,(no units),
42,0,,
42,1,,,
;0.0,(no units),
42,2,,,
42,3,,,
;1040.4 mbar,Absolute Pres.,
42,4,,,
;0.000 V,Voltage,
43,0,,
43,1,,,
;651 /min,RPM,
43,2,,,
;899.0°C,Temperature,
43,3,,,
43,4,,,
;172.0,(no units),
44,0,,
44,1,,,
;651 /min,RPM,
44,2,,,
;10000001,Bin. Bits,
44,3,,,
;16.0,(no units),
44,4,,,
;0.0,(no units),
50,0,,
50,1,,,
;651 /min,RPM,
50,2,,,
50,3,,,
50,4,,,
;00000010,Bin. Bits,
51,0,,
51,1,,,
;651 /min,RPM,
51,2,,,
;315 /min,RPM,
51,3,,,
;48.0,(no units),
51,4,,,
55,0,,
55,1,,,
;0.00,(no units),
55,2,,,
;0 km,Mileage,
55,3,,,
;0.0,(no units),
55,4,,,
;0 /min,RPM,
56,0,,
56,1,,,
;0.0,(no units),
56,2,,,
;0.0,(no units),
56,3,,,
;-53.1°C,Temperature,
56,4,,,
;0.0,(no units),
58,0,,
58,1,,,
;651 /min,RPM,
58,2,,,
;0.0 km/h,Speed,
58,3,,,
;       0,Bin. Bits,
58,4,,,
;       0,Bin. Bits,
59,0,,
59,1,,,
;630 /min,RPM,
59,2,,,
;0.0 km/h,Speed,
59,3,,,
;       0,Bin. Bits,
59,4,,,
;       0,Bin. Bits,
60,0,,
60,1,,,
;630 /min,RPM,
60,2,,,
;39.0 Nm,Torque,
60,3,,,
;46.8 Nm,Torque,
60,4,,,
;3.9 Nm,Torque,
61,0,,
61,1,,,
;46.8 Nm,Torque,
61,2,,,
;-39.0 Nm,Torque,
61,3,,,
;0.0 Nm,Torque,
61,4,,,
;102.0,(no units),
65,0,,
65,1,,,
;651 /min,RPM,
65,2,,,
;4.9 mg/str,Inj. Quantity,
65,3,,,
65,4,,,
;0.0,(no units),
66,0,,
66,1,,,
66,2,,,
66,3,,,
66,4,,,
;0.0,(no units),
70,0,,
70,1,,,
;0.0,(no units),
70,2,,,
;0.0,(no units),
70,3,,,
;0.0,(no units),
70,4,,,
72,0,,
72,1,,,
;0.0 ms,Time Corr.,
72,2,,,
;0.0 ms,Time Corr.,
72,3,,,
;0.0 ms,Time Corr.,
72,4,,,
73,0,,
73,1,,,
;0.0 ms,Time Corr.,
73,2,,,
;0.0 ms,Time Corr.,
73,3,,,
;0.0 ms,Time Corr.,
73,4,,,
74,0,,
74,1,,,
;0.0 ms,Time Corr.,
74,2,,,
;0.0 ms,Time Corr.,
74,3,,,
;0.0 ms,Time Corr.,
74,4,,,
75,0,,
75,1,,,
;0.0 ms,Time Corr.,
75,2,,,
;0.0 ms,Time Corr.,
75,3,,,
;0.0 ms,Time Corr.,
75,4,,,
76,0,,
76,1,,,
;0.0 ms,Time Corr.,
76,2,,,
;0.0 ms,Time Corr.,
76,3,,,
;0.0 ms,Time Corr.,
76,4,,,
77,0,,
77,1,,,
;0.0 ms,Time Corr.,
77,2,,,
;0.0 ms,Time Corr.,
77,3,,,
;0.0 ms,Time Corr.,
77,4,,,
80,0,,
80,1,,,
;BPG-810 16.05.08 ÿÿÿÿÿÿÿÿ 1349 0312, ,
81,0,,
81,1,,,
82,0,,
82,1,,,
;3183678507360 <>  <>  <>   <>  <> , ,
86,0,,
86,1,,,
;01001100,Bin. Bits,
86,2,,,
;11110000,Bin. Bits,
86,3,,,
;01011111,Bin. Bits,
86,4,,,
;10001101,Bin. Bits,
87,0,,
87,1,,,
87,2,,,
;00001111,Bin. Bits,
87,3,,,
87,4,,,
90,0,,
90,1,,,
;630 /min,RPM,
90,2,,,
90,3,,,
;922.4 mg/str,Mass Air / Rev.,
90,4,,,
91,0,,
91,1,,,
;127.0,(no units),
91,2,,,
;-128.0,(no units),
91,3,,,
;963.5 mg/str,Mass Air / Rev.,
91,4,,,
;45.0,(no units),
93,0,,
93,1,,,
93,2,,,
;1.99,(no units),
93,3,,,
;172.0,(no units),
93,4,,,
;172.0,(no units),
94,0,,
94,1,,,
;11110111,Bin. Bits,
94,2,,,
94,3,,,
94,4,,,
95,0,,
95,1,,,
;       0,Bin. Bits,
95,2,,,
;       1,Bin. Bits,
95,3,,,
;       0,Bin. Bits,
95,4,,,
;       0,Bin. Bits,
96,0,,
96,1,,,
;       0,Bin. Bits,
96,2,,,
96,3,,,
96,4,,,
;14.44 V,Voltage,
100,0,,
100,1,,,
;651 /min,RPM,
100,2,,,
100,3,,,
;0.0,(no units),
100,4,,,
;      0 ,Bin. Bits,
101,0,,
101,1,,,
101,2,,,
101,3,,,
;00000   ,Bin. Bits,
101,4,,,
;     000,Bin. Bits,
102,0,,
102,1,,,
102,2,,,
102,3,,,
;-914 mbar,Pressure,
102,4,,,
103,0,,
103,1,,,
;0.0,(no units),
103,2,,,
;    0000,Bin. Bits,
103,3,,,
103,4,,,
;      00,Bin. Bits,
104,0,,
104,1,,,
;0.00,(no units),
104,2,,,
;0.0,(no units),
104,3,,,
;0.0,(no units),
104,4,,,
;0 km,Mileage,
105,0,,
105,1,,,
;0.0,(no units),
105,2,,,
;0.0,(no units),
105,3,,,
105,4,,,
;0.0 l,Tank Cont.,
110,0,,
110,1,,,
;630 /min,RPM,
110,2,,,
110,3,,,
;15.0,(no units),
110,4,,,
125,0,,
125,1,,,
125,2,,,
125,3,,,
;Instruments 0, ,
125,4,,,
;HVAC 0, ,
129,0,,
129,1,,,
129,2,,,
;Gateway 0, ,
129,3,,,
129,4,,,
135,0,,
135,1,,,
;70.7 %,Duty Cycle,
135,2,,,
135,3,,,
135,4,,,
140,0,,
140,1,,,
;4.98,(no units),
140,2,,,
;4.98,(no units),
140,3,,,
;5.08,(no units),
140,4,,,
;4.98,(no units),
141,0,,
141,1,,,
;4.88,(no units),
141,2,,,
;5.08,(no units),
141,3,,,
141,4,,,
150,0,,
150,1,,,
;0.0,(no units),
150,2,,,
150,3,,,
;     000,Bin. Bits,
150,4,,,
;    0000,Bin. Bits,
152,0,,
152,1,,,
;      0 ,Bin. Bits,
152,2,,,
;      00,Bin. Bits,
152,3,,,
;       1,Bin. Bits,
152,4,,,
;       0,Bin. Bits,
154,0,,
154,1,,,
;       0,Bin. Bits,
154,2,,,
;799.5 Nm,Torque,
154,3,,,
154,4,,,
156,0,,
156,1,,,
;0.0,(no units),
156,2,,,
;0 km,Mileage,
156,3,,,
156,4,,,
158,0,,
158,1,,,
158,2,,,
158,3,,,
158,4,,,
159,0,,
159,1,,,
159,2,,,
159,3,,,
159,4,,,
160,0,,
160,1,,,
160,2,,,
160,3,,,
160,4,,,
161,0,,
161,1,,,
161,2,,,
161,3,,,
161,4,,,
166,0,,
166,1,,,
;1.00,(no units),
166,2,,,
;1.00,(no units),
166,3,,,
;1.00,(no units),
166,4,,,
;1.00,(no units),
167,0,,
167,1,,,
;1.00,(no units),
167,2,,,
;1.02,(no units),
167,3,,,
167,4,,,
225,0,,
225,1,,,
;0.0,(no units),
225,2,,,
;0.0,(no units),
225,3,,,
;0.0,(no units),
225,4,,,
;0.0,(no units),
226,0,,
226,1,,,
;0.0,(no units),
226,2,,,
226,3,,,
;255.0,(no units),
226,4,,,
;0.0,(no units),
227,0,,
227,1,,,
;0.0,(no units),
227,2,,,
;0.0,(no units),
227,3,,,
;0.0,(no units),
227,4,,,
228,0,,
228,1,,,
;0.0,(no units),
228,2,,,
228,3,,,
228,4,,,
229,0,,
229,1,,,
;255.0,(no units),
229,2,,,
;255.0,(no units),
229,3,,,
229,4,,,
;Monday,07,September,2015,18:50:40:34655
1,0,,
1,1,,,
;651 /min,RPM,
1,2,,,
1,3,,,
1,4,,,
;75.6°C,Temperature,
2,0,,
2,1,,,
;651 /min,RPM,
2,2,,,
;1.0 %,Duty Cycle,
2,3,,,
; 0 01   ,Bin. Bits,
2,4,,,
3,0,,
3,1,,,
;651 /min,RPM,
3,2,,,
;904.8 mg/str,Mass Air / Rev.,
3,3,,,
3,4,,,
;95.6 %,Duty Cycle,
4,0,,
4,1,,,
;630 /min,RPM,
4,2,,,
4,3,,,
;0.42 ms,Time,
4,4,,,
5,0,,
5,1,,,
;651 /min,RPM,
5,2,,,
5,3,,,
;48.0,(no units),
5,4,,,
6,0,,
6,1,,,
;0.0 km/h,Speed,
6,2,,,
6,3,,,
;0.0 km/h,Speed,
6,4,,,
7,0,,
7,1,,,
;25.2°C,Temperature,
7,2,,,
7,3,,,
7,4,,,
8,0,,
8,1,,,
;630 /min,RPM,
8,2,,,
;39.0 Nm,Torque,
8,3,,,
;198.9 Nm,Torque,
8,4,,,
;300.3 Nm,Torque,
9,0,,
9,1,,,
;0.0 Nm,Torque,
9,2,,,
;1045.5 Nm,Torque,
9,3,,,
;-195.0 Nm,Torque,
9,4,,,
;799.5 Nm,Torque,
10,0,,
10,1,,,
10,2,,,
10,3,,,
10,4,,,
;1.0 %,Duty Cycle,
11,0,,
11,1,,,
;630 /min,RPM,
11,2,,,
11,3,,,
11,4,,,
;80.9 %,Duty Cycle,
12,0,,
12,1,,,
12,2,,,
;0.00 s,Time,
12,3,,,
;14.52 V,Voltage,
12,4,,,
13,0,,
13,1,,,
13,2,,,
13,3,,,
13,4,,,
14,0,,
14,1,,,
14,2,,,
14,3,,,
14,4,,,
15,0,,
15,1,,,
;630 /min,RPM,
15,2,,,
;6.0 mg/str,Inj. Quantity,
15,3,,,
15,4,,,
;0.0 Nm,Torque,
16,0,,
16,1,,,
;      00,Bin. Bits,
16,2,,,
16,3,,,
;      00,Bin. Bits,
16,4,,,
;10.0 %,Duty Cycle,
17,0,,
17,1,,,
17,2,,,
17,3,,,
17,4,,,
18,0,,
18,1,,,
;630 /min,RPM,
18,2,,,
;0.4 %,Duty Cycle,
18,3,,,
18,4,,,
19,0,,
19,1,,,
19,2,,,
19,3,,,
;10.3 %,Duty Cycle,
19,4,,,
;10.3 %,Duty Cycle,
20,0,,
20,1,,,
20,2,,,
20,3,,,
20,4,,,
21,0,,
21,1,,,
21,2,,,
21,3,,,
21,4,,,
22,0,,
22,1,,,
;630 /min,RPM,
22,2,,,
22,3,,,
22,4,,,
;18.5 %,Duty Cycle,
23,0,,
23,1,,,
;651 /min,RPM,
23,2,,,
23,3,,,
23,4,,,
;31.2 %,Duty Cycle,
24,0,,
24,1,,,
;651 /min,RPM,
24,2,,,
24,3,,,
;0.24 ms,Time,
24,4,,,
25,0,,
25,1,,,
;630 /min,RPM,
25,2,,,
25,3,,,
;0.24 ms,Time,
25,4,,,
26,0,,
26,1,,,
;651 /min,RPM,
26,2,,,
26,3,,,
;0.00 ms,Time,
26,4,,,
27,0,,
27,1,,,
;651 /min,RPM,
27,2,,,
;0.00 ms,Time,
27,3,,,
;0.00 ms,Time,
27,4,,,
28,0,,
28,1,,,
;1B9F,RPM,
29,0,,
29,1,,,
;1.0,(no units),
29,2,,,
29,3,,,
;0.0 km/h,Speed,
29,4,,,
30,0,,
30,1,,,
;0.400 V,Voltage,
30,2,,,
;0.000 V,Voltage,
30,3,,,
; 0 01   ,Bin. Bits,
30,4,,,
;1.0 %,Duty Cycle,
34,0,,
34,1,,,
;651 /min,RPM,
34,2,,,
;78.9 %,Duty Cycle,
34,3,,,
;0.4 %,Duty Cycle,
34,4,,,
35,0,,
35,1,,,
;630 /min,RPM,
35,2,,,
35,3,,,
;1.64,(no units),
35,4,,,
;1.64,(no units),
36,0,,
36,1,,,
;630 /min,RPM,
36,2,,,
;20.5 %,Duty Cycle,
36,3,,,
;0.4 %,Duty Cycle,
36,4,,,
37,0,,
37,1,,,
;630 /min,RPM,
37,2,,,
;20.5 %,Duty Cycle,
37,3,,,
;0.4 %,Duty Cycle,
37,4,,,
40,0,,
40,1,,,
;2.2 %,Lambda,
40,2,,,
;0.000 V,Voltage,
40,3,,,
;1.0 %,Duty Cycle,
40,4,,,
;0.0,(no units),
41,0,,
41,1,,,
;0.0,(no units),
41,2,,,
;93.9 %,Duty Cycle,
41,3,,,
;4.980 V,Voltage,
41,4,,,
;1.00,(no units),
42,0,,
42,1,,,
;0.0,(no units),
42,2,,,
42,3,,,
42,4,,,
;0.000 V,Voltage,
43,0,,
43,1,,,
;630 /min,RPM,
43,2,,,
43,3,,,
43,4,,,
;172.0,(no units),
44,0,,
44,1,,,
;630 /min,RPM,
44,2,,,
44,3,,,
;16.0,(no units),
44,4,,,
;0.0,(no units),
50,0,,
50,1,,,
;651 /min,RPM,
50,2,,,
50,3,,,
50,4,,,
51,0,,
51,1,,,
;630 /min,RPM,
51,2,,,
;315 /min,RPM,
51,3,,,
;48.0,(no units),
51,4,,,
55,0,,
55,1,,,
;0.00,(no units),
55,2,,,
;0 km,Mileage,
55,3,,,
;0.0,(no units),
55,4,,,
;0 /min,RPM,
56,0,,
56,1,,,
;0.0,(no units),
56,2,,,
;0.0,(no units),
56,3,,,
56,4,,,
;0.0,(no units),
58,0,,
58,1,,,
;630 /min,RPM,
58,2,,,
;0.0 km/h,Speed,
58,3,,,
;       0,Bin. Bits,
58,4,,,
;       0,Bin. Bits,
59,0,,
59,1,,,
;630 /min,RPM,
59,2,,,
;0.0 km/h,Speed,
59,3,,,
;       0,Bin. Bits,
59,4,,,
;       0,Bin. Bits,
60,0,,
60,1,,,
;651 /min,RPM,
60,2,,,
;31.2 Nm,Torque,
60,3,,,
;46.8 Nm,Torque,
60,4,,,
;3.9 Nm,Torque,
61,0,,
61,1,,,
;46.8 Nm,Torque,
61,2,,,
;-39.0 Nm,Torque,
61,3,,,
;0.0 Nm,Torque,
61,4,,,
;102.0,(no units),
65,0,,
65,1,,,
;651 /min,RPM,
65,2,,,
65,3,,,
65,4,,,
;0.0,(no units),
66,0,,
66,1,,,
66,2,,,
66,3,,,
66,4,,,
;0.0,(no units),
70,0,,
70,1,,,
;0.0,(no units),
70,2,,,
;0.0,(no units),
70,3,,,
;0.0,(no units),
70,4,,,
72,0,,
72,1,,,
;0.0 ms,Time Corr.,
72,2,,,
;0.0 ms,Time Corr.,
72,3,,,
;0.0 ms,Time Corr.,
72,4,,,
73,0,,
73,1,,,
;0.0 ms,Time Corr.,
73,2,,,
;0.0 ms,Time Corr.,
73,3,,,
;0.0 ms,Time Corr.,
73,4,,,
74,0,,
74,1,,,
;0.0 ms,Time Corr.,
74,2,,,
;0.0 ms,Time Corr.,
74,3,,,
;0.0 ms,Time Corr.,
74,4,,,
75,0,,
75,1,,,
;0.0 ms,Time Corr.,
75,2,,,
;0.0 ms,Time Corr.,
75,3,,,
;0.0 ms,Time Corr.,
75,4,,,
76,0,,
76,1,,,
;0.0 ms,Time Corr.,
76,2,,,
;0.0 ms,Time Corr.,
76,3,,,
;0.0 ms,Time Corr.,
76,4,,,
77,0,,
77,1,,,
;0.0 ms,Time Corr.,
77,2,,,
;0.0 ms,Time Corr.,
77,3,,,
;0.0 ms,Time Corr.,
77,4,,,
80,0,,
80,1,,,
81,0,,
81,1,,,
82,0,,
82,1,,,
86,0,,
86,1,,,
86,2,,,
86,3,,,
86,4,,,
87,0,,
87,1,,,
87,2,,,
87,3,,,
87,4,,,
90,0,,
90,1,,,
;651 /min,RPM,
90,2,,,
90,3,,,
;851.9 mg/str,Mass Air / Rev.,
90,4,,,
91,0,,
91,1,,,
;127.0,(no units),
91,2,,,
;-128.0,(no units),
91,3,,,
;728.5 mg/str,Mass Air / Rev.,
91,4,,,
;21.0,(no units),
93,0,,
93,1,,,
93,2,,,
;1.99,(no units),
93,3,,,
;168.0,(no units),
93,4,,,
;168.0,(no units),
94,0,,
94,1,,,
94,2,,,
94,3,,,
94,4,,,
95,0,,
95,1,,,
;       0,Bin. Bits,
95,2,,,
;       1,Bin. Bits,
95,3,,,
;       0,Bin. Bits,
95,4,,,
;       0,Bin. Bits,
96,0,,
96,1,,,
;       0,Bin. Bits,
96,2,,,
96,3,,,
96,4,,,
;14.52 V,Voltage,
100,0,,
100,1,,,
;651 /min,RPM,
100,2,,,
100,3,,,
;0.0,(no units),
100,4,,,
;      0 ,Bin. Bits,
101,0,,
101,1,,,
101,2,,,
101,3,,,
;00000   ,Bin. Bits,
101,4,,,
;     000,Bin. Bits,
102,0,,
102,1,,,
102,2,,,
102,3,,,
102,4,,,
103,0,,
103,1,,,
;0.0,(no units),
103,2,,,
;    0000,Bin. Bits,
103,3,,,
103,4,,,
;      00,Bin. Bits,
104,0,,
104,1,,,
;0.00,(no units),
104,2,,,
;0.0,(no units),
104,3,,,
;0.0,(no units),
104,4,,,
;0 km,Mileage,
105,0,,
105,1,,,
;0.0,(no units),
105,2,,,
;0.0,(no units),
105,3,,,
105,4,,,
;0.0 l,Tank Cont.,
110,0,,
110,1,,,
;651 /min,RPM,
110,2,,,
110,3,,,
;15.0,(no units),
110,4,,,
125,0,,
125,1,,,
125,2,,,
125,3,,,
;Instruments 0, ,
125,4,,,
;HVAC 0, ,
129,0,,
129,1,,,
129,2,,,
;Gateway 0, ,
129,3,,,
129,4,,,
135,0,,
135,1,,,
;70.7 %,Duty Cycle,
135,2,,,
135,3,,,
135,4,,,
140,0,,
140,1,,,
;4.98,(no units),
140,2,,,
;4.98,(no units),
140,3,,,
;5.18,(no units),
140,4,,,
;4.98,(no units),
141,0,,
141,1,,,
;4.88,(no units),
141,2,,,
;5.08,(no units),
141,3,,,
141,4,,,
150,0,,
150,1,,,
;0.0,(no units),
150,2,,,
150,3,,,
;     000,Bin. Bits,
150,4,,,
;    0000,Bin. Bits,
152,0,,
152,1,,,
;      0 ,Bin. Bits,
152,2,,,
;      00,Bin. Bits,
152,3,,,
;       1,Bin. Bits,
152,4,,,
;       0,Bin. Bits,
154,0,,
154,1,,,
;       0,Bin. Bits,
154,2,,,
;799.5 Nm,Torque,
154,3,,,
154,4,,,
156,0,,
156,1,,,
;0.0,(no units),
156,2,,,
;0 km,Mileage,
156,3,,,
156,4,,,
158,0,,
158,1,,,
158,2,,,
158,3,,,
158,4,,,
159,0,,
159,1,,,
159,2,,,
159,3,,,
159,4,,,
160,0,,
160,1,,,
160,2,,,
160,3,,,
160,4,,,
161,0,,
161,1,,,
161,2,,,
161,3,,,
161,4,,,
166,0,,
166,1,,,
;1.00,(no units),
166,2,,,
;1.00,(no units),
166,3,,,
;1.00,(no units),
166,4,,,
;1.00,(no units),
167,0,,
167,1,,,
;1.00,(no units),
167,2,,,
;1.02,(no units),
167,3,,,
167,4,,,
225,0,,
225,1,,,
;0.0,(no units),
225,2,,,
;0.0,(no units),
225,3,,,
;0.0,(no units),
225,4,,,
;0.0,(no units),
226,0,,
226,1,,,
;0.0,(no units),
226,2,,,
226,3,,,
;255.0,(no units),
226,4,,,
;0.0,(no units),
227,0,,
227,1,,,
;0.0,(no units),
227,2,,,
;0.0,(no units),
227,3,,,
;0.0,(no units),
227,4,,,
228,0,,
228,1,,,
;0.0,(no units),
228,2,,,
228,3,,,
228,4,,,
229,0,,
229,1,,,
;255.0,(no units),
229,2,,,
;255.0,(no units),
229,3,,,
229,4,,,
