Help with 2015 VW CrossFox (South America)
fxtsi
Uruguay
C?ID=243709
Today I came accross a brand new VW CrossFox and could not make changes to it as the labels are still not present for its modules. So I'm posting the car's autoscan and some other info to see if the units are present on another models. I can get hold of the car anytime as it is a friend's car so if you need more info I can get it. Thanks in advance.
09 Adaptation channels (I'll translate and test them as soon as I can):
Autoscan:
Thursday,03,September,2015,20:03:29:34553
VCDS Version: 15.7.0.1 (x64)
Data version: 20150729
VIN: 9BWAL45Z1F4061360   License Plate: CROSSFOX
Chassis Type: 5Z (5Z - VW Fox (2004 >))
Scan: 01 03 08 09 15 17 19 44 46 56
Address 01: Engine (J623-CWSA)       Labels: None
   Part No SW: 04E 906 032 J    HW: 04E 907 425
   Component: 1.6l R4 MPI   H07 2806
   Revision: --H07---
   Coding: 00190012020400000000
   Shop #: WSC 01530 935 00200
   ASAM Dataset: EV_ECM16MPI02104E906032J 001006
   ROD: EV_ECM16MPI02104E906032A.rod
   VCID: 271E32BC5E6BED0637-8072
   Part No SW: 5Z0 907 379 L    HW: 6R0 907 379 AQ
   Component: ABS9.0 front  H01 0001
   Serial number: --------------
   Coding: F1DC908D322963C18F17096F4C51C6400800
   ASAM Dataset: EV_Brake1MABS90BOSCH 004002
   ROD: EV_Brake1MABS90BOSCH.rod
   VCID: 4ED0A7181151DC4E94-801A
Address 09: Cent. Elect. (J519)       Labels: 34D-937-087.clb
   Part No SW: 34D 937 087 C    HW: 34D 937 087 C
   Component: BFM H         122 0105
   Coding: 5FE5D56E87020F0F0D01997DB00100221F17
   ASAM Dataset: EV_BCMBFMHella 003001
   ROD: EV_BCMBFMHella_VW21.rod
   VCID: 302CD9E06BA5AABEE6-8064
   Subsystem 1 - Part No SW: 5Z0 959 800 B    HW: 5Z0 959 800 B
   Component: ZFH_Cross  H08 0015
   Serial number: 3982FL00001501200025
   Coding: 006B54
   Subsystem 2 - Part No SW: 5Z0 959 800 B    HW: 5Z0 959 800 B
   Coding: 006B54
   Subsystem 3 - Part No: 5Z0 947 105 E
   Component: DWA-Sensor  003 0008
   Subsystem 4 - Part No SW: 18D 959 442     HW: 18D 959 442
   Component: E221__MFL-PR6  H01 0110
   Serial number: 000000000A0314190115
   Coding: 200000
   Subsystem 5 - Part No SW: 5Z0 959 800 B    HW: 5Z0 959 800 B
   Coding: 006B54
   Subsystem 6 - Part No SW: 5Z0 959 800 B    HW: 5Z0 959 800 B
   Coding: 006B54
Address 15: Airbags (J234)       Labels: None
   Part No SW: 5Z0 959 655     HW: 5Z0 959 655
   Component: VW10AirbagZYC H02 0215
   Revision: --------    Serial number: 003NB0059X64
   Coding: 000000000000000000000000000000005943
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
   ROD: EV_AirbaVW10BPAVN750_SE12.rod
   VCID: 06405F38B9A1D40E6C-8052
Address 17: Instruments (J285)       Labels: 5Zx-920-xxx-17.lbl
   Part No SW: 5Z0 920 865 A    HW: 5Z0 920 865 A
   Component: KOMBI         H07 0010
   Coding: 87080A
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04726
   ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
   VCID: 3E30F7D8A1F14CCE64-806A
Address 44: Steering Assist (J500)       Labels: None
   Part No SW: 5Z1 909 144 D    HW: 5Z1 909 144
   Component: EPS_ECU       401 4040
   Coding: 000F
   ASAM Dataset: EV_SteerAssisNSKGen2 005107
   ROD: EV_SteerAssisNSKGen2_VW21.rod
   VCID: 3FCE8ADCA6FB45C66F-806A
Address 46: Central Conv.        Labels: None
   Part No: 5Z0 959 800 B
   Component: Z F H  GOL/FOX  H08 0015
   Coding: 0000001
   VCID: 40CC892012053A3E16-4B3C
Address 56: Radio (J503)       Labels: None
   Part No SW: 5Z0 035 160     HW: 5Z0 035 160
   Component: MIBGLAM       H11 0039
   Revision: RC101000    Serial number: VWZ7Z2R2209500
   Coding: 00000400020000
   VCID: 6E900798B911FC4EB4-803A
End-------------------------(Elapsed Time: 01:58)--------------------------
