- Apr 1, 2015
- 124
- 82
- London, United Kingdom
- C?ID=238277
I am trying to activate Developer Mode on my MMI unit however "Request Out of Range" is being returned when I try to set the adaptation to Active, both with Engine On and Off.
I was wondering if anyone would be able to suggest how to Activate this?
Many thanks in advance for the help!
Thursday,03,September,2015,13:36:23:21835
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(Parallels)
VCDS Version 15.7.0.2 (x64)
Data version: 20150820
VIN: WAUZZZ8V7E1010072 License Plate:
Chassis Type: 8V (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: WAUZZZ8V7E1010072 Mileage: 10521km-6537miles
Address 01: Engine (J623-CJSA) Labels: 06K-907-425-V1.clb
Part No SW: 8V0 906 264 B HW: 06K 907 425 A
Component: 1.8l R4 TFSI H09 0003
Revision: --H09---
Coding: 0A2500322404010B2000
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM18TFS0218V0906264B 001003
ROD: EV_ECM18TFS0218V0906264B_AU37.rod
VCID: 3B72BBC1B230EBE640-806F
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 045 P HW: 0AM 927 769 G
Component: GSG DQ200-MQB H43 4530
Revision: 00043014 Serial number: CU501309107614
Shop #: WSC 17734 418 534600
ROD: EV_TCMDQ200021_AU37.rod
VCID: 4684DA35F9F2A60E2F-8013
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 62683000000594
Coding: 13F18AA234212A6C0177060741C529C8512C5480608294F4004100388508
VCID: 7BF27BC1F2B02BE600-802F
Address 08: Auto HVAC (E87) Labels: 8V0-820-043.clb
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H13 0052
Revision: 20025000 Serial number: 00000000161197
Coding: 03100014100000011000000000001100
VCID: 336293E19A6023A698-8067
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AA HW: 5Q0 937 084 AA
Component: BCM MQBAB H H14 0112
Serial number: 00011326901276
Coding: 07101A46C24122FD03804004B11807A80000000000000000000000000000
ROD: EV_BCMBOSCH_AU37.rod
VCID: 77FA67F1CE980F8664-8023
Slave 1:
Subsystem 1 - Part No SW: 8V2 955 119 C HW: 8V2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 130825 041 0585
Serial number: 130911003409
Coding: 0A47F7
Slave 2:
Component: G397_RLFS H06 0002
Serial number: 20449421
Coding: 07006C
Slave 3:
Subsystem 3 - Part No SW: 8V0 941 531 Q HW: 8V0 941 531 Q
Serial number: 12 07 2012 00000198
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY1323145BH
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Serial number: 00000000000027931362
Subsystem 6 - Part No SW: 8V3 959 591 HW: 8V3 959 591
Component: J245 PS73.009 H02 0007
Serial number: WOO23970296
Coding: 901E00
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-283.clb
Part No SW: 5Q0 919 283 B HW: 5Q0 919 283
Component: PARKHILFE 4K H09 0033
Revision: -------- Serial number: 60831326300552
Coding: 0000050011
ASAM Dataset: EV_EPHVA14AU3700000 002018
ROD: EV_EPHVA14AU3700000_AU37.rod
VCID: 3878A4CD8306C0FEAD-806D
Part No SW: 5Q0 959 655 AB HW: 5Q0 959 655 AB
Component: AirbagVW20 014 0385
Serial number: 003MMR009MN%
Coding: 98CCC0000C0000005C5400CA00C800000065
VCID: 00080C2D9B56483E55-8055
Subsystem 1 - Part No SW: ----------- HW: 480 000 409 13
Serial number: 35767000000BA3FCBD0H
Subsystem 2 - Part No SW: ----------- HW: 480 000 409 13
Serial number: 358670000004C20DBD0+
Subsystem 3 - Part No SW: ----------- HW: 480 401 609 13
Serial number: 3516502A31118A52F25%
Subsystem 4 - Part No SW: ----------- HW: 480 401 609 13
Serial number: 3526502A311FBEB2B24M
Subsystem 5 - Part No SW: ----------- HW: 480 401 109 13
Serial number: 3556502A91118A526283
Pedestrian protection crash sensor; driver side:
Subsystem 6 - Part No SW: ----------- HW: 480 401 109 13
Component: PedP_Sensor_D 001 6149
Serial number: 2286502B11118A53838%
Pedestrian protection crash sensor; front passenger side:
Subsystem 7 - Part No SW: ----------- HW: 480 401 109 13
Component: PedP_Sensor_P 001 6149
Serial number: 2296502AD1118A546313
Subsystem 8 - Part No SW: ----------- HW: 480 002 108 13
Serial number: I0M80000000694249D09
Subsystem 9 - Part No SW: ----------- HW: 480 002 108 13
Serial number: I0N80000000C44249D0B
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 8V0 953 521 F HW: 5Q0 953 549 A
Revision: -------- Serial number: 26091304220118
Coding: 8018
ROD: EV_SMLSKLOMQB_AU37.rod
VCID: 3D76B5D9AC24E5D67E-8069
Part No SW: 8V0 920 970 M HW: 8V0 920 970 M
Component: KOMBI H03 2212
Coding: 238D19082B8026000101EA00000000
Shop #: WSC 04698 001 104857
Part No SW: 5Q0 907 530 M HW: 5Q0 907 530 M
Component: GW MQB High 212 2147
Revision: -------- Serial number: 20091310801689
Coding: 030100042B085A005B0002481C0B00000001000000000000000000000000
ASAM Dataset: EV_GatewConti 009011
ROD: EV_GatewConti.rod
Subsystem 2 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C
Component: E221 - MFL H02 0014
Serial number: 17 09 2013 C0342910
Subsystem 3 - Part No SW: 5Q0 915 181 D HW: 5Q0 915 181 D
Component: J367-BDM H08 0192
Serial number: 00000000004051110240
Part No SW: 5Q0 959 593 A HW: 5Q0 959 593
Component: TSG FS 012 0006
Serial number: 07081304081240
Coding: 00108E205C01040000001002
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
VCID: 3F8ACFD1A628F7C66C-806B
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 M
Component: EPS_MQB_ZFLS 127 1021
Coding: 81
ROD: EV_SteerAssisMQB.rod
Part No SW: 5Q0 959 592 A HW: 5Q0 959 592
Component: TSG BFS 012 0006
Serial number: 13091303111490
Coding: 001086205E01040000001002
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
VCID: 3E74B2D5A122FECE67-806B
Address 55: Headlight Range (J431) Labels: 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Coding: 019E000001000000
ROD: EV_HeadlRegulVWLWRMQB_AU37.rod
VCID: 75E66DF9D4947D9676-8021
Part No SW: 8V0 035 874 B HW: 8V0 035 874 B
Component: MU-S-ND-ER 040 0420
Serial number: A7F01809130964
Coding: 01730101FF00000021111101000A00002F0205460100010006
ASAM Dataset: EV_MUStd6C3PASE 002010
ROD: EV_MUStd6C3PASE_AU37.rod
Engine Control Module 2:
Subsystem 1 - Part No SW: 8V0 919 866 B HW: -----------
Component: ECE 2014 --- 0036
Seat Adjustment Driver Side:
Subsystem 2 - Part No SW: 8V0 919 603 C HW: 8V0 919 603 C
Component: DU Std H48 0013
Serial number: AUZ8Z9DY3000NS
Sound System:
Subsystem 3 - Part No SW: 8V0 919 614 B HW: 8V0 919 614 B
Component: ControlUnit_B H33 0037
Serial number: C1000027071300020767
End-------------------------(Elapsed Time: 04:01)--------------------------
