- Jun 28, 2014
- 5,256
- 3,546
- Northern NJ USA
- C?ID=208579
Tuesday,10,October,2023,16:50:11:47988
VCDS Version: 23.7.1.0 (x64) HEX-NET CB: 0.4639.4
Data version: 20230818 DS350.0
VIN: WUAEAAFX License Plate:
Chassis Type: FX-AU72 (4S0)
Scan: 01 02 03 05 06 08 09 11 31 14 15 16 17 19 1B 20 22 36 3B 42
44 46 52 53 55 5F 65 6C 81 A6 C2
VIN: WUAEAAFX Mileage: 95441km-59304miles
06-Seat Mem. Pass -- Status: Cannot be reached 0100
1B-Active Steering -- Status: Malfunction 0010
A6-Microphone -- Status: OK 0000
C2-Auto Trans 2 -- Status: OK 0000
Address 01: Engine (------CSPB) Labels:. 07L-907-552-V1.clb
Part No SW: 4S0 907 552 H HW: 4T0 907 552 A
Component: 5.2l V10HDZ / H56 0003
Revision: NHH56--- CVN: BCE97792
Coding: 1A2500320526000D3000
Shop #: WSC 51068 001 1048576
ASAM Dataset: EV_ECM52FSI1114S0907552H 001003
ROD: EV_ECM52FSI1114S0907552G.rod
VCID: 3B36F697B2DED44ADE-806E
VINID: 9E54554515A80181C90011061CBBA78DC1
17158 - Databus
U1123 00 [039] - Received Error Message
Mileage: 95441 km
Date: 2023.10.10
Time: 16:20:14
Engine RPM: 0.00 /min
Coolant temperature: 34 °C
Intake air temperature: 33 °C
Voltage terminal 30: 11.756 V
Drivetrain coordinator: brake fault status-Bits 0-7: 5
Drivetrain coordinator: brake function status-Bits 0-7: 32
Acceleration: 0.000 m/s²
Readiness: 1110 1101
Address 02: Auto Trans (J217) Labels:. 0BH-927-711.clb
Part No SW: 4S0 927 155 C HW: 0BH 927 711 F
Component: AU 6E 2B NAR H10 3914
Revision: 00H10V01 CVN: 70CECA0B
ASAM Dataset: EV_TCMDL800041 001013
ROD: EV_TCMDL800041_AU72.rod
VCID: 373EEAA78EF6F02A3A-8062
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4S0 907 379 A HW: 4S0 907 379 A
Component: ESP PREMIUM H09 0210
Coding: 01A9C10B809583D04B00
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremiAU57X 004048
ROD: EV_ESPPremiAU57X_AU72.rod
0859 - Function Restriction due to Faults in Other Modules
U1113 00 [137] - -
[DSASanityCheck_SteeringAngleCalculation]
Reset counter: 221
Mileage: 95441 km
Date: 2023.10.10
Time: 16:20:16
VzRef: 00
Bit Info 1: 00
Bit Info 2: 02
Bit Info 3: 22
Bit Info 4: 1F
F-Path: 01
F-Type: 4C
Uz: 98
29208 - Electronic Stability Program
C125F F0 [009] - Activated via Wheel Dampening Electronics
Reset counter: 221
Mileage: 95441 km
Date: 2023.10.10
Time: 16:20:15
VzRef: 00
Bit Info 1: 00
Bit Info 2: 02
Bit Info 3: 22
Bit Info 4: 1F
F-Path: 02
F-Type: 3F
Uz: 98
Part No SW: 4H0 907 064 GD HW: 4H0 907 064 GD
Component: BCM2 2.0 H37 0572
Coding: 0D806006000000000000
VCID: 71AA14BFA8126E1A34-8024
Serial number: 3216000036446013
Address 06: Seat Mem. Pass
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 4S0 820 043 K HW: 4S0 820 043 K
Component: AC Automat H08 0040
Revision: 20012000 Serial number: 96800000002737
Coding: 4000A01000000410
ASAM Dataset: EV_AirCondiVAPrehAU72x 003005
ROD: EV_AirCondiVAPrehAU72x.rod
VCID: 3326DEB79A8E1C0A06-8066
Rear A/C Control Head 2:
Subsystem 1 - Part No SW: 8S0 820 359 A HW: 8S0 820 359 A
Component: E775 BuA_2 H07 0020
Serial number: 00000000000000003877
Rear A/C Control Head 3:
Subsystem 2 - Part No SW: 8S0 820 359 HW: 8S0 820 359
Component: E776 BuA_3 H07 0020
Rear A/C Control Head 4:
Subsystem 3 - Part No SW: 8S0 820 359 B HW: 8S0 820 359 B
Component: E777 BuA_4 H07 0020
Part No SW: 4H0 907 063 GK HW: 4H0 907 063 EK
Component: BCM1 2.0 H21 0369
Revision: 2502105S Serial number: 00002381635101
Coding: 010D0011143C9FF07D0048C380003800C59CD2882A08322100040894F1001100006000340B0000
Shop #: WSC 60159 005 1048576
VCID: 77BE2AA7C676302AFA-8022
Subsystem 1 - Part No SW: 4S1 955 119 HW: 8V2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS624 160401 043 0071
Serial number: 90248139160405064101
Coding: 3247FD
Component: G397_RLFS H06 0004
Serial number: 61658212
Coding: 02005D
Subsystem 3 - Part No SW: 4S0 941 531 HW: 4S0 941 531
Component: E1 - LDS H01 0044
Serial number: 04 04 2016 00001038
Component: USHL4.2 H30 0030
Serial number: 00000000095Z0239CFC9
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0005
Serial number: 9DB9491800PAG0MUFU01
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 221
Mileage: 95441 km
Date: 2023.10.10
Time: 16:20:15
Address 11: Engine II (-----) Labels:. 07L-907-552-V1.clb
ASAM Dataset: EV_ECM52FSI2114S0907552H 001003
ROD: EV_ECM52FSI2114S0907552G.rod
Address 14: Susp. Elect. (J250) Labels: 8V0-907-376.clb
Part No SW: 4S0 907 376 E HW: 4S0 907 376 C
Component: DAEMPFUNGS-SG H06 0065
Serial number: 270221024 Dataset Number: 4S0909554B 0007
ASAM Dataset: EV_AudiMagneRide 003007
ROD: EV_AudiMagneRide_003.rod
VCID: 3C34F58BB7D0D372D7-8068
3153924 - Valve for DamPing Adjustment Front Right
C1041 13 [137] - Open Circuit
Reset counter: 221
Mileage: 95441 km
Date: 2023.10.10
Time: 16:20:15
COM: 03 2E 08 00 00 00 00 00 00 00
Voltage terminal 30: 11.9 V
Terminal 15 status via CAN: Terminal 15 on
Vehicle_level_sender_PWM-Left front: 4.0 %
Vehicle_level_sender_PWM-Right front: Not available
Vehicle_level_sender_PWM-Left rear: 17.2 %
Vehicle_level_sender_PWM-Right rear: 0.4 %
AMR state: 0
Damping adjustment indicator lamp: OFF
Dampening adjustment: current Highside-Left front: 252 mA
Dampening adjustment: current Highside-Right front: -8 mA
Dampening adjustment: current Highside-Left rear: 880 mA
Dampening adjustment: current Highside-Right rear: 1992 mA
Dampening adjustment valve: current Lowside-Left front: 255 mA
Dampening adjustment valve: current Lowside-Right front: -11 mA
Dampening adjustment valve: current Lowside-Left rear: 883 mA
Dampening adjustment valve: current Lowside-Right rear: 2000 mA
ESP automatic engagement: not activated
Fall-back level: 00 00 10 20
10579973 - Databus
U1122 00 [137] - Implausible Message
[init value steer angle]
Reset counter: 221
Mileage: 95441 km
Date: 2023.10.10
Time: 16:20:15
COM: 09 5D 09 8C 00 00 57 2B 00 00
Voltage terminal 30: 12.0 V
Steering angle: Not available
Steering rate: 0 rad/s
AMR state: 6
Damping adjustment indicator lamp: On
ESP automatic engagement: activated
Fall-back level: 00 00 16 62
Part No SW: 4S0 959 655 HW: 4S0 959 655
Component: Airbag10.43 H62 0203
Revision: -------- Serial number: 003NJ0012UC4 Dataset Number: 4S0909602D 0005
Coding: 30333845303530303731554A304C34533053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001034
VCID: 7EB03F83E14C0162B9-802A
Serial number: 6940000Y160001GKS703
Serial number: 3575HRB400I55BE6CHSN
Serial number: 3585HRB40573VRKK50C
Serial number: 3515JRB400M55COADHBM
Serial number: 3525JRB400M55COAEOH.
Serial number: 3554VRB401C5570AJ9OA
Serial number: 3564VRB401G5570AJ1J2
B13BC F2 [137] - No function
Mileage: 95441 km
Date: 2023.10.10
Time: 16:20:21
Part No SW: 4S0 907 129 K HW: 4S0 907 129 K
Component: Lenks.Modul H06 0006
Revision: C0071527 Serial number: 91335PD700153-
Coding: 000034
VCID: 3E30FF83A9CCC162F9-806A
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 4S0 920 890 HW: 4S0 920 890
Component: FBenUSA H14 0228
Coding: 086F30C1BA81D7050230ECC41800801000000000
ASAM Dataset: EV_DashBoardBOSCHAU724 001020
ROD: EV_DashBoardBOSCHAU724.rod
VCID: 73A61EB7DA0E5C0AC6-8026
Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb
Part No SW: 4S0 907 468 B HW: 4S0 907 468 A
Component: J533--Gateway H15 0074
Revision: -------- Serial number: 00000002202324 Dataset Number: 4S0909515A 0025
Coding: 802103161C
GVL: FF91CD88DC0A200180740000
Subsystem 1 - Part No SW: 8K0 915 181 M HW: 8K0 915 181 M
Component: J367-BDM H08 0270
Serial number: 53082L42483371778910
5735 - Seat/Mirror Postion Control Passenger - Driver
U0209 00 [009] - No Communications
Reset counter: 221
Mileage: 95441 km
Date: 2023.10.10
Time: 16:20:14
Voltage terminal 30: 11.7 V
Voltage terminal 15: 11.7 V
Control Module temperature: 30 °C
System status: Terminal 15 on
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 0
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 N HW: 8K0 907 144 N
Component: DYNAMIKLENK. H06 0740
Revision: 52001005 Serial number: --------------
Coding: 0D0000
VCID: 3A38F393B5E4ED42C5-806E
000 - - - MIL ON
Fault Status: 11100000
Count: 56
Count: 1
Hex Value: 0x0073
Hex Value: 0x741A
Hex Value: 0x0C00
Hex Value: 0x0000
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 4S0 857 511 A HW: 8S0 857 511 D
Component: FLA H09 0003
Revision: AB001001
Coding: 0404001D00010001000001
ASAM Dataset: EV_HighBeamAssisAU724 001007
ROD: EV_HighBeamAssisAU724.rod
Address 22: AWD (J492) Labels: 4T0-907-160.clb
Part No SW: 4S0 907 160 HW: 4S0 907 160
Component: 4 Wheel Drive H07 0207
Revision: 00001002 Serial number: 00G8800 Dataset Number: 4S0909104B 0007
ASAM Dataset: EV_AllWheelContrBORGLB724 006012
ROD: EV_AllWheelContrBORGLB724.rod
VCID: 6E900FC3B12C71E229-803A
Part No SW: 4S HW: 4S0 9
VCID: 075E5A67B69640AA8A-8052
No Faults Found
Part No SW: 4G0 907 637 L HW: 4G0 907 637 G
Component: SARA 6D red H04 0056
Revision: -------- Serial number: EJ1BPA7E023Z0C Dataset Number: 4S0909573A 0002
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0511
Coding: 011C53425000000300000402
VCID: 47DE9A67F61680AA4A-8012
02123 - Door Warning Light / Entry Light
Fault Status: 01101100
Reset counter: 221
Mileage: 95441 km
Date: 2023.10.10
Time: 16:20:16
Address 44: Steering Assist (J500) Labels:| 4S0-909-144.clb
Part No SW: 4S0 909 144 G HW: 4S0 909 144 B
Component: EPS H13 0904
Revision: 00000000 Serial number: L00126034
Coding: 0803
Shop #: WSC 04125 004 1048576
ASAM Dataset: EV_EPSZFAU72X 002010
ROD: EV_EPSZFAU72X_002.rod
VCID: 393AEC9FB8E2E65ACC-806C
65555 - Internal Control Module Memory Check Sum Error
B2000 00 [105] - -
[ECU_error]
Expanded ambient data 1-Terminal 30 voltage filtered: 11.80 V
Expanded ambient data 1-Internal voltage supply 5V: 0.00 V
Expanded ambient data 1-Vehicle speed: 0 km/h
Expanded ambient data 1-Control module temp: internal sensor: 26 °C
Expanded ambient data 1-Speed source: CAN ESP speed
Expanded ambient data 1-AD converter reference voltage: 1.50 V
Expanded ambient data 1-Voltage terminal 30 unfiltered: 11.75 V
Expanded ambient data 1-AD converter reference voltage 2: 1.50 V
Expanded ambient data 1-Switched voltage terminal 30 unfiltered: 12.01 V
Expanded ambient data 1-KFA: 00 00
Expanded ambient data 1-KFC: 00 4D
131077 - Internal Control Module Memory Check Sum Error
B2000 96 [105] - Component Internal Failure
[CAN_Error]
Expanded ambient data 1-Switched voltage terminal 30 unfiltered: 11.99 V
Expanded ambient data 1-KFC: 00 2B
Revision: 00002001 Serial number: 0401181595
Coding: 0106029A00F2C081E0B0CA00008500000001000000000000000000000000
Subsystem 1 - Part No SW: 4S0 959 719 A HW: 4S0 959 719 A
Component: GTO BF H01 0010
Serial number: 20160217192059 00167
Subsystem 3 - Part No SW: 4G8 959 252 A HW: 4G8 959 252
Component: HSP-SG H11 0031
Serial number: WA151040000109115264
Component: TSG BF H03 0511
Coding: 011C53425E00000300000400
VCID: 46C09763F11C99A2B1-8012
Part No SW: 4S0 907 801 HW: 8K0 907 801 J
Component: EPB-4 H03 0001
Revision: -------- Serial number: 20000000001881
ROD: EV_ParkiBrake_AU72.rod
VCID: 70AC11BBAB1867123B-8024
Part No SW: 4H4 907 357 G HW: 7P6 907 357 B
Component: MxB-ECU 001 0115
Revision: -------- Serial number: -------------- Dataset Number: 4S0909865C 0011
Coding: 077A081122600400
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005011
VCID: 3620E7A389FC092221-8062
Subsystem 1 - Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H09 0008
Coding: E02200
Subsystem 2 - Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H09 0008
Coding: E02200
Address 5F: Information Electr. (J794) Labels:* 8W0-035-MIB-HGH2.clb
Part No SW: 4S0 035 025 K HW: 4S0 035 025
Component: MU-H-LNS-US 051 0383
Serial number: A353D0GB000906 Dataset Number: 4S0909545E 0020
Coding: 012704020000000013220002041A00102F0000E1007000047E
ASAM Dataset: EV_MUHig6C8Gen2HBAS 001182
ROD: EV_MUHig6C8Gen2HBAS.rod
VCID: 312AD4BF60922E1A74-8064
Subsystem 1 - Part No SW: V03 959 801 GE HW: -----------
Component: NAR 2016 --- 0048
Subsystem 2 - Part No SW: 4S1 919 614 HW: 4S1 919 614
Component: ControlUnit_H H23 0136
Serial number: APVAK103031600010054
Compact disc data bank:
Component: Gracenote2 --- 3008
7184 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Seat adjustment/seat memory (0x10) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 6
Mileage: 95441 km
Date: 2023.10.10
Time: 16:20:16
BAP-BAP_Function_ID: 01
7200 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Seat adjustment/seat memory 2 (0x20) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 221
Mileage: 95441 km
Date: 2023.10.10
Time: 16:20:29
BAP-BAP_Function_ID: 02
Address 65: Tire Pressure (-----) Labels: 3Y0-907-273.clb
Part No SW: 4H0 907 273 D HW: 4H0 907 273 B
Component: RDKBERU25 H10 0900
Serial number: 10000000054898 Dataset Number: 4S0909850A 0005
ASAM Dataset: EV_RDKBERU25 003014
ROD: EV_RDKBERU25_AU57.rod
VCID: 2C14C5CB47B043F247-8078
8400901 - TPMS Warning; Front Right Tire
C1056 00 [009] - Pressure too Low
Reset counter: 221
Mileage: 95441 km
Date: 2023.10.10
Time: 16:20:49
Part No SW: 4S0 907 441 B HW: 5Q0 907 441 A
Component: D4-PA RVC Mid H07 0050
Dataset Number: 4S0909460A 0008
Coding: 022704010A01000100
Shop #: WSC 09768 003 1048576
ASAM Dataset: EV_CamSysRearPANAAU914 002002
ROD: EV_CamSysRearPANAAU914_VW51.rod
VCID: 3228DBB3659415020D-8066
10489856 - No Basic Setting
B2010 00 [009] - -
Reset counter: 221
Mileage: 95441 km
Date: 2023.10.10
Time: 16:20:16
passive
13706023 - Databus
[Initvalue-monitoring Gateway_06_SCU_Soll_Ue_Winkel]
Reset counter: 221
Mileage: 95441 km
Date: 2023.10.10
Time: 16:20:16
passive
13706024 - Databus
[Initvalue-monitoring Gateway_06_SCU_Ue_Winkel_ADS]
Reset counter: 221
Mileage: 95441 km
Date: 2023.10.10
Time: 16:20:16
passive
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 4S1 713 041 B HW: 4M1 713 041 D
Component: GSM-LL H07 0068
Revision: 0L0D5012 Serial number: 20160307000499
ASAM Dataset: EV_GSMWaehlZFAU736 001013
ROD: EV_GSMWaehlZFAU736_AU49.rod
VCID: 2A18C3D34D445DC2B5-807E
Address A6: Microphone (J886) Labels:. 420-907-394.clb
Part No SW: 420 907 394 B HW: 420 907 394
Component: BELTMICBOX H10 0840
Coding: 0101030202
ASAM Dataset: EV_BeltMicPARAGAU335 003011
ROD: EV_BeltMicPARAGAU335.rod
VCID: 187C091BE328DF5213-804C
Address C2: Auto Trans 2 (J217) Labels:. 0BH-927-711-C2.clb
Part No SW: 4S0 927 109 HW: 4S0 927 109
Component: DL800 ZSG H11 0002
Revision: --H11--- Serial number: 0000000096 CVN: 0000CB9C
ASAM Dataset: EV_TCMDL800421 001024
ROD: EV_TCMDL800.rod
End----------(Elapsed Time: 02:48, VBatt start/end: 11.8V/11.8V)-----------
Got a call from a local shop yesterday, they we're having a hard time trying to program a Front shock. When I got there I wasn't surprised, vehicle looks like it had water in it and I have issues with steering rack which was changed, but it looks like a used unit is no good. I will try swapping the original motor from original rack as at least they claim it had power steering with that rack installed. Then is seems like I can try programming the front shock after I figure out why it had an open circuit fault stored for it. Something tells me broken wire in the floor on passenger side, thats where the water was and J250 is on that side behind the rear shelf. I will be there later to dick around with it. Figured I'd post the scan just on case someone is looking for codings. This should be a fun one. I can't wait.
I hid the vin is this instance as I am not sure if the owner of this vehicle knows I am yet involved so it is merely to protect the shop and owner of the vehicle.
