2004 Jetta TDI - Engine light - Code 00152 Right Windshield Wiper Module
Ramp
Verified VCDS-Lite User
WA State, USA
C?ID=563744
HI, Im New to the forum, hopefully have this posted correctly. I recently obtained a 2004 Jetta TDI and have been going through various repairs / maint. Im getting a check Engine light and it appears to be from a 00152 code regarding the RH Windshield wiper control module. I havent noticed any issues with the wipers, they appear to be functioning properly. I clear the code but the Check engine light / fault reappears after 2 startups. The Ross WIKI doesnt list this code but it comes up in the scan. The car only has one motor driving both wipers so it seems strange the fault indicates a right wiper motor / module. Any help would be apprieciated, with the wipers working fine Im stumped and also wonder if the error code is legit. I recently put in an aftermarket lock module which appears to work fine but may be giving the lock fault but I dont think that is causing the engine light and will probably disrgard it and the radio antenna fault for now.
VCDS-Lite Version: Release 1.2
Tuesday, 10 October 2023, 11:29:06:19958
Chassis Type: 9M - VW Jetta IV
Scan: 01,02,03,08,09,15,16,17,19,22,29,35,36,37,39,46,47,55,56,57,75,76
Address 01: Engine       Labels: 038-906-016-BEW.LBL
   Controller: 038 997 016 R
   Component: R4 1,9L EDC G000SG  0282
   Coding: 0150031
   Shop #: WSC 07801
   VCID: 2D2DC741F409
00152 -  Right Windshield Wiper Motor Control Module (J584)
            000 -   -
Readiness: N/A
Address 03: ABS Brakes       Labels: None
   Controller: 1C0 907 379 M
   Coding: 0019458
   Shop #: WSC 00028
   VCID: 341BD2251723
Address 15: Airbags       Labels: 6Q0-909-605-VW5.LBL
   Controller: 1C0 909 605 F
   Component: 04 AIRBAG VW61 0202 0003
   Coding: 12340
   Shop #: WSC 00066
   VCID: 27213569D6F5
Address 16: Steering wheel       Labels: 1J0-907-487-A.LBL
   Controller: 1J0 907 487 A
   Component: Lenkradelektronik   0005
   Coding: 00118
   Shop #: WSC 00028
   VCID: 2F11DD49FE05
Address 17: Instruments       Labels: 1J0-920-xx5-17.LBL
   Controller: 1J5 920 906 Q
   Component: KOMBI+WEGFAHRSP VDO V55
   Coding: 15232
   Shop #: WSC 07801
   VCID: 3B09F9193A7D
   3VWSR69M24M112256     VWZ7Z0D9322129
Address 19: CAN Gateway       Labels: 6N0-909-901-19.LBL
   Controller: 6N0 909 901
   Coding: 00006
   Shop #: WSC 00028
   VCID: F0939E35A3BB
Address 46: Central Conv.       Labels: 1C0-959-799.LBL
   Controller: 1C0 959 799 C
   Component: 1H Komfortgerát HLO 0003
   Coding: 00258
   Shop #: WSC 00028
   VCID: 3701E5290655
00928 -  Locking Module for Central Locking; Front Driver Side (F220)
            54-00 -  Incorrectly Equipped
Address 56: Radio       Labels: 3B7-035-1xx-56.LBL
   Controller: 3B7 035 180 G
   Component: RADIO 3CP          0007
   Coding: 04031
   Shop #: WSC 00028
   VCID: 243B2265A7C3
00856 -  Radio Antenna
            36-10 -  Open Circuit - Intermittent
End   --------------------------------------------------------------------------------------------------
Dafuq? This car has no Windshield Wiper Motor Control Module, nor does this ECU have any business throwing that code. I mean, the text is correct for 00152, but the ECU shouldn't be producing it.
Is this ECU "chipped"?
Ramp
WA State, USA
C?ID=563744
Hi Uwe, Thanks for the quick reply. As far as I know the ECU is original and never been chipped. I have had a few other codes come up that I was able to correct. The latest were for a faulty Side airbag sensor and another for glow plug connections. Replaing the airbag sensor under the seat solved one and some cleaning at the glow plug harness solved the other. Then out of the blue comes the 00152.
Ramp
WA State, USA
C?ID=563744
Just to close this out - I tried a generic generic OB2 code reader and no codes found - it could clear the engine light but it came back after one start. I pulled and cleaned the ECU contacts - no joy. After a few trys I was able to duplicate a key and get a new fob working. At some point I pulled the codes again and the 00152 was gone but the glow plug code came back. Im not sure at what point this happened since I had been cycling a few times to get the immobolizer to update. After a few cleaning of the GP harness the codes are all clear - at least for now. I have a new GP harness on the way. I suspect there is or was something with the GP codes or harness that might have been somehow reading out as a wiper module but speculation on my part. I did previouly come across a thread that someone was seeing these 2 codes but couldnt find it again.
