Let's clear up some assumptions...
#1 The displayed values are for internal reference and do not represent the actual vehicle height.
#2 Your coding is all good, next update for will have an updated table.
...now that we're done with this, let's go back to your original issue. What exactly have you been unhappy with? Which wheel/tire combination are you running? When has the last actual alignment been done? Oh, let's not forget - PLEASE POST A
COMPLETE AUTO-SCAN.
Thanks for your fast response, Sebastian,
#1 What concerns me is that the reported LHS figures are very accurate and the RHS figures are well out. & all figures show the car as lower than stock. I bought the car 2nd hand but the suspension looks stock. here is the screen from :
#2 That's good to know, thanks & that's the great value of this product and the support forum.
To answer your question why I am unhappy with the handling:
I currently compete in Tarmac Rallys (usually on alpine roads) in my 2009 Mitsubishi Lancer EVO X RS. This car has AWD and an active centre diff. We have had a fair degree of success with it. The TT RS has become eligible in our competition and they are clearly a faster car. So I bought this 2010 TT RS 6MT with 21,000klm.
It's a very nice road car but before I commit to a big spend to make it a competition car, I work through a testing process at a local race track. I'm not looking for ultimate race track setup. This track has a very good combination of different corner types and I can data log the laps and see the cars behaviour compared to my EVO by overlaying laps from each car, so it's real data not seat of the pants feel.
A rally car will always have a softer setup to cope with less than perfect road surfaces and changing weather conditions. What I can do at the track is drive at speeds and close to the limits that I could never do on a public road.
Wheels & tyres?
On the road it has the stock 19x9 wheels with 265/35/19 Michelin Pilot Super Sport tyres. At the track I run a set of 18x9 wheels with Yokohama Advan AO50 Medium compound semi slick tyres. I don't think these are available in many countries but they are a very good tyre for tarmac rally. Compared to a Dunlop Direzza 03G semi slick, they are somewhere between an M2 & an R2 compound. Much more grippy and well behaved than a road tyre and very short life.
Alignment:
It had an alignment 3 months ago and was supposed to be set to Front: Max negative camber -1.2 deg, zero toe-in. Rear: -1.5 neg camber, 1mm toe in (I later found the rear toe was wrong and it had 4.1mm toe in)
It's just had a new alignment and it now Front: camber -1.2 deg Negative, 7.1 deg caster, zero toe-in. Rear: -1.5 neg camber, 1mm toe in
I did my first test day on stock anti-roll bars and then fitted H&R bars that have soft & hard link positions.
Haldex:
The car had the stock Haldex and I kept on getting codes relating to controller or clutch failure. I installed a competition controller (the single mode one) from HPA and while it didn't help lap times much, the car was much nicer to drive. More composed under brakes and much more settled when I have to upshift mid-corner.
Problem:
What I never experienced on the road but did when i was driving at a higher level at the track was the very bad power-on corner exit understeer. Note that this is not corner entry understeer. i am doing what I think is the right thing, the slow in fast out method and the car has no problem turning in to the apex. it has a serious understeer problem when, having reached the apex, I try to power out of the corner. With the stock bars this was a case of back off or you will hit the wall. With the H&R bars it is much better but it's still a problem. In a rally, if I arrive at a corner too fast because I have listened to the note call properly, I might have understeer and be looking at the big tree I will hit. In the EVO, I can chuck it in and manage things with the throttle.
One further bit of info: I'm no youngster. I'll be 67 next week. :-)
My next track day in three weeks will be with a custom set of MSS stacked rear springs with height adjustment like coilovers. The overall spring rates will be harder than stock.
This has been a long reply but I appreciate your input and I wanted to tell you what I have been doing.
I'm not sure how to post the autoscan correctly but here it is:
Version Release 15.7.0 (x64) Running on Windows 7 x64(VMWare)
Data version: 20150729
Friday,04,September,2015,08:21:29:35289
Chassis Type: 8J (8P0)
Scan: 01 03 08 09 10 14 15 16 17 19 20 22 25 2E 37 42 44 46 47 4C
52 55 56 61 77
VIN: TRUZZZ8J0B1900043 Mileage: 25550km-15876miles
03- Brakes -- Status: OK 0000
Address 01: Engine (CEP) Labels: 07K-907-404-CEP.clb
Part No SW: 8J0 907 404 F HW: 8J0 907 404
Component: 2.5l R5/4V TFSI 0010
Revision: F4H05--- Serial number: AUX7Z0J4FNH067
Coding: 0113000C180F0160
Shop #: 01236 785 00200
VCID: 306F2ED8A3AA8ABEE6-8065
Address 03: Brakes Labels: 8J0-614-517.clb
Part No SW: 8J0 910 517 HW: 8J0 614 517 C
Component: ESP MK60E1 0010
Revision: 00H60001
Coding: 0618391
VCID: 69D983BC40F03B76E1-803D
Address 08: Auto HVAC Labels: None
Part No SW: 8J0 820 043 BA HW: 8J0 820 043 BA
Component: J255 Klima 1 Zone 0110
Revision: 00H09006 Serial number: 00000001152826
Coding: 1573957
VCID: 66C3888051EE140ECC-8033
Address 09: Cent. Elect.
Address 10: Park/Steer Assist (J446) Labels: 8P0-919-475-7X1.clb
Part No SW: 8P0 919 475 G HW: 8P0 919 475
Component: PARKHILFE 4K H06 0120
Revision: 11001001 Serial number: 93641013419135
Coding: 00000B
Shop #: 01236 758 00200
VCID: 428B7410DD06082E00-8017
Address 14: Susp. Elect. Labels: 8P0-907-376.lbl
Part No SW: 8J0 910 376 E HW: 8J0 907 376 E
Component: J250 Raddaempfung 0110
Revision: --H22--- Serial number: 190DPH 0110378
Coding: 0000072
VCID: 31692BDCA8A083B6E9-8065
Address 15: Airbags Labels: 8J0-959-655.lbl
Part No SW: 8J0 959 655 HW: 8J0 959 655
Component: -r Airbag 9.43 H03 0020
Revision: 93H03002 Serial number: 0036K004FE2L
Coding: 0011634
VCID: 79F9D3FC30508BF611-802D
Subsystem 1 - Serial number: 6332DRB40B6E0CB1
Subsystem 2 - Serial number: 6342DRB40B6E0BA3$
Subsystem 3 - Serial number: 63747RB4058B1309K
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0004041
VCID: 46836800312E340E2C-8013
Component: E0221 H06 0030
Address 17: Instruments Labels: 8J0-920-xxx-17-MY8.clb
Part No SW: 8J0 920 930 S HW: 8J0 920 930 S
Component: KOMBIINSTR. VDO H01 0580
Revision: D0H01002 Serial number: 2244J002000023
Coding: 0117728
Shop #: 20460 822 999999
VCID: 3C770AE87FE27EDE4A-8069
Address 19: CAN Gateway Labels: 7N0-907-530-V1.clb
Part No SW: 8P0 907 530 A HW: 1K0 907 951
Component: J533 Gateway H33 0302
Revision: H33 Serial number: 210510F2000185
Coding: E9BB1F0650065204004101
Address 20: High Beam Assist. (J844) Labels: 8K0-857-511.clb
Part No SW: 8J0 857 511 G HW: 8J0 857 511 G
Component: H03 0004
Revision: AA002001
Coding: 02028D64747464545425363E
VCID: 346722C897B2B69E82-8061
Address 22: AWD Labels: None
Part No SW: 563 tun ere l HW: 563 tun ere l
Component: Haldex 4Motion T403
Coding: 0000001
Shop #: 00000 000 00000
VCID: 1D31E76CC43817D65D-8049
Revision: D0H01002 Serial number: AUX7Z0J4FNH067
Address 2E: Media Player 3 (R199) Labels: 8T0-035-785.clb
Part No SW: 8P0 035 785 HW: 8P0 035 785
Component: SG ext.Player H08 0100
Revision: 00000000
Coding: 020202
VCID: 74E7E2C8D732F69E42-8021
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8J0 035 193 D HW: 8J0 035 193 D
Component: RNS-E PU EU H04 0200
Revision: 0000010S Serial number: AUZBZ7KD400450
Coding: 0610725
Shop #: 20460 822 173925
VCID: 2B5539B48A8CE966D3-807F
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8J8 959 801 J HW: 8J8 959 801 J
Component: Tuer-SG H04 0101
Coding: 0000605
Shop #: 20460 822 13273
VCID: 448772080712061E32-8011
Part No: 8J0 909 144 J
Component: EPS_ZFLS Kl. 239 3001
Revision: 00H17000
VCID: 377D15C446C45D86A7-8063
Address 46: Central Conv.
Address 47: Sound System (J525) Labels: 8J0-035-223.lbl
Part No SW: 8J0 035 223 F HW: 8J0 035 223 F
Component: Audi TT Amp5K H05 0170
Revision: -------- Serial number: BP208309190387
Coding: 070101060002
Dataset: EV_AudioAmpli5ChannBNO1 003011
ROD: EV_AudioAmpli5ChannBNO1.rod
VCID: 275DC5845E64CD0637-8073
Address 4C: Tire Pressure II Labels: 8J0-907-274.lbl
Part No SW: 8J0 907 274 C HW: 4F0 907 274
Component: J793 RKA+ H02 0190
Revision: 00000813 Serial number: 00008130113299
Coding: 0604100
VCID: 326B24D0ADA6B8AE90-8067
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 8J8 959 802 H HW: 8J8 959 802 H
Coding: 0000605
VCID: 43857114021C01260B-8017
Part No SW: 4L0 910 357 HW: 4L0 907 357
Component: 1 H01 0060
Coding: 0000025
Subsystem 1 - Part No: 8E0 941 329 A
Component: -Modul links H05 0030
Subsystem 2 - Part No: 8E0 941 329 A
Component: -Modul rechtsH05 0030
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0610725
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 8P0 907 534 HW: 1K0 907 951
Component: Batt.regelung H33 0302
Coding: 0302015A
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Part No SW: 8P1 862 335 HW: 8P1 862 335
Component: FSE_256x BT H41 0650
Revision: 00000000 Serial number: 00000005205469
Coding: 0011422
VCID: 74E7E2C81732F69E42-8021
