Hi there,
I'm new to the forum, as well as to VCDS, but i'm always up for learning a new skill when it concerns vehicles, and as we currently have 4 VW stable cars in the family it seemed to make sense to dig a little deeper into how to be able to do a few home maintenance items when the needs arise.
My daughter has a 2011 VW EOS which a couple of months ago developed the typical symptoms of clock spring death - ABS light, no horn, all MFSW buttons dead.
Recognising the symptoms from a previous Seat Alhambra, I started the search for a 2nd hand replacement part from Ebay.
Knowing it would be need to be coded to the vehicle, I've purchased a VCDS interface cable with 10 VIN user capacity for the coding element, and whilst hunting for the replacement part came across a video of a guy adding cruise control to an EOS of the same age, which involved the replacement of the clockspring with a different unit capable of providing the cruise control interface coupled with swapping out the column stalks.
This appeared to be a perfect outcome for my daughters car, not only fixing the clockspring issue but getting an added extra on the side.
Having located an identical clockspring as in the video being sold together with the cruise enabled column stalk set all taken from the same doner car, I set about swapping out the old parts for the new.
I took a baseline scan of the car before I started the dismantle process, and one at the stage I now find myself at, having installed the new parts and coded everything as I believe to be correct, but I have still not got the clockspring issues resolved.
The cruise control aspect is however recognised and working, which has really thrown me as i expected this to only work if the clockspring was coded and recognised.
The issue I have is the scan reveals that the steering column controller returns a 'No Communication ' error
What's even more perplexing is that when I first installed the new parts and took a scan there were 3 faults listing as no communication under the steering column module information : Databus, Powertrain databus, and Steering Wheel controls.
Now having done the coding, 2 of these these errors have been closed out, but I'm still left with the Steering Wheel Controls no communication error??
Any guidance / advice as to where i have gone wrong would be really appreciated.
Scans taken from car are appended below
Original settings:
Settings with new parts fitted prior to coding :
Original settings:
Wednesday,06,September,2023,19:13:14:65142
VCDS Version: 23.3.1.0 (x64) HEX-V2 CB: 0.4631.4
VIN: WVWZZZ1FZBV014209 License Plate: A17XXA
Mileage: 173840km-108019mi Repair Order:
Chassis Type: 1F-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 26 2E 42 44 46 52 56 61 62 72
77
VIN: WVWZZZ1FZBV014209 Mileage: 173840km-108019miles
Address 01: Engine (J623-CFFB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 GA HW: 03L 907 309 N
Component: R4 2.0l TDI H24 9977
Revision: 41H24--- Serial number: CVN: D0187299
Coding: 00190012042501080000
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_ECM20TDI01103L906018GA 003006
ROD: EV_ECM20TDI01103L906018GA_VW36.rod
VCID: 6FBBC14F2712EB12E61-803A
VINID: 9E69EAAAA056A9298004408024F210B4AF
12002 - Particulate Filter; Differential Pressure Sensor
P2453 00 [100] - Implausible Signal
Mileage: 173752 km
Date: 2023.09.06
Time: 15:45:00
Engine RPM: 0.00 /min
Coolant temperature: 83 °C
Intake air temperature: 28 °C
Voltage terminal 30: 12.960 V
Sensor for particle filter differential press: raw value: -201 hPa
Particle filter: difference pressure: -201 hPa
DPF: offset for differential pressure: -74 hPa
Particle filter: differential pressure: dynamic offset: 0 hPa
Outside temperature: 24.0 °C
Particle filter: soot mass measured: -13.94 g
Particle filter: soot mass calculated: 10.93 g
5262 - Particulate Filter; Differential Pressure Sensor
P2454 00 [168] - Short to GND
Fault Frequency: 86
Mileage: 173776 km
Engine RPM: 186.00 /min
Normed load value: 100.0 %
Coolant temperature: 57 °C
Intake air temperature: 36 °C
Voltage terminal 30: 10.740 V
Sensor for particle filter differential press: raw value: -214 hPa
Particle filter: difference pressure: 150 hPa
Particle filter: differential pressure: dynamic offset: -150 hPa
Outside temperature: 22.0 °C
Particle filter: soot mass calculated: 9.83 g
4987 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 00 [101] - Electrical Fault
Mileage: 173682 km
Date: 2023.09.06
Time: 21:22:09
Engine RPM: 1128.50 /min
Normed load value: 89.0 %
Coolant temperature: 14 °C
Intake air temperature: 16 °C
Voltage terminal 30: 12.080 V
Electric auxiliary heater: shut-off conditions-Bits 0-7: 0
Electric auxiliary heater: shut-off conditions-Bits 0-7: 2
Electric auxiliary heater: relay activation-Bits 0-7: 0
Pre-glow time: 1400 ms
Glow status-Bits 0-7: 0
Glow cycles above temperature threshold-Bits 0-7: 0
Glow cycles above temperature threshold-Bits 0-7: 8
Glow cycles below temperature threshold-Bits 0-7: 0
Glow cycles below temperature threshold-Bits 0-7: 4
Outside temperature: 15.0 °C
4714 - Steering Column Control Module
U0212 00 [047] - No Communications
Mileage: 173682 km
Date: 2023.09.06
Time: 21:21:50
Voltage terminal 30: 11.760 V
Limitation: accelerator pedal: 126.7 Nm
Cruise Control System (CCS): status-Bits 0-7: 200
selected gear-Bits 0-7: 0
4891 - EGR Valve (N18)
P0403 00 [109] - Malfunction
Mileage: 173729 km
Date: 2023.09.06
Time: 14:43:01
Engine RPM: 1667.00 /min
Vehicle speed: 106 km/h
Coolant temperature: 82 °C
Intake air temperature: 29 °C
Voltage terminal 30: 14.540 V
Air mass: actual value (mg/stroke): 605.8 mg/stroke
EGR Vacuum Regulator Solen.val.: activation: 15.00 %
EGR Solen.val.: actual value: 97.57 %
EGR valve: offset closed: 5.96 %
Actuator for high pressure EGR: status-Bits 0-7: 0
Actuator for high pressure EGR: status-Bits 0-7: 55
Actuator for high pressure EGR: status-Bits 0-7: 7
Actuator for high pressure EGR: status-Bits 0-7: 4
High press EGR actuator: actual unconditioned volt val: 894.2 mV
Readiness: 1 2 0 0 0
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 563B6008092300FE6A0D06E490220092350000
Shop #: WSC 00020 790 00000
VCID: 76B5F42B58C8DADA257-8022
Part No SW: 5K0 907 044 EA HW: 5K0 907 044 EA
Component: Climatronic H17 1010
Revision: 00003001
Coding: 0000000003
Shop #: WSC 00020 999 00000
VCID: 6E85DC4B2018E21AED7-803A
Part No SW: 5K0 937 086 J HW: 5K0 937 086 J
Component: BCM PQ35 M 011 0046
Revision: BC011001
Coding: 46000A3B8A23F06040080080310081EC47715E08602005606480C7000041
Shop #: WSC 00020 790 12345
VCID: 3B23251F236A47B21A9-806E
Subsystem 1 - Part No: 1Q2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 02031 26 0512
Coding: 009795
Component: RLS 250311 05 54 0403
Coding: 0330CD
Subsystem 3 - Part No: 1Q0 951 177 C
Component: Innenraumuebe 200 0203
Component: LIN BACKUP HO H11 9005
Subsystem 5 - Part No: 1K0 907 719 C
Component: Neigungssenso 005 0003
00924 - Relay for Headlamp Cleaning System (J39)
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 59
Mileage: 173682 km
Date: 2018.01.27
Time: 21:21:56
Voltage: 11.80 V
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 59
Mileage: 173682 km
Date: 2018.01.27
Time: 21:24:13
Voltage: 12.90 V
Address 10: Park/Steer Assist (J446) Labels:| 1Q0-919-475.clb
Part No SW: 1Q0 919 475 HW: 1Q0 919 475
Component: PARKHILFE 4K H02 0005
Revision: -------- Serial number: 32901106204518
Coding: 10C001
ASAM Dataset: EV_EPHVA14VW4650000 001003
ROD: EV_EPHVA14VW4650000.rod
VCID: 75B7F327454ED1C22CD-8020
Address 15: Airbags Labels: 1Q0-959-655.lbl
Part No SW: 1Q0 959 655 B HW: 1Q0 959 655 B
Component: 0Z Airbag VW8C 0210
Revision: 92011021 Serial number: 003G2000HPS5
Coding: 0012378
VCID: 3B23251F2F6A47B21A9-806E
Subsystem 1 - Serial number: 6332SRB40D4A07A32
Subsystem 2 - Serial number: 6342SRB40D4A108B3
Subsystem 3 - Serial number: 637 RB4 8
Subsystem 4 - Serial number: 638 RB4 9
Fault Status: 11100001
Mileage: 173682 km
Date: 2018.01.27
Time: 21:21:58
Part No SW: 1K5 953 521 AH HW: 5K0 953 569 A
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20110328300330
Coding: 0082040000
ROD: EV_SMLSNGVOLWS.rod
VCID: 73B3CD3F4B3ACFF2029-8026
365080 - Controls in Steering Wheel
U108E 00 [009] - No Communications
Reset counter: 66
Mileage: 173847 km
Date: 2023.09.06
Time: 00:01:28
Part No SW: 1Q0 920 975 A HW: 1Q0 920 975 A
Component: KOMBI H20 0420
Coding: 471F01
VCID: 33330D3F0BBA8FF2C29-8066
Part No SW: 7N0 907 530 D HW: 1K0 907 951
Component: J533 Gateway H35 0614
Revision: H35 Serial number: 090411F2000028
Coding: 355001
VCID: 313F0737F126BDE2B05-8064
Component: IMMO H20 0420
VCID: 6A8DD05B1CF00E3AB1F-803E
Address 26: Auto Roof Labels: 1Q0-959-255.clb
Part No SW: 1Q0 959 255 F HW: 1Q0 959 255 F
Component: Verdecksteuergeraet 0854
Revision: 0033100Q Serial number: 110750137
Coding: 0655374
Part No SW: 5N0 035 342 D HW: 5N0 035 342 D
Revision: A1001003 Serial number: 7669689665
VCID: 2809EA53C2FCFC2A67B-807C
Part No SW: 1Q0 959 701 H HW: 1Q0 959 701 H
Component: Tuer-SG 009 2152
Coding: 0152247
VCID: 392F3F17255675A2085-806C
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 70 3201
Revision: 00H20000
VCID: 34310E23023488CADB3-8060
000 - - - MIL ON
Fault Status: 11100000
Battery Volts: 12.7 V
PD
Temperature: 53.0°C
Count: 2
Steering Angle: 0.00°
Count: 1
SteerAng n.Init
Part No SW: 1Q0 959 702 H HW: 1Q0 959 702 H
Coding: 0152502
VCID: 3A2D201B20507EBA01F-806E
Part No SW: 1K0 035 186 AA HW: 1K0 035 186 AA
Component: Radio RCD310 016 0049
Revision: 01000000 Serial number: VWZ1Z2L9215649
Coding: 0100040004
VCID: 6597A367F56E21429CD-8030
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H35 0614
Coding: 030B185A
VCID: 71BFC73731A6FDE2F05-8024
Subsystem 1 - Part No SW: 1K0 915 181 F HW: 1K0 915 181 A
Component: J367-BDM H07 0150
Serial number: 00000000009370138555
02256 - Quiescent Current
Fault Status: 00110001
Reset counter: 105
Mileage: 173682 km
Date: 2018.01.27
Time: 02:45:25
Part No SW: 1Q0 959 811 B HW: 1Q0 959 811 B
Component: Tuer-SG 004 0602
Coding: 0131216
Shop #: WSC 00020 790 1012544
VCID: 35373327094E91C2ECD-8060
Part No SW: 1Q0 959 812 B HW: 1Q0 959 812 B
Coding: 0131216
VCID: 3635342B14489ADAE57-8062
Part No SW: 5K0 035 730 B HW: 5K0 035 730 B
Component: TELEFON H09 1020
Revision: 1B001001 Serial number: 00007669599329 Dataset Number: 5K0035730B 0001
Coding: 0A01000000010101
ASAM Dataset: UHVNA A01009
ROD: UHVNA.rod
VCID: 2411FE63BE54184A4B3-8070
End----------(Elapsed Time: 01:47, VBatt start/end: 12.5V/12.4V)-----------
Thursday,31,August,2023,21:30:32:65142
Mileage: 173680km-107919mi Repair Order:
77
VIN: WVWZZZ1FZBV014209 Mileage: 173680km-107919miles
Mileage: 173682 km
Date: 2023.08.31
Time: 21:22:09
U0212 00 [039] - No Communications
Mileage: 173682 km
Date: 2023.08.31
Time: 21:21:50
Revision: 00H31001
Revision: 00003001
Coding: 0000000003
Revision: BC011001
Coding: 009795
Coding: 0330CD
Reset counter: 59
Mileage: 173682 km
Date: 2018.01.21
Time: 21:21:56
Voltage: 11.80 V
Reset counter: 59
Mileage: 173682 km
Date: 2018.01.21
Time: 21:24:13
Voltage: 12.90 V
Coding: 10C001
Coding: 0012378
Mileage: 173682 km
Date: 2018.01.21
Time: 21:21:58
Part No SW: 5K0 953 569 AL HW: 5K0 953 569 AL
Component: LENKS.MODUL 016 0180
Revision: --X01--- Serial number: 20151218100495
Coding: 0382140008
VCID: 025D98FB0480F67A19F-8056
97284 - Databus
Reset counter: 59
Mileage: 173682 km
Date: 2023.08.31
Time: 21:21:56
335876 - Powertrain Databus
U0002 00 [009] - No Communications
Reset counter: 59
Mileage: 173682 km
Date: 2023.08.31
Time: 21:21:56
Reset counter: 59
Mileage: 173682 km
Date: 2023.08.31
Time: 21:21:56
1140738 - Steering angle sensor
Reset counter: 59
Mileage: 173682 km
Date: 2023.08.31
Time: 21:21:56
UBat: 11.90 V
MC1 interner Fehlercode: 0
MC2 interner Fehlercode: 0
Coding: 471F01
Coding: 355001
Coding: 0655374
Coding: 0152247
Revision: 00H20000
Coding: 0152502
Coding: 0100040004
Coding: 030B185A
Coding: 0131216
Coding: 0131216
ROD: UHVNA.rod
End----------(Elapsed Time: 01:54, VBatt start/end: 12.4V/12.1V)-----------
Settings after coding of new parts
Wednesday,20,September,2023,17:57:57:65142
Mileage: 174130km-108199mi Repair Order:
77
VIN: WVWZZZ1FZBV014209 Mileage: 174130km-108199miles
Revision: 00H31001
Revision: 00003001
Coding: 0000000003
Revision: BC011001
Coding: 009795
Coding: 0330CD
Reset counter: 69
Mileage: 173847 km
Date: 2018.02.10
Time: 00:04:14
Voltage: 12.40 V
Fault Status: 00101010
Reset counter: 106
Mileage: 173847 km
Date: 2018.02.10
Time: 00:04:18
Voltage: 12.35 V
Coding: 10C001
Coding: 0012378
Mileage: 174138 km
Date: 2018.02.10
Time: 17:53:53
Coding: 0082140000
ASAM Dataset: EV_SMLSNGVOLWS A01004
Reset counter: 71
Mileage: 174138 km
Date: 2023.09.20
Time: 17:53:18
Coding: 471F01
Coding: 355001
Coding: 0655374
Coding: 0152247
Revision: 00H20000
Coding: 0152502
Coding: 0100040004
Coding: 030B185A
Fault Frequency: 12
Reset counter: 110
Mileage: 173897 km
Date: 2018.02.10
Time: 08:19:15
Coding: 0131216
Coding: 0131216
ROD: UHVNA.rod
End----------(Elapsed Time: 01:52, VBatt start/end: 12.4V/12.3V)-----------
