I have changend the abs module
MaxxLetlotlo
Botswana
C?ID=522582
Tuesday,19,September,2023,19:03:15:39152
VCDS Version: 23.3.1.0 (x64)  HEX-NET2 CB: 0.4631.5
VIN: WAUZZZ8P19A151811   License Plate:
Chassis Type: 8P-AU35 (1K0)
Scan: 01 02 03 08 09 11 31 15 16 17 19 25 42 44 46 47 52 55 62 72
          76
VIN: WAUZZZ8P19A151811   Mileage: 218690km-135887miles
03-ABS Brakes -- Status: Not registered 0011
11-Engine II -- Status: Cannot be reached 1100
31-Engine other -- Status: Cannot be reached 1100
76-Park Assist -- Status: Cannot be reached 1100
Address 01: Engine (CAX)       Labels: 03C-906-016-CAX.clb
   Part No SW: 03C 997 016 A    HW: 03C 906 016 F
   Component: MED17.5.5           8016
   Revision: LCH04---    Serial number: AUX7Z0I3FNU05V
   Coding: 0000077
   Shop #: WSC 77840 741 95481
   VCID: 2700947FE3E49B326E1-8072
   VINID: 9D196AAAA22004944114120104B1CAD96E
10 Faults Found:
049441 - No Communication with ABS Brake Control Module
               U0121 - 000 -  - Intermittent
                    Mileage: 217818 km
                    Date: 2023.08.30
                    Time: 14:48:45
                    RPM: 789 /min
                    Load: 16.9 %
                    Temperature: 78.0°C
                    Temperature: 49.0°C
                    Absolute Pres.: 900.0 mbar
                    Voltage: 13.589 V
005161 - Circuit for Brake Vacuum Pump
               P1429 - 000 - Open Circuit
                    Mileage: 217818 km
                    Date: 2023.08.30
                    Time: 14:48:45
                    RPM: 784 /min
                    Load: 16.9 %
                    Temperature: 78.0°C
                    Temperature: 49.0°C
                    Voltage: 13.716 V
006418 - Pressure Sensor for Brake Boost (G294)
               P1912 - 000 - Short to Plus
                    Mileage: 217818 km
                    Date: 2023.08.30
                    Time: 14:48:45
                    RPM: 784 /min
                    Load: 16.9 %
                    Temperature: 78.0°C
                    Temperature: 49.0°C
                    Voltage: 13.716 V
049153 - Powertrain Databus
               U0001 - 000 - Unspecified Malfunction - Intermittent
                    Fault Frequency: 42
                    Mileage: 218463 km
                    Date: 2023.09.12
                    Time: 17:59:16
                    RPM: 1371 /min
                    Load: 23.1 %
                    Speed: 31.0 km/h
                    Temperature: 77.0°C
                    Temperature: 39.0°C
                    Absolute Pres.: 910.0 mbar
                    Voltage: 13.970 V
049478 - No Communication with Diagnostic Gateway
               U0146 - 000 -  - Intermittent
                    Mileage: 218463 km
                    Date: 2023.09.12
                    Time: 18:01:28
                    RPM: 644 /min
                    Load: 16.9 %
                    Temperature: 86.0°C
                    Temperature: 38.0°C
                    Voltage: 13.716 V
049508 - No Communications with HVAC Control Module (J301)
               U0164 - 000 -  - Intermittent
                    Mileage: 218463 km
                    Date: 2023.09.12
                    Time: 18:01:30
                    RPM: 652 /min
                    Load: 16.9 %
                    Temperature: 86.0°C
                    Temperature: 38.0°C
                    Voltage: 13.462 V
               U0155 - 000 -  - Intermittent
                    Mileage: 218463 km
                    Date: 2023.09.12
                    Time: 18:01:33
                    RPM: 657 /min
                    Load: 15.3 %
                    Temperature: 86.0°C
                    Temperature: 38.0°C
                    Voltage: 13.716 V
049409 - No Communication with Transmission Control Module
               U0101 - 000 -  - Intermittent
                    Mileage: 218463 km
                    Date: 2023.09.12
                    Time: 18:01:35
                    RPM: 654 /min
                    Load: 14.9 %
                    Temperature: 86.0°C
                    Temperature: 38.0°C
                    Voltage: 13.589 V
               U1017 - 000 -  - Intermittent
                    Mileage: 218506 km
                    Date: 2023.09.14
                    Time: 17:22:27
                    Temperature: 69.0°C
                    Temperature: 42.0°C
                    Voltage: 12.065 V
                    Mileage: 218506 km
                    Date: 2023.09.14
                    Time: 17:22:38
                    Temperature: 69.0°C
                    Temperature: 42.0°C
                    Voltage: 12.065 V
   Part No SW: 0AM 300 048 L    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 2669
   Revision: 00043014    Serial number: CU501412156484
   Shop #: WSC 55587 001 1048576
   VCID: 3924420705501DC2085-806C
   Revision: 00H31001
   Shop #: WSC 06314 000 00000
   VCID: 76BE893B78CEB2BA257-8022
                    Reset counter: 172
                    Date: 2023.09.14
                    Time: 02:12:59
                    Count: 3
                    Count: 12
                    Count: 20992
                    Count: 195
                    Count: 47872
                    Fault Status: 01100101
                    Reset counter: 172
                    Mileage: 218506 km
                    Date: 2023.09.14
                    Time: 02:11:17
                    Count: 3
                    Count: 14
                    Count: 29184
                    Count: 279
                    Count: 47872
                    Count: 256
                    Reset counter: 172
                    Mileage: 218506 km
                    Date: 2023.09.14
                    Time: 02:11:17
                    Count: 3
                    Count: 14
                    Count: 29184
                    Count: 295
                    Count: 47872
                    Count: 256
                    Reset counter: 172
                    Mileage: 218506 km
                    Date: 2023.09.14
                    Time: 02:11:17
                    Count: 3
                    Count: 14
                    Count: 29184
                    Count: 270
                    Count: 47872
                    Count: 256
00150 - Plausibility Brake Booster System
                    Reset counter: 172
                    Mileage: 218506 km
                    Date: 2023.09.14
                    Time: 02:11:18
                    Count: 3
                    Count: 14
                    Count: 29184
                    Count: 398
                    Count: 47616
   Part No SW: 8P0 820 043 BG    HW: 8P0 820 043 BG
   Component: KlimavollautomatH09 0100
   Revision: 000183      Serial number: 8P0820043BG
   VCID: 72B6B52B18A6AE9A09F-8026
Address 09: Cent. Elect.        Labels:. 8P0-907-279-30-H.lbl
   Part No SW: 8P0 907 279 N    HW: 8P0 907 279 N
   Component: Bordnetz-SG     H54 2801
   Revision: 00H54000    Serial number: 00000009616144
   Coding: E18E1F81B0141380EF00000A0000000000094E056406040364A000000000
   Shop #: WSC 06314 000 08192
   VCID: 48C237C34EBA744A87B-801C
   Subsystem 1 - Part No: 8P2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350   H10 0040
   Coding: 00056595
   Shop #: WSC 06314
   Coding: 00150573
   Shop #: WSC 06314
Address 11: Engine II
Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 J    HW: 8P0 959 655 J
   Component: Airbag AU1042 H06 0090
   Revision: --------    Serial number: 003CA006FVKB Dataset Number: 8P0909602L  0002
   Coding: 303142383038303030384A55305238503053
   ROD: EV_Airba10AURB4_AU35.rod
   VCID: 49C432C759308D42985-801C
   Serial number: 3572DRB4000068110B3G
   Serial number: 3582DRB400006808F24U
   Serial number: 35128RB400004D201DDL
   Serial number: 35228RB400004D1D363J
   Serial number: 35547RB400004D687F1Y
   Serial number: 35647RB400004D68793V
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Component: J0527           H36 0070
   Coding: 0012012
   VCID: 41D42AE76D804502405-8014
   Component: E0221           H02 0030
01304 - Radio
   Part No SW: 8P0 920 931 T    HW: 8P0 920 931 T
   Component: KOMBIINSTR. VDO H20 0860
   Revision: D0H20008    Serial number: 2243I008055003
   Coding: 0000928
   Shop #: WSC 14080 668 435878
   VCID: 44DA23F37292502A6B3-8010
   Part No SW: 1K0 907 530 S    HW: 1K0 907 951
   Component: J533__Gateway   H16 0210
   Revision:   H16       Serial number: 3400K095040B57
   Coding: E7817F0E100002002103
   Shop #: WSC 80093 222 69422
   VCID: 3720443F33440BB2FE1-8062
01342 - Engine Control Module 2 (Slave 1)
                    Reset counter: 177
                    Mileage: 218693 km
                    Date: 2023.09.18
                    Time: 06:28:26
01327 - Control Module for Parking Aid (J446)
                    Reset counter: 177
                    Mileage: 218693 km
                    Date: 2023.09.18
                    Time: 06:28:30
                    Reset counter: 177
                    Mileage: 218693 km
                    Date: 2023.09.18
                    Time: 06:28:31
   Revision: D0H20008    Serial number: AUX7Z0I3FNU05V
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MAX3.lbl
   Part No SW: 8P0 959 801 J    HW: 8P0 959 801 J
   Component: Tuer-SG         H03 0060
   Coding: 0004788
   VCID: 42D625EB68865E1A59F-8016
01706 - Switch for Mirror-Adjust (E43)
   Part No: 1K0 909 144 E
   Component: EPS_ZFLS Kl. 232    2501
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
   VCID: 2C0A6B53FA02B86A833-8078
Address 46: Central Conv.        Labels: 8P0-959-433.lbl
   Part No: 8P0 959 433 K
   Component:    KSG          H11 0080
   Coding: 1880200002186D0985054C9F0167
Address 47: Sound System        Labels: 8Px-035-382.lbl
   Part No SW: 8P4 035 382 E    HW: 8P4 035 382 E
   Component: AB2 SUBWOOFERBOXH07 0180
   Revision: 00006       Serial number: 92158949029772
   VCID: 363E493B344EF2BAE57-8062
   Part No SW: 8P0 959 802 J    HW: 8P0 959 802 J
   Coding: 0004788
   VCID: 43D820EF779C5712529-8016
00097 - Front Passengers Central Locking (Safe) Motor (V162)
   Part No: 8P3 907 357
   Coding: 0000013
   VCID: 7AA69D0B40D6D6DA41F-802E
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No SW: 8P4 959 801 E    HW: 8P4 959 801 E
   Component: Tuer-SG         H04 0040
   Coding: 0000144
   Shop #: WSC 06314 000 1012544
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No SW: 8P4 959 802 E    HW: 8P4 959 802 E
   Coding: 0000144
Address 76: Park Assist
End----(Elapsed Time: 01:17, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
I'll be back in the form of an edit if I can locate any good baselines from the Japanese market.
Edit; If WAUZZZ8P19A151811 matches the car I believe it was born with 1K0 907 379 AE. That would make the direct replacement path: 1K0 907 379 AP > 1K0 907 379 AJ
Please verify the VIN in the scan is correct. If so, I do not believe the direct replacement unit was installed.
However, if I base the coding off of the installed 2011 M.Y. ABS control module part number I come up with:
13424012092700FBC81302E5901A0080390000
The Replacement steps on this page apply:
Vehicle Identification No. WAUZZZ8P19A151811
Model Audi A3 Sportback 1.4 A3
Date of production 15.05.2009
Year 2009
Sales type 8PAABG
Engine Code CAXC
Transmission Code LKM
G1C 7-speed automatic transmission
L0R Right-hand drive
B29 Type approval country Japan
0YF Weight range 6 installation control only, no requirement forecast
1N3 Speed-related variable steering assist (Servotronic)
2UA Standard design
1ZE Disc brakes in front (Geomet D)
1KD Disc brakes in rear
UG1 Hill start assist
7K0 Without tyre pressure monitor
Boki Ar
Arandjelovac, Serbia
C?ID=57300
The gentlemen maybe wish :cool:
:D
