SEAT_problems_NorthEU
Hello!
I'm new to this forum and have yet to purchase the HEX-V2 cable, I'm planning on buying it but there's only one issue that concerns me. I plan on using my Windows 10 tablet (http://support.linxtablets.com/Products/Linx1020/) with a USB-port and also have it connected to the cars cigarette outlet incase the battery dies while I'm diagnosing the car.
Apparently, charging a laptop/tablet while being plugged into the car can cause something known as a "ground loop", I've researched this and as far as I understand it ground loop is essentially when two ground points with different potentials make a connection allowing voltage and current to flow between them, this seems to really only be an issue that pertains to audio systems as far as I can tell. Reading Ross-techs website they don't advice using universal laptop 12V laptop chargers for this reason but I'm planing on just using a micro-USB cable connected to the cigarette outlet with a normal charger like this .
The question is, can charging my tablet from the cigarette outlet of the car with a micro-USB cable cause a ground loop if I'm also using VCDS? If yes, how do I prevent this? do I buy a different charger or do I simply charge and work on the car at different times? I suppose I could just bring with me a bunch of battery powerbanks but I'd rather just use the cars outlet if possible.
Just for reference, the car I'm working on is my personal vehicle which is a SEAT Ibiza 6l model year 2004 with a 1,4 petrol engine. I live in an apartment and don't really have access to a wall outlet nearby as my car is parked in a local garage.
