2004 Jetta TDI Sedan Central Convenience Control Module issues
Dango09
California, USA
C?ID=561863
Afternoon, I'm Dan and this is my first post here on the forum. I have a 2004 Jetta TDI Sedan that's having issues with door locking modules locking/unlocking (with the fob and without). I can unlock 3 of the doors from inside with the fob (the pass rear will need the lock module replaced) but I have to lock the car from the outside by clicking the lock button above the steering wheel or it won't respond. It does all this with different fobs with fresh batteries too. So, I got the Hex-V2 to try and figure it out. So, this is what i've come up with. Do I need to replace all the door control modules or just the central convenience control module?
Monday,18,September,2023,14:01:30:20611
VCDS Version: 23.3.1.0 (x64)  HEX-V2 CB: 0.4631.4
VIN: 3VWSR69M44M144013   License Plate:
Mileage: 296540km-184261mi   Repair Order:
Chassis Type: 9M (9M - VW Jetta IV (1998 > 2014))
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
          75 76
VIN: 3VWSR69M44M144013   Mileage: 296540km-184261miles
Address 01: Engine        Labels: 038-906-016-BEW.lbl
   Part No SW: 038 906 016 H    HW: 028 101 114 6
   Component: R4 1,9L EDC G000SG  6327
   Revision: 12345678    Serial number: VWZ7Z0D9547947
   Coding: 0150031
   Shop #: WSC 66565 257 00032
   VCID: 196FDC41558CBAF2E85-5184
   VINID: 0E69E388625D1047411040010C4D6C4B55
Address 03: ABS Brakes        Labels: 1C0-907-37x-ABS.lbl
   Part No: 1C0 907 379 L
   Component: ABS FRONT MK60      0101
   Coding: 0004097
   Shop #: WSC 00066 000 00000
   VCID: 33330EE9D72060A2C29-5184
   Part No: 1C0 909 605 F
   Component: 04 AIRBAG VW61 0202 0003
   Coding: 12340
   Shop #: WSC 00066
   VCID: 270BEAB916F81C026E1-5160
   Part No: 1J5 920 906 Q
   Component: KOMBI+WEGFAHRSP VDO V55
   Coding: 15232
   VCID: 3B2326C9FA70A8E21A9-5160
   3VWSR69M44M144013     VWZ7Z0D9547947
01304 - Radio
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 00066
   VCID: 70B9C1E5E3B61BBAFFB-5160
01304 - Radio
   Part No: 1C0 959 799 C
   Component: 1H Komfortger t HLO 0003
   Coding: 00258
   Shop #: WSC 00066
   VCID: 372B3AF9C6588C82FE1-4B1E
   Component: 1H T rsteuer.FS KLO 0202
   Component: 1H T rsteuer.BF KLO 0202
   Component: 1H T rsteuer.HL KLO 0202
   Component: 1H T rsteuer.HR KLO 0202
7 Faults Found:
00912 - Window Regulator Switch; Front Left (E40)
            37-00 - Faulty
            37-00 - Faulty
            37-00 - Faulty
            37-00 - Faulty
            27-00 - Implausible Signal
Address 56: Radio        Labels: 3B7-035-1xx-56.lbl
   Part No: 3B7 035 180 G
   Component:    Radio ZSW        0016
   Coding: 00031
   Shop #: WSC 00066
   VCID: 2411FDB567CEF71A4B3-5160
End----------(Elapsed Time: 05:20, VBatt start/end: 12.1V/12.1V)-----------
Dango09
California, USA
C?ID=561863
If I get another central convenience module (with part numbers matching) can I copy the info from the old one in the car and program the replacement?
Yes, but be careful. The part number alone on these (like "1C0 959 799 C") is not a complete spec. There's also an "Index" or "Color Code". Yours is "1H". So a compete spec would be "1C0959799C /01H". And as general rule, the Index isn't actually printed on the label of the module, so if you're looking at used parts, it can be a real crap-shoot.
Dango09
California, USA
C?ID=561863
Thank you very much Uwe. I found one on ebay, here are the numbers on that module.
1CO 959 799 C
ZM max 5DK 008 214-10 I 23304 :H01/S0004
The one that's in the car is:
1CO 959 799 C
ZM max 5DK 008 214-10 I 11104 :H01/S0003
I'm guessing that won't work.
Dango09
California, USA
C?ID=561863
Ok, im willing to try it for science. So, how do i copy the old ones info to the replacement?
EuroX
Northern NJ USA
C?ID=208579
Should be pretty simple in that car. IF anything I think adaption is just a vin transfer if anything and then adding the remotes via channel 21 IIRC.
Dango09
California, USA
C?ID=561863
So, when I look up 00258 it brings up "Solenoid Valve 1 (N88)". A google search gives me "N88 automatic transmission solenoid". I have a 5 speed manual.
Dango09
California, USA
C?ID=561863
Dango09
California, USA
C?ID=561863
Alright. I just cleared the codes, installed the new (to me) Ebay convenience module and here are the results.
I'm still having the same issues with having to have the fob directly above the steering wheel when I'm locking the vehicle from the outside. I programmed the key following the coding instructions and put a new battery in the fob. The car starts and all the windows and sunroof work. I can also lock and unlock the doors with the fob while inside. But it still won't lock from anywhere around the car, except above the steering wheel, and I can't do the double unlock button tap to unlock the doors. Any ideas?
Friday,22,September,2023,14:07:13:20611
Mileage: 296980km-184534mi   Repair Order:
          75 76
VIN: 3VWSR69M44M144013   Mileage: 296980km-184534miles
   Coding: 0150031
   Coding: 0004097
   Coding: 12340
   Shop #: WSC 00066
   Coding: 15232
01304 - Radio
   Coding: 00006
   Shop #: WSC 00066
01304 - Radio
   Component: 08 Komfortger t HLO 0004
   Coding: 00258
   Shop #: WSC 00028
   Coding: 00031
   Shop #: WSC 00066
End----------(Elapsed Time: 05:15, VBatt start/end: 12.2V/12.1V)-----------
