G85 Calibration on 2016 VW Tigaun S
narrab
Savannah, USA
C?ID=421565
I replaced the slip ring on a 2016 Tiguan S with a factory new VW slip ring. I am unable to get the angle sensor to work. When trying to follow the procedure in VCDS to zero the angle sensor in ABS Basic settings I get an error in the box after selecting go. Any ideas what I could be doing wrong? I am using the latest version of VCDS.
Bruce
Near Philadelphia, PA, USA
In order for us to know about your car, we ask all to post an autoscan from the car. It gives us context to answer your question.
Don't know how? See the blue bar at the top of the page - specifically the "How To" drop down menu.
narrab
Savannah, USA
C?ID=421565
thanks you Bruce,
Here is the autoscan.
I appreciate any help that you can provide on how to calibrate the G85 steering angle sensor
Monday,18,September,2023,08:17:39:27047
VCDS Version: 23.3.1.0 (x64)  HEX-V2 CB: 0.4631.4
VIN: WVGAV7AX0GW536959   License Plate:
Mileage: 144450km-89757mi   Repair Order:
Chassis Type: AX-VW36 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 42 44 46 4C 52 53 5F 62
          72
VIN: WVGAV7AX0GW536959   Mileage: 144450km-89757miles
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 06J 906 027 JN    HW: 06J 907 309 A
   Component: MED17.5.2 TFSI 2 07 1334
   Revision: P3H08---    Serial number:
   Coding: 0423010A19070160
   VCID: 00598B095605997A0FB-8054
   VINID: 9E65D19874680179C50C624524AB423AC9
Readiness: 1110 0101
   Part No SW: 09G 927 750 NK    HW: 09G 927 750 NK
   Component: AQ 250 6F           2627
   Revision: 00H97000    Serial number:
   Coding: 0000840
   VCID: 074B9015732BAE424E1-8052
   Part No SW: 5N0 614 109 BN    HW: 5N0 614 109 BN
   Component: J104   C6 450M VDF2 0021
   Revision: --H07---    Serial number: 00000008977116
   Coding: 0005158
   VCID: 78A9E3E90ED5D1BA37B-802C
                    Reset counter: 242
                    Mileage: 144450 km
                    Date: 2018.02.08
                    Time: 11:15:35
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 14.00 V
                    Bin. Bits: 00011110
                    Count: 191
                    Hex Value: 0x0000
                    Reset counter: 242
                    Mileage: 144450 km
                    Date: 2018.02.08
                    Time: 11:15:35
   Part No SW: 5K0 959 434 E    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1202
   Revision: 00092000    Serial number: 0378673274 Dataset Number: 5N0116v____ 0002
   Coding: 030C0C
   VCID: 372B20D54FCB1EC2FE1-8062
   Part No SW: 561 907 426 G    HW: 561 907 426 G
   Component: AC Manuell    H03 0506
   Revision: 00001K02
   Coding: 0010001002
   ROD: EV_ACManuaElectGen2BHTC_VW36.rod
   VCID: 1F1BE875C73B4682161-804A
   Part No SW: 5K0 937 084 N    HW: 5K0 937 084 N
   Component: BCM PQ35 B    122 0183
   Revision: BG122001
   Coding: EF1A0A1B80232EC4008800C11400044448510086566D8DF064800000A040
   VCID: 3D2732FD6D77349224D-8068
   Subsystem 1 - Part No SW: 5N1 955 119 B    HW: 5N1 955 119 B  Labels: 1KX-955-119.CLB
   Component: WWS316 290715  24  0664
   Coding: 009795
   Component: RLS 090915 05  54  0403
   Coding: 02304D
   Part No SW: 5N0 959 655 AB    HW: 5N0 959 655 AB
   Component: J234__005 VW10 HI   5418
   Revision: 36023000    Serial number: 003MAPJF618N
   Coding: 0012341
   VCID: 7DA7F2FD21F7F49264D-8028
   Subsystem 1 - Part No: 5N0 959 339 B
   Subsystem 2 - Serial number: 0000000000R4FP
   Subsystem 3 - Serial number: 0008.07.150000300000650073ˇÜ63
   Subsystem 4 - Serial number: 650073ˇÜ6332MTS618162235+ˇÜ63
   Subsystem 5 - Serial number: 62235+ˇÜ6342MTS6456222350ˇÜ63
   Subsystem 6 - Serial number: 222350ˇÜ6351HTS628FVSDKJGˇÜ63
   Subsystem 7 - Serial number: VSDKJGˇÜ6361HTS6692NRDKR8ˇÜ63
   Subsystem 8 - Serial number: NRDKR8ˇÜ63727TS672U6RDKJ/ˇÜ63
   Subsystem 9 - Serial number: 6RDKJ/ˇÜ63827TS68E57RDKR ˇ
   Subsystem 10 - Serial number: 7RDKR ˇ
   Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
   Revision: --X01---    Serial number: 20230224200374
   Coding: 1102140000
   Shop #: WSC 01286 386 08256
   VCID: 025D810154898B6A19F-8056
   Serial number: 0883123
   Coding: 820000
1140738 - Steering angle sensor
                    Reset counter: 242
                    Mileage: 144450 km
                    Date: 2023.09.18
                    Time: 11:15:58
                    UBat: 14.20 V
                    MC1 interner Fehlercode: 0
                    MC2 interner Fehlercode: 0
   Part No SW: 5N0 920 973 L    HW: 5N0 920 973 L
   Component: KOMBI         H04 1008
   Coding: 211F010000
   VCID: 3D2732FD6DF7349224D-8068
   Part No SW: 7N0 907 530 AT    HW: 7N0 907 530 AK
   Component: J533  Gateway H57 1663
   Revision:   H57       Serial number: 220815F1002099
   Coding: 356022
   VCID: 025D810154098B6A19F-8056
   Component: IMMO          H04 1008
   Coding: 000007
   VCID: 6A8DC9A14CF9732AB1F-803E
   Revision: 00000000    Serial number: 15000195715008
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 30391BC9AAA5C9FABFB-8064
   Part No SW: 5N0 959 701 F    HW: 3C0 959 793 B
   Component: TUER-SG FT    002 0503
   Revision: 13110009    Serial number: 0010013960
   Coding: 0004B4
   VCID: 382923E942D511BAF7B-806C
   Slave Driver:
   Subsystem 1 - Part No SW: 5N0 959 703 G    HW: 3C0 959 794 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  010 1505
   Serial number: 00000009924221
   Coding: 00A090
          B11EC 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 239
67589 - Turn Signal in Exterior Mirror
          B11FD 01 [009] - Electrical Failure
                    Reset counter: 215
                    Mileage: 143126 km
                    Date: 2023.09.04
                    Time: 19:40:45
131075 - Rear Door Control Module
          B11ED F2 [009] - Not Coded
                    Reset counter: 215
                    Mileage: 143126 km
                    Date: 2023.09.04
                    Time: 19:40:43
   Part No SW: 5N1 909 144 R    HW: 5N1 909 148 J
   Component: J500__APA-BS KL.285 1401
   Revision: 1BH04841    Serial number: 00152380298801
   Coding: 0000258
   VCID: 41DF4E0D1D8F5072405-8014
02546 - Steering Limit Stop
                    Fault Status: 11100101
                    Reset counter: 242
                    Mileage: 144450 km
                    Date: 2018.02.08
                    Time: 11:13:32
                    RPM: 796 /min
                    (no units): 7.0
                    Voltage: 14.10 V
00566 - Steering Assistance Operation
            008 - Implausible Signal - MIL ON
                    Fault Status: 11101000
                    Reset counter: 242
                    Mileage: 144450 km
                    Date: 2018.02.08
                    Time: 11:13:32
                    Hex Value: 0x7301
                    Hex Value: 0x7601
                    Hex Value: 0x7301
                    Hex Value: 0x7601
                    Hex Value: 0x7301
                    Reset counter: 242
                    Mileage: 144450 km
                    Date: 2018.02.08
                    Time: 11:13:32
                    (no units): 7.0
                    Steering Angle: 0.00∞
                        Not OK
                    (no units): 9
   Part No SW: 5N0 959 702 F    HW: 3C0 959 792 B
   Component: TUER-SG BT    002 0503
   Revision: 15110009    Serial number: 0009991031
   Coding: 0004B4
   VCID: 392F26ED79DF08B2085-806C
   Slave Passenger:
   Subsystem 1 - Part No SW: 5N0 959 704 G    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  010 1505
   Serial number: 00000009522668
   Coding: 000490
   Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
   Component: J540 EPB4  VW-63206 0012
   Revision:   H19       Serial number: 00000000842595
   Coding: 0026156
   VCID: 382923E94E5511BAF7B-806C
   Part No SW: 561 035 150     HW: 561 035 150
   Component: MU-E--US      857 6495
   Serial number: 03091500010618 Dataset Number: 5K7CV1v____ 0001
   Coding: 02130600FF00000041220001001000001F0000D40000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001025
   ROD: EV_MUEnt4CGen2LGE_VW32.rod
   VCID: 4ACD69212C39932A91F-801E
End----------(Elapsed Time: 01:20, VBatt start/end: 14.1V/14.1V)-----------
Monday,18,September,2023,08:30:54:27047
          72
   Coding: 0000840
   Component: J104   C6 450M VDF3 0021
   Coding: 0005158
                    Reset counter: 243
                    Mileage: 144450 km
                    Date: 2018.02.08
                    Time: 11:15:35
                    Hex Value: 0x0000
                    Voltage: 14.00 V
                    Bin. Bits: 00011110
                    Count: 191
                    Hex Value: 0x0000
                    Reset counter: 243
                    Mileage: 144450 km
                    Date: 2018.02.08
                    Time: 11:15:35
   Coding: 030C0C
   Revision: 00001K02
   Coding: 0010001002
   Revision: BG122001
   Coding: 009795
   Coding: 02304D
                    Fault Status: 00100011
                    Reset counter: 28
                    Mileage: 144450 km
                    Date: 2018.02.08
                    Time: 11:25:10
                        Term 15 Off
                    Voltage: 12.90 V
   Coding: 0012341
   Coding: 1102140000
   Coding: 820000
                    Reset counter: 242
                    Mileage: 144450 km
                    Date: 2023.09.18
                    Time: 11:15:58
                    UBat: 14.20 V
   Coding: 211F010000
   Coding: 356022
   Coding: 000007
   Coding: 0004B4
   Slave Driver:
   Coding: 00A090
                    Reset counter: 239
                    Reset counter: 215
                    Mileage: 143126 km
                    Date: 2023.09.04
                    Time: 19:40:45
                    Reset counter: 215
                    Mileage: 143126 km
                    Date: 2023.09.04
                    Time: 19:40:43
   Coding: 0000258
                    Reset counter: 243
                    (no units): 4.0
                    Voltage: 12.40 V
                    Reset counter: 242
                    Mileage: 144450 km
                    Date: 2018.02.08
                    Time: 11:13:32
                    Hex Value: 0x7301
                    Hex Value: 0x7601
                    Hex Value: 0x7301
                    Hex Value: 0x7601
                    Hex Value: 0x7301
                    Reset counter: 243
                    Mileage: 144450 km
                    Date: 2018.02.08
                    Time: 11:25:20
                    (no units): 7.0
                        Not OK
                    (no units): 0
   Coding: 0004B4
   Slave Passenger:
   Coding: 000490
   Coding: 0026156
End----------(Elapsed Time: 01:22, VBatt start/end: 14.0V/14.0V)-----------
Let's start with some basics:
Take a look at MVB 004.1 in the ABS. With front wheels pointed straight ahead and steering wheel centered, what do do you see there? When turning the steering wheel a bit to the to the left and to the right what happens to that value?
Also check it in 16-Steering wheel, but since this is a UDS module, you will have to use Advanced Measuring Values to look at:
MAS00815-IDE00326 -- Steering angle sensor - Steering wheel angle
narrab
Savannah, USA
C?ID=421565
Actually I was able to figure this out!
In the ABS module while I could not go to block 60 I found in the drop down menu the command to set the steering angle.
I would post a picture but dont seem to be able to figure out how to do this.
What are your results from the testing advised in post #4 ?
narrab
Savannah, USA
C?ID=421565
I fixed the issue hence the reason I posted the picture of how I set G85. I can still post the results if needed for info but I was able to figure it out and the car is running properly now. The VCDS system has saved me way more than I paid for it having 3 VWs.
