Vw Passat B8 Check last alarm set off
MrJC
Sweden
C?ID=220437
I drive a VW Passat B8. Looking to find how to check if and when my alarm has gone off. Reason being that someone smashed my right front window but as far as I know the ark arm hasn’t gone off.
Found a thread where it said 09 central elect, mb 20 to 23 should give last 4 triggers but that was posted back in 2017 and that field isn’t active or available for my car/version of VCDS.
What’s the drill now?
Don’t have the Autoscan available on my phone at the moment.
Post one please. We need to see how the car is equipped and configured.
MrJC
Sweden
C?ID=220437
Hope that this is the right one even though it’s in Swedish.
Chassityp: 3C-VW48 (5Q0)
Skanna: 01 02 03 05 08 09 10 13 15 16 17 18 19 22 2B 42 44 52 55 5F
          69 6C 6D BB BC
VIN: WVWZZZ3CZGE   Mätarställning: 222007km
01-Motor -- Status: Felfunktion 0010
02-Automatväxel -- Status: OK 0000
03-Bromselektronik -- Status: OK 0000
05-Behör.kontroll -- Status: OK 0000
08-Klimatanläggning -- Status: OK 0000
09-Elektron. elcentral -- Status: OK 0000
10-park/styr-hjälp -- Status: OK 0000
13-Distansreglering -- Status: OK 0000
15-Krockkuddar -- Status: OK 0000
16-Rattelektronik -- Status: OK 0000
17-Instrument -- Status: OK 0000
18-Extra/p-värmare -- Status: OK 0000
2B-Styraxellås -- Status: OK 0000
42-Dörrel. förare -- Status: OK 0000
44-Styrservo -- Status: OK 0000
52-Dörrelektr. pass. -- Status: OK 0000
55-Helljusområde -- Status: OK 0000
5F-Information Elektr. -- Status: OK 0000
69-Släpvagn -- Status: OK 0000
6C-Back-kamera -- Status: OK 0000
6D-El Bagageutr. -- Status: OK 0000
BB-bakre dörr förar -- Status: OK 0000
BC- bakre dörr pass -- Status: OK 0000
Adress 01: Motor (J623-DFCA)       Labels:. AER\04L-907-309-V1.clb
   Artikelnr SW: 04L 906 026 GA    HW: 04L 907 309 M
   Komponent: R4 2.0l TDI   H23 2013
   Revision: B4H23---    CVN: 570F665F38D3FF82
   Kodning: 011D003A04761D083000
   Verkstad #: WSC 05311 115 00304
   ASAM Dataset: EV_ECM20TDI01104L906026GA 004002
   ROD: EV_ECM20TDI01104L906026FM_004_VW48.rod
   VCID: 6FBBC06A071A4DF2E61-803A
   VINID: 9E69EAAAA0D3A9754200624408E276B933
1 fel funnet:
5262 - Dieselpartikelfilter differenstryckgivare
          P2454 00 [036] - kortsl. mot gods
          Intermittent fel - Ej bekräftad - Testad efter att minnet rensats
             frysta data:
                    Felstatus: 00000001
                    Felprioritet: 2
                    Felfrekvens: 1
                    Mätarställning: 222007 km
                    Datum: 2000.00.00
                    Tid: 00:00:00
                    Motorvarvtal: 0.00 /min
                    Normerat lastvärde: 0.0 %
                    Körhastighet: 0 km/h
                    Kylvätsketemperatur: 37 °C
                    Insugningslufttemperatur: 36 °C
                    Omgivningens lufttryck: 1010 mbar
                    Spänning klämma 30: 12.240 V
                    Felfördröjningsräknare enligt OBD: 40
                    Partikelfilter: differenstryckgivare 1 rad 1: råvärde: -214 hPa
                    Partikelfilter: differenstryckgivare 1 rad 1: anpassningsvärde: 0 hPa
                    Partikelfilter: differenstryckgivare 1 rad 1: offset: 1 hPa
                    Partikelfilter: differenstryckgivare 1 rad 1: dyn. offset: 0 hPa
                    Yttertemp.-givare 1: rad 1: råvärde: 25.5 °C
                    Partikelfilter: sotmängd uppmätt: -3.37 g
                    Partikelfilter: sotmängd beräknat: 10.31 g
Adress 02: Automatväxel (J743)       Labels: AER\0D9-927-770.clb
   Artikelnr SW: 0D9 300 012 A    HW: 02E 927 770 AQ
   Komponent: DQ250-6A MQB  H53 4902
   Revision: 06253104    Serienummer: TFK01602110064 CVN: 000012EE
   Kodning: 0014
   Verkstad #: WSC 05311 115 00063
   ROD: EV_TCMDQ250021.rod
   VCID: 1471AF864EFCCE2ABB3-8040
1 fel funnet:
10763 - Frigivning av startmotor från väljarvajern
          P1734 00 [002] - -
Adress 03: Bromselektronik (J104)       Labels: AER\5Q0-907-379-IPB-V1.clb
   Artikelnr SW: 3Q0 907 379 AB    HW: 3Q0 907 379 G
   Komponent: ESC           H42 0723
   Revision: 00000000    Serienummer: 60786000000493
   Kodning: 40EC6A8F34204B720780070441C54902562CD2E0E08292F9B8625078E209
   Verkstad #: WSC 00015 115 00001
   VCID: 7AADE13E4C58185A41F-802E
Ingen felkod funnen.
Adress 05: Behör.kontroll (J518)       Labels:| AER\5Q0-959-435.clb
   Artikelnr SW: 3Q0 959 435 B    HW: 3Q0 959 435 B
   Komponent: VWKESSYMQB    026 0710
   Revision: 00026000    Serienummer: 0398275354 Dataset Nummer: V03935228XM 0001
   Kodning: 000F0F0F03
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 392F3E3209DED342085-806C
   Styrdon för öppning av bakluckan:
Adress 08: Klimatanläggning (J255)       Labels:| AER\5G0-907-044.clb
   Artikelnr SW: 5G1 907 044 J    HW: 5G1 907 044 J
   Komponent: Climatronic   H04 1202
   Revision: 00001K10
   Kodning: 12020104204101011015500C0010190A
   Verkstad #: WSC 00015 115 08193
   ASAM Dataset: EV_ACClimaBHBVW37X 005137
   VCID: 2F3B006AC79A0DF2A61-807A
   Styrdon för friskluftsfläkt (fram):
   Givare för kylvätsketryck/-temperatur:
   Sensor för luftkvalitet:
   Givare för luftfuktighet: utvändigt:
Adress 09: Elektron. elcentral (J519)       Labels:| AER\5Q0-937-08X-HV1.clb
   Artikelnr SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
   Komponent: BCM PQ37BOSCH 028 0163
   Revision: --------    Serienummer: 865813031600YA Dataset Nummer: V03935235HB 0001
   Kodning: 00031C46C2C102FF17844094B11C57281C80000000000000000000000000
   ASAM Dataset: EV_BodyContrModul1UDSBosc 015001
   ROD: EV_BCMBOSCH_015.rod
   VCID: 03539CDA3B925992129-8056
   styrdon för torkarmotor:
   Subsystem 1 - Artikelnr SW: 3G1 955 119 A    HW: 3G1 955 119   Labels: AER\5QX-955-119-V1.CLB
   Komponent: WWS    160224  042 0607
   Serienummer:         160229063829
   Kodning: 0E4DDD
   regn- och ljussensor:
   Subsystem 2 - Artikelnr SW: 8UD 955 559 B    HW: 8UD 955 559 B  Labels: AER\8U0-955-559.CLB
   Komponent: G397_RLFS  H06 0004
   Serienummer: 30046982
   Kodning: 00006E
   ljusreglage:
   Subsystem 3 - Artikelnr SW: 3G0 941 633 H    HW: 3G0 941 633 H
   Komponent: E1 - LDS MQB  H01 0032
   Serienummer: 04 12 2015  10000354
   sensor för stöldlarm:
   Subsystem 4 - Artikelnr SW: 5Q0 951 172     HW: 5Q0 951 172
   Komponent: Sensor, DWA  005 0316
   Serienummer: 000000000ZY110390J0B
   Alarmsignalhorn:
   Subsystem 5 - Artikelnr SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Komponent: Sirene, DWA  005 0313
   Serienummer: 00000000000034917815
   Givare för luftfuktighet: invändigt:
Adress 10: park/styr-hjälp (J791)       Labels:| AER\5Q0-919-298.clb
   Artikelnr SW: 5QA 919 298     HW: 5Q0 919 298 C
   Komponent: PLA 3.0 12KH08 0161
   Serienummer: 000305183616059 Dataset Nummer: V03935223VR 0001
   Kodning: 0A71161951
   ASAM Dataset: EV_EPHVA2CAU3700000 009017
   VCID: 0D47BAE26DD61FE274D-8058
Adress 13: Distansreglering (J428)       Labels:| AER\3Q0-907-572.clb
   Artikelnr SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
   Komponent: ACC BOSCH MQB H04 0192
   Dataset Nummer: V03935229RW 0001
   Kodning: 3200678B11FFC428949C804D
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 34310F062EBC2E2ADB3-8060
Adress 15: Krockkuddar (J234)       Labels:| AER\5Q0-959-655.clb
   Artikelnr SW: 3Q0 959 655 BA    HW: 3Q0 959 655 BA
   Komponent: Airbag VW20   013 0195
   Revision: --------    Serienummer: 003SSP5VZL15 Dataset Nummer: 3G0003V____ 0036
   Kodning: 88CCC000008000005C5400CC000800000065
   Verkstad #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7EA5ED2E5070347A7D7-802A
   Bältessträckare vänster:
   Subsystem 1 - Artikelnr SW: 4M0 980 945 A    HW: 4M0 980 945 A
   Komponent: BeltPretRevFL  106 1032
   Serienummer: 3G1857705G0069Q01201
   Kodning: 80000D
   Bältessträckare höger:
   Subsystem 2 - Artikelnr SW: 4M0 980 946 A    HW: 4M0 980 946 A
   Komponent: BeltPretRevFR  106 1032
   Serienummer: 3G1857706G0063Q00322
   Kodning: 80000D
   krocksensor för sidoairbag på förarsidan:
   Subsystem 3 - Artikelnr SW: -----------    HW: 454 001 103 16
   Komponent: SideSensor_Df  008 0887
   Serienummer: 3576U000000624C4B91E
   Kodning: 2D2D2D
   krocksensor för sidoairbag på passagerarsidan:
   Subsystem 4 - Artikelnr SW: -----------    HW: 454 001 103 16
   Komponent: SideSensor_Pf  008 0887
   Serienummer: 3586U00000005485B919
   Kodning: 2D2D2D
   krocksensor för sidoairbag bak på förarsidan:
   Subsystem 5 - Artikelnr SW: -----------    HW: 454 802 802 16
   Komponent: SideSensor_Dr  301 0148
   Serienummer: 3516R62433E0A000000+
   Kodning: 2D2D2D
   Krocksensor för sidoairbag bak: passagerarsidan:
   Subsystem 6 - Artikelnr SW: -----------    HW: 454 802 802 16
   Komponent: SideSensor_Pr  301 0148
   Serienummer: 3526R5C413E0A0000006
   Kodning: 2D2D2D
   krocksensor för airbag fram på förarsidan:
   Subsystem 7 - Artikelnr SW: -----------    HW: 454 801 302 16
   Komponent: FrontSensor_D  304 0149
   Serienummer: 3556V8E861A0A000000L
   Kodning: 2D2D2D
Adress 16: Rattelektronik (J524)       Labels:| AER\5Q0-953-549.clb
   Artikelnr SW: 3Q0 953 521 EJ    HW: 5Q0 953 569 B
   Komponent: Lenks.Modul   100 0205
   Revision: FF035035    Serienummer: 20160306500307 Dataset Nummer: 3G0094V____ 0001
   Kodning: 0410
   ASAM Dataset: EV_SMLSVALEOMQBLRH 001005
   ROD: EV_SMLSVALEOMQBLRH.rod
   VCID: 7CA1E726466C266A533-8028
Adress 17: Instrument (J285)       Labels:| AER\5G0-920-XXX-17.clb-SRI3
   Artikelnr SW: 3G0 920 751 A    HW: 3G0 920 751 A
   Komponent: KOMBI         301 6421
   Kodning: 07A5081BAF80000801882B013001000000000000
   VCID: 2313FC5A9B52B992329-8076
Adress 18: Extra/p-värmare (J364)       Labels:| AER\5Q0-963-272.clb
   Artikelnr SW: 5Q0 963 272 E    HW: 5Q0 963 272 E
   Komponent: STH-MQB       007 0072
   Kodning: 9309
   VCID: 38293B3632D4CA4AF7B-806C
   Fjärrkontroll parkeringsvärmare:
   Subsystem 1 - Artikelnr SW: 5Q0 963 513 A    HW: 5Q0 963 513 A
   Komponent: R149 T91-LIN  003 0301
   Serienummer: 00000000000001348351
Adress 19: CAN Gateway (J533)       Labels:| AER\5Q0-907-530-V1.clb
   Artikelnr SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Komponent: GW MQB High   212 2246
   Revision: --------    Serienummer: 12031610802244 Dataset Nummer: 3G0067V____ 2404
   Kodning: 030300345F017300FB00225E1E0F00010001070000000000000000000000
   Verkstad #: WSC 131071 1023 2097151
   GVL: 01D43C0008000600C00C90000006C80000000000000000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 79AFFE32495E1342485-802C
   Generator:
   Styrdon för multifunktionsratt:
   Subsystem 2 - Artikelnr SW: 5G0 959 442 K    HW: 5G0 959 442 K  Labels: AER\3C8-959-537.CLB
   Komponent: E221__MFL-DC1  H17 0040
   Serienummer: 29160000417230076083
   Kodning: 2FFFFF
   Styrdon för batteriövervakning:
   Subsystem 3 - Artikelnr SW: 3Q0 915 181 A    HW: 3Q0 915 181 A
   Komponent: J367-BDMHella  H04 8050
   Serienummer: 6561819103
   Analog klocka:
   Subsystem 4 - Artikelnr SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Komponent: Analoguhr  209 2002
Adress 22: AWD (J492)       Labels:* AER\0CQ-907-554.clb
   Artikelnr SW: 0CQ 907 554 H    HW: 0CQ 525 130
   Komponent: Haldex4Motion H52 7083
   Serienummer: HA1-00018.02.16 Dataset Nummer: v1260x015G0 0000
   Kodning: 0301
   VCID: 4ACD71FE5C3848DA91F-801E
Adress 2B: Styraxellås (J764)       Labels:| AER\1EA-905-861.clb
   Artikelnr SW: 3Q0 905 861     HW: 3Q0 905 861
   Komponent: ELV-MQBB      H05 0032
   Serienummer: 16000046465001
   Kodning: 0800000000000000
   ROD: EV_ELVMarquMQBB_VW41.rod
   VCID: 71BFC612112E5B02F05-8024
Adress 42: Dörrel. förare (J386)       Labels:| AER\5QX-959-X93-42.clb
   Artikelnr SW: 5Q0 959 593 E    HW: 5Q0 959 593 B
   Komponent: TSG FS        020 0041
   Serienummer: 010216EAU12379 Dataset Nummer: V03935234RN 0001
   Kodning: 003F0A20D000028000001000
   VCID: 43D35CDA7B129992529-8016
Adress 44: Styrservo (J500)       Labels:| AER\5Q0-909-143.clb
   Artikelnr SW: 5Q0 909 143 M    HW: 5Q0 909 143 E
   Komponent: MQB_PP_APA    204 2041
   Revision: 00000000    Serienummer: 0000678173 Dataset Nummer: 3G0074V____ 0241
   Kodning: 01010010005001
   Verkstad #: WSC 00015 115 00304
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
   ROD: EV_SteerAssisVWBSMQBA_008_VW48.rod
   VCID: 3D272A221DF6EF6224D-8068
Adress 52: Dörrelektr. pass. (J387)       Labels:| AER\5QX-959-X92-52.clb
   Artikelnr SW: 5Q0 959 592 E    HW: 5Q0 959 592 B
   Komponent: TSG BFS       020 0041
   Serienummer: 220116EAL04097 Dataset Nummer: V03935234TC 0001
   Kodning: 003F0020D000028000001000
   VCID: 42DD59DE6408909A59F-8016
Adress 55: Helljusområde (J745)       Labels:| AER\7P6-907-357.clb
   Artikelnr SW: 7P6 907 357 C    HW: 7P6 907 357 B
   Komponent: AFS-ECU       H01 0120
   Revision: --------    Serienummer: --------------
   Kodning: 03AA00000F200200
   Verkstad #: WSC 05311 000 08193
   ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
   VCID: 3FDB502A17FAFD72361-806A
   effektmodul 1 för vänster LED-strålkastare:
   Subsystem 1 - Artikelnr SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: AER\3D0-941-329.CLB
   Komponent: LED LeiMo li.  H09 0003
   Kodning: E02400
   effektmodul 1 för höger LED-strålkastare:
   Subsystem 2 - Artikelnr SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: AER\3D0-941-329.CLB
   Komponent: LED LeiMo re.  H09 0003
   Kodning: E02400
   Effektmodul för vänster strålkastare:
   Subsystem 3 - Artikelnr SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: AER\3D0-941-329.CLB
   Komponent: LeiMo links  H02 0003
   Kodning: E02400
   Effektmodul för höger strålkastare:
   Subsystem 4 - Artikelnr SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: AER\3D0-941-329.CLB
   Komponent: LeiMo rechts  H02 0003
   Kodning: E02400
Adress 5F: Information Elektr. (J794)       Labels:| AER\5G0-035-MIB-STD2.clb
   Artikelnr SW: 3Q0 035 824 A    HW: 3Q0 035 824 A
   Komponent: MU-S--ER      620 0633
   Serienummer:                Dataset Nummer: V03935233XZ 0001
   Kodning: 02840200FF00000051110001000808001F0108C40120010003
   Verkstad #: WSC 40526 003 1048576
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 2B03147AF38271D28A9-807E
   Indikerings- och manöverenhet 1 för informationselektronik:
   Subsystem 1 - Artikelnr SW: 3G0 919 605 B    HW: 3G0 919 605 B
   Komponent: ABT_Std-2  H43 4064
   Serienummer: VWZ6Z9S0790970
Adress 69: Släpvagn (J345)       Labels:| AER\5Q0-907-383.clb
   Artikelnr SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
   Komponent: Anhaenger     H21 0203
   Revision: 8A001003    Serienummer: 0398755817 Dataset Nummer: 0G0124v____ 0016
   Kodning: 0100000202000000
   VCID: 3B23243A03E2E1521A9-806E
Adress 6C: Back-kamera (J772)       Labels:| AER\5Q0-980-556.clb
   Artikelnr SW: 5Q0 980 568     HW: 5Q0 980 568
   Komponent: RVC Compact+  H05 0100
   Dataset Nummer: V03935222WP 0001
   Kodning: 0184020163002017000048
   ASAM Dataset: EV_CamSysRVRVCARPANAMQBAB 006008
   ROD: EV_CamSysRVRVCARPANAMQBAB_006_VW37.rod
Adress 6D: El Bagageutr. (J605)       Labels:| AER\5Q0-959-107.clb
   Artikelnr SW: 5Q0 959 107 J    HW: 5Q0 959 107 J
   Komponent: HDSG-Modul    H13 0253
   Revision: --------    Serienummer: 30561999200000 Dataset Nummer: V03935230GZ 0001
   Kodning: 0280
   ASAM Dataset: EV_DeckLidCONTIAU736 001012
Adress BB: bakre dörr förar (J388)       Labels:* saknas
   Artikelnr SW: 5Q0 959 595 E    HW: 5Q0 959 595 B
   Komponent: TSG HFS       020 0041
   Serienummer: 260216BB902303 Dataset Nummer: V03935234UT 0001
   Kodning: 000E00200100028000001000
   VCID: 45D742C27526A7A27CD-8010
Adress BC:  bakre dörr pass (J389)       Labels:* saknas
   Komponent: TSG HBFS      020 0041
   Serienummer: 260216BB902309 Dataset Nummer: V03935234TU 0001
The BCM at address 09 has a number of Measuring Values with the identifier IDE05828. Have a look at them. The last one should be: DWA History data for alarm triggering - Number of alarm activations, although I have no idea what this would be in Swedish.
Also IDE05832.
PS: Please use the English version of VCDS for posting data here. You can download it from this page and it will happily coexist on your computer with the Swedish translation you are currently using.
MrJC
Sweden
C?ID=220437
Now I’ve been out checking. Only get a count of how many time the alarm has gone off but not when.
On other threads I’ve read that they look through address 9 and then Meas. Blocks -08. That one is not active on my so I went through Adv. Meas. Values.
Did an English scan as well.
Sunday,17,September,2023,11:26:00:29720
VCDS Version: 23.3.1.0 (x64)  HEX-V2 CB: 0.4631.4
VIN:    License Plate:
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 22 2B 42 44 52 55 5F
          69 6C 6D BB BC
VIN:    Mileage: 224689km-139615miles
Address 01: Engine (J623-DFCA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 GA    HW: 04L 907 309 M
   Component: R4 2.0l TDI   H23 2013
   Coding: 011D003A04761D083000
   Shop #: WSC 05311 115 00304
5262 - Particulate Filter; Differential Pressure Sensor
          P2454 00 [032] - Short to GND
                    Mileage: 223163 km
                    Engine RPM: 0.00 /min
                    Coolant temperature: 18 °C
                    Intake air temperature: 18 °C
                    Voltage terminal 30: 12.240 V
                    Unlearning counter according OBD: 37
                    Particle filter: air pressure sensor 1 bank 1: raw value: -214 hPa
                    Particl.filt.: different.press.sensor 1 bank 1: adaptat. value: 0 hPa
                    Par.fil: diff.pr.sens.1 bank 1: offset: 2 hPa
                    Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset: 0 hPa
                    Outside temperature sensor 1: B1: raw value: 9.0 °C
                    Particle filter: soot mass measured: 1.28 g
                    Particle filter: soot mass calculated: 11.45 g
   Part No SW: 0D9 300 012 A    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4902
   Revision: 06253104    Serial number: TFK01602110064 CVN: 000012EE
   Shop #: WSC 05311 115 00063
   Revision: 00000000    Serial number: 60786000000493
   Coding: 40EC6A8F34204B720780070441C54902562CD2E0E08292F9B8625078E209
   Shop #: WSC 00015 115 00001
   Part No SW: 3Q0 959 435 B    HW: 3Q0 959 435 B
   Component: VWKESSYMQB    026 0710
   Revision: 00026000    Serial number: 0398275354 Dataset Number: V03935228XM 0001
   Coding: 000F0F0F03
   Part No SW: 5G1 907 044 J    HW: 5G1 907 044 J
   Component: Climatronic   H04 1202
   Revision: 00001K10
   Coding: 12020104204101011015500C0010190A
   Shop #: WSC 00015 115 08193
   Air quality sensor:
   Humidity sensor: exterior:
328199 - Position Sensor for Right Temperature Flap Motor
          B1095 15 [008] - Open or Short to Plus
                    Reset counter: 192
                    Mileage: 224677 km
                    Date: 2023.09.15
                    Time: 18:57:34
                    Voltage terminal 30: 13.1 V
                    Outside temperature: 17.5 °C
                    Inside temperature: 26.0 °C
                    Right temperature flap: actual value: 0.0 %
                    Right temperature flap: actual value: 114
                    Temperature door right - Specified value: 114
263425 - Air Quality Sensor
          B10AF 04 [008] - Internal System Fault
                    Reset counter: 182
                    Mileage: 223664 km
                    Date: 2023.09.02
                    Time: 10:20:54
                    Voltage terminal 30: 14.7 V
                    Outside temperature: 21.0 °C
                    System run time-Engine running time: 35 s
                    System run time-Terminal 15 on: 35 s
   Part No SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
   Component: BCM PQ37BOSCH 028 0163
   Revision: --------    Serial number: 865813031600YA Dataset Number: V03935235HB 0001
   Coding: 00031C46C2C102FF17844094B11C57281C80000000000000000000000000
   Subsystem 1 - Part No SW: 3G1 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    160224  042 0607
   Serial number:         160229063829
   Subsystem 2 - Part No SW: 8UD 955 559 B    HW: 8UD 955 559 B  Labels: 8U0-955-559.CLB
   Serial number: 30046982
   Coding: 00006E
   Subsystem 3 - Part No SW: 3G0 941 633 H    HW: 3G0 941 633 H
   Serial number: 04 12 2015  10000354
   Subsystem 4 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY110390J0B
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000034917815
   Humidity sensor: interior:
   Part No SW: 5QA 919 298     HW: 5Q0 919 298 C
   Component: PLA 3.0 12KH08 0161
   Serial number: 000305183616059 Dataset Number: V03935223VR 0001
   Coding: 0A71161951
   Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
   Dataset Number: V03935229RW 0001
   Coding: 3200678B11FFC428949C804D
   Part No SW: 3Q0 959 655 BA    HW: 3Q0 959 655 BA
   Component: Airbag VW20   013 0195
   Revision: --------    Serial number: 003SSP5VZL15 Dataset Number: 3G0003V____ 0036
   Coding: 88CCC000008000005C5400CC000800000065
   Shop #: WSC 05314 000 00001
   Left seat belt tensioner:
   Serial number: 3G1857705G0069Q01201
   Coding: 80000D
   Right seat belt tensioner:
   Serial number: 3G1857706G0063Q00322
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 454 001 103 16
   Serial number: 3576U000000624C4B91E
   Subsystem 4 - Part No SW: -----------    HW: 454 001 103 16
   Serial number: 3586U00000005485B919
   Subsystem 5 - Part No SW: -----------    HW: 454 802 802 16
   Serial number: 3516R62433E0A000000+
   Subsystem 6 - Part No SW: -----------    HW: 454 802 802 16
   Serial number: 3526R5C413E0A0000006
   Subsystem 7 - Part No SW: -----------    HW: 454 801 302 16
   Serial number: 3556V8E861A0A000000L
   Part No SW: 3Q0 953 521 EJ    HW: 5Q0 953 569 B
   Component: Lenks.Modul   100 0205
   Revision: FF035035    Serial number: 20160306500307 Dataset Number: 3G0094V____ 0001
   Coding: 0410
   Part No SW: 3G0 920 751 A    HW: 3G0 920 751 A
   Component: KOMBI         301 6421
   Coding: 07A5081BAF80000801882B013001000000000000
Address 18: Aux. Heat (J364)       Labels:| 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 E    HW: 5Q0 963 272 E
   Component: STH-MQB       007 0072
   Coding: 9309
   Auxiliary heating remote control:
   Subsystem 1 - Part No SW: 5Q0 963 513 A    HW: 5Q0 963 513 A
   Component: R149 T91-LIN  003 0301
   Serial number: 00000000000001348351
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 12031610802244 Dataset Number: 3G0067V____ 2404
   Coding: 030300345F017300FB00225E1E0F00010001070000000000000000000000
   Generator:
   Component: E221__MFL-DC1  H17 0040
   Serial number: 29160000417230076083
   Coding: 2FFFFF
   Subsystem 3 - Part No SW: 3Q0 915 181 A    HW: 3Q0 915 181 A
   Serial number: 6561819103
   Analog clock:
   Subsystem 4 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  209 2002
131689 - Rear View Camera System Control Module
          U104C 00 [008] - No communication
          [Timeout Knoten 0x69 / 6C - Steuergerät für Rückfahrkamerasystem]
                    Reset counter: 165
                    Mileage: 223163 km
                    Date: 2023.08.28
                    Time: 06:56:48
                    Terminal 30 power supply: 12.3 V
                    Terminal 15: OFF
131699 - Control unit for information electronics 1
          U1054 00 [008] - No Communication
          [Timeout Knoten 0x73 / 5F - Steuergerät für Informationselektronik 1]
                    Reset counter: 184
                    Mileage: 224238 km
                    Date: 2023.09.11
                    Time: 07:27:45
                    Terminal 30 power supply: 12.1 V
                    Terminal 15: OFF
   Serial number: HA1-00018.02.16 Dataset Number: v1260x015G0 0000
   Coding: 0301
   Serial number: 16000046465001
   Coding: 0800000000000000
   Serial number: 010216EAU12379 Dataset Number: V03935234RN 0001
   Coding: 003F0A20D000028000001000
   Part No SW: 5Q0 909 143 M    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    204 2041
   Revision: 00000000    Serial number: 0000678173 Dataset Number: 3G0074V____ 0241
   Coding: 01010010005001
   Shop #: WSC 00015 115 00304
   Serial number: 220116EAL04097 Dataset Number: V03935234TC 0001
   Coding: 003F0020D000028000001000
65799 - Door Warning / Entry Lighting
          B1775 01 [008] - Electrical Failure
                    Reset counter: 190
                    Mileage: 224566 km
                    Date: 2023.09.14
                    Time: 10:36:44
65649 - Lamp for Ambient Illumination
          B1325 13 [008] - Open Circuit
                    Reset counter: 190
                    Mileage: 224566 km
                    Date: 2023.09.14
                    Time: 10:36:44
   Component: AFS-ECU       H01 0120
   Coding: 03AA00000F200200
   Shop #: WSC 05311 000 08193
   Subsystem 1 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H09 0003
   Coding: E02400
   Subsystem 2 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H09 0003
   Coding: E02400
   Subsystem 3 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 0003
   Coding: E02400
   Subsystem 4 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 0003
   Coding: E02400
   Part No SW: 3Q0 035 824 A    HW: 3Q0 035 824 A
   Component: MU-S--ER      620 0633
   Serial number:                Dataset Number: V03935233XZ 0001
   Coding: 02840200FF00000051110001000808001F0108C40120010003
   Shop #: WSC 40526 003 1048576
   Subsystem 1 - Part No SW: 3G0 919 605 B    HW: 3G0 919 605 B
   Component: ABT_Std-2  H43 4064
   Serial number: VWZ6Z9S0790970
   Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
   Component: Anhaenger     H21 0203
   Revision: 8A001003    Serial number: 0398755817 Dataset Number: 0G0124v____ 0016
   Coding: 0100000202000000
   Part No SW: 5Q0 980 568     HW: 5Q0 980 568
   Component: RVC Compact+  H05 0100
   Dataset Number: V03935222WP 0001
   Coding: 0184020163002017000048
   Part No SW: 5Q0 959 107 J    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0253
   Revision: --------    Serial number: 30561999200000 Dataset Number: V03935230GZ 0001
   Coding: 0280
   Serial number: 260216BB902303 Dataset Number: V03935234UT 0001
   Coding: 000E00200100028000001000
   Serial number: 260216BB902309 Dataset Number: V03935234TU 0001
End----(Elapsed Time: 02:23, VBatt start/end: 11.9V/12.0V. VIgn 11.9V)-----
MrJC
Sweden
C?ID=220437
Okey, then it’s not possible sadly to see on the newer models.
MrJC
Sweden
C?ID=220437
Now Ive been out and checked. Hope that I got the file you asked for, followed the instructions 2:18 in to the clip on the page you sent.
Shall I just paste it in here or should I send the file somewhere? Not that used to posting on forums so dont really find my way around.
I made a log of IDE05833 which showed what I was looking for as soon as I got it in a text file.
Just paste the contents here, preferably between CODE tags.
MrJC
Sweden
C?ID=220437
This should be it I think.
;SW:5Q0-937-086-AK   HW:5Q0-937-086-AK ---  Cent. Elect.
;Component:BCM PQ37BOSCH 028 0163, Coding:00031C46C2C102FF17844094B11C57281C80000000000000000000000000
;EV_BodyContrModul1UDSBosc,015001,EV_BCMBOSCH_015.rod
;Monday,18,September,2023,17:15:20:29720
;VCDS Version: Release 23.3.1 (x64)  Data version: 20230421 DS346.2
;VCID: 03539CDA3B925992129-8056
Group,Description,Actual
IDE00374-MAS05377,Electric auxiliary heater: relay activation-Low heat output relay,not coded/not installed,
IDE00374-MAS05378,Electric auxiliary heater: relay activation-High heat output relay,not coded/not installed,
IDE00550,Identification of parameterization,10 E2,
IDE00844-MAS07314,Switch for engine hood-Status engine hood contact,closed,
IDE00844-ENG122175,Switch for engine hood-Bonnet_Magnetic_Lock,not coded/not installed,
IDE00973,Outside temperature,28.50,  C
IDE01066-IDE02092,Convertible top status-Tailgate condition,not coded/not installed,
IDE01066,Convertible top status,not coded/not installed,
IDE01464-IDE04741,Rear window defogger-Rear window defogger button,Not operated,
IDE01464-IDE04744,Rear window defogger-Rear window defogger indicator lamp,not coded/not installed,
IDE01537-IDE04742,Front windshield heater-Windshield defogger button,not coded/not installed,
IDE01537-IDE04743,Front windshield heater-Windshield defogger indicator lamp,not coded/not installed,
IDE01537-MAS01580,Front windshield heater-Activation,not coded/not installed,
IDE01943,Turn signal lamp,|Connector number,Connector terminal number,Duty cycle,Signal state,Diagnosis|Connector B,36,0.00,not active,normal|Connector B,20,0.00,not active,normal|Connector A,60,0.00,not active,normal|Plug C,31,0.00,not active,normal|,
IDE02092-IDE02093,Tailgate condition-Status of rear lid lock,Implausible,
IDE02092-IDE02133,Tailgate condition-Activation using rear lid unlocking button,not coded/not installed,
IDE02092-MAS01872,Tailgate condition-Rear lid remote control lock switch,Not operated,
IDE02092-MAS02405,Tailgate condition-Pre-engagement contact for rotary latch,to,
IDE02092-MAS02447,Tailgate condition-Release,Enabled,
IDE02092-MAS06265,Tailgate condition-Release button in rear lid handle,Not operated,
IDE02092-MAS06430,Tailgate condition-Main notch contact of rotary latch,to,
IDE02488-MAS01632,Anti-theft system interior monitoring-Status,not active,
IDE02488-MAS04508,Anti-theft system interior monitoring-Alarm detected,No,
IDE02515,Low beam,|Connector number,Connector terminal number,Duty cycle,Signal state,Diagnosis|Plug C,5,100.00,active,normal|Connector B,1,100.00,active,normal|,
IDE02588-IDE00020,Terminal signals and start release-Terminal 15 status,active,
IDE02588-IDE00773,Terminal signals and start release-Terminal 15 status via CAN,active,
IDE02588-IDE01351,Terminal signals and start release-Terminal 75 status,On,
IDE02588-IDE01715,Terminal signals and start release-Status terminal S,active,
IDE02588-IDE01716,Terminal signals and start release-Terminal 50 status,OFF,
IDE02588-IDE06027,Terminal signals and start release-Terminal S status via CAN,active,
IDE02588-MAS12787,Terminal signals and start release-Terminal 15 ignition switch signal 1,active,
IDE02588-MAS12788,Terminal signals and start release-Terminal 15 ignition switch signal 2,active,
IDE02614-MAS02788,Reversing light switch-CAN,not active,
IDE02614-MAS05360,Reversing light switch-Discreet wire,not active,
IDE02711,Rear wiper,not active,
IDE02743,High Beam,|Connector number,Connector terminal number,Duty cycle,Signal state,Diagnosis|not coded/not installed,0,0.00,Measuring value not available,not coded/not installed|,
IDE02857-IDE03111,Activation current-Interior lighting,0, mA
IDE02857-IDE05533,Activation current-Heater for nozzles,0, mA
IDE02857-IDE06012,Activation current-Background lighting,90, mA
IDE02857-MAS01554,Activation current-Left heated seat,0, mA
IDE02857-MAS01556,Activation current-Right heated seat,0, mA
IDE02857-ENG128454,Activation current-Cockpittaster_1,0, mA
IDE02857-ENG128455,Activation current-Cockpittaster_2,0, mA
IDE02857-ENG128456,Activation current-Cockpittaster_3,10, mA
IDE02857-ENG128457,Activation current-Cockpittaster_4,0, mA
IDE02857-ENG128458,Activation current-DWA_Einfachhorn,0, mV
IDE02857-ENG126436,Activation current-signal_horn,0, mV
IDE02957,Ambient lighting,|Channel,Connector number,Connector terminal number,Duty cycle,Signal state,Diagnosis|Not available,not coded/not installed,0,0.00,NOT-DEFINED,not coded/not installed|,
IDE03111,Interior lighting,|Connector number,Connector terminal number,Duty cycle,Signal state,Diagnosis|Plug C,12,88.50,active,normal|,
IDE03310,Brake lamp,|Connector number,Connector terminal number,Duty cycle,Signal state,Diagnosis|Plug C,9,88.50,active,normal|Connector B,3,89.00,active,normal|Connector A,71,0.00,not active,normal|Plug C,8,0.00,not active,normal|Connector A,57,0.00,not active,normal|Plug C,10,88.50,active,normal|Connector A,65,89.00,active,normal|Plug C,6,88.50,active,normal|Plug C,11,0.00,not active,normal|,
IDE03388-IDE01217,Left front heated seat: status-Left heated seat stage,OFF,
IDE03388-MAS02201,Left front heated seat: status-Temperature,27.00,  C
IDE03389-IDE01218,Right front heated seat: status-Right heated seat stage,OFF,
IDE03389-MAS02201,Right front heated seat: status-Temperature,23.50,  C
IDE03504,Personalized settings,|profile,Comfort opening,Sunroof,Electrical rear lid,Manual door unlock,Rain closure,Mirror adjustment,Mirror lowering,Automatic mirror fold-in,Activation sound: theft warning system,Auto lock,Auto unlock,Virtual pedal,Automatic rear window wiper,Tourist light,Status Coming Home,Status Leaving Home,Coming Home set point,Leaving Home set point,Light intensity,Comfort flasher,Comfort flasher set point,Adaptive light functions,High beam assistant: status,Sliding beam range,Masked continuous high beam,Rain light|1,OFF,not active,active,all,not active,synchronous,not active,active,not active,active,active,not active,active,not active,active,active,15,15,normal,active,5,active,active,active,active,active|2,All windows,not active,active,all,not active,synchronous,not active,active,not active,active,active,not active,active,not active,active,active,5,5,normal,active,5,active,active,active,active,active|4,All windows,not active,active,all,not active,synchronous,not active,active,not active,active,active,not active,active,not active,active,active,10,10,insensitive,active,3,active,active,active,active,active|,
IDE03638,Stationary cornering lamp,|Connector number,Connector terminal number,Duty cycle,Signal state,Diagnosis|not coded/not installed,0,0.00,Measuring value not available,not coded/not installed|,
IDE04213,Central locking button,not coded/not installed,
IDE04213-IDE07357,Central locking button-Indicator lamp for central locking,not coded/not installed,
IDE04254-MAS06517,Play protection for central locking-Rear spoiler counter,not active,
IDE04925,Daytime running lights,|Connector number,Connector terminal number,Duty cycle,Signal state,Diagnosis|not coded/not installed,0,0.00,Measuring value not available,not coded/not installed|,
IDE05042-MAS03873,Emergency flasher button-Duty cycle,18.50, %
IDE05045-IDE05183,Front wiper module-Malfunction left,No malfunction,
IDE05045-IDE05184,Front wiper module-Malfunction right,No malfunction,
IDE05045-MAS03638,Front wiper module-Wipe speed,0, /min
IDE05045-MAS05057,Front wiper module-Number of wiper cycles,309100,
IDE05045-MAS05878,Front wiper module-Stage,not coded/not installed,
IDE05323,Fog lamp,|Connector number,Connector terminal number,Duty cycle,Signal state,Diagnosis|Connector B,10,27.50,active,normal|Connector B,21,27.50,active,normal|Connector B,45,0.00,not active,normal|Connector B,5,0.00,not active,normal|,
IDE05434,Rear entry light,|Connector number,Side,Connector terminal number,Duty cycle,Signal state,Diagnosis|not coded/not installed,Unknown (0),0,0.00,Measuring value not available,not coded/not installed|,
IDE05533,Heater for nozzles,not active,
IDE05719-IDE05534,Window washer system-Headlamp washer system,not active,
IDE05719-MAS02341,Window washer system-Rear window washer system,not active,
IDE05720-IDE02589,Front driver side door status-Rotary latch status,closed,
IDE05720-IDE04213,Front driver side door status-Central locking button,Not operated,
IDE05722-IDE02589,Door status: driver side rear-Rotary latch status,closed,
IDE05722-IDE04213,Door status: driver side rear-Central locking button,Not operated,
IDE05722-MAS06256,Door status: driver side rear-Status door lock,Signal from door lock: released,
IDE05727-IDE04213,Front passenger side door status-Central locking button,Not operated,
IDE05727-IDE04214,Front passenger side door status-Key switch in door lock,Not operated,
IDE05729-IDE02589,Door status: frt. pass. side rear-Rotary latch status,closed,
IDE05729-IDE04213,Door status: frt. pass. side rear-Central locking button,Not operated,
IDE05729-MAS06256,Door status: frt. pass. side rear-Status door lock,Signal from door lock: released,
IDE05730,Luggage compartment light,|Connector number,Connector terminal number,Duty cycle,Signal state,Diagnosis|not coded/not installed,0,0.00,Measuring value not available,not coded/not installed|,
IDE05739,Footwell lamp,|Connector number,Connector terminal number,Duty cycle,Signal state,Diagnosis|Plug C,72,36.00,active,normal|,
IDE05742-IDE02515,Light switch position-Low beam,Not operated,
IDE05742-IDE05323,Light switch position-Fog lamp,Not operated,
IDE05742-IDE07956,Light switch position-redundant signal line,Position lamps,
IDE05742-MAS00063,Light switch position-OFF,Not operated,
IDE05742-MAS02462,Light switch position-Automatic high beam assist,operated,
IDE05742-MAS03835,Light switch position-Position lamps,Not operated,
IDE05742-MAS03836,Light switch position-Rear fog lamp,Not operated,
IDE05822-MAS01632,Anti-theft alarm system vehicle inclination sensor-Status,not active,
IDE05822-MAS04508,Anti-theft alarm system vehicle inclination sensor-Alarm detected,No,
IDE05824-MAS04583,DWA Vehicle inclination sensor: angle-Reference angle: X-axis,-19.40,
IDE05824-MAS04584,DWA Vehicle inclination sensor: angle-Reference angle: Y-axis,-0.90,
IDE05824-MAS04585,DWA Vehicle inclination sensor: angle-Reference angle: Z-axis,Implausible,
IDE05824-MAS04586,DWA Vehicle inclination sensor: angle-Angle difference: X-axis,0.00,
IDE05824-MAS04587,DWA Vehicle inclination sensor: angle-Angle difference: Y-axis,0.00,
IDE05824-MAS04588,DWA Vehicle inclination sensor: angle-Angle difference: Z-axis,Implausible,
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch,OFF,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,Not operated,
IDE05826-MAS01632,DWA Sirens / alarm horn for anti-theft warning system-Status,not active,
IDE05826-MAS04508,DWA Sirens / alarm horn for anti-theft warning system-Alarm detected,No,
IDE05826-MAS04509,DWA Sirens / alarm horn for anti-theft warning system-Alarm activated,No,
IDE05827,Horn for anti-theft warning system,not coded/not installed,
IDE05828-MAS06608,DWA History data for alarm triggering-Cause for last alarm activation,Alarm trigger via anti-theft alarm system master,
IDE05828-MAS06609,DWA History data for alarm triggering-Cause for second-to-last alarm activation,Alarm trigger via anti-theft alarm system master,
IDE05828-MAS06610,DWA History data for alarm triggering-Cause for third-to-last alarm activation,Alarm trigger via anti-theft alarm system master,
IDE05828-MAS06611,DWA History data for alarm triggering-Cause for fourth-to-last alarm activation,Alarm trigger via anti-theft alarm system master,
IDE05828-MAS06613,DWA History data for alarm triggering-Number of alarm activations,74,
IDE05829,Rear spoiler history data,|Spoiler_Activation_Trigger,Spoiler_Activation_Trigger_Date,Spoiler_Activation_Trigger_Time,Spoiler_Activation_Trigger_Milage|NoEntry,0,0,5898586|NoEntry,0,0,5898586|NoEntry,0,0,5898586|NoEntry,0,0,5898586|NoEntry,0,0,5898586|NoEntry,0,0,5898586|NoEntry,0,0,5898586|NoEntry,0,0,5898586|NoEntry,0,0,5898586|NoEntry,0,0,5898586|, km
IDE05830-MAS02282,Rear Spoiler-Position,not coded/not installed,
IDE05830-ENG115793,Rear Spoiler-Spoiler_Button,not coded/not installed,
IDE05830-ENG115792,Rear Spoiler-Spoiler_Cycle_Protection,not coded/not installed,
IDE05830-ENG115794,Rear Spoiler-Spoiler_Indication_Light,not coded/not installed,
IDE05830-ENG115791,Rear Spoiler-Spoiler_Position,not coded/not installed,
IDE05832,DWA Number of alarms triggered in anti-theft warn.system sensor,255,
IDE05833,Anti-theft warning system: history data,|Cause for alarm activation,Odometer reading,Year,Month,Day,Hours,Minutes,Seconds|Incline sensor alarm,214097,2023,4,10,13,54,14|Interior monitoring alarm (windows / roof closed),207259,2022,8,1,13,58,10|Interior monitoring alarm (windows / roof closed),207259,2022,8,1,13,56,55|Interior monitoring alarm (windows / roof closed),207259,2022,8,1,10,22,3|Interior monitoring alarm (windows / roof closed),207259,2022,7,31,23,40,49|Interior monitoring alarm (windows / roof closed),207259,2022,7,31,8,54,35|Interior monitoring alarm (windows / roof closed),207259,2022,7,31,3,28,51|Interior monitoring alarm (windows / roof closed),207259,2022,7,31,2,58,9|Interior monitoring alarm (windows / roof closed),207259,2022,7,31,2,38,12|Interior monitoring alarm (windows / roof closed),207259,2022,7,31,2,35,56|,
IDE05834-IDE01718,Driver info-Crash signal,not active,
IDE05834-MAS00212,Driver info-Insufficient washer fluid,not active,
IDE05834-MAS00214,Driver info-Brake pad wear,not active,
IDE05836-MAS03637,Rain recognition sensor-Rain quantity,not coded/not installed,
IDE05838-MAS02248,Light recognition sensor-Signal state,active,
IDE05838-MAS02475,Light recognition sensor-Brightness infrared,1200, lx
IDE05838-MAS02851,Light recognition sensor-Brightness,252, lx
IDE05838-MAS04809,Light recognition sensor-Darkness,On,
IDE05838-MAS04810,Light recognition sensor-Request for light activation,On,
IDE05839,Parking lamps,|Connector number,Connector terminal number,Duty cycle,Signal state,Diagnosis|Connector B,10,27.50,active,normal|Connector B,21,27.50,active,normal|Connector B,4,100.00,active,normal|Connector B,32,100.00,active,normal|Plug C,9,89.00,active,normal|Connector B,3,89.00,active,normal|Plug C,10,89.00,active,normal|Connector A,65,89.00,active,normal|,
IDE05841,Central locking history data,|Control-section / cause,Operating dir.,Command,Additional information|remote_lock_unlock_switch,Door unlock,complete unlock,radio remote control: number 1|remote_lock_unlock_switch,Lock door,safe,radio remote control: number 2|Auto unlock,Door unlock,complete unlock,Measuring value not available|Auto lock,Lock door,lock,Measuring value not available|remote_lock_unlock_switch,Door unlock,complete unlock,radio remote control: number 2|remote_lock_unlock_switch,Lock door,safe,radio remote control: number 2|Auto unlock,Door unlock,complete unlock,Measuring value not available|Auto lock,Lock door,lock,Measuring value not available|remote_lock_unlock_switch,Door unlock,complete unlock,radio remote control: number 2|remote_lock_unlock_switch,Lock door,safe,radio remote control: number 2|,
IDE05842,Comfort function history data,|Control-section / cause,Operating command,convertible top,Sun roof/tilt roof,Driver door,Front Passenger Door,Left rear door,Right rear door|radio remote control number_3,Close,not active,not active,active,active,active,active|radio remote control number_3,Open,not active,not active,active,active,active,active|radio remote control number_3,Open,not active,not active,active,active,active,active|radio remote control number_3,Open,not active,not active,active,active,active,active|radio remote control number_3,Close,not active,not active,active,active,active,active|radio remote control number_3,Open,not active,not active,active,active,active,active|radio remote control number_3,Close,not active,not active,active,active,active,active|radio remote control number_3,Open,not active,not active,active,active,active,active|radio remote control number_3,Open,not active,not active,active,active,active,active|radio remote control number_3,Open,not active,not active,active,active,active,active|,
IDE06012,Background lighting,|Connector number,clamp,Connector terminal number,Duty cycle,Signal state,Diagnosis|Plug C,Variant A,62,88.50,active,normal|,
IDE06091-IDE01440,Humidity sensor: interior-Front windshield temperature,-38.7,  C
IDE06091-MAS04629,Humidity sensor: interior-Sensor temperature,23.5,  C
IDE06091-MAS04630,Humidity sensor: interior-Relative humidity,59.0, %
IDE06091-MAS04647,Humidity sensor: interior-Dew point,-38.8,  C
IDE06096-IDE03111,Interior lights-Interior lighting,0, %
IDE06096-IDE05724,Interior lights-Dimmer terminal 58xt,100.00, %
IDE06096-IDE05725,Interior lights-Dimmer terminal 58xs,100.00, %
IDE06096-IDE05726,Interior lights-Dimmer terminal 58xd,100.00, %
IDE06096-MAS01634,Interior lights-Supply voltage,89.00, %
IDE06096-MAS04528,Interior lights-Instrument panel and switch illumination dimmer switch,100, %
IDE06324-IDE04217,Tank cap lock-Fuel filler door release button,not coded/not installed,
IDE06324-MAS01580,Tank cap lock-Activation,not active,
IDE06324-MAS06251,Tank cap lock-Contact switch,not coded/not installed,
IDE06470,Periphery lighting,|Connector number,Connector terminal number,Duty cycle,Signal state,Diagnosis|not coded/not installed,0,0.00,Measuring value not available,not coded/not installed|,
IDE06507-MAS13127,Button in center console-Status of button 1,Not operated,
IDE06507-MAS13128,Button in center console-Indicator lamp button 1,OFF,
IDE06507-MAS13130,Button in center console-Status of button 2,not coded/not installed,
IDE06507-MAS13131,Button in center console-Indicator lamp button 2,not coded/not installed,
IDE06507-MAS13133,Button in center console-Status of button 3,Not operated,
IDE06507-MAS13134,Button in center console-Indicator lamp button 3,On,
IDE06507-MAS13136,Button in center console-Indicator lamp button 4,not coded/not installed,
IDE06507-MAS13137,Button in center console-Status of button 4,not coded/not installed,
IDE06644-IDE06864,Vehicle positioning system-Daytime running lamps,not coded/not installed,
IDE06644-MAS00145,Vehicle positioning system-Starter lock,not coded/not installed,
IDE06644-MAS01288,Vehicle positioning system-Horn,not coded/not installed,
IDE06644-MAS03834,Vehicle positioning system-Emergency signal flashing,not coded/not installed,
IDE06644-MAS03835,Vehicle positioning system-Position lamps,not coded/not installed,
IDE06695,Energy management: last critical state,|Maximum switch-off priority while driving,Energy management heat output control status,Number of critical operation cycles,min_prio_Tab_M,min_prio_Tab_K,Anz_krit_Betriebszyklen,Bedingung_Tab_NQ,min_prio_Tab_NQ,Anz_erreichte_Max_Freigaben,Year,Month,Day|0,0,0,0,0,0,0,0,0,2000,0,0|0,0,0,0,0,0,0,0,0,2000,0,0|0,0,0,0,0,0,0,0,0,2000,0,0|,
IDE06864,Daytime running lamps,|Connector number,Connector terminal number,Duty cycle,Signal state,Diagnosis|Connector B,10,27.50,active,normal|Connector B,21,27.50,active,normal|Connector B,4,100.00,active,normal|Connector B,32,100.00,active,normal|,
IDE07344-IDE00542,Sunroof shade-Excessive temperature protection,Write only channel,
IDE07344-IDE03114,Sunroof shade-Comfort function,Write only channel,
IDE07344-MAS01979,Sunroof shade-Adapting,Write only channel,
IDE07344-MAS02282,Sunroof shade-Position,Write only channel, %
IDE07344-MAS02447,Sunroof shade-Release,Write only channel,
IDE07344-MAS03656,Sunroof shade-Reverse,Write only channel,
IDE07344-MAS05563,Sunroof shade-Norming,Write only channel,
IDE07345-MAS07997,Sunroof front closed position switch-Rotary switch activation,Write only channel,
IDE07345,Sunroof front closed position switch,Write only channel,
IDE07345-ENG122183,Sunroof front closed position switch-rotary_switch_position,Write only channel,
IDE07346,Sunroof shade switches,Write only channel,
IDE08125-MAS01458,Left head area heater-Operating condition,not coded/not installed,
IDE08125-MAS06651,Left head area heater-PTC heater element: current consumption,not coded/not installed,
IDE08125-MAS06652,Left head area heater-Blower motor: speed,not coded/not installed,
IDE08125-MAS06653,Left head area heater-Indicator light for head area heater,not coded/not installed,
IDE08126-MAS01458,Right head area heater-Operating condition,not coded/not installed,
IDE08126-MAS06651,Right head area heater-PTC heater element: current consumption,not coded/not installed,
IDE08126-MAS06652,Right head area heater-Blower motor: speed,not coded/not installed,
IDE08126-MAS06653,Right head area heater-Indicator light for head area heater,not coded/not installed,
IDE08949-MAS07869,Operating current: light driver-Conn. pin 2,10, mA
IDE08949-MAS07870,Operating current: light driver-Conn. pin 3,10, mA
IDE08949-MAS07871,Operating current: light driver-Conn. pin 4,560, mA
IDE08949-MAS07872,Operating current: light driver-Conn. pin 5,230, mA
IDE08949-MAS07873,Operating current: light driver-Conn. pin 6,1580, mA
IDE08949-MAS07874,Operating current: light driver-Conn. pin 7,1510, mA
IDE08949-MAS07875,Operating current: light driver-Conn. pin 8,0, mA
IDE08949-MAS07876,Operating current: light driver-Conn. pin 9,0, mA
IDE08949-MAS07877,Operating current: light driver-Conn. pin 10,0, mA
IDE08949-MAS07878,Operating current: light driver-Conn. pin 11,0, mA
IDE08949-MAS07879,Operating current: light driver-Conn. pin 12,0, mA
IDE08949-MAS07880,Operating current: light driver-Conn. pin 13,0, mA
IDE08949-MAS07883,Operating current: light driver-Conn. pin 16,230, mA
IDE08949-MAS07884,Operating current: light driver-Conn. pin 17,220, mA
IDE08949-MAS07890,Operating current: light driver-Conn. pin 23,100, mA
IDE08949-MAS07891,Operating current: light driver-Conn. pin 24,110, mA
IDE08949-MAS07892,Operating current: light driver-Conn. pin 25,150, mA
IDE08949-MAS07894,Operating current: light driver-Conn. pin 27,100, mA
IDE08949-MAS07897,Operating current: light driver-Conn. pin 30,40, mA
IDE09065-MAS07963,Status: remote start-Number of permissible remote starts,2.0,
IDE09065-MAS07964,Status: remote start-Engine run time after remote start,600.0, s
IDE09850-MAS07146,Garage door opener control head-Button 1,not coded/not installed,
IDE09850-MAS07147,Garage door opener control head-Button 2,not coded/not installed,
IDE09850-MAS07148,Garage door opener control head-Button 3,not coded/not installed,
IDE11134-IDE01943,Light sequence HU test result-Turn signal lamp,installed_not_active,
IDE11134-IDE02515,Light sequence HU test result-Low beam,installed_not_active,
IDE11134-IDE02614,Light sequence HU test result-Reversing light switch,installed_not_active,
IDE11134-IDE02743,Light sequence HU test result-High Beam,installed_not_active,
IDE11134-IDE03310,Light sequence HU test result-Brake lamp,installed_not_active,
IDE11134-IDE03638,Light sequence HU test result-Stationary cornering lamp,installed_not_active,
IDE11134-IDE05323,Light sequence HU test result-Fog lamp,installed_not_active,
IDE11134-IDE05839,Light sequence HU test result-Parking lamps,installed_not_active,
IDE11134-IDE06470,Light sequence HU test result-Periphery lighting,not_installed_not_active,
IDE11134-IDE06864,Light sequence HU test result-Daytime running lamps,installed_not_active,
IDE11134-MAS02354,Light sequence HU test result-Headlamp flasher,installed_not_active,
IDE11134-MAS03835,Light sequence HU test result-Position lamps,installed_not_active,
IDE11134-MAS03836,Light sequence HU test result-Rear fog lamp,installed_not_active,
IDE11134-MAS11025,Light sequence HU test result-Status,0,
IDE11727-MAS13125,Function of the central console button-Function of button 1,Start-stop,
IDE11727-MAS13129,Function of the central console button-Function of button 2,GTE,
IDE11727-MAS13132,Function of the central console button-Function of button 3,Driving program,
IDE11727-MAS13135,Function of the central console button-Function of button 4,Steering wheel heating,
IDE80251-MAS06439,Head area heater-Crash status,not coded/not installed,
IDE80251-MAS06646,Head area heater-Head area heater left: specified level,not coded/not installed,
IDE80251-MAS06647,Head area heater-Head area heater right: specified level,not coded/not installed,
IDE80251-MAS06648,Head area heater-Continuation at terminal 15 on,not coded/not installed,
IDE80251-MAS06649,Head area heater-Left front seat occupation status,not coded/not installed,
IDE80251-MAS06650,Head area heater-Right front occupation status,not coded/not installed,
MAS00043-IDE00019,Terminal 30 power supply-Voltage terminal 30,14.40, V
MAS00043-IDE05835,Terminal 30 power supply-Supply voltage for central locking,14.40, V
MAS00043-IDE05967,Terminal 30 power supply-Voltage terminal 30 left,14.40, V
MAS00043-IDE05968,Terminal 30 power supply-Voltage terminal 30 right,14.30, V
MAS00043-IDE08734,Terminal 30 power supply-Supply voltage for anti-theft alarm system,5.00, V
MAS00043-IDE08735,Terminal 30 power supply-Supply voltage for seat heater,14.40, V
MAS00043-MAS00362,Terminal 30 power supply-Battery voltage,5.00, V
MAS00043-MAS07472,Terminal 30 power supply-Battery voltage BEM,14.55, V
MAS00043-MAS07473,Terminal 30 power supply-Test voltage rear window defogger,0.00, V
MAS00043-MAS07474,Terminal 30 power supply-Test voltage windshield defogger,0.00, V
MAS00179-MAS04422,Brake lamp switch-Brake light signal via CAN,OFF,
MAS00179-MAS07313,Brake lamp switch-Brake light signal via HW,OFF,
MAS00464-MAS00106,Standard - ambient data 1-Year,2023,
MAS00464-MAS00107,Standard - ambient data 1-Month,9,
MAS00464-MAS00108,Standard - ambient data 1-Day,18,
MAS00464-MAS00109,Standard - ambient data 1-Hours,17,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,19,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,34,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,156,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,224815, km
MAS00829-MAS00244,Access/start authorization-Prompt wire,Not operated,
MAS00829-MAS01763,Access/start authorization-Signal Strength,-52,
MAS00829-MAS07866,Access/start authorization-Duration: last awakening wire actua.,5, ms
MAS01281,Back-up lamp,|Connector number,Connector terminal number,Duty cycle,Signal state,Diagnosis|Connector A,64,0.00,not active,normal|,
MAS01431-IDE01442,Vehicle key with remote control-Pressing a button,Not operated,
MAS01431-IDE01839,Vehicle key with remote control-Battery charge level,Not available,
MAS01431-MAS00077,Vehicle key with remote control-Immobilizer,OK,
MAS01431-MAS01551,Vehicle key with remote control-Key number,255,
MAS01431-MAS05048,Vehicle key with remote control-Number of transmitters adapted,2,
MAS01431-MAS06362,Vehicle key with remote control-Code in catch area,Not available,
MAS01490-IDE02744,Energy management-Steering wheel heating,Enabled,
MAS01490-IDE04216,Energy management-Mirror heater,Enabled,
MAS01490-IDE80251,Energy management-Head area heater,not coded/not installed,
MAS01490-MAS01535,Energy management-Rear window defogger,Enabled,
MAS01490-MAS01563,Energy management-Auxiliary Air Heater,Enabling stage 3,
MAS01490-MAS01564,Energy management-Front windshield heater,Enabled,
MAS01490-MAS01632,Energy management-Status,not active,
MAS01490-MAS02390,Energy management-Shutoff,2228,
MAS01490-MAS05795,Energy management-Rear seat heater,Enabled,
MAS01490-MAS05796,Energy management-Emergency shut-down,0,
MAS01490-MAS05887,Energy management-Battery cut out relay 2,not enabled,
MAS01490-MAS06551,Energy management-Seat ventilation,not coded/not installed,
MAS01490-MAS06552,Energy management-Front seat heating,Enabling stage 3,
MAS01490-MAS06553,Energy management-Display consumer switch-off,not active,
MAS01490-MAS06554,Energy management-Switch-off priority while driving,0,
MAS01490-MAS06555,Energy management-Maximum switch-off priority while driving,6,
MAS01490-MAS06556,Energy management-Switch-off with voltage drops,0,
MAS01490-MAS06557,Energy management-Switch-off priority with vehicle crash,0,
MAS01490-MAS06558,Energy management-Current negative charge balance,6, %
MAS01490-MAS06559,Energy management-Switch-off priority with engine off,0,
MAS01490-MAS06560,Energy management-Short distance driving,0,
MAS01597-IDE00542,Sunroof-Excessive temperature protection,Write only channel,
MAS01597-IDE03114,Sunroof-Comfort function,Write only channel,
MAS01597-MAS01979,Sunroof-Adapting,Write only channel,
MAS01597-MAS02282,Sunroof-Position,Write only channel, %
MAS01597-MAS02447,Sunroof-Release,Write only channel,
MAS01597-MAS03656,Sunroof-Reverse,Write only channel,
MAS01597-MAS05563,Sunroof-Norming,Write only channel,
MAS01597-MAS05737,Sunroof-Position,Write only channel,
MAS03835,Position lamps,|Connector number,Connector terminal number,Duty cycle,Signal state,Diagnosis|Connector B,10,27.50,active,normal|Connector B,21,27.50,active,normal|Connector B,4,100.00,active,normal|Connector B,32,100.00,active,normal|Plug C,9,88.50,active,normal|Connector B,3,88.50,active,normal|Plug C,10,88.50,active,normal|Connector A,65,88.50,active,normal|Connector A,59,100.00,active,normal|Plug C,6,88.50,active,normal|,
MAS03836,Rear fog lamp,|Connector number,Connector terminal number,Duty cycle,Signal state,Diagnosis|Connector A,72,0.00,not active,normal|Plug C,6,88.50,active,normal|Plug C,11,0.00,not active,normal|,
MAS07959,Remote start history data,|Remote_Start_Stop_Abort_Trigger,Abortion_reason,Month,Day,Hours,Minutes|no_reason_for_prohibition,no_reason_for_abortion,15,31,31,63|remotestart_is_active,car_movement_detected,0,0,0,0|no_reason_for_prohibition,no_reason_for_abortion,15,31,31,63|remotestart_is_active,car_movement_detected,0,0,0,0|no_reason_for_prohibition,no_reason_for_abortion,15,31,31,63|remotestart_is_active,car_movement_detected,0,0,0,0|no_reason_for_prohibition,no_reason_for_abortion,15,31,31,63|remotestart_is_active,car_movement_detected,0,0,0,0|no_reason_for_prohibition,no_reason_for_abortion,15,31,31,63|remotestart_is_active,car_movement_detected,0,0,0,0|no_reason_for_prohibition,no_reason_for_abortion,15,31,31,63|remotestart_is_active,car_movement_detected,0,0,0,0|no_reason_for_prohibition,no_reason_for_abortion,15,31,31,63|remotestart_is_active,car_movement_detected,0,0,0,0|no_reason_for_prohibition,no_reason_for_abortion,15,31,31,63|remotestart_is_active,car_movement_detected,0,0,0,0|,
MAS08228-MAS01632,Light sensor-Status,not coded/not installed,
MAS08228-MAS02851,Light sensor-Brightness,not coded/not installed,
MAS08228-MAS04121,Light sensor-Voltage,not coded/not installed,
MAS13141,Test voltage,0, V
ENG116910,Control unit internal measured value (supplier),31,
ENG117285-ENG115840,Cycle_Protection_Counter-general_cycle_protection_counter,0,
ENG117285-ENG124947,Cycle_Protection_Counter-last_wake_up,keine Stoerschutzursache,
ENG116908-ENG115779,Ecu_Intern_Meas._Values_2-Betriebsstunden_Abblendlicht_an,0, H
ENG116908-ENG115778,Ecu_Intern_Meas._Values_2-Hours_of_operation,0, H
ENG116908-ENG115775,Ecu_Intern_Meas._Values_2-Hours_of_operation_front_window_wiper,0,
ENG116908-ENG115776,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_front_window_wiper,0,
ENG116908-ENG115777,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_rear_window_wiper,0,
ENG116813-ENG115632,Entwicklermesswerte_CONTI-Kurzschlussz hler 0..99,|KurzSchlussZaehler|0|,
ENG117286-ENG116724,Kopfraumheizung_Entwicklung-KRH_l_Error,not coded/not installed,
ENG117286-ENG116725,Kopfraumheizung_Entwicklung-KRH_l_Error_Gueltigkeit,not coded/not installed,
ENG117286-ENG116723,Kopfraumheizung_Entwicklung-KRH_l_Luefter_Error,not coded/not installed,
ENG117286-ENG116727,Kopfraumheizung_Entwicklung-KRH_l_PTC_Error,not coded/not installed,
ENG117286-ENG116726,Kopfraumheizung_Entwicklung-KRH_l_ResponseError,not coded/not installed,
ENG117286-ENG116730,Kopfraumheizung_Entwicklung-KRH_r_Error,not coded/not installed,
ENG117286-ENG116731,Kopfraumheizung_Entwicklung-KRH_r_Error_Gueltigkeit,not coded/not installed,
ENG117286-ENG116728,Kopfraumheizung_Entwicklung-KRH_r_Luefter_Error,not coded/not installed,
ENG117286-ENG116729,Kopfraumheizung_Entwicklung-KRH_r_PTC_Error,not coded/not installed,
ENG117286-ENG116732,Kopfraumheizung_Entwicklung-KRH_r_ResponseError,not coded/not installed,
ENG116909-ENG107391,LIN activity-LIN 1,active,
ENG116909-ENG107392,LIN activity-LIN 2,active,
ENG116909-ENG114948,LIN activity-LIN 3,active,
ENG116909-ENG114949,LIN activity-LIN 4,not coded/not installed,
ENG116909-ENG114950,LIN activity-LIN 5,not coded/not installed,
ENG116909-ENG114951,LIN activity-LIN 6,not coded/not installed,
ENG128380,Parametermonitor_0,82 14 01 01 A0 00 00 00 00 00 00 00 00 00 00 00 50 50 32 32 00 50 50 50 50 3E 3E 62 62 00 00 64 3C 01 21 21 0A 04 00 00 1E 00 00 00 00 00 00 00 06 06 28 00 3C 03 1E 22 00 04 19 05 00 01 01 28 00 02 00 02 1E 64 05 B4 1E 00 00 00 00 00 14 1D 5A 96 02 05 0A 6E 96 05 00 00 00 00 00 00 00 00 0A 1E 3C 42 0F 00 00 00 00 00 00 00 00 00 00 00 64 0A 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 5A 19 E1 32 01 0A 00 00 00 00 00 A0 00 00 00 A0 00 00 00 A0 06 0C 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116806,Parametermonitor_1,00 00 00 00 00 00 00 05 00 00 00 00 00 00 14 00 00 00 00 00 00 14 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 64 64 64 64 64 00 64 64 64 64 64 64 64 64 3C 00 60 7E 7F 60 60 7E 60 60 60 7F 60 60 60 60 28 00 46 7E 7F 46 46 7E 46 46 46 7F 46 46 46 46 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 3C 00 60 7E 7F 60 60 7E 60 60 60 7F 60 60 60 60 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 28 3C 3C 7E 7F 3C 3C 7E 3C 3C 3C 7F 3C 3C 3C 3C 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 01 01 00 00 00 00 00 00 01 3C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG130145,Parametermonitor_10,00 00 00 00 00 00 00 00 00 0C 44 80 40 01 3C B8 00 0C 48 E8 00 0C 45 40 00 00 00 02 18 8C CE 34 40 00 7C 20 40 01 3B 48 00 00 00 00 00 00 00 04 00 00 00 02 40 00 AF 40 40 00 AF A0 FF F4 80 08 40 01 3B F0 00 00 80 00 00 0C 44 68 FF FF FF FF 40 01 3B E8 00 00 00 0F 00 00 00 7F 00 02 B4 F4 40 01 3B F8 00 02 B4 FA 40 01 3C 00 18 8C CE DE 40 01 3C 20 00 00 00 08 40 01 3C 40 FF FF FF FF 00 00 00 01 40 00 D0 60 40 01 3C 40 40 01 05 C4 57 56 57 5A 5A 5A 33 43 40 01 3C 40 30 36 39 34 32 00 00 01 00 00 00 00 40 01 3C 40 40 00 D0 53 40 01 3C 40 40 00 D0 45 40 01 3C 68 00 07 85 E2 40 01 04 91 40 01 04 9B 40 01 3C 58 00 00 00 0F 40 01 3C 68 00 07 89 40 40 01 3C 68 00 00 00 00 40 01 3C 90 00 07 8C 7E 00 00 00 00 00 FF FF FF 00 00 00 01 00 00 00 0F 40 01 3C A0 FF F4 80 08,
ENG116807,Parametermonitor_2,0F 05 0A 00 16 00 00 14 28 05 00 14 32 5A 32 0A 1E 12 03 00 0A 01 1E 5A 0F 3C 3C 05 0A 02 0A 78 00 FA 01 1C 14 0F 00 05 0A 14 03 02 00 19 64 00 64 1E 32 18 18 7D 28 05 28 28 7D 3C 3C 7D 7D 0A 19 3C 7D 2B 14 00 02 00 00 01 28 0A 28 19 0A 23 04 C8 FA 18 16 88 00 1E 05 00 01 C8 32 C8 14 00 5A 03 00 03 03 00 00 04 01 05 32 00 32 3C 03 32 00 32 3C 03 00 00 00 00 00 00 00 00 00 00 00 00 0F 14 50 78 32 3C 02 58 00 00 0A 6E 05 64 28 00 0A 06 05 02 0A 28 00 00 00 00 00 00 00 00 00 00 14 14 14 00 32 46 00 00 1E 28 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116808-ENG115827,Parametermonitor_3-parameter_monitor_3_climatic,FF 02 32 00 5A FF 80 05 05 00 00 00 00 00 00 00 80 FF 02 32 5A 00 05 00 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 0A 28 0F 1E 06 1E 0A 0B 0A 01 64 64 03 0A 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116808-ENG115828,Parametermonitor_3-parameter_monitor_3_wiper,0A 00 00 19 19 00 03 06 19 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 50 46 00 58 8B FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116809,Parametermonitor_4,04 04 14 1E 00 B4 00 0A 05 05 0A 4B 4B 32 0A 03 00 1E 32 06 00 00 00 00 00 00 00 00 00 00 00 00 01 02 02 01 0A 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 04 0C 78 04 04 0C 01 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2A 3E 00 00 00 00 00 00 00 00 00 00 00 05 03 00 00 00 00 00 00 00 00 00 00 00 00 00 0A FF 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 03 0A 00 00 00 00 00 04 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 32 28 00 00 00 00 00 05 05 3C 04 01 01 01 01 96 01 01 C8 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 EF FE FD FF 00 00 00 00 00 00 00 00 00 00 00 00 3C 14 37 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116810,Parametermonitor_5,0A 00 0C 08 09 0A 05 0A 0A 14 08 0A 03 00 0A 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 04 00 00 1E 0A 05 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 55 00 03 09 01 0F 00 00 00 00 00 00 05 0F 96 00 00 30 03 0B 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116811,Parametermonitor_6,00 46 32 FA 3C 00 1E 32 05 04 3C 00 08 05 01 00 01 00 00 00 05 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116911,Parametermonitor_7,00 0A 00 0A 00 0A FF FF 00 0A 00 0A FF FF FF FF 0F A0 00 32 00 32 00 32 00 32 00 32 00 0A 00 0A 00 32 FF FE 00 0A 00 32 00 32 00 00 00 0A 00 0A 00 00 FF FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116812,Parametermonitor_FF,00 00 05 30 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG126653,Personalized_Account_Key_History,|Key number,Account,Month,Day,Hours,Minutes,Seconds|1,1,0,0,0,0,0|2,2,0,0,0,0,0|1,1,0,0,0,0,0|2,2,0,0,0,0,0|1,1,0,0,0,0,0|2,2,0,0,0,0,0|1,1,0,0,0,0,0|2,2,0,0,0,0,0|,
ENG126652-MAS03692,Personalized_key__Setting-Key 1,1,
ENG126652-MAS03693,Personalized_key__Setting-Key 2,2,
ENG126652-MAS03694,Personalized_key__Setting-Key 3,0,
ENG126652-MAS03695,Personalized_key__Setting-Key 4,0,
ENG126652-MAS03696,Personalized_key__Setting-Key 5,0,
ENG126652-MAS03697,Personalized_key__Setting-Key 6,0,
ENG126652-MAS03698,Personalized_key__Setting-Key 7,0,
ENG126654,Personalized_Signals,|Perso_Steuerungs_parameter,Perso_Steuerung,Perso_Konto,Perso_Freigabe_Verstellung,Perso_Bedienstelle,Perso_Status,Month,Day,Hours,Minutes,Seconds|0,0,1,0,0,1,0,0,0,0,0|0,0,2,0,0,1,0,0,0,0,0|0,0,1,0,0,1,0,0,0,0,0|0,0,2,0,0,1,0,0,0,0,0|0,0,1,0,0,1,0,0,0,0,0|0,0,2,0,0,1,0,0,0,0,0|,
ENG116792-ENG115817,Power up history-Funktionsanforderung,|Funktionsanforderung|10|10|10|10|10|10|10|10|10|10|,
ENG116805-ENG121648,Rain sensor parameter-rb_CloseTypeStandby_g,0,
ENG116805-ENG121657,Rain sensor parameter-rb_Errorflags_g,0,
ENG116805-ENG121651,Rain sensor parameter-rb_HumTemp_ErrorCode_g,0,
ENG116805-ENG121656,Rain sensor parameter-rb_Max_WDGFastTaskCounter_g,71,
ENG116805-ENG121655,Rain sensor parameter-rb_Min_WDGFastTaskCounter_g,69,
ENG116805-ENG121653,Rain sensor parameter-rb_NoCommunicationCounter,0,
ENG116805-ENG121641,Rain sensor parameter-rb_PotiStageFromBox_g,0,
ENG116805-ENG121642,Rain sensor parameter-rb_PWM_Voltage_g,169,
ENG116805-ENG121652,Rain sensor parameter-rb_StaticNoCommunicationCounter,0,
ENG116805-ENG121654,Rain sensor parameter-rb_SupplyVoltage_mg,144,
ENG116805-ENG121640,Rain sensor parameter-rub_Empf_Faktor,0,
ENG116805-ENG121639,Rain sensor parameter-rub_Int_Speicher,0,
ENG116805-ENG121645,Rain sensor parameter-rub_LengthCounter,5,
ENG116805-ENG121643,Rain sensor parameter-rub_Nachwisch_Count,0,
ENG116805-ENG121638,Rain sensor parameter-rub_Ovr_Speicher,0,
ENG116805-ENG121646,Rain sensor parameter-rub_PulseCounter,1,
ENG116805-ENG121647,Rain sensor parameter-rub_SignalIntegral_g,0,
ENG116805-ENG121644,Rain sensor parameter-ruw_StX_Speicher,0,
ENG116805-ENG121650,Rain sensor parameter-rw_HumiTicks_g,1696,
ENG116805-ENG121649,Rain sensor parameter-rw_TempTicks_g,22.88,  C
ENG130589-ENG130618,Remotestart_Monitor-Double_remote_start_activations,0,
ENG130589-ENG130615,Remotestart_Monitor-Klemme_15_Zaehler,0,
ENG130589-ENG130616,Remotestart_Monitor-Remote_start_activations,0,
ENG130589-ENG130617,Remotestart_Monitor-Remote_start_directly_followed_by_driving_cycle,0,
ENG124897-ENG124955,Resetcounter_EMW-3.letzte Resetursache,8,
ENG124897-ENG124956,Resetcounter_EMW-4.letzte Resetursach,0,
ENG124897-ENG114872,Resetcounter_EMW-last cause of reset,0,
ENG124897-ENG115805,Resetcounter_EMW-Number of resets,2,
ENG124897-ENG124954,Resetcounter_EMW-vorletzte Resetursache,0,
ENG116790-MAS00711,Supply voltage history-Odometer reading,90817, km
ENG116790-ENG115814,Supply voltage history-highest voltage ever measured,15.60, V
ENG116790-ENG115815,Supply voltage history-hoechste im letzten Fahrzyklus gemessen Batteriespannung,14.40, V
ENG116790-ENG115816,Supply voltage history-voltage measurement: intern,14.40, V
ENG116791,Temperatures,29.00,  C
ENG116907-IDE00020,Zusaetzliche Umgebungsdaten-Terminal 15 status,On,
ENG116907-IDE01716,Zusaetzliche Umgebungsdaten-Terminal 50 status,OFF,
ENG116907-IDE02515,Zusaetzliche Umgebungsdaten-Low beam,Not operated,
ENG116907-IDE07956,Zusaetzliche Umgebungsdaten-redundant signal line,infinite,
ENG116907-MAS00063,Zusaetzliche Umgebungsdaten-OFF,Not operated,
ENG116907-MAS01957,Zusaetzliche Umgebungsdaten-Outside temperature,29.00,  C
ENG116907-MAS02462,Zusaetzliche Umgebungsdaten-Automatic high beam assist,operated,
ENG116907-MAS02788,Zusaetzliche Umgebungsdaten-CAN,On,
ENG116907-MAS03835,Zusaetzliche Umgebungsdaten-Position lamps,Not operated,
ENG116907-MAS04121,Zusaetzliche Umgebungsdaten-Voltage,14.40, V
ENG116907-MAS06466,Zusaetzliche Umgebungsdaten-Parking light left,Not operated,
ENG116907-MAS06467,Zusaetzliche Umgebungsdaten-Parking light right,Not operated,
ENG116907-ENG124952,Zusaetzliche Umgebungsdaten-last_wakeup,keine Stoerschutzursache,
ENG116907-ENG115838,Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN),OFF,
ENG116907-ENG115837,Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW),OFF,
Elapsed Time: 00:47
Hey, IDE05833 looks pretty interesting:
Let's reformat that:
The only thing from this year is the Incline Sensor...
MrJC
Sweden
C?ID=220437
Yeah, it was when I wanted to see how much in sounded when I lifted the car.
Just sad that it didn’t catch when the window was cracked.
Really thankful for the help!
