Auto Headlights Sensitivity (LUX Rating) (2018 Multivan)
State-808
C?ID=522224
Hi All, I'm seeing a lot of conflicting reports on weather one can Adjust the "Auto Headlights Sensitivity" in LUX Ratings and nothing concrete here.
My Multivan @ 07:00 Hrs Sun is shining, and the Headlights are on! What?
So I would like to Code the Headlights not to be so sensitive to Shade/Dim Light.
Is this possible?
Thanks...
Thursday,24,November,2022,17:54:43:04215
VCDS Version: 22.10.0.1 (x64)  HEX-V2 CB: 0.4623.4
VIN: WV1ZZZ7HZCH068233   License Plate:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 09 15 17 19 25 56 0B
VIN: WV1ZZZ7HZCH068233   Mileage: 223180km-138677miles
01-Engine -- Status: Sporadic communication error 1000
Address 01: Engine (J623-CAAA)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 022 CB    HW: 03L 907 309 K
   Component: R4 2,0L EDC   X43 9116
   Revision: 26X43---    Serial number: 00000000000000 CVN: 76CFFF03
   Coding: 01114010230400080000
   Shop #: WSC 02736 790 50316
   ASAM Dataset: EV_ECM20TDI01103L906022CB 002012
   ROD: EV_ECM20TDI01103L906022CB_002.rod
   VCID: 678BB6041FECD3434A8-8032
   VINID: 9E606AAAA1D8A936001880830C8A65C403
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 H    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0107
   Revision: 00H43001
   Coding: 508724AD89AA0A9D24A49174A96110
   Shop #: WSC 02736 790 49152
   VCID: 372B26440F4C83C31A8-8062
                    Reset counter: 78
                    Mileage: 223189 km
                    Date: 2017.04.14
                    Time: 21:22:16
                    Count: 16384
                    Count: 1
                    Count: 8194
                    Count: 764
   Part No SW: 7H0 937 086 H    HW: 7H0 937 086
   Component: BCM T5GP M++4 H47 0251
   Revision: BM047001    Serial number: 0428 311110363
   Coding: A0A0303A0E212031002008102C2B8C500000430F60060000300000000000
   Shop #: WSC 02736 790 00000
   VCID: 3829257802528CBB132-806C
   Subsystem 1 - Part No SW: 7E0 959 801 B    HW: 7E0 959 801 B  Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3311
   Subsystem 2 - Part No SW: 7E0 959 802 B    HW: 7E0 959 802 B  Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3311
00538 - Reference Voltage
                    Fault Status: 00101011
                    Reset counter: 118
   Component: VW10Airbag009 H06 0013
   Revision: --------    Serial number: 003HL008SR0I
   Shop #: WSC 02734 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 35372C4C15C071D3084-8060
   Part No SW: 7E0 920 960 E    HW: 7E0 920 960 E
   Component: KOMBI         H04 0305
   Coding: 460200
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   VCID: 2B030A34C38437236E0-807E
   Part No SW: 6N0 909 901     HW: 7H0 937 086
   Component: GW-K-CAN TP20 H47 0251
   Revision: BM047001
   Coding: 042300
   VCID: 70B9DD582AA214FB1B2-8024
                    Reset counter: 78
                    Mileage: 92922 km
                    Date: 2016.07.08
                    Time: 18:35:44
                    Reset counter: 118
                    Mileage: 223189 km
                    Date: 2017.04.14
                    Time: 21:22:17
   Component: IMMO          H04 0305
   VCID: 6A8DCF300CFEEE2B556-803E
Address 56: Radio
End----(Elapsed Time: 01:28, VBatt start/end: 11.5V/11.5V. VIgn 11.4V)-----
I'm confused. I see no Rain/Light Sensor in your scan, and your BCM doesn't seem to be coded for one either.
State-808
C?ID=522224
Hi Uwe, I can asure you it does have the rain sensor. (and it works well)
I will check my cut'n'paste, maybe I screwed up...:confused:
siLc
Tallinn, Estonia
C?ID=330192
T6 windscreen, interior mirror and newer model factory RLS fitted?
State-808
C?ID=522224
Yes 2018 Model Multivan, with LED Headlights
Strange, because normally they're visible as a sub-system in one of the control modules.
State-808
C?ID=522224
Thank you NEtech for making me aware of my mistake...:banghead:
Yes I messed up with my cut 'n' paste... (sorry)
here's a new fresh Autoscan...:cool:
Monday,18,September,2023,16:39:48:14270
VCDS Version: 23.3.1.0 (x64)  HEX-V2 CB: 0.4631.4
VIN: WV2ZZZ7HZJH037065   License Plate:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 13 15 17 18 19 25 55 5F 61 69 6E 0B
VIN: WV2ZZZ7HZJH037065   Mileage: 82550km-51294miles
6E-Ctrl Head Roof -- Status: OK 0000
Address 01: Engine (J623-CJKB)       Labels:. 06J-907-309-V2.clb
   Part No SW: 06J 906 021 AC    HW: 06J 907 309 C
   Component: 2.0l R4 T-FSI H03 2032
   Revision: ELH03---    Serial number: 00000000000000 CVN: 069D5DD9
   Coding: 0119001B435401080000
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_ECM20TFS01106J906021AC 001005
   ROD: EV_ECM20TFS01106J906021AC.rod
   VCID: 6694B42ED8E4B6DA957-8032
   VINID: 9E60AAAAA1D8A9A6000C70061442F5F034
   Revision: 00000000    Serial number: 62087000002046
   Coding: 307E4398256584850C75C27CA48721D378F500
   Shop #: WSC 02739 790 50316
   VCID: 3FDA414AE7FEC712361-806A
   Serial number: 30071713470034
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA4FC4EA0740E1A7D7-802A
Address 08: Auto HVAC (J255)       Labels:| 7E5-907-040.clb
   Part No SW: 7E0 907 040 R    HW: 7E0 907 040 R
   Component: ClimatronicT5 H04 0613
   Revision: 00001K04
   Coding: 0004000103
   ASAM Dataset: EV_ClimatronicT5 A01003
   ROD: EV_ClimaAutoT5Basis.rod
   VCID: 323C187E24AC1A7AC9F-8066
   Slave 1:
   Subsystem 1 - Part No SW: 7E5 907 049 C    HW: 7E5 907 049 C
   Component: Heckbedienung  H11 0303
   Serial number: BHB-0010108170015284
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Component: BCM PQ25 Max4 H82 0752
   Revision: B9082001    Serial number: 4000 206172101
   Coding: 62A8393A0A21201301280F602CEB8FD4C0D47389604579603304003F0860
   Shop #: WSC 02739 022 119508
   VCID: 2B02051A03064BB28A9-807E
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 280717 04  42  0106
   Coding: 0228DD
   Subsystem 2 - Part No SW: 7E0 959 801 N    HW: 7E0 959 801 N  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  003 0653
   Serial number: KU0KU002081772141558
   Coding: 0400A1
   Subsystem 3 - Part No SW: 7E0 959 802 R    HW: 7E0 959 802 R  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  004 0653
   Serial number: KU0KU002081772140338
   Coding: 1400A1
   Subsystem 4 - Part No SW: 7E0 959 442 A    HW: 7E0 959 442 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H02 0103
   Serial number: 39170001879460037274
   Coding: B4FFFF
   Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0212
   Revision: --------    Serial number: 28261717800587
   Coding: 118009
   ASAM Dataset: EV_VW75XParkAssis8K 001012
   ROD: EV_VW75XParkAssis8K_001_VN75.rod
   VCID: 71BED772E12A6162F05-8024
   Part No SW: 7N0 907 572 C    HW: 7E0 907 572
   Serial number: 2407170452A209 Dataset Number: 7E0114v____ 0009
   Coding: 00004800FE0779
   Shop #: WSC 01383 790 50316
   ROD: EV_ACCBEGVW361.rod
   VCID: 3634246EC8C4065AE57-8062
   Part No SW: 7E0 959 655 H    HW: 7E0 959 655 H
   Component: VW10Airbag01V H08 0018
   Revision: --------    Serial number: 003V40039LM7 Dataset Number: 7E0003V____ 0912
   Coding: 000000000000000000000000000000003156
   VCID: 3B22355AF3E6DB321A9-806E
   Serial number: 3495ZRB400M59OGCGPQ
   Serial number: 3505ZRB400659GF2Q1CA
   Serial number: 3515ZRB400M59OGCC22N
   Serial number: 3525ZRB400O59OGCF8C2
   Part No SW: 7E0 920 870 R    HW: 7E0 920 870 R
   Component: KOMBI         H03 1107
   Coding: 140F010200
   VCID: 38282A56C2D0F02AF7B-806C
Address 18: Aux. Heat (J364)       Labels:| 7E0-963-27X-18.clb
   Part No SW: 7E0 963 272 C    HW: 7E0 963 272 C
   Component: STH-T5GP2     003 0009
   Coding: 4401
   ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001013
   ROD: EV_AuxilParkiHeateWOST5G2.rod
   VCID: 2C00060606884C8A833-8078
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Component: GW-K-CAN TP20 H82 0752
   Revision: B9082001
   Coding: 042205
   VCID: 6888BA16D270A0AAA7B-803C
   Component: IMMO          H03 1107
   VCID: 6A8CC01ECCFC92BAB1F-803E
Address 55: Headlight Range (J431)       Labels:. 6R0-907-357.clb
   Part No SW: 6R0 907 357 C    HW: 6R0 907 357 B
   Component: AFS-ECU       005 0050
   Revision: --------    Serial number: -------------- Dataset Number: V03600097E0 0001
   Coding: 0FCA020001000000
   Shop #: WSC 02757 790 50316
   ASAM Dataset: EV_HeadlRegulVWLWRCC 002006
   ROD: EV_HeadlRegulVWLWRCC.rod
   VCID: 3A2C305EFCDCE23A01F-806E
   Part No SW: 1K8 035 150 H    HW: 1K8 035 150 H
   Component: MU-E--ER      056 7205
   Serial number: 11071700011436 Dataset Number: V03935266VJ 0001
   Coding: 06570000BE00000041110001000000001F0000C40000010001
   ROD: EV_MUEnt4CGen2LGE_VW32.rod
   VCID: 2A0C001E0C7C52BA71F-807E
   Part No SW: 7E0 907 534     HW: 7E0 937 090 C
   Component: Batt.regelung H82 0752
   Coding: 332B1A59
   Shop #: WSC 02739 790 00000
   Subsystem 1 - Part No SW: 7E0 915 181 K    HW: 7E0 915 181 K
   Serial number: 758857000017072400C6
   Part No SW: 1K0 907 383 H    HW: 1K0 907 383 G
   Component: Anhaenger     H12 0130
   Revision: 3B001001    Serial number: 00000449944386
   Coding: 410D000103000000
   VCID: 323C187E242C1A7AC9F-8066
Address 6E: Ctrl Head Roof (J702)       Labels:. 7E5-919-037-W2.clb
   Part No SW: 7E5 919 037 J    HW: 7E5 919 037 J
   Component: Dachdisplay   H17 0200
   Revision: 10100013    Serial number: 503357
   Coding: 000102
   Shop #: WSC 02759 790 00000
   VCID: 38282A56C250F02AF7B-806C
End----------(Elapsed Time: 01:41, VBatt start/end: 12.2V/12.3V)-----------
And look, there's a Rain & Light sensor here!
   Coding: 0228DD
And coding for it is documented in a label file. But no, you can't adjust it by "lux". VAG doesn't do that, not for tire sizes, or for light sensors. It looks like you can change the activation threshold to be sensitive, but not less (Byte 0). Perhaps turning down the value in Byte 1?
State-808
C?ID=522224
Thank you Uwe for your Time...
I don't suppose you know of a Video tutorial/guide?
Where do I find this file?
iichel
Netherlands, Operation Market Garden
C?ID=284912
go to 09 central electrics, coding, select the RLS in the drop down menu and press long code helper
State-808
C?ID=522224
Thanks iichel, I'll take a look. Sounds scary!:eek:
State-808
C?ID=522224
:thanks:
Cuzoe
C?ID=279487
Let me start this post by saying if this link is not allowed please delete the link and/or post. My feelings will not be hurt and I will understand the message completely 😬.
The adaptation mentioned here, for which will have to try some different values...
In the German: helligkeitgrenze sehr hell
Translates to: brightness limit very bright
Please, please record your current value(s) first.
iichel
C?ID=284912
That's a really nice post and you can always have a look at your adaplog.csv and codinglog.csv to revert.
The car that's mentioned on the russian site is an MQB car, those informations don't generally apply to the PQ25 platform-based T6.
State-808
C?ID=522224
Yes done that, so I changed it from 04 to 02
Have to wait until tomorrow morning to see how the change reacts... :p
Color me confused. I the picture you posted, I see you changing Byte 0 of your driver's side Door Controller, not Byte 1 of the Rain/Light sensor.
I'm confident that no change you can possibly make to the TürSteuerGerät_FahrerTür will produce the results you were looking for at the beginning of this thread. ;)
State-808
C?ID=522224
Hahahaaa... You got me (again):facepalm:
Finger trouble with my touch screen (I have fat German sausage fingers:ohaha) RLS is the menu above, and I didn't Check the title of the Position.
Lesson learned!!!:p
So here are two correct screen shots. RLS menu and the drop down menu.
By the looks of things I'm on standard and I can't go less sensitive. Only more sensitive, am I reading that correctly?
