Resolved Transporter TPMS
Resolved
Busyguy
V2-2H
Hello im new here and not up to speed with VCDS
I have a 2020 transporter with tpms sensors fitted in the wheels.
The problem i have is that the tyres fitted to the new 20s only have a max pressure of 50psi (3.5bar) and i cant find any tyres that have a higher max pressure but the van is asking to see 4Bar on the front tyres and 3.5Bar on the rear tyres.
I want to know if its possible to reset the van so it only want to see 3.5Bar or maybe a little less?
I can see required pressure and actual pressures on the screen in the dash and also on the screen in the middle.
Any help would be great thanks. Brian.
Dont know if this question should be here or somewhere else on the forum.
Please post an Auto-Scan so people can see how this van is equipped and configured.
Busyguy
V2-2H
Saturday,16,September,2023,08:47:18:23673
VCDS Version: 23.3.1.0 (x64)  HEX-V2 CB: 0.4631.4
VIN: WV1ZZZ7HZLX010089   License Plate:
Chassis Type: 7H-VN46 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 44 55 5F 65 75 D6 D7
VIN: WV1ZZZ7HZLX010089   Mileage: 43862km-27254miles
Address 01: Engine (J623-CXHA)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 SA    HW: 04L 907 445 M
   Component: R4 2.0l TDI   H01 9697
   Revision: 23301001
   Coding: 002540144364050900000000000000000000000000000000
   Shop #: WSC 00035 377 00141
   ASAM Dataset: EV_ECM20TDI03004L906056SA 004004
   ROD: EV_ECM20TDI03004L906056QF_004.rod
   VCID: 7EA407135072B26A7D7-802A
   VINID: 9E606AAAA1D8A9CA0004000824F69E0B55
32127 - Particulate Matter Sensor Temperature
          P24C7 00 [032] - Implausible Signal
          [Particulate Matter Sensor TemperatureCircuit Range/performance]
                    Mileage: 43644 km
                    Engine RPM: 0.00 /min
                    Coolant temperature: 34 °C
                    Intake air temperature: 17 °C
                    Voltage terminal 30: 12.671 V
                    Air mass at air mass meter 1: 0.0 kg/h
                    Standardized air flow ratio: 1.000 counts
                    Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: -110.75 %
                    Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 0.00 %
                    Charge air pressure: specified value: 0.000 bar
                    Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 1002 mbar
                    Mean injection quantity: 0 mg/stroke
                    Index of current engine mode: 7
                    Index of next requested engine mode: 7
                    Index of engine target mode: 7
Readiness: N/A
   Part No SW: 0BT 300 046 N    HW: 0GC 927 711 H
   Component: GSG DQ500     H06 3107
   Revision: 00H06V10    CVN: 4644A9CA
   ROD: EV_TCMDQ500021_VN46.rod
   VCID: 41DEBCEF610C0D92405-8014
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 7LA 614 517 A    HW: 7LA 614 517
   Component: ESC_high      H01 0700
   Serial number: 08510490190923
   Coding: 305524524848EE850C5424AC126F7706392720B8
   Shop #: WSC 00035 377 00129
   ASAM Dataset: EV_Brake1ESP90iBOSCHVN46X 002010
   ROD: EV_Brake1ESP90iBOSCHVN46X_002.rod
   VCID: 3D26C01F1DF4697224D-8068
Address 08: Auto HVAC (J301)       Labels:* Redir Fail!
   Part No SW: 7LA 907 426 C    HW: 7LA 907 426 C
   Component: AC Manuell    H01 0502
   Coding: A03110000810000001000800504001050000000000001000800000000000
   ASAM Dataset: EV_AirCondiBHTCT6PA 001004
   ROD: EV_AirCondiBHTCT6PA.rod
   VCID: 43D2B6E77B101F82529-8016
   Part No SW: 2Q5 937 090     HW: 2Q5 937 090
   Component: BCM T6PA Std+ H10 0935
   Serial number: 01101933402040 Dataset Number: V03935315CB 0001
   ASAM Dataset: EV_BCMA0 205001
   ROD: EV_BCMA0_205_VN46.rod
   VCID: 74B0253B6E3EE83A1B3-8020
   Subsystem 1 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  050 0105
   Serial number: S6Y19M11D14H03M00S03
   Coding: 02B8EE
   Driver door control module:
   Subsystem 2 - Part No SW: 7L1 959 405 B    HW: 7L1 959 163 B
   Component: FHSG_DRV  001 0002
   Serial number: 00000000000036272531
   Coding: 1F000F
   Front passenger door control module:
   Subsystem 3 - Part No SW: 7L1 959 406 B    HW: 7L1 959 164 B
   Component: FHSG_PSG  001 0002
   Serial number: 00000000000036032898
   Coding: 050007
   Subsystem 4 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY193250YZE
   Serial number: 00000000000047943289
   Part No SW: 5QA 919 294 G    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0061
   Serial number: 000150058319334 Dataset Number: V03935304BK 0001
   Coding: 0471151811
   ASAM Dataset: EV_EPHVA18AU3700000 009046
   ROD: EV_EPHVA18AU3700000_AU27.rod
   VCID: 50F889ABBA66F41ADFB-8004
   Part No SW: 2Q0 907 572 R    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0372
   Dataset Number: V03935303EM 0001
   Coding: 3200670241FF8748949C815580508700000000000000000004
   Shop #: WSC 00035 377 00190
   ROD: EV_ACCMRRCONTIVW376_003.rod
   Part No SW: 2Q0 959 655 AD    HW: 2Q0 959 655 AD
   Component: VW22Airbag    015 0506
   Revision: --------    Dataset Number: V03935308TZ 0001
   Coding: 8800C00000000000800000CF008C40000065
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001022
   ROD: EV_AirbaVW22BPAVW27X_VN46.rod
   VCID: 7F5AFA175778BB62761-802A
Address 17: Instruments (J285)       Labels:| 7LA-920-XXX-V1.clb-SRI3
   Part No SW: 7LA 920 941     HW: 7LA 920 941
   Component: KOMBI         204 6750
   Coding: 27A40A882480260001886A051401000000600000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009069
   ROD: EV_DashBoardVDDMQBAB_VN46.rod
   VCID: 7DA6001F5D74A97264D-8028
16777018 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [BAP_Audio_0x31 keine Kommunikation]
                    Reset counter: 157
                    Mileage: 43829 km
                    Date: 2023.09.12
                    Time: 20:50:05
9456681 - Key
          B104C 29 [008] - Implausible Signal
                    Mileage: 42477 km
                    Date: 2023.08.07
                    Time: 06:59:12
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5388
   Serial number: 02121910523164 Dataset Number: V03935310HZ 0001
   Coding: 030100044F05730001100018100F00010001070000000000000000000000
   Shop #: WSC 00035 377 00188
   GVL: 014C3C0000000000400090008000C80000000000000000000000000000000000
   ROD: EV_GatewNF_VN46.rod
   VCID: 70B8292B1A26D41AFFB-8024
   Generator:
   Component: 4-01-09-01-04
   Subsystem 2 - Part No SW: 3G0 959 442 F    HW: 3G0 959 442 F  Labels: 3C8-959-537.CLB
   Component: E221__MFL-PR6  H06 0110
   Serial number: PR6-0440036334192467
   Coding: 2C1D00
   Subsystem 3 - Part No SW: 7E0 915 181 N    HW: 7E0 915 181 N
   Component: J367-BDMConti  H03 1052
   Serial number: 773433010019112907C8
Address 44: Steering Assist (J500)       Labels:| 2N0-909-143.clb
   Part No SW: 7LA 909 144 F    HW: 7LA 909 144 D
   Component: EPS_MQB_ZFLS  751 7150
   Dataset Number: V03935309JN 0001
   Coding: 0106
   ASAM Dataset: EV_SteerAssisMNB 002012
   ROD: EV_SteerAssisMNB_VN46.rod
   VCID: 45D6A8FF752421B27CD-8010
   Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
   Revision: --------    Serial number: -------------- Dataset Number: V03935306CX 0001
   Coding: 0C8E020009200003
   ROD: EV_HeadlRegulAFSMQBMAX_VN46.rod
   Part No SW: 3G5 035 820 B    HW: 3G5 035 820
   Component: MU-O-ND-EU    H12 0278
   Serial number: VWZAZ2W1201712  Dataset Number: V03935346LW 0001
   Coding: 64600008000020000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB 001001
   ROD: EV_MUOIMQB_001_VN3S.rod
   VCID: 231216679B503F82329-8076
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  H61 8214
   Serial number: VWZ6ZJW3320837
   Subsystem 2 - Part No: V03 959 806 MG
   Component: EU 2019/04     1004
12291 - Ethernet Databus Branch 4
          U11BE 00 [008] - Electrical Malfunction
                    Reset counter: 9
                    Mileage: 43207 km
                    Date: 2023.08.23
                    Time: 16:58:11
                    Ethernet counter checksum error: branch 4: 0
                    Ethernet counter connection interruptions: branch 4: 0
7223 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [ENI (0x37) - function restriction due to communication error - BapErr_retry not successful]
                    Fault Frequency: 8
                    Reset counter: 28
                    Mileage: 42960 km
                    Date: 2023.08.18
                    Time: 11:43:34
                    BAP: 27
                    Voltage terminal 30: 12.5 V
   Part No SW: 5Q0 907 273 D    HW: 5Q0 907 273
   Component: RDKBERU30     H05 0010
   Serial number: 30000000363515 Dataset Number: V03935305SJ 0001
   ROD: EV_RDKBERU30_VW41.rod
   VCID: 3634DF3338C2BA2AE57-8062
   Part No SW: 5WA 035 284 E    HW: 5WA 035 284
   Component: OCUGen3High   H20 0141
   Serial number: 0000000203VIRGD Dataset Number: V03935314UU 0001
   Coding: 06462000196898209005460160000607
   ASAM Dataset: EV_OCUGen3High 003007
   ROD: EV_OCUGen3High_003_VN46.rod
   VCID: 48C8A1CB42363CDA87B-801C
1644017 - Online Services
          B1915 F1 [008] - Temporary Function Restriction due to Battery Budget
                    Fault Frequency: 37
                    Reset counter: 28
                    Mileage: 42220 km
                    Date: 2023.07.25
                    Time: 11:37:22
                    Voltage terminal 30: 12.8 V
                    Remaining long term energy budget: 3569 mAh
                    Remaining short term energy budget: 1 mAh
                    Wake up cycles counter: 2598
   Part No SW: 992 941 571 AA    HW: 992 941 571 A
   Component: LED1L         H08 9002
   ROD: EV_LLPGen3LKEBODPO68X_001_VW49.rod
   VCID: 619E5C6FC1CC6D92605-8034
   Component: LED1R         H08 9002
End----(Elapsed Time: 01:35, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
Have you looked at what's in these Adaptation channels in your TPMS module?
Front-axle SPECIFIED pressure fully loaded
Rear-axle SPECIFIED pressure fully loaded
Front-axle SPECIFIED pressure comfort
Rear-axle SPECIFIED pressure comfort
Front-axle SPECIFIED pressure standard
Rear-axle SPECIFIED pressure standard
We have a map of AW 65 and they were showing the default of 255
IDE03508-SPECIFIED pressure line selection (end of assembly line)
1​
IDE03511-Front-axle SPECIFIED pressure fully loaded
255​
IDE03512-Rear-axle SPECIFIED pressure fully loaded
255​
IDE03513-IDE03525-Write sensor identification number-Sensor identification number (sensor ID)
0​
IDE03513-IDE06104-Write sensor identification number-Wheel positionLeft front
IDE03532-Load status selectedStandard
IDE08521-Front-axle SPECIFIED pressure comfort
255​
IDE08522-Rear-axle SPECIFIED pressure comfort
255​
IDE08523-Front-axle SPECIFIED pressure standard
255​
IDE08524-Rear-axle SPECIFIED pressure standard
255​
MAS02356-Type of calibrationMenu
I don't know if this controller will allow changes, of if those specifications are on the parameter level, but I would try changing these channels in the order listed below to the new value of 34:
IDE03511-Front-axle SPECIFIED pressure fully loaded​
IDE03512-Rear-axle SPECIFIED pressure fully loaded​
IDE08521-Front-axle SPECIFIED pressure comfort​
IDE08522-Rear-axle SPECIFIED pressure comfort​
IDE08523-Front-axle SPECIFIED pressure standard​
IDE08524-Rear-axle SPECIFIED pressure standard​
At that point in time the Advanced Measuring values should show 3.4 bar specified. You may want to select slightly lower values but the final step would involve a reset through the in-car TPMS Menu. I don't know if that would be on the cluster or MIB but try resetting it followed by a drive.
If modifications to those channels are rejected this may not be possible via Adaptation using VCDS. In that case you may need someone with ODIS or similar to make the modifications.
NEtech
Denmark
C?ID=56995
Additional, as far as I know.
255 means no specification.
If there is a specification or you want one, value is multiplied with 10, so 3.0 bar value is: 30
To erase an specification (not 255), save: 0
Busyguy
V2-2H
Thanks for your replys,i had seen 255 in the setting and did try some values but nothing took.
But i didnt know what values it would take if it was possible.
Before i could get more into the system the customer collected his van so looks like i will be looking at it again sometime.
It left with the correct pressures in all the tyres so it showed all 4 tyres low pressure.
I will update here when i get to look at it again
Thanks again for all your help.
TTT
C?ID=547002
Specified tyres pressure in that module are set using .xml parameters file, something which vcds cannot upload in the module. At least from my limited experience retrofitting one of these in a 2018 vehicle.
At the end of the day, van has the wrong tyres fitted!
  • Agree
Busyguy
V2-2H
Just got news from the customer.
The van had to go back to VW for a recall and while it was there its been reprogrammed for the correct pressures for the tyres fitted to the 20s
