Audi E-tron TPMS error
Esser
Denmark
C?ID=419845
I have a weird issue with the TPMS on my 2019 Audi E-tron.
The car has direct TPMS with a sensor in each wheel. When I use my original 19 inch winter wheels, the TPMS always works, no issues at all.
At some point I bought a new set of 22 inch wheels with aftermarket sensors in the wheels. They worked without any issues at all.
Then earlier this year I bought a set of 23 inch wheel and again I fitted aftermarket sensors, but a different brand this time.
When I first fitted the 23 inch wheels, the sensors did not work and I got a yellow TPMS light in the dash.
I then took the car to a local mechanic who scanned each wheel with a tool and could see that all the sensors worked, were 433mhz and showed temperature, pressure and sensor ID.
After that I then manually entered the sensor id's in VCDS and shortly after the sensors worked! I could see pressure and temperature for each wheel and the yellow TPMS light went away.
Now, a week ago I briefly fitted the winter tires, and the TPMS worked as always, and a few hours later I fitted the 23 inch wheels again, but now I can not in any way, get the sensors to work... The car will not display pressure or temperature for any wheel and there's a yellow TPMS light in the dash again.
I did try to manually enter the sensors ID's with VCDS, tried setting the sensors ID's to 0, but nothing works...
I've posted a complete autoscan below.
The TPMS is module 65.
Does anyone have any idea what I can do, or have I maybe just bought some crappy aftermarket sensors...?
Friday,15,September,2023,10:07:02:01663
VCDS Version: 23.3.1.0 (x64)  HEX-V2 CB: 0.4631.4
VIN: WAUZZZGE6KB008689   License Plate:
Mileage: 68127km-42332mi   Repair Order:
Chassis Type: GE-AU58 (4K1)
Scan: 01 03 09 13 15 16 17 19 2B 36 3C 42 44 46 47 51 52 5F 65 69
          6D 74 75 81 82 84 8C A5 BB BC C5 C6 CA CD CE CF D6 D7 DB DC
          DE 8104 8111 8112
VIN: WAUZZZGE6KB008689   Mileage: 68127km-42332miles
74-Chassis Control -- Status: Malfunction 0010
C5-Therm. mgt. -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CD-Laser Scanner -- Status: Malfunction 0010
CE-Drive Motor 2 -- Status: OK 0000
DB-Frt Corner Rdar 1 -- Status: OK 0000
DC-Frt Corner Rdar 2 -- Status: OK 0000
8104-DC/DC Converter HV -- Status: OK 0000
8111-Rearview Mirror R -- Status: OK 0000
8112-Rearview Mirror L -- Status: OK 0000
Address 01: Engine (J623-    )       Labels: Redir Fail!
   Part No SW: 4KE 907 558 C    HW: 4KE 907 558
   Component: I99 99.9l XXX H02 0002
   CVN: 7D75D4C5
   Coding: 2A0A0012007E040034280000000000000000000000000000
   ASAM Dataset: EV_VCU00XXX0204KE907558C 001003
   ROD: EV_VCU00XXX0204KE907558C.rod
   VCID: 49CF59FC993965B2985-801C
   VINID: 9D196AAAA5D519B4800081882476DCA5D1
   Parking lock:
   Subsystem 1 - Part No SW: 0MA 341 601 B    HW: 0MA 341 601 B
   Component: V682 ParkLock  H23 0611
   Serial number: 2018.11.23.000000470
33321 - Front Camera for Driver Assist Systems
          U1229 00 [032] - Implausible Message
23039 - Implausible Data Received from ABS Control Module
          U0415 00 [032] - -
                    Mileage: 67797 km
                    Date: 2023.09.07
                    Time: 13:02:02
                    Engine RPM: 16383.75 /min
                    Normed load value: 100.0 %
                    Vehicle speed: 2 km/h
                    Coolant temperature: 215 °C
                    Intake air temperature: 215 °C
                    Ambient air pressure: 2550 mbar
                    Voltage terminal 30: 13.789 V
                    Unlearning counter according OBD: 30
                    LF_MVB_PDU_INTC_DIAG_1: 0
                    LF_MVB_PDU_INTC_DIAG_2: 2048
                    LF_MVB_PDU_INTC_DIAG_3: 2080
                    LF_MVB_PDU_INTC_DIAG_4: 32768
                    LF_MVB_PDU_INTC_DIAG_5: 32768
                    LF_MVB_PDU_INTC_DIAG_6: 32
                    LF_MVB_BUS_INTC_DIAG: 12544
17176 - Databus
38468 - Implausible Data Received from ESP Control Module
          U0416 00 [032] - -
                    Mileage: 67797 km
                    Date: 2023.09.07
                    Time: 13:02:02
                    Engine status: Stop
                    ECU_STATE: ENG_STOP
                    ACC variants (coding): ACC with braking until standstill / Stop & Go
                    Drivetrain coordinator: brake function status-ABS intervention: No
                    Drivetrain coordinator: brake function status-ESP intervention: No
                    Drivetrain coordinator: brake function status-EDL intervention: No
                    Drivetrain coordinator: brake function status-ASR intervention: No
                    Drivetrain coordinator: brake function status-MSR intervention: No
                    Drivetrain coordinator: brake function status-Driver braking: No
                    Drivetrain coordinator: brake function status-HDC active: No
                    Drivetrain coordinator: brake function status-ESP invokes TSK braking: No
                    Drivetrain coordinator: brake function status-EPB active: No
                    Drivetrain coordinator: brake function status-ASP intervention: No
                    Drivetrain coordinator: brake function status-ADS intervention: No
                    Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt: No
                    Drivetrain coordinator: brake function status-ESP sampled passive (ESP off): No
                    Drivetrain coordinator: brake function status-ASR sampled passive (ASR off): No
                    Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest: No
                    Drivetrain coordinator: brake function status-ACC stopping distance control active: No
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 4KE 909 059 AF    HW: 4KE 909 059 G
   Component: ESC           H09 0242
   Revision: 00000000    Serial number: 60199000005760 Dataset Number: 4KE909504AH 0003 CVN: D4D7BE22
   Coding: 008800BA3D940BA193560C79188092E425BEA90000BCD0C930184927A47D95
   Shop #: WSC 46075 004 104857
   ASAM Dataset: EV_BRSContiMKC1AU516 011001
   ROD: EV_BRSContiMKC1AU516_011.rod
   VCID: 0B43A3F4D3C537A26A9-805E
8440 - Lane change assistant control module
          U1046 00 [044] - Implausible signal
          [CCan_RCTA_Status_failure]
                    Mileage: 67797 km
                    Date: 2023.09.07
                    Time: 13:02:02
                    Unlearning counter according OBD-OBD unlearning counter: 30
                    History Data-History data 1: 00
                    History Data-History data 2: 00
                    History Data-History data 3: 00
                    History Data-History data 4: 00
                    History Data-History data 5: 00
                    History Data-History data 6: 00
                    History Data-History data 7: 00
                    History Data-History data 8: 00
                    History Data-History data 9: 00
                    History Data-History data 10: 00
                    History Data-History data 11: 00
                    History Data-History data 12: 00
                    History Data-History data 13: 00
                    History Data-History data 14: 00
                    History Data-History data 15: 00
                    History Data-History data 16: 00
                    History Data-History data 17: 00
                    History Data-History data 18: 00
                    History Data-History data 19: 00
                    History Data-History data 20: 00
                    History Data-History data 21: 00
                    History Data-History data 22: 00
                    History Data-History data 23: 00
                    History Data-History data 24: 00
                    History Data-History data 25: 00
                    History Data-History data 26: 00
                    History Data-History data 27: 00
                    History Data-History data 28: 00
                    History Data-History data 29: 00
                    History Data-History data 30: 00
                    History Data-History data 31: 00
                    History Data-History data 0: 00
Address 09: Cent. Elect. (J519)       Labels:* 4N0-907-063-V2.clb
   Part No SW: 4N0 907 063 HG    HW: 4N0 907 063 AG
   Component: BCM1 MLBevo   H10 0673
   Dataset Number: 4KE909514D  0021
   Coding: 07000143C13900DD074057889CFB9C68131B37110C06009789010A00192316810A45090240102000000001000049181A08028000C4030000000000000000000000
   Shop #: WSC 00046 412 00046
   ASAM Dataset: EV_BCM1BOSCHAU651 015010
   ROD: EV_BCM1BOSCHAU651_015.rod
   VCID: 7AADF6308C5F3E2A41F-802E
   Subsystem 1 - Part No SW: 4KL 955 119     HW: 4K1 955 119
   Component: J400FRWISCH  063 0840
   Serial number: 00000001811280406425
   Coding: 7DC727
   Serial number: 22340322X81A955555A0
   Coding: 02005E
   Subsystem 3 - Part No SW: 4K1 941 501 A    HW: 4K1 941 501 A
   Component: E1 - LTM  H09 0086
   Serial number: 14S07.03.1900691583
   Subsystem 4 - Part No SW: 4N0 907 410 B    HW: 4M0 907 410 A
   Component: USHL5  H10 0100
   Serial number: 0000009600368Z00NV02
   Coding: 210000
   Subsystem 5 - Part No SW: 8W0 857 511     HW: 8W0 857 511
   Serial number: GX1CE112121823310945
   Interior Light Module:
   Subsystem 6 - Part No SW: 4K0 947 135 L    HW: 4K0 947 135 L
   Component: Dachmodul  H42 0413
   Serial number: C00207987
   Coding: 0D0104
   Subsystem 7 - Part No SW: 80A 907 705     HW: 80A 907 705
   Component: J866-EVLS-SG  H03 0100
   Serial number: WA136327000063090467
   Coding: 0A0700
   Front windshield washer pump:
   Subsystem 8 - Part No SW: 4N0 907 605 C    HW: 4N0 907 605 A
   Component: J1100/SWP  H21 0015
   Serial number: 00000000001906700297
   Coding: 040000
65689 - Heated Seat Backrest; Front Left
          B14E1 15 [009] - Open or Short to Plus
                    Reset counter: 231
                    Mileage: 58879 km
                    Date: 2023.05.05
                    Time: 15:08:26
                    average_Voltage_terminals: 13.00 V
                    Outside air temperature sensor-Outside air temperature on CAN: 10.00 °C
                    interior_temperature: 11.00 °C
                    Vehicle speed: 0.00 km/h
                    Terminal activation-Terminal 75 status: OFF
                    Terminal activation-Terminal 15 status signal: OFF
                    Terminal activation-Terminal 15 via CAN: OFF
   Part No SW: 4KE 907 561 B    HW: 4K0 907 561
   Component: LRR4R         H04 0332
   Dataset Number: 4KE909863F  0001
   Coding: 7E65FF5C58082C0001038020000000BE4A1246494481009E01
   ASAM Dataset: EV_ACCBOSCHAU65X 002023
   ROD: EV_ACCBOSCHAU65X_AU58.rod
   VCID: 42DD4ED0A40FB6EA59F-8016
2342 - Databus
          [FAULT_ACA_QF_STATUS_DISPLAY_ERROR]
                    Reset counter: 162
                    Mileage: 66965 km
                    Date: 2023.08.14
                    Time: 12:09:57
                    Control Module temperature: 39 °C
                    Voltage terminal 15: 14.2 V
                    Vehicle speed: 4.33 m/s
                    Longitudinal acceleration: 1.36 m/s²
                    Adaptive distance regulation: status: ACC_reversible_error
                    Steering_angle-Data: 32.100 °
                    Yaw_rate-Data: 0.836 rad/s
                    adjustment_calculation: On
                    Misalignment angle: horiz: 0.166 °
                    Misalignment angle: horiz: fast algorithm: 0.143 °
                    Congestion pilot: status: OFF
                    Outside temperature: 25.50 °C
                    Sensor blindness: radar: no blindness detected
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM]
                    Reset counter: 162
                    Mileage: 67797 km
                    Date: 2023.09.07
                    Time: 13:02:02
                    Control Module temperature: 37 °C
                    Voltage terminal 15: 14.3 V
                    Vehicle speed: -0.02 m/s
                    Longitudinal acceleration: 0.00 m/s²
                    Adaptive distance regulation: status: ACC_Off_MainSwitch_Off
                    Steering_angle-Data: 0.500 °
                    Yaw_rate-Data: 0.014 rad/s
                    Misalignment angle: horiz: 0.347 °
                    Misalignment angle: horiz: fast algorithm: 0.280 °
                    Outside temperature: 22.50 °C
2340 - Databus
          [FAULT_LIDAR_DATA_TRANSFER]
                    Reset counter: 143
                    Mileage: 66965 km
                    Date: 2023.08.14
                    Time: 12:09:56
                    Vehicle speed: 3.46 m/s
                    Longitudinal acceleration: 1.60 m/s²
                    Steering_angle-Data: 43.800 °
                    Yaw_rate-Data: 0.973 rad/s
2341 - Databus
          [FAULT_LIDAR_ERROR]
                    Reset counter: 143
                    Mileage: 66965 km
                    Date: 2023.08.14
                    Time: 12:10:00
                    Vehicle speed: 5.84 m/s
                    Longitudinal acceleration: 0.36 m/s²
                    Steering_angle-Data: 194.100 °
                    Yaw_rate-Data: 7.947 rad/s
   Part No SW: 4KE 959 655     HW: 4KE 959 655
   Component: AirbagVW32    H36 3122
   Serial number: 003XPM00EADY Dataset Number: 4KE909602K  0003
   Coding: AACCF0C0002000009A5400FFF81D41A800C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001034
   Left seat belt tensioner:
   Serial number: 00AI2019061707200000
   Coding: 03F002
   Right seat belt tensioner:
   Serial number: 00AI2019058303700000
   Coding: 03F002
   Subsystem 3 - Part No SW: -----------    HW: 480 002 202 19
   Serial number: 35700000000C9434B93R
   Subsystem 4 - Part No SW: -----------    HW: 480 002 202 19
   Serial number: 3580000000055095693F
   Subsystem 5 - Part No SW: -----------    HW: 480 030 503 19
   Serial number: 351001C1CC04E9D12E9R
   Subsystem 6 - Part No SW: -----------    HW: 480 030 503 19
   Serial number: 352001C1CC0CEDC05CE1
   Subsystem 7 - Part No SW: -----------    HW: 480 022 901 19
   Component: FrontSensor_D  000 0149
   Serial number: 35500011E2B7C7F5E40K
   Subsystem 8 - Part No SW: -----------    HW: 480 022 901 19
   Component: FrontSensor_P  000 0149
   Serial number: 3560001C32F0DDC5531D
   Crash sensor high-voltage system 1:
   Subsystem 9 - Part No SW: -----------    HW: 480 022 901 19
   Component: HVSensor_gSat  000 0149
   Serial number: 35100011E2B7C7F45259
   Crash sensor for side airbag: B-pillar: driver side:
   Subsystem 10 - Part No SW: -----------    HW: 480 022 901 19
   Component: SideSens_B_Df  000 0149
   Serial number: 35200011E2B7C7F694AN
   Crash sensor for side airbag: B-pillar: passenger side:
   Subsystem 11 - Part No SW: -----------    HW: 480 022 901 19
   Component: SideSens_B_Pf  000 0149
   Serial number: 3550001C32F0DDC6127E
1065477 - Databus
          [NWD: 0xTBD BV_SensorHeader error value BV2_Fehler_MOD]
                    Fault Frequency: 73
                    Reset counter: 170
                    Mileage: 58806 km
                    Date: 2023.05.04
                    Time: 11:12:49
1071877 - Databus
          [NWD: 0x1A2 ESP_15 error value VZM_Status]
                    Reset counter: 162
                    Mileage: 67797 km
                    Date: 2023.09.07
                    Time: 13:02:02
1056773 - Databus
          [NWD: 0x17F PCR_02 error value PCR_Obj_xRel]
                    Reset counter: 154
                    Mileage: 64005 km
                    Date: 2023.07.15
                    Time: 12:06:15
   Part No SW: 4N0 907 129 AJ    HW: 4N0 907 129 AJ
   ROD: EV_SMLSKLOAU736_VW53.rod
   VCID: 79AFE93C89593532485-802C
   Part No SW: 4KE 920 795 B    HW: 4KE 920 795
   Component: FHybRDWACC--- H13 0031
   Coding: 850400C87C88000800A6E170B284680008000100
   ROD: EV_DashBoardAU65X_001_AU58.rod (VIN: N/A)
   VCID: 46D552C088278ACA757-8012
16777046 - Charger for HV Battery
          U1139 00 [008] - No Communications
          [BAP_BatteryControl_0x25 communication error bap_error_timeout heartbeat]
                    Fault Frequency: 105
                    Reset counter: 169
                    Mileage: 58752 km
                    Date: 2023.05.02
                    Time: 21:36:05
1246810 - Activatable Functions
          B18D3 F4 [008] - Authentication of Transmission Failed
                    Fault Frequency: 17
                    Reset counter: 169
                    Mileage: 58829 km
                    Date: 2023.05.04
                    Time: 17:09:15
   Part No SW: 4K1 907 468 D    HW: 4K1 907 468 C
   Component: Gateway       H04 0322
   Serial number: 1DF06037889601 Dataset Number: 4KE909515A  0018
   Coding: 02030005000100C000810000005B01329C8A004718000000090000DF00000000
   GVL: F1593C088800020094DC880080004818110E0060000080013000000000000700
   ASAM Dataset: EV_Gatew31xAU65x 003170
   ROD: EV_Gatew31xAU65x_AU58.rod
   VCID: 36352200F8C71A4AE57-8062
   Subsystem 1 - Part No SW: 4N0 951 523 G    HW: 4N0 951 523 G
   Component: E221__MFL  H06 0003
   Subsystem 2 - Part No SW: 4N0 915 181 D    HW: 4N0 915 181 D
   Serial number: 76749601001901210199
   Subsystem 3 - Part No SW: 4N0 419 508     HW: 4N0 419 508
   Component: J1158 KLR  H44 0030
   Serial number: 18330006106S00304401
131655 - No Communication with Towing System Control Module (J345)
          U1003 00 [008] - -
          [Timeout_Node_0x47_DiagAdress_69_AAG]
                    Fault Frequency: 21
                    Reset counter: 172
                    Mileage: 68014 km
                    Date: 2023.09.11
                    Time: 11:58:06
8913155 - Development Code 4
          B2F04 00 [009] - -
          [RWB_TME_Init_Abwurf_Dauerinit]
                    Reset counter: 128
                    Mileage: 68031 km
                    Date: 2023.09.12
                    Time: 00:11:30
8913156 - Development Code 5
          B2F05 00 [009] - -
          [RWB_BCME_Init_Abwurf_Dauerinit]
                    Reset counter: 128
                    Mileage: 68014 km
                    Date: 2023.09.11
                    Time: 12:08:39
8978692 - Activatable Functions
          B18D3 F3 [008] - Faulty Vehicle Configuration
                    Reset counter: 169
                    Mileage: 68058 km
                    Date: 2023.09.13
                    Time: 15:55:17
   Part No SW: 3Q0 905 861 C    HW: 3Q0 905 861 C
   Component: ELV-MLBevo    H05 0020
   Serial number: 19000043136001
   Coding: 8800000000000000
   ROD: EV_ELVMarqMQBA0_VW53.rod
   VCID: 34311808EEBB085ADB3-8060
   Serial number: 00000364892214 Dataset Number: 4KE909856B  0005
   Coding: 00581A400000B4010003010101010000000000000000000000000000004000
   Part No SW: 4KE 907 566     HW: 4N0 907 566 A
   Component: MRR_HR H12 0426
   Dataset Number: 4KE909535A  0005
   Coding: 1FDC80
   ASAM Dataset: EV_RearRadarS1DelphAU651 001018
   ROD: EV_RearRadarS1DelphAU651.rod
   VCID: 055795CCF5A141D23CD-8050
1191961 - Databus
          [databus error value received - ESP_15_VZM_Status]
                    Reset counter: 162
                    Mileage: 67797 km
                    Date: 2023.09.07
                    Time: 13:02:02
                    Control Module temperature: 57 °C
                    Voltage terminal 30: 14.40 V
                    Vehicle speed: 2.45 km/h
                    Terminal 15 status: On
                    Voltage terminal 15: Measuring value not available
   Part No SW: 4M0 959 793 M    HW: 4M0 959 793 J
   Component: TSG FS        007 0387
   Serial number: 0000360544409  Dataset Number: 4KE909872B  0013
   Coding: 001DDB0143000480A008B020
   Shop #: WSC 24856 182 00000
   VCID: 48C95CF882339CBA87B-801C
   Part No SW: 4N0 909 144 E    HW: 4N0 909 144 A
   Component: EPS_MLBEVO2BS H21 0505
   Dataset Number: 4KE909852E  0002
   Coding: B4000101010000
   ROD: EV_EPSVWBSAU426_010.rod
   VCID: 323D1E1014AF066AC9F-8066
   Part No SW: 8W0 907 064 GH    HW: 8W0 907 064 DH
   Component: BCM2 MLBevo   025 0424
   Dataset Number: 4KE909501C  0020
   Coding: 01740003002003E16301A0046C00C80200004000804F06582F0400000504823B001F0100010F13
   ASAM Dataset: EV_BCM2HellaAU736 016016
   ROD: EV_BCM2HellaAU736_016_AU58.rod
   VCID: 08499CF8C2B35CBA47B-805C
   left tail lamp 1:
   Subsystem 1 - Part No SW: 4KE 945 423     HW: 4KE 945 423
   Component: T1 LH ECE HD  H10 0403
   Serial number: A1W700008US
   Subsystem 2 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 11544028
   Antenna for short-range communication:
   Subsystem 3 - Part No SW: 4N1 927 753     HW: 4N1 927 753
   Component: NFCTGS  H13 0050
   Serial number:            382942759
   Antenna 2 for short-range communication:
   Subsystem 4 - Part No SW: 4N0 959 428 A    HW: 4N0 959 428 A
   Component: NFCMIKO  H41 0036
   Serial number: 4418000245201024
   left tail lamp 2:
   Subsystem 5 - Part No SW: 4KE 945 429 B    HW: 4KE 945 429 B
   Component: T2 LH ECE HD  H12 0403
   Serial number: A1WK0001JN1
   Right rear tail lamp 1:
   Subsystem 6 - Part No SW: 4KE 945 424     HW: 4KE 945 424
   Component: T1 RH ECE HD  H10 0403
   Serial number: A1WD00007YL
   Right rear tail lamp 2:
   Subsystem 7 - Part No SW: 4KE 945 430 B    HW: 4KE 945 430 B
   Component: T2 RH ECE HD  H12 0403
   Serial number: A1WL0001JN2
65605 - Databus
          [Brake control module: ESP_21: no signal/communication]
                    Reset counter: 160
                    Mileage: 67617 km
                    Date: 2023.09.02
                    Time: 10:56:01
                    Supply voltages-Terminal 30 power supply: 12.691 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.704 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.745 V
                    general_additional_freeze_frame-terminal_control_intern_status: 40 04 42 10 00 80
                    general_additional_freeze_frame-Vehicle speed: Not available
65729 - Databus
          [Brake control module: ESP_05: no signal/communication]
                    Reset counter: 160
                    Mileage: 67617 km
                    Date: 2023.09.02
                    Time: 10:56:01
   Part No SW: 4N0 035 223 C    HW: 4N0 035 223
   Component: MIB2_amp_P_D5 H01 0170
   Revision: 00000001    Serial number: AUZ8ZAJ7D00RN35 Dataset Number: 4KE909510A  0002
   Coding: 0115160000AAAA2FAA0000010002
   ASAM Dataset: EV_AMPMst16C1Gen2pALPI 001010
   ROD: EV_AMPMst16C1Gen2pALPI.rod
   VCID: 2411E8485E5B98DA4B3-8070
Address 51: Electric Drive (J841)       Labels: 0EF-907-XXX-V1.clb
   Part No SW: 0EF 907 080 H    HW: 0EF 907 080 C
   Component: CUFZD68570AD0 H03 1005
   Revision: --------    Serial number: -00106.12.18000
   Coding: 01000000000000000000
   Shop #: WSC 43335 004 1048576
   ASAM Dataset: EV_DMCMHITACAU516 003009
   ROD: EV_DMCM2HITACAU516_003.rod
   VCID: 3B233334C3E5C7221A9-806E
   Part No SW: 4M0 959 792 M    HW: 4M0 959 792 J
   Component: TSG BFS       007 0387
   Serial number: 0000356492161  Dataset Number: 4KE909873B  0013
   VCID: 47CB5FC48F2D93C28E1-8012
Address 5F: Information Electr. (J794)       Labels:| 4G1-035-MIB-HGH2.clb
   Part No SW: 4K0 035 063 D    HW: 4KE 035 063
   Component: MU-H-LND-EU   046 2711
   Dataset Number: 4KE909545B  0012
   Coding: 0115760100000000C3111102C00802302F0001E4037008008E
   Subsystem 1 - Part No: V03 959 807 SG
   Component: MIB2P_EU_Q221  0550
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4KE 919 605 C    HW: 4KE 919 605
   Component: DU AU516 High  H41 0147
   Serial number: INX00109111800130352
   Compact disc data bank:
   Component: Gracenote2  1009
   Volume Control 1:
   Subsystem 4 - Part No SW: 4K1 919 616 B    HW: 4K1 919 616 A
   Serial number: 00004419000026250048
   Multimedia System 5:
   Subsystem 5 - Part No SW: 4KE 919 603 A    HW: 4KE 919 603
   Component: DU AU516 Bot  H41 0147
   Serial number: INX00130111800140417
   Media socket:
   Subsystem 6 - Part No SW: 4N0 035 736 A    HW: 4N0 035 736
   Component: MediaConnectH  014 0133
   Serial number: 051900085040010
6190 - Display Module 1 for Multimedia System
          B1297 FC [008] - Haptic Unit Defective
                    Reset counter: 144
                    Mileage: 66991 km
                    Date: 2023.08.14
                    Time: 15:26:20
                    Voltage terminal 30: 14.0 V
Address 65: Tire Pressure (J502)       Labels: 4M0-907-273.clb
   Part No SW: 4M0 907 273 B    HW: 4M0 907 273 B
   Component: RDKHUFAU736   H05 0010
   Serial number: 30000000034441 Dataset Number: 4KE909850A  0002
   ROD: EV_RDKHUFAU736.rod
   VCID: 2F3B1764079D2B82A61-807A
8397058 - Front Left TPMS Sensor
          C1050 31 [009] - No Signal
                    Reset counter: 130
                    Mileage: 68081 km
                    Date: 2023.09.14
                    Time: 07:56:56
                    Expanded ambient data 6-Vehicle speed: 0.00 km/h
                    Expanded ambient data 6-Outside temperature: 13.50 °C
                    Left front tire pressure sensor: remaining oper. life: 127 m
                    Left front tire pressure sensor: remaining oper. life-Left_front_tire_pressure_sensor_remaining_operation_time_Textual: Not available
8397314 - Front Right TPMS Sensor
          C1051 31 [009] - No Signal
                    Reset counter: 130
                    Mileage: 68081 km
                    Date: 2023.09.14
                    Time: 07:56:56
                    Right front tire pressure sensor: remaining oper. life: 127 m
                    Right front tire pressure sensor: remaining oper. life-Right_front_tire_pressure_sensor_remaining_operation_time_Textual: Not available
8397826 - Rear Right TPMS Sensor
          C1053 31 [009] - No Signal
                    Reset counter: 130
                    Mileage: 68081 km
                    Date: 2023.09.14
                    Time: 07:56:56
                    Right rear tire pressure sensor: remaining oper. life: 127 m
                    Right rear tire pressure sensor: remaining oper. life-Right_rear_tire_pressure_sensor_remaining_operation_time_Textual: Not available
8389636 - Adapatation Not Possible
          C112B 00 [009] - Too Many Tire Pressure Sensors
                    Reset counter: 132
                    Mileage: 68113 km
                    Date: 2023.09.14
                    Time: 16:14:41
                    Expanded ambient data 6-Vehicle speed: 34.17 km/h
                    Expanded ambient data 6-Outside temperature: 19.50 °C
   Part No SW: 5Q0 907 383 E    HW: 5Q0 907 383 B
   Component: Anhaenger     H14 0137
   Serial number: 0356562488
   Coding: 0110000202000000
   Shop #: WSC 38886 004 1048576
   ROD: EV_TrailFunctGener2Hella_VW27.rod
   VCID: 392F293CC9D9F532085-806C
656394 - Bulb for Left Tail Light on Trailer
          C10F5 15 [008] - Open or Short to Plus
656650 - Bulb for Right Turn Signal on Trailer
          C10F6 15 [008] - Open or Short to Plus
   Part No SW: 8W8 959 107 D    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0170
   Revision: --------    Serial number: A2-C744-8781-0 Dataset Number: 4KE909541B  0004
   Coding: 33B0
   VCID: 4ACD66F09C3F6EAA91F-801E
Address 74: Chassis Control (J775)       Labels:* 4KE-907-777.clb
   Part No SW: 4KE 907 777 AH    HW: 4KE 907 777 A
   Component: Fahrwerk-SG   H52 2320
   Serial number: 0803190926  Dataset Number: 4KE909576T  0008
   Coding: 98D86083DA4010
   ASAM Dataset: EV_ChassContrContiAU651 003018
   ROD: EV_ChassContrContiAU651_003.rod
   VCID: 127DBE90B4EFE66AA9F-8046
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004130481145
   Coding: 303030
4456458 - Implausible Data Received from ABS Control Module
          U0415 00 [008] - -
          [Function_restriction_due_to_communication_interruption_EspOverSteer]
                    Reset counter: 162
                    Mileage: 67797 km
                    Date: 2023.09.07
                    Time: 13:02:02
                    Internal DTC: 129
4456531 - Implausible Data Received from ABS Control Module
          U0415 00 [008] - -
          [Function_restriction_due_to_communication_interruption_EspUnderSteer]
                    Reset counter: 162
                    Mileage: 67797 km
                    Date: 2023.09.07
                    Time: 13:02:02
                    Internal DTC: 137
   Part No SW: 4K1 035 282 D    HW: 4K1 035 282 B
   Component: ConBox        H09 0232
   Serial number: 005CCA11F120301 Dataset Number: 4KE909612A  0012
   Coding: 01C0E0FFC040800000
   ROD: EV_ConBoxAU651_002.rod
   VCID: 2809FC7822737CBA67B-807C
Address 81: Gear Shift (J587)       Labels: 4KX-713-041-81.clb
   Part No SW: 4KL 713 041 A    HW: 4KL 713 041
   Component: GSM-LL H04 0036
   Serial number: 92145SC400132
   ASAM Dataset: EV_GSMKLOAU516 001008
   ROD: EV_GSMKLOAU516.rod
   VCID: 3C213028C6EBC01A133-8068
Address 82: Head Up Display (J898)       Labels:* None
   Part No SW: 4KL 919 617     HW: 4KL 919 617
   Component: HeadupDisplay H05 2831
   Coding: 5700E0
   ASAM Dataset: EV_HeadUpDisplAU65X 001010
   ROD: EV_HeadUpDisplAU65X.rod
   VCID: 0C41A0E8D6CB309A633-8058
Address 84: Night Vision (J853)       Labels:* None
   Part No SW: 4KE 907 547 B    HW: 4M0 907 547
   Component: NV-ECU-Gen3   H13 0260
   Serial number: 648027100201905
   Coding: 100112
   ASAM Dataset: EV_NightVisioG3AUTOLAU516 001002
   ROD: EV_NightVisioG3AUTOLAU516.rod
   Night vision system camera:
   Subsystem 1 - Part No SW: 4G0 980 552 A    HW: 4G0 980 552
   Component: NV-CAM-Gen3  H06 0007
   Serial number: 639589400B1905300068
Address 8C: HV Battery (J840)       Labels: None
   Part No SW: 4KE 915 233 S    HW: 4KE 915 233 B
   Component: BMC_MLBCBEV   H15 0468
   CVN: 9DDFAF83B5D9CDDC9F3843E89F3843E89F3843E89F3843E89F3843E89F3843E8
   ASAM Dataset: EV_BECM0842071 001004
   ROD: EV_BECM0842071_VW53.rod
   VCID: 4EC56AE06057428ACD7-801A
   Battery interrupt switch:
   Subsystem 1 - Part No SW: 4KE 915 250 C    HW: 4KE 915 250 B
   Component: BJB_MLBBEV  H12 0370
   Cell module control module 1:
   Subsystem 2 - Part No SW: 4KE 915 215 D    HW: 4KE 915 215
H06 0112
   Cell module control module 2:
   Subsystem 3 - Part No SW: 4KE 915 215 D    HW: 4KE 915 215
H06 0112
   Cell module control module 3:
   Subsystem 4 - Part No SW: 4KE 915 215 D    HW: 4KE 915 215
H06 0112
   Cell module control module 4:
   Subsystem 5 - Part No SW: 4KE 915 215 D    HW: 4KE 915 215
H06 0112
   Cell module control module 5:
   Subsystem 6 - Part No SW: 4KE 915 215 D    HW: 4KE 915 215
H06 0112
   Cell module control module 6:
   Subsystem 7 - Part No SW: 4KE 915 215 D    HW: 4KE 915 215
H06 0112
   Cell module control module 7:
   Subsystem 8 - Part No SW: 4KE 915 215 D    HW: 4KE 915 215
H06 0112
   Cell module control module 8:
   Subsystem 9 - Part No SW: 4KE 915 215 D    HW: 4KE 915 215
H06 0112
   Cell module control module 9:
   Subsystem 10 - Part No SW: 4KE 915 215 D    HW: 4KE 915 215
H06 0112
   Cell module control module 10:
   Subsystem 11 - Part No SW: 4KE 915 215 D    HW: 4KE 915 215
H06 0112
   Cell module control module 11:
   Subsystem 12 - Part No SW: 4KE 915 215 D    HW: 4KE 915 215
H06 0112
   Cell module control module 12:
   Subsystem 13 - Part No SW: 4KE 915 215 D    HW: 4KE 915 215
H06 0112
4122 - No Communication with ABS Brake Control Module
          U0121 00 [032] - -
          [Diag_C_HCAN_ESP_21_TO]
32789 - Battery Disconnect Element
          U158C 00 [032] - Control Module - Reset
          [Diag_F_BJB_ResetOccured]
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* 4N0-907-107-V2.clb
   Part No SW: 4KE 907 107 AC    HW: 4N0 907 107 H
   Component: zFAS Var C    H09 0291
   Dataset Number: 4KE909466H  0021
   Coding: 042184000000000000FFD60000F4470E5B9E5200000000000000000000969401009BA8000000000000000080000000000000000000000000F98040000000000000007CD80000009000800080000000000080400000E0
   ASAM Dataset: EV_ZFASAU516 001003
   ROD: EV_ZFASAU516_001.rod
   VCID: 005984D8EA8364FA0FB-8054
9 Faults Found:
2117711 - Internal Fault
          B200F F9 [008] - Unknown Error Elaboration
          [ZGT Überwachung am SRH fehlgeschlagen]
                    Fault Frequency: 68
                    Reset counter: 168
                    Mileage: 58879 km
                    Date: 2023.05.04
                    Time: 20:41:30
                    Platform_zFAS_Error_Handler_Master-ErrorHandlerMaster: 01 00 48 11 93 11 00 00 00 00 00 00 00 00 00 00
                    Platform_zFAS_Error_Handler_SSH-ErrorHandlerSSH: FF FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                    Platform_zFAS_Error_Handler_SRH-ErrorHandlerSRH: FF FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2114053 - Databus
          [RCTA_01_RCTA_Status]
                    Reset counter: 162
                    Mileage: 67797 km
                    Date: 2023.09.07
                    Time: 13:02:02
2114638 - Databus
          [LS1_SensorHeader_LS1_Fehler]
                    Reset counter: 143
                    Mileage: 66965 km
                    Date: 2023.08.14
                    Time: 12:09:56
2114770 - Databus
          [ESP_15_VZM_Status]
                    Reset counter: 162
                    Mileage: 67797 km
                    Date: 2023.09.07
                    Time: 13:02:02
98314 - Implausible Data Received from Power Steering Control Module
          U0420 00 [008] - -
          [LH_EPS_03_EPS_Lenkmoment]
                    Reset counter: 145
                    Mileage: 62097 km
98333 - Databus
          [ESP_21_ESP_Systemstatus]
                    Reset counter: 162
                    Mileage: 67797 km
                    Date: 2023.09.07
                    Time: 13:02:02
                    Supply voltages-Supply voltage Terminal 30 - internal: 0.00 V
                    Supply voltages-Terminal 30: 14.40 V
                    Supply voltages-Terminal 30 local: 14.30 V
                    Control Module temperature-Printed circuit: 44 °C
                    Control Module temperature-Average temperature: -50 °C
                    Control Module temperature-Application service computer: 45 °C
                    Control Module temperature-Sensor service computer: 41 °C
                    Control Module temperature-Environment recognition service computer: 49 °C
98337 - Databus
          [ESP_15_HMS_Notstopp_Status]
                    Reset counter: 132
                    Mileage: 58751 km
                    Date: 2023.05.02
                    Time: 21:27:35
4107 - Databus
          [reversibler_Fehler_im_ACC_System]
                    Reset counter: 162
                    Mileage: 66965 km
                    Date: 2023.08.14
                    Time: 12:09:57
4157 - Databus
          [ESP_Error]
                    Reset counter: 162
                    Mileage: 67797 km
                    Date: 2023.09.07
                    Time: 13:02:02
   Part No SW: 4M0 959 795 M    HW: 4M0 959 795 J
   Component: TSG HFS       006 0387
   Serial number: 0000367576504  Dataset Number: 4KE909897B  0013
   Coding: 000DD90100000480A008B020
   ROD: EV_DCU2RearDriveMAXHCONT_VW41.rod
   Component: TSG HBFS      006 0387
   Serial number: 0000367576565  Dataset Number: 4KE909896B  0013
   ROD: EV_DCU2RearPasseMAXHCONT_VW41.rod
Address C5: Therm. mgt. (J1024)       Labels:* None
   Part No SW: 4KE 965 429 C    HW: 4KE 965 429
   Component: TME-Max       H08 0312
   Serial number: 0023808 Dataset Number: 4KE909476VD 0001
   Coding: 00
   Shop #: WSC 46075 004 1048576
   ASAM Dataset: EV_ThermContrVISAU49X 002036
   ROD: EV_ThermContrVISAU49X_002_AU58.rod
   Subsystem 1 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G395 pT-Sens1  H11 0010
   Subsystem 2 - Part No SW: 3Q0 963 231 E    HW: 3Q0 963 231 E
   Serial number: -00100.8W.4C20370367
   A/C compressor sub:
   Subsystem 3 - Part No SW: 4G0 816 797 C    HW: 4G0 816 797 C
   Component: J842 EKK es33  H03 0015
   Serial number: 00000000019011300623
   A/C pressure/coolant temperature sensor 2:
   Subsystem 4 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G826 pT-Sens2  H11 0010
   Expansion valve 2 for refrigerant:
   Subsystem 5 - Part No SW: 4M0 816 682 E    HW: 4M0 816 682 E
   Component: N637 EV2_KaMi  H12 0102
   Serial number: 00000000000150607745
   Shut-off valve 2 for refrigerant:
   Subsystem 6 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N640 AV2_KaMi  H12 0102
   Serial number: 00000000000130558052
   Shut-off valve 3 for refrigerant:
   Subsystem 7 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N641 AV3_KaMi  H12 0102
   Serial number: 00000000000130558032
   Shut-off valve 4 for refrigerant:
   Subsystem 8 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N642 AV4_KaMi  H12 0102
   Serial number: 00000000000130558054
   Shut-off valve 5 for refrigerant:
   Subsystem 9 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N643 AV5_KaMi  H12 0102
   Serial number: 00000000000130558046
   Radiator shutter:
   Subsystem 10 - Part No SW: 95B 965 501 S    HW: 95B 965 501 S
   Component: V544KJS1  H12 0109
   Serial number: 20181116020103054048
   Radiator louver 2:
   Subsystem 11 - Part No SW: 95B 965 501 S    HW: 95B 965 501 S
   Component: V550KJS2  H12 0109
   Serial number: 20190107020103053575
   Coolant valve 1:
   Subsystem 12 - Part No SW: 4KE 963 375 K    HW: 4KE 963 375 K
   Component: N632 V1_KUEMI  010 0103
   Serial number: 00000000000000055677
   Coolant valve 2:
   Subsystem 13 - Part No SW: 4KE 963 375 J    HW: 4KE 963 375 J
   Component: N633 V2_KUEMI  010 0103
   Serial number: 00000000000000050503
   Coolant valve 3:
   Subsystem 14 - Part No SW: 4KE 963 375 H    HW: 4KE 963 375 H
   Component: N634 V3_KUEMI  010 0103
   Serial number: 00000000000000044029
   Coolant valve 4:
   Subsystem 15 - Part No SW: 4KE 963 375 N    HW: 4KE 963 375 N
   Component: N635 V4_KUEMI  010 0103
   Serial number: 00000000000000038112
   Part No SW: 5QE 915 684 J    HW: 5QE 915 684 J
   Component: OBC KOSTAL    H24 0023
   Serial number: --------------- Dataset Number: 4KE909811F  0001
   Coding: 7B588C6742080E000000
   ASAM Dataset: EV_OBC3Phase1KLOMLBev14B 002001
   ROD: EV_OBC2PhaseKLOMLBev14P.rod
   VCID: 56F5828058873A4A057-8002
   Flap 1 for charging socket:
   Subsystem 1 - Part No SW: 4KE 862 277 A    HW: 4KE 862 277 A
   Component: F496LKL1       004 0004
   Serial number: 20190622030206080256
   Flap 2 for charging socket:
   Subsystem 2 - Part No SW: 4KE 862 277 A    HW: 4KE 862 277 A
   Component: F497LKL2       004 0004
   Serial number: 20210711030206081327
2097938 - Charging Socket B; Charging Plug Lock
          P33E9 00 [032] - Mechanical Malfunction
13705549 - Databus
          U1121 00 [040] - Missing Message
          [DCDC_01_Timeout]
                    Reset counter: 35
                    Mileage: 66763 km
                    Date: 2023.08.11
                    Time: 15:05:55
3211269 - LIN Actuator for Tailgate 1
          B1A8A F0 [032] - Range of Motion Error
13709330 - Security Module (FuSi)
          U15C9 00 [032] - Function Override
2097287 - DC Quick-Charge; Charging Station Initialization Error
          P33E5 00 [032] - -
          [failed_authentification_charging_station]
3280899 - Signal Damping Protocol
          U15AC 00 [032] - Malfunction
          [ETHTRCV_30_AR7000_SLAC_STEP_3_PARAM_REQ_Timeout]
   Dataset Number: 4KE909469A  0005
   Coding: 628040051602
   VCID: 75B7E50CA54151522CD-8020
Address CD: Laser Scanner (J1122)       Labels: None
   Part No SW: 4K8 907 660 B    HW: 4N0 907 660
   Component: LASER_SCANNER H36 0202
   Dataset Number: 4KE909639G  0004
   ASAM Dataset: EV_LaserScannAU651 013013
   ROD: EV_LaserScannAU651_013.rod
   VCID: 3537250CE5C11152ECD-8060
11567120 - Laser for Adaptive Cruise
          C12EB F1 [008] - Malfunction
          [Zync_Watchdog_Error]
                    Reset counter: 143
                    Mileage: 66965 km
                    Date: 2023.08.14
                    Time: 12:09:56
                    Control Module temperature-Host: external temperature: 38 °C
                    Control Module temperature-Zynq: internal temperature: 52 °C
                    Control Module temperature-Host: internal temperature: 38 °C
                    Control Module temperature-Zynq: external temperature: 35 °C
                    Voltage terminal 15: 14.293 V
                    Vehicle speed: 11.67 km/h
                    Number of objects and segments-Number of objects: 94
                    Number of objects and segments-Number of segments: 102
                    Zynq_watchdog_failure_data-Glas_time: 32451 ms
                    Zynq_watchdog_failure_data-Mc0_runtime: 00 00
                    Zynq_watchdog_failure_data-Slas_time: 8673 ms
                    Zynq_watchdog_failure_data-Zynq_crash_indicator: 00
                    Zynq_watchdog_failure_data-Zynq_watchdog_causer: 00 00 00 00
Address CE: Drive Motor 2 (J944)       Labels: None
   Part No SW: 0EF 907 180 K    HW: 0EF 907 180 C
   Component: CUBZE68570AD0 H03 1005
   Revision: --------    Serial number: -00105.12.18000
   ASAM Dataset: EV_DMCM2HITACAU516 003009
   VCID: 3FDB4724D7FDDB02361-806A
Address CF: Lane Chge Asst 2 (J770)       Labels:* None
   Component: MRR_HL H12 0426
   Dataset Number: 4KE909468A  0005
   Coding: 1FDC80
   ASAM Dataset: EV_RearRadarS2DelphAU651 001018
   ROD: EV_RearRadarS2DelphAU651.rod
   Part No SW: 4K0 941 591 BC    HW: 4K0 941 591 B
   Component: LMS_MLBevo    H11 0031
   Dataset Number: 4KE909471D  0006
   ROD: EV_LMSLeftHELLAAU58X.rod
   VCID: 71BFD11CD1297D72F05-8024
   Dataset Number: 4KE909472D  0006
Address DB: Frt Corner Rdar 1 (J1089)       Labels:* None
   Part No SW: 4KE 907 669     HW: 4N0 907 669 A
   Component: MRR_VR H12 0426
   Dataset Number: 4KE909482A  0005
   Coding: 001000
   ASAM Dataset: EV_FrontCorneRadarS1AU651 001018
   ROD: EV_FrontCorneRadarS1AU651.rod
   VCID: 094F99FCD9B925B2585-805C
Address DC: Frt Corner Rdar 2 (J1088)       Labels:* None
   Component: MRR_VL H12 0426
   Dataset Number: 4KE909483A  0005
   Coding: 001000
   ASAM Dataset: EV_FrontCorneRadarS2AU651 001018
   ROD: EV_FrontCorneRadarS2AU651.rod
Address DE: Charger 1 for mobile dev (J1146)       Labels:* None
   Part No SW: 4N0 035 773 A    HW: 4N0 035 773 A
   Component: WLC Front NFC H11 0061
   Coding: 808000
   VCID: 2C010068368B509A833-8078
Address 8104: DC/DC Converter HV (A19)       Labels: None
   Part No SW: 4KE 907 171 B    HW: 4KE 907 171 B
   Component: DCDC Wandler H10 0400
   ASAM Dataset: EV_DCDCHVTDKAU516 001004
   ROD: EV_DCDCHVTDKAU516.rod
Address 8111: Rearview Mirror R (J1030)       Labels:* None
   Part No SW: 4KE 907 181 B    HW: 4KE 907 181 A
   Component: VAS H31 0029
   Coding: 00010B07
   ASAM Dataset: EV_RearVLeftFicosAU516 001009
   ROD: EV_RearVLeftFicosAU516.rod
   VCID: 40D944D8AA03A4FA4FB-8014
Address 8112: Rearview Mirror L (J1031)       Labels:* None
   Part No SW: 4KE 907 182 B    HW: 4KE 907 182 B
   Component: VAS H32 0029
   Coding: 00010B07
   ASAM Dataset: EV_RearVRightFicosAU516 001009
   VCID: 41DF41DCA109ADF2405-8014
End----------(Elapsed Time: 03:25, VBatt start/end: 13.1V/13.1V)-----------
Please install the English version of VCDS from this page. It will happily coexist on your PC with the Danish translation you are currently using.
"Too many tire pressure sensors"
I suspect the TPMS module can only support a certain number of sensor sets. My guess is two; one for summer tires and one for winter tires. But please post an English scan.
NEtech
Denmark
C?ID=56995
A controller map from Address [65] would also be interesting.
[Applications]
[Controller Channel Map]
- Controller Address = 65
- Login or security code: Leave blank
- Function: Measuring values
- Output: CSV file
[Go]
File is placed in C:\Ross-Tech\VCDS\Logs
Do you know if sensor in left rear wheel is different, compared to the other 3 ?
Esser
Denmark
C?ID=419845
Sorry, I downloaded the english version of VCDS, and have posted an english scan in the original post instead.
Esser
Denmark
C?ID=419845
[Applications]
- Output: CSV file
[Go]
Okay, I will see if I can get that as well.
All 4 sensors are exactly the same, fitted at the same time etc. And they did all work until I quickly took off the wheels and fitted them again a few hours later...
I think the map will help and here's reference data from mine:
(That thread is massive so give it some time to load)
I only have one wheel set however I recall needing to use a store type of option in the MIB followed by a test drive when a low pressure warning was present. I also believe it leaned the pressure that I put into the tires as the baseline rather than pre-set values.
You may want to wake up the sensors in the wheels that are going to stay on the car with a point and shoot tool -or- by rapidly letting air out and then re-inflating them to the proper value. Then, as long as all of the other/extra spare wheels and tires are far way use the MIB/MMI reset and let it sit there key on, e-motor(s) off for a while to see if it sorts itself before driving.
Esser
Denmark
C?ID=419845
Thanks for your reply Dana. I did all the normal procedures to get the TPMS working, which has also worked in the past with other wheel sets.
I will try and post the map, to see if there's anything useful in there.
Esser
Denmark
C?ID=419845
I managed to get the map, both the block map and the adaptation map:
;SW:4M0-907-273-B   HW:4M0-907-273-B ---  Tire Pressure
;Component:RDKHUFAU736   H05 0010, Coding:
;EV_RDKHUFAU736,002007,EV_RDKHUFAU736.rod
;Friday,15,September,2023,23:06:12:01663
;VCDS Version: Release 23.3.1 (x64)  Data version: 20230421 DS346.2
;VCID: 2F3B1764079D2B82A61-807A
Group,Description,Actual
IDE00019,Voltage terminal 30,13.00, V
IDE00310,Outside temperature,13.50, °C
IDE03529-IDE03205,Last received tire pressure sensor in reception range-Manufacturer code,0,
IDE03529-IDE03525,Last received tire pressure sensor in reception range-Sensor identification number (sensor ID),Not available,
IDE03529-MAS02818,Last received tire pressure sensor in reception range-CURRENT pressure,Not available,
IDE03529-MAS02819,Last received tire pressure sensor in reception range-CURRENT temperature,Not available,
IDE03529-ENG163867,Last received tire pressure sensor in reception range-Supplier identification_Textual,Not available,
IDE03535-IDE02955,System information-System status,active,
IDE03535-IDE03526,System information-Radio interference,not active,
IDE03535-MAS00080,System information-Coding information,02 00,
IDE03535-MAS00084,System information-Terminal 15 on,Yes,
IDE03535-MAS01561,System information-Unit,bar,
IDE03535-MAS01745,System information-Vehicle speed is not zero,No,
IDE03535-MAS02356,System information-Type of calibration,Menu,
IDE03535-MAS04188,System information-Transport mode,not activated,
IDE06105-IDE03205,Tire pressure sensor 01-Manufacturer code,0,
IDE06105-IDE03525,Tire pressure sensor 01-Sensor identification number (sensor ID),1,
IDE06105-IDE06104,Tire pressure sensor 01-Wheel position,Left front,
IDE06105-MAS02818,Tire pressure sensor 01-CURRENT pressure,Not available,
IDE06105-MAS02819,Tire pressure sensor 01-CURRENT temperature,Not available,
IDE06105-MAS02820,Tire pressure sensor 01-SPECIFIED pressure,2.20, bar
IDE06105-MAS05317,Tire pressure sensor 01-Warning pressure,Not available,
IDE06106-IDE03205,Tire pressure sensor 02-Manufacturer code,2,
IDE06106-IDE03525,Tire pressure sensor 02-Sensor identification number (sensor ID),757765312,
IDE06106-IDE06104,Tire pressure sensor 02-Wheel position,Left rear,
IDE06106-MAS02818,Tire pressure sensor 02-CURRENT pressure,Not available,
IDE06106-MAS02819,Tire pressure sensor 02-CURRENT temperature,Not available,
IDE06106-MAS02820,Tire pressure sensor 02-SPECIFIED pressure,2.40, bar
IDE06106-MAS05317,Tire pressure sensor 02-Warning pressure,Not available,
IDE06107-IDE03205,Tire pressure sensor 03-Manufacturer code,0,
IDE06107-IDE03525,Tire pressure sensor 03-Sensor identification number (sensor ID),3,
IDE06107-IDE06104,Tire pressure sensor 03-Wheel position,Right front,
IDE06107-MAS02818,Tire pressure sensor 03-CURRENT pressure,Not available,
IDE06107-MAS02819,Tire pressure sensor 03-CURRENT temperature,Not available,
IDE06107-MAS02820,Tire pressure sensor 03-SPECIFIED pressure,2.20, bar
IDE06107-MAS05317,Tire pressure sensor 03-Warning pressure,Not available,
IDE06108-IDE03205,Tire pressure sensor 04-Manufacturer code,0,
IDE06108-IDE03525,Tire pressure sensor 04-Sensor identification number (sensor ID),4,
IDE06108-IDE06104,Tire pressure sensor 04-Wheel position,Right rear,
IDE06108-MAS02818,Tire pressure sensor 04-CURRENT pressure,Not available,
IDE06108-MAS02819,Tire pressure sensor 04-CURRENT temperature,Not available,
IDE06108-MAS02820,Tire pressure sensor 04-SPECIFIED pressure,2.40, bar
IDE06108-MAS05317,Tire pressure sensor 04-Warning pressure,Not available,
IDE07159-MAS01155,Control module switch-off: counter-Control module,00,
IDE07159-MAS05583,Control module switch-off: counter-Data bus,1,
IDE10637-MAS10949,Currently received wheel electronics-Manufacturer code 1,Not available,
IDE10637-MAS10950,Currently received wheel electronics-Manufacturer code 2,Not available,
IDE10637-MAS10951,Currently received wheel electronics-Manufacturer code 3,Not available,
IDE10637-MAS10952,Currently received wheel electronics-Manufacturer code 4,Not available,
IDE10637-MAS10953,Currently received wheel electronics-Manufacturer code 5,Not available,
IDE10637-MAS10954,Currently received wheel electronics-Manufacturer code 6,Not available,
IDE10637-MAS10955,Currently received wheel electronics-Manufacturer code 7,Not available,
IDE10637-MAS10956,Currently received wheel electronics-Manufacturer code 8,Not available,
IDE10637-MAS10959,Currently received wheel electronics-Identification number 1,Not available,
IDE10637-MAS10960,Currently received wheel electronics-Identification number 2,Not available,
IDE10637-MAS10961,Currently received wheel electronics-Identification number 3,Not available,
IDE10637-MAS10962,Currently received wheel electronics-Identification number 4,Not available,
IDE10637-MAS10963,Currently received wheel electronics-Identification number 5,Not available,
IDE10637-MAS10964,Currently received wheel electronics-Identification number 6,Not available,
IDE10637-MAS10965,Currently received wheel electronics-Identification number 7,Not available,
IDE10637-MAS10966,Currently received wheel electronics-Identification number 8,Not available,
IDE10637-ENG163868,Currently received wheel electronics-Supplier_code_1_Textual,Not available,
IDE10637-ENG163869,Currently received wheel electronics-Supplier_code_2_Textual,Not available,
IDE10637-ENG163870,Currently received wheel electronics-Supplier_code_3_Textual,Not available,
IDE10637-ENG163871,Currently received wheel electronics-Supplier_code_4_Textual,Not available,
IDE10637-ENG163872,Currently received wheel electronics-Supplier_code_5_Textual,Not available,
IDE10637-ENG163873,Currently received wheel electronics-Supplier_code_6_Textual,Not available,
IDE10637-ENG163874,Currently received wheel electronics-Supplier_code_7_Textual,Not available,
IDE10637-ENG163875,Currently received wheel electronics-Supplier_code_8_Textual,Not available,
IDE10756,Left front tire pressure sensor: remaining oper. life,127, m
IDE10756-ENG162989,Left front tire pressure sensor: remaining oper. life-Left_front_tire_pressure_sensor_remaining_operation_time_Textual,Not available,
IDE10757,Right front tire pressure sensor: remaining oper. life,127, m
IDE10757-ENG163541,Right front tire pressure sensor: remaining oper. life-Right_front_tire_pressure_sensor_remaining_operation_time_Textual,Not available,
IDE10758,Left rear tire pressure sensor: remaining oper. life,127, m
IDE10758-ENG162994,Left rear tire pressure sensor: remaining oper. life-Left_rear_tire_pressure_sensor_remaining_operation_time_Textual,Not available,
IDE10759,Right rear tire pressure sensor: remaining oper. life,127, m
IDE10759-ENG163546,Right rear tire pressure sensor: remaining oper. life-Right_rear_tire_pressure_sensor_remaining_operation_time_Textual,Not available,
IDE10760-MAS02820,Left front tire pressure sensor: nominal pressure-SPECIFIED pressure,2.20, bar
IDE10761-MAS02820,Right front tire pressure sensor: nominal pressure-SPECIFIED pressure,2.20, bar
IDE10762-MAS02820,Left rear tire pressure sensor: nominal pressure-SPECIFIED pressure,2.40, bar
IDE10763-MAS02820,Right rear tire pressure sensor: no-SPECIFIED pressure,2.40, bar
IDE10764-MAS02818,Left front tire pressure sensor: actual pressure-CURRENT pressure,Not available,
IDE10765-MAS02818,Right front tire pressure sensor: actual pressure-CURRENT pressure,Not available,
IDE10766-MAS02818,Left rear tire pressure sensor: actual pressure-CURRENT pressure,Not available,
IDE10767-MAS02818,Right rear tire pressure sensor: actual pressure-CURRENT pressure,Not available,
IDE10768-MAS02819,Left front tire pressure sensor: temperature-CURRENT temperature,Not available,
IDE10769-MAS02819,Right front tire pressure sensor: temperature-CURRENT temperature,Not available,
IDE10770-MAS02819,Left rear tire pressure sensor: temperature-CURRENT temperature,Not available,
IDE10771-MAS02819,Right rear tire pressure sensor: temperature-CURRENT temperature,Not available,
IDE10772-IDE03205,Left front tire pressure sensor: identification-Manufacturer code,Not available,
IDE10772-IDE03525,Left front tire pressure sensor: identification-Sensor identification number (sensor ID),1,
IDE10772-ENG163867,Left front tire pressure sensor: identification-Supplier identification_Textual,Not available,
IDE10773-IDE03205,Right front tire pressure sensor: identification-Manufacturer code,Not available,
IDE10773-IDE03525,Right front tire pressure sensor: identification-Sensor identification number (sensor ID),3,
IDE10773-ENG163867,Right front tire pressure sensor: identification-Supplier identification_Textual,Not available,
IDE10774-IDE03205,Left rear tire pressure sensor: identification-Manufacturer code,numerical value: no text,
IDE10774-IDE03525,Left rear tire pressure sensor: identification-Sensor identification number (sensor ID),757765312,
IDE10774-ENG163867,Left rear tire pressure sensor: identification-Supplier identification_Textual,numerical value: no text,
IDE10775-IDE03205,Right rear tire pressure sensor: identification-Manufacturer code,Not available,
IDE10775-IDE03525,Right rear tire pressure sensor: identification-Sensor identification number (sensor ID),4,
IDE10775-ENG163867,Right rear tire pressure sensor: identification-Supplier identification_Textual,Not available,
IDE10776,Radio interference levels,25,
IDE10902-IDE10772,Expanded ambient data 1-Left front tire pressure sensor: identification,1,
IDE10902-IDE10773,Expanded ambient data 1-Right front tire pressure sensor: identification,3,
IDE10902-IDE10774,Expanded ambient data 1-Left rear tire pressure sensor: identification,757765312,
IDE10902-IDE10775,Expanded ambient data 1-Right rear tire pressure sensor: identification,4,
IDE10903-IDE10760,Expanded ambient data 2-Left front tire pressure sensor: nominal pressure,2.20, bar
IDE10903-IDE10764,Expanded ambient data 2-Left front tire pressure sensor: actual pressure,Not available,
IDE10903-IDE10768,Expanded ambient data 2-Left front tire pressure sensor: temperature,Not available,
IDE10903-IDE10772,Expanded ambient data 2-Left front tire pressure sensor: identification,1,
IDE10904-IDE10761,Expanded ambient data 3-Right front tire pressure sensor: nominal pressure,2.20, bar
IDE10904-IDE10765,Expanded ambient data 3-Right front tire pressure sensor: actual pressure,Not available,
IDE10904-IDE10769,Expanded ambient data 3-Right front tire pressure sensor: temperature,Not available,
IDE10904-IDE10773,Expanded ambient data 3-Right front tire pressure sensor: identification,3,
IDE10905-IDE10762,Expanded ambient data 4-Left rear tire pressure sensor: nominal pressure,2.40, bar
IDE10905-IDE10766,Expanded ambient data 4-Left rear tire pressure sensor: actual pressure,Not available,
IDE10905-IDE10770,Expanded ambient data 4-Left rear tire pressure sensor: temperature,Not available,
IDE10905-IDE10774,Expanded ambient data 4-Left rear tire pressure sensor: identification,757765312,
IDE10906-IDE10763,Expanded ambient data 5-Right rear tire pressure sensor: no,2.40, bar
IDE10906-IDE10767,Expanded ambient data 5-Right rear tire pressure sensor: actual pressure,Not available,
IDE10906-IDE10771,Expanded ambient data 5-Right rear tire pressure sensor: temperature,Not available,
IDE10906-IDE10775,Expanded ambient data 5-Right rear tire pressure sensor: identification,4,
IDE10907-IDE00075,Expanded ambient data 6-Vehicle speed,0.00, km/h
IDE10907-IDE00310,Expanded ambient data 6-Outside temperature,13.50, °C
IDE10908,Expanded ambient data 7,00,
IDE80002-IDE00056,Analysis 2-History data 1,0C 01 0A 11 0E 09 17 27 91 11 8B 2F 15 00 00 00,
IDE80002-IDE00057,Analysis 2-History data 2,0C 01 09 F1 0E 09 17 19 92 00 7F 2D 15 00 00 00,
IDE80002-IDE00058,Analysis 2-History data 3,0C 01 09 F1 0E 09 17 0F 92 00 7F 2C 15 00 00 00,
IDE80002-IDE00059,Analysis 2-History data 4,0C 01 09 F1 0E 09 17 0A 92 00 7F 2D 15 00 00 00,
IDE80002-IDE00060,Analysis 2-History data 5,0D 01 09 F1 0E 09 17 19 00 00 00 00 00 00 00 00,
IDE80002-IDE00061,Analysis 2-History data 6,0D 01 09 F1 0E 09 17 0A 00 00 00 00 00 00 00 00,
IDE80002-IDE00062,Analysis 2-History data 7,0C 01 09 EB 0D 09 17 27 90 22 88 2D 15 00 00 00,
IDE80002-IDE00063,Analysis 2-History data 8,0C 01 09 B8 0B 09 17 19 90 16 89 2D 15 00 00 00,
IDE80002-IDE00064,Analysis 2-History data 9,0C 01 09 B8 0B 09 17 14 90 16 89 2D 15 00 00 00,
IDE80002-IDE00065,Analysis 2-History data 10,0C 01 09 B8 0B 09 17 0A 90 16 89 2D 15 00 00 00,
IDE80002-MAS03991,Analysis 2-Reception level antenna 1,460, mV
IDE80002-MAS04488,Analysis 2-Offset level antenna 1,210, mV
MAS00464-MAS00106,Standard - ambient data 1-Year,2023, yr
MAS00464-MAS00107,Standard - ambient data 1-Month,9, m
MAS00464-MAS00108,Standard - ambient data 1-Day,15, d
MAS00464-MAS00109,Standard - ambient data 1-Hours,22, H
MAS00464-MAS00110,Standard - ambient data 1-Minutes,36, min
MAS00464-MAS00111,Standard - ambient data 1-Seconds,20, s
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,133,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,68185, km
MAS02821-MAS01853,Check tire pressure-Left front,no warning,
MAS02821-MAS01854,Check tire pressure-Right front,no warning,
MAS02821-MAS01855,Check tire pressure-Left rear,no warning,
MAS02821-MAS01856,Check tire pressure-Right rear,no warning,
MAS02821-MAS05636,Check tire pressure-Unknown position,no warning,
MAS02822-MAS01853,Flat tire-Left front,no warning,
MAS02822-MAS01854,Flat tire-Right front,no warning,
MAS02822-MAS01855,Flat tire-Left rear,no warning,
MAS02822-MAS01856,Flat tire-Right rear,no warning,
MAS02822-MAS05636,Flat tire-Unknown position,no warning,
MAS02823-MAS01853,Tire pressure too low-Left front,no warning,
MAS02823-MAS01854,Tire pressure too low-Right front,no warning,
MAS02823-MAS01855,Tire pressure too low-Left rear,no warning,
MAS02823-MAS01856,Tire pressure too low-Right rear,no warning,
MAS02823-MAS05636,Tire pressure too low-Unknown position,no warning,
;Friday,15,September,2023,23:06:20:01663
IDE00820-ENG136322-Activating and deactivating all development messages-Internal_fault_number,0 ,3
IDE00820-ENG110578-Activating and deactivating all development messages-S_100,not activated ,3
IDE00820-ENG110579-Activating and deactivating all development messages-S_101,not activated ,3
IDE00820-ENG110580-Activating and deactivating all development messages-S_102,not activated ,3
IDE00820-ENG136320-Activating and deactivating all development messages-S_103-S_104,not activated ,3
IDE00820-ENG136321-Activating and deactivating all development messages-S_105-S_112,not activated ,3
IDE00820-ENG99057-Activating and deactivating all development messages-XCP,not activated ,3
IDE03513-IDE03525-Write sensor identification number-Sensor identification number (sensor ID),757765312 ,5
IDE03513-IDE06104-Write sensor identification number-Wheel position,Left rear ,5
It seems there's only the sensor id: 757765312, for the rear left wheel in the block map, which is the last sensor id I manually entered in VCDS...
Esser
Denmark
C?ID=419845
[Applications]
- Output: CSV file
[Go]
Does the maps tell you anything useful..? I am not completly certain of what to look for myself.
NEtech
Denmark
C?ID=56995
To me it looks like DTC C112B is the reason you can only save 1 wheel sensor.
Maybe Basic Setting IDE01475-ENG114972 is used to reset all pressure sensors.
But if not, could also mean you have to go to Audi to fix it !
If you should be nearby my address, I can test it on your car.
You could test if Security Access: 20103 is accepted, Just try one time, if not accepted!
Maybe @Dana has more input on Monday.
Esser
Denmark
C?ID=419845
But isn’t it strange that the sensors did work, until I removed the wheels from the car for a few hours..?
Also I used to have a set of both summer and winter tires that worked without any issues at all…
Westbury, UK
Did you put the wheels back on in the same places they came from?
Esser
Denmark
C?ID=419845
Yes, each wheel went back to where they were just a few hours before.
NEtech
Denmark
C?ID=56995
So you maybe calibrated sensor's in the morning Sep.14 ?
And DTC:
Came for the first time, when you drove, Sep.14 in the afternoon ?
Esser
Denmark
C?ID=419845
And DTC:
On the morning of the 14th., I cleared the fault codes again and entered the sensors ID's again, just to give it a try before driving for 45 minutes or so. But the yellow TPMS light appeared soon after driving off...
Hi guys,
I ran some testing this morning on my e-tron. The hood had to be opened due to the diagnostic firewall but the steps were done in this order:
1) Maps key on after it sat most unused for roughly 20 hours.
2) Maps with SA code used.
3) I drove it fast enough to get all 4 TPMS sensors showing on the MIB screen, stopped the car, opened the hood and did the final map set.
4) Ran/saved a scan before disconnecting.
@NEtech has a copy of the files but I dropped a copy here as well: https://drive.google.com/file/d/1O1AjxrSoAb0Lxu46cUH6Q7Guwfvl237l/view?usp=sharing
I do not have spare wheels or spare sensors but based on what I see there the sensors would need to be awake (point and shoot tool, let air out and reinflate or simply drive it) before sensor data is shown. I'll try a few more things and report back if I have any contributions.
Esser
Denmark
C?ID=419845
Hi guys,
Thank you so much for going through all this trouble Dana! That's crazy...
I don't have a tool to wake up the sensors, but I have tried driving the car, a lot and tried inflating the tires more, but nothing seems to do the trick...
When the sensors did work during the summer, there were some rare occasions where the car would loose connection with them for a bit, but then they would come back on again.
If you do not have a better suggestion, I'm affraid they might just be crappy sensors...? That's all I can come up with at least.
It's just that replacing them, is a bit of a hassle since I don't have access to a tire maching myself, so I have to get a workshop to swap them out...
Yeah, but you don't want a tire machine. We owned one for years and .. 99% of the use was friends / family stopping over for free tire mounting or TPMS things. Selling it (shortly after I left the dealer and started with Ross-Tech) was the smartest thing I ever did!
I will report back with any further suggestions but I would be tempted to either put one of the older wheel sets back on and use the MMI/MIB to learn tires followed by a drive -or- check your distance to Niels. If a drive to his location is reasonable he has ODIS which helps if this is an issue that can't be sorted with VCDS.
Esser
Denmark
C?ID=419845
Haha, good point.
I did recently have my other set of wheels on the car, and the sensors worked fine, without having to use VCDS or anything, other than the normal procedure in the MMI when swapping wheels.
OK, I think putting that wheel set back on and driving for a while to see if you can get the goofy C112B 00 [009] - Too Many Tire Pressure Sensors DTC to clear would be best for now. It that will clear automatically, or flip to Intermittent so it can be cleared, I think you will be in a better way.
