Help needed with fault code 01315 on my 2006 Audi A4 3.0tdi please
dt-tdi
C?ID=207607
Hi all
Can anyone help with this fault code please: 01315 - Transmission Control Module
Done a scan on my car today to clear a fault code from a faulty earth wire I had in my boot lid but this one will not clear.
The scan showing this is below:
 Tuesday,22,April,2014,16:34:54:43365
 VCDS Version: 12.12.2.0 (x64)
 Data version: 20140212
 VIN: WAUZZZ8EX7A144772 License Plate: DT7734
 Mileage: 67570km-41986mi Repair Order:
 67 69 75 76 77
 VIN: WAUZZZ8EX7A144772 Mileage: 67570km/41986miles
 Address 01: Engine Labels: Redir Fail!
 Part No SW: 8E0 910 401 N HW: 8E0 907 401 AL
 Component: 3.0L V6TDI G000AG 0050
 Revision: --H03--- Serial number: XXXXXXXXXXXXXX
 Coding: 0011171
 Shop #: WSC 66565 257 00032
 VCID: 2A5D6E2985564C4EE53-807F
 Readiness: 0 0 1 1 1
 Part No SW: 8E1 910 156 H HW: 09L 927 156 B
 Component: AG6 09L 3,0 TDI 171 0070
 Revision: --H01--- Serial number: 4256683
 Coding: 0000002
 Shop #: WSC 06325 000 00000
 VCID: 2C5168318FA2527E17F-8079
 Address 03: ABS Brakes Labels: 8E0-910-517.clb
 Part No SW: 8E0 910 517 J HW: 8E0 614 517 BH
 Component: ESP8 quattro H06 0140
 Coding: 0004426
 VCID: 2E556239B9BE206E39B-807B
 Reset counter: 10
 Hex Value: 0x0000
 Hex Value: 0x0002
 Hex Value: 0x0013
 Hex Value: 0x4495
 Hex Value: 0x0001
 Address 08: Auto HVAC Labels: 8E0-820-043.lbl
 Part No: 8E0 820 043 BM
 Component: A4 Klimaautomat 3233
 Coding: 00000
 VCID: 6DD7A53527389B76401-5196
 Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
 Part No: 8E0 907 279 N
 Component: int. Lastmodul ECE 0907
 Coding: 00001
 Shop #: WSC 06325
 VCID: 3D77557537D8CBF6B01-4B32
 Address 15: Airbags Labels: 8E0-959-655-94.lbl
 Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
 Component: Airbag 9.41 H12 3730
 Revision: 91H12373 Serial number: 0036M0G4MUU4
 Coding: 0031612
 VCID: 3B735B6D7ACCC5C68E5-806E
 Subsystem 1 - Serial number: 6332DRB404360C9EV
 Subsystem 2 - Serial number: 6342DRB4042AD42BU
 Subsystem 3 - Serial number: 6352ARB401D63E67W
 Subsystem 4 - Serial number: 6362ARB401D6387AV
 Subsystem 5 - Serial number: 63729RB401D9773CZ
 Subsystem 6 - Serial number: 63829RB401D9770AV
Address 16: Steering wheel Labels: 8E0-953-549.lbl
 Part No: 8E0 953 549 Q
 Component: Lenksáulenmodul 0701
 Coding: 02041
 Shop #: WSC 06325
 VCID: 418F29854B20AF16D49-4B32
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
 Part No SW: 8E0 920 983 A HW: 8E0 920 983 A
 Component: KOMBI+WFS 4 H14 0200
 Revision: 0200 Serial number: 00000000000000
 Coding: 0007418
 Shop #: WSC 01189 210 175629
 VCID: 2D576535B7B85B76001-5178
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
 Coding: 0007418
 VCID: 2D576535B7B85B76001-515A
Tuesday,22,April,2014,17:05:10:43365
 67 69 75 76 77
 Coding: 0011171
 Coding: 0000002
 Coding: 0004426
 Reset counter: 10
 Hex Value: 0x0000
 Hex Value: 0x0002
 Hex Value: 0x0013
 Hex Value: 0x4495
 Hex Value: 0x0001
 Coding: 00000
 Coding: 00001
 Shop #: WSC 06325
 Coding: 0031612
 Coding: 02041
 Shop #: WSC 06325
 Coding: 0007418
 Coding: 0007418
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
 Part No: 8E0 951 177
 Component: Innenraumueberw. 0804
 Coding: 00001
 VCID: EBD32B2D992C1546DE5-515A
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
 Part No: 8E0 959 433 CH
 Component: Komfortgerát T3B 4135
 Coding: 07919
 Shop #: WSC 06325
 VCID: 79FF8165637037D6DC9-4B18
 Subsystem 1 - Part No: 8E2959802F
 Component: Tõrsteuer.FS BRM 0606
 Subsystem 2 - Part No: 8E2959801F
 Component: Tõrsteuer.BF BRM 0606
 Component: Tõrsteuer.HL BRM 0606
 Subsystem 4 - Part No: 8E0959802E
 Component: Tõrsteuer.HR BRM 0606
Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
 Part No SW: 8E0 919 283 E HW: 8E0 919 283 E
 Component: Parkhilfe 8-Kan H06 0010
 Revision: 00H06000 Serial number: 00067802130629
 Coding: 0001104
 VCID: 326D7649AE86048E5D3-515A
 Reset counter: 96
 End ---------------------------------------------------------------------
Thanks in advance
David
NostraJackAss
Sounds like a faulty twisted pair or inadequate shield picking up possible noise.
Check connections but please first reboot the system and try a direct reset of the DTC.
Observe com in VCDS advance measuring blocks....... logging while performing wiggle tests to see if you catch something.
dt-tdi
C?ID=207607
Apologies if I sound a bit thick but could you please explain that to me as a 4 year old lol
I'm very new to this diagnostics but am keen to learn and save myself a few quid in the process.
At present I have only done a basic scan of my car to show the fault codes I've been getting.
Many thanks in advance for your patience.
David
NostraJackAss
Check the wires which are responsible for CANBUS High/Low communications as per wire diagram in repair manual. ( twisted pair )
Check connections at modules for rodent damage or shield disruption or foreign objects such as water.....
Observe measured values in VCDS advanced blocks....selecting modules related to communication and tug wires to see if connectivity can be observed disrupted while logging.
Review the log when you are done to see if you find a problem.
Hope that helps....
