2012 US-spec Audi TTRS - Instruments to RoW, parking light feature, rain closing?
ZPrime
USA - Cleveland, OH
C?ID=69222
Hello all...
I have a 2012 US-spec TTRS, and 3 questions.
Question #1:
I would like to change the instrument cluster to Rest-of-World (LHD) in order to stop the stupid dinging from the cluster when the key is in the ignition with the door open.
I am able to change the code without issue, but when I do this, my gas gauge magically drops something like 1/16th of a tank. It reads too low, and I'm not sure why. I've verified this by topping the tank and then changing from US cluster to RoW cluster while sitting at the gas station, and the needle visibly drops off of "F" when in RoW and returns to the correct spot when back in US cluster mode. Oddly, if I change the cluster to Canada (instead of US), the gas gauge maintains its accuracy, but this doesn't eliminate the dings I'm looking to remove so RoW seems to be my only answer.
I'm aware that the FIS/DIS cluster display values change when switching to RoW, but it allows me to alter the units back to US/English so I'm not sure why/how this would affect the gas gauge.
Is there a way to fix this? I'm aware that there are Adaptation channels in Instruments that allow me to tweak the location of the needle, but I don't understand why US & Canada spec would be accurate while RoW isn't. Or does each country have its own independent Adaptation values that don't affect each other??
Question #2:
On my old VW (2008 R32), switching to Euro/RoW cluster enabled the ability to use the Euro "side parking light" feature, where one light on the front and rear of the car stay lit when the indicator stalk is left in that direction when exiting the car. This was a feature that I really liked, because I occasionally park on a curve on the street in front of my parents' house, and the increased visibility was very nice.
The indicator stalk on the Audi has the appropriate "P <-" icon that indicates this function, but leaving it in a position does nothing, even with the Instruments in RoW mode. I suspect that I might have to alter the lighting setting in module 09 byte 18, but that drop-down box comes with dire warnings so I didn't want to touch it without consulting with experts first. (If nobody from Ross-Tech answers here I will be e-mailing, being a registered VCDS owner.)
To my knowledge, the only differences between US-spec and RoW-spec lighting on an 8J/Mk2 TT is that the headlights have an amber slash with amber LED behind it for the sidelight (at the end of the DRL strip), and the RoW tails use amber instead of red turn signals (I wish we had those, even though the full-red is nicer to look at). I have a few concerns about altering the lighting drop-down.
  1. If I change it from 77 to 59, will I be able to change it back? Why does this dialog have dire warnings?
  2. Assuming 59 will enable the Parking light feature, will the car then treat the amber sidemarker light as part of the LED DRL? If so, this would mean the amber sidemarker is lit whenever DRLs are on - currently the sidemarker only lights when DRLs are "dim" to act as "city lights".
  3. What the heck is 58? I'm not sure why 77 or 59 claim "LED DRLs (front/rear)" because there are no LEDs on the rear of the Mk2 TT.
Question #3:
Why can't I enable rain-closing on this car? It has a RLS, but the coding screen for the RLS is missing the check box in Byte 0 / Bit 1, "Rain closing active." If I manually flip Bit 1 to ON, the coding does save / accept, but it still doesn't seem to work. (I've already enabled the appropriate bits in module 09 for rain closing as well.)
A recent full auto-scan is below. I own a HEX-CAN so I can re-scan or do anything else requested. I'll be providing a full "virgin" scan for the car in the appropriate subforum as well. I have an aftermarket radio in the car because RNS-E is awful, that's why there are errors regarding radio connectivity.
Monday,24,August,2015,20:10:05:15606
VCDS Version: 15.7.0.2
Data version: 20150820
VIN: TRUB3AFK7C1901112   License Plate: BLU SHEL
Mileage: 26520km-16478mi   Repair Order: us cluster for fuel level
Chassis Type: FK (7N0)
Scan: 01 03 08 09 10 14 15 16 17 19 22 25 42 44 46 47 4C 52 55 61
          77
VIN: TRUB3AFK7C1901112   Mileage: 26520km-16478miles
Address 01: Engine (CEP)       Labels: 07K-907-404-CEP.clb
   Part No SW: 8J0 907 404 Q    HW: 8J0 907 404 M
   Component: 2.5l R5/4V TFSI     0020
   Revision: F7H05---    Serial number: AUX7Z0KNFN403E
   Coding: 0113000A180F0160
   Shop #: WSC 01236 785 00200
   VCID: 3B90E0E878B5F0E7E06CDA-806E
Address 03: ABS Brakes        Labels: 8J0-614-517.clb
   Part No SW: 8J0 910 517 A    HW: 8J0 614 517 F
   Component: ESP MK60E1          0020
   Revision: 00H60001
   Coding: 0618391
   VCID: 2ABED5AC872F796F8B9A87-807E
   Part No SW: 8J0 820 043 BD    HW: 8J0 820 043 BD
   Component: J255  Klima 1 Zone  0110
   Revision: 00H09006    Serial number: 00000001201872
   Coding: 1572901
   VCID: 693C6AA042A9B2774220D0-803C
Address 09: Cent. Elect. (J519)       Labels: 8P0-907-063.clb
   Part No SW: 8P0 907 063 S    HW: 8P0 907 063 S
   Component: BCM PQ35  H   110 0667
   Revision: AG110667
   Coding: 6E000B3CE83336242074C1E000900C4D52F677AA1020D928DF000A440041
   Shop #: WSC 01236 758 00200
   VCID: 44629B14054B4F1F9196B9-8010
   Subsystem 1 - Part No SW: 8J1 955 119 A    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer AU354  H08 0070
   Coding: 00FD10
   Subsystem 2 - Part No SW: 8K0 910 557     HW: 8K0 955 559 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSEN  H04 0003
   Coding: 06492C
Address 10: Park/Steer Assist (J446)       Labels: 8P0-919-475-7X1.clb
   Part No SW: 8P0 919 475 M    HW: 8P0 919 475 M
   Component: PARKHILFE 4K  H01 0140
   Revision: 11001001    Serial number: 36861132201627
   Coding: 00000B
   VCID: 487A8F2439636B7F7DEE4D-801C
Address 14: Susp. Elect.        Labels: 8P0-907-376.lbl
   Part No SW: 8J0 910 376 E    HW: 8J0 907 376 E
   Component: J250 Raddaempfung   0110
   Revision: --H22---    Serial number: 190DPH 1277098
   Coding: 0000072
   VCID: 318CC2C0AAF90AB74AD048-8064
Address 15: Airbags        Labels: 8J0-959-655.lbl
   Part No SW: 8J0 959 655     HW: 8J0 959 655
   Component: 20 Airbag 9.43  H03 0020
   Revision: 93H03002    Serial number: 0036K005MU22
   Coding: 0012848
   VCID: 791C3AE0320902F7B28060-802C
   Subsystem 1 - Part No: 8J0 959 339 B
   Component: BF-Gewichtsens. H03 0040
   Subsystem 2 - Serial number: 00QEX
   Subsystem 3 - Serial number: 0001.01.0000H0300000000000ˇÜ63
   Subsystem 4 - Serial number: 000000ˇÜ6332DRB40E0BD0B3ZˇÜ63
   Subsystem 5 - Serial number: BD0B3ZˇÜ6342DRB40E0CCB0F5ˇÜ63
   Subsystem 6 - Serial number: CCB0F5ˇÜ63747RB4067B20C4PˇÜ63
   Subsystem 7 - Serial number: B20C4PˇÜ63847RB4067B7BC0 ˇ
   Subsystem 8 - Serial number: B7BC0 ˇ
   Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
   Coding: 0004041
   VCID: 4666811C3377BD0F8F8253-8012
   Component: E0221           H06 0030
01304 - Radio
01301 - Control Module for Voice Recognition (J507)
Address 17: Instruments        Labels: 8J0-920-xxx-17-MY8.clb
   Part No SW: 8J0 920 990 P    HW: 8J0 920 990 P
   Component: KOMBIINSTR. VDO H02 0650
   Revision: D0H02002    Serial number: 224NK002000355
   Coding: 0117208
   Shop #: WSC 51621 001 104857
   VCID: 3F6894F86CADECC7CC44EE-806A
   Part No SW: 7N0 907 530 N    HW: 1K0 907 951
   Component: J533  Gateway H43 1623
   Revision:   H43       Serial number: 171111F1003257
   Coding: 354100
   VCID: 3B90E0E878B530E7E06CDA-806E
   Part No SW: 2K0 907 554 D    HW: 2K0 907 554 D
   Component: Haldex 4Motion      5010
   Coding: 0000005
   Shop #: WSC 07126 001 1048576
   VCID: 2F88C4B8BCCD1C475CE45E-807A
   Revision: D0H02002    Serial number: AUX7Z0KNFN403E
   Part No SW: 8J8 959 801 J    HW: 8J8 959 801 J
   Component: Tuer-SG         004 0102
   Coding: 0001149
   VCID: 44629B14054B8F1F9196B9-8010
   Part No: 8J0 909 144 N
   Component: EPS_ZFLS Kl. 239    3301
   Revision: 00H22000
Address 47: Sound System        Labels: 8J0-035-223.lbl
   Part No SW: 8J0 035 223 D    HW: 8J0 035 223 D
   Component: J525 Amp High   H04 0160
   Revision: PROD_01     Serial number: 00000000032329
   Coding: 0246116
   VCID: 25A42690EE315617A648CC-8070
01304 - Radio
                    Fault Frequency: 187
                    Reset counter: 161
                    Mileage: 24420 km
                    Date: 2015.07.05
                    Time: 14:13:13
Address 4C: Tire Pressure II        Labels: 8J0-907-274.lbl
   Part No SW: 8J0 907 274 C    HW: 4F0 907 274
   Component: J793  RKA+      H04 0190
   Revision: 00000518    Serial number: 00005180128320
   Coding: 0604600
   VCID: 328ECDCCAFFF31AF33CA7F-8066
   Part No SW: 8J8 959 802 J    HW: 8J8 959 802 J
   Coding: 0001148
   VCID: 456486100E71B6178688AC-8010
   Part No SW: 4L0 910 357 B    HW: 4L0 907 357 B
   Coding: 0000025
   VCID: 2BB0D0A888D56067708C8A-807E
   Subsystem 1 - Part No: 8E0 941 329 A
   Component: AFS-Modul links H05 0030
   Subsystem 2 - Part No: 8E0 941 329 A
   Component: AFS-Modul rechtsH05 0030
   Component: Batt.regelung H43 1623
   Coding: F324115A
   VCID: 710C02C06A798AB70A5088-8024
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0141
   Part No SW: 8P1 862 336 A    HW: 8P1 862 336
   Component: FSE_256x BT     H44 0660
   Revision: 00000000    Serial number: 00000005160000
   Coding: 0011407
   VCID: 3686F1DC43972D8F1F2203-8062
02503 - Output Wire to Radio
                    Reset counter: 68
                    Mileage: 24420 km
                    Date: 2015.07.05
                    Time: 13:51:19
01304 - Radio
                    Fault Frequency: 177
                    Reset counter: 161
                    Mileage: 24420 km
                    Date: 2015.07.05
                    Time: 13:51:19
End-------------------------(Elapsed Time: 02:41)--------------------------
