VW Phaeton 2005 (55 reg) 3.0 TDI - G450 Adaption
DGMotors
C?ID=57532
Hi,
Ive fitted a new G450 pressure sesnor/Pipes to a VW Phaeton 3.0 TDi BMK engine. Can anyone tell me the code for adapting the sensors on these please?
Ive tried the normal 30605 in (Coding-II 11) and (Security - 16) but these dont seem to work.
Any ideas?
Cheers Toby
VCDS Version: Release 15.7.0 Running on Windows 7 x86
Data version: 20150729
DG Motor Services
Friday,21,August,2015,10:57:55:33814
Chassis Type: 3D (3D - VW Phaeton (2002 > 2006))
Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 27 28 29 2E
          34 36 37 38 39 46 47 55 56 57 65 66 68 69 71 75 76 77
VIN: WVWZZZ3DZ68001***   Mileage: 149860km-93118miles
   Part No SW: 3D0 907 401     HW: 8E0 907 401 AB
   Component: 3.0L V6TDI  A000AG  0040
   Revision: --H01---    Serial number: VWZ3Z0E1371050
   Coding: 0011773
   Shop #: WSC 00864 210 104192
   VCID: DCBDD01C1CAF11DEEA-5140
001378 - System Voltage
               P0562 - 001 - Too Low - Intermittent
                    Fault Status: 00100001
                    Mileage: 148342 km
                    Torque: 167.7 Nm
                    Duty Cycle: 1.0 %
                    Voltage: 8.66 V
                    Bin. Bits: 00010100
                    Temperature: 36.0°C
008194 - Particulate Trap Bank 1
               P2002 - 001 - Efficiency Below Threshold - Intermittent
                    Fault Status: 00110001
                    Mileage: 149805 km
                    RPM: 2394 /min
                    Torque: 253.5 Nm
                    Speed: 33.6 km/h
                    Temperature: 243.6°C
                    Temperature: 206.5°C
                    (no units): 0.0
                    Temperature: 27.0°C
   Part No SW: 09L 927 760 J    HW: GS1 9.1 1.4
   Component: AG6 09L 3.0lTDI RdW 2204
   Revision: 00000001    Serial number:        4052443
   Coding: 0000001
   VCID: BE797A94EAF323CEE4-515E
Address 03: ABS Brakes        Labels: 3D0-614-517.lbl
   Part No: 3D0 614 517 AK
   Component: ESP 5.7 allrad  H33 0047
   Coding: 0008356
   Shop #: WSC 01065 000 00000
   VCID: EBDF83C0C901666613-5140
   Part No SW: 3D0 909 135 S    HW: 5WK 470 21
   Component:    Kessy            6700
   Revision: 67005514    Serial number: VWZ3Z0E1371050
   Coding: 0004328
   VCID: B56B65B8DFC5E09635-5140
Address 06: Seat Mem. Pass        Labels: 3D0-959-759.lbl
   Part No: 3D0 959 759 CA
   Component: Sitzmemory D1 BF    1722
   Coding: 0000001
   VCID: F7F7AFB08549D286E7-5140
Address 07: Control Head        Labels: 3D0-035-00x-07.lbl
   Part No: 3D0 035 007 P
   Component:    ZAB COCKPIT      0223
   Coding: 0400705
   VCID: A649B2F412639B0E8C-5140
Address 08: Auto HVAC        Labels: 3D0-907-040.lbl
   Part No: 3D0 907 040 J
   Component: Climatronic D1      2031
   Coding: 0000001
   Shop #: WSC 63005 001 1048576
   VCID: A54BB5F86F65901685-5140
Address 09: Cent. Elect.        Labels: 3D0-937-049-V1.clb
   Part No: 3D0 937 049 H
   Component: STG.Bordnetz        5101
   Coding: 0000003
   VCID: AF6757D03D99DA467F-5140
            000 -  -
Address 13: Auto Dist. Reg        Labels: 3D0-907-567.lbl
   Part No: 3D0 907 567 H
   Component: AC101 V6D 6HP194 09 0338
   Coding: 0001441
   Shop #: WSC 00864 210 86384
   VCID: B16351A82BADCCB669-5140
01312 - Powertrain Data Bus
   Part No: 3D0 909 601 E
   Component: 0J Airbag 8.4E+ H10 0935
   Coding: 0012362
   VCID: A54BB5F86F65901685-515E
Address 16: Steering wheel        Labels: 3D0-953-549.lbl
   Part No: 3D0 953 549 E
   Coding: 0000222
Address 17: Instruments        Labels: 3D0-920-xxx-17.lbl
   Part No: 3D0 920 982 A
   Component: KOMBIINSTRUMENT RB8 0521
   Coding: 0007411
Address 18: Aux. Heat        Labels: None
   Part No: 3D0 815 005 AG
   Component: Standheizung        2426
   Shop #: WSC 00864 210 72397
   VCID: E2C1EEE43ECB272EA0-5140
   Part No: 6N0 909 901
   Coding: 0000006
   VCID: F0E594ACE02785BE26-5140
Address 23: Brake Booster        Labels: None
   Part No: 3D0 907 563 C
   Component: BREMSBOOSTER        4310
   VCID: A855BCCC18778D7EBE-5140
Address 29: Left Light        Labels: 3D0-909-157.lbl
   Part No: 3D0 909 157
   Component: EVG GDL+AutoLWR(l)  0001
   Coding: 0000001
   Shop #: WSC 00864 210 91883
   VCID: E6C9F2F4D2E35B0E4C-5122
Address 34: Level Control        Labels: 3D0-907-553-V2.clb
   Part No: 3D0 907 553 C
   Component: LUFTFDR.-CDC- 3C3V0 1122
   Coding: 0005521
   Shop #: WSC 00864 210 72120
   VCID: A757BFF015698206B7-5140
Address 36: Seat Mem. Drvr        Labels: 3D0-959-760.lbl
   Part No: 3D0 959 760 C
   Component: Sitzmemory D1 F     1722
   Coding: 0000004
   VCID: AE594AD43A93D34E74-5140
Address 37: Navigation        Labels: 3D0-919-887.lbl
   Part No: 3D0 919 887 E
   Component:    NAVIGATION       0168
   Coding: 0400000
   VCID: B66962B4C2C3EB8E3C-5140
Address 38: Roof Electronics        Labels: 3D0-907-135.lbl
   Part No: 3D0 907 135 B
   Component: Dachmodul           0605
   Coding: 0000055
   VCID: A241AEE47E4B672EE0-5140
00403 - Sunroof Motor (V1)
            000 -  -  - Intermittent
Address 39: Right Light        Labels: 3D0-909-158.lbl
   Part No: 3D0 909 158
   Component: EVG GDL+AutoLWR(r)  0001
   Coding: 0000001
   VCID: E7D7FFF0D5E9420677-5122
Address 46: Central Conv.        Labels: 3D0-959-933.lbl
   Part No: 3D0 959 933 F
   Component:    HSG              0101
   Coding: 0000040
   Shop #: WSC 00864 210 01102
   VCID: B36F5BA0D1B1FEA61B-4B04
   Subsystem 1 - Part No: 3D2 959 701 H
   Component: Tuersteuergeraet FS 0201
   Subsystem 2 - Part No: 3D2 959 702 H
   Component: Tuersteuergeraet BF 0201
   Subsystem 3 - Part No: 3D0 959 703 G
   Component: Tuersteuergeraet HL 0201
   Subsystem 4 - Part No: 3D0 959 704 G
   Component: Tuersteuergeraet HR 0201
   Subsystem 5 - Part No: 3D0 909 610 C
   Component: 3L HDSG             2330
   Subsystem 6 - Part No: 7L0 907 719
   Part No: 3D0 035 466 A
   Component: 12K-AUDIOVERST      0118
   VCID: A045A4EC7047753EF6-5140
Address 65: Tire Pressure        Labels: None
   Part No: 3D0 907 273 G
   Component: Reifendruckueberw.  0026
   Coding: 0310214
   Shop #: WSC 00864 210 86585
   VCID: AA5146C4067BBF6EA8-5140
01478 - Monitoring of Spare Tire Turned Off
            000 -  -
Address 68: Wiper Electr.        Labels: 3Dx-955-1xx-V1.clb
   Part No: 3D2 955 120
   Component: Front Wiper         3000
   VCID: DFC7E7100DB90AC68F-5140
Address 71: Battery Charger        Labels: 3D0-915-181.lbl
   Part No: 3D0 915 181 C
   Component: Batteriemanagement  2700
   VCID: A34FABE061516E26EB-5140
Address 76: Park Assist        Labels: None
   Part No: 3D0 919 283 D
   Component: 01 Einparkhilfe     0907
   VCID: AB5F43C00981A66653-5140
End-------------------------(Elapsed Time: 07:21)--------------------------
DGMotors
C?ID=57532
The old sensor was reading with the engine off.
New sensor reads 0 with engine off (about 15mb on idle and goes upto around 100mb high rpm) but just wanted to reset the adaption (Elsa said it should be adapted but to use guided functions)
With the codes cleared it seems quite happy but just like to make sure things are right.
I have used that page and the ECU accepts the DPF regen code but there not G450 adaption listed on that page.
NEtech
Denmark
C?ID=56995
Seems it is reading correct.
Remove hose before DPF and connect a mityvac or similar, check readings up to 300 mbar.
Check MWB 102.4 value
For calibration procedure I think it should be Adaptation-10, channel 83
Enter 0001 > [Test] > [Save] > Ign OFF 1 min.
