MK6 Wiper motor replaced... now won't even crank, help pls!
Javier2023
Toronto, Canada
C?ID=392876
Hello All, A bit stumped, hoping for some guidance. Thank you so much !
2012 Sportswagen TDI - Little cousin replaced the Wiper motor and now car won't crank.
  • We have checked all relays and fuses, all are fine.
  • Took out battery tray and intake, checked grounds and did continuity on all the cables coming out of the fuse box under the hood.
  • Checked to ensure both plugs to ecu where seated correctly - Currently trying to get the two studs out to get full visibility to connections and cables.
  • error below on Address 09: Cent. Elect. (J519) I took out the BCM part number 5K0 937 086 N opened it up and I don't see any damage at all, cables are as tight as they can go. I did that after reading this thread https://forums.tdiclub.com/index.php?threads/electrical-gremlins-bcm-issue.522875/
  • First thing we did is check battery and even took it to get tested just in case.
Please see VCDS readout
Sunday,27,August,2023,12:54:44:34263
VCDS Version: 23.3.1.0 (x64)  HEX-V2 CB: 0.4631.4
VIN: 3VWPL7AJ1CM68XXXX   License Plate: 0827231254PM
Mileage: 336610km-209159mi   Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 62 72 77
VIN: 3VWPL7AJ1CM68XXXX   Mileage: 336610km-209159miles
   Part No SW: 03L 997 030 E    HW: 03L 907 309 AA
   Component: R4 2.0l TDI G000AG  9983
   Revision: 12H14---    Serial number:
   Coding: 0350078
   Shop #: WSC 41839 002 1048576
   VCID: 303916D3E62B0EFABFB-8064
   VINID: 0E69E070745A05374620004708C45D0AE8
011174 - NOx Emissions Exceeded
               P2BA6 - 000 - SCR Catalyst Malfunction
                    Mileage: 336611 km
                    Date: 2018.01.17
                    Time: 01:10:39
                    Pressure: 955.9 mbar
                    Temperature: 18.0°C
                    Mass Air / Rev.: 1100.0 mg/str
                    Temperature: 18.9°C
001166 - Sensor for Exhaust Flap
               P048E - 000 - Short to Plus
                    Mileage: 336611 km
                    Date: 2018.01.17
                    Time: 01:10:40
                    Voltage: 11.63 V
                    Lambda: 99.4 %
                    Lambda: 0.0 %
                    Bin. Bits: 00000000
                    Voltage: 5.016 V
Readiness: 0 0 0 1 1
Address 02: Auto Trans        Labels: 02E-927-770.clb                   No fault code found.
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb      No fault code found.
Address 08: Auto HVAC (J301)       Labels:| 3C8-907-336.clb              No fault code found.
   Part No SW: 5K0 937 086 N    HW: 5K0 937 086 N
   Component: BCM PQ35 M    021 3068
   Revision: BJ021001
   Coding: 2D380E1A802F3EC4008800C17000054449000086535D0560648020200040
   Shop #: WSC 56997 002 1048576
   VCID: 3FDB45EF2775E182361-806A
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 143
                    Mileage: 336611 km
                    Date: 2018.01.17
                    Time: 01:11:29
                    Voltage: 12.80 V
                    Reset counter: 143
                    Mileage: 336611 km
                    Date: 2018.01.17
                    Time: 01:11:27
                    Voltage: 12.80 V
Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb                       No fault code found.
   Revision: --------    Serial number:  90422LAU000N5 Dataset Number: 5K0953507AH D005
   Coding: 188A140000
   Shop #: WSC 00066 000 00184
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 76B5E0CB484F60CA257-8022
   Component: E221__MFL-TAS  H09 0013
   Serial number: 0064585
   Coding: 820000
147464 - Terminal 15
          B1148 29 [009] - Signal Implausible
                    Reset counter: 143
                    Mileage: 336611 km
                    Date: 2023.08.27
                    Time: 01:13:30
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1           No fault code found.
Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb                No fault code found.
Address 1C: Position Sensing
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb                No fault code found.
Address 2E: Media Player 3
Address 42: Door Elect, Driver (J386)       Labels:| 3C0-959-70X-GEN4.clb         No fault code found.
   Part No: 1K0 909 144 N
   Component: EPS_ZFLS Kl. 70     3301
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 353727C719492BD2ECD-8060
            000 - - - MIL ON
                    Fault Status: 11100000
                    Mileage: 336611 km
                    Date: 2018.01.17
                    Time: 01:13:07
                    Battery Volts: 11.8 V
                        DD
                    Temperature: 21.0°C
                    Count: 2
                    Steering Angle: 0.00°
                    Count: 1
                        SteerAng n.Init
Address 52: Door Elect, Pass. (J387)       Labels:| 3C0-959-70X-GEN4.clb         No fault code found.
Address 56: Radio (J503)                   Labels:. 5M0-035-1xx-56.clb           No fault code found.
Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb                      No fault code found.
End----(Elapsed Time: 01:06, VBatt start/end: 11.8V/11.8V. VIgn 11.7V)-----
NOx Emissions Exceeded P2BA6 - 000 - SCR Catalyst Malfunction
Any chance it has hit the NOx/SCR re-start limit?
Wiring diagram. Meter. Work backwards from the starter to see where it's being prevented..
Yet...
Javier2023
Toronto, Canada
C?ID=392876
Thank you ! Good question about the N0x/SCR restart, I'll go do some research on that, I replaced the back pressure exhaust flap but couldn't get it to readust via vcds , prob 15k ago though
great link to the wiring diagram!
well that 11.8 was after about a good 6 hours checking different things, i'll keep it charging to ensure that is not causing any more issues.
Thanks again for the helpful direction.
Javier2023
Toronto, Canada
C?ID=392876
Found a mont old read out and it had same error, so my assumption is no re-start limit.
P2BA6 - 000 - SCR Catalyst Malfunction - MIL ON
Mileage: 332133 km
Date: 2017.12.28
Time: 15:08:05
Always plugged in the battery now, also swapped it out with another one just in case.
I finally found them else where, definetely starter is not getting any power, manuallly put wire from positive battery to alternator connector plug that aside from the one from the battery and it started.
Javier2023
Toronto, Canada
C?ID=392876
- I see the Angle sensor, my thought though car should still turn on with that error, correct?
- BCM not working , would not allow the car to start ? only thing that jumps at me from latests read out below. thank you for your help and guidance!
Monday,04,September,2023,17:20:25:34263
VIN: 3VWPL7AJ1CMXXXXXX   License Plate: 520
VIN: 3VWPL7AJ1C   Mileage: 336610km-209159miles
   Coding: 0350078
                    Mileage: 336611 km
                    Date: 2018.01.25
                    Time: 14:13:54
                    Pressure: 968.0 mbar
                    Temperature: 18.0°C
                    Temperature: 19.8°C
                    Mileage: 336611 km
                    Date: 2018.01.25
                    Time: 14:13:55
                    Voltage: 12.62 V
                    Lambda: 99.4 %
                    Lambda: 0.0 %
                    Bin. Bits: 00000000
                    Voltage: 5.016 V
006744 - NOx Catalyst
               P1A58 - 000 - Regeneration Required - Intermittent
                    Mileage: 336611 km
                    Temperature: 18.0°C
                    Temperature: 19.8°C
   Component: GSG DSG AG6     512 9430
   Revision: 05551213    Serial number: 00001112300191
   Shop #: WSC 00066 000 00000
   VCID: 1471BA437273D2DABB3-8040
18036 - Powertrain Data Bus
            P1628 - 000 - Missing Message from Steering Angle Sensor - Intermittent
                    Mileage: 336611 km
                    Date: 2018.01.25
                    Time: 01:15:50
   Revision: 00H31001
   Coding: 114B600C492A00FA880C06EB921B0042310000
   VCID: 7DA7FFE76DF9339264D-8028
   Part No SW: 7N0 907 426 AN    HW: 7N0 907 426 AN
   Component: AC Manuell    H19 0304
   Revision: 00001016
   Coding: 0000004002
   Shop #: WSC 00066 000 00120
   VCID: 005986131A8B5E7A0FB-8054
   Revision: BJ021001
                    Reset counter: 143
                    Mileage: 336611 km
                    Date: 2018.01.25
                    Time: 12:47:54
                        Term 15 Off
                    Voltage: 12.80 V
                    Reset counter: 143
                    Mileage: 336611 km
                    Date: 2018.01.25
                    Time: 12:48:53
                        Term 15 Off
                    Voltage: 12.80 V
   Part No SW: 5K0 959 655 H    HW: 5K0 959 655 H
   Component: AirbagVW10G   013 0724
   Serial number: 003GVRA1B2M.   Dataset Number: 1KM003v__B_ 0036
   Coding: 00003134
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3FDB45EF27F5E182361-806A
   Subsystem 1 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3572MSME14247649ZZZU
   Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3582MSME1A617549ZZZ.
   Serial number: 3511HSME380C3D2BZZZX
   Serial number: 3521HSME4672242BZZZK
   Serial number: 35527SME5D6D7729ZZZ
   Serial number: 35627SME09106929ZZZD
   Coding: 188A140000
   Coding: 820000
                    Fault Frequency: 13
                    Reset counter: 143
                    Mileage: 336611 km
                    Date: 2023.09.04
                    Time: 00:33:26
   Part No SW: 5K0 920 872 A    HW: 5K0 920 872 A
   Coding: 370F00
   VCID: 2D070FA7FD99631294D-8078
   Part No SW: 7N0 907 530 M    HW: 1K0 907 951
   Component: J533  Gateway H42 1623
   Revision:   H42       Serial number: 08031201270248
   Coding: 352002
   VCID: 3A2D34FB3C57C4AA01F-806E
   VCID: 6A8DC4BB0CF7B42AB1F-803E
   Component: TUER-SG FT    002 0501
   Revision: 13110009    Serial number: 0004133152
   Coding: 0004B5
   Shop #: WSC 01383 790 50316
   VCID: 5BE3917FD3ADDDA23A9-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703 C    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  007 1509
   Serial number: 00000006422858
   Coding: 000490
67589 - Turn Signal in Exterior Mirror
          B11FD 01 [009] - Electrical Failure
                    Reset counter: 143
                    Mileage: 336611 km
                    Date: 2023.09.04
                    Time: 00:54:06
   Revision: 00H22000
            000 - - - MIL ON
                    Mileage: 336611 km
                    Date: 2018.01.25
                    Time: 00:37:12
                    Battery Volts: 12.4 V
                        DD
                    Temperature: 25.0°C
                    Count: 2
                    Count: 1
                        SteerAng n.Init
            004 - No Signal/Communication - Intermittent - MIL ON
                    Fault Status: 10100100
                    Reset counter: 183
                    Mileage: 336611 km
                    Date: 2018.01.25
                    Time: 01:15:54
                    Battery Volts: 12.3 V
                        DD
                    Temperature: 28.0°C
                    Count: 2
                    Count: 1
                        SteerAng n.Init
   Component: TUER-SG BT    002 0501
   Revision: 15110009    Serial number: 0004216335
   Coding: 0004B4
   VCID: 5CE19263D6A3DA9A333-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704 C    HW: 3C0 959 794 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  007 1509
   Serial number: 00000006338721
   Coding: 000490
                    Reset counter: 143
                    Mileage: 336611 km
                    Date: 2023.09.04
                    Time: 00:30:29
   Part No SW: 1K0 035 180 AE    HW: 1K0 035 180 AE
   Component: Radio Prem-8  H02 0016
   Revision: -----16S    Serial number: VWZ4Z7M3263783
   Coding: 21000400040007
   VCID: 6393A99FEB5DE562729-8036
   Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
   Component: TELEFON       H12 2902
   Revision: 1B001001    Serial number: 00007661721922 Dataset Number: 5K0035730E  0001
   Coding: 0A10040000010100
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 270BFD8FDF6549426E1-8072
End----------(Elapsed Time: 01:07, VBatt start/end: 12.2V/12.2V)-----------
Javier2023
Toronto, Canada
C?ID=392876
used body control module from a 2014 did the job, recoded it with old module parameters. i'll have to see why keys are not locking or unlocking but now we have a working car. thanks again for all your support! much appreciate it.
Next is to deal with those pesky emission codes.
