Audi A5 - Retrofiting ACC triggers strange errorcode 00526 008 from trailer ECU J345
Michel
Denmark
C?ID=31176
Audi A5 - Retrofitting ACC triggers strange errorcode 00526 008 from trailer ECU J345
Hi All,
Ive just finished retrofitting ACC (installed new J428 and upgraded J527 and J285) on my Audi A5 2013 succesfully, but just after i now receive errorcode 00526 008 from trailer ECU J345, indicating that my brake switch is periodically defect (I can clear the DTC but it returns if i use the ACC ) ? I think i have verified the trailer coding on all modules but im not sure if anything in terms of ACC is to be coded for the trailer module itself as i have not been able to find any detailed documentation ?
Hopefully somebody can help me out ?
Below is my latest VCDS scan:
Sunday,23,August,2015,17:49:31:21781
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VMWare)
VCDS Version 15.7.0.1 (x64)
Data version: 20150729
Dealer/Shop Name: Audi A5 XXXXXXX
VIN: WAUZZZ8F9DN011417   License Plate:
Mileage: 18220km-11321mi   Repair Order:
Chassis Type: 8F (8R0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 20 26 3C 42 44 46 47 52 53
          56 5F 62 69 72
VIN: WAUZZZ8F9DN011417   Mileage: 18220km-11321miles
Address 01: Engine (J623-CJEB)       Labels: 06L-906-264-CJE.clb
   Part No SW: 8K0 906 264     HW: 8K0 906 264
   Component: 1.8l R4 TFSI  H07 0007
   Revision: --H07---
   Coding: 22190012245401022000
   Shop #: WSC 45328 000 104857
   ASAM Dataset: EV_ECM18TFS0218K0906264 002006
   ROD: EV_ECM18TFS0218K0906264.rod
   VCID: 6EEBDA06B1C2104EB4-803B
Readiness: 1110 0001
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V1.clb
   Part No SW: 8K0 907 379 CH    HW: 8K0 907 379 CH
   Component: ESP8 front    H09 0100
   Coding: 03DD4C
   Shop #: WSC 45328 123 104857
   VCID: 013191BA985C1F3659-8055
   Part No SW: 8K0 907 064 GD    HW: 8K0 907 064 FD
   Component: BCM2 2.0      H12 0633
   Coding: 03A34000000000000000
   Shop #: WSC 02391 785 00200
   VCID: 78C7FC5ECB865EFE6E-802D
   Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
   Part No SW: 8K1 820 043 R    HW: 8K1 820 043 R
   Component: KLIMA 1 ZONE  H02 0121
   Revision: A1000000    Serial number: 01020220130237
   Coding: 642302C000
   VCID: 37453F6286189186A7-8063
   Part No SW: 8K0 907 063 DF    HW: 8K0 907 063 DF
   Revision: 06016001    Serial number: 00000042302801
   Coding: 2600C0108074AFC00081400300001D0D431C238826090201000004000400020100000040000000
   VCID: 76DBF266C192288E7C-8023
   Subsystem 1 - Part No SW: 8F1 955 119     HW: 8K1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 280113  H07 0080
   Coding: 00FD11
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Subsystem 4 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H03 0002
Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
   Part No SW: 8K0 919 475 AA    HW: 8P0 919 475 N
   Component: PARKHILFE 8K  H01 0081
   Revision: 11001001    Serial number: 12531400800438
   Coding: 110002
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 8K0 907 561 B    HW: 8K0 907 561 B
   Component: ACC3          H09 0100
   Coding: 008189
   Shop #: WSC 06325 123 12345
   VCID: 3151017A687C4FB6E9-8065
Address 15: Airbags (J234)       Labels: 8F0-959-655.clb
   Part No SW: 8F0 959 655 D    HW: 8F0 959 655 D
   Component: AirbagVW-AU10 H12 0430
   Serial number: 003KGD80D1VJ
   Coding: 30394135353130303030554A304C38463053
   ASAM Dataset: EV_AirbaAU10SMEAU485 001004
   ROD: EV_AirbaAU10SMEAU485.rod
   VCID: 3941395AB80C87F651-806D
   Serial number: 6334MSME7765042DH
   Serial number: 6344MSME7775550FP
   Serial number: 6352QSME69291674L
   Serial number: 6362QSME47291962I
   Serial number: 63732SME6D294B528
   Serial number: 63832SME6B290C401
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Revision: --------    Serial number: 90372MHG000CC
   Coding: 0000DE
   VCID: 44BF58AEC7CECA1E32-8011
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8T0 920 930 H    HW: 8T0 920 930 H
   Component: KOMBIINSTR.   H09 0551
   Revision: 00000000    Serial number: GDE35J6AA
   Coding: 0FF7180007010008010101
   Shop #: WSC 00017 780 00200
   VCID: 3B4D2352BA30B5E643-806F
   Part No SW: 8R0 907 468 P    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0055
   Revision: 1Z100027    Serial number: 2741Z1312780DE
   Coding: 80CF00FF00
   VCID: 4CAF708EEF9E025EFA-8019
Address 20: High Beam Assist. (J844)       Labels: 8K0-857-511.clb
   Part No SW: 8T0 857 511 AD    HW: 8T0 857 511 AD
   Component: FLA           H04 0012
   Revision: AA001002
   Coding: 02018A64747464545425363E00
   VCID: 7CCFE04EFFBE72DE0A-8029
Address 26: Auto Roof        Labels: None
   ASAM Dataset: EV_ Unknown
   ROD: N/A
   VCID: 559995EA3454439655-8001
No ASAM data for: "EV_" (AU48)
   Part No SW: 8K0 907 566 F    HW: 4L0 907 566 B
   Component: J0769_SWA_MasterH01 0010
   Revision: 00H01000    Serial number: 6PZ 009 014-13
   Coding: 0010105
   Shop #: WSC 00000 785 00200
   VCID: 3A432656750A8CEE58-806F
   Subsystem 1 - Part No: 8K0 907 568 F
   Component: J0770_SWA_Slave_H01 0010
   Subsystem 2 - Serial number: 6PZ 009 014-33
   Subsystem 3 - Serial number: 5F16.08.0800H010003CD10130ÿ
   Subsystem 4 - Serial number: D10130ÿ
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H09 0304
   Coding: 011D42725008330C03
   VCID: 569B92E62152488E5C-8003
Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
   Component: RCEPS         H37 0507
   Revision: 00001000    Serial number: 0021207452
   Coding: 100000000001
   ROD: EV_RCEPSAU48X.rod
   VCID: 345F086E9F6E7A9E82-8061
   Revision: 00002001    Serial number: 0300455090
   Coding: 010006A000B900E08130033680000000
   Part No SW: 8F1 035 223 A    HW: 8F1 035 223 A
   Revision: 00005001    Serial number: 94833010375701
   VCID: 1F75F7C20EE8C9C64F-804B
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H09 0304
   Coding: 011D40325008330C03
   VCID: 559995EA3C54439655-8001
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 10000000165545
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 38473C5E83069EFEAE-806D
   Part No SW: 4G1 035 053 F    HW: 4G1 035 053
   Component: Radio U Basic H41 0122
   Revision: AB001007    Serial number: 226A-0D7705782
   Coding: 010003010000000101
   VCID: 2273FE363D9AE42E60-8077
   Part No SW: 8R1 035 670 E    HW: 8R1 035 670 C
   Component: H-BNT-EU      H44 0793
   Revision: --------    Serial number: 207G-0C7507049
   Coding: 130100030106E9ED3100A95E00000401040000000000000000
   VCID: 3559356A9C146396B5-8061
   Subsystem 1 - Part No: 8R0 060 884 BK
   Component: EUR 2014  1703
   Subsystem 2 - Part No SW: 8R0 919 604     HW: 8R0 919 604
   Component: DU7 High  H41 0104
   Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
   Subsystem 4 - Part No: 8R0 060 961 C
   Component: CD-Database  3638
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Part No SW: 8T0 959 795 F    HW: 8T0 959 795 F
   Component: TSG HL        H08 0304
   Coding: 010000300008370C03
   VCID: 4EAB7A861982304E94-801B
Address 69: Trailer (J345)       Labels: 8K0-907-383.clb
   Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
   Revision: 1A001001    Serial number: 00000189413987
   Coding: 0100000000000000
   VCID: 365B32668112688EBC-8063
                    Fault Frequency: 20
                    Reset counter: 211
                    Mileage: 17713 km
                    Date: 2015.08.19
                    Time: 20:15:25
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-794.clb
   Component: TSG HR        H08 0304
End-------------------------(Elapsed Time: 02:53)--------------------------
delboy
C?ID=192457
When I carried out an ACC retrofit recently on my S8 I too had an error for towing module that would not go away until the correct cluster was fitted and coded, then adapted have you adapted it to suit?
I may be barking up the wrong tree though as my install didn't have a trailer module, so it was strange that I would get a fault for it.
Michel
Denmark
C?ID=31176
Hi Delboy, Thank you for the reply. As written i added the radar (J428) and upgraded the steering wheel and instrument cluster (J527 and J285) to versions supporting the ACC. I have also coded all my modules for trailer but as ive posted, i can not code the trailer for ACC (maybe due to insufficient doc - i can however see that the meassurement blocks for the trailer module seem to have values for ACC but states its "not occupied" so maybe a cord/wire is missing ?) The ACC however runs without error in all matters (except for the trailer DTC) though i seem to have the same challange as you (read your posting), in regards to adjustment (moving target after driving between -0.8 ..+0.8). In this matter i seem to have a static vertical value 2 (adjusting the radar vertical and horisontal physically, only affects the horisontal value 1 in the meassurement valueblock 002 ). Do you also experience that in terms of adjustment ? Br. Michel
delboy
C?ID=192457
Yes in all the readings I have taken from the radar control unit the Vertical maladjustment never changes, only the readings for horizontal, steering angle, and lateral yaw change with each drive cycle.
I have noticed however that on drives with twisty roads the values are far from the 0.5 stated in ELSA, on journeys mostly of motorway etc the values are better, for the most part mine behaves ok but i think that the beam is still slightly to the right side.
I intend to make a mirror plate to fit over the radar so i can adjust the radar unit using a laser level that you can buy from diy store.
Here is a screenshot of my latest readings with the label file I made for the radar control unit.
Michel
Denmark
C?ID=31176
Hi del, Your plan sounds as a good idea. Could you provide some more details on how you expect to do it, as id like to try it to (read about a DIY but i have only been able to find the desc of the radar valueblocks and DIYs using WAS testers) ?
By the way, wathch out for your current value. When i adjusted my radar it ended at somepoint above 0.9 and then it locked up with the misadjustment DTC code and another DTC code saying it was defect. At that point the misadjustment DTC it could only be cleared when it was adjusted to be below 0.8. The defect code only disappered when i disconnected/connected the battery (i was close to buying a new radar unit as the defect DTC appeared permanent ).
delboy
C?ID=192457
You can see all the steps I took here in this thread, I can't say for sure if your radar has the same measuring blocks as the one in my car but doing a comparison of the various screens you may be able to determine what your blocks are too, if they are the same you can apply the label file thats in that thread, but beware that its not complete as far as adaptations etc and the coding info relates to A8 D3 not your car.
You can comment out the coding section of the file so its not presented to you in VCDS.
As for your trailer fault have you checked that the trailer wiring socket is not got any issues?
Michel
Denmark
C?ID=31176
What a great and impressive DYI work you have done. Your posting on http://forum.a8parts.co.uk/showthread.php?t=10419 will help out a lot of people. I wish i had read it before i started doing mine - it would have saved me a lot of time i think. The work i've done however seems very simular on the A5 except for partnumbers and ECU locations of course.
As soon as i have some spare time i will dig deeper into the adjustment you have described and see if i missed something important.
However, my question to you was regarding the mirror and laser you described, but looking at your radar picture it seems as the A8 radar does not have a mirror mounted permanent like mine ? If so, thats is what confused me as i thought you would use a laser having 2 mirrors (I plan to setup a fixed laser approximately 500m in front of my car and then let it hit my permanent mounted radar mirror and adjust untill the laser allmost hits itself - i guess that what you also planned ?).
Regarding my trailer problem - My trailer ECU works perfect using trailer physically (factory mounted and coded - i only had to apply coding to the radar and the parts i have upgraded/replaced) and the DTC i get only arise when i use ACC and use the breaks at some point. I have checked the diagrams for other models and they all indicate that the communication between the trailer ECU and other ECUs communicate via the CAN bus so missing wires should not be an issue. I therefore suspect that the trailer ECU needs some coding but i hav not been able to find any docs besides coding the trailertype (manuel/electric). I therefore made my posting hoping that somebody knows what all the bits are for - seems as only 0100000000000000 and 0200000000000000 is documented from what i can find.
nipro
Poland
C?ID=286249 (NRRT)
Hi Michel,
replying to this old thread and hope you resolved it in the meantime. I have a European VW Sharan originally equipped with ACC and a trailer, but receiving same error. The brake light switch and its plug was already replaced by the dealer, but the error still happens occasionally. It is less than before, but still exists. Any help from you is much appreciated. The dealer is running out of ideas what might be causing it.
Thanks, Nipro
