no rod values
rob64
South Africa
C?ID=226009
i have got a 2011 6r polo with the air bag light on vcds has no rod value for the airbag and will nit give fault codes or deleat code. needc your help.
I have saved the autoscan but not sure how to post it
rob64
South Africa
C?ID=226009
here is the auto scan
VCDS Version Release 15.7.0 (x64) Running on Windows Vista x64(VMWare)
Data version: 20150729
randj motors
Tuesday,25,August,2015,13:17:45:36767
Chassis Type: 60 (6N0)
Scan: 01 03 09 15 17 19 25 44 56
VIN: WVWZZZ60ZBT040980   Mileage: 146710km-91161miles
Address 01: Engine (J623-CLNA)       Labels: 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 CR    HW: 03L 906 023 D
   Component: 1,6l R4 CR td H13 9970
   Revision: --H13---    Serial number:
   Coding: 00110012032500080000
   Shop #: WSC 00793 648 00255
   ASAM Dataset: EV_ECM16TDI02103L906023CR 003016
   ROD: EV_ECM16TDI02103L906023CR.rod
   VCID: 78F90A48C35CD4FE6E-802D
9867 - Coolant Pump 2
          P261A 00 [237] - Open circuit
                    Mileage: 146715 km
                    Date: 2015.08.25
                    Time: 11:25:36
9870 - Coolant pump 2
          P261B 00 [101] - Implausible signal
                    Mileage: 146715 km
                    Date: 2015.08.25
                    Time: 11:30:31
   Part No SW: 6RF 907 379 B    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 63024CC1417104B2C62E32EA82D120821000
   Shop #: WSC 02069 000 00000
   VCID: 53A39DE4367AD7A6BB-8007
Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
   Part No SW: 6R0 937 087 F    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H46 0221
   Revision: BF046001    Serial number: 0345 242100730
   Coding: 22904ABF08E12400923800003C0B04900080414F60040000200000000000
   Shop #: WSC 124697 483 00190
   VCID: 4089A2A8D30C5C3E16-8015
   Subsystem 1 - Part No SW: 6R0 959 802 D    HW: 6R0 959 802 D  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  002 3420
   Subsystem 2 - Part No SW: 6R0 959 801 F    HW: 6R0 959 801 F  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  002 3420
   Subsystem 3 - Part No: 1K8 951 171 A
   Component: DWA-Sensor 00  001 0103
   Component: LIN BACKUP HO  H11 9004
   Subsystem 5 - Part No: 1K8 951 171 A
   Subsystem 6 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A
   Component: E221__MFL-TAS  H07 0013
   Coding: 020000
   Subsystem 7 - Part No SW: 6R0 959 811 E    HW: 6R0 959 811 E
   Component: J388__TSG_HL  002 3420
   Coding: 020000
   Subsystem 8 - Part No SW: 6R0 959 812 E    HW: 6R0 959 812 E
   Component: J389__TSG_HR  002 3420
   Coding: 020000
00975 - Heated Rear Window (Z1)
                    Reset counter: 128
                    Mileage: 146715 km
                    Date: 2015.08.25
                    Time: 11:30:10
   Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
   Component: VW10AirbagU04 H09 0020
   Revision: --------    Serial number: 003GX00G0DHC
   Coding: 003034
   Shop #: WSC 01383 785 00200
   ROD: N/A
   VCID: 4A9D8080ED30966EC8-801F
   Subsystem 1 - Serial number: 3495RRB404T08IEI9HD5
   Subsystem 2 - Serial number: 3505RRB404V08IEIN8H8
No ASAM data for: "EV_AirbaVW10BPAVW250" (VW26)
9440017 - ROD - Unknown Error Code
          - 00 [137]
                    Mileage: 146715 km
                    Date: 2015.08.25
                    Time: 11:30:31
   Part No SW: 6R0 920 861 F    HW: 6R0 920 861 F
   Component: KOMBI         H04 0304
   Coding: 140A00
   VCID: 3879CA4883DC14FEAE-806D
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 0221
   Coding: 002300
   VCID: 70E93268A32C8CBEA6-8025
   Component: IMMO          H04 0304
   VCID: 6ADD20008DF0766EE8-803F
Address 44: Steering Assist (J792)       Labels: 6Rx-909-144-V1.clb
   Part No SW: 6RF 909 144 H    HW: 6RF 909 144 G
   Component: EPS_ECU       H25 0321
   Coding: 0000
   ASAM Dataset: EV_SteerAssisUDSNSK 004004
   ROD: EV_SteerAssisUDSNSK.rod
   VCID: 51AF97EC0066A5B689-8005
   Part No SW: 5M0 035 156 C    HW: 5M0 035 156 C
   Component: Radio         510 0521
   Revision: R0510001    Serial number: VWZ5Z1K0432812
   Coding: 0500040001
   VCID: 295F1F0C4076BD7621-807D
End-------------------------(Elapsed Time: 02:07)--------------------------
Sebastian
Magdeburg, Germany
HN0-nnnnnn
rob64, please see my earlier reply - you haven't updated yet. Please do so and post a fresh scan with that updated version.
Keithuk, different/unrelated problem. ;)
