USB-C retrofit A4 B9 8W0035708A - U11B8 00 [009] No Communications
gramsca
Phoenix, AZ, USA
C?ID=492771
Hello all,
Switched out 8W0035708 with 8W0035708A (USB-A+AUX to USB-C) in the center console armrest in an A4 B9 with CarPlay functionality installed from factory.
Repinned power wires to the new 6-pin connector of the new -708A interface.
Plugged in the green and purple data connectors too, these were plug-and-play.
New interface illuminates and charges as expected.
However, CarPlay/Audi smartphone interface now does not work. Doesn't work with the new unit or even the other USB-A connection at the front of the console.
When switched back to the old unit - CarPlay works again.
Getting fault code U11B8 00 [009] No Communications [USB - communication error].
Any ideas? Thinking it could be a coding/adaptation/parameterization issue. Or possibly the new module isn't compatible with MIB2+, since it's factory installed in MIB3 cars.
Thanks in advance!
Chassis Type: F4-AU49 (8W6)
Scan: 01 02 03 08 09 15 16 17 19 29 36 39 3C 42 44 46 47 52 5F 6C
          81 A5 BB BC CA CF D6 D7
VIN: WAUENAF40JA110725   Mileage: 154172km-95798miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CYMC)       Labels:. 06K-907-425-V2.clb
   Part No SW: 8W0 906 259 J    HW: 06L 907 425 C
   Component: 2.0l R4 TFSI  H15 0002
   Revision: --H15---    CVN: 94407C3A
Coding: 0A2500322326010E34280000000000000000000000000000
   Shop #: WSC 06314 790 00001
   ASAM Dataset: EV_ECM20TFS0208W0906259J 001003
   ROD: EV_ECM20TFS0208W0906259J.rod
   VCID: 48C94A8BD231A12A87B-801C
VINID: 9D195579158401A4410401C214C8F3D22F
Readiness: 0000 0100
   Part No SW: 8W2 927 155 BA    HW: 0CJ 927 156
   Component: 0CL 20TFSINAR H05 0001
   Revision: --H05---    Serial number: 0000001481 CVN: F66A77DF
   ASAM Dataset: EV_TCMDL382021 002027
   ROD: EV_TCMDL382021_AU49.rod
   VCID: 015F97AFB18B5062005-8054
   MTF pump:
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 L
   Component: V553 MTFP  003 0576
   Serial number: 75145041170326000562
Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PLU-V1.clb
   Part No SW: 8W0 907 379 K    HW: 8W0 907 379 J
   Component: ESP9 Plus     H10 0766
   Dataset Number: 8W0909504M  0007 CVN: 18E61C2C
Coding: 18AA409928A30A9611A5489300825292E425DA180214508812004A4927A45B
   Shop #: WSC 17023 005 104857
   ROD: EV_ESP9BOSCHCMP_004_AU49.rod
   VCID: 4DC77B9F3D534402B4D-8018
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 8W0 820 043 T    HW: 8W0 820 043 T
   Component: Klima Zone 3  H55 0210
Coding: 140805095544000D10000100880100000000000000000000000000000000
   Shop #: WSC 06335 790 00001
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 44D15EBBEE19854A6B3-8010
   Subsystem 1 - Part No SW: 4M1 820 021 B    HW: 4M1 820 021 B
   Component: J126 FLuftV  H09 0003
   Serial number: 00000000000001964774
   Humidity sensor: exterior:
   Serial number: 1A719DD800PAG0MUFU02
525056 - Control/Display Unit for Rear Climatronic
          B10AA 31 [009] - No Signal
                    Reset counter: 243
                    Mileage: 153796 km
                    Date: 2023.08.10
                    Time: 16:14:49
                    Voltage terminal 30: 14.06 V
459521 - Databus
                    Reset counter: 34
                    Mileage: 154092 km
                    Date: 2023.08.16
                    Time: 18:55:10
Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
   Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0267
   Dataset Number: 8W0909514L  0048
Coding: 07001B63E0690CCD05158715182C18FB110B3D08000000400000000020001A010A690122025705
   VCID: 025D98A3B48D4B7A19F-8056
   Subsystem 1 - Part No SW: 8W1 955 119     HW: 8V1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS491 171111  043 0813
   Serial number: 89435300301731504078
   Coding: 5BC7F7
   Serial number: 20913775X81A955555A0
   Coding: 02005D
   Subsystem 3 - Part No SW: 4M0 941 531 AK    HW: 4M0 941 531 AK
   Component: E1 - LDS  H06 0008
   Serial number: 09 09 2017  01129197
   Subsystem 4 - Part No SW: 4N0 907 410 A    HW: 4M0 907 410 A
   Component: USHL5  H10 0100
   Serial number: 0000009600350Z012W02
   Coding: 350000
   Garage door opener control head:
   Subsystem 5 - Part No SW: 4M0 959 719 A    HW: 4M0 959 719 A
   Component: GTO BF  H01 0010
   Serial number: 20171122092705 00785
   Subsystem 6 - Part No SW: 8W0 857 511 B    HW: 8W0 857 511 B
   Component: Y7_Innenspieg  H01 0002
   Serial number: GX1CE115091723611364
   Interior Light Module:
   Subsystem 7 - Part No SW: 8W0 947 135 CJ    HW: 8W0 947 135
   Component: J528-Dachele  H14 0130
   Serial number: B00595723
   Subsystem 8 - Part No SW: 8W0 925 301 BC    HW: 8W0 925 301 BC
   Component: SL-B9/Q5NF  H17 0010
   Serial number: 2617000185816001
Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
   Part No SW: 8W0 959 655 G    HW: 8W0 959 655 G
   Component: Airbag10.44   H05 0107
   Serial number: 003UQ0021ZKV Dataset Number: 8W0909602AH 0007
Coding: BFCCF0C000800000A0000033D24C00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 006016
   ROD: EV_AirbaAU10BPAAU736_006.rod
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 4M0 980 945 B    HW: 4M0 980 945 B
   Component: BeltPretRevFL  306 2033
   Serial number: 8W0857705G0332R02251
   Coding: 80000D
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 4M0 980 946 B    HW: 4M0 980 946 B
   Component: BeltPretRevFR  306 2033
   Serial number: 8W0857706J0332R01512
   Coding: 80000D
   Component: BF-Gewichtss.  H11 0022
   Serial number: IBH0000J170008FLXS06
   Subsystem 4 - Part No SW: -----------    HW: 442 061 611 17
   Serial number: 3577Y009B2716BC503C6
   Subsystem 5 - Part No SW: -----------    HW: 442 061 611 17
   Serial number: 3587Y00B928A7A70A2DH
   Subsystem 6 - Part No SW: -----------    HW: 442 0B0 111 17
   Serial number: 3517700A1287DB81D21E
   Subsystem 7 - Part No SW: -----------    HW: 442 0B0 111 17
   Serial number: 3527700B928929A1F16L
   Subsystem 8 - Part No SW: -----------    HW: 442 0C1 807 17
   Serial number: 3557500C9277781170EE
   Subsystem 9 - Part No SW: -----------    HW: 442 0C1 807 17
   Serial number: 3567500C9277781421BB
   Part No SW: 4M0 907 129 GB    HW: 4M0 907 129 GB
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 76B5F473E84567DA257-8022
   Part No SW: 8W5 920 890 D    HW: 8W5 920 890 D
   Component: FBenUSA       H18 0379
Coding: 01EF61C12888CF050223EF601800001008000000
   Part No SW: 8W6 907 468 F    HW: 8W6 907 468 E
   Component: Gateway       H42 0123
   Revision: 7B000001    Serial number: 0187B759317B21 Dataset Number: 8W0909515J  0063
Coding: 030100010000064029070000005900124C180007100000000150000000000000
   Shop #: WSC 17031 005 1048576
GVL: 01503C000000000040DC08000002C800100C0000000000000000000000000000
   ASAM Dataset: EV_CGateCONTIAU491 003111
   Subsystem 1 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0002
   Serial number: 20171024053819 20721
   Serial number: 6509156004
   Part No SW: 4M0 907 397 AC    HW: 4M0 907 397 C
   Component: LCM_MLBevoH05 0024
   Dataset Number: 8W0909519B  0010
   VCID: 78A9FA4BE25111AA37B-802C
   Component: MEM-FS        009 0042
   Serial number: 00000291347286 Dataset Number: 8W0909856C  0009
Coding: 005C1B000000B0010000010101010000000000000000000000000000000000
   Shop #: WSC 06325 790 00001
   VCID: 79AFFF4FD95B08A2485-802C
   Dataset Number: 8W0909520B  0010
   Part No SW: 4M0 907 566 D    HW: 4M0 907 566
   Component: MRR1Rear      H18 0410
   Revision: --------    Dataset Number: 8W0909535C  0020
   Coding: 0E8002
   Shop #: WSC 06324 790 00001
   ASAM Dataset: EV_RearRadarS1BoschAU736 001022
   VCID: 36353473A8C527DAE57-8062
   Part No SW: 4M0 959 793 H    HW: 4M0 959 793 F
   Component: TSG FS        005 0125
   Serial number: 0000290191001  Dataset Number: 8W0909872E  0029
   Coding: 005F1B205E001080000100B2
   VCID: 43D35DA7EB178272529-8016
   Part No SW: 8W0 909 144 H    HW: 8W0 909 144 B
   Component: EPS_MLBEVO_ZF H08 0410
   Dataset Number: 8W0909852Q  0039
   Coding: 09000380008000
   ASAM Dataset: EV_EPSZFAU49X 003023
   ROD: EV_EPSZFAU49X_003.rod
   VCID: 42DD58A3F40D8B7A59F-8016
   Part No SW: 8W0 907 064 EC    HW: 8W0 907 064 DC
   Component: BCM2 MLBevo   025 0387
   Dataset Number: 8W0909501J  0052
Coding: 013400004F300080658F80002E01000033024000810022502F0400000B04803F001E0001000000
   ASAM Dataset: EV_BCM2HellaAU736 014014
   ROD: EV_BCM2HellaAU736_014_AU49.rod
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY173002LPW
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000099974334
   Subsystem 3 - Part No SW: 3AA 962 243 H    HW: 3AA 962 243 H
   Component: GEB.F.Heckoef  H16 0905
   Serial number: >1187515
65896 - Databus
          [Climatronic control module: Klima_03: no signal/communication]
                    Fault Frequency: 34
                    Reset counter: 36
                    Mileage: 154107 km
                    Date: 2023.08.17
                    Time: 17:29:44
                    Supply voltages-Terminal 30 power supply: 12.093 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.106 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.093 V
general_additional_freeze_frame-terminal_control_intern_status: 40 04 0A 12 04 98
   Part No SW: 8W0 035 465     HW: 8W0 035 465
   Component: MIB2_amp_P_B9 H11 0420
   Revision: 00000001    Serial number: AUZ8ZAHJA0357V5 Dataset Number: 8W0909510D  0015
   Coding: 0194010800AFAAAFAA0000010000
   ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
   ROD: EV_AMPMst16C2Gen2ALPI.rod
   Part No SW: 4M0 959 792 H    HW: 4M0 959 792 F
   Component: TSG BFS       005 0129
   Serial number: 0000290937282  Dataset Number: 8W0909873E  0029
   Coding: 005F1B205E001080000100B0
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
   Part No SW: 8W5 035 880 B    HW: 8W5 035 880
   Component: MU-P-LNS-US   034 1178
   Serial number: A798K0HB075674 Dataset Number: 8W0909545AB 0042
Coding: 019401020000000003220002041A00102F0002E501700904FE
   VCID: 3E252C5380F5EF9A3D7-806A
   Subsystem 1 - Part No SW: V03 959 801 GH    HW: -----------
   Component: NAR 2017/2018  --- 0060
   Multimedia System 1:
   Subsystem 2 - Part No SW: 8W0 919 605     HW: 8W0 919 605
   Component: AU49x_DU_HIGH  H40 0008
   Serial number: AUZ8Z9HBJ049J5
   Subsystem 3 - Part No SW: 8W0 919 614 T    HW: 8W0 919 614 T
   Component: ControlUnit_H  H30 0206
   Serial number: APVAK112071800020449
   Compact disc data bank:
   Component: Gracenote2  --- 3012
1637 - Interface for External Media
          U11B8 00 [009] - No Communications
                    Reset counter: 251
                    Mileage: 154172 km
                    Date: 2023.08.19
                    Time: 16:21:01
                    Voltage terminal 30: 13.2 V
                    Interface for external media: status-Status: Open circuit
   Component: RVC Compact   H12 0250
   Dataset Number: 8W0909460B  0010
   Coding: 0294010102002001400040
ROD: EV_CamSysRVRVCPANAMLBEv_005_AU49.rod
   VCID: 33330D67BBB732F2C29-8066
   Part No SW: 8W1 713 041 G    HW: 8W1 713 041 J
   Component: GSM-LL        H09 0077
   Revision: 0L0D5012    Serial number: 18022446167096
   ROD: EV_GSMWaehlZFAU736_AU49.rod
   VCID: 372B3977AFCFDED2FE1-8062
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 8W0 907 217 E    HW: 8W0 907 217 C
   Component: BVS           H18 0055
   Dataset Number: 8W0909466F  0039
Coding: 0404090100000201022023A2A50000FC00F0C020C020
   Shop #: WSC 16412 005 104857
   ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
   Part No SW: 4M0 959 795 H    HW: 4M0 959 795 F
   Component: TSG HFS       005 0129
   Serial number: 0000290409069  Dataset Number: 8W0909897E  0029
   Coding: 000F1B2000001080400000A0
ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
   VCID: 45D743BFE523BC427CD-8010
   Component: TSG HBFS      005 0129
   Serial number: 0000290409071  Dataset Number: 8W0909896E  0029
ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
   Part No SW: 4M0 907 594 H    HW: 4M0 907 594
   Component: SAD_STG_1     014 0005
   Dataset Number: 8W0909469D  0009
   Coding: 2A8000049100
   ROD: EV_SunRoofCONTIAU736_006.rod
   VCID: 3B23254793E7FAB21A9-806E
Address CF: Lane Chge Asst 2 (J770)       Labels: None
   Part No SW: 4M0 907 590 D    HW: 4M0 907 590
   Revision: --------
   Coding: 0E8002
   ASAM Dataset: EV_RearRadarS2BoschAU736 001022
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   Dataset Number: 8W0909471C  0008
   VCID: 1675D4F3C805C7DAC57-8042
   Component: LED1R         H09 0003
   Dataset Number: 8W0909472C  0008
End----------(Elapsed Time: 02:05, VBatt start/end: 13.1V/13.1V)-----------
MasterTommy
Amsterdam
C?ID=295586
I tried this with my Tiguan.
I never got it working with the USB-C variant where both connectors are part of a single unit with a HSD and a normal connector on the back. However, my factory USB-A ports were one unit for each port with a HSD connector on the back. I swapped them out for a USB-C version and that did work. I’ll have to look up the part no.
Only downside is the trim still has a rectangular cutout instead of an oval one.
gramsca
Phoenix, AZ, USA
C?ID=492771
Aha. It looks like I'll be returning the module then...
If you end up finding that part number, let me know. If it doesn't look too odd with the rectangular cutout I might opt for that.
MasterTommy
Amsterdam
C?ID=295586
Suddenly remembered my participation in this topic. My apologies for the extremely late reply!
The USB-C sockets that slid right in place of the old USB-A ones have the part number 3G5 035 726.
The original sockets were 5Q0 035 726. They have a HSD connection on the back, color code green.
If your original two USB-A sockets are two separate parts with part no. 5Q0 035 726 and have a green HSD connector on the back, the 3G5 035 726 will slide right in.
If your original sockets have a different part number, do not have a green HSD socket on the back, or if your car has the sockets as an integrated parts of a single unit, then these will not fit.
