Error with Lane Assist - 2008 VW Touareg
ColumbusCC
C?ID=111555
I recently installed Lane assist to my Touareg but having errors. I'm thinking maybe the slave module 2 is defective or not working. The master and the slave both show up on the scan with the part number etc, and based on searching it appears the coding is correct. Can anyone give insight if this points to a bad module. I bought it used but they said it was working. I'll post my log below. I ran through the output tests and everything lights up as far as the mirrors etc and i know I have the wiring correct.
Ignore the errors under 13 - ACC, it's working fine, I cleared out all the errors and that one cleared but i can't get the 3C channel to clear the 4 errors. My radio and backup camera have errors bc I have an aftermarket android unit.
Monday,24,August,2015,18:20:59:34364
VCDS Version: 15.7.0.1
Data version: 20150729
VIN: WVGMB77L98D037276   License Plate: LANE ASSIST
Mileage: 142310km-88427mi   Repair Order:
Chassis Type: 7L (6N0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 22 34 36 3C 46 47 55 56 65
          68 69 6C 6D 6E 76
VIN: WVGMB77L98D037276   Mileage: 142310km-88427miles
68-Wiper Electr. -- Status: OK 0000
6E-Ctrl Head Roof -- Status: OK 0000
   Part No SW: 7L0 907 560 E    HW: 7L0 907 560 E
   Component: 4.2l V8/4V          0030
   Revision: 79H02---    Serial number: VWX3Z0G2670466
   Coding: 04210009590F0E60
   Shop #: WSC 31414 790 00001
   VCID: 336FF76E51B354A69B-5102
No Faults Found
Address 02: Auto Trans        Labels: 09D-927-750.lbl
   Part No SW: 09D 927 750 GE    HW: 09D 927 750 GE
   Component: AL 750 6A           1092
   Revision: 00H61000    Serial number:
   Coding: 0004200
   VCID: 77F7037E054B788667-5102
No Faults Found
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25E1.clb
   Part No SW: 7L0 907 379 K    HW: 7L0 907 379 K
   Component: ESP ALLRAD MK25E1   0302
   Revision: 00H53001
   Coding: 0006530
   VCID: 4183ADA61C0FF63619-8014
Address 05: Acc/Start Auth.        Labels: None
   Part No SW: 7L0 909 135 B    HW: 5WK 485 16
   Component:    Kessy            6840
   Revision: 68406620    Serial number: VWX3Z0G2670466
   Coding: 0000232
   VCID: 3065F862A7A56FBEE6-8064
Address 08: Auto HVAC        Labels: 7L6-907-040.clb
   Part No: 7L6 907 040 AF
   Component: CLIMAtronic R/L     4331
   Coding: 0021030
   VCID: 74ED3472133D139E42-8020
Address 09: Cent. Elect.        Labels: 7Lx-937-049-V2.clb
   Part No SW: 7L6 937 049 AF    HW: 7L6 937 049 AF
   Component: J519                2001
   Revision: -0004---    Serial number: --------------
   Coding: 220008002F243C000000000000000000
   VCID: 000568A257853F3E56-8054
Address 13: Auto Dist. Reg        Labels: None
   Part No SW: 7L6 907 567     HW: 7L6 907 567
   Component: AC201  NAR 1    030 0363
   Revision: 00030000    Serial number: 00000000005694
   Coding: 0020000
   Shop #: WSC 12345 254 39265
   VCID: 7BFF1F4E3E635CE603-802E
51593 - Unknown Error Code
            Unknown - 004 -  - Intermittent
                    Reset counter: 226
                    Mileage: 141758 km
                    Date: 2015.08.11
                    Time: 13:50:58
                    Count: 31
Address 15: Airbags        Labels: 7L0-959-655.lbl
   Part No SW: 7L0 959 655     HW: 7L0 959 655
   Component: J234  3A VW8T       0250
   Revision: 92011025    Serial number: 0039P0030T0Q
   Coding: 0013121
   VCID: 7AF11A4A315965EE18-802E
   Subsystem 1 - Part No: 7L0 959 339 F
   Component: BF-Gewichtsens. 007 0010
   Subsystem 2 - Serial number: 3N89N
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 G
   Component: Lenksaeulenmodul    X090
   Coding: 0001021
   VCID: 438FA7AE0613E4260B-8016
Address 17: Instruments        Labels: 7L6-920-xxx-7L6.lbl
   Part No SW: 7L6 920 990     HW: 7L6 920 990
   Component: J285 KOMBI-INST.    7520
   Revision: KHH06V02
   Coding: 0005201
   Shop #: WSC 23312 444 85738
   VCID: 76E90E7A0141018E7C-8022
01304 - Radio
                    Reset counter: 250
                    Mileage: 142304 km
                    Date: 2015.08.24
                    Time: 13:58:50
Address 19: CAN Gateway        Labels: 6N0-909-901-7L.clb
   Part No SW: 6N0 909 901     HW: 7L6 920 990
   Component: J533  GW-K-CAN TP20 7520
   Coding: FFE6FFDB43046002
   VCID: 70E5386263252FBEA6-8024
01304 - Radio
                    Reset counter: 250
                    Mileage: 142304 km
                    Date: 2015.08.24
                    Time: 13:58:50
   Part No: 0AD 927 755 BG
   Component: TRANSFERCASE        0126
   VCID: 01036DA65B8F363659-5102
Address 34: Level Control        Labels: 7Lx-907-553-34.clb
   Part No: 7L0 907 553 J
   Component: LUFTFDR.-CDC- 3C3P1 3125
   Coding: 0015521
   VCID: 3A71DA4A71D9A5EE58-806E
   Part No: 7L0 959 760
   Component: Sitzverstellung     0702
   VCID: 77F7037E024B788667-8022
   Part No SW: 7L6 907 566 B    HW: 7L6 907 566 A
   Component: J0769_SWA_MasterH09 0070
   Revision: 00H09000    Serial number: 6PZ 009 014-01
   Coding: 0010151
   VCID: 3C7DDC527BED9BDE4A-8068
   Subsystem 1 - Part No: 7L6 907 568 B
   Component: J0770_SWA_Slave_H08 0070
   Subsystem 2 - Serial number: 6PZ 009 014-21
   Subsystem 3 - Serial number: 3F05.11.0700H0800000010178�
   Subsystem 4 - Serial number: 010178�
16358 - Control Module - External RAM Error; CPU 2
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 8
                    Mileage: 142 km
                    Date: 2007.07.04
                    Time: 00:00:11
16364 - Control Module - Programming Error; CPU 2
            014 - Defective
                    Reset counter: 8
                    Mileage: 142 km
                    Date: 2007.07.04
                    Time: 00:00:11
16366 - Control Module - Internal Malfunction; CPU 2
            014 - Defective
                    Reset counter: 8
                    Mileage: 142 km
                    Date: 2007.07.04
                    Time: 00:00:12
16365 - Control Module - Electrical Error; CPU 2
            014 - Defective
                    Reset counter: 8
                    Mileage: 142 km
                    Date: 2007.07.04
                    Time: 00:00:12
Address 46: Central Conv.        Labels: 7L0-959-933.lbl
   Part No: 7L6 959 933
   Component: 13 HSG              7124
   Coding: 0000085
   VCID: 7F07EB5E2D7B40C62F-4ACE
   Subsystem 1 - Part No: 7L0 959 701 N
   Component: Tuersteuergeraet FS 6302
   Subsystem 2 - Part No: 7L0 959 702 N
   Component: Tuersteuergeraet BF 6302
   Subsystem 3 - Part No: 7L0 959 703 C
   Component: Tuersteuergeraet HL 0201
   Subsystem 4 - Part No: 7L0 959 704 C
   Component: Tuersteuergeraet HR 0201
   Part No SW: 7L6 035 456 B    HW: 7L6 035 456 B
   Component: 08K Audioverst.     0008
   Revision: 00006000    Serial number: 00000008124018
   VCID: 3261F26AADA95DAE90-8066
Address 55: Headlight Range        Labels: 7L6-907-357-A.lbl
   Part No SW: 7L6 907 357 A    HW: 7L6 907 357 A
   Component: AFS-Steuergeraet    0001
   Revision:   H02       Serial number:
   Coding: 1288387
   VCID: 3973C54674DFAEF651-806C
   Component: AFS-Lst.-Modul l    X008
   Coding: 00000019
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    X008
   Coding: 00000019
Address 56: Radio
Address 65: Tire Pressure        Labels: 7L6-907-273.lbl
   Part No SW: 7L6 907 273 E    HW: 7L6 907 273 E
   Component: J0502 RDK           0006
   Revision: 00004006    Serial number: 00000600008725
   Coding: 0740006B6B0000000000000000
   Shop #: WSC 94516 937 100524
Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
   Part No: 7L6 955 119 B
   Component: J400__ Front Wiper  5301
   Coding: 0001397
   VCID: 3973C54670DFAEF651-806C
   Component: RLS     141007 046  0204
   Coding: 00208933
   Shop #: WSC 31414
Address 69: Trailer        Labels: 7L0-907-383-1D2.lbl
   Part No SW: 7L0 907 383 G    HW: 7L0 907 383 G
   Component: ANHAENGERELEKTRONIK 8854
   Coding: 0000002
   VCID: 3875C0424FD5B7FEAE-806C
   Part No SW: 7L6 907 441 C    HW: 7L6 907 441 C
   Component: J772__Rearview      0021
   Revision: 00H13000    Serial number:    PA8 J7X0067
   Coding: 0110001
   VCID: 356BC9765CC74A96B5-8060
03006 - Back-up Camera System not calibrated
            000 -  -
                    Reset counter: 210
                        Invalid
                        Invalid
                        Invalid
02203 - Audio / Video Input 1
                    Reset counter: 210
                    Mileage: 142319 km
                    Date: 2015.08.24
                    Time: 18:07:16
                        Reverse OFF
                    Count: 3
Address 6D: Trunk Elect.        Labels: Redir Fail!
   Part No SW: 7L6 959 107 A    HW: 7L6 959 107 A
   Component: J605  HECKKLAPPE    1210
   Revision: --H05---    Serial number: --------021960
   Coding: 0122110
                    Reset counter: 249
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
                    Reset counter: 249
Address 6E: Ctrl Head Roof        Labels: 7L6-919-044.lbl
   Part No SW: 7L6 919 044 Q    HW: 7L6 919 044 Q
   Component: J702  Dachdisplay   0400
   Revision: --30004S    Serial number: 00000000041626
   VCID: 458BB9B60C27DA1625-8010
   Part No: 7L0 919 283 F
   Component: 0E Einparkhilfe     1107
End-------------------------(Elapsed Time: 05:16)--------------------------
Columbus: Hi. I tried to help a friend out with a similar issue (different error messages). In the end, we couldn't fix the problem, but here's a few suggestions for you to think-about (based on our failed attempts):
Have you checked the cabling in the looms from the two control units (J669 & J770) to the front of the vehicle ?
We learnt that lots of things need to be working correctly for lane assist to operate - including:
ABS control unit - provides speed signal
Instrument control unit - needed to display activation lamp
CAN Gateway (J533) - necessary for relaying data bus information
BCM (J519) - controls the operation for turn signals
Trailer detect control unit (J345) - deactivates lane assist when trailer is connected
Wiper unit (J400) -provides the Light Sensor signal for adjustment to the lane-assist warning lights
Start Auth control unit (J518) - remote key signal​
Plus, we discovered that lane-assist is integrated deeply into the Powertrain CAN bus (for ABS and Airbag), the Convenience CAN bus (for Start Auth, BCM, Steering column and Trailer detect) and the Infotainment CAN bus (for wiper/RLS).​
Your error messages for 3C look odd - fault frequency =1, mileage 142 km and date: 2007.07.04.
Spacewalker
Poland
C?ID=159607
Coding: 0010151
014 - Defective
Reset counter: 8
Mileage: 142 km
Date: 2007.07.04
Time: 00:00:11
014 - Defective
Reset counter: 8
Mileage: 142 km
Date: 2007.07.04
Time: 00:00:11
014 - Defective
Reset counter: 8
Mileage: 142 km
Date: 2007.07.04
Time: 00:00:12
014 - Defective
Reset counter: 8
Mileage: 142 km
Date: 2007.07.04
Time: 00:00:12
Look like Hardware issue .
I will leave alone wire
connect in on the bench and try diagnose .
ColumbusCC
C?ID=111555
Im going to take the bumper off and swap the modules to see if anything changes and if it follows the module. CPU 2 i assume is the slave, but on some audi forums it says its the main master one. All the wiring seemed fine to me, i'll double check but the test in the VCDS all worked fine, CAN showed up fine. Below is where i wired everything. Seemed to be correct based on ELSA.
Pin 1 - Power wire to fuse 48 driver side dash
Pin 2 - Can Low to Pin 9 on green cluster plug (same pins as the ACC CAN wires)
Pin 3 - Can High to Pin 8 on green cluster plug (same pins as the ACC CAN wires)
Pin 4 - goes to driver side blue wire on the new 4-pin mirror connector
Pin 5 - goes to the passenger side blue wire on the new 4 pin mirror connector
Pin 6 - Goes to both mirrors to the red wire on the 4 pin connector (i connected both driver side and passenger side red wires together, then ran one wire to the back, they both share the same pin)
Pin 7 - Ground wherever you want
Pins 8,9,10 blank
ColumbusCC
C?ID=111555
when you say hardwire issue you mean i have something wired wrong possibly?
Spacewalker
Poland
C?ID=159607
internal error
hardware inside module
might be itself, or after lq damage
7L6 907 566 B is a MASTER
7L6 907 568 B is a SLAVE
you can simple disconnect SLAVE to look if error apear in MASTER
Mileage: 142 km
might be after wrong / failed SW update
but distance 142km ... I am sure your one is much much higher now
Maybe VW can reflash module, ask local dealer
SW 0070 is a latest one
ColumbusCC
C?ID=111555
OK thanks for clarification. I tried to troubleshoot this morning and I think I narrowed it down to the master. I unplugged the slave and still same 4 errors came up and the slave just didn't show on the VCDS as extra module. I'm thinking you are right since the 142 KM, it must be defective from the start. I'll try to call the dealer and see what they think but it might be cheaper for me to just buy another one instead of pay the dealer and it doesn't work. I greatly appreciate the fast response. I will call dealer but i sent a few emails to people in Poland to see if they can send me a module. Its much cheaper there than here in the USA. Let alone next to impossible to find a module in the USA.
***Update**** I called dealer and they said $100 usd to look at it, so i'm going to just buy another one and see if that takes care of it.
ColumbusCC
C?ID=111555
Just an update, ordered a new master module and waiting for it to arrive. Ordered two actually just in case this time because It's always a long wait coming from Germany. Ordered 7L6 907 566 B and 7L6 907 566 C to see if either will work fine. Will post updates after it comes and I get it plugged in! Thanks for all the help on the forum so far! Great product with a great community! Thanks Ross Tech!
ColumbusCC
C?ID=111555
I wanted to post an update since my lane assist is now WORKING! The master module was defective that I first received. I returned it and ordered another one from a different seller in Poland. Plugged it in, ran through the output tests, and PERFECTION! It works perfect, no errors, no calibration messages. All is great. I took it for a test run and all went perfectly! I will attach my scan incase it would benefit someone in the future. I have now successfully Retrofitted the "Safety Package" that was offered on the 2008 Touaregs. Adaptive Cruiser Control with Front Assist and Side Assist/Lane Change Assist.
Thanks again for everyone's help on this issue!
Thursday,03,September,2015,12:30:04:34364
VIN: WVGMB77L98D037276   License Plate: SIDE_ASSIST_FINAL
Mileage: 142530km-88564mi   Repair Order:
          68 69 6C 6D 6E 76
VIN: WVGMB77L98D037276   Mileage: 142530km-88564miles
   Coding: 0004200
   Revision: 00H53001
   Coding: 0006530
   Coding: 0000232
   Coding: 0021030
   Component: AC201  RDW 1    030 0363
   Coding: 0010000
   Shop #: WSC 119091 028 81798
   Coding: 0013121
   Coding: 0001021
   Revision: KHH06V02
   Coding: 0005201
   Coding: 0015521
   Coding: 0010151
   Shop #: WSC 14580 666 30328
   Coding: 0000085
   VCID: 7F07EB5E2D7B40C62F-4AE6
   Coding: 1288387
   Coding: 00000019
   Coding: 00000019
Address 56: Radio
   Coding: 0001397
   Coding: 00208933
   Shop #: WSC 31414
   Coding: 0000002
   Coding: 0110001
            000 -  -
                    Reset counter: 211
                        Invalid
                        Invalid
                        Invalid
                    Reset counter: 211
                    Mileage: 142339 km
                    Date: 2015.08.25
                    Time: 08:23:36
                        Reverse OFF
                    Count: 3
   Coding: 0122110
End-------------------------(Elapsed Time: 04:43)--------------------------
